  4. Fehler in host.raspberryPi
36 Beiträge 3 Kommentatoren 4.2k Aufrufe 2 Beobachtet
  • werner2000xW werner2000x
    @thomas-braun Ich habe die Version 2.0
    @werner2000x sagte in Fehler in host.raspberryPi:
    Kann eigentlich nicht sein. Das falsche parsing wurde da korrigiert.
    iob diag
    in der Langfassung liefert?
    werner2000xW 1 Antwort Letzte Antwort
      iob diag
      werner2000xW Offline
      werner2000x
      @thomas-braun Der Fehler ist noch da:
      2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) VALUE: 204796 POST: (rpi.swap_total - $1)/1024
      2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.swap.swap_used VALUE = 0
      2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) CURRENT = temperature true
      2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) -1
      2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) ---> POST: $1/1000 for soc_temp in [object Object]
      2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) VALUE: 66218 POST: $1/1000
      2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.temperature.soc_temp VALUE = 66.22
      2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) CURRENT = uptime true
      2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) -1
      2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) ---> POST: for uptime in [object Object]
      2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.uptime.uptime VALUE = 1511
      2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) CURRENT = wlan true
      2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) -1
      2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) ---> POST: $1*-1 for wifi_received in [object Object]
      2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) VALUE: 0 POST: $1*-1
      2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.wlan.wifi_received VALUE = 0
      2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) ---> POST: for wifi_send in [object Object]
      2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.wlan.wifi_send VALUE = 0
      2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) CURRENT = gpios undefined
      2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) -1
      2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) CURRENT = inputPullUp undefined
      2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) -1
      2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = inputDebounceMs undefined
      2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonPullUp undefined
      2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonDebounceMs undefined
      2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonPressMs undefined
      2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) -1
      2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) CURRENT = buttonDoubleMs undefined
      2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) CURRENT = dhtPollInterval undefined
      2024-09-19 11:54:11.197 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.cpu_frequency found state = {"val":1800,"ack":true,"ts":1726739651194,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739427963}
      2024-09-19 11:54:11.239 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load1 found state = {"val":0.7,"ack":true,"ts":1726739651236,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651236}
      2024-09-19 11:54:11.241 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load5 found state = {"val":0.61,"ack":true,"ts":1726739651236,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651236}
      2024-09-19 11:54:11.244 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load15 found state = {"val":0.82,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
      2024-09-19 11:54:11.245 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.scaling_governor found state = {"val":"ondemand","ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972151}
      2024-09-19 11:54:11.247 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.cpu_voltage found state = {"val":0.92,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739427964}
      2024-09-19 11:54:11.251 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.mem_arm found state = {"val":948,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310982794}
      2024-09-19 11:54:11.252 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.mem_gpu found state = {"val":76,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310982794}
      2024-09-19 11:54:11.254 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_total found state = {"val":7809.97,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972151}
      2024-09-19 11:54:11.256 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_free found state = {"val":4582.61,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
      2024-09-19 11:54:11.259 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_available found state = {"val":5839.04,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
      2024-09-19 11:54:11.260 - debug: rpi2.0 (4899) stateChange for rpi2.0.network.net_received found state = {"val":-195147982,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
      2024-09-19 11:54:11.262 - debug: rpi2.0 (4899) stateChange for rpi2.0.network.net_send found state = {"val":45400627,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
      2024-09-19 11:54:11.264 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_root_total found state = {"val":119529.39,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972153}
      2024-09-19 11:54:11.265 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_boot_total found state = {"val":null,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
      2024-09-19 11:54:11.267 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_root_used found state = {"val":13036.82,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
      2024-09-19 11:54:11.269 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_boot_used found state = {"val":null,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
      2024-09-19 11:54:11.276 - debug: rpi2.0 (4899) stateChange for rpi2.0.swap.swap_total found state = {"val":200,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972163}
      2024-09-19 11:54:11.277 - debug: rpi2.0 (4899) stateChange for rpi2.0.swap.swap_used found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972164}
      2024-09-19 11:54:11.279 - debug: rpi2.0 (4899) stateChange for rpi2.0.temperature.soc_temp found state = {"val":66.22,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651238}
      2024-09-19 11:54:11.281 - debug: rpi2.0 (4899) stateChange for rpi2.0.uptime.uptime found state = {"val":1511,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651238}
      2024-09-19 11:54:11.283 - debug: rpi2.0 (4899) stateChange for rpi2.0.wlan.wifi_received found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972164}
      2024-09-19 11:54:11.284 - debug: rpi2.0 (4899) stateChange for rpi2.0.wlan.wifi_send found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972226}
      Raspi4 8 GB mit Aqara Zigbee USB, iob
      Innogy Smarthome
      Bosch Bridge 2
      HUE Bridge
      OpenWB Wallbox mit EVU Kit
      Google Nest Pro Hub
      HA auf uGreen dxp4800
        @werner2000x
        Ich seh da keine Fehler der Art
        Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
        • werner2000xW Offline
          werner2000x
          @thomas-braun Der Log war zu kurz:
          pi2.0
          2024-09-19 12:19:10.905	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13321100 102843800 12% / /1024
          rpi2.0
          2024-09-19 12:19:10.904	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13321100 102843800 12% / /1024
          rpi2.0
          2024-09-19 12:18:10.928	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320888 102844012 12% / /1024
          rpi2.0
          2024-09-19 12:18:10.927	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320888 102844012 12% / /1024
          rpi2.0
          2024-09-19 12:17:10.907	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320584 102844316 12% / /1024
          rpi2.0
          2024-09-19 12:17:10.905	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320584 102844316 12% / /1024
          rpi2.0
          2024-09-19 12:16:10.904	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
          rpi2.0
          2024-09-19 12:16:10.903	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
          Innogy Smarthome
          Bosch Bridge 2
          HUE Bridge
          Google Nest Pro Hub
            pi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            @werner2000x
            cd /opt/iobroker
            npm ls
              @werner2000x
              cd /opt/iobroker
              npm ls
              werner2000x
              Ausgabe:
              :/opt/iobroker $ npm ls
              iobroker.inst@3.0.0 /opt/iobroker
              ├── @emnapi/runtime@1.2.0 extraneous
              ├── iobroker.admin@7.1.1
              ├── iobroker.alexa2@3.26.5
              ├── iobroker.alias-manager@1.2.6
              ├── iobroker.backitup@3.0.22
              ├── iobroker.ble@0.14.0
              ├── iobroker.bshb@0.2.8
              ├── iobroker.chromecast@3.4.1
              ├── iobroker.cloud@5.0.1
              ├── iobroker.daikin-cloud@0.4.8
              ├── iobroker.denon@1.15.12
              ├── iobroker.device-reminder@3.1.2
              ├── iobroker.discovery@5.0.0
              ├── iobroker.echarts@1.7.2
              ├── iobroker.email@1.3.1
              ├── iobroker.energiefluss@3.6.0
              ├── iobroker.flot@1.12.0
              ├── iobroker.fritzbox@0.6.0
              ├── iobroker.fritzdect@2.5.11
              ├── iobroker.heos@2.2.1
              ├── iobroker.history@3.0.1
              ├── iobroker.homeconnect@1.4.1
              ├── iobroker.hue@3.12.0
              ├── iobroker.ical@1.15.0
              ├── iobroker.icons-fatcow-hosting@0.1.0
              ├── iobroker.icons-icons8@0.0.1
              ├── iobroker.icons-material-png@0.1.0
              ├── iobroker.icons-mfd-svg@1.2.0
              ├── iobroker.influxdb@4.0.2
              ├── iobroker.innogy-smarthome@1.2.6
              ├── iobroker.iot@3.3.0
              ├── iobroker.iqontrol@2.3.0
              ├── iobroker.jarvis@3.1.8
              ├── iobroker.javascript@8.7.6
              ├── iobroker.js-controller@6.0.11
              ├── iobroker.lovelace@4.1.10
              ├── iobroker.material@1.3.1
              ├── iobroker.meross@1.17.0
              ├── iobroker.mqtt@5.2.0
              ├── iobroker.net-tools@1.0.11
              ├── iobroker.node-red@5.2.1
              ├── iobroker.openweathermap@1.1.2
              ├── iobroker.parser@2.2.2
              ├── iobroker.pushover@4.1.0
              ├── iobroker.pvforecast@3.0.0
              ├── iobroker.ring@5.1.0
              ├── iobroker.rpi2@1.3.2
              ├── iobroker.simple-api@2.8.0
              ├── iobroker.socketio@6.7.1
              ├── iobroker.systeminfo@1.2.0
              ├── iobroker.text2command@3.0.3
              ├── iobroker.tr-064@4.3.0
              ├── iobroker.trashschedule@3.3.0
              ├── iobroker.tuya@3.16.0
              ├── iobroker.vis-2-widgets-energy@1.0.0
              ├── iobroker.vis-2-widgets-gauges@1.1.0
              ├── iobroker.vis-2-widgets-material@1.4.8
              ├── iobroker.vis-2@2.9.32
              ├── iobroker.vis-bars@0.1.4
              ├── iobroker.vis-canvas-gauges@1.0.1
              ├── iobroker.vis-colorpicker@2.0.3
              ├── iobroker.vis-fancyswitch@1.1.0
              ├── iobroker.vis-history@1.0.0
              ├── iobroker.vis-hqwidgets@1.5.1
              ├── iobroker.vis-icontwo@1.5.0
              ├── iobroker.vis-inventwo@3.3.4
              ├── iobroker.vis-jqui-mfd@1.1.1
              ├── iobroker.vis-justgage@2.1.7
              ├── iobroker.vis-map@1.1.2
              ├── iobroker.vis-material-advanced@1.7.4
              ├── iobroker.vis-material@0.1.3
              ├── iobroker.vis-materialdesign@0.5.9
              ├── iobroker.vis-metro@1.2.0
              ├── iobroker.vis-timeandweather@1.2.2
              ├── iobroker.vis@1.5.6
              ├── iobroker.web@6.2.5
              └── iobroker.ws@2.6.2
              pi@raspberrypi:/opt/iobroker $
              Innogy Smarthome
              Bosch Bridge 2
              HUE Bridge
              Google Nest Pro Hub
                Ausgabe:
                werner2000x
                @werner2000x Heute immer noch der selbe Fehler:
                rpi2.0
                2024-09-20 17:49:56.547	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13640780 102524120 12% / /1024
                rpi2.0
                2024-09-20 17:49:56.535	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13640780 102524120 12% / /1024
                rpi2.0
                2024-09-20 17:48:56.304	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
                rpi2.0
                2024-09-20 17:48:56.302	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on/dev/mmcblk0p2 122398100 13640584 102524316 12% //1024
                Innogy Smarthome
                Bosch Bridge 2
                HUE Bridge
                Google Nest Pro Hub
                  rpi2.0
                  rpi2.0
                  rpi2.0
                  rpi2.0
                  @werner2000x
                  Natürlich. Weil das erst in Version 2.0.0 behoben ist, du aber diese einsetzt:
                  iobroker.rpi2@1.3.2
                    @werner2000x
                    iobroker.rpi2@1.3.2
                    werner2000x
                    @thomas-braun wie bekomme ich den rpi 2.0 denn, im beta Modus sehe ich den auch nicht
                    Innogy Smarthome
                    Bosch Bridge 2
                    HUE Bridge
                    Google Nest Pro Hub
                      @werner2000x
                      rpi2
                      github:	2.0.0-alpha.3
                      latest:	2.0.0 for 88 days
                      stable:	1.3.2 for 31 months
                      Alles da.
                        HomoranH Offline
                        HomoranH Offline
                        hast du einen Refresh der Adapterliste gemacht, nachdem du das Repo umgestellt hast?
                          werner2000x
                          @homoran Danke für den Tipp. Ein Refresh zeigte nun den rpi 2.0. :-)
                          Innogy Smarthome
                          Bosch Bridge 2
                          HUE Bridge
                          Google Nest Pro Hub
