NUC-Proxmox-steigender Ram
Steigt wieder :-(
top - 19:07:04 up 2:05, 1 user, load average: 0.08, 0.09, 0.04 Tasks: 19 total, 1 running, 18 sleeping, 0 stopped, 0 zombie %Cpu(s): 5.9 us, 1.2 sy, 0.0 ni, 92.7 id, 0.0 wa, 0.0 hi, 0.1 si, 0.0 st MiB Mem : 7096.0 total, 5087.6 free, 1800.3 used, 208.2 buff/cache MiB Swap: 512.0 total, 512.0 free, 0.0 used. 5295.7 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 441 iobroker 20 0 22.7g 1.6g 51200 S 20.7 22.8 2:22.49 io.admin.0 129 iobroker 20 0 21.4g 203716 44416 S 0.0 2.8 0:31.70 iobroker.js-con 348 iobroker 20 0 21.0g 85976 49152 S 0.0 1.2 0:05.20 io.backitup.0 55 root 20 0 49636 15488 14720 S 0.0 0.2 0:00.13 systemd-journal 1 root 20 0 167760 11648 8832 S 0.0 0.2 0:00.40 systemd 135 root 20 0 15432 9216 7936 S 0.0 0.1 0:00.01 sshd 96 systemd+ 20 0 17892 8320 7296 S 0.0 0.1 0:00.10 systemd-network 111 root 20 0 16572 7552 6656 S 0.0 0.1 0:00.09 systemd-logind 566 postfix 20 0 43044 7040 6400 S 0.0 0.1 0:00.00 pickup 298 postfix 20 0 43088 6912 6272 S 0.0 0.1 0:00.00 qmgr 108 message+ 20 0 9120 4608 4224 S 0.0 0.1 0:00.03 dbus-daemon 567 dirk 20 0 8572 4608 2688 R 0.0 0.1 0:00.00 top 296 root 20 0 42660 4376 3840 S 0.0 0.1 0:00.02 master 367 dirk 20 0 5224 4352 2816 S 0.0 0.1 0:00.02 bash 133 root 20 0 6112 3948 3456 S 0.0 0.1 0:00.07 login 87 _rpc 20 0 7880 3840 3456 S 0.0 0.1 0:00.01 rpcbind 106 root 20 0 3600 2048 1920 S 0.0 0.0 0:00.01 cron 132 root 20 0 2516 1408 1408 S 0.0 0.0 0:00.00 agetty 134 root 20 0 2516 1408 1408 S 0.0 0.0 0:00.00 agetty -
Steigt wieder :-(
Die Idee hatte ich auch gerade. Doch ich logge und es stehen Meldungen drin, die ich aber nicht deuten kann
admin.0 2024-09-19 22:13:51.437 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 22:13:46.672 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 22:13:46.671 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 22:13:46.538 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 22:13:46.400 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 22:13:46.399 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 22:13:45.123 debug Subscribes: dummy admin.0 2024-09-19 22:13:45.121 debug 2024-09-19T20:13:45.121Z Request authenticate [system.user.admin] admin.0 2024-09-19 22:13:45.118 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 22:13:44.216 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 22:13:44.215 debug Disable logging, because no one socket connected admin.0 2024-09-19 19:07:21.407 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.406 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.405 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.402 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.402 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.400 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.399 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.396 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-19 19:07:21.393 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-19 19:07:21.393 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-19 19:07:21.391 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-19 19:07:21.390 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-19 19:07:21.390 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-19 19:07:21.389 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-19 17:56:17.180 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:56:12.243 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:56:12.238 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 17:56:12.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:56:12.165 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 17:56:12.163 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 17:56:11.102 debug Subscribes: dummy admin.0 2024-09-19 17:56:11.099 debug 2024-09-19T15:56:11.099Z Request authenticate [system.user.admin] admin.0 2024-09-19 17:56:11.097 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:56:10.424 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 17:56:10.424 debug Disable logging, because no one socket connected admin.0 2024-09-19 17:56:10.416 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:56:10.328 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 17:56:10.327 debug Disable logging, because no one socket connected admin.0 2024-09-19 17:46:41.996 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:46:41.996 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-19 17:46:41.995 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.995 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.992 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.989 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.989 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.166 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.166 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.163 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.163 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.162 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.157 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:40.157 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-19 17:46:40.155 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-19 17:46:40.155 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-19 17:46:40.154 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-19 17:46:40.153 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-19 17:46:40.153 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-19 17:46:40.151 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-19 17:46:40.151 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-19 17:46:40.150 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-19 17:45:58.501 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:45:58.500 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-19 17:45:58.500 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.498 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.493 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.493 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.491 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:44:34.216 debug Next repo update on 9/20/2024, 5:44:34 PM admin.0 2024-09-19 17:44:34.182 info Repository received successfully. admin.0 2024-09-19 17:44:32.007 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:44:31.997 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } host.ioB-Test 2024-09-19 17:44:31.966 info Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 17:44:31.530 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 17:44:31.530 debug Subscribes: dummy admin.0 2024-09-19 17:44:31.523 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:44:31.307 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 17:44:31.307 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:44:31.306 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 17:44:31.306 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning -
admin.0 2024-09-19 22:13:51.437 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 22:13:46.672 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 22:13:46.671 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 22:13:46.538 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 22:13:46.400 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 22:13:46.399 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 22:13:45.123 debug Subscribes: dummy admin.0 2024-09-19 22:13:45.121 debug 2024-09-19T20:13:45.121Z Request authenticate [system.user.admin] admin.0 2024-09-19 22:13:45.118 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 22:13:44.216 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 22:13:44.215 debug Disable logging, because no one socket connected admin.0 2024-09-19 19:07:21.407 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.406 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.405 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.402 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.402 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.400 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.399 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.396 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-19 19:07:21.393 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-19 19:07:21.393 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-19 19:07:21.391 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-19 19:07:21.390 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-19 19:07:21.390 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-19 19:07:21.389 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-19 17:56:17.180 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:56:12.243 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:56:12.238 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 17:56:12.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:56:12.165 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 17:56:12.163 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 17:56:11.102 debug Subscribes: dummy admin.0 2024-09-19 17:56:11.099 debug 2024-09-19T15:56:11.099Z Request authenticate [system.user.admin] admin.0 2024-09-19 17:56:11.097 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:56:10.424 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 17:56:10.424 debug Disable logging, because no one socket connected admin.0 2024-09-19 17:56:10.416 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:56:10.328 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 17:56:10.327 debug Disable logging, because no one socket connected admin.0 2024-09-19 17:46:41.996 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:46:41.996 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-19 17:46:41.995 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.995 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.992 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.989 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.989 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.166 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.166 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.163 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.163 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.162 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.157 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:40.157 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-19 17:46:40.155 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-19 17:46:40.155 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-19 17:46:40.154 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-19 17:46:40.153 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-19 17:46:40.153 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-19 17:46:40.151 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-19 17:46:40.151 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-19 17:46:40.150 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-19 17:45:58.501 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:45:58.500 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-19 17:45:58.500 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.498 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.493 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.493 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.491 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:44:34.216 debug Next repo update on 9/20/2024, 5:44:34 PM admin.0 2024-09-19 17:44:34.182 info Repository received successfully. admin.0 2024-09-19 17:44:32.007 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:44:31.997 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } host.ioB-Test 2024-09-19 17:44:31.966 info Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 17:44:31.530 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 17:44:31.530 debug Subscribes: dummy admin.0 2024-09-19 17:44:31.523 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:44:31.307 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 17:44:31.307 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:44:31.306 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 17:44:31.306 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning@marko67
Nur eine fixe Idee: Was passsiert, wenn Du den Discovery-Adapter deinstallierst und den Container neu startest?
Den braucht ja eh kein Mensch ;-) -
@marko67
Den braucht ja eh kein Mensch ;-)Adapter Discovery vor ca. 1 Std. über die Konsole gelöscht und Container neu gestartet. Und immer wieder taucht der Discovery in den Logs auf.
backitup.0 2024-09-20 00:21:07.479 info [iobroker] backup will be activated at 02:48 every 1 day(s) backitup.0 2024-09-20 00:21:07.436 info starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11 admin.0 2024-09-20 00:21:06.792 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.776 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.776 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.775 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.775 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.771 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.742 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.731 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.701 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:21:06.701 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:21:06.698 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:21:06.698 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:21:06.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:21:06.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:21:06.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive admin.0 2024-09-20 00:21:06.695 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension admin.0 2024-09-20 00:21:06.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection admin.0 2024-09-20 00:21:06.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.691 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.675 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.668 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.667 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.666 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.675 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.668 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.667 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.666 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.655 info ==> Connected system.user.admin from ::ffff:192.168.1.35 host.ioB-Test 2024-09-20 00:21:06.164 info instance system.adapter.backitup.0 in version "3.0.22" started with pid 348 admin.0 2024-09-20 00:21:06.101 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:06.100 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.823 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:04.805 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:04.803 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.785 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.502 info Use link "http://127.0.0.1:8081" to configure. admin.0 2024-09-20 00:21:04.502 info http server listening on port 8081 admin.0 2024-09-20 00:21:04.500 info socket.io server listening on port 8081 admin.0 2024-09-20 00:21:04.483 debug Next repo update on 9/20/2024, 5:44:32 PM admin.0 2024-09-20 00:21:04.249 debug Secure connection not enabled - using http createServer admin.0 2024-09-20 00:21:04.238 info received all objects admin.0 2024-09-20 00:21:03.805 info requesting all objects admin.0 2024-09-20 00:21:03.782 info starting. Version 7.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11 admin.0 2024-09-20 00:21:03.547 debug Plugin sentry Initialize Plugin (enabled=true) admin.0 2024-09-20 00:21:03.529 debug States connected to redis: 127.0.0.1:9000 admin.0 2024-09-20 00:21:03.522 debug States create User PubSub Client admin.0 2024-09-20 00:21:03.521 debug States create System PubSub Client admin.0 2024-09-20 00:21:03.517 debug Redis States: Use Redis connection: 127.0.0.1:9000 admin.0 2024-09-20 00:21:03.506 debug Objects connected to redis: 127.0.0.1:9001 admin.0 2024-09-20 00:21:03.501 debug Objects client initialize lua scripts admin.0 2024-09-20 00:21:03.487 debug Objects create User PubSub Client admin.0 2024-09-20 00:21:03.487 debug Objects create System PubSub Client admin.0 2024-09-20 00:21:03.485 debug Objects client ready ... initialize now admin.0 2024-09-20 00:21:03.464 debug Redis Objects: Use Redis connection: 127.0.0.1:9001 host.ioB-Test 2024-09-20 00:21:02.042 info Some obsolete host states deleted. host.ioB-Test 2024-09-20 00:21:02.039 info Delete state "system.host.ioB-Test.versions.npmNewestNext" host.ioB-Test 2024-09-20 00:21:02.034 info Delete state "system.host.ioB-Test.versions.npmNewest" host.ioB-Test 2024-09-20 00:21:02.030 info Delete state "system.host.ioB-Test.versions.npmCurrent" host.ioB-Test 2024-09-20 00:21:02.026 info Delete state "system.host.ioB-Test.versions.nodeNewestNext" host.ioB-Test 2024-09-20 00:21:01.993 info instance system.adapter.admin.0 in version "7.1.1" started with pid 307 host.ioB-Test 2024-09-20 00:21:01.980 info Delete state "system.host.ioB-Test.versions.nodeNewest" host.ioB-Test 2024-09-20 00:21:01.869 info Delete state "system.host.ioB-Test.versions.nodeCurrent" host.ioB-Test 2024-09-20 00:21:01.762 info starting 2 instances host.ioB-Test 2024-09-20 00:21:01.757 info 2 instances found host.ioB-Test 2024-09-20 00:21:01.377 info added notifications configuration of host host.ioB-Test 2024-09-20 00:21:01.362 info connected to Objects and States host.ioB-Test 2024-09-20 00:21:00.674 info ip addresses: 192.168.1.160 2a02:810c:1bf:f826:be24:11ff:feb1:1bd1 fe80::be24:11ff:feb1:1bd1 host.ioB-Test 2024-09-20 00:21:00.673 info hostname: ioB-Test, node: v20.17.0 host.ioB-Test 2024-09-20 00:21:00.673 info Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker host.ioB-Test 2024-09-20 00:21:00.669 info iobroker.js-controller version 6.0.11 js-controller starting host.ioB-Test 2024-09-20 00:20:50.697 info terminated host.ioB-Test 2024-09-20 00:20:50.560 info All instances are stopped. host.ioB-Test 2024-09-20 00:20:50.560 info instance system.adapter.admin.0 terminated with code 0 (NO_ERROR) host.ioB-Test 2024-09-20 00:20:50.469 info instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR) backitup.0 2024-09-20 00:20:50.384 info terminating admin.0 2024-09-20 00:20:50.383 info terminating backitup.0 2024-09-20 00:20:49.942 info Terminated (NO_ERROR): Without reason backitup.0 2024-09-20 00:20:49.941 info terminating admin.0 2024-09-20 00:20:49.902 info Terminated (NO_ERROR): Without reason admin.0 2024-09-20 00:20:49.901 debug Plugin sentry destroyed host.ioB-Test 2024-09-20 00:20:49.900 info stopInstance system.adapter.backitup.0 send kill signal admin.0 2024-09-20 00:20:49.899 info terminating host.ioB-Test 2024-09-20 00:20:49.899 info stopInstance system.adapter.admin.0 send kill signal backitup.0 2024-09-20 00:20:49.897 info Got terminate signal TERMINATE_YOURSELF admin.0 2024-09-20 00:20:49.897 info Got terminate signal TERMINATE_YOURSELF host.ioB-Test 2024-09-20 00:20:49.885 info stopInstance system.adapter.backitup.0 (force=false, process=true) host.ioB-Test 2024-09-20 00:20:49.885 info stopInstance system.adapter.admin.0 (force=false, process=true) backitup.0 2024-09-20 00:20:49.876 info cleaned everything up... admin.0 2024-09-20 00:20:49.876 info terminating http server on port 8081 host.ioB-Test 2024-09-20 00:20:49.875 info received SIGTERM admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.709 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.706 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.705 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.703 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.701 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:17:15.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:17:15.657 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:15.655 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.652 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.203 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.199 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList admin.0 2024-09-20 00:17:12.197 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson admin.0 2024-09-20 00:17:12.196 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId admin.0 2024-09-20 00:17:12.195 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected admin.0 2024-09-20 00:17:12.188 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.184 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.369 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.709 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.706 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.705 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.703 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.701 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:17:15.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:17:15.657 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:15.655 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.652 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.203 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.199 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList admin.0 2024-09-20 00:17:12.197 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson admin.0 2024-09-20 00:17:12.196 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId admin.0 2024-09-20 00:17:12.195 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected admin.0 2024-09-20 00:17:12.188 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.184 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.369 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.365 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.364 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:16:52.357 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:16:52.356 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:16:52.356 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:16:52.355 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:16:52.355 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:16:52.354 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed -
Die Idee hatte ich auch gerade. Doch ich logge und es stehen Meldungen drin, die ich aber nicht deuten kann
admin.0 2024-09-19 22:13:51.437 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 22:13:46.672 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 22:13:46.671 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 22:13:46.538 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 22:13:46.400 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 22:13:46.399 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 22:13:45.123 debug Subscribes: dummy admin.0 2024-09-19 22:13:45.121 debug 2024-09-19T20:13:45.121Z Request authenticate [system.user.admin] admin.0 2024-09-19 22:13:45.118 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 22:13:44.216 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 22:13:44.215 debug Disable logging, because no one socket connected admin.0 2024-09-19 19:07:21.407 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.406 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.405 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.404 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.402 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.402 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.401 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.400 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.399 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 19:07:21.396 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 19:07:21.395 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-19 19:07:21.394 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-19 19:07:21.393 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-19 19:07:21.393 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-19 19:07:21.391 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-19 19:07:21.390 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-19 19:07:21.390 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-19 19:07:21.389 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-19 17:56:17.180 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:56:12.243 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:56:12.238 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 17:56:12.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:56:12.165 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 17:56:12.163 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 17:56:11.102 debug Subscribes: dummy admin.0 2024-09-19 17:56:11.099 debug 2024-09-19T15:56:11.099Z Request authenticate [system.user.admin] admin.0 2024-09-19 17:56:11.097 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:56:10.424 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 17:56:10.424 debug Disable logging, because no one socket connected admin.0 2024-09-19 17:56:10.416 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:56:10.328 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-19 17:56:10.327 debug Disable logging, because no one socket connected admin.0 2024-09-19 17:46:41.996 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:46:41.996 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-19 17:46:41.995 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.995 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.992 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.991 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.990 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.989 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:41.989 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.169 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.167 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.166 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.166 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.163 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.163 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.162 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:46:40.157 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:46:40.157 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-19 17:46:40.156 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-19 17:46:40.155 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-19 17:46:40.155 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-19 17:46:40.154 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-19 17:46:40.153 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-19 17:46:40.153 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-19 17:46:40.151 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-19 17:46:40.151 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-19 17:46:40.150 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-19 17:45:58.501 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:45:58.500 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-19 17:45:58.500 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.499 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.498 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.494 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.493 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.493 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:45:58.491 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:44:34.216 debug Next repo update on 9/20/2024, 5:44:34 PM admin.0 2024-09-19 17:44:34.182 info Repository received successfully. admin.0 2024-09-19 17:44:32.007 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-19 17:44:31.997 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } host.ioB-Test 2024-09-19 17:44:31.966 info Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-19 17:44:31.531 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-19 17:44:31.530 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-19 17:44:31.530 debug Subscribes: dummy admin.0 2024-09-19 17:44:31.523 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-19 17:44:31.307 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-19 17:44:31.307 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-19 17:44:31.306 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-19 17:44:31.306 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning@marko67 Vllt hat z. B @foxriver76 eine Idee dazu
Adapter Discovery vor ca. 1 Std. über die Konsole gelöscht und Container neu gestartet. Und immer wieder taucht der Discovery in den Logs auf.
backitup.0 2024-09-20 00:21:07.479 info [iobroker] backup will be activated at 02:48 every 1 day(s) backitup.0 2024-09-20 00:21:07.436 info starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11 admin.0 2024-09-20 00:21:06.792 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.776 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.776 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.775 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.775 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.771 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.742 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.731 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.701 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:21:06.701 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:21:06.698 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:21:06.698 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:21:06.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:21:06.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:21:06.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive admin.0 2024-09-20 00:21:06.695 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension admin.0 2024-09-20 00:21:06.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection admin.0 2024-09-20 00:21:06.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.691 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.675 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.668 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.667 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.666 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.675 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.668 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.667 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.666 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.655 info ==> Connected system.user.admin from ::ffff:192.168.1.35 host.ioB-Test 2024-09-20 00:21:06.164 info instance system.adapter.backitup.0 in version "3.0.22" started with pid 348 admin.0 2024-09-20 00:21:06.101 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:06.100 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.823 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:04.805 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:04.803 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.785 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.502 info Use link "http://127.0.0.1:8081" to configure. admin.0 2024-09-20 00:21:04.502 info http server listening on port 8081 admin.0 2024-09-20 00:21:04.500 info socket.io server listening on port 8081 admin.0 2024-09-20 00:21:04.483 debug Next repo update on 9/20/2024, 5:44:32 PM admin.0 2024-09-20 00:21:04.249 debug Secure connection not enabled - using http createServer admin.0 2024-09-20 00:21:04.238 info received all objects admin.0 2024-09-20 00:21:03.805 info requesting all objects admin.0 2024-09-20 00:21:03.782 info starting. Version 7.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11 admin.0 2024-09-20 00:21:03.547 debug Plugin sentry Initialize Plugin (enabled=true) admin.0 2024-09-20 00:21:03.529 debug States connected to redis: 127.0.0.1:9000 admin.0 2024-09-20 00:21:03.522 debug States create User PubSub Client admin.0 2024-09-20 00:21:03.521 debug States create System PubSub Client admin.0 2024-09-20 00:21:03.517 debug Redis States: Use Redis connection: 127.0.0.1:9000 admin.0 2024-09-20 00:21:03.506 debug Objects connected to redis: 127.0.0.1:9001 admin.0 2024-09-20 00:21:03.501 debug Objects client initialize lua scripts admin.0 2024-09-20 00:21:03.487 debug Objects create User PubSub Client admin.0 2024-09-20 00:21:03.487 debug Objects create System PubSub Client admin.0 2024-09-20 00:21:03.485 debug Objects client ready ... initialize now admin.0 2024-09-20 00:21:03.464 debug Redis Objects: Use Redis connection: 127.0.0.1:9001 host.ioB-Test 2024-09-20 00:21:02.042 info Some obsolete host states deleted. host.ioB-Test 2024-09-20 00:21:02.039 info Delete state "system.host.ioB-Test.versions.npmNewestNext" host.ioB-Test 2024-09-20 00:21:02.034 info Delete state "system.host.ioB-Test.versions.npmNewest" host.ioB-Test 2024-09-20 00:21:02.030 info Delete state "system.host.ioB-Test.versions.npmCurrent" host.ioB-Test 2024-09-20 00:21:02.026 info Delete state "system.host.ioB-Test.versions.nodeNewestNext" host.ioB-Test 2024-09-20 00:21:01.993 info instance system.adapter.admin.0 in version "7.1.1" started with pid 307 host.ioB-Test 2024-09-20 00:21:01.980 info Delete state "system.host.ioB-Test.versions.nodeNewest" host.ioB-Test 2024-09-20 00:21:01.869 info Delete state "system.host.ioB-Test.versions.nodeCurrent" host.ioB-Test 2024-09-20 00:21:01.762 info starting 2 instances host.ioB-Test 2024-09-20 00:21:01.757 info 2 instances found host.ioB-Test 2024-09-20 00:21:01.377 info added notifications configuration of host host.ioB-Test 2024-09-20 00:21:01.362 info connected to Objects and States host.ioB-Test 2024-09-20 00:21:00.674 info ip addresses: 192.168.1.160 2a02:810c:1bf:f826:be24:11ff:feb1:1bd1 fe80::be24:11ff:feb1:1bd1 host.ioB-Test 2024-09-20 00:21:00.673 info hostname: ioB-Test, node: v20.17.0 host.ioB-Test 2024-09-20 00:21:00.673 info Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker host.ioB-Test 2024-09-20 00:21:00.669 info iobroker.js-controller version 6.0.11 js-controller starting host.ioB-Test 2024-09-20 00:20:50.697 info terminated host.ioB-Test 2024-09-20 00:20:50.560 info All instances are stopped. host.ioB-Test 2024-09-20 00:20:50.560 info instance system.adapter.admin.0 terminated with code 0 (NO_ERROR) host.ioB-Test 2024-09-20 00:20:50.469 info instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR) backitup.0 2024-09-20 00:20:50.384 info terminating admin.0 2024-09-20 00:20:50.383 info terminating backitup.0 2024-09-20 00:20:49.942 info Terminated (NO_ERROR): Without reason backitup.0 2024-09-20 00:20:49.941 info terminating admin.0 2024-09-20 00:20:49.902 info Terminated (NO_ERROR): Without reason admin.0 2024-09-20 00:20:49.901 debug Plugin sentry destroyed host.ioB-Test 2024-09-20 00:20:49.900 info stopInstance system.adapter.backitup.0 send kill signal admin.0 2024-09-20 00:20:49.899 info terminating host.ioB-Test 2024-09-20 00:20:49.899 info stopInstance system.adapter.admin.0 send kill signal backitup.0 2024-09-20 00:20:49.897 info Got terminate signal TERMINATE_YOURSELF admin.0 2024-09-20 00:20:49.897 info Got terminate signal TERMINATE_YOURSELF host.ioB-Test 2024-09-20 00:20:49.885 info stopInstance system.adapter.backitup.0 (force=false, process=true) host.ioB-Test 2024-09-20 00:20:49.885 info stopInstance system.adapter.admin.0 (force=false, process=true) backitup.0 2024-09-20 00:20:49.876 info cleaned everything up... admin.0 2024-09-20 00:20:49.876 info terminating http server on port 8081 host.ioB-Test 2024-09-20 00:20:49.875 info received SIGTERM admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.709 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.706 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.705 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.703 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.701 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:17:15.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:17:15.657 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:15.655 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.652 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.203 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.199 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList admin.0 2024-09-20 00:17:12.197 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson admin.0 2024-09-20 00:17:12.196 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId admin.0 2024-09-20 00:17:12.195 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected admin.0 2024-09-20 00:17:12.188 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.184 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.369 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.709 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.706 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.705 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.703 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.701 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:17:15.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:17:15.657 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:15.655 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.652 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.203 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.199 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList admin.0 2024-09-20 00:17:12.197 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson admin.0 2024-09-20 00:17:12.196 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId admin.0 2024-09-20 00:17:12.195 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected admin.0 2024-09-20 00:17:12.188 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.184 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.369 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.365 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.364 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:16:52.357 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:16:52.356 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:16:52.356 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:16:52.355 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:16:52.355 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:16:52.354 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed -
@marko67 hast du den admin absichtlich auf debug stehen?
@marko67 sagte in NUC-Proxmox-steigender Ram:
hier gab es schonmal so etwas
https://forum.iobroker.net/post/843911 -
https://forum.iobroker.net/post/843911@crunchip Hmm ... kriegte heute morgen ein Update auf Admin 7.1.1 ....
Heute nachmittag dann 7.1.2 ....
Denke aber nicht, dass da ein Zusammenhang besteht, trotzdem es merkwürdig ist, im Stable Repo für ein Modul zwei Updates an einem Tag zu bekommen ...
@martinp sagte in NUC-Proxmox-steigender Ram:
fixed host base settings dialog
Adapter Discovery vor ca. 1 Std. über die Konsole gelöscht und Container neu gestartet. Und immer wieder taucht der Discovery in den Logs auf.
backitup.0 2024-09-20 00:21:07.479 info [iobroker] backup will be activated at 02:48 every 1 day(s) backitup.0 2024-09-20 00:21:07.436 info starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11 admin.0 2024-09-20 00:21:06.792 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:21:06.780 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:21:06.779 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:21:06.778 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:21:06.777 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.776 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.776 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.775 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.775 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.771 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.742 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.731 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:21:06.701 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:21:06.701 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:21:06.700 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:21:06.699 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:21:06.698 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:21:06.698 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:21:06.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:21:06.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:21:06.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension, system.adapter.*.alive admin.0 2024-09-20 00:21:06.695 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection, admin.0.info.extension admin.0 2024-09-20 00:21:06.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected, admin.0.info.connection admin.0 2024-09-20 00:21:06.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive, system.adapter.admin.0.connected admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel, system.adapter.admin.0.alive admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.admin.0.logLevel admin.0 2024-09-20 00:21:06.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.692 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.691 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.675 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.668 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.667 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.666 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.675 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:21:06.669 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive admin.0 2024-09-20 00:21:06.668 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive admin.0 2024-09-20 00:21:06.667 debug Subscribes: system.host.*.notifications.* admin.0 2024-09-20 00:21:06.666 debug Subscribes: dummy admin.0 2024-09-20 00:21:06.655 info ==> Connected system.user.admin from ::ffff:192.168.1.35 host.ioB-Test 2024-09-20 00:21:06.164 info instance system.adapter.backitup.0 in version "3.0.22" started with pid 348 admin.0 2024-09-20 00:21:06.101 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:06.100 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.823 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:04.805 info <== Disconnect system.user.admin from ::ffff:192.168.1.35 admin admin.0 2024-09-20 00:21:04.803 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.785 info ==> Connected system.user.admin from ::ffff:192.168.1.35 admin.0 2024-09-20 00:21:04.502 info Use link "http://127.0.0.1:8081" to configure. admin.0 2024-09-20 00:21:04.502 info http server listening on port 8081 admin.0 2024-09-20 00:21:04.500 info socket.io server listening on port 8081 admin.0 2024-09-20 00:21:04.483 debug Next repo update on 9/20/2024, 5:44:32 PM admin.0 2024-09-20 00:21:04.249 debug Secure connection not enabled - using http createServer admin.0 2024-09-20 00:21:04.238 info received all objects admin.0 2024-09-20 00:21:03.805 info requesting all objects admin.0 2024-09-20 00:21:03.782 info starting. Version 7.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11 admin.0 2024-09-20 00:21:03.547 debug Plugin sentry Initialize Plugin (enabled=true) admin.0 2024-09-20 00:21:03.529 debug States connected to redis: 127.0.0.1:9000 admin.0 2024-09-20 00:21:03.522 debug States create User PubSub Client admin.0 2024-09-20 00:21:03.521 debug States create System PubSub Client admin.0 2024-09-20 00:21:03.517 debug Redis States: Use Redis connection: 127.0.0.1:9000 admin.0 2024-09-20 00:21:03.506 debug Objects connected to redis: 127.0.0.1:9001 admin.0 2024-09-20 00:21:03.501 debug Objects client initialize lua scripts admin.0 2024-09-20 00:21:03.487 debug Objects create User PubSub Client admin.0 2024-09-20 00:21:03.487 debug Objects create System PubSub Client admin.0 2024-09-20 00:21:03.485 debug Objects client ready ... initialize now admin.0 2024-09-20 00:21:03.464 debug Redis Objects: Use Redis connection: 127.0.0.1:9001 host.ioB-Test 2024-09-20 00:21:02.042 info Some obsolete host states deleted. host.ioB-Test 2024-09-20 00:21:02.039 info Delete state "system.host.ioB-Test.versions.npmNewestNext" host.ioB-Test 2024-09-20 00:21:02.034 info Delete state "system.host.ioB-Test.versions.npmNewest" host.ioB-Test 2024-09-20 00:21:02.030 info Delete state "system.host.ioB-Test.versions.npmCurrent" host.ioB-Test 2024-09-20 00:21:02.026 info Delete state "system.host.ioB-Test.versions.nodeNewestNext" host.ioB-Test 2024-09-20 00:21:01.993 info instance system.adapter.admin.0 in version "7.1.1" started with pid 307 host.ioB-Test 2024-09-20 00:21:01.980 info Delete state "system.host.ioB-Test.versions.nodeNewest" host.ioB-Test 2024-09-20 00:21:01.869 info Delete state "system.host.ioB-Test.versions.nodeCurrent" host.ioB-Test 2024-09-20 00:21:01.762 info starting 2 instances host.ioB-Test 2024-09-20 00:21:01.757 info 2 instances found host.ioB-Test 2024-09-20 00:21:01.377 info added notifications configuration of host host.ioB-Test 2024-09-20 00:21:01.362 info connected to Objects and States host.ioB-Test 2024-09-20 00:21:00.674 info ip addresses: 192.168.1.160 2a02:810c:1bf:f826:be24:11ff:feb1:1bd1 fe80::be24:11ff:feb1:1bd1 host.ioB-Test 2024-09-20 00:21:00.673 info hostname: ioB-Test, node: v20.17.0 host.ioB-Test 2024-09-20 00:21:00.673 info Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker host.ioB-Test 2024-09-20 00:21:00.669 info iobroker.js-controller version 6.0.11 js-controller starting host.ioB-Test 2024-09-20 00:20:50.697 info terminated host.ioB-Test 2024-09-20 00:20:50.560 info All instances are stopped. host.ioB-Test 2024-09-20 00:20:50.560 info instance system.adapter.admin.0 terminated with code 0 (NO_ERROR) host.ioB-Test 2024-09-20 00:20:50.469 info instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR) backitup.0 2024-09-20 00:20:50.384 info terminating admin.0 2024-09-20 00:20:50.383 info terminating backitup.0 2024-09-20 00:20:49.942 info Terminated (NO_ERROR): Without reason backitup.0 2024-09-20 00:20:49.941 info terminating admin.0 2024-09-20 00:20:49.902 info Terminated (NO_ERROR): Without reason admin.0 2024-09-20 00:20:49.901 debug Plugin sentry destroyed host.ioB-Test 2024-09-20 00:20:49.900 info stopInstance system.adapter.backitup.0 send kill signal admin.0 2024-09-20 00:20:49.899 info terminating host.ioB-Test 2024-09-20 00:20:49.899 info stopInstance system.adapter.admin.0 send kill signal backitup.0 2024-09-20 00:20:49.897 info Got terminate signal TERMINATE_YOURSELF admin.0 2024-09-20 00:20:49.897 info Got terminate signal TERMINATE_YOURSELF host.ioB-Test 2024-09-20 00:20:49.885 info stopInstance system.adapter.backitup.0 (force=false, process=true) host.ioB-Test 2024-09-20 00:20:49.885 info stopInstance system.adapter.admin.0 (force=false, process=true) backitup.0 2024-09-20 00:20:49.876 info cleaned everything up... admin.0 2024-09-20 00:20:49.876 info terminating http server on port 8081 host.ioB-Test 2024-09-20 00:20:49.875 info received SIGTERM admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.709 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.706 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.705 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.703 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.701 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:17:15.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:17:15.657 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:15.655 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.652 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.203 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.199 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList admin.0 2024-09-20 00:17:12.197 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson admin.0 2024-09-20 00:17:12.196 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId admin.0 2024-09-20 00:17:12.195 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected admin.0 2024-09-20 00:17:12.188 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.184 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.369 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:18:15.722 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.721 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.720 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:18:15.719 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.709 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.708 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.707 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.706 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.705 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.704 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.703 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.701 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:17:15.697 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:17:15.696 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:17:15.694 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:17:15.693 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:17:15.657 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:15.655 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.654 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.653 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:15.652 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.203 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList, admin.0.info.updatesNumber admin.0 2024-09-20 00:17:12.199 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson, admin.0.info.updatesList admin.0 2024-09-20 00:17:12.197 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId, admin.0.info.updatesJson admin.0 2024-09-20 00:17:12.196 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag, admin.0.info.newsLastId admin.0 2024-09-20 00:17:12.195 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates, admin.0.info.newsETag admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck, admin.0.info.newUpdates admin.0 2024-09-20 00:17:12.192 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection, admin.0.info.lastUpdateCheck admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected, admin.0.info.connection admin.0 2024-09-20 00:17:12.191 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state, admin.0.info.connected admin.0 2024-09-20 00:17:12.188 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, 0_userdata.0.example_state admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:17:12.185 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.184 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.182 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:17:12.181 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.370 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.369 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.367 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.366 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.365 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.364 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection admin.0 2024-09-20 00:16:52.359 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree admin.0 2024-09-20 00:16:52.358 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled admin.0 2024-09-20 00:16:52.357 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel admin.0 2024-09-20 00:16:52.356 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount admin.0 2024-09-20 00:16:52.356 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss admin.0 2024-09-20 00:16:52.355 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount admin.0 2024-09-20 00:16:52.355 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected admin.0 2024-09-20 00:16:52.354 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, system.adapter.*.alive admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.extension admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed, *.info.connection, *.info.extension admin.0 2024-09-20 00:16:25.330 debug Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed@marko67 sagte in NUC-Proxmox-steigender Ram:
Discovery vor ca. 1 Std. über die Konsole gelöscht
Warum nicht direkt in ioBroker?
Und zeige mal wie du ioBroker installiert hast. Also jeden einzelnen Schritt (Befehl) nach Erstellung des LXC.
@dr-bakterius
Ich habe mich an die Empfehlung von @crunchip gehalten und die Installation nach dieser Doku vorgenommen:
https://www.iobroker.net/#de/documentation/install/proxmox.md
Warum über Konsole?? Weil ich dazu folgendes gefunden habe:
https://github.com/ioBroker/ioBroker/wiki/Console-commands#iobroker-del-adaptername
Es gibt viele Wege die nach Rom führen. Dass einige falsch sind weiß ich. Aber welcher letzten Endes der richtige ist .... woher soll man das wissen?
Auch unter den "Profis`s" gibt es verschiedene (Lösungs) Ansätze. -
hier gab es schonmal so etwas
https://forum.iobroker.net/post/843911 -
Hallo
Dein Tipp mit
hat mir vielleicht weiter geholfen.
Ich habe beides ausgewählt und einen Reboot gemacht. Seitdem läuft es stabiler.
@marko67 ich glaube nicht, dass die Häkchen die Ursache sind. Möglicherweise wurde eine "fehlerhaft" gespeicherte Konfiguration wieder korrigiert.
Mach die Probe und stelle zurück.
Ro75.
Ro75.
