  4. Test Adapter OpenLigaDB
    6.0k
adapteropenligadbtest
716 Beiträge 59 Kommentatoren 222.3k Aufrufe 52 Beobachtet
  • OliverIOO OliverIO
    @einstein2002
    so dann nochmal komplett ersetzen
    ich habe ein paar logausgaben hinzugefügt.
    da müsste dann unten so etwas angezeigt werden
    datenpunktname für signal noch anpassen
    let dp_allmatches = "openligadb.0.KOLWTBJ.2024.allmatches";
    let dp_currgameday = "openligadb.0.KOLWTBJ.2024.currgameday";
    let dp_signal="0_userdata.0.testFolder.bool";
    let suchbegriff = "mühlberg"
    async function main(){
        let allmatches = await getStateAsync(dp_allmatches);
        let currgameday = await getStateAsync(dp_currgameday);
        let fav = filterFavGames(JSON.parse(allmatches.val),"",1,currgameday.val,suchbegriff,false,"");
        console.log("ungefiltert");
        console.log(fav);
        fav = fav.filter(el=>checkDateInRange(el.matchDateTime,24));
        console.log("gefiltert");
        console.log(fav);
        console.log("statuswert");
        console.log(!!fav.length);
        setState(dp_signal,!!fav.length);
    main();
    function filterFavGames(allmatches, gameday, gamedaycount, currgameday, filter, shortname, abbreviation) {
        if (!Array.isArray(allmatches)) return [];
        gameday = gameday || currgameday || "";
        gameday = parseInt(gameday) || "";
        gamedaycount = parseInt(gamedaycount) || 9999;
        currgameday = parseInt(currgameday);
        abbreviation = abbreviation || "";
        shortname = shortname || false;
        filter = filter || "";
        return allmatches.reduce(function (result, item) {
            let found;
            item.abbreviation = abbreviation;
            if (gameday > 0 && item.group.groupOrderID >= gameday && item.group.groupOrderID < gameday + gamedaycount) found = item;
            if (gameday < 0 && item.group.groupOrderID >= currgameday + gameday && item.group.groupOrderID < currgameday + gameday + gamedaycount) found = item;
            item.filter = filter;
            item.shortname = shortname;
            if (found && (checkHighlite(item.team1.teamName, filter) || checkHighlite(item.team2.teamName, filter))) result.push(item);
            return result;
    function checkHighlite(value, highlights, sep) {
        sep = typeof sep !== "undefined" ? sep : ";";
        const highlight = highlights.split(sep);
        return highlight.reduce(function (acc, cur) {
            if (cur == "") return acc;
            return acc || value.toLowerCase().indexOf(cur.toLowerCase()) >= 0;
        }, false);
    function checkDateInRange(date,hours) {
        let futureDate=new Date(date).getTime();
        return futureDate < Date.now()+hours*60*60*1000 ;
    Einstein2002
    #629
    @oliverio
    Leider funktioniert es doch nicht so wie gewünscht, der Wert beider Vereine bleibt immer auf True stehen, egal wie ich die Zeit ändere. Nur wenn ich den Namen der Vereine falsch schreibe dann geht der Wert auf false.
    Deswegen vielleicht auf dem Weg wie es in der Doku beschrieben ist.
    Nur so als Idee.
    Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
    Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
      Neue Version 1.5.0
      • Hinzufügen eines CSS-Beispiels für das PivotTable-Widget
      • Hinzufügen des Befehls sendTo getMatchData um per javascript die spieldaten abzurufen und auf einen zeitbereich einzugrenzen. Details dazu siehe readme
      • Entfernen veralteter Widgets
      • Hinzufügen der Widget-Option „nur Logo“, um den Teamnamen zu unterdrücken
      Einstein2002
      #630
      @oliverio sagte in Test Adapter OpenLigaDB:
      Neue Version 1.5.0
      Ich habe auf die 1.5.0 upgedatet und versucht mit deinem readme klarzukommen, bin aber nicht ganz schlau draus geworden. Auch das könnte ja schon die Lösung bringen.
      Oder?
      • E Einstein2002
        könnte ich noch mal ein Beispiel bekommen wie diese Funktion richtig angelegt wird
        {a:oid;vis.binds["openligadb"].checkTodayFavorite('oid_allmatches','clubsuche1,clubsuche2')?'ja':'nein'}
        ich hab das so abgeändert aber bekomme immer nur eine 0 angezeigt:
        {a:oid;vis.binds["openligadb.0.bl1.2024"].checkTodayFavorite('openligadb.0.bl1.2024.allmatches','frankfurt,dortmund')?'ja':'nein'}
        Da komme ich nicht ganz mit:
        oid ein beliebiger Datenpunkt, der nur aufgrund der Notation des Bindings ausgewählt werden muss. Dieser Datenpunkt darf kein JSON zurückgeben.
        Die habe ich wie in der Anleitung beschrieben in einem html Widget
        Link Text
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #631
        @einstein2002 sagte in Test Adapter OpenLigaDB:
        tja, was soll ich sagen.
        die funktion ist irgendwie rausgeflogen. warum weiß ich nicht.
        muss sie erst wieder hinzufügen.
        werde dann auch die doku verbessern
        Meine Adapter und Widgets
        Links im Profil
        • E Einstein2002
          Neue Version 1.5.0
          Oder?
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          #632
          Oder?
          welchen punkt sprichst du den genau an
          • checktoday
          • die sendto funktion
          • die no logo option?
          bitte etwas mehr kontext, ich bin kein hellseher
          Links im Profil
          • OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #633
            Neue Version 1.7.0
            • die checkTodayFavorite funktion ist wieder da
            • die doku dazu wurde verbessert
            Links im Profil
            • OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #634
              auch wenn das wahrscheinlich nicht soviele lesen.
              Gerne dürft ihr ein Rating für den Adapter abgeben.
              Wenn es ein Problem gibt, dann bitte hier im Forum posten,
              so das man sich das mal anschauen kann. Oft sind die Daten auch bei openligadb nicht gepflegt.
              Mit diesen Angaben lässt sich leider nicht viel anfangen, noch kann man feedback dazu geben
              Links im Profil
                sigi234S Online
                sigi234S Online
                #635
                Ja und das ist das Problem.
                • sigi234S sigi234
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #636
                  @sigi234
                  da es ein communityprojekt ist, was mit dem adapter nix zu tun hat,
                  kann sich da natürlich jeder anmelden und bei der erfassung der daten helfen
                  Links im Profil
                  icebearI 1 Antwort Letzte Antwort
                    @sigi234
                    icebearI Online
                    icebearI Online
                    icebear
                    #637
                    @oliverio said in Test Adapter OpenLigaDB:
                    Also, ich bin angemeldet und hab letztes WE die Spielstände (also Tore, Torschütze, Min) sofort nachdem das Tor gefallen ist eingegeben.
                    Das hat bei der 1.Bundesliga auch funktioniert und die Spielstände (auch Zwischenstände)wurden aktualisiert, bei der 2. Bundesliga waren keine Zwischenstände und Halbzeitergebnisse da, das Ergebnis wurde erst nach Spielende im Adapter (Widget) aktualisiert. (Dies hatte ich oben auch schonmal geschrieben)
                    Ich würde aber deshalb den Adapter nicht grundsätzlich als schlecht bewerten, ohne zu wissen woran es genau liegt.
                    Nur mal so als Anregung bzw. Info.
                    Ich hab dann mal, weil ich es sowieso hab bei HA die Teamtracker Integration installiert, die auf die API von ESPN zugreift, und da läuft das eigentlich so wie ich mir das vorstelle, die Spielstände und alle wichtigen Info werden ruckzuck automatisch aktualisiert, die Cards der Teams und Spieltage sind super und ich kann fast alle Sportarten auswählen.
                    Nachteil ist halt das es keine API für die unteren Ligen gibt.
                    Hier mal ein paar Screenshots:
                    @OliverIO bitte nicht falsch verstehen, finde deinen Adapter super und bin froh das sich jemand der Sache angenommen hat und viel Zeit in das Projekt steckt, die Frage die ich mir halt stelle ist warum gibt es sowas wie den Teamtracker Adapter nicht auch für IOB, mein Programierkenntnisse reichen leider nicht aus um sowas umzusetzen.
                    OliverIOO 2 Antworten Letzte Antwort
                    • icebearI icebear
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #638
                      @icebear
                      Ich habe vom teamtracker noch nie was gehört.
                      Erstaunlich ist, das es die Ergebnisse von espn kostenfrei gibt.
                      Normalerweise muss man für so etwas bezahlen bzw. Von der Web Seite scrapen, immer mit dem Risiko, das morgen die seitenstruktur geändert wird.
                      Links im Profil
                        @icebear
                        icebearI Online
                        icebearI Online
                        icebear
                        #639
                        @oliverio
                        Ich kannte das auch nicht. Hab es jetzt mal bei mir eingerichtet und werde mir das am WE mal anschauen wie das läuft.
                        • icebearI icebear
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #640
                          @icebear sagte in Test Adapter OpenLigaDB:
                          Super das du angemeldet bist.
                          Wie der Aktualisierung Prozess bei openligadb genau läuft weiß ich nicht. Evtl muss ein maintainer die Daten immer mal noch frei geben, das da niemand Schrott eingeben kann.
                          Links im Profil
                          • OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            #641
                            Neue Version 1.8.0
                            • die widget dokumentation befindet sich nun in der readme, die bisherige html-doku wurde entfernt.
                            • in den verschiedenen widgets konnte man mit highlight seine vereine etwas hervorheben. dazu wurde immer die selbe css klasse favorite verwendet. nun können für jeden verein idividuelle formatierungen angewendet werden, indem man noch den namen einer eigenen css klasse hinzufügt
                              Beispiel für highlight
                            vfb[colorvfb];bayern[colorbayern]
                            im css reiter kann man dann bspw folgende css klassen einfügen,
                            dadurch werden die manschaftsnamen dann in den entsprechenden Formatierungen angezeigt.
                            .colorvfb {
                              color:green;
                            .colorbayern {
                              color:red;
                            Widget zum importieren, die Datenpunkte zeigen auf die aktuelle Bundesliga
                            [{"tpl":"tplOLiDBFavGames3","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","lcount":"1","maxicon":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid-allmatches1":"openligadb.0.bl1.2024.allmatches","oid-currgameday1":"openligadb.0.bl1.2024.currgameday","filter1":"vfb[colorvfb];bayern[colorbayern]","showgamedaycount1":"2","abbreviation1":" "},"style":{"left":"41px","top":"67px"},"widgetSet":"openligadb"}]
                            hier noch ein Beispiel mit dem aktuellen und nächsten Spieltag
                            [{"tpl":"tplOLiDBGameDay2","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","maxicon":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"highlight":"vfb[colorvfb];bayern[colorbayern]","oid-allmatches":"openligadb.0.bl1.2024.allmatches","onlylogo":false,"showgamedaycount":"2","oid-currgameday":"openligadb.0.bl1.2024.currgameday"},"style":{"left":"38px","top":"48px","width":"312px","height":"210px"},"widgetSet":"openligadb"}]
                            Links im Profil
                              Neue Version 1.8.0
                              .colorvfb {
                                color:green;
                              .colorbayern {
                                color:red;
                              stenmic
                              schrieb am zuletzt editiert von stenmic
                              #642
                              @oliverio
                              kann es sein, dass die Torschützenliste aktuell nicht gepflegt wird? Irgendwie tut sich da seit 3 Spieltagen nichts mehr. Ich nutze zwar nicht den Adapter aber frage die gleiche API ab.
                              • S stenmic
                                @oliverio
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #643
                                @stenmic
                                ich habe gerade mal bei einem zufälligen spieler bei der bl1 2024 überprüft der am letzten spieltag ein toor geschossen hat.
                                da stimmt es. dummerweise ist der Spieler 2 mal vorhanden und wird dadurch als 2 separate spieler gesehen
                                Links im Profil
                                  @stenmic
                                  stenmic
                                  #644
                                  @oliverio
                                  wie viele Tore hat Kane bei dir?
                                  bei mir steht er auch 2 mal drinnen… Die Summe ist aber auch falsch
                                  • S stenmic
                                    @oliverio
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    #645
                                    @stenmic
                                    also die goalgetter api gibt das zurück
                                    wenn ich die beiden nummern mir bei allmatches schaue passt das. leider muss man da mit nummer suchen, das namens feld ist leer
                                    "goalGetterId": 17093,
                                    "goalGetterName": "Harry Kane",
                                    "goalCount": 4
                                    "goalGetterId": 18898,
                                    "goalGetterName": "H. Kane",
                                    "goalCount": 6
                                    hier steht jeweils 9
                                    https://www.sport1.de/daten/fussball/bundesliga/torjaeger
                                    https://www.bundesliga.com/de/bundesliga/statistiken/spieler/tore
                                    bayern:vfb=3=ok
                                    bayern:freiburg=1 ok
                                    kiel:bayern=3 ok
                                    bremen:bayern:1 ok
                                    bochum:bayern=1 ok
                                    bayern:wolfsburg=1
                                    wolfsburg ist zuviel eingetragen, da hätte kaminski stehen müssen
                                    also eher überpflegt
                                    Links im Profil
                                      @stenmic
                                      "goalCount": 4
                                      "goalCount": 6
                                      bayern:vfb=3=ok
                                      kiel:bayern=3 ok
                                      bremen:bayern:1 ok
                                      bochum:bayern=1 ok
                                      bayern:wolfsburg=1
                                      stenmic
                                      #646
                                      @oliverio
                                      ok, vielen Dank für deine Recherche.
                                      • H Offline
                                        hsjan
                                        #647
                                        ich nutze den Adapter schon lange. Jetzt habe ich auf Version 1.8 aktualisiert und kann nichts mehr sehen.
                                        Kein Widget wird mehr angezeigt.
                                        Hat jemand eine Idee, was ich falsch gemacht habe?
                                        Auch eine neue Installation des Adapters brachte keine Besserung.
                                        • H hsjan
                                          Maas-Meister
                                          #648
                                          @hsjan
                                          hatte ich auch.
                                          Du musst die Datenpunkte der Widgets neu verlinken.
                                          Am besten alle Widgets löschen und neu erstellen.
                                          H 1 Antwort Letzte Antwort
