  4. Zeitplan startet nicht mehr
86 Beiträge 7 Kommentatoren 11.0k Aufrufe 4 Beobachtet
    @haus-automatisierung sagte in Zeitplan startet nicht mehr:
    Das geht nur mit Datenpunkten im Format hh:mm oder hh:mm:ss
    auch wenn der DP nicht vom typ text, sondern number ist?
    SMSS Offline
    SMSS Offline
    SMS
    @homoran so schaut es jetzt aus:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: Homee
           Icon name: computer
              Kernel: Linux 6.6.31+rpt-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:17:59 up 8 min,  3 users,  load average: 1.45, 1.78, 1.05
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2024-09-03 14:17:59 CEST
               Universal time: Tue 2024-09-03 12:17:59 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.2G        1.9G        5.3G        1.4M        1.1G        6.3G
    Swap:           209M          0B        209M
    Total:          8.4G        1.9G        5.5G
    Active iob-Instances:   36
             7810 M total memory
             1796 M used memory
             1973 M active memory
              663 M inactive memory
             5013 M free memory
               99 M buffer memory
              967 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 14:17:59 up 8 min,  3 users,  load average: 1.45, 1.78, 1.05
    Tasks: 206 total,   1 running, 205 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7810.0 total,   5011.3 free,   1797.9 used,   1066.7 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6012.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     782M  1.3M  780M   1% /run
    /dev/mmcblk0p2 ext4      117G   19G   93G  17% /
    tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
    tmpfs          tmpfs     781M   36K  781M   1% /run/user/1000
    [Tue Sep  3 14:09:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B6:0D:F1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f26be412-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Tue Sep  3 14:09:23 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
    [Tue Sep  3 14:09:26 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET                                                  SOURCE         FSTYPE      OPTIONS
    /                                                       /dev/mmcblk0p2 ext4        rw,noatime,commit=600
    |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
    |-/proc                                                 proc           proc        rw,relatime
    | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5303
    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=3725556k,nr_inodes=931389,mode=755
    | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
    | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
    |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=799748k,mode=755
    | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=799744k,nr_inodes=199936,mode=700,uid=1000,gid=1000
    `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.2G    /var/
    4.1G    /var/log
    4.0G    /var/log/journal/6c7cbef6aa2e4815900727fbf6286f9a
    771M    /var/lib
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    5.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    816M    /opt/iobroker/iobroker-data/
    719M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D306MB4E-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.17.0-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
     *** 20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.0.23
    javascript:     8.7.6
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Homee                                    -  enabled, port: 7770, bind: 0.0.0.0, run as: admin
    + system.adapter.alpha-ess.0              : alpha-ess             : Homee                                    -  enabled
    + system.adapter.backitup.0               : backitup              : Homee                                    -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: Homee                                    -  enabled
      system.adapter.daswetter.0              : daswetter             : Homee                                    -  enabled
      system.adapter.devices.0                : devices               : Homee                                    -  enabled
    + system.adapter.discovery.0              : discovery             : Homee                                    -  enabled
    + system.adapter.ds18b20.1                : ds18b20               : Kellerkind                               -  enabled
    + system.adapter.ds18b20.3                : ds18b20               : PapaHuette                               -  enabled
      system.adapter.dwd.0                    : dwd                   : Homee                                    -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : Homee                                    -  enabled
    + system.adapter.email.0                  : email                 : Homee                                    -  enabled
    + system.adapter.growatt.0                : growatt               : Homee                                    -  enabled
    + system.adapter.growatt.1                : growatt               : Homee                                    -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : Homee                                    -  enabled
      system.adapter.ical.0                   : ical                  : Homee                                    -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Homee                                    -  enabled
    + system.adapter.influxdb.0               : influxdb              : Homee                                    -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : Homee                                    -  enabled
    + system.adapter.modbus.0                 : modbus                : Homee                                    -  enabled
    + system.adapter.modbus.1                 : modbus                : Homee                                    -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : Homee                                    -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : Homee                                    -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : Homee                                    -  enabled
      system.adapter.pegelalarm.1             : pegelalarm            : Homee                                    -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : Homee                                    -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Homee                                    -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : Kellerkind                               -  enabled
    + system.adapter.rpi2.2                   : rpi2                  : MotionEye                                -  enabled
    + system.adapter.rpi2.3                   : rpi2                  : PapaHuette                               -  enabled
    + system.adapter.rpi2.4                   : rpi2                  : Gartenklo                                -  enabled
    + system.adapter.semp.0                   : semp                  : Homee                                    -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : Homee                                    -  enabled
    + system.adapter.sonoff.0                 : sonoff                : Homee                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.systeminfo.0             : systeminfo            : Homee                                    -  enabled
    + system.adapter.systeminfo.1             : systeminfo            : Kellerkind                               -  enabled
    + system.adapter.systeminfo.2             : systeminfo            : MotionEye                                -  enabled
    + system.adapter.systeminfo.3             : systeminfo            : PapaHuette                               -  enabled
    + system.adapter.systeminfo.4             : systeminfo            : Gartenklo                                -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : Homee                                    -  enabled
      system.adapter.vis-bars.0               : vis-bars              : Homee                                    -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Homee                                    -  enabled
      system.adapter.vis-history.0            : vis-history           : Homee                                    -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Homee                                    -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : Homee                                    -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : Homee                                    -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Homee                                    -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : Homee                                    -  enabled
      system.adapter.vis-metro.0              : vis-metro             : Homee                                    -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : Homee                                    -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : Homee                                    -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : Homee                                    -  enabled
      system.adapter.vis.0                    : vis                   : Homee                                    -  enabled
    + system.adapter.web.0                    : web                   : Homee                                    -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.2                   : worx                  : PapaHuette                               -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "alpha-ess"    : 2.1.4    , installed 2.1.4
    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "growatt"      : 3.2.4    , installed 3.2.4
    Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "semp"         : 1.4.5    , installed 1.4.5
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        13068
    States:         13797
    W: GPG error: https://repos.influxdata.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bookworm InRelease' is not signed.
    W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    W: GPG error: http://archive.raspbian.org/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
    E: The repository 'http://archive.raspbian.org/raspbian bookworm InRelease' is not signed.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5866       754/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       7563       1001/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       6097       1001/iobroker.js-co
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        7071       857/influxd
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       9748       1235/io.mqtt.0
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       9749       1235/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8658       1363/io.sonoff.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6963       747/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5868       754/sshd: /usr/sbin
    tcp6       0      0 :::9765                 :::*                    LISTEN      1001       12331      1770/io.semp.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6962       747/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      112        7543       1000/grafana
    tcp6       0      0 :::7777                 :::*                    LISTEN      1001       9042       1829/io.web.0
    tcp6       0      0 :::7770                 :::*                    LISTEN      1001       9409       1042/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        9327       857/influxd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        824        543/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       12334      1770/io.semp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       12333      1770/io.semp.0
    udp        0      0 0.0.0.0:47277           0.0.0.0:*                           104        826        543/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          7355       833/cups-browsed
    udp6       0      0 :::5353                 :::*                                104        825        543/avahi-daemon: r
    udp6       0      0 :::33089                :::*                                104        827        543/avahi-daemon: r
    udp6       0      0 fe80::c6ff:9450:166:546 :::*                                0          7065       689/NetworkManager
    udp6       0      0 fe80::fe25:eded:c85:546 :::*                                0          7303       689/NetworkManager
    2024-09-03 14:18:22.844  - debug: homeconnect.0 (1167) event: {"type":"NOTIFY","data":"{\"haId\":\"484020392374002592\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"level\":\"hint\",\"timestamp\":1725365902,\"unit\":\"%\",\"uri\":\"/api/homeappliances/484020392374002592/programs/active/options/BSH.Common.Option.ProgramProgress\",\"value\":61}]}","lastEventId":"484020392374002592","origin":"https://api.home-connect.com"}
    2024-09-03 14:18:22.845  - debug: homeconnect.0 (1167) 484020392374002592.programs.active.options.BSH_Common_Option_ProgramProgress:61
    2024-09-03 14:18:22.848  - debug: homeconnect.0 (1167) Set event state
    2024-09-03 14:18:22.854  - silly: homeconnect.0 (1167) States user redis pmessage homeconnect.0.*/homeconnect.0.484020392374002592.programs.active.options.BSH_Common_Option_ProgramProgress:{"val":61,"ack":true,"ts":1725365902852,"q":0,"from":"system.adapter.homeconnect.0","user":"system.user.admin","lc":1725365902852}
    2024-09-03 14:18:22.901  - debug: homeconnect.0 (1167) event: {"type":"NOTIFY","data":"{\"haId\":\"484020392374002592\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.RemainingProgramTime\",\"level\":\"hint\",\"timestamp\":1725365902,\"unit\":\"seconds\",\"uri\":\"/api/homeappliances/484020392374002592/programs/active/options/BSH.Common.Option.RemainingProgramTime\",\"value\":5220},{\"handling\":\"none\",\"key\":\"BSH.Common.Option.EstimatedTotalProgramTime\",\"level\":\"hint\",\"timestamp\":1725365902,\"unit\":\"seconds\",\"uri\":\"/api/homeappliances/484020392374002592/programs/active/options/BSH.Common.Option.EstimatedTotalProgramTime\",\"value\":5220}]}","lastEventId":"484020392374002592","origin":"https://api.home-connect.com"}
    2024-09-03 14:18:22.901  - debug: homeconnect.0 (1167) 484020392374002592.programs.active.options.BSH_Common_Option_RemainingProgramTime:5220
    2024-09-03 14:18:22.902  - debug: homeconnect.0 (1167) 484020392374002592.programs.active.options.BSH_Common_Option_EstimatedTotalProgramTime:5220
    2024-09-03 14:18:22.905  - debug: homeconnect.0 (1167) Set event state
    2024-09-03 14:18:22.906  - debug: homeconnect.0 (1167) Set event state
    2024-09-03 14:18:22.954  - silly: homeconnect.0 (1167) States user redis pmessage homeconnect.0.*/homeconnect.0.484020392374002592.programs.active.options.BSH_Common_Option_RemainingProgramTime:{"val":5220,"ack":true,"ts":1725365902952,"q":0,"from":"system.adapter.homeconnect.0","user":"system.user.admin","lc":1725365902952}
    2024-09-03 14:18:22.958  - silly: homeconnect.0 (1167) States user redis pmessage homeconnect.0.*/homeconnect.0.484020392374002592.programs.active.options.BSH_Common_Option_EstimatedTotalProgramTime:{"val":5220,"ack":true,"ts":1725365902956,"q":0,"from":"system.adapter.homeconnect.0","user":"system.user.admin","lc":1725365902956}
    2024-09-03 14:18:23.848  - debug: mqtt.0 (1235) Client [Wemos_.81_0] received publish package {"cmd":"publish","retain":false,"qos":0,"dup":false,"length":55,"topic":"Wemos .81/Füllstand Brunnen/Füllstand Brunnen","payload":{"type":"Buffer","data":[50,49,56,46,52,54]}}
    2024-09-03 14:18:23.849  - debug: mqtt.0 (1235) Server received "Wemos .81/Füllstand Brunnen/Füllstand Brunnen" (number): 218.46
    2024-09-03 14:18:23.860  - silly: mqtt.0 (1235) States user redis pmessage mqtt.0.*/mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen:{"val":218.46,"ack":true,"ts":1725365903855,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725365903855}
    2024-09-03 14:18:23.866  - debug: mqtt.0 (1235) stateChange mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen: {"val":218.46,"ack":true,"ts":1725365903855,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725365903855}
    2024-09-03 14:18:23.866  - debug: mqtt.0 (1235) onStateChange mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen: {"val":218.46,"ack":true,"ts":1725365903855,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725365903855}
    2024-09-03 14:18:23.870  - debug: mqtt.0 (1235) Client [Wemos_.81_0] send to this client "Wemos .81/Füllstand Brunnen/Füllstand Brunnen": 218.46
    2024-09-03 14:18:31.587  - info: smartmeter.0 (1352) Received 10 values, 3 updated
    2024-09-03 14:18:33.846  - debug: mqtt.0 (1235) Client [Wemos_.81_0]  pingreq
    2024-09-03 14:18:38.829  - debug: mqtt.0 (1235) Client [Wemos_.81_0] received publish package {"cmd":"publish","retain":false,"qos":0,"dup":false,"length":54,"topic":"Wemos .81/Füllstand Brunnen/Füllstand Brunnen","payload":{"type":"Buffer","data":[50,53,46,56,50]}}
    2024-09-03 14:18:38.830  - debug: mqtt.0 (1235) Server received "Wemos .81/Füllstand Brunnen/Füllstand Brunnen" (number): 25.82
    2024-09-03 14:18:38.865  - silly: mqtt.0 (1235) States user redis pmessage mqtt.0.*/mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen:{"val":25.82,"ack":true,"ts":1725365918856,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725365918856}
    2024-09-03 14:18:38.873  - debug: mqtt.0 (1235) stateChange mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen: {"val":25.82,"ack":true,"ts":1725365918856,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725365918856}
    2024-09-03 14:18:38.879  - debug: mqtt.0 (1235) onStateChange mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen: {"val":25.82,"ack":true,"ts":1725365918856,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725365918856}
    2024-09-03 14:18:38.882  - debug: mqtt.0 (1235) Client [Wemos_.81_0] send to this client "Wemos .81/Füllstand Brunnen/Füllstand Brunnen": 25.82
    iob diag has finished.
      wurde doch danach auf string umgestellt
      richtig!
      soll aber vorher "immer"™ mit der alten Einstellung typ=number funktioniert haben.
      haus-automatisierungH Offline
      @homoran sagte in Zeitplan startet nicht mehr:
      soll aber vorher "immer" mit der alten Einstellung typ=number funktioniert haben.
      Naja der js-controller ist da ja (noch) recht tolerant und erlaubt auch andere Datentypen zu schreiben. Generiert halt eine Warning.
      📚 Meine Dokumentation
        Danke!
        Da hatte ich u.a. das Problem vermutet, dass das (schon) nicht mehr der Fall ist.
          richtig!
          SMSS Offline
          SMSS Offline
          SMS
          @homoran Kurzversion:
          Copy text starting here:
                                  v.2024-05-22
                 Icon name: computer
              Architecture: arm64
          Kernel:                 aarch64
          Userland:               64 bit
          User-ID:                1000
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          Recommended versions are nodejs 20.17.0 and npm 10.8.2
          MEMORY:
          Mem:            8.2G        2.3G        4.8G        1.4M        1.1G        5.9G
          Swap:           209M          0B        209M
          Total:          8.4G        2.3G        5.0G
          ioBroker Core:          js-controller           6.0.11
                                  admin                   7.0.23
          Objects type: jsonl
          States  type: jsonl
          Objects:                13068
          States:                 13797
          Size of iob-Database:
          8.2M    /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          • SMSS SMS
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           209M          0B        209M
                     7810 M total memory
                     1796 M used memory
                     5013 M free memory
                       99 M buffer memory
                      967 M swap cache
                      199 M total swap
                        0 M used swap
                      199 M free swap
            *** FILESYSTEM ***
            /var:
            5.2G    /var/
            4.1G    /var/log
            771M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          7.0.23
            javascript:     8.7.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        13068
            States:         13797
            Pending Updates: 0
            @sms sagte in Zeitplan startet nicht mehr:
            und bei den slaves?
            bitte einzeln! einer nach dem anderen
            SMSS 4 Antworten Letzte Antwort
              und bei den slaves?
              SMSS Offline
              SMSS Offline
              SMS
              @homoran Kellerkind:
              Skript v.2024-05-22
              *** BASE SYSTEM ***
               Static hostname: Kellerkind
                     Icon name: computer
                  Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
               13:28:49 up 15 min,  4 users,  load average: 0.15, 0.14, 0.13
              CPU threads: 4
              Current issues:
                             Local time: Tue 2024-09-03 13:28:50 BST
                         Universal time: Tue 2024-09-03 12:28:50 UTC
                               RTC time: n/a
                              Time zone: Europe/London (BST, +0100)
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Display-Server: true
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.0G        518M        2.8G         17M        745M        3.5G
              Swap:           209M          0B        209M
              Total:          4.2G        518M        3.0G
                       3792 M total memory
                        494 M used memory
                        646 M active memory
                        347 M inactive memory
                       2673 M free memory
                         41 M buffer memory
                        669 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 13:28:50 up 15 min,  4 users,  load average: 0.30, 0.17, 0.14
              Tasks: 218 total,   1 running, 217 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 83.3 id, 16.7 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3792.1 total,   2673.3 free,    495.4 used,    711.4 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3296.7 avail Mem
              *** FILESYSTEM ***
              udev           devtmpfs  1.6G     0  1.6G   0% /dev
              tmpfs          tmpfs     380M  1.4M  378M   1% /run
              /dev/mmcblk0p2 ext4       58G  6.1G   49G  11% /
              tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
              tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
              [Tue Sep  3 13:13:49 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:59:95:2E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e6691f19-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              [Tue Sep  3 13:13:52 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
              [Tue Sep  3 13:13:54 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
              | `-/sys/fs/fuse/connections                            fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
              | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2583
              |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=1668348k,nr_inodes=417087,mode=755
              |-/run                                                  tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
              | `-/run/user/1000                                      tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
              |   |-/run/user/1000/gvfs                               gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              |   `-/run/user/1000/doc                                portal         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              /var:
              795M    /var/
              207M    /var/log
              206M    /var/log/journal/29e1cae54c5f42aba99c823242ab5946
              198M    /var/lib
              Archived and active journals take up 205.8M in the file system.
              4.0K    /opt/iobroker/backups/
              15M     /opt/iobroker/iobroker-data/files
              13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
              1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
              652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
              384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller_D-if00-port0
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              At least one iobroker host is running.
              Objects type: jsonl
              States  type: jsonl
              admin:          6.17.14
              javascript:     "javascript" not found
              Adapter State
              + instance is alive
              Adapter    "admin"        : 7.0.23   , installed 6.17.14 [Updatable]
              Adapter    "backitup"     : 3.0.19   , installed 2.11.0 [Updatable]
              Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
              Adapter    "rpi2"         : 1.3.2    , installed 2.0.0
              Objects and States
              Objects:        13068
              States:         13756
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6789       789/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          9225       773/cupsd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          6791       789/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          9224       773/cupsd
              udp        0      0 0.0.0.0:43551           0.0.0.0:*                           104        3026       582/avahi-daemon: r
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          7037       1085/cups-browsed
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3024       582/avahi-daemon: r
              udp6       0      0 fe80::59f1:774b:474:546 :::*                                0          7101       704/NetworkManager
              udp6       0      0 fe80::e7c:a388:984::546 :::*                                0          8434       704/NetworkManager
              udp6       0      0 :::41969                :::*                                104        3027       582/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        3025       582/avahi-daemon: r
              2024-09-03 13:25:22.644  - warn: ds18b20.1 (1975) Error reading sensor 28-01144f959aaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f959aaa/w1_slave'
              2024-09-03 13:25:23.522  - warn: ds18b20.1 (1975) Error reading sensor 28-01144fc984aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fc984aa/w1_slave'
              2024-09-03 13:25:23.524  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a2793d5d: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a2793d5d/w1_slave'
              2024-09-03 13:25:23.527  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a279ee0c: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a279ee0c/w1_slave'
              2024-09-03 13:25:23.529  - warn: ds18b20.1 (1975) Error reading sensor 28-0120506f240b: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0120506f240b/w1_slave'
              2024-09-03 13:26:22.642  - warn: ds18b20.1 (1975) Error reading sensor 28-01144f959aaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f959aaa/w1_slave'
              2024-09-03 13:26:23.522  - warn: ds18b20.1 (1975) Error reading sensor 28-01144fc984aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fc984aa/w1_slave'
              2024-09-03 13:26:23.525  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a2793d5d: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a2793d5d/w1_slave'
              2024-09-03 13:26:23.526  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a279ee0c: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a279ee0c/w1_slave'
              2024-09-03 13:26:23.528  - warn: ds18b20.1 (1975) Error reading sensor 28-0120506f240b: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0120506f240b/w1_slave'
              2024-09-03 13:27:22.643  - warn: ds18b20.1 (1975) Error reading sensor 28-01144f959aaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f959aaa/w1_slave'
              2024-09-03 13:27:23.522  - warn: ds18b20.1 (1975) Error reading sensor 28-01144fc984aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fc984aa/w1_slave'
              2024-09-03 13:27:23.523  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a2793d5d: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a2793d5d/w1_slave'
              2024-09-03 13:27:23.525  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a279ee0c: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a279ee0c/w1_slave'
              2024-09-03 13:27:23.526  - warn: ds18b20.1 (1975) Error reading sensor 28-0120506f240b: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0120506f240b/w1_slave'
              2024-09-03 13:28:22.643  - warn: ds18b20.1 (1975) Error reading sensor 28-01144f959aaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f959aaa/w1_slave'
              2024-09-03 13:28:23.526  - warn: ds18b20.1 (1975) Error reading sensor 28-01144fc984aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fc984aa/w1_slave'
              2024-09-03 13:28:23.528  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a2793d5d: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a2793d5d/w1_slave'
              2024-09-03 13:28:23.529  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a279ee0c: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a279ee0c/w1_slave'
              2024-09-03 13:28:23.530  - warn: ds18b20.1 (1975) Error reading sensor 28-0120506f240b: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0120506f240b/w1_slave'
              2024-09-03 13:29:22.643  - warn: ds18b20.1 (1975) Error reading sensor 28-01144f959aaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f959aaa/w1_slave'
              2024-09-03 13:29:23.526  - warn: ds18b20.1 (1975) Error reading sensor 28-01144fc984aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fc984aa/w1_slave'
              2024-09-03 13:29:23.528  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a2793d5d: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a2793d5d/w1_slave'
              2024-09-03 13:29:23.529  - warn: ds18b20.1 (1975) Error reading sensor 28-0316a279ee0c: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a279ee0c/w1_slave'
              2024-09-03 13:29:23.530  - warn: ds18b20.1 (1975) Error reading sensor 28-0120506f240b: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0120506f240b/w1_slave'
              CodierknechtC HomoranH 2 Antworten Letzte Antwort
                und bei den slaves?
                SMSS Offline
                SMSS Offline
                SMS
                @homoran PapaHuette:
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                   Static hostname: PapaHuette
                         Icon name: computer
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 14:28:47 up 18 min,  1 user,  load average: 0.34, 0.11, 0.05
                CPU threads: 4
                Current issues:
                               Local time: Tue 2024-09-03 14:28:48 CEST
                           Universal time: Tue 2024-09-03 12:28:48 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.8G        291M        7.3G        0.0K        225M        7.4G
                Swap:            99M          0B         99M
                Total:          7.9G        291M        7.4G
                         7812 M total memory
                          291 M used memory
                          354 M active memory
                           68 M inactive memory
                         7294 M free memory
                           32 M buffer memory
                          193 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                top - 14:28:48 up 18 min,  1 user,  load average: 0.34, 0.11, 0.05
                Tasks: 159 total,   1 running, 158 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  1.5 us,  1.5 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   7812.3 total,   7294.9 free,    291.2 used,    226.3 buff/cache
                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7408.3 avail Mem
                *** FILESYSTEM ***
                /dev/root      ext4       15G  4.0G  9.6G  30% /
                devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     1.6G  832K  1.6G   1% /run
                /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
                tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                [Tue Sep  3 14:10:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:9D:54 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a622e112-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Tue Sep  3 14:10:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Tue Sep  3 14:10:21 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Tue Sep  3 14:10:23 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=3735680k,nr_inodes=933920,mode=755
                | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755
                | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000
                `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                /var:
                1.8G    /var/
                1.2G    /var/log/journal/a72fb28f007b470eaff3aacdf7e11b84
                1.2G    /var/log
                287M    /var/cache
                Archived and active journals take up 1.1G in the file system.
                1.4M    /opt/iobroker/iobroker-data/
                1.1M    /opt/iobroker/iobroker-data/files
                472K    /opt/iobroker/iobroker-data/files/discovery.admin
                384K    /opt/iobroker/iobroker-data/files/backitup.admin
                252K    /opt/iobroker/iobroker-data/files/admin.admin
                200K    /opt/iobroker/iobroker-data/files/discovery.admin/words.js
                148K    /opt/iobroker/iobroker-data/files/backitup.admin/words.js
                136K    /opt/iobroker/iobroker-data/objects.jsonl
                120K    /opt/iobroker/iobroker-data/files/discovery.admin/index_m.html
                108K    /opt/iobroker/iobroker-data/files/discovery.admin/index.html
                USB-Devices by-id:
                No Devices found 'by-id'
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.13.16
                Adapter State
                + instance is alive
                Adapter    "admin"        : 7.0.23   , installed 6.13.16 [Updatable]
                Adapter    "backitup"     : 3.0.19   , installed 2.8.1  [Updatable]
                Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
                Adapter    "ds18b20"      : 2.0.5    , installed 2.0.4  [Updatable]
                Adapter    "systeminfo"   : 1.2.0    , installed 1.1.0  [Updatable]
                Adapter    "worx"         : 3.0.2    , installed 2.3.2  [Updatable]
                Objects and States
                Objects:        13068
                States:         13756
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Pending Updates: 0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12683      534/sshd: /usr/sbin
                tcp6       0      0 :::22                   :::*                    LISTEN      0          12685      534/sshd: /usr/sbin
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14244      720/dhcpcd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1611       399/avahi-daemon: r
                udp        0      0 0.0.0.0:38158           0.0.0.0:*                           108        1613       399/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          1795       720/dhcpcd
                udp6       0      0 :::50365                :::*                                108        1614       399/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        1612       399/avahi-daemon: r
                2024-09-03 14:11:23.659  - warn: systeminfo.3 (1008) Error TypeError: Cannot read properties of null (reading 'toString') in doPoll for System.Led_Red
                2024-09-03 14:11:24.159  - info: host.PapaHuette instance system.adapter.worx.2 in version "2.3.2" started with pid 1028
                2024-09-03 14:11:24.343  - warn: systeminfo.3 (1008) Error TypeError: Cannot read properties of null (reading 'toString') in doPoll for HP_Photosmart_7520.[name/value]
                2024-09-03 14:11:27.814  - warn: systeminfo.3 (1008) Unhandled error in main: TypeError: Cannot read private member #objects from an object whose class did not declare it
                2024-09-03 14:11:27.873  - info: worx.2 (1028) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.worx, node: v20.17.0, js-controller: 6.0.11
                2024-09-03 14:11:27.899  - info: worx.2 (1028) Login to worx
                2024-09-03 14:11:29.095  - info: worx.2 (1028) Connected to worx server
                2024-09-03 14:11:29.275  - info: worx.2 (1028) Found 1 devices
                2024-09-03 14:11:29.276  - info: worx.2 (1028) Found device EVA with id 2019A0000005000140DB
                2024-09-03 14:11:29.515  - warn: worx.2 (1028) INFORMATION - Change common: worx.2.2019A0000005000140DB.mower.wifiQuality
                2024-09-03 14:11:29.591  - warn: worx.2 (1028) INFORMATION - Change common: worx.2.2019A0000005000140DB.mower.batteryState
                2024-09-03 14:11:29.604  - warn: worx.2 (1028) INFORMATION - Change common: worx.2.2019A0000005000140DB.mower.batteryTemperature
                2024-09-03 14:11:29.619  - warn: worx.2 (1028) INFORMATION - Change common: worx.2.2019A0000005000140DB.mower.batteryVoltage
                2024-09-03 14:11:29.656  - info: worx.2 (1028) Multi-ZoneKeeper found! Create State : zoneKeeper
                2024-09-03 14:11:30.014  - info: worx.2 (1028) DoubleShedule found, create states...
                2024-09-03 14:11:30.131  - info: worx.2 (1028) OneTimeShedule found, create states...
                2024-09-03 14:11:30.140  - info: worx.2 (1028) Firmware found, create states...
                2024-09-03 14:11:30.432  - info: worx.2 (1028) Create folder activityLog and set states.
                2024-09-03 14:11:30.711  - info: worx.2 (1028) Create product folder and states for WR141E
                2024-09-03 14:11:31.412  - info: worx.2 (1028) Torque control found, create states...
                2024-09-03 14:11:31.461  - info: worx.2 (1028) Autolock found! Create State : AutoLock
                2024-09-03 14:11:31.507  - info: worx.2 (1028) Autolock found! Create State : AutoLockTimer
                2024-09-03 14:11:31.655  - info: worx.2 (1028) Start MQTT connection
                2024-09-03 14:11:32.140  - info: worx.2 (1028) MQTT connected to: iot.eu-west-1.worxlandroid.com
                2024-09-03 14:11:32.221  - info: worx.2 (1028) Request Counter: 1
                  und bei den slaves?
                  SMSS Offline
                  SMSS Offline
                  SMS
                  @homoran MptionPi
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                     Static hostname: MotionEye
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   14:28:52 up 18 min,  2 users,  load average: 0.58, 0.43, 0.30
                  CPU threads: 4
                  Current issues:
                                 Local time: Tue 2024-09-03 14:28:52 CEST
                             Universal time: Tue 2024-09-03 12:28:52 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            7.8G        430M        7.1G        0.0K        270M        7.3G
                  Swap:            99M          0B         99M
                  Total:          7.9G        430M        7.2G
                           7812 M total memory
                            430 M used memory
                            532 M active memory
                             75 M inactive memory
                           7110 M free memory
                             32 M buffer memory
                            238 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  top - 14:28:52 up 18 min,  2 users,  load average: 0.58, 0.43, 0.30
                  Tasks: 157 total,   1 running, 156 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  1.5 us,  2.9 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7812.3 total,   7110.5 free,    430.6 used,    271.2 buff/cache
                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7268.0 avail Mem
                  *** FILESYSTEM ***
                  /dev/root      ext4       29G   13G   15G  47% /
                  tmpfs          tmpfs     3.9G   16K  3.9G   1% /dev/shm
                  tmpfs          tmpfs     1.6G  836K  1.6G   1% /run
                  [Tue Sep  3 14:10:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:94:B6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e1cec37a-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Tue Sep  3 14:10:41 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Sep  3 14:10:41 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Tue Sep  3 14:10:44 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  /var:
                  3.6G    /var/
                  3.0G    /var/log
                  2.9G    /var/log/journal/f844222954834511854453c716d9071c
                  393M    /var/cache
                  Archived and active journals take up 2.8G in the file system.
                  4.1M    /opt/iobroker/iobroker-data/
                  1.2M    /opt/iobroker/iobroker-data/files
                  420K    /opt/iobroker/iobroker-data/files/backitup.admin
                  2.7M    /opt/iobroker/iobroker-data/objects.jsonl
                  276K    /opt/iobroker/iobroker-data/states.jsonl
                  164K    /opt/iobroker/iobroker-data/files/backitup.admin/words.js
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.13.16
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        13068
                  States:         13756
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          10959      556/motion
                  tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN      0          10958      556/motion
                  tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          10960      556/motion
                  tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          14534      401/python2
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14441      515/sshd: /usr/sbin
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14443      515/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:36850           0.0.0.0:*                           108        10908      389/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14225      753/dhcpcd
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10906      389/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          14252      753/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        10907      389/avahi-daemon: r
                  udp6       0      0 :::34901                :::*                                108        10909      389/avahi-daemon: r
                  2024-09-03 14:10:10.107  - info: host.MotionEye stopInstance system.adapter.systeminfo.2 send kill signal
                  2024-09-03 14:10:10.164  - info: host.MotionEye force terminating
                  2024-09-03 14:10:23.263  - info: host.MotionEye iobroker.js-controller version 6.0.11 js-controller starting
                  2024-09-03 14:10:23.269  - info: host.MotionEye Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                  2024-09-03 14:10:23.270  - info: host.MotionEye hostname: MotionEye, node: v20.17.0
                  2024-09-03 14:10:23.271  - info: host.MotionEye ip addresses: 2001:16b8:a516:1000:597c:7ba7:31d3:6539 fe80::a782:a386:773a:7150
                  2024-09-03 14:11:26.775  - error: host.MotionEye No connection to databases possible, restart
                  2024-09-03 14:11:26.782  - info: host.MotionEye iobroker _restart
                  2024-09-03 14:11:32.990  - info: host.MotionEye iobroker.js-controller version 6.0.11 js-controller starting
                  2024-09-03 14:11:32.996  - info: host.MotionEye Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                  2024-09-03 14:11:32.998  - info: host.MotionEye hostname: MotionEye, node: v20.17.0
                  2024-09-03 14:11:32.999  - info: host.MotionEye ip addresses: 192.168.178.72 2001:16b8:a516:1000:597c:7ba7:31d3:6539 fe80::a782:a386:773a:7150
                  2024-09-03 14:11:33.525  - info: host.MotionEye connected to Objects and States
                  2024-09-03 14:11:33.554  - info: host.MotionEye added notifications configuration of host
                  2024-09-03 14:11:33.563  - info: host.MotionEye Node.js version has changed from 20.15.1 to 20.17.0
                  2024-09-03 14:11:33.637  - info: host.MotionEye Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                  2024-09-03 14:11:34.574  - info: host.MotionEye 55 instances found
                  2024-09-03 14:11:34.612  - info: host.MotionEye starting 2 instances
                  2024-09-03 14:11:35.283  - info: host.MotionEye instance system.adapter.rpi2.2 in version "1.3.2" started with pid 966
                  2024-09-03 14:11:38.438  - info: rpi2.2 (966) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.17.0, js-controller: 6.0.11
                  2024-09-03 14:11:39.237  - info: host.MotionEye instance system.adapter.systeminfo.2 in version "1.1.0" started with pid 1019
                  2024-09-03 14:11:43.186  - info: systeminfo.2 (1019) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v20.17.0, js-controller: 6.0.11
                  2024-09-03 14:11:43.212  - error: systeminfo.2 (1019) err from getObjectList: TypeError: Cannot read private member #objects from an object whose class did not declare it
                  2024-09-03 14:11:43.241  - info: systeminfo.2 (1019) Startup Systeminfo Adapter systeminfo.2: {  startup: '#\n' +    'gpio mode 1 output\n' +    '#rpi: echo none >/sys/class/leds/led0/trigger\n' +    'echo none >/sys/class/leds/green_led/trigger',  items: [    {      name: 'System.Temperature',      type: 'file',      source: '/sys/class/thermal/thermal_zone0/temp',      regexp: '',      conv: 'number',      role: 'value.temperature|°C',      write: '',      sched: '*/5 * * * *'    },    {      name: '-System.Memory_[used, free, available]',      type: 'exec',      source: 'free -k',      regexp: 'Mem\\:\\s+\\d+\\s+(\\d+)\\s+(\\d+)\\s+\\d+\\s+\\d+\\s+(\\d+)',      conv: '@/1000',      role: 'number|MB',      write: '',      sched: '1 * * * * '    },    {      name: 'GPIO.1',      type: 'exec',      source: 'gpio read 1',      regexp: '',      conv: '!parseInt(@)',      role: 'switch',      write: "gpio write 1 @(@ ?  '0' : '1')",      sched: '*/20 * * * * *'    },    {      name: 'Currency.[currency/rate]',      type: 'web',      source: 'https://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml',      regexp: "Cube.Cube.Cube[?(@.currency=='USD' || @.currency=='GBP')]",      conv: 'xml',      role: 'number | €/?',      write: '',      sched: '19:10:10'    },    {      name: 'Currency.BTC_CNY',      type: 'web',      source: 'https://www.alphavantage.co/query?function=CURRENCY_EXCHANGE_RATE&from_currency=BTC&to_currency=CNY&apikey=demo',      regexp: '[0][4]',      conv: 'json',      role: 'number | CNY',      write: '',      sched: '19:10:10'    },    {      name: 'UWZ',      type: 'web',      source: 'http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=UWZAT02402',      regexp: '..translationsShortText.DE',      conv: 'json',      role: 'json',      write: '',      sched: '*:1'    },    {      name: '-TestSystem.processes.[command/pcpu]',      type: 'info',      source: 'processes',      regexp: "list[?(@.user == 'pi')]",      conv: '',      role: '',      write: '',      sched: '*:2'    },    {      name: '-XS2.[name/value]',      type: 'web',      source: "http://xs1/control.html'",      regexp: `{"l[?(@.value  !== null )]": {"l[tr]": { '![@.children()]':0, name: {_eq:1}, value: {_eq:2, _conv:"parseInt(@.slice(0,-1))"}}, _filter: ($) => $[0].childNodes.length==3}}`,      conv: 'html',      role: '',      write: '',      sched: '`:*:*/20'    },    {      name: 'MSFT.[*]',      type: 'web',      source: 'https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&symbol=MSFT&apikey=demo',      regexp: '[1:2][0:1]',      conv: 'json',      role: 'number',      write: '',      sched: '19:10:10'    },    {      name: 'System.[Mem_used, Mem_free, Swap_used]',      type: 'info',      source: 'mem',      regexp: '[used,free,swapused]',      conv: 'parseInt(@*(1000/1024/1024))/1000',      role: 'number|MB',      write: '',      sched: '0/30 * * * *'    },    {      name: 'System.Software.[*]',      type: 'info',      source: 'osInfo',      regexp: '',      conv: '',      role: 'string',      write: '',      sched: '*/3:58'    },    {      name: 'System.Software.[*]',      type: 'info',      source: 'versions',      regexp: '',      conv: '',      role: 'string',      write: '',      sched: '*/3:58'    },    {      name: 'System.FileSystem.[fs/use]',      type: 'info',      source: 'fsSize',      regexp: '*',      conv: '',      role: 'number|%',      write: '',      sched: '*/3:58'    },    {      name: 'System.FileSystem.IO_[Read,Write]',      type: 'info',      source: 'fsStats',      regexp: '[rx,wx]',      conv: 'parseInt(@*(1000/1024/1024))/1000',      role: 'number|MB',      write: '',      sched: '*:/1'    },    {      name: 'System.Network.[iface/]',      type: 'info',      source: 'networkInterfaces',      regexp: '*',      conv: '',      role: '',      write: '',      sched: '*/3:58'    },    {      name: 'System.Network.Connections.[name/value]',      type: 'info',      source: 'networkConnections',      regexp: "[*][!(@.localaddress == @.peeraddress ? null :  {name:`${@.protocol}:${@.localaddress.replace(/\\./g,'_')}:${@.localport}`, value:`${@.state}:${@.peeraddress}:${@.peerport}`})]",      conv: '',      role: 'string',      write: '',      sched: '*:/1'    },    {      name: 'System.Network.MB_[Received,Sent]',      type: 'info',      source: 'networkStats',      regexp: '[rx,tx]',      conv: 'parseInt(@*(1000/1024/1024))/1000',      role: 'number|MB',      write: '',      sched: '*:/1'    },    {      name: 'System.Network.FritzBox.[*]',      type: 'info',      source: 'inetChecksite("http://fritz.box")',      regexp: '',      conv: '',      role: '',      write: '',      sched: '*:/1'    },    {      name: 'System.Network.Latency',      type: 'info',      source: 'inetLatency',      regexp: '',      conv: '',      role: 'number|ms',      write: '',      sched: '*:/1'    },    {      name: 'System.Load.[Load,User,System,Idle]',      type: 'info',      source: 'currentLoad',      regexp: '[currentload, currentload_user, currentload_system, currentload_idle]',      conv: 'parseInt(@*1000)/1000',      role: 'number|ms',      write: '',      sched: '*:*:/10'    }  ]}
                  2024-09-03 14:11:47.442  - warn: systeminfo.2 (1019) Unhandled error in main: TypeError: Cannot read private member #objects from an object whose class did not declare it
                  • SMSS SMS
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           209M          0B        209M
                             3792 M total memory
                              494 M used memory
                              646 M active memory
                             2673 M free memory
                               41 M buffer memory
                              669 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    *** FILESYSTEM ***
                    /var:
                    795M    /var/
                    207M    /var/log
                    198M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.17.14
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        13068
                    States:         13756
                    Pending Updates: 0
                    CodierknechtC Offline
                    Codierknecht
                    @sms
                    Auch auf den Slaves sollte der Desktop abgeschaltet werden.
                    Der frisst nur unnötig Ressourcen und ist eine zusätzliche Fehlerquelle.
                    HmIP|ZigBee|Tasmota|Unifi
                    Zabbix Certified Specialist
                    SMSS 1 Antwort Letzte Antwort
                      und bei den slaves?
                      SMSS Offline
                      SMSS Offline
                      SMS
                      #66
                      @homoran Gartenklo
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: Gartenklo
                             Icon name: computer
                          Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.1
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       13:28:45 up 16 min,  2 users,  load average: 0.37, 0.20, 0.11
                      CPU threads: 4
                      Current issues:
                                     Local time: Tue 2024-09-03 13:28:46 BST
                                 Universal time: Tue 2024-09-03 12:28:46 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            1.9G        274M        1.5G        1.2M        237M        1.7G
                      Swap:           209M          0B        209M
                      Total:          2.1G        274M        1.7G
                               1846 M total memory
                                262 M used memory
                                288 M active memory
                                 61 M inactive memory
                               1417 M free memory
                                 26 M buffer memory
                                199 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      top - 13:28:46 up 16 min,  2 users,  load average: 0.37, 0.20, 0.11
                      Tasks: 170 total,   1 running, 169 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   1846.9 total,   1415.4 free,    263.8 used,    226.7 buff/cache
                      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   1583.2 avail Mem
                      *** FILESYSTEM ***
                      udev           devtmpfs  660M     0  660M   0% /dev
                      tmpfs          tmpfs     185M  1.2M  184M   1% /run
                      /dev/mmcblk0p2 ext4       29G  3.5G   24G  13% /
                      tmpfs          tmpfs     924M     0  924M   0% /dev/shm
                      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                      tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
                      [Tue Sep  3 13:11:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5C:62:46 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d88e2e88-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                      [Tue Sep  3 13:11:58 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                      [Tue Sep  3 13:12:00 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3420
                      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=675396k,nr_inodes=168849,mode=755
                      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=189128k,mode=755
                      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=189124k,nr_inodes=47281,mode=700,uid=1000,gid=1000
                      /var:
                      875M    /var/
                      301M    /var/log
                      300M    /var/log/journal/8b083168c8bc4150ad1b17664abb30f7
                      209M    /var/cache
                      Archived and active journals take up 299.8M in the file system.
                      528K    /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.16
                      Adapter State
                      + instance is alive
                      Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
                      Adapter    "rpi2"         : 1.3.2    , installed 2.0.0-alpha.6
                      Objects and States
                      Objects:        13068
                      States:         13756
                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6237       650/sshd: /usr/sbin
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          6239       650/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:47287           0.0.0.0:*                           104        4655       439/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4653       439/avahi-daemon: r
                      udp6       0      0 :::55418                :::*                                104        4656       439/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                104        4654       439/avahi-daemon: r
                      udp6       0      0 fe80::9233:c5ee:213:546 :::*                                0          4015       524/NetworkManager
                      /1024
                      2024-09-03 13:25:54.984  - error: rpi2.4 (775) Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
                      /dev/mmcblk0p2  30097288 3619380  24929608  13% /
                      /1024
                      2024-09-03 13:25:55.084  - error: rpi2.4 (775) Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
                      /1024
                      2024-09-03 13:26:54.974  - error: rpi2.4 (775) Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
                      /1024
                      2024-09-03 13:26:55.054  - error: rpi2.4 (775) Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
                      /1024
                      2024-09-03 13:27:54.992  - error: rpi2.4 (775) Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
                      /dev/mmcblk0p2  30097288 3618864  24930124  13% /
                      /1024
                      2024-09-03 13:27:55.075  - error: rpi2.4 (775) Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
                      /1024
                      2024-09-03 13:28:55.040  - error: rpi2.4 (775) Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
                      /dev/mmcblk0p2  30097288 3618948  24930040  13% /
                      /1024
                      2024-09-03 13:28:55.156  - error: rpi2.4 (775) Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
                      /1024
                      • CodierknechtC Codierknecht
                        @sms
                        SMSS Offline
                        SMSS Offline
                        SMS
                        #67
                        @codierknecht erledigt:
                        pi@Kellerkind:~ $ sudo systemctl set-default multi-user.target
                        Removed "/etc/systemd/system/default.target".
                        Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
                        pi@Kellerkind:~ $
                        • SMSS SMS
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           209M          0B        209M
                                   3792 M total memory
                                    494 M used memory
                                    646 M active memory
                                   2673 M free memory
                                     41 M buffer memory
                                    669 M swap cache
                                    199 M total swap
                                      0 M used swap
                                    199 M free swap
                          *** FILESYSTEM ***
                          /var:
                          795M    /var/
                          207M    /var/log
                          198M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.17.14
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        13068
                          States:         13756
                          Pending Updates: 0
                          #68
                          beim Kellerkind!
                          und im Gartenklo
                            beim Kellerkind!
                            und im Gartenklo
                            SMSS Offline
                            SMSS Offline
                            SMS
                            #69
                            @homoran geändert
                            • SMSS SMS
                              @homoran geändert
                              #70
                              @sms So, dann müsste das Großreinemachen beendet sein und wir können wieder zurück zum Programm.
                              Die Anregungen dazu hast du alle gelesen?
                              Insbesondere
                              https://forum.iobroker.net/post/1197438
                              und
                              https://forum.iobroker.net/post/1197440
                                Insbesondere
                                und
                                SMSS Offline
                                SMSS Offline
                                SMS
                                #71
                                @homoran so könnte es funktionieren:
                                HomoranH CodierknechtC 2 Antworten Letzte Antwort
                                • SMSS SMS
                                  #72
                                  ja, wobei ich gerade nicht alles zuordnen kann, was du da programmiert hast.
                                  Was genau schwebt dir vor dass passieren soll?
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    #73
                                    @homoran Das oben war jetzt nur ein Testaufbau zum Schauen ob es funktioniert.
                                    Der 11_Test wurde "wahr" bei erreichen der eingestellten Uhrzeit 14:45 Uhr. Das Andere war lediglich eine Ausgabe der aktuellen Uhrzeit, zum Schauen ob die stimmt.
                                    Nachher soll entweder die Spülmaschine, die Waschmaschine oder der Trockner zu einer bestimmten Uhrzeit starten. Was auch schon funktioniert hatte.
                                    Das eigentliche Problem wird die Uhrzeit mit Einstellung "London" gewesen sein. Das kann ich später mit dem Trockner mal ausprobieren.
                                    • SMSS SMS
                                      Codierknecht
                                      #74
                                      @sms
                                      In den Zeitplan kommt dann nur das Einschalten des Verbrauchers.
                                        @sms
                                        SMSS Offline
                                        SMSS Offline
                                        SMS
                                        #75
                                        @codierknecht So sieht das dann aus
                                        Variable Uhrzeit bedeutet, das ich die Vorwahl Uhrzeit eingestellt habe. Es gibt noch andere Vorwahlmöglichkeiten wie z.B. Solarproduktion >4000W.
                                        • SMSS SMS
                                          Codierknecht
                                          #76
                                          @sms
                                          Droht zu klappen.
                                          Allerdings nicht, wenn zu der Zeit zufälligerweise noch die Waschmaschine läuft ;-)
                                          SMSS 2 Antworten Letzte Antwort
