  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. openDTU per MQTT auslesen und steuern
    6.4k
64 Beiträge 9 Kommentatoren 26.4k Aufrufe 8 Beobachtet
  • E ed.fischer
    @mickym Servus, ich benutze Home Assistant. Als Add-Ons habe ich Mosquitto und Node-Red.
    Entschuldigung wegen meines fehlenden Knowhows.
    Export von Node-Red:
    [{"id":"f270af8063daa8ba","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"fd0281821d60a8bf","type":"debug","z":"f270af8063daa8ba","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":380,"y":220,"wires":[]},{"id":"b5af40868ab82ebc","type":"mqtt in","z":"f270af8063daa8ba","name":"Subscribe OpenDTU","topic":"cmd/limit_nonpersistent_relative","qos":"0","datatype":"auto-detect","broker":"3c02452ae7d56b46","nl":false,"rap":true,"rh":0,"inputs":0,"x":190,"y":220,"wires":[["fd0281821d60a8bf"]]},{"id":"81cd3aca1855bd7d","type":"inject","z":"f270af8063daa8ba","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"11 09 * * *","once":false,"onceDelay":0.1,"topic":"cmd/limit_nonpersistent_relative","payload":"10","payloadType":"num","x":170,"y":120,"wires":[["5f706a5e20b2d481"]]},{"id":"5f706a5e20b2d481","type":"mqtt out","z":"f270af8063daa8ba","name":"Publish OpenDTU","topic":"cmd/limit_nonpersistent_relative","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"3c02452ae7d56b46","x":390,"y":120,"wires":[]},{"id":"3c02452ae7d56b46","type":"mqtt-broker","name":"Mqtt OpenDTU","broker":"192.168.178.66","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
    Ich verusuche zu verstehen, wie kann ich den Wert 10 (von solar/116183066760/cmd/status/limit_relative) bei DTU schreiben kann.
    1000 Dank vorab.
    Gruss
    Ed
    mickymM Offline
    mickymM Offline
    mickym
    @ed-fischer Mal abgesehen - dass man einen Export in CodeTags packt, wenn man den hier postet - da man den sonst oft nicht importieren kann
    passt doch alles - im Prinzip.
    Du musst halt nur - falls Du Dein Basetopic solar genannt hast nicht nach
    publishen, sondern halt den den ganzen Pfad in das topic schreiben, also solar/116183066760/cmd/status/limit_relative
    So wie ich die Github Seite aber verstehe,
    musst Du nicht solar/116183066760/cmd//status/limit_relative als topic beschreiben, sondern ohne status also: solar/116183066760/cmd/limit_persistent_relative
    Der Status ist NUR ZUM LESEN - deswegen das R, cmd ist zum schreiben deshalb W
    E 1 Antwort Letzte Antwort
    • mickymM mickym
      ed.fischer
      @mickym Wow, Es funz. 1000 Dank. 🙏 🙏 🙏
      Ich spiele jetzt noch damit weiter.
      DANKE!!!!
      Gruss
      Ed
      L 1 Antwort Letzte Antwort
      • E ed.fischer
        DANKE!!!!
        Gruss
        Ed
        Laser
        schrieb am zuletzt editiert von Laser
        @mickym ich habe diesen Datenpunkt angelegt (mehr brauche ich erst mal nicht):
        Darin steht das:
          "common": {
            "name": "limit_nonpersistent_absolute\"",
            "desc": "Manuell erzeugt",
            "role": "state",
            "type": "number",
            "read": true,
            "write": true,
            "def": 0
          "type": "state",
          "native": {},
          "_id": "mqtt.3.cmd.limit_nonpersistent_absolute",
          "acl": {
            "object": 1638,
            "state": 1638,
            "owner": "system.user.admin",
          "from": "system.adapter.admin.1",
          "user": "system.user.admin",
          "ts": 1724690709025
        Ich kann den Wert beschreiben, ohne "bestätigt" den Wert setzen. Die Zahl wird grün, dann wieder rot. Es tut sich aber nichts im Umrichter.
        Ich kann allerdings erst morgen weiter daran arbeiten.
        • L Laser
          Darin steht das:
            "common": {
              "role": "state",
              "type": "number",
              "read": true,
              "write": true,
              "def": 0
            "type": "state",
            "native": {},
            "acl": {
              "object": 1638,
              "state": 1638,
            "ts": 1724690709025
          mickymM Offline
          mickymM Offline
          mickym
          @laser Also ich bin mit diesem openDTU ja nicht wirklich vertraut, sondern hab das ja nur aus der Github Beschreibung damals irgendwo rausgezogen.
          Wenn sich nichts tut, dann hört Dein Gerät nicht auf dieses topic (datenpunkt). Den Datenpunkt den Du angelegt hast, würde bedeuten, dass Dein Gerät auf das topic
          cmd/limit_nonpersistent_absolute
          hören würde - und ich glaube das ist viel zu unspezifisch. Da fehlt noch irgendwas vorne dran.
          Wenn sich Dein Gerät meldet oder wie unten in dem Thread
          ist dieser ganze cmd Ast ja viel tiefer angelegt.
          • mickymM mickym
            Laser
            @mickym Danke, da ich den Inverter über Nacht brauche, werde ich erst mal mit dem openDTU-Adapter weitersteuern. Der funktioniert aber nicht zuverlässig. Deshalb will ich versuchen, den Sollwert über mqtt zu senden.
            Der cmd Ast ist an der falschen Position? Muß ich korrigieren.
            • L Laser
              mickymM Offline
              mickymM Offline
              mickym
              @laser sagte in openDTU per MQTT auslesen und steuern:
              Ja
              schau mal Du musst irgendwo den ganzen cmd Ast da anlegen, wo parallel auch status etc. steht. Also wahrscheinlich unter
              solar/..../
              Die gesamte Dokumentation ist ja inzwischen wohl hier hin gewandert: https://www.opendtu.solar/firmware/mqtt_topics/#dc-input-channel-topics
              Wie Du daraus ersehen kannst, muss das cmd topic auf der gleichen Ebene wie das status topic liegen.
              • mickymM mickym
                Ja
                solar/..../
                Laser
                @mickym ich versuche es mal dort:
                • L Laser
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @laser Ne mach mal den Ordner mit der Zahl auf, ob da status topic sind.
                  • mickymM mickym
                    Laser
                    @mickym ja, dort ist "status":
                    so? Dort wird auch richtig gelesen.
                    • L Laser
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @laser Nein auf der Ebene vom status - also den cmd Ordner direkt unter der Nummer - das ist die serial Nummer
                      Siehst Du ja - grün lesen (R), orange (W) schreiben.
                      Also cmd Ordner direkt unter dem 1121... Ordner.
                      Wie gesagt die topics auf die ein Gerät hört, sind in der Firmware fest definiert.
                      Gilt auch für den absoluten Wert:
                      • mickymM mickym
                        Laser
                        @mickym cmd rutscht immer wieder nach unten. "Ordner" heißt bei mir aber "Kanal"?
                        Der Text "limit_..." muß natürlich absolut richtig geschrieben sein.
                        • L Laser
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @laser Ja das passt aber so. Das mit dem Kanal - das hat mit admin5 eingeführt, ist aber für mqtt Schall und Rauch und ohne Bedeutung. Müsste so funktionieren.
                          Ich weiss zwar nicht, ob der Name angepasst werden muss - aber im Prinzip muss dann das mqtt topic wohl
                          solar/112183818346/cmd/limit_nonpersistent_absolute
                          heißen.
                          Wenn du den mqtt Adapter als Broker verwendest, gibts da auch manchmal Probleme. Ich nutze immer mosquitto und den mqtt Adapter immer als Client.
                          • mickymM mickym
                            heißen.
                            Laser
                            @mickym
                            Es tut sich einfach nichts im Umrichter- Limit. Ich benutze den mqtt Adapter.
                            • L Laser
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @laser
                              Der 2. Datenpunkt ist definitiv verkehrt nur der Name des 1. Datenpunktes mal anpassen.
                              Normalerweise steht im Namen - das originäre Mqtt topic
                              Ich glaube auch in den Objektdaten unter native
                                "_id": "mqtt.1.shellies.licht.wohnzimmer.decke.light.0.command",
                                "common": {
                                  "name": "shellies/licht/wohnzimmer/decke/light/0/command",
                                  "write": true,
                                  "read": true,
                                  "role": "variable",
                                  "desc": "mqtt client variable",
                                  "type": "string"
                                "native": {
                                  "topic": "shellies/licht/wohnzimmer/decke/light/0/command"
                                "type": "state",
                                "from": "system.adapter.mqtt.1",
                                "ts": 1670870062801,
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              Wie gesagt, wenn Du mehr mit mqtt machen willst, empfehle ich Dir wirklich mosquitto als mqtt Broker zu nutzen, da der Adapter in meinen Augen als Broker manche Merkwürdigkeiten aufweist.
                              • mickymM mickym
                                @laser
                                  "common": {
                                    "write": true,
                                    "read": true,
                                    "role": "variable",
                                    "type": "string"
                                  "native": {
                                  "type": "state",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                Laser
                                @mickym eigentlich wollte ich ja den openDTU- Adapter verwenden. Aber dort gibt es auch Probleme. Unter Anderem wird die openDTU vom Router nicht gefunden. Aber dann geht mqtt auch bloß nicht.
                                Heute packe ich das nicht mehr. Danke für die Hilfe. Evtl. löst sich über Nacht ein Knoten in mir. Ich schalte meine Akku-Entladeregelung erst mal auf den openDTU- Adapter um.
                                • L Laser
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @laser Wie gesagt, ich benutze mosquitto als Broker für die gesamte mqtt Kommunikation ist easy und den Client/Broker mqtt Adapter als Client. Das funktioniert prima und einfach.
                                  Ich habe kein openDTU, aber Du siehst, bei mir läuft alles mqtt von tasmota, shelly, zigbee2mqtt und owntracks alles über natives mqtt.
                                  • mickymM mickym
                                    Laser
                                    @mickym "mosquitto" ist wieder ein absolutes Neuland für mich. Da muß ich mich mit beschäftigen.
                                    • L Laser
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @laser Das ist easy.
                                      Mit
                                      sudo apt install mosquitto
                                      installieren (wenn es ein LINUX System) ist. Und dann in der Konfigurationsdatei nur Port und ggf. ein Passwort mit User erstellen.
                                      Ich verlinke Dir gleich noch eine Anleitung. Aber im Prinzip ist das easy und läuft immer unauffällig parallel.
                                      • mickymM mickym
                                        Mit
                                        Laser
                                        @mickym Das läuft bei mir auf einem Raspi4. Ich werde das morgen in Angriff nehmen.
                                        Wenn die Kiste natürlich mal abschmiert (hatte immer mal Defekte in der SSD), habe ich ein Installationsproblem von Null an anzufangen.
                                        • L Laser
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          Ok - ich such Dir noch eine Anleitung raus, ist aber easy. Ist englisch auch OK?
                                          L mickymM 2 Antworten Letzte Antwort
