  4. [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?
    1.0k
64 Beiträge 6 Kommentatoren 10.5k Aufrufe 5 Beobachtet
  • sigi234S sigi234
    @gaspode sagte in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
    @sigi234 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
    Alles gemacht wie du geschrieben hast. Fehler kommt noch.
    Hast du auch Diskusage manuell installiert?
    Im ioBroker Root Verzeichnis:
    npm i diskusage
    Ging das fehlerfrei?
    ***               Welcome to ioBroker.                 ***
    ***     Type 'iob help' for list of instructions.      ***
    ***                For more help see                   ***
    ***     https://github.com/ioBroker/ioBroker.docs      ***
    Your environment has been set up for using Node.js 20.16.0 (x64) and npm.
    C:\SmartHome>npm i diskusage
    npm error code 1
    npm error path C:\SmartHome\node_modules\diskusage
    npm error command failed
    npm error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild
    npm error gyp info it worked if it ends with ok
    npm error gyp info using node-gyp@10.1.0
    npm error gyp info using node@20.16.0 | win32 | x64
    npm error gyp info find Python using Python version 3.12.4 found at "C:\Users\Sigi\AppData\Local\Programs\Python\Python312\python.exe"
    npm error gyp ERR! find VS
    npm error gyp ERR! find VS msvs_version not set from command line or npm config
    npm error gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
    npm error gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details.
    npm error gyp ERR! find VS Failure details: undefined
    npm error gyp ERR! find VS checking VS2022 (17.11.35208.52) found at:
    npm error gyp ERR! find VS "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools"
    npm error gyp ERR! find VS - found "Visual Studio C++ core features"
    npm error gyp ERR! find VS - missing any VC++ toolset
    npm error gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
    npm error gyp ERR! find VS unsupported version "17.11.35208.52" found at "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools"
    npm error gyp ERR! find VS not looking for VS2015 as it is only supported up to Node.js 18
    npm error gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
    npm error gyp ERR! find VS **************************************************************
    npm error gyp ERR! find VS You need to install the latest version of Visual Studio
    npm error gyp ERR! find VS including the "Desktop development with C++" workload.
    npm error gyp ERR! find VS For more information consult the documentation at:
    npm error gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
    npm error gyp ERR! configure error
    npm error gyp ERR! stack Error: Could not find any Visual Studio installation to use
    npm error gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:116:11)
    npm error gyp ERR! stack at VisualStudioFinder.findVisualStudio (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:72:17)
    npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    npm error gyp ERR! stack at async createBuildDir (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:95:26)
    npm error gyp ERR! stack at async run (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18)
    npm error gyp ERR! System Windows_NT 10.0.19045
    npm error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    npm error gyp ERR! cwd C:\SmartHome\node_modules\diskusage
    npm error gyp ERR! node -v v20.16.0
    npm error gyp ERR! node-gyp -v v10.1.0
    npm error gyp ERR! not ok
    npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T06_57_48_846Z-debug-0.log
    C:\SmartHome>
    GaspodeG Offline
    GaspodeG Offline
    Gaspode
    schrieb am zuletzt editiert von Gaspode
    Ich schätze mal, das liegt daran:
    Sorry, da hab ich dich weiter oben wohl auf die falsche Fährte geschickt. Bei mir laufen die Build Tools 2019 auf dem Testrechner und 2017 auf dem Produktivrechner, also evtl. mal damit versuchen (ich hab es im Beitrag oben mal auf 2019 angepasst).
    • GaspodeG Gaspode
      sigi234S Online
      sigi234S Online
      @gaspode
      npm error code 1
      npm error gyp ERR! find Python
      npm error gyp ERR! find Python Python is not set from command line or npm configuration
      npm error gyp ERR! find Python Python is not set from environment variable PYTHON
      npm error gyp ERR! find Python checking if the py launcher can be used to find Python 3
      npm error gyp ERR! find Python - executable path is ""
      npm error gyp ERR! find Python - "" could not be run
      npm error gyp ERR! find Python checking if "python3" can be used
      npm error gyp ERR! find Python checking if "python" can be used
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe
      npm error gyp ERR! find Python - version is ""
      npm error gyp ERR! find Python - version is  - should be >=3.6.0
      npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python311\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python311-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python311-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files (x86)\Python311-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python310\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python310-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python310-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files (x86)\Python310-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files (x86)\Python39-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run
      npm error gyp ERR! find Python **********************************************************
      npm error gyp ERR! find Python You need to install the latest version of Python.
      npm error gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
      npm error gyp ERR! find Python you can try one of the following options:
      npm error gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
      npm error gyp ERR! find Python (accepted by both node-gyp and npm)
      npm error gyp ERR! find Python - Set the environment variable PYTHON
      npm error gyp ERR! find Python - Set the npm configuration variable python:
      npm error gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
      npm error gyp ERR! find Python For more information consult the documentation at:
      npm error gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
      npm error gyp ERR! stack Error: Could not find any Python installation to use
      npm error gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:306:11)
      npm error gyp ERR! stack at PythonFinder.findPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:164:17)
      npm error gyp ERR! stack at async configure (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:27:18)
      npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T07_42_55_666Z-debug-0.log
      C:\SmartHome>
      python3 ???
      GaspodeG 1 Antwort Letzte Antwort
      • GaspodeG Gaspode
        Achtung: Windows-System. Ich denke aber nicht, dass das Problem Windows spezifisch ist.
        Plötzlich wird bei jedem Adapter Update "node-gyp rebuild" ausgeführt. So genau weiß ich nicht seit wann.
        Das rebuild geht schief, weil ich node-gyp gar nicht eingerichtet habe (hab gar kein Python auf dem Server) und es eigentlich auch nicht brauche.
        $ iobroker upgrade backitup@3.0.16 --debug
        Update backitup from @3.0.15 to @3.0.16
        NPM version: 10.8.1
        Installing iobroker.backitup@3.0.16... (System call)
        > node-gyp rebuild
        gyp info using node-gyp@8.4.1
        gyp ERR! find Python gyp ERR! find Python Python is not set from command line or npm configuration gyp ERR! find Python Python is not set from environment variable PYTHON gyp ERR! find Python checking if "python3" can be used
        gyp ERR! find Python - "python3" is not in PATH or produced an error gyp ERR! find Python checking if "python" can be used gyp ERR! find Python - "python" is not in PATH or produced an error gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run
        gyp ERR! find Python - Set the environment variable PYTHON gyp ERR! find Python - Set the npm configuration variable python: gyp ERR! find Python npm config set python "C:\Path\To\python.exe" gyp ERR! find Python For more information consult the documentation at:
        gyp ERR! stack Error: Could not find any Python installation to use gyp ERR! stack at PythonFinder.fail (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:330:47) gyp ERR! stack at PythonFinder.runChecks (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:159:21) gyp ERR! stack at PythonFinder.<anonymous> (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:228:18) gyp ERR! stack at PythonFinder.execFileCallback (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:294:16) gyp ERR! stack at exithandler (node:child_process:430:5) gyp ERR! stack at ChildProcess.errorhandler (node:child_process:442:5)
        gyp ERR! System Windows_NT 10.0.19045 gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\ioBroker\\XXXXXXX\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" gyp ERR! cwd C:\ioBroker\XXXXXXX\node_modules\diskusage gyp ERR! node -v v20.16.0 gyp ERR! node-gyp -v v8.4.1 gyp ERR! not ok
        > unix-dgram@2.0.6 install
        > node-gyp rebuild
        gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe
        gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe
        gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe
        gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe
        gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37\python.exe
        gyp ERR! find Python - "C:\Program Files\Python36\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python36-32\python.exe gyp ERR! find Python - "C:\Program Files\Python36-32\python.exe" could not be run
        gyp ERR! stack at exithandler (node:child_process:430:5) gyp ERR! stack at ChildProcess.errorhandler (node:child_process:442:5) gyp ERR! stack at ChildProcess.emit (node:events:519:28) gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) gyp ERR! stack at onErrorNT (node:internal/child_process:484:16) gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
        gyp ERR! not ok
        added 1 package, changed 4 packages, and audited 1261 packages in 25s
        147 packages are looking for funding run `npm fund` for details
        66 vulnerabilities (6 low, 37 moderate, 22 high, 1 critical)
        To address issues that do not require attention, run: npm audit fix To address all issues possible (including breaking changes), run: npm audit fix --force Some issues need review, and may require choosing a different dependency. Run `npm audit` for details.
        Update "system.adapter.backitup.0"
        upload [95] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
        upload [90] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/cifs.jsonConfig.json5 cifs.jsonConfig.json5 application/json5
        upload [80] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
        upload [70] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/src_AdapterExist_jsx-src_BackupNow_jsx-src_CheckConfigInvisible_jsx-src_DetectConfig_jsx-src_-1b9e72.11bed00e.chunk.js custom/static/js/src_AdapterExist_jsx-src_BackupNow_jsx-src_CheckConfigInvisible_jsx-src_DetectConfig_jsx-src_-1b9e72.11bed00e.chunk.js application/javascript
        upload [60] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-6ae257.a0771a5e.chunk.js custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-6ae257.a0771a5e.chunk.js application/javascript
        upload [50] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.8635b033.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.8635b033.chunk.js application/javascript
        upload [40] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/grafana.jsonConfig.json5 grafana.jsonConfig.json5 application/json5
        upload [30] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [20] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
        upload [19] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
        upload [18] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
        upload [17] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
        upload [16] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
        upload [15] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
        upload [14] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
        upload [13] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
        upload [12] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
        upload [11] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css.map static/css/main.bd1167d4.css.map application/json
        upload [10] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js static/js/main.ce422ec2.js application/javascript
        upload [9] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js.LICENSE.txt static/js/main.ce422ec2.js.LICENSE.txt text/plain
        upload [8] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js.map static/js/main.ce422ec2.js.map application/json
        upload [7] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
        upload [6] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/style.css style.css text/css
        upload [5] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
        upload [4] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
        upload [3] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
        upload [2] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
        upload [1] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
        upload [0] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
        Process exited with code 0$ iobroker upgrade backitup@3.0.16 --debug
        Wie werde ich das wieder los? Hat jemand eine Idee?
        Edit:
        Ach ja, das passiert nur bei Adapter Update über den Admin. Per npm über CLI passiert das nicht.
        Nochmal Edit:
        Soweit ich herausfinden konnte, liegt es an der optionalen dependency diskusage in JS-Controller, dafür wird node-gyp gebraucht. Das Modul ist (zumindest unter Windows) wohl nicht zwingend erforderlich, daher können die nervigen Meldungen ignoriert werden, falls sie auftauchen.
        Eine andere Option ist es, node-gyp zu instrallieren. auf einem frischen Windows 11 System war ich auf diese Weise erfolgreich:
        winget install --id=Python.Python.3.12
        winget install Microsoft.VisualStudio.2019.BuildTools
        Jetzt muss ein neues iob Cmd Fenster geöffnet werden (wegen Path-Änderungen), dann
        npm i node-gyp -g
        npm i diskusage
        Und nochmal Edit:
        Wie sich herausgestellt hat, verhält es sich auf anderen Rechnern anders.
        Dort hat @sigi234 es schließlich hinbekommen, indem er vorgagangen ist, wie weiter hinten in diesem Thread von ihm beschrieben.
        sigi234S Online
        sigi234S Online
        @gaspode
        Da frage ich mich welcher Adapter braucht das Ganze eigentlich?
        • sigi234S sigi234
          @gaspode
          GaspodeG Offline
          GaspodeG Offline
          Gaspode
          Gute Frage, ich finde nur eine optionale Dependency in node_modules@iobroker\js-controller-common-db\package.json
          @foxriver76 , eine Idee?
          • sigi234S sigi234
            @gaspode
            npm error code 1
            C:\SmartHome>
            python3 ???
            GaspodeG Offline
            GaspodeG Offline
            Gaspode
            python3 ???
            Steht Python 2.7. auch im Pfad? Was passiert denn, wenn du in der iob Shell
            python
            eingibst?
            • GaspodeG Gaspode
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              @gaspode ja das ist genau die Stelle, ist auch nur optional https://github.com/jduncanator/node-diskusage/issues/48
              Damit schauen wir wie viel Speicher noch frei ist auf den Systemen um das im Admin etc anzuzeigen
              Videotutorials & mehr
              • foxriver76F foxriver76
                GaspodeG Offline
                GaspodeG Offline
                Gaspode
                @foxriver76 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
                Ja, dass die Dependency optional ist, hatte ich ja geschrieben. Anscheinend verursacht sie dennoch das komische verhalten mit node-gyp.
                Wenn ich diskusage aus meinem npm tree deinstalliere und lösche, wird zumindest unter Windows immer noch der korrekte Festplattenplatz angezeigt. Ist die Dependency also wirklich notwendig? Wie gesagt, es kommt halt auf einigen Systemen zu diesen Meldungen, das könnte evtl. bei einigen Usern zu Verwirrungen führen. Linux konnte ich jetzt noch nicht testen.
                foxriver76F GaspodeG 2 Antworten Letzte Antwort
                • GaspodeG Gaspode
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  @gaspode puh war noch vor meiner Zeit als die Funktion implementiert wurde kann man mal checken ob alles ohne gehen würde mach gerne mal Controller issue bin die Woche im Urlaub
                  • GaspodeG Gaspode
                    GaspodeG Offline
                    GaspodeG Offline
                    Gaspode
                    @gaspode said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
                    Edit:
                    Mit sauber konfiguriertem node-gyp ist das kein Problem, diese Voraussetzung dürfte auf den meisten Windos Systemen aber nicht erfüllt sein.
                      GaspodeG Offline
                      GaspodeG Offline
                      Gaspode
                      Kann ich demnächst mal unter Linux testen und ggfs. ein Issue schreiben.
                      Ich wünsche dir einen schönen Urlaub, Danke, dass du trotzdem geantwortet hast. :)
                      • GaspodeG Gaspode
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        @gaspode aber im Endeffekt muss man sagen ist es vollkommen ok, die optional dep kann nicht installiert werden Controller handelt das richtig, wenn sie da ist wird sie genutzt. Es ist halt blöd dass der User das sieht. Aber führt Admin denn das immer mit debug Flag aus? Ich denke das sollte nicht der Standard sein
                        • GaspodeG Gaspode
                          python3 ???
                          python
                          eingibst?
                          sigi234S Online
                          sigi234S Online
                          python3 ???
                          python
                          eingibst?
                          Da komme ich da hin:
                          • sigi234S sigi234
                            python3 ???
                            python
                            eingibst?
                            GaspodeG Offline
                            GaspodeG Offline
                            Gaspode
                            @sigi234
                            OK, dann steht es wohl nicht im Pfad. Am schnellsten geht es wahrscheinlich, wenn du das manuell machst.
                            Im Startmenü "Systemumgebungsvariablen" eingeben, Dialog öffnen, Karte "Erweitert" wählen, Umgebungsvariablen wählen, im oberen Bereich "Path" wählen, dann "Bearbeiten". "Neu" drücken und den Pfad zu deiner Python Exe eintragen, meist "C:\Python27" oder so.
                            Dann die iob Shell schließen und neu starten. Nochmal versuchen.
                              GaspodeG Offline
                              GaspodeG Offline
                              Gaspode
                              Stimmt schon, auf der anderen Seite muss man ja nix mitschleppen, was nicht gebraucht wird, oder?
                              Im Admin wird ein Adapter Update ja anscheinend nicht immer mit debug Flag ausgeführt, ich muss mal ein wenig forschen. Wird aber dauern. Genieße deinen Urlaub. :)
                              • GaspodeG Gaspode
                                @sigi234
                                sigi234S Online
                                sigi234S Online
                                @sigi234
                                Soll ich jetzt die 3 er installieren oder bei der 2.7 bleiben? Installieren wenn 3 in der cmd oder mit dem Downloadlink.
                                • sigi234S sigi234
                                  @sigi234
                                  GaspodeG Offline
                                  GaspodeG Offline
                                  Gaspode
                                  Sollte egal sein, die 2.7 hat den Vorteil, dass das wohl die offiziell von node-gyp empfohlene Version ist. Daher würde ich erst mal die ausprobieren, zumal die ja bereits installiert ist und wohl nur im Pfad fehlt.
                                  • GaspodeG Gaspode
                                    sigi234S Online
                                    sigi234S Online
                                    Selbe Meldung , es such noch immer im Falschen Verzeichnis?
                                    Edit:
                                    • sigi234S sigi234
                                      Edit:
                                      GaspodeG Offline
                                      GaspodeG Offline
                                      Gaspode
                                      @sigi234
                                      Was passiert denn jetzt bei
                                      python
                                      in der iob Shell?
                                      • GaspodeG Gaspode
                                        @sigi234
                                        python
                                        in der iob Shell?
                                        sigi234S Online
                                        sigi234S Online
                                        @sigi234
                                        python
                                        in der iob Shell?
                                        npm error code 1
                                        npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T11_21_58_639Z-debug-0.log
                                        C:\SmartHome>
                                        • sigi234S sigi234
                                          @sigi234
                                          python
                                          in der iob Shell?
                                          npm error code 1
                                          C:\SmartHome>
                                          GaspodeG Offline
                                          GaspodeG Offline
                                          Gaspode
                                          @sigi234
                                          https://github.com/nodejs/node-gyp#configuring-python-dependency
                                          Also gucken, was alles verfügbar ist mit
                                          py --list-paths
                                          Und testweise setzen mit
                                          set npm_config_python=C:\python27
                                          npm i diskusage
                                          Sollte das klappen (sonst bin ich mit meinem Latein erst mal am Ende), die Variable npm_config_python im System setzen, analog zur Erweiterung von Path, nur halt als neue Variable anlegen.
                                          Edit: Bei mir war das nicht notwendig, ich hatte Glück und er hat sich die korrekte Version automatisch rausgesucht.
