  4. [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?
    1.0k
64 Beiträge 6 Kommentatoren 10.5k Aufrufe 5 Beobachtet
  • GaspodeG Gaspode
    @sigi234 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
    Alles gemacht wie du geschrieben hast. Fehler kommt noch.
    Hast du auch Diskusage manuell installiert?
    Im ioBroker Root Verzeichnis:
    npm i diskusage
    Ging das fehlerfrei?
    sigi234S Online
    sigi234S Online
    @gaspode sagte in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
    npm i diskusage
    ***               Welcome to ioBroker.                 ***
    ***     Type 'iob help' for list of instructions.      ***
    ***                For more help see                   ***
    ***     https://github.com/ioBroker/ioBroker.docs      ***
    Your environment has been set up for using Node.js 20.16.0 (x64) and npm.
    C:\SmartHome>npm i diskusage
    npm error code 1
    npm error path C:\SmartHome\node_modules\diskusage
    npm error command failed
    npm error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild
    npm error gyp info it worked if it ends with ok
    npm error gyp info using node-gyp@10.1.0
    npm error gyp info using node@20.16.0 | win32 | x64
    npm error gyp info find Python using Python version 3.12.4 found at "C:\Users\Sigi\AppData\Local\Programs\Python\Python312\python.exe"
    npm error gyp ERR! find VS
    npm error gyp ERR! find VS msvs_version not set from command line or npm config
    npm error gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
    npm error gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details.
    npm error gyp ERR! find VS Failure details: undefined
    npm error gyp ERR! find VS checking VS2022 (17.11.35208.52) found at:
    npm error gyp ERR! find VS "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools"
    npm error gyp ERR! find VS - found "Visual Studio C++ core features"
    npm error gyp ERR! find VS - missing any VC++ toolset
    npm error gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
    npm error gyp ERR! find VS unsupported version "17.11.35208.52" found at "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools"
    npm error gyp ERR! find VS not looking for VS2015 as it is only supported up to Node.js 18
    npm error gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
    npm error gyp ERR! find VS **************************************************************
    npm error gyp ERR! find VS You need to install the latest version of Visual Studio
    npm error gyp ERR! find VS including the "Desktop development with C++" workload.
    npm error gyp ERR! find VS For more information consult the documentation at:
    npm error gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
    npm error gyp ERR! configure error
    npm error gyp ERR! stack Error: Could not find any Visual Studio installation to use
    npm error gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:116:11)
    npm error gyp ERR! stack at VisualStudioFinder.findVisualStudio (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:72:17)
    npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    npm error gyp ERR! stack at async createBuildDir (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:95:26)
    npm error gyp ERR! stack at async run (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18)
    npm error gyp ERR! System Windows_NT 10.0.19045
    npm error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    npm error gyp ERR! cwd C:\SmartHome\node_modules\diskusage
    npm error gyp ERR! node -v v20.16.0
    npm error gyp ERR! node-gyp -v v10.1.0
    npm error gyp ERR! not ok
    npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T06_57_48_846Z-debug-0.log
    C:\SmartHome>
    GaspodeG 1 Antwort Letzte Antwort
    • sigi234S sigi234
      npm i diskusage
      npm error code 1
      C:\SmartHome>
      GaspodeG Offline
      GaspodeG Offline
      Gaspode
      schrieb am zuletzt editiert von Gaspode
      Ich schätze mal, das liegt daran:
      Sorry, da hab ich dich weiter oben wohl auf die falsche Fährte geschickt. Bei mir laufen die Build Tools 2019 auf dem Testrechner und 2017 auf dem Produktivrechner, also evtl. mal damit versuchen (ich hab es im Beitrag oben mal auf 2019 angepasst).
      • GaspodeG Gaspode
        sigi234S Online
        sigi234S Online
        @gaspode
        npm error code 1
        npm error gyp ERR! find Python
        npm error gyp ERR! find Python Python is not set from command line or npm configuration
        npm error gyp ERR! find Python Python is not set from environment variable PYTHON
        npm error gyp ERR! find Python checking if the py launcher can be used to find Python 3
        npm error gyp ERR! find Python - executable path is ""
        npm error gyp ERR! find Python - "" could not be run
        npm error gyp ERR! find Python checking if "python3" can be used
        npm error gyp ERR! find Python checking if "python" can be used
        npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe
        npm error gyp ERR! find Python - version is ""
        npm error gyp ERR! find Python - version is  - should be >=3.6.0
        npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED
        npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311\python.exe
        npm error gyp ERR! find Python - "C:\Program Files\Python311\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe
        npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311-32\python.exe
        npm error gyp ERR! find Python - "C:\Program Files\Python311-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python311-32\python.exe
        npm error gyp ERR! find Python - "C:\Program Files (x86)\Python311-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe
        npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310\python.exe
        npm error gyp ERR! find Python - "C:\Program Files\Python310\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe
        npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310-32\python.exe
        npm error gyp ERR! find Python - "C:\Program Files\Python310-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python310-32\python.exe
        npm error gyp ERR! find Python - "C:\Program Files (x86)\Python310-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe
        npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe
        npm error gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe
        npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe
        npm error gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe
        npm error gyp ERR! find Python - "C:\Program Files (x86)\Python39-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe
        npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe
        npm error gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe
        npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe
        npm error gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run
        npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe
        npm error gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run
        npm error gyp ERR! find Python **********************************************************
        npm error gyp ERR! find Python You need to install the latest version of Python.
        npm error gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
        npm error gyp ERR! find Python you can try one of the following options:
        npm error gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
        npm error gyp ERR! find Python (accepted by both node-gyp and npm)
        npm error gyp ERR! find Python - Set the environment variable PYTHON
        npm error gyp ERR! find Python - Set the npm configuration variable python:
        npm error gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
        npm error gyp ERR! find Python For more information consult the documentation at:
        npm error gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
        npm error gyp ERR! stack Error: Could not find any Python installation to use
        npm error gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:306:11)
        npm error gyp ERR! stack at PythonFinder.findPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:164:17)
        npm error gyp ERR! stack at async configure (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:27:18)
        npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T07_42_55_666Z-debug-0.log
        C:\SmartHome>
        python3 ???
        • GaspodeG Gaspode
          Achtung: Windows-System. Ich denke aber nicht, dass das Problem Windows spezifisch ist.
          Plötzlich wird bei jedem Adapter Update "node-gyp rebuild" ausgeführt. So genau weiß ich nicht seit wann.
          Das rebuild geht schief, weil ich node-gyp gar nicht eingerichtet habe (hab gar kein Python auf dem Server) und es eigentlich auch nicht brauche.
          $ iobroker upgrade backitup@3.0.16 --debug
          Update backitup from @3.0.15 to @3.0.16
          NPM version: 10.8.1
          Installing iobroker.backitup@3.0.16... (System call)
          > node-gyp rebuild
          gyp info using node-gyp@8.4.1
          gyp ERR! find Python gyp ERR! find Python Python is not set from command line or npm configuration gyp ERR! find Python Python is not set from environment variable PYTHON gyp ERR! find Python checking if "python3" can be used
          gyp ERR! find Python - "python3" is not in PATH or produced an error gyp ERR! find Python checking if "python" can be used gyp ERR! find Python - "python" is not in PATH or produced an error gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run
          gyp ERR! find Python - Set the environment variable PYTHON gyp ERR! find Python - Set the npm configuration variable python: gyp ERR! find Python npm config set python "C:\Path\To\python.exe" gyp ERR! find Python For more information consult the documentation at:
          gyp ERR! stack Error: Could not find any Python installation to use gyp ERR! stack at PythonFinder.fail (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:330:47) gyp ERR! stack at PythonFinder.runChecks (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:159:21) gyp ERR! stack at PythonFinder.<anonymous> (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:228:18) gyp ERR! stack at PythonFinder.execFileCallback (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:294:16) gyp ERR! stack at exithandler (node:child_process:430:5) gyp ERR! stack at ChildProcess.errorhandler (node:child_process:442:5)
          gyp ERR! System Windows_NT 10.0.19045 gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\ioBroker\\XXXXXXX\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" gyp ERR! cwd C:\ioBroker\XXXXXXX\node_modules\diskusage gyp ERR! node -v v20.16.0 gyp ERR! node-gyp -v v8.4.1 gyp ERR! not ok
          > unix-dgram@2.0.6 install
          > node-gyp rebuild
          gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe
          gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe
          gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe
          gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe
          gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37\python.exe
          gyp ERR! find Python - "C:\Program Files\Python36\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python36-32\python.exe gyp ERR! find Python - "C:\Program Files\Python36-32\python.exe" could not be run
          gyp ERR! stack at exithandler (node:child_process:430:5) gyp ERR! stack at ChildProcess.errorhandler (node:child_process:442:5) gyp ERR! stack at ChildProcess.emit (node:events:519:28) gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) gyp ERR! stack at onErrorNT (node:internal/child_process:484:16) gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
          gyp ERR! not ok
          added 1 package, changed 4 packages, and audited 1261 packages in 25s
          147 packages are looking for funding run `npm fund` for details
          66 vulnerabilities (6 low, 37 moderate, 22 high, 1 critical)
          To address issues that do not require attention, run: npm audit fix To address all issues possible (including breaking changes), run: npm audit fix --force Some issues need review, and may require choosing a different dependency. Run `npm audit` for details.
          Update "system.adapter.backitup.0"
          upload [95] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
          upload [90] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/cifs.jsonConfig.json5 cifs.jsonConfig.json5 application/json5
          upload [80] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
          upload [70] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/src_AdapterExist_jsx-src_BackupNow_jsx-src_CheckConfigInvisible_jsx-src_DetectConfig_jsx-src_-1b9e72.11bed00e.chunk.js custom/static/js/src_AdapterExist_jsx-src_BackupNow_jsx-src_CheckConfigInvisible_jsx-src_DetectConfig_jsx-src_-1b9e72.11bed00e.chunk.js application/javascript
          upload [60] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-6ae257.a0771a5e.chunk.js custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-6ae257.a0771a5e.chunk.js application/javascript
          upload [50] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.8635b033.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.8635b033.chunk.js application/javascript
          upload [40] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/grafana.jsonConfig.json5 grafana.jsonConfig.json5 application/json5
          upload [30] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [20] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
          upload [19] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
          upload [18] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
          upload [17] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
          upload [16] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
          upload [15] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
          upload [14] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
          upload [13] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
          upload [12] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
          upload [11] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css.map static/css/main.bd1167d4.css.map application/json
          upload [10] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js static/js/main.ce422ec2.js application/javascript
          upload [9] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js.LICENSE.txt static/js/main.ce422ec2.js.LICENSE.txt text/plain
          upload [8] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js.map static/js/main.ce422ec2.js.map application/json
          upload [7] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
          upload [6] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/style.css style.css text/css
          upload [5] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
          upload [4] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
          upload [3] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
          upload [2] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
          upload [1] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
          upload [0] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
          Process exited with code 0$ iobroker upgrade backitup@3.0.16 --debug
          Wie werde ich das wieder los? Hat jemand eine Idee?
          Edit:
          Ach ja, das passiert nur bei Adapter Update über den Admin. Per npm über CLI passiert das nicht.
          Nochmal Edit:
          Soweit ich herausfinden konnte, liegt es an der optionalen dependency diskusage in JS-Controller, dafür wird node-gyp gebraucht. Das Modul ist (zumindest unter Windows) wohl nicht zwingend erforderlich, daher können die nervigen Meldungen ignoriert werden, falls sie auftauchen.
          Eine andere Option ist es, node-gyp zu instrallieren. auf einem frischen Windows 11 System war ich auf diese Weise erfolgreich:
          winget install --id=Python.Python.3.12
          winget install Microsoft.VisualStudio.2019.BuildTools
          Jetzt muss ein neues iob Cmd Fenster geöffnet werden (wegen Path-Änderungen), dann
          npm i node-gyp -g
          npm i diskusage
          Und nochmal Edit:
          Wie sich herausgestellt hat, verhält es sich auf anderen Rechnern anders.
          Dort hat @sigi234 es schließlich hinbekommen, indem er vorgagangen ist, wie weiter hinten in diesem Thread von ihm beschrieben.
          sigi234S Online
          sigi234S Online
          @gaspode
          Da frage ich mich welcher Adapter braucht das Ganze eigentlich?
          • sigi234S sigi234
            @gaspode
            GaspodeG Offline
            GaspodeG Offline
            Gaspode
            Gute Frage, ich finde nur eine optionale Dependency in node_modules@iobroker\js-controller-common-db\package.json
            @foxriver76 , eine Idee?
            • sigi234S sigi234
              @gaspode
              npm error code 1
              C:\SmartHome>
              python3 ???
              GaspodeG Offline
              GaspodeG Offline
              Gaspode
              python3 ???
              Steht Python 2.7. auch im Pfad? Was passiert denn, wenn du in der iob Shell
              python
              eingibst?
              • GaspodeG Gaspode
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                @gaspode ja das ist genau die Stelle, ist auch nur optional https://github.com/jduncanator/node-diskusage/issues/48
                Damit schauen wir wie viel Speicher noch frei ist auf den Systemen um das im Admin etc anzuzeigen
                Videotutorials & mehr
                • foxriver76F foxriver76
                  GaspodeG Offline
                  GaspodeG Offline
                  Gaspode
                  @foxriver76 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
                  Ja, dass die Dependency optional ist, hatte ich ja geschrieben. Anscheinend verursacht sie dennoch das komische verhalten mit node-gyp.
                  Wenn ich diskusage aus meinem npm tree deinstalliere und lösche, wird zumindest unter Windows immer noch der korrekte Festplattenplatz angezeigt. Ist die Dependency also wirklich notwendig? Wie gesagt, es kommt halt auf einigen Systemen zu diesen Meldungen, das könnte evtl. bei einigen Usern zu Verwirrungen führen. Linux konnte ich jetzt noch nicht testen.
                  foxriver76F GaspodeG 2 Antworten Letzte Antwort
                  • GaspodeG Gaspode
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    @gaspode puh war noch vor meiner Zeit als die Funktion implementiert wurde kann man mal checken ob alles ohne gehen würde mach gerne mal Controller issue bin die Woche im Urlaub
                    • GaspodeG Gaspode
                      GaspodeG Offline
                      GaspodeG Offline
                      Gaspode
                      @gaspode said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
                      Edit:
                      Mit sauber konfiguriertem node-gyp ist das kein Problem, diese Voraussetzung dürfte auf den meisten Windos Systemen aber nicht erfüllt sein.
                        GaspodeG Offline
                        GaspodeG Offline
                        Gaspode
                        Kann ich demnächst mal unter Linux testen und ggfs. ein Issue schreiben.
                        Ich wünsche dir einen schönen Urlaub, Danke, dass du trotzdem geantwortet hast. :)
                        • GaspodeG Gaspode
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          @gaspode aber im Endeffekt muss man sagen ist es vollkommen ok, die optional dep kann nicht installiert werden Controller handelt das richtig, wenn sie da ist wird sie genutzt. Es ist halt blöd dass der User das sieht. Aber führt Admin denn das immer mit debug Flag aus? Ich denke das sollte nicht der Standard sein
                          • GaspodeG Gaspode
                            python3 ???
                            python
                            eingibst?
                            sigi234S Online
                            sigi234S Online
                            python3 ???
                            python
                            eingibst?
                            Da komme ich da hin:
                            • sigi234S sigi234
                              python3 ???
                              python
                              eingibst?
                              GaspodeG Offline
                              GaspodeG Offline
                              Gaspode
                              @sigi234
                              OK, dann steht es wohl nicht im Pfad. Am schnellsten geht es wahrscheinlich, wenn du das manuell machst.
                              Im Startmenü "Systemumgebungsvariablen" eingeben, Dialog öffnen, Karte "Erweitert" wählen, Umgebungsvariablen wählen, im oberen Bereich "Path" wählen, dann "Bearbeiten". "Neu" drücken und den Pfad zu deiner Python Exe eintragen, meist "C:\Python27" oder so.
                              Dann die iob Shell schließen und neu starten. Nochmal versuchen.
                                GaspodeG Offline
                                GaspodeG Offline
                                Gaspode
                                Stimmt schon, auf der anderen Seite muss man ja nix mitschleppen, was nicht gebraucht wird, oder?
                                Im Admin wird ein Adapter Update ja anscheinend nicht immer mit debug Flag ausgeführt, ich muss mal ein wenig forschen. Wird aber dauern. Genieße deinen Urlaub. :)
                                • GaspodeG Gaspode
                                  @sigi234
                                  sigi234S Online
                                  sigi234S Online
                                  @sigi234
                                  Soll ich jetzt die 3 er installieren oder bei der 2.7 bleiben? Installieren wenn 3 in der cmd oder mit dem Downloadlink.
                                  • sigi234S sigi234
                                    @sigi234
                                    GaspodeG Offline
                                    GaspodeG Offline
                                    Gaspode
                                    Sollte egal sein, die 2.7 hat den Vorteil, dass das wohl die offiziell von node-gyp empfohlene Version ist. Daher würde ich erst mal die ausprobieren, zumal die ja bereits installiert ist und wohl nur im Pfad fehlt.
                                    • GaspodeG Gaspode
                                      sigi234S Online
                                      sigi234S Online
                                      Selbe Meldung , es such noch immer im Falschen Verzeichnis?
                                      Edit:
                                      • sigi234S sigi234
                                        Edit:
                                        GaspodeG Offline
                                        GaspodeG Offline
                                        Gaspode
                                        @sigi234
                                        Was passiert denn jetzt bei
                                        python
                                        in der iob Shell?
                                        • GaspodeG Gaspode
                                          @sigi234
                                          python
                                          in der iob Shell?
                                          sigi234S Online
                                          sigi234S Online
                                          @sigi234
                                          python
                                          in der iob Shell?
                                          npm error code 1
                                          npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T11_21_58_639Z-debug-0.log
                                          C:\SmartHome>
