  4. Beim Update von Adaptern stürzt der ioBroker ab
89 Beiträge 7 Kommentatoren 17.4k Aufrufe 4 Beobachtet
  • F flommaster
    erledigt. Bin als Root abgemeldet.
    Sorry, das wusste ich nicht.
    Ich habe npm prune gerade unter dem Verzeichnis "/opt/iobroker" gestartet.
    Hier ist das Ergebnis:
    flo@ioBrokerdebian:/opt/iobroker$ npm prune
    npm error code ENOTEMPTY
    npm error syscall rename
    npm error path /opt/iobroker/node_modules/ajv
    npm error dest /opt/iobroker/node_modules/.ajv-Kze9IpmC
    npm error errno -39
    npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ajv' -> '/opt/iobroker/node_modules/.ajv-Kze9IpmC'
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T19_54_02_939Z-debug-0.log
    npm ls
    flo@ioBrokerdebian:~$ cd /opt/iobroker && npm ls
    [sudo] Passwort für flo:
    iobroker.inst@2.0.3 /opt/iobroker
    ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
    ├── @alcalzone/jsonl-db@3.1.1 extraneous
    ├── @alcalzone/pak@0.8.1 extraneous
    ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
    ├── @azure/abort-controller@1.1.0 extraneous
    ├── @azure/core-auth@1.7.2 extraneous
    ├── @azure/core-client@ extraneous
    ├── @azure/core-http-compat@2.1.2 extraneous
    ├── @azure/core-lro@ extraneous
    ├── @azure/core-paging@1.6.2 extraneous
    ├── @azure/core-rest-pipeline@ extraneous
    ├── @azure/core-tracing@1.1.2 extraneous
    ├── @azure/core-util@1.9.2 extraneous
    ├── @azure/identity@ extraneous
    ├── @azure/keyvault-keys@4.8.0 extraneous
    ├── @azure/logger@1.1.4 extraneous
    ├── @azure/msal-browser@ extraneous
    ├── @azure/msal-common@ extraneous
    ├── @azure/msal-node@ extraneous
    ├── @babel/runtime@ extraneous
    ├── @colors/colors@1.5.0 extraneous
    ├── @dabh/diagnostics@2.0.3 extraneous
    ├── @datalust/winston-seq@1.0.2 extraneous
    ├── @gar/promisify@1.1.3 extraneous
    ├── @googleapis/calendar@9.7.7 extraneous
    ├── @googleapis/drive@5.1.0 extraneous
    ├── @googleapis/oauth2@1.0.7 extraneous
    ├── @iobroker/db-base@6.0.10 extraneous
    ├── @iobroker/db-objects-file@6.0.10 extraneous
    ├── @iobroker/db-objects-jsonl@6.0.10 extraneous
    ├── @iobroker/db-objects-redis@6.0.10 extraneous
    ├── @iobroker/db-states-file@6.0.10 extraneous
    ├── @iobroker/db-states-jsonl@6.0.10 extraneous
    ├── @iobroker/db-states-redis@6.0.10 extraneous
    ├── @iobroker/js-controller-adapter@6.0.10 extraneous
    ├── @iobroker/js-controller-cli@ extraneous
    ├── @iobroker/js-controller-common-db@6.0.10 extraneous
    ├── @iobroker/js-controller-common@6.0.10 extraneous
    ├── @iobroker/plugin-base@1.2.1 extraneous
    ├── @iobroker/plugin-sentry@1.2.1 extraneous
    ├── @iobroker/socket-classes@1.5.6 extraneous
    ├── @iobroker/webserver@1.0.3 extraneous
    ├── @isaacs/cliui@8.0.2 extraneous
    ├── @js-joda/core@ extraneous
    ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
    ├── @npmcli/fs@2.1.2 extraneous
    ├── @npmcli/move-file@2.0.1 extraneous
    ├── @pkgjs/parseargs@0.11.0 extraneous
    ├── @protobufjs/aspromise@1.1.2 extraneous
    ├── @protobufjs/base64@1.1.2 extraneous
    ├── @protobufjs/codegen@2.0.4 extraneous
    ├── @protobufjs/eventemitter@1.1.0 extraneous
    ├── @protobufjs/fetch@1.1.0 extraneous
    ├── @protobufjs/float@1.0.2 extraneous
    ├── @protobufjs/inquire@1.1.0 extraneous
    ├── @protobufjs/path@1.1.2 extraneous
    ├── @protobufjs/pool@1.1.0 extraneous
    ├── @protobufjs/utf8@1.1.0 extraneous
    ├── @quasar/extras@ extraneous
    ├── @sentry-internal/tracing@ extraneous
    ├── @sentry/core@5.30.0 extraneous
    ├── @sentry/hub@5.30.0 extraneous
    ├── @sentry/minimal@5.30.0 extraneous
    ├── @sentry/node@5.30.0 extraneous
    ├── @sentry/tracing@ extraneous
    ├── @sentry/types@5.30.0 extraneous
    ├── @sentry/utils@5.30.0 extraneous
    ├── @tootallnate/once@2.0.0 extraneous
    ├── @types/caseless@0.12.5 extraneous
    ├── @types/geojson@7946.0.14 extraneous
    ├── @types/leaflet@1.9.12 extraneous
    ├── @types/node-cron@2.0.8 extraneous
    ├── @types/request@2.48.12 extraneous
    ├── @types/tough-cookie@4.0.5 extraneous
    ├── @types/triple-beam@1.3.5 extraneous
    ├── @types/tz-offset@0.0.3 extraneous
    ├── abab@2.0.6 extraneous
    ├── agentkeepalive@4.5.0 extraneous
    ├── ajv@ extraneous
    ├── anymatch@3.1.3 extraneous
    ├── archiver-utils@5.0.2 extraneous
    ├── archiver@7.0.1 extraneous
    ├── argparse@1.0.10 extraneous
    ├── array-buffer-byte-length@1.0.1 extraneous
    ├── arraybuffer.prototype.slice@1.0.3 extraneous
    ├── arrify@2.0.1 extraneous
    ├── available-typed-arrays@1.0.7 extraneous
    ├── b4a@1.6.6 extraneous
    ├── bare-events@2.4.2 extraneous
    ├── base-64@1.0.0 extraneous
    ├── binary-extensions@2.3.0 extraneous
    ├── bindings@1.5.0 extraneous
    ├── bottleneck@2.19.5 extraneous
    ├── brace-expansion@2.0.1 extraneous
    ├── buffer-crc32@1.0.0 extraneous
    ├── buffer-equal-constant-time@1.0.1 extraneous
    ├── buffer-shims@1.0.0 extraneous
    ├── buildcheck@0.0.6 extraneous
    ├── busboy@1.6.0 extraneous
    ├── byte-length@1.0.2 extraneous
    ├── cacache@16.1.3 extraneous
    ├── charenc@0.0.2 extraneous
    ├── chokidar@3.6.0 extraneous
    ├── ci-info@3.9.0 extraneous
    ├── cloneextend@0.0.3 extraneous
    ├── cluster-key-slot@1.1.2 extraneous
    ├── coffeescript@1.12.7 extraneous
    ├── color-string@1.9.1 extraneous
    ├── color@3.2.1 extraneous
    ├── colors@1.4.0
    ├── colorspace@1.1.4 extraneous
    ├── commist@3.2.0 extraneous
    ├── compress-commons@6.0.2 extraneous
    ├── compress-json@2.1.2 extraneous
    ├── compressible@2.0.18 extraneous
    ├── compression@1.7.4 extraneous
    ├── core-js@ extraneous
    ├── crc-32@1.2.2 extraneous
    ├── crc@4.1.1 extraneous
    ├── crc32-stream@6.0.0 extraneous
    ├── cross-fetch@4.0.0 extraneous
    ├── crypt@0.0.2 extraneous
    ├── cssstyle@3.0.0 extraneous
    ├── cycle@1.0.3 extraneous
    ├── data-urls@4.0.0 extraneous
    ├── data-view-buffer@1.0.1 extraneous
    ├── data-view-byte-length@1.0.1 extraneous
    ├── data-view-byte-offset@1.0.0 extraneous
    ├── date-and-time@ extraneous
    ├── dayjs@ extraneous
    ├── decache@4.6.2 extraneous
    ├── decimal.js@10.4.3 extraneous
    ├── deep-clone@3.0.3 extraneous
    ├── define-lazy-prop@2.0.0 extraneous
    ├── denque@1.5.1 extraneous
    ├── digest-header@1.1.0 extraneous
    ├── diskusage@1.2.0 extraneous
    ├── domexception@4.0.0 extraneous
    ├── draftlog@1.0.13 extraneous
    ├── dropbox-v2-api@ extraneous
    ├── duplexer@0.1.2 extraneous
    ├── eastasianwidth@0.2.0 extraneous
    ├── ecdsa-sig-formatter@1.0.11 extraneous
    ├── echarts@ extraneous
    ├── emoji-regex@9.2.2 extraneous
    ├── enabled@2.0.0 extraneous
    ├── entities@4.5.0 extraneous
    ├── err-code@2.0.3 extraneous
    ├── es-abstract@ extraneous
    ├── es-aggregate-error@1.0.13 extraneous
    ├── es-object-atoms@1.0.0 extraneous
    ├── es-set-tostringtag@2.0.3 extraneous
    ├── es-to-primitive@1.2.1 extraneous
    ├── es6-promise@4.2.8 extraneous
    ├── es6-promisify@5.0.0 extraneous
    ├── esbuild@0.11.23 extraneous
    ├── event-stream@4.0.1 extraneous
    ├── expand-template@2.0.3 extraneous
    ├── express-fileupload@1.5.1 extraneous
    ├── fast-deep-equal@3.1.3 extraneous
    ├── fast-fifo@1.3.2 extraneous
    ├── fast-json-stable-stringify@2.1.0 extraneous
    ├── fast-text-encoding@1.0.6 extraneous
    ├── fast-unique-numbers@8.0.13 extraneous
    ├── fast-uri@3.0.1 extraneous
    ├── fast-xml-parser@4.4.1 extraneous
    ├── fecha@4.2.3 extraneous
    ├── file-stream-rotator@0.6.1 extraneous
    ├── file-type@10.11.0 extraneous
    ├── file-uri-to-path@1.0.0 extraneous
    ├── fn.name@1.1.0 extraneous
    ├── for-each@0.3.3 extraneous
    ├── foreground-child@3.3.0 extraneous
    ├── from@0.1.7 extraneous
    ├── fs-constants@1.0.0 extraneous
    ├── fs-extra@7.0.1
    ├── fsevents@ extraneous
    ├── ftp@0.3.10 extraneous
    ├── function.prototype.name@1.1.6 extraneous
    ├── functions-have-names@1.2.3 extraneous
    ├── futoin-hkdf@1.4.3 extraneous
    ├── gaxios@5.1.3 extraneous
    ├── gcp-metadata@5.3.0 extraneous
    ├── get-ssl-certificate@2.3.3 extraneous
    ├── get-symbol-description@1.0.2 extraneous
    ├── github-from-package@0.0.0 extraneous
    ├── glob@10.4.5 extraneous
    ├── globalthis@1.0.4 extraneous
    ├── glossy@0.1.7 extraneous
    ├── google-auth-library@8.9.0 extraneous
    ├── google-p12-pem@4.0.1 extraneous
    ├── googleapis-common@6.0.4 extraneous
    ├── googleapis@ extraneous
    ├── gtoken@6.1.2 extraneous
    ├── has-bigints@1.0.2 extraneous
    ├── has-tostringtag@1.0.2 extraneous
    ├── he@1.2.0 extraneous
    ├── help-me@5.0.0 extraneous
    ├── homebridge-plugin-wrapper@ extraneous
    ├── hot-patcher@1.0.0 extraneous
    ├── html-encoding-sniffer@3.0.0 extraneous
    ├── http-proxy-agent@5.0.0 extraneous
    ├── https@1.0.0 extraneous
    ├── humanize-ms@1.2.1 extraneous
    ├── ical.js@1.5.0 extraneous
    ├── image-type@4.1.0 extraneous
    ├── infer-owner@1.0.4 extraneous
    ├── internal-slot@1.0.7 extraneous
    ├── iobroker-adapter-helpers@0.0.8 extraneous
    ├── iobroker.admin@ invalid: "^6.10.1" from the root project
    ├── iobroker.backitup@ invalid: "2.6.23" from the root project
    ├── iobroker.bmw@2.5.7
    ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
    ├── iobroker.cloud@4.4.1
    ├── iobroker.coronavirus-statistics@0.8.7
    ├── iobroker.daswetter@3.1.10
    ├── iobroker.discovery@ invalid: "3.1.0" from the root project
    ├── iobroker.dwd@2.8.5
    ├── iobroker.echarts@ invalid: "1.5.1" from the root project
    ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
    ├── iobroker.eusec@1.1.2
    ├── iobroker.flot@ invalid: "1.12.0" from the root project
    ├── iobroker.fritzbox@0.2.1
    ├── iobroker.fullcalendar@1.2.0
    ├── iobroker.fullybrowser@2.1.2
    ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
    ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
    ├── iobroker.harmony@1.2.2
    ├── iobroker.heatingcontrol@2.11.1
    ├── iobroker.history@2.2.6
    ├── iobroker.hm-rega@3.0.47
    ├── iobroker.hm-rpc@1.15.19
    ├── iobroker.hue@3.9.5
    ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
    ├── iobroker.icons-icons8@0.0.1
    ├── iobroker.icons-material-png@0.1.0
    ├── iobroker.icons-mfd-png@1.1.0
    ├── iobroker.icons-ultimate-png@1.0.1
    ├── iobroker.info@ invalid: "1.9.26" from the root project
    ├── iobroker.javascript@ invalid: "7.1.4" from the root project
    ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
    ├── iobroker.logparser@2.2.0
    ├── iobroker.material@ invalid: "1.3.1" from the root project
    ├── iobroker.meross@1.15.1
    ├── iobroker.mihome-vacuum@3.11.0
    ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
    ├── iobroker.milight@0.3.6
    ├── iobroker.mobile@ invalid: "1.0.1" from the root project
    ├── iobroker.modbus@ invalid: "5.0.11" from the root project
    ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
    ├── iobroker.nina@ invalid: "0.0.25" from the root project
    ├── iobroker.pollenflug@1.0.6
    ├── iobroker.pushover@3.0.3
    ├── iobroker.pushsafer@1.0.3
    ├── iobroker.pvforecast@2.7.1
    ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
    ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
    ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
    ├── iobroker.simple-api@2.7.2
    ├── iobroker.smartmeter@3.3.4
    ├── iobroker.socketio@6.5.2
    ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
    ├── iobroker.sql@2.2.0
    ├── iobroker.statistics@2.3.0
    ├── iobroker.sunnyportal@0.1.5
    ├── iobroker.synology@2.1.13
    ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
    ├── iobroker.terminal@1.0.0
    ├── iobroker.tr-064@4.2.18
    ├── iobroker.trashschedule@2.2.0
    ├── iobroker.unifi@0.6.6
    ├── iobroker.upnp@1.0.21
    ├── iobroker.valloxmv@1.2.0
    ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
    ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
    ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
    ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
    ├── iobroker.vis-colorpicker@2.0.3
    ├── iobroker.vis-fancyswitch@1.1.0
    ├── iobroker.vis-google-fonts@1.0.4
    ├── iobroker.vis-history@1.0.0
    ├── iobroker.vis-hqwidgets@1.4.0
    ├── iobroker.vis-inventwo@3.3.3
    ├── iobroker.vis-jqui-mfd@1.0.12
    ├── iobroker.vis-justgage@1.0.2
    ├── iobroker.vis-map@1.0.4
    ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
    ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
    ├── iobroker.vis-rgraph@0.0.2
    ├── iobroker.vis-timeandweather@1.2.2
    ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
    ├── iobroker.vis@ invalid: "1.4.16" from the root project
    ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
    ├── iobroker.weatherunderground@3.4.2
    ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
    ├── iobroker.web@ invalid: "6.1.0" from the root project
    ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
    ├── iobroker.wiffi-wz@2.2.1
    ├── iobroker.windows-control@0.1.5
    ├── iobroker.worx@2.3.2
    ├── iobroker.ws@2.5.3
    ├── iobroker@2.0.3
    ├── ioredis@4.28.5 extraneous
    ├── ip-address@9.0.5 extraneous
    ├── ip-regex@4.3.0 extraneous
    ├── ipaddr.js@2.2.0 extraneous
    ├── is-array-buffer@3.0.4 extraneous
    ├── is-bigint@1.0.4 extraneous
    ├── is-binary-path@2.1.0 extraneous
    ├── is-boolean-object@1.1.2 extraneous
    ├── is-buffer@1.1.6 extraneous
    ├── is-callable@1.2.7 extraneous
    ├── is-data-view@1.0.1 extraneous
    ├── is-date-object@1.0.5 extraneous
    ├── is-empty-object@1.1.1 extraneous
    ├── is-lambda@1.0.1 extraneous
    ├── is-negative-zero@2.0.3 extraneous
    ├── is-number-object@1.0.7 extraneous
    ├── is-potential-custom-element-name@1.0.1 extraneous
    ├── is-regex@1.1.4 extraneous
    ├── is-shared-array-buffer@1.0.3 extraneous
    ├── is-string@1.0.7 extraneous
    ├── is-symbol@1.0.4 extraneous
    ├── is-typed-array@1.1.13 extraneous
    ├── is-url@1.2.4 extraneous
    ├── is-weakref@1.0.2 extraneous
    ├── is@3.3.0 extraneous
    ├── is2@2.0.9 extraneous
    ├── jackspeak@3.4.3 extraneous
    ├── js-md4@0.3.2 extraneous
    ├── js-yaml@3.14.1 extraneous
    ├── jsbi@4.3.0 extraneous
    ├── jsbn@1.1.0 extraneous
    ├── jsdom@ extraneous
    ├── jshashes@1.0.8 extraneous
    ├── json-schema-traverse@1.0.0 extraneous
    ├── json5@2.2.3 extraneous
    ├── jsonata@2.0.5 extraneous
    ├── jsonc-parser@3.3.1 extraneous
    ├── jsonwebtoken@9.0.2 extraneous
    ├── jszip@3.10.1 extraneous
    ├── jwa@2.0.0 extraneous
    ├── jws@4.0.0 extraneous
    ├── kuler@2.0.0 extraneous
    ├── layerr@0.1.2 extraneous
    ├── lazystream@1.0.1 extraneous
    ├── lie@3.3.0 extraneous
    ├── loadavg-windows@1.1.1 extraneous
    ├── lodash.defaults@4.2.0 extraneous
    ├── lodash.flatten@4.4.0 extraneous
    ├── lodash.includes@4.3.0 extraneous
    ├── lodash.isarguments@3.1.0 extraneous
    ├── lodash.isboolean@3.0.3 extraneous
    ├── lodash.isinteger@4.0.4 extraneous
    ├── lodash.isnumber@3.0.3 extraneous
    ├── lodash.isplainobject@4.0.6 extraneous
    ├── lodash.isstring@4.0.1 extraneous
    ├── lodash.once@4.1.1 extraneous
    ├── logform@2.6.1 extraneous
    ├── long@5.2.3 extraneous
    ├── make-fetch-happen@10.2.1 extraneous
    ├── map-stream@0.0.7 extraneous
    ├── md5@2.3.0 extraneous
    ├── mime-db@1.53.0 extraneous
    ├── minimatch@9.0.5 extraneous
    ├── minipass-collect@1.0.2 extraneous
    ├── minipass-fetch@2.1.2 extraneous
    ├── minipass-flush@1.0.5 extraneous
    ├── minipass-pipeline@1.2.4 extraneous
    ├── minipass-sized@1.0.3 extraneous
    ├── minipass@7.1.2 extraneous
    ├── mkdirp-classic@0.5.3 extraneous
    ├── mock-require@3.0.3 extraneous
    ├── moment-duration-format@2.3.2 extraneous
    ├── mqtt-connection@4.1.0 extraneous
    ├── mqtt-packet@9.0.0 extraneous
    ├── mqtt@ extraneous
    ├── nanoid@3.3.7 extraneous
    ├── napi-build-utils@1.0.2 extraneous
    ├── native-duplexpair@1.0.0 extraneous
    ├── nconf@0.10.0 extraneous
    ├── nested-property@4.0.0 extraneous
    ├── netmask@2.0.2 extraneous
    ├── node-abi@3.65.0 extraneous
    ├── node-abort-controller@3.1.1 extraneous
    ├── node-cron@2.0.3 extraneous
    ├── node-forge@ extraneous
    ├── node-gyp@9.3.0 extraneous
    ├── node-ical@0.16.1 extraneous
    ├── node-inspect@2.0.0 extraneous
    ├── node-libcurl@3.0.0 extraneous
    ├── node-mndp@0.0.3 extraneous
    ├── node-persist@0.0.11 extraneous
    ├── node-rsa@1.1.1 extraneous
    ├── node-wol@0.1.1 extraneous
    ├── node.extend@2.0.3 extraneous
    ├── normalize-path@3.0.0 extraneous
    ├── nwsapi@2.2.12 extraneous
    ├── object-hash@3.0.0 extraneous
    ├── one-time@1.0.0 extraneous
    ├── onedrive-api@1.1.1 extraneous
    ├── opencollective-postinstall@2.0.3 extraneous
    ├── ospath@1.2.2 extraneous
    ├── osx-temperature-sensor@ extraneous
    ├── otplib@11.0.1 extraneous
    ├── p-throttle@4.1.1 extraneous
    ├── package-json-from-dist@1.0.0 extraneous
    ├── pako@1.0.11 extraneous
    ├── parse5@7.1.2 extraneous
    ├── passport@0.7.0 extraneous
    ├── path-parse@1.0.7 extraneous
    ├── path-posix@1.0.0 extraneous
    ├── path-scurry@1.11.1 extraneous
    ├── pause-stream@0.0.11 extraneous
    ├── pidusage@3.0.2 extraneous
    ├── ping@0.4.4 extraneous
    ├── pluralize@8.0.0 extraneous
    ├── possible-typed-array-names@1.0.0 extraneous
    ├── prebuild-install@7.1.2 extraneous
    ├── promise-inflight@1.0.1 extraneous
    ├── promise-object@0.1.7 extraneous
    ├── promise-retry@2.0.1 extraneous
    ├── promise-retryer@0.0.1 extraneous
    ├── promisify-child-process@4.1.2 extraneous
    ├── prompt@1.3.0 extraneous
    ├── protobufjs@ extraneous
    ├── proxy-from-env@1.1.0 extraneous
    ├── q@1.1.2 extraneous
    ├── quasar@ extraneous
    ├── queue-tick@1.0.1 extraneous
    ├── read@1.0.7 extraneous
    ├── readdir-glob@1.1.3 extraneous
    ├── readdirp@3.6.0 extraneous
    ├── readline-sync@1.4.10 extraneous
    ├── readline@1.3.0 extraneous
    ├── redis-commands@1.7.0 extraneous
    ├── redis-errors@1.2.0 extraneous
    ├── redis-parser@3.0.0 extraneous
    ├── regenerator-runtime@0.14.1 extraneous
    ├── regex-escape@3.4.10 extraneous
    ├── regexp.prototype.flags@1.5.2 extraneous
    ├── remove-trailing-separator@1.1.0 extraneous
    ├── require-from-string@2.0.2 extraneous
    ├── respjs@4.2.0 extraneous
    ├── retry-axios@2.6.0 extraneous
    ├── retry@0.12.0 extraneous
    ├── revalidator@0.1.8 extraneous
    ├── rrule@2.8.1 extraneous
    ├── rrweb-cssom@0.6.0 extraneous
    ├── safe-array-concat@1.1.2 extraneous
    ├── safe-regex-test@1.0.3 extraneous
    ├── safe-stable-stringify@2.4.3 extraneous
    ├── saxes@6.0.0 extraneous
    ├── secure-keys@1.0.0 extraneous
    ├── semver@5.7.2
    ├── seq-logging@1.1.2 extraneous
    ├── set-function-name@2.0.2 extraneous
    ├── setimmediate@1.0.5 extraneous
    ├── signal-exit@4.1.0 extraneous
    ├── simple-swizzle@0.2.2 extraneous
    ├── smart-buffer@4.2.0 extraneous
    ├── socks-proxy-agent@7.0.0 extraneous
    ├── socks@2.8.3 extraneous
    ├── speedtest-net@1.6.2 extraneous
    ├── sprintf-js@1.1.3 extraneous
    ├── ssri@9.0.1 extraneous
    ├── stack-trace@0.0.10 extraneous
    ├── stampit-event-bus@0.1.1 extraneous
    ├── stampit-state-machine@0.2.1 extraneous
    ├── stampit@2.1.2 extraneous
    ├── standard-as-callback@2.1.0 extraneous
    ├── stoppable@1.1.0 extraneous
    ├── stream-combiner@0.2.2 extraneous
    ├── streamsearch@1.1.0 extraneous
    ├── streamx@2.18.0 extraneous
    ├── string-argv@0.3.2 extraneous
    ├── string-width-cjs@npm:string-width@4.2.3 extraneous
    ├── string-width@5.1.2 extraneous
    ├── string.prototype.trim@1.2.9 extraneous
    ├── string.prototype.trimend@1.0.8 extraneous
    ├── string.prototype.trimstart@1.0.8 extraneous
    ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
    ├── strnum@1.0.5 extraneous
    ├── suncalc@1.9.0 extraneous
    ├── suncalc2@1.8.1 extraneous
    ├── supermixer@1.0.5 extraneous
    ├── supports-preserve-symlinks-flag@1.0.0 extraneous
    ├── sweet-collections@1.1.0 extraneous
    ├── symbol-tree@3.2.4 extraneous
    ├── systeminformation@5.23.4 extraneous
    ├── tar-fs@2.1.1 extraneous
    ├── tar-stream@3.1.7 extraneous
    ├── tcp-port-used@1.0.2 extraneous
    ├── text-decoder@1.1.1 extraneous
    ├── text-hex@1.0.0 extraneous
    ├── thirty-two@1.0.2 extraneous
    ├── through2@2.0.5 extraneous
    ├── tiny-typed-emitter@2.1.0 extraneous
    ├── tinycolor2@1.6.0 extraneous
    ├── tr46@4.1.1 extraneous
    ├── triple-beam@1.4.1 extraneous
    ├── tsdav@2.1.1 extraneous
    ├── tslib@2.3.0 extraneous
    ├── typed-array-buffer@1.0.2 extraneous
    ├── typed-array-byte-length@1.0.1 extraneous
    ├── typed-array-byte-offset@1.0.2 extraneous
    ├── typed-array-length@1.0.6 extraneous
    ├── typedarray.prototype.slice@1.0.3 extraneous
    ├── typescript@ extraneous
    ├── tz-offset@0.0.1 extraneous
    ├── unbox-primitive@1.0.2 extraneous
    ├── unique-filename@2.0.1 extraneous
    ├── unique-slug@3.0.0 extraneous
    ├── unix-dgram@2.0.6 extraneous
    ├── uri-js@4.4.1 extraneous
    ├── url-join@4.0.1 extraneous
    ├── url-template@2.0.8 extraneous
    ├── virtual-tsc@0.6.2 extraneous
    ├── vue-i18n@8.28.2 extraneous
    ├── vuelidate-messages@0.1.2 extraneous
    ├── vuelidate@0.7.7 extraneous
    ├── vuex-map-fields@1.4.1 extraneous
    ├── w3c-xmlserializer@4.0.0 extraneous
    ├── wake_on_lan@1.0.0 extraneous
    ├── weak-daemon@1.0.3 extraneous
    ├── webdav@4.11.3 extraneous
    ├── webidl-conversions@7.0.0 extraneous
    ├── websocket-stream@5.5.2 extraneous
    ├── whatwg-encoding@2.0.0 extraneous
    ├── whatwg-mimetype@3.0.0 extraneous
    ├── whatwg-url@12.0.1 extraneous
    ├── which-boxed-primitive@1.0.2 extraneous
    ├── which-typed-array@1.1.15 extraneous
    ├── window-size@0.1.4 extraneous
    ├── winston-daily-rotate-file@5.0.0 extraneous
    ├── winston-seq-updated@1.0.4 extraneous
    ├── winston-syslog@2.7.1 extraneous
    ├── winston-transport@4.7.1 extraneous
    ├── winston@3.14.2 extraneous
    ├── worker-timers-broker@6.1.8 extraneous
    ├── worker-timers-worker@7.0.71 extraneous
    ├── worker-timers@7.1.8 extraneous
    ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
    ├── wrap-ansi@8.1.0 extraneous
    ├── xml-js@1.6.11 extraneous
    ├── xml-name-validator@4.0.0 extraneous
    ├── xmlchars@2.2.0 extraneous
    ├── xregexp@2.0.0 extraneous
    ├── yargs@7.1.2
    ├── zip-stream@6.0.1 extraneous
    └── zrender@ extraneous
    npm error code ELSPROBLEMS
    npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
    npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
    npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
    npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
    npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
    npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
    npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
    npm error extraneous: @azure/core-http-compat@2.1.2 /opt/iobroker/node_modules/@azure/core-http-compat
    npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
    npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
    npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
    npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
    npm error extraneous: @azure/core-util@1.9.2 /opt/iobroker/node_modules/@azure/core-util
    npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
    npm error extraneous: @azure/keyvault-keys@4.8.0 /opt/iobroker/node_modules/@azure/keyvault-keys
    npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
    npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
    npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
    npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
    npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
    npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
    npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
    npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
    npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
    npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
    npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
    npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
    npm error extraneous: @iobroker/db-base@6.0.10 /opt/iobroker/node_modules/@iobroker/db-base
    npm error extraneous: @iobroker/db-objects-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-file
    npm error extraneous: @iobroker/db-objects-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
    npm error extraneous: @iobroker/db-objects-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-redis
    npm error extraneous: @iobroker/db-states-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-file
    npm error extraneous: @iobroker/db-states-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
    npm error extraneous: @iobroker/db-states-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-redis
    npm error extraneous: @iobroker/js-controller-adapter@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-adapter
    npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
    npm error extraneous: @iobroker/js-controller-common-db@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
    npm error extraneous: @iobroker/js-controller-common@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common
    npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
    npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
    npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
    npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
    npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
    npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
    npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
    npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
    npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
    npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
    npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
    npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
    npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
    npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
    npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
    npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
    npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
    npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
    npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
    npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
    npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
    npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
    npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
    npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
    npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
    npm error extraneous: @sentry/node@5.30.0 /opt/iobroker/node_modules/@sentry/node
    npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
    npm error extraneous: @sentry/types@5.30.0 /opt/iobroker/node_modules/@sentry/types
    npm error extraneous: @sentry/utils@5.30.0 /opt/iobroker/node_modules/@sentry/utils
    npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
    npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
    npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
    npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
    npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
    npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
    npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
    npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
    npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
    npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
    npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
    npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
    npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
    npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
    npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
    npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
    npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
    npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
    npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
    npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
    npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
    npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
    npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
    npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
    npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
    npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
    npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
    npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
    npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
    npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
    npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
    npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
    npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
    npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
    npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
    npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
    npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
    npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
    npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
    npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
    npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
    npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
    npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
    npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
    npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
    npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
    npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
    npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
    npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
    npm error extraneous: crc@4.1.1 /opt/iobroker/node_modules/crc
    npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
    npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
    npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
    npm error extraneous: cssstyle@3.0.0 /opt/iobroker/node_modules/cssstyle
    npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
    npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
    npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
    npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
    npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
    npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
    npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
    npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
    npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
    npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
    npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
    npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
    npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
    npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
    npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
    npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
    npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
    npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
    npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
    npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
    npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
    npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
    npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
    npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
    npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
    npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
    npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
    npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
    npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
    npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
    npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
    npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
    npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
    npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
    npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
    npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
    npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
    npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
    npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
    npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
    npm error extraneous: fast-unique-numbers@8.0.13 /opt/iobroker/node_modules/fast-unique-numbers
    npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
    npm error extraneous: fast-xml-parser@4.4.1 /opt/iobroker/node_modules/fast-xml-parser
    npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
    npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
    npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
    npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
    npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
    npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
    npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
    npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
    npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
    npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
    npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
    npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
    npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
    npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
    npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
    npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
    npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
    npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
    npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
    npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
    npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
    npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
    npm error extraneous: google-auth-library@8.9.0 /opt/iobroker/node_modules/google-auth-library
    npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
    npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
    npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
    npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
    npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
    npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
    npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
    npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
    npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
    npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
    npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
    npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
    npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
    npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
    npm error extraneous: ical.js@1.5.0 /opt/iobroker/node_modules/ical.js
    npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
    npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
    npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
    npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
    npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
    npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
    npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
    npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
    npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
    npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
    npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
    npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
    npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
    npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
    npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
    npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
    npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
    npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
    npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
    npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
    npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
    npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
    npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
    npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
    npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
    npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
    npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
    npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
    npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
    npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
    npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
    npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
    npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
    npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
    npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
    npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
    npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
    npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
    npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
    npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
    npm error extraneous: ioredis@4.28.5 /opt/iobroker/node_modules/ioredis
    npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
    npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
    npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
    npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
    npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
    npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
    npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
    npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
    npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
    npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
    npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
    npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
    npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
    npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
    npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
    npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
    npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
    npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
    npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
    npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
    npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
    npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
    npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
    npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
    npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
    npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
    npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
    npm error extraneous: js-yaml@3.14.1 /opt/iobroker/node_modules/js-yaml
    npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
    npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
    npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
    npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
    npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
    npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
    npm error extraneous: jsonata@2.0.5 /opt/iobroker/node_modules/jsonata
    npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
    npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
    npm error extraneous: jszip@3.10.1 /opt/iobroker/node_modules/jszip
    npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
    npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
    npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
    npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
    npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
    npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
    npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
    npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
    npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
    npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
    npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
    npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
    npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
    npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
    npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
    npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
    npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
    npm error extraneous: logform@2.6.1 /opt/iobroker/node_modules/logform
    npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
    npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
    npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
    npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
    npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
    npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
    npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
    npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
    npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
    npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
    npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
    npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
    npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
    npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
    npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
    npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
    npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
    npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
    npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
    npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
    npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
    npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
    npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
    npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
    npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
    npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
    npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
    npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
    npm error extraneous: node-gyp@9.3.0 /opt/iobroker/node_modules/node-gyp
    npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
    npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
    npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
    npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
    npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
    npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
    npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
    npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
    npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
    npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
    npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
    npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
    npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
    npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
    npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
    npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
    npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
    npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
    npm error extraneous: pako@1.0.11 /opt/iobroker/node_modules/pako
    npm error extraneous: parse5@7.1.2 /opt/iobroker/node_modules/parse5
    npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
    npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
    npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
    npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
    npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
    npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
    npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
    npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
    npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
    npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
    npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
    npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
    npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
    npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
    npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
    npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
    npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
    npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
    npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
    npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
    npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
    npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
    npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
    npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
    npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
    npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
    npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
    npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
    npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
    npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
    npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
    npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
    npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
    npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
    npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
    npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
    npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
    npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
    npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
    npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
    npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
    npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
    npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
    npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
    npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
    npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
    npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
    npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
    npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
    npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
    npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
    npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
    npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
    npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
    npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
    npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
    npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
    npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
    npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
    npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
    npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
    npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
    npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
    npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
    npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
    npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
    npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
    npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
    npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
    npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
    npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
    npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
    npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
    npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
    npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
    npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
    npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
    npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
    npm error extraneous: systeminformation@5.23.4 /opt/iobroker/node_modules/systeminformation
    npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
    npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
    npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
    npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
    npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
    npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
    npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
    npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
    npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
    npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
    npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
    npm error extraneous: tsdav@2.1.1 /opt/iobroker/node_modules/tsdav
    npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
    npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
    npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
    npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
    npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
    npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
    npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
    npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
    npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
    npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
    npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
    npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
    npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
    npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
    npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
    npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm error extraneous: vue-i18n@8.28.2 /opt/iobroker/node_modules/vue-i18n
    npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
    npm error extraneous: vuelidate@0.7.7 /opt/iobroker/node_modules/vuelidate
    npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
    npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
    npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
    npm error extraneous: webdav@4.11.3 /opt/iobroker/node_modules/webdav
    npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
    npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
    npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
    npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
    npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
    npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
    npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
    npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
    npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
    npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
    npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
    npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
    npm error extraneous: winston@3.14.2 /opt/iobroker/node_modules/winston
    npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
    npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
    npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
    npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
    npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
    npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
    npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
    npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
    npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
    npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
    npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T19_53_39_857Z-debug-0.log
    flo@ioBrokerdebian:/opt/iobroker$
    @flommaster
    groups
    F 1 Antwort Letzte Antwort
      @flommaster
      groups
      flommaster
      @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
      groups
      flo@ioBrokerdebian:/opt/iobroker$ groups
      flo adm cdrom floppy sudo audio dip video plugdev netdev iobroker
      • F flommaster
        groups
        @flommaster
        Das passt. Was mich wundert ist die Frage nach sudo und passwort oben. Das sollte eigentlich nicht kommen bei den Gruppen. Außer du hast dir per root da komplett das Rechtegefüge zerdeppert...
        iob fix
        sagt?
          @flommaster
          iob fix
          sagt?
          flommaster
          iob fix
          Da will er wieder das Passwort für sudo...
          flo@ioBrokerdebian:/opt/iobroker$ iob fix
          library: loaded
          Library version=2024-05-24
              Welcome to the ioBroker installation fixer!
              Script version: 2024-01-04
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          [sudo] Passwort für flo:
          OK:1 http://deb.debian.org/debian bookworm InRelease
          Holen:2 http://deb.debian.org/debian bookworm-updates InRelease [55,4 kB]
          Holen:3 http://deb.debian.org/debian-security bookworm-security InRelease [48,0 kB]
          OK:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Holen:5 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages [170 kB]
          Holen:6 http://deb.debian.org/debian-security bookworm-security/main Translation-en [103 kB]
          Es wurden 377 kB in 1 s geholt (342 kB/s).
              Checking ioBroker user and directory permissions (2/5)
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 1 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          • F flommaster
            iob fix
            library: loaded
            Done.
            Autostart enabled!
            @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
            Da ergibt das auch Sinn.
            • F flommaster
              iob fix
              library: loaded
              Done.
              Autostart enabled!
              @flommaster
              Alles wird im Verzeichnis /opt/iobroker aufgerufen:
              npm prune
              npm ls
                @flommaster
                npm prune
                npm ls
                flommaster
                @flommaster
                npm prune
                npm ls
                Das hatte ich im Post vor ein paar Minunten schon geteilt.
                https://forum.iobroker.net/post/1193208
                • F flommaster
                  @flommaster
                  npm prune
                  npm ls
                  Da hattes du aber den fix noch nicht drübergejagt.
                  Und ich muss den aktuellen Output sehen, nicht den von vorhin.
                    flommaster
                    Alles klar. Hier sind die neusten Ergebnisse. :-)
                    Der Befehl npm prune läuft ganz schön lange... (ca. 15 Minuten)
                    npm prune
                    flo@ioBrokerdebian:/opt/iobroker$ npm prune
                    npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                    npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                    npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                    npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                    npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                    npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                    npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                    npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                    npm warn deprecated har-validator@5.1.5: this library is no longer supported
                    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                    npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                    npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                    npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                    npm warn deprecated
                    npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                    npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                    npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                    npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                    npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                    npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                    npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                    npm warn deprecated gauge@3.0.2: This package is no longer supported.
                    npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                    npm warn deprecated gauge@4.0.4: This package is no longer supported.
                    npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                    npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                    npm error code 127
                    npm error path /opt/iobroker/node_modules/zlib
                    npm error command failed
                    npm error command sh -c node-waf clean || true; node-waf configure build
                    npm error sh: 1: node-waf: not found
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T20_20_03_692Z-debug-0.log
                    npm ls
                    flo@ioBrokerdebian:/opt/iobroker$ npm ls
                    iobroker.inst@2.0.3 /opt/iobroker
                    ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                    ├── @alcalzone/jsonl-db@3.1.1 extraneous
                    ├── @alcalzone/pak@0.8.1 extraneous
                    ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                    ├── @azure/abort-controller@1.1.0 extraneous
                    ├── @azure/core-auth@1.7.2 extraneous
                    ├── @azure/core-client@ extraneous
                    ├── @azure/core-http-compat@2.1.2 extraneous
                    ├── @azure/core-lro@ extraneous
                    ├── @azure/core-paging@1.6.2 extraneous
                    ├── @azure/core-rest-pipeline@ extraneous
                    ├── @azure/core-tracing@1.1.2 extraneous
                    ├── @azure/core-util@1.9.2 extraneous
                    ├── @azure/identity@ extraneous
                    ├── @azure/keyvault-keys@4.8.0 extraneous
                    ├── @azure/logger@1.1.4 extraneous
                    ├── @azure/msal-browser@ extraneous
                    ├── @azure/msal-common@ extraneous
                    ├── @azure/msal-node@ extraneous
                    ├── @babel/runtime@ extraneous
                    ├── @colors/colors@1.5.0 extraneous
                    ├── @dabh/diagnostics@2.0.3 extraneous
                    ├── @datalust/winston-seq@1.0.2 extraneous
                    ├── @gar/promisify@1.1.3 extraneous
                    ├── @googleapis/calendar@9.7.7 extraneous
                    ├── @googleapis/drive@5.1.0 extraneous
                    ├── @googleapis/oauth2@1.0.7 extraneous
                    ├── @iobroker/db-base@6.0.10 extraneous
                    ├── @iobroker/db-objects-file@6.0.10 extraneous
                    ├── @iobroker/db-objects-jsonl@6.0.10 extraneous
                    ├── @iobroker/db-objects-redis@6.0.10 extraneous
                    ├── @iobroker/db-states-file@6.0.10 extraneous
                    ├── @iobroker/db-states-jsonl@6.0.10 extraneous
                    ├── @iobroker/db-states-redis@6.0.10 extraneous
                    ├── @iobroker/js-controller-adapter@6.0.10 extraneous
                    ├── @iobroker/js-controller-cli@ extraneous
                    ├── @iobroker/js-controller-common-db@6.0.10 extraneous
                    ├── @iobroker/js-controller-common@6.0.10 extraneous
                    ├── @iobroker/plugin-base@1.2.1 extraneous
                    ├── @iobroker/plugin-sentry@1.2.1 extraneous
                    ├── @iobroker/socket-classes@1.5.6 extraneous
                    ├── @iobroker/webserver@1.0.3 extraneous
                    ├── @isaacs/cliui@8.0.2 extraneous
                    ├── @js-joda/core@ extraneous
                    ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                    ├── @npmcli/fs@2.1.2 extraneous
                    ├── @npmcli/move-file@2.0.1 extraneous
                    ├── @pkgjs/parseargs@0.11.0 extraneous
                    ├── @protobufjs/aspromise@1.1.2 extraneous
                    ├── @protobufjs/base64@1.1.2 extraneous
                    ├── @protobufjs/codegen@2.0.4 extraneous
                    ├── @protobufjs/eventemitter@1.1.0 extraneous
                    ├── @protobufjs/fetch@1.1.0 extraneous
                    ├── @protobufjs/float@1.0.2 extraneous
                    ├── @protobufjs/inquire@1.1.0 extraneous
                    ├── @protobufjs/path@1.1.2 extraneous
                    ├── @protobufjs/pool@1.1.0 extraneous
                    ├── @protobufjs/utf8@1.1.0 extraneous
                    ├── @quasar/extras@ extraneous
                    ├── @sentry-internal/tracing@ extraneous
                    ├── @sentry/core@5.30.0 extraneous
                    ├── @sentry/hub@5.30.0 extraneous
                    ├── @sentry/minimal@5.30.0 extraneous
                    ├── @sentry/node@5.30.0 extraneous
                    ├── @sentry/tracing@ extraneous
                    ├── @sentry/types@5.30.0 extraneous
                    ├── @sentry/utils@5.30.0 extraneous
                    ├── @tootallnate/once@2.0.0 extraneous
                    ├── @types/caseless@0.12.5 extraneous
                    ├── @types/geojson@7946.0.14 extraneous
                    ├── @types/leaflet@1.9.12 extraneous
                    ├── @types/node-cron@2.0.8 extraneous
                    ├── @types/request@2.48.12 extraneous
                    ├── @types/tough-cookie@4.0.5 extraneous
                    ├── @types/triple-beam@1.3.5 extraneous
                    ├── @types/tz-offset@0.0.3 extraneous
                    ├── abab@2.0.6 extraneous
                    ├── agentkeepalive@4.5.0 extraneous
                    ├── ajv@ extraneous
                    ├── anymatch@3.1.3 extraneous
                    ├── archiver-utils@5.0.2 extraneous
                    ├── archiver@7.0.1 extraneous
                    ├── argparse@1.0.10 extraneous
                    ├── array-buffer-byte-length@1.0.1 extraneous
                    ├── arraybuffer.prototype.slice@1.0.3 extraneous
                    ├── arrify@2.0.1 extraneous
                    ├── available-typed-arrays@1.0.7 extraneous
                    ├── b4a@1.6.6 extraneous
                    ├── bare-events@2.4.2 extraneous
                    ├── base-64@1.0.0 extraneous
                    ├── binary-extensions@2.3.0 extraneous
                    ├── bindings@1.5.0 extraneous
                    ├── bottleneck@2.19.5 extraneous
                    ├── brace-expansion@2.0.1 extraneous
                    ├── buffer-crc32@1.0.0 extraneous
                    ├── buffer-equal-constant-time@1.0.1 extraneous
                    ├── buffer-shims@1.0.0 extraneous
                    ├── buildcheck@0.0.6 extraneous
                    ├── busboy@1.6.0 extraneous
                    ├── byte-length@1.0.2 extraneous
                    ├── cacache@16.1.3 extraneous
                    ├── charenc@0.0.2 extraneous
                    ├── chokidar@3.6.0 extraneous
                    ├── ci-info@3.9.0 extraneous
                    ├── cloneextend@0.0.3 extraneous
                    ├── cluster-key-slot@1.1.2 extraneous
                    ├── coffeescript@1.12.7 extraneous
                    ├── color-string@1.9.1 extraneous
                    ├── color@3.2.1 extraneous
                    ├── colors@1.4.0
                    ├── colorspace@1.1.4 extraneous
                    ├── commist@3.2.0 extraneous
                    ├── compress-commons@6.0.2 extraneous
                    ├── compress-json@2.1.2 extraneous
                    ├── compressible@2.0.18 extraneous
                    ├── compression@1.7.4 extraneous
                    ├── core-js@ extraneous
                    ├── crc-32@1.2.2 extraneous
                    ├── crc@4.1.1 extraneous
                    ├── crc32-stream@6.0.0 extraneous
                    ├── cross-fetch@4.0.0 extraneous
                    ├── crypt@0.0.2 extraneous
                    ├── cssstyle@3.0.0 extraneous
                    ├── cycle@1.0.3 extraneous
                    ├── data-urls@4.0.0 extraneous
                    ├── data-view-buffer@1.0.1 extraneous
                    ├── data-view-byte-length@1.0.1 extraneous
                    ├── data-view-byte-offset@1.0.0 extraneous
                    ├── date-and-time@ extraneous
                    ├── dayjs@ extraneous
                    ├── decache@4.6.2 extraneous
                    ├── decimal.js@10.4.3 extraneous
                    ├── deep-clone@3.0.3 extraneous
                    ├── define-lazy-prop@2.0.0 extraneous
                    ├── denque@1.5.1 extraneous
                    ├── digest-header@1.1.0 extraneous
                    ├── diskusage@1.2.0 extraneous
                    ├── domexception@4.0.0 extraneous
                    ├── draftlog@1.0.13 extraneous
                    ├── dropbox-v2-api@ extraneous
                    ├── duplexer@0.1.2 extraneous
                    ├── eastasianwidth@0.2.0 extraneous
                    ├── ecdsa-sig-formatter@1.0.11 extraneous
                    ├── echarts@ extraneous
                    ├── emoji-regex@9.2.2 extraneous
                    ├── enabled@2.0.0 extraneous
                    ├── entities@4.5.0 extraneous
                    ├── err-code@2.0.3 extraneous
                    ├── es-abstract@ extraneous
                    ├── es-aggregate-error@1.0.13 extraneous
                    ├── es-object-atoms@1.0.0 extraneous
                    ├── es-set-tostringtag@2.0.3 extraneous
                    ├── es-to-primitive@1.2.1 extraneous
                    ├── es6-promise@4.2.8 extraneous
                    ├── es6-promisify@5.0.0 extraneous
                    ├── esbuild@0.11.23 extraneous
                    ├── event-stream@4.0.1 extraneous
                    ├── expand-template@2.0.3 extraneous
                    ├── express-fileupload@1.5.1 extraneous
                    ├── fast-deep-equal@3.1.3 extraneous
                    ├── fast-fifo@1.3.2 extraneous
                    ├── fast-json-stable-stringify@2.1.0 extraneous
                    ├── fast-text-encoding@1.0.6 extraneous
                    ├── fast-unique-numbers@8.0.13 extraneous
                    ├── fast-uri@3.0.1 extraneous
                    ├── fast-xml-parser@4.4.1 extraneous
                    ├── fecha@4.2.3 extraneous
                    ├── file-stream-rotator@0.6.1 extraneous
                    ├── file-type@10.11.0 extraneous
                    ├── file-uri-to-path@1.0.0 extraneous
                    ├── fn.name@1.1.0 extraneous
                    ├── for-each@0.3.3 extraneous
                    ├── foreground-child@3.3.0 extraneous
                    ├── from@0.1.7 extraneous
                    ├── fs-constants@1.0.0 extraneous
                    ├── fs-extra@7.0.1
                    ├── fsevents@ extraneous
                    ├── ftp@0.3.10 extraneous
                    ├── function.prototype.name@1.1.6 extraneous
                    ├── functions-have-names@1.2.3 extraneous
                    ├── futoin-hkdf@1.4.3 extraneous
                    ├── gaxios@5.1.3 extraneous
                    ├── gcp-metadata@5.3.0 extraneous
                    ├── get-ssl-certificate@2.3.3 extraneous
                    ├── get-symbol-description@1.0.2 extraneous
                    ├── github-from-package@0.0.0 extraneous
                    ├── glob@10.4.5 extraneous
                    ├── globalthis@1.0.4 extraneous
                    ├── glossy@0.1.7 extraneous
                    ├── google-auth-library@8.9.0 extraneous
                    ├── google-p12-pem@4.0.1 extraneous
                    ├── googleapis-common@6.0.4 extraneous
                    ├── googleapis@ extraneous
                    ├── gtoken@6.1.2 extraneous
                    ├── has-bigints@1.0.2 extraneous
                    ├── has-tostringtag@1.0.2 extraneous
                    ├── he@1.2.0 extraneous
                    ├── help-me@5.0.0 extraneous
                    ├── homebridge-plugin-wrapper@ extraneous
                    ├── hot-patcher@1.0.0 extraneous
                    ├── html-encoding-sniffer@3.0.0 extraneous
                    ├── http-proxy-agent@5.0.0 extraneous
                    ├── https@1.0.0 extraneous
                    ├── humanize-ms@1.2.1 extraneous
                    ├── ical.js@1.5.0 extraneous
                    ├── image-type@4.1.0 extraneous
                    ├── infer-owner@1.0.4 extraneous
                    ├── internal-slot@1.0.7 extraneous
                    ├── iobroker-adapter-helpers@0.0.8 extraneous
                    ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                    ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                    ├── iobroker.bmw@2.5.7
                    ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                    ├── iobroker.cloud@4.4.1
                    ├── iobroker.coronavirus-statistics@0.8.7
                    ├── iobroker.daswetter@3.1.10
                    ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                    ├── iobroker.dwd@2.8.5
                    ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                    ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                    ├── iobroker.eusec@1.1.2
                    ├── iobroker.flot@ invalid: "1.12.0" from the root project
                    ├── iobroker.fritzbox@0.2.1
                    ├── iobroker.fullcalendar@1.2.0
                    ├── iobroker.fullybrowser@2.1.2
                    ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                    ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                    ├── iobroker.harmony@1.2.2
                    ├── iobroker.heatingcontrol@2.11.1
                    ├── iobroker.history@2.2.6
                    ├── iobroker.hm-rega@3.0.47
                    ├── iobroker.hm-rpc@1.15.19
                    ├── iobroker.hue@3.9.5
                    ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                    ├── iobroker.icons-icons8@0.0.1
                    ├── iobroker.icons-material-png@0.1.0
                    ├── iobroker.icons-mfd-png@1.1.0
                    ├── iobroker.icons-ultimate-png@1.0.1
                    ├── iobroker.info@ invalid: "1.9.26" from the root project
                    ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                    ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                    ├── iobroker.logparser@2.2.0
                    ├── iobroker.material@ invalid: "1.3.1" from the root project
                    ├── iobroker.meross@1.15.1
                    ├── iobroker.mihome-vacuum@3.11.0
                    ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                    ├── iobroker.milight@0.3.6
                    ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                    ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                    ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                    ├── iobroker.nina@ invalid: "0.0.25" from the root project
                    ├── iobroker.pollenflug@1.0.6
                    ├── iobroker.pushover@3.0.3
                    ├── iobroker.pushsafer@1.0.3
                    ├── iobroker.pvforecast@2.7.1
                    ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                    ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                    ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                    ├── iobroker.simple-api@2.7.2
                    ├── iobroker.smartmeter@3.3.4
                    ├── iobroker.socketio@6.5.2
                    ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                    ├── iobroker.sql@2.2.0
                    ├── iobroker.statistics@2.3.0
                    ├── iobroker.sunnyportal@0.1.5
                    ├── iobroker.synology@2.1.13
                    ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                    ├── iobroker.terminal@1.0.0
                    ├── iobroker.tr-064@4.2.18
                    ├── iobroker.trashschedule@2.2.0
                    ├── iobroker.unifi@0.6.6
                    ├── iobroker.upnp@1.0.21
                    ├── iobroker.valloxmv@1.2.0
                    ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                    ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                    ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                    ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                    ├── iobroker.vis-colorpicker@2.0.3
                    ├── iobroker.vis-fancyswitch@1.1.0
                    ├── iobroker.vis-google-fonts@1.0.4
                    ├── iobroker.vis-history@1.0.0
                    ├── iobroker.vis-hqwidgets@1.4.0
                    ├── iobroker.vis-inventwo@3.3.3
                    ├── iobroker.vis-jqui-mfd@1.0.12
                    ├── iobroker.vis-justgage@1.0.2
                    ├── iobroker.vis-map@1.0.4
                    ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                    ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                    ├── iobroker.vis-rgraph@0.0.2
                    ├── iobroker.vis-timeandweather@1.2.2
                    ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                    ├── iobroker.vis@ invalid: "1.4.16" from the root project
                    ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                    ├── iobroker.weatherunderground@3.4.2
                    ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                    ├── iobroker.web@ invalid: "6.1.0" from the root project
                    ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                    ├── iobroker.wiffi-wz@2.2.1
                    ├── iobroker.windows-control@0.1.5
                    ├── iobroker.worx@2.3.2
                    ├── iobroker.ws@2.5.3
                    ├── iobroker@2.0.3
                    ├── ioredis@4.28.5 extraneous
                    ├── ip-address@9.0.5 extraneous
                    ├── ip-regex@4.3.0 extraneous
                    ├── ipaddr.js@2.2.0 extraneous
                    ├── is-array-buffer@3.0.4 extraneous
                    ├── is-bigint@1.0.4 extraneous
                    ├── is-binary-path@2.1.0 extraneous
                    ├── is-boolean-object@1.1.2 extraneous
                    ├── is-buffer@1.1.6 extraneous
                    ├── is-callable@1.2.7 extraneous
                    ├── is-data-view@1.0.1 extraneous
                    ├── is-date-object@1.0.5 extraneous
                    ├── is-empty-object@1.1.1 extraneous
                    ├── is-lambda@1.0.1 extraneous
                    ├── is-negative-zero@2.0.3 extraneous
                    ├── is-number-object@1.0.7 extraneous
                    ├── is-potential-custom-element-name@1.0.1 extraneous
                    ├── is-regex@1.1.4 extraneous
                    ├── is-shared-array-buffer@1.0.3 extraneous
                    ├── is-string@1.0.7 extraneous
                    ├── is-symbol@1.0.4 extraneous
                    ├── is-typed-array@1.1.13 extraneous
                    ├── is-url@1.2.4 extraneous
                    ├── is-weakref@1.0.2 extraneous
                    ├── is@3.3.0 extraneous
                    ├── is2@2.0.9 extraneous
                    ├── jackspeak@3.4.3 extraneous
                    ├── js-md4@0.3.2 extraneous
                    ├── js-yaml@3.14.1 extraneous
                    ├── jsbi@4.3.0 extraneous
                    ├── jsbn@1.1.0 extraneous
                    ├── jsdom@ extraneous
                    ├── jshashes@1.0.8 extraneous
                    ├── json-schema-traverse@1.0.0 extraneous
                    ├── json5@2.2.3 extraneous
                    ├── jsonata@2.0.5 extraneous
                    ├── jsonc-parser@3.3.1 extraneous
                    ├── jsonwebtoken@9.0.2 extraneous
                    ├── jszip@3.10.1 extraneous
                    ├── jwa@2.0.0 extraneous
                    ├── jws@4.0.0 extraneous
                    ├── kuler@2.0.0 extraneous
                    ├── layerr@0.1.2 extraneous
                    ├── lazystream@1.0.1 extraneous
                    ├── lie@3.3.0 extraneous
                    ├── loadavg-windows@1.1.1 extraneous
                    ├── lodash.defaults@4.2.0 extraneous
                    ├── lodash.flatten@4.4.0 extraneous
                    ├── lodash.includes@4.3.0 extraneous
                    ├── lodash.isarguments@3.1.0 extraneous
                    ├── lodash.isboolean@3.0.3 extraneous
                    ├── lodash.isinteger@4.0.4 extraneous
                    ├── lodash.isnumber@3.0.3 extraneous
                    ├── lodash.isplainobject@4.0.6 extraneous
                    ├── lodash.isstring@4.0.1 extraneous
                    ├── lodash.once@4.1.1 extraneous
                    ├── logform@2.6.1 extraneous
                    ├── long@5.2.3 extraneous
                    ├── make-fetch-happen@10.2.1 extraneous
                    ├── map-stream@0.0.7 extraneous
                    ├── md5@2.3.0 extraneous
                    ├── mime-db@1.53.0 extraneous
                    ├── minimatch@9.0.5 extraneous
                    ├── minipass-collect@1.0.2 extraneous
                    ├── minipass-fetch@2.1.2 extraneous
                    ├── minipass-flush@1.0.5 extraneous
                    ├── minipass-pipeline@1.2.4 extraneous
                    ├── minipass-sized@1.0.3 extraneous
                    ├── minipass@7.1.2 extraneous
                    ├── mkdirp-classic@0.5.3 extraneous
                    ├── mock-require@3.0.3 extraneous
                    ├── moment-duration-format@2.3.2 extraneous
                    ├── mqtt-connection@4.1.0 extraneous
                    ├── mqtt-packet@9.0.0 extraneous
                    ├── mqtt@ extraneous
                    ├── nanoid@3.3.7 extraneous
                    ├── napi-build-utils@1.0.2 extraneous
                    ├── native-duplexpair@1.0.0 extraneous
                    ├── nconf@0.10.0 extraneous
                    ├── nested-property@4.0.0 extraneous
                    ├── netmask@2.0.2 extraneous
                    ├── node-abi@3.65.0 extraneous
                    ├── node-abort-controller@3.1.1 extraneous
                    ├── node-cron@2.0.3 extraneous
                    ├── node-forge@ extraneous
                    ├── node-gyp@9.3.0 extraneous
                    ├── node-ical@0.16.1 extraneous
                    ├── node-inspect@2.0.0 extraneous
                    ├── node-libcurl@3.0.0 extraneous
                    ├── node-mndp@0.0.3 extraneous
                    ├── node-persist@0.0.11 extraneous
                    ├── node-rsa@1.1.1 extraneous
                    ├── node-wol@0.1.1 extraneous
                    ├── node.extend@2.0.3 extraneous
                    ├── normalize-path@3.0.0 extraneous
                    ├── nwsapi@2.2.12 extraneous
                    ├── object-hash@3.0.0 extraneous
                    ├── one-time@1.0.0 extraneous
                    ├── onedrive-api@1.1.1 extraneous
                    ├── opencollective-postinstall@2.0.3 extraneous
                    ├── ospath@1.2.2 extraneous
                    ├── osx-temperature-sensor@ extraneous
                    ├── otplib@11.0.1 extraneous
                    ├── p-throttle@4.1.1 extraneous
                    ├── package-json-from-dist@1.0.0 extraneous
                    ├── pako@1.0.11 extraneous
                    ├── parse5@7.1.2 extraneous
                    ├── passport@0.7.0 extraneous
                    ├── path-parse@1.0.7 extraneous
                    ├── path-posix@1.0.0 extraneous
                    ├── path-scurry@1.11.1 extraneous
                    ├── pause-stream@0.0.11 extraneous
                    ├── pidusage@3.0.2 extraneous
                    ├── ping@0.4.4 extraneous
                    ├── pluralize@8.0.0 extraneous
                    ├── possible-typed-array-names@1.0.0 extraneous
                    ├── prebuild-install@7.1.2 extraneous
                    ├── promise-inflight@1.0.1 extraneous
                    ├── promise-object@0.1.7 extraneous
                    ├── promise-retry@2.0.1 extraneous
                    ├── promise-retryer@0.0.1 extraneous
                    ├── promisify-child-process@4.1.2 extraneous
                    ├── prompt@1.3.0 extraneous
                    ├── protobufjs@ extraneous
                    ├── proxy-from-env@1.1.0 extraneous
                    ├── q@1.1.2 extraneous
                    ├── quasar@ extraneous
                    ├── queue-tick@1.0.1 extraneous
                    ├── read@1.0.7 extraneous
                    ├── readdir-glob@1.1.3 extraneous
                    ├── readdirp@3.6.0 extraneous
                    ├── readline-sync@1.4.10 extraneous
                    ├── readline@1.3.0 extraneous
                    ├── redis-commands@1.7.0 extraneous
                    ├── redis-errors@1.2.0 extraneous
                    ├── redis-parser@3.0.0 extraneous
                    ├── regenerator-runtime@0.14.1 extraneous
                    ├── regex-escape@3.4.10 extraneous
                    ├── regexp.prototype.flags@1.5.2 extraneous
                    ├── remove-trailing-separator@1.1.0 extraneous
                    ├── require-from-string@2.0.2 extraneous
                    ├── respjs@4.2.0 extraneous
                    ├── retry-axios@2.6.0 extraneous
                    ├── retry@0.12.0 extraneous
                    ├── revalidator@0.1.8 extraneous
                    ├── rrule@2.8.1 extraneous
                    ├── rrweb-cssom@0.6.0 extraneous
                    ├── safe-array-concat@1.1.2 extraneous
                    ├── safe-regex-test@1.0.3 extraneous
                    ├── safe-stable-stringify@2.4.3 extraneous
                    ├── saxes@6.0.0 extraneous
                    ├── secure-keys@1.0.0 extraneous
                    ├── semver@5.7.2
                    ├── seq-logging@1.1.2 extraneous
                    ├── set-function-name@2.0.2 extraneous
                    ├── setimmediate@1.0.5 extraneous
                    ├── signal-exit@4.1.0 extraneous
                    ├── simple-swizzle@0.2.2 extraneous
                    ├── smart-buffer@4.2.0 extraneous
                    ├── socks-proxy-agent@7.0.0 extraneous
                    ├── socks@2.8.3 extraneous
                    ├── speedtest-net@1.6.2 extraneous
                    ├── sprintf-js@1.1.3 extraneous
                    ├── ssri@9.0.1 extraneous
                    ├── stack-trace@0.0.10 extraneous
                    ├── stampit-event-bus@0.1.1 extraneous
                    ├── stampit-state-machine@0.2.1 extraneous
                    ├── stampit@2.1.2 extraneous
                    ├── standard-as-callback@2.1.0 extraneous
                    ├── stoppable@1.1.0 extraneous
                    ├── stream-combiner@0.2.2 extraneous
                    ├── streamsearch@1.1.0 extraneous
                    ├── streamx@2.18.0 extraneous
                    ├── string-argv@0.3.2 extraneous
                    ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                    ├── string-width@5.1.2 extraneous
                    ├── string.prototype.trim@1.2.9 extraneous
                    ├── string.prototype.trimend@1.0.8 extraneous
                    ├── string.prototype.trimstart@1.0.8 extraneous
                    ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                    ├── strnum@1.0.5 extraneous
                    ├── suncalc@1.9.0 extraneous
                    ├── suncalc2@1.8.1 extraneous
                    ├── supermixer@1.0.5 extraneous
                    ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                    ├── sweet-collections@1.1.0 extraneous
                    ├── symbol-tree@3.2.4 extraneous
                    ├── systeminformation@5.23.4 extraneous
                    ├── tar-fs@2.1.1 extraneous
                    ├── tar-stream@3.1.7 extraneous
                    ├── tcp-port-used@1.0.2 extraneous
                    ├── text-decoder@1.1.1 extraneous
                    ├── text-hex@1.0.0 extraneous
                    ├── thirty-two@1.0.2 extraneous
                    ├── through2@2.0.5 extraneous
                    ├── tiny-typed-emitter@2.1.0 extraneous
                    ├── tinycolor2@1.6.0 extraneous
                    ├── tr46@4.1.1 extraneous
                    ├── triple-beam@1.4.1 extraneous
                    ├── tsdav@2.1.1 extraneous
                    ├── tslib@2.3.0 extraneous
                    ├── typed-array-buffer@1.0.2 extraneous
                    ├── typed-array-byte-length@1.0.1 extraneous
                    ├── typed-array-byte-offset@1.0.2 extraneous
                    ├── typed-array-length@1.0.6 extraneous
                    ├── typedarray.prototype.slice@1.0.3 extraneous
                    ├── typescript@ extraneous
                    ├── tz-offset@0.0.1 extraneous
                    ├── unbox-primitive@1.0.2 extraneous
                    ├── unique-filename@2.0.1 extraneous
                    ├── unique-slug@3.0.0 extraneous
                    ├── unix-dgram@2.0.6 extraneous
                    ├── uri-js@4.4.1 extraneous
                    ├── url-join@4.0.1 extraneous
                    ├── url-template@2.0.8 extraneous
                    ├── virtual-tsc@0.6.2 extraneous
                    ├── vue-i18n@8.28.2 extraneous
                    ├── vuelidate-messages@0.1.2 extraneous
                    ├── vuelidate@0.7.7 extraneous
                    ├── vuex-map-fields@1.4.1 extraneous
                    ├── w3c-xmlserializer@4.0.0 extraneous
                    ├── wake_on_lan@1.0.0 extraneous
                    ├── weak-daemon@1.0.3 extraneous
                    ├── webdav@4.11.3 extraneous
                    ├── webidl-conversions@7.0.0 extraneous
                    ├── websocket-stream@5.5.2 extraneous
                    ├── whatwg-encoding@2.0.0 extraneous
                    ├── whatwg-mimetype@3.0.0 extraneous
                    ├── whatwg-url@12.0.1 extraneous
                    ├── which-boxed-primitive@1.0.2 extraneous
                    ├── which-typed-array@1.1.15 extraneous
                    ├── window-size@0.1.4 extraneous
                    ├── winston-daily-rotate-file@5.0.0 extraneous
                    ├── winston-seq-updated@1.0.4 extraneous
                    ├── winston-syslog@2.7.1 extraneous
                    ├── winston-transport@4.7.1 extraneous
                    ├── winston@3.14.2 extraneous
                    ├── worker-timers-broker@6.1.8 extraneous
                    ├── worker-timers-worker@7.0.71 extraneous
                    ├── worker-timers@7.1.8 extraneous
                    ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                    ├── wrap-ansi@8.1.0 extraneous
                    ├── xml-js@1.6.11 extraneous
                    ├── xml-name-validator@4.0.0 extraneous
                    ├── xmlchars@2.2.0 extraneous
                    ├── xregexp@2.0.0 extraneous
                    ├── yargs@7.1.2
                    ├── zip-stream@6.0.1 extraneous
                    └── zrender@ extraneous
                    npm error code ELSPROBLEMS
                    npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                    npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                    npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                    npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                    npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                    npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                    npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                    npm error extraneous: @azure/core-http-compat@2.1.2 /opt/iobroker/node_modules/@azure/core-http-compat
                    npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                    npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                    npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                    npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                    npm error extraneous: @azure/core-util@1.9.2 /opt/iobroker/node_modules/@azure/core-util
                    npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                    npm error extraneous: @azure/keyvault-keys@4.8.0 /opt/iobroker/node_modules/@azure/keyvault-keys
                    npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                    npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                    npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                    npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
                    npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                    npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                    npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                    npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                    npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                    npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                    npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                    npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                    npm error extraneous: @iobroker/db-base@6.0.10 /opt/iobroker/node_modules/@iobroker/db-base
                    npm error extraneous: @iobroker/db-objects-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-file
                    npm error extraneous: @iobroker/db-objects-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                    npm error extraneous: @iobroker/db-objects-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-redis
                    npm error extraneous: @iobroker/db-states-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-file
                    npm error extraneous: @iobroker/db-states-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                    npm error extraneous: @iobroker/db-states-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-redis
                    npm error extraneous: @iobroker/js-controller-adapter@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                    npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                    npm error extraneous: @iobroker/js-controller-common-db@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                    npm error extraneous: @iobroker/js-controller-common@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common
                    npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                    npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                    npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                    npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                    npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                    npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                    npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                    npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                    npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                    npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                    npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                    npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                    npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                    npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                    npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                    npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                    npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                    npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                    npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                    npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                    npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                    npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                    npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                    npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                    npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                    npm error extraneous: @sentry/node@5.30.0 /opt/iobroker/node_modules/@sentry/node
                    npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                    npm error extraneous: @sentry/types@5.30.0 /opt/iobroker/node_modules/@sentry/types
                    npm error extraneous: @sentry/utils@5.30.0 /opt/iobroker/node_modules/@sentry/utils
                    npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                    npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                    npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                    npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                    npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                    npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                    npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                    npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                    npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                    npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                    npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                    npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                    npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                    npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                    npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                    npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                    npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                    npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                    npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                    npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                    npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                    npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                    npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                    npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                    npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                    npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                    npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                    npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                    npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                    npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                    npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                    npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                    npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                    npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                    npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                    npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                    npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                    npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                    npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                    npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                    npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                    npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                    npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                    npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                    npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                    npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                    npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                    npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                    npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                    npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                    npm error extraneous: crc@4.1.1 /opt/iobroker/node_modules/crc
                    npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                    npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                    npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                    npm error extraneous: cssstyle@3.0.0 /opt/iobroker/node_modules/cssstyle
                    npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                    npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                    npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                    npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                    npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                    npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                    npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                    npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                    npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                    npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                    npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                    npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                    npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                    npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                    npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                    npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                    npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                    npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                    npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                    npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                    npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                    npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                    npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                    npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                    npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                    npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                    npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                    npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                    npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                    npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                    npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                    npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                    npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                    npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                    npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                    npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                    npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                    npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                    npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                    npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                    npm error extraneous: fast-unique-numbers@8.0.13 /opt/iobroker/node_modules/fast-unique-numbers
                    npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                    npm error extraneous: fast-xml-parser@4.4.1 /opt/iobroker/node_modules/fast-xml-parser
                    npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                    npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                    npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                    npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                    npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                    npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                    npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                    npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                    npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                    npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                    npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                    npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                    npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                    npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                    npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                    npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                    npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                    npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                    npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                    npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                    npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                    npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                    npm error extraneous: google-auth-library@8.9.0 /opt/iobroker/node_modules/google-auth-library
                    npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                    npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                    npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                    npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                    npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                    npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                    npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                    npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                    npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                    npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                    npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                    npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                    npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                    npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                    npm error extraneous: ical.js@1.5.0 /opt/iobroker/node_modules/ical.js
                    npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                    npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                    npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                    npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                    npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                    npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                    npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                    npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                    npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                    npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                    npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                    npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                    npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                    npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                    npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                    npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                    npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                    npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                    npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                    npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                    npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                    npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                    npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                    npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                    npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                    npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                    npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                    npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                    npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                    npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                    npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                    npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                    npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                    npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                    npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                    npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                    npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                    npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                    npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                    npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                    npm error extraneous: ioredis@4.28.5 /opt/iobroker/node_modules/ioredis
                    npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                    npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                    npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                    npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                    npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                    npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                    npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                    npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                    npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                    npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                    npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                    npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                    npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                    npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                    npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                    npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                    npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                    npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                    npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                    npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                    npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                    npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                    npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                    npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                    npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                    npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                    npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                    npm error extraneous: js-yaml@3.14.1 /opt/iobroker/node_modules/js-yaml
                    npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                    npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                    npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                    npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                    npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                    npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                    npm error extraneous: jsonata@2.0.5 /opt/iobroker/node_modules/jsonata
                    npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                    npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                    npm error extraneous: jszip@3.10.1 /opt/iobroker/node_modules/jszip
                    npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                    npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                    npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                    npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                    npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                    npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                    npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                    npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                    npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                    npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                    npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                    npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                    npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                    npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                    npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                    npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                    npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                    npm error extraneous: logform@2.6.1 /opt/iobroker/node_modules/logform
                    npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                    npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                    npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                    npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                    npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                    npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                    npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                    npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                    npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                    npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                    npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                    npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                    npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                    npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                    npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                    npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                    npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                    npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                    npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                    npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                    npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                    npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                    npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                    npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                    npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                    npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                    npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                    npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                    npm error extraneous: node-gyp@9.3.0 /opt/iobroker/node_modules/node-gyp
                    npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                    npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                    npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                    npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                    npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                    npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                    npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                    npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                    npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                    npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                    npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                    npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                    npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                    npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                    npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                    npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                    npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                    npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                    npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                    npm error extraneous: pako@1.0.11 /opt/iobroker/node_modules/pako
                    npm error extraneous: parse5@7.1.2 /opt/iobroker/node_modules/parse5
                    npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                    npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                    npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                    npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                    npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                    npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                    npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                    npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                    npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                    npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                    npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                    npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                    npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                    npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                    npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                    npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                    npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                    npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                    npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                    npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                    npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                    npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                    npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                    npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                    npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                    npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                    npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                    npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                    npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                    npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                    npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                    npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                    npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                    npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                    npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                    npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                    npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                    npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                    npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                    npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                    npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                    npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                    npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                    npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                    npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                    npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                    npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                    npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                    npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                    npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                    npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                    npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                    npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                    npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                    npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                    npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                    npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                    npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                    npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                    npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                    npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                    npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                    npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                    npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                    npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                    npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                    npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                    npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                    npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                    npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                    npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                    npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                    npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                    npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                    npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                    npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                    npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                    npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                    npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                    npm error extraneous: systeminformation@5.23.4 /opt/iobroker/node_modules/systeminformation
                    npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                    npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                    npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                    npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                    npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                    npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                    npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                    npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                    npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                    npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                    npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                    npm error extraneous: tsdav@2.1.1 /opt/iobroker/node_modules/tsdav
                    npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                    npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                    npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                    npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                    npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                    npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                    npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                    npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                    npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                    npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                    npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                    npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                    npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                    npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                    npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                    npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                    npm error extraneous: vue-i18n@8.28.2 /opt/iobroker/node_modules/vue-i18n
                    npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                    npm error extraneous: vuelidate@0.7.7 /opt/iobroker/node_modules/vuelidate
                    npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                    npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                    npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                    npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                    npm error extraneous: webdav@4.11.3 /opt/iobroker/node_modules/webdav
                    npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                    npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                    npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                    npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                    npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                    npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                    npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                    npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                    npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                    npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                    npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                    npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                    npm error extraneous: winston@3.14.2 /opt/iobroker/node_modules/winston
                    npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                    npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                    npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                    npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                    npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                    npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                    npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                    npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                    npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                    npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                    npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T20_35_20_689Z-debug-0.log
                    flo@ioBrokerdebian:/opt/iobroker$
                    • F flommaster
                      Alles klar. Hier sind die neusten Ergebnisse. :-)
                      Der Befehl npm prune läuft ganz schön lange... (ca. 15 Minuten)
                      npm prune
                      flo@ioBrokerdebian:/opt/iobroker$ npm prune
                      npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                      npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                      npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                      npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                      npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                      npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                      npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                      npm warn deprecated har-validator@5.1.5: this library is no longer supported
                      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                      npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                      npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                      npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                      npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                      npm warn deprecated
                      npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                      npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                      npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                      npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                      npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                      npm warn deprecated gauge@3.0.2: This package is no longer supported.
                      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      npm warn deprecated gauge@4.0.4: This package is no longer supported.
                      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                      npm error code 127
                      npm error path /opt/iobroker/node_modules/zlib
                      npm error command failed
                      npm error command sh -c node-waf clean || true; node-waf configure build
                      npm error sh: 1: node-waf: not found
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T20_20_03_692Z-debug-0.log
                      npm ls
                      flo@ioBrokerdebian:/opt/iobroker$ npm ls
                      [sudo] Passwort für flo:
                      iobroker.inst@2.0.3 /opt/iobroker
                      ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                      ├── @alcalzone/jsonl-db@3.1.1 extraneous
                      ├── @alcalzone/pak@0.8.1 extraneous
                      ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                      ├── @azure/abort-controller@1.1.0 extraneous
                      ├── @azure/core-auth@1.7.2 extraneous
                      ├── @azure/core-client@ extraneous
                      ├── @azure/core-http-compat@2.1.2 extraneous
                      ├── @azure/core-lro@ extraneous
                      ├── @azure/core-paging@1.6.2 extraneous
                      ├── @azure/core-rest-pipeline@ extraneous
                      ├── @azure/core-tracing@1.1.2 extraneous
                      ├── @azure/core-util@1.9.2 extraneous
                      ├── @azure/identity@ extraneous
                      ├── @azure/keyvault-keys@4.8.0 extraneous
                      ├── @azure/logger@1.1.4 extraneous
                      ├── @azure/msal-browser@ extraneous
                      ├── @azure/msal-common@ extraneous
                      ├── @azure/msal-node@ extraneous
                      ├── @babel/runtime@ extraneous
                      ├── @colors/colors@1.5.0 extraneous
                      ├── @dabh/diagnostics@2.0.3 extraneous
                      ├── @datalust/winston-seq@1.0.2 extraneous
                      ├── @gar/promisify@1.1.3 extraneous
                      ├── @googleapis/calendar@9.7.7 extraneous
                      ├── @googleapis/drive@5.1.0 extraneous
                      ├── @googleapis/oauth2@1.0.7 extraneous
                      ├── @iobroker/db-base@6.0.10 extraneous
                      ├── @iobroker/db-objects-file@6.0.10 extraneous
                      ├── @iobroker/db-objects-jsonl@6.0.10 extraneous
                      ├── @iobroker/db-objects-redis@6.0.10 extraneous
                      ├── @iobroker/db-states-file@6.0.10 extraneous
                      ├── @iobroker/db-states-jsonl@6.0.10 extraneous
                      ├── @iobroker/db-states-redis@6.0.10 extraneous
                      ├── @iobroker/js-controller-adapter@6.0.10 extraneous
                      ├── @iobroker/js-controller-cli@ extraneous
                      ├── @iobroker/js-controller-common-db@6.0.10 extraneous
                      ├── @iobroker/js-controller-common@6.0.10 extraneous
                      ├── @iobroker/plugin-base@1.2.1 extraneous
                      ├── @iobroker/plugin-sentry@1.2.1 extraneous
                      ├── @iobroker/socket-classes@1.5.6 extraneous
                      ├── @iobroker/webserver@1.0.3 extraneous
                      ├── @isaacs/cliui@8.0.2 extraneous
                      ├── @js-joda/core@ extraneous
                      ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                      ├── @npmcli/fs@2.1.2 extraneous
                      ├── @npmcli/move-file@2.0.1 extraneous
                      ├── @pkgjs/parseargs@0.11.0 extraneous
                      ├── @protobufjs/aspromise@1.1.2 extraneous
                      ├── @protobufjs/base64@1.1.2 extraneous
                      ├── @protobufjs/codegen@2.0.4 extraneous
                      ├── @protobufjs/eventemitter@1.1.0 extraneous
                      ├── @protobufjs/fetch@1.1.0 extraneous
                      ├── @protobufjs/float@1.0.2 extraneous
                      ├── @protobufjs/inquire@1.1.0 extraneous
                      ├── @protobufjs/path@1.1.2 extraneous
                      ├── @protobufjs/pool@1.1.0 extraneous
                      ├── @protobufjs/utf8@1.1.0 extraneous
                      ├── @quasar/extras@ extraneous
                      ├── @sentry-internal/tracing@ extraneous
                      ├── @sentry/core@5.30.0 extraneous
                      ├── @sentry/hub@5.30.0 extraneous
                      ├── @sentry/minimal@5.30.0 extraneous
                      ├── @sentry/node@5.30.0 extraneous
                      ├── @sentry/tracing@ extraneous
                      ├── @sentry/types@5.30.0 extraneous
                      ├── @sentry/utils@5.30.0 extraneous
                      ├── @tootallnate/once@2.0.0 extraneous
                      ├── @types/caseless@0.12.5 extraneous
                      ├── @types/geojson@7946.0.14 extraneous
                      ├── @types/leaflet@1.9.12 extraneous
                      ├── @types/node-cron@2.0.8 extraneous
                      ├── @types/request@2.48.12 extraneous
                      ├── @types/tough-cookie@4.0.5 extraneous
                      ├── @types/triple-beam@1.3.5 extraneous
                      ├── @types/tz-offset@0.0.3 extraneous
                      ├── abab@2.0.6 extraneous
                      ├── agentkeepalive@4.5.0 extraneous
                      ├── ajv@ extraneous
                      ├── anymatch@3.1.3 extraneous
                      ├── archiver-utils@5.0.2 extraneous
                      ├── archiver@7.0.1 extraneous
                      ├── argparse@1.0.10 extraneous
                      ├── array-buffer-byte-length@1.0.1 extraneous
                      ├── arraybuffer.prototype.slice@1.0.3 extraneous
                      ├── arrify@2.0.1 extraneous
                      ├── available-typed-arrays@1.0.7 extraneous
                      ├── b4a@1.6.6 extraneous
                      ├── bare-events@2.4.2 extraneous
                      ├── base-64@1.0.0 extraneous
                      ├── binary-extensions@2.3.0 extraneous
                      ├── bindings@1.5.0 extraneous
                      ├── bottleneck@2.19.5 extraneous
                      ├── brace-expansion@2.0.1 extraneous
                      ├── buffer-crc32@1.0.0 extraneous
                      ├── buffer-equal-constant-time@1.0.1 extraneous
                      ├── buffer-shims@1.0.0 extraneous
                      ├── buildcheck@0.0.6 extraneous
                      ├── busboy@1.6.0 extraneous
                      ├── byte-length@1.0.2 extraneous
                      ├── cacache@16.1.3 extraneous
                      ├── charenc@0.0.2 extraneous
                      ├── chokidar@3.6.0 extraneous
                      ├── ci-info@3.9.0 extraneous
                      ├── cloneextend@0.0.3 extraneous
                      ├── cluster-key-slot@1.1.2 extraneous
                      ├── coffeescript@1.12.7 extraneous
                      ├── color-string@1.9.1 extraneous
                      ├── color@3.2.1 extraneous
                      ├── colors@1.4.0
                      ├── colorspace@1.1.4 extraneous
                      ├── commist@3.2.0 extraneous
                      ├── compress-commons@6.0.2 extraneous
                      ├── compress-json@2.1.2 extraneous
                      ├── compressible@2.0.18 extraneous
                      ├── compression@1.7.4 extraneous
                      ├── core-js@ extraneous
                      ├── crc-32@1.2.2 extraneous
                      ├── crc@4.1.1 extraneous
                      ├── crc32-stream@6.0.0 extraneous
                      ├── cross-fetch@4.0.0 extraneous
                      ├── crypt@0.0.2 extraneous
                      ├── cssstyle@3.0.0 extraneous
                      ├── cycle@1.0.3 extraneous
                      ├── data-urls@4.0.0 extraneous
                      ├── data-view-buffer@1.0.1 extraneous
                      ├── data-view-byte-length@1.0.1 extraneous
                      ├── data-view-byte-offset@1.0.0 extraneous
                      ├── date-and-time@ extraneous
                      ├── dayjs@ extraneous
                      ├── decache@4.6.2 extraneous
                      ├── decimal.js@10.4.3 extraneous
                      ├── deep-clone@3.0.3 extraneous
                      ├── define-lazy-prop@2.0.0 extraneous
                      ├── denque@1.5.1 extraneous
                      ├── digest-header@1.1.0 extraneous
                      ├── diskusage@1.2.0 extraneous
                      ├── domexception@4.0.0 extraneous
                      ├── draftlog@1.0.13 extraneous
                      ├── dropbox-v2-api@ extraneous
                      ├── duplexer@0.1.2 extraneous
                      ├── eastasianwidth@0.2.0 extraneous
                      ├── ecdsa-sig-formatter@1.0.11 extraneous
                      ├── echarts@ extraneous
                      ├── emoji-regex@9.2.2 extraneous
                      ├── enabled@2.0.0 extraneous
                      ├── entities@4.5.0 extraneous
                      ├── err-code@2.0.3 extraneous
                      ├── es-abstract@ extraneous
                      ├── es-aggregate-error@1.0.13 extraneous
                      ├── es-object-atoms@1.0.0 extraneous
                      ├── es-set-tostringtag@2.0.3 extraneous
                      ├── es-to-primitive@1.2.1 extraneous
                      ├── es6-promise@4.2.8 extraneous
                      ├── es6-promisify@5.0.0 extraneous
                      ├── esbuild@0.11.23 extraneous
                      ├── event-stream@4.0.1 extraneous
                      ├── expand-template@2.0.3 extraneous
                      ├── express-fileupload@1.5.1 extraneous
                      ├── fast-deep-equal@3.1.3 extraneous
                      ├── fast-fifo@1.3.2 extraneous
                      ├── fast-json-stable-stringify@2.1.0 extraneous
                      ├── fast-text-encoding@1.0.6 extraneous
                      ├── fast-unique-numbers@8.0.13 extraneous
                      ├── fast-uri@3.0.1 extraneous
                      ├── fast-xml-parser@4.4.1 extraneous
                      ├── fecha@4.2.3 extraneous
                      ├── file-stream-rotator@0.6.1 extraneous
                      ├── file-type@10.11.0 extraneous
                      ├── file-uri-to-path@1.0.0 extraneous
                      ├── fn.name@1.1.0 extraneous
                      ├── for-each@0.3.3 extraneous
                      ├── foreground-child@3.3.0 extraneous
                      ├── from@0.1.7 extraneous
                      ├── fs-constants@1.0.0 extraneous
                      ├── fs-extra@7.0.1
                      ├── fsevents@ extraneous
                      ├── ftp@0.3.10 extraneous
                      ├── function.prototype.name@1.1.6 extraneous
                      ├── functions-have-names@1.2.3 extraneous
                      ├── futoin-hkdf@1.4.3 extraneous
                      ├── gaxios@5.1.3 extraneous
                      ├── gcp-metadata@5.3.0 extraneous
                      ├── get-ssl-certificate@2.3.3 extraneous
                      ├── get-symbol-description@1.0.2 extraneous
                      ├── github-from-package@0.0.0 extraneous
                      ├── glob@10.4.5 extraneous
                      ├── globalthis@1.0.4 extraneous
                      ├── glossy@0.1.7 extraneous
                      ├── google-auth-library@8.9.0 extraneous
                      ├── google-p12-pem@4.0.1 extraneous
                      ├── googleapis-common@6.0.4 extraneous
                      ├── googleapis@ extraneous
                      ├── gtoken@6.1.2 extraneous
                      ├── has-bigints@1.0.2 extraneous
                      ├── has-tostringtag@1.0.2 extraneous
                      ├── he@1.2.0 extraneous
                      ├── help-me@5.0.0 extraneous
                      ├── homebridge-plugin-wrapper@ extraneous
                      ├── hot-patcher@1.0.0 extraneous
                      ├── html-encoding-sniffer@3.0.0 extraneous
                      ├── http-proxy-agent@5.0.0 extraneous
                      ├── https@1.0.0 extraneous
                      ├── humanize-ms@1.2.1 extraneous
                      ├── ical.js@1.5.0 extraneous
                      ├── image-type@4.1.0 extraneous
                      ├── infer-owner@1.0.4 extraneous
                      ├── internal-slot@1.0.7 extraneous
                      ├── iobroker-adapter-helpers@0.0.8 extraneous
                      ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                      ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                      ├── iobroker.bmw@2.5.7
                      ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                      ├── iobroker.cloud@4.4.1
                      ├── iobroker.coronavirus-statistics@0.8.7
                      ├── iobroker.daswetter@3.1.10
                      ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                      ├── iobroker.dwd@2.8.5
                      ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                      ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                      ├── iobroker.eusec@1.1.2
                      ├── iobroker.flot@ invalid: "1.12.0" from the root project
                      ├── iobroker.fritzbox@0.2.1
                      ├── iobroker.fullcalendar@1.2.0
                      ├── iobroker.fullybrowser@2.1.2
                      ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                      ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                      ├── iobroker.harmony@1.2.2
                      ├── iobroker.heatingcontrol@2.11.1
                      ├── iobroker.history@2.2.6
                      ├── iobroker.hm-rega@3.0.47
                      ├── iobroker.hm-rpc@1.15.19
                      ├── iobroker.hue@3.9.5
                      ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                      ├── iobroker.icons-icons8@0.0.1
                      ├── iobroker.icons-material-png@0.1.0
                      ├── iobroker.icons-mfd-png@1.1.0
                      ├── iobroker.icons-ultimate-png@1.0.1
                      ├── iobroker.info@ invalid: "1.9.26" from the root project
                      ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                      ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                      ├── iobroker.logparser@2.2.0
                      ├── iobroker.material@ invalid: "1.3.1" from the root project
                      ├── iobroker.meross@1.15.1
                      ├── iobroker.mihome-vacuum@3.11.0
                      ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                      ├── iobroker.milight@0.3.6
                      ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                      ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                      ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                      ├── iobroker.nina@ invalid: "0.0.25" from the root project
                      ├── iobroker.pollenflug@1.0.6
                      ├── iobroker.pushover@3.0.3
                      ├── iobroker.pushsafer@1.0.3
                      ├── iobroker.pvforecast@2.7.1
                      ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                      ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                      ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                      ├── iobroker.simple-api@2.7.2
                      ├── iobroker.smartmeter@3.3.4
                      ├── iobroker.socketio@6.5.2
                      ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                      ├── iobroker.sql@2.2.0
                      ├── iobroker.statistics@2.3.0
                      ├── iobroker.sunnyportal@0.1.5
                      ├── iobroker.synology@2.1.13
                      ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                      ├── iobroker.terminal@1.0.0
                      ├── iobroker.tr-064@4.2.18
                      ├── iobroker.trashschedule@2.2.0
                      ├── iobroker.unifi@0.6.6
                      ├── iobroker.upnp@1.0.21
                      ├── iobroker.valloxmv@1.2.0
                      ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                      ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                      ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                      ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                      ├── iobroker.vis-colorpicker@2.0.3
                      ├── iobroker.vis-fancyswitch@1.1.0
                      ├── iobroker.vis-google-fonts@1.0.4
                      ├── iobroker.vis-history@1.0.0
                      ├── iobroker.vis-hqwidgets@1.4.0
                      ├── iobroker.vis-inventwo@3.3.3
                      ├── iobroker.vis-jqui-mfd@1.0.12
                      ├── iobroker.vis-justgage@1.0.2
                      ├── iobroker.vis-map@1.0.4
                      ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                      ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                      ├── iobroker.vis-rgraph@0.0.2
                      ├── iobroker.vis-timeandweather@1.2.2
                      ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                      ├── iobroker.vis@ invalid: "1.4.16" from the root project
                      ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                      ├── iobroker.weatherunderground@3.4.2
                      ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                      ├── iobroker.web@ invalid: "6.1.0" from the root project
                      ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                      ├── iobroker.wiffi-wz@2.2.1
                      ├── iobroker.windows-control@0.1.5
                      ├── iobroker.worx@2.3.2
                      ├── iobroker.ws@2.5.3
                      ├── iobroker@2.0.3
                      ├── ioredis@4.28.5 extraneous
                      ├── ip-address@9.0.5 extraneous
                      ├── ip-regex@4.3.0 extraneous
                      ├── ipaddr.js@2.2.0 extraneous
                      ├── is-array-buffer@3.0.4 extraneous
                      ├── is-bigint@1.0.4 extraneous
                      ├── is-binary-path@2.1.0 extraneous
                      ├── is-boolean-object@1.1.2 extraneous
                      ├── is-buffer@1.1.6 extraneous
                      ├── is-callable@1.2.7 extraneous
                      ├── is-data-view@1.0.1 extraneous
                      ├── is-date-object@1.0.5 extraneous
                      ├── is-empty-object@1.1.1 extraneous
                      ├── is-lambda@1.0.1 extraneous
                      ├── is-negative-zero@2.0.3 extraneous
                      ├── is-number-object@1.0.7 extraneous
                      ├── is-potential-custom-element-name@1.0.1 extraneous
                      ├── is-regex@1.1.4 extraneous
                      ├── is-shared-array-buffer@1.0.3 extraneous
                      ├── is-string@1.0.7 extraneous
                      ├── is-symbol@1.0.4 extraneous
                      ├── is-typed-array@1.1.13 extraneous
                      ├── is-url@1.2.4 extraneous
                      ├── is-weakref@1.0.2 extraneous
                      ├── is@3.3.0 extraneous
                      ├── is2@2.0.9 extraneous
                      ├── jackspeak@3.4.3 extraneous
                      ├── js-md4@0.3.2 extraneous
                      ├── js-yaml@3.14.1 extraneous
                      ├── jsbi@4.3.0 extraneous
                      ├── jsbn@1.1.0 extraneous
                      ├── jsdom@ extraneous
                      ├── jshashes@1.0.8 extraneous
                      ├── json-schema-traverse@1.0.0 extraneous
                      ├── json5@2.2.3 extraneous
                      ├── jsonata@2.0.5 extraneous
                      ├── jsonc-parser@3.3.1 extraneous
                      ├── jsonwebtoken@9.0.2 extraneous
                      ├── jszip@3.10.1 extraneous
                      ├── jwa@2.0.0 extraneous
                      ├── jws@4.0.0 extraneous
                      ├── kuler@2.0.0 extraneous
                      ├── layerr@0.1.2 extraneous
                      ├── lazystream@1.0.1 extraneous
                      ├── lie@3.3.0 extraneous
                      ├── loadavg-windows@1.1.1 extraneous
                      ├── lodash.defaults@4.2.0 extraneous
                      ├── lodash.flatten@4.4.0 extraneous
                      ├── lodash.includes@4.3.0 extraneous
                      ├── lodash.isarguments@3.1.0 extraneous
                      ├── lodash.isboolean@3.0.3 extraneous
                      ├── lodash.isinteger@4.0.4 extraneous
                      ├── lodash.isnumber@3.0.3 extraneous
                      ├── lodash.isplainobject@4.0.6 extraneous
                      ├── lodash.isstring@4.0.1 extraneous
                      ├── lodash.once@4.1.1 extraneous
                      ├── logform@2.6.1 extraneous
                      ├── long@5.2.3 extraneous
                      ├── make-fetch-happen@10.2.1 extraneous
                      ├── map-stream@0.0.7 extraneous
                      ├── md5@2.3.0 extraneous
                      ├── mime-db@1.53.0 extraneous
                      ├── minimatch@9.0.5 extraneous
                      ├── minipass-collect@1.0.2 extraneous
                      ├── minipass-fetch@2.1.2 extraneous
                      ├── minipass-flush@1.0.5 extraneous
                      ├── minipass-pipeline@1.2.4 extraneous
                      ├── minipass-sized@1.0.3 extraneous
                      ├── minipass@7.1.2 extraneous
                      ├── mkdirp-classic@0.5.3 extraneous
                      ├── mock-require@3.0.3 extraneous
                      ├── moment-duration-format@2.3.2 extraneous
                      ├── mqtt-connection@4.1.0 extraneous
                      ├── mqtt-packet@9.0.0 extraneous
                      ├── mqtt@ extraneous
                      ├── nanoid@3.3.7 extraneous
                      ├── napi-build-utils@1.0.2 extraneous
                      ├── native-duplexpair@1.0.0 extraneous
                      ├── nconf@0.10.0 extraneous
                      ├── nested-property@4.0.0 extraneous
                      ├── netmask@2.0.2 extraneous
                      ├── node-abi@3.65.0 extraneous
                      ├── node-abort-controller@3.1.1 extraneous
                      ├── node-cron@2.0.3 extraneous
                      ├── node-forge@ extraneous
                      ├── node-gyp@9.3.0 extraneous
                      ├── node-ical@0.16.1 extraneous
                      ├── node-inspect@2.0.0 extraneous
                      ├── node-libcurl@3.0.0 extraneous
                      ├── node-mndp@0.0.3 extraneous
                      ├── node-persist@0.0.11 extraneous
                      ├── node-rsa@1.1.1 extraneous
                      ├── node-wol@0.1.1 extraneous
                      ├── node.extend@2.0.3 extraneous
                      ├── normalize-path@3.0.0 extraneous
                      ├── nwsapi@2.2.12 extraneous
                      ├── object-hash@3.0.0 extraneous
                      ├── one-time@1.0.0 extraneous
                      ├── onedrive-api@1.1.1 extraneous
                      ├── opencollective-postinstall@2.0.3 extraneous
                      ├── ospath@1.2.2 extraneous
                      ├── osx-temperature-sensor@ extraneous
                      ├── otplib@11.0.1 extraneous
                      ├── p-throttle@4.1.1 extraneous
                      ├── package-json-from-dist@1.0.0 extraneous
                      ├── pako@1.0.11 extraneous
                      ├── parse5@7.1.2 extraneous
                      ├── passport@0.7.0 extraneous
                      ├── path-parse@1.0.7 extraneous
                      ├── path-posix@1.0.0 extraneous
                      ├── path-scurry@1.11.1 extraneous
                      ├── pause-stream@0.0.11 extraneous
                      ├── pidusage@3.0.2 extraneous
                      ├── ping@0.4.4 extraneous
                      ├── pluralize@8.0.0 extraneous
                      ├── possible-typed-array-names@1.0.0 extraneous
                      ├── prebuild-install@7.1.2 extraneous
                      ├── promise-inflight@1.0.1 extraneous
                      ├── promise-object@0.1.7 extraneous
                      ├── promise-retry@2.0.1 extraneous
                      ├── promise-retryer@0.0.1 extraneous
                      ├── promisify-child-process@4.1.2 extraneous
                      ├── prompt@1.3.0 extraneous
                      ├── protobufjs@ extraneous
                      ├── proxy-from-env@1.1.0 extraneous
                      ├── q@1.1.2 extraneous
                      ├── quasar@ extraneous
                      ├── queue-tick@1.0.1 extraneous
                      ├── read@1.0.7 extraneous
                      ├── readdir-glob@1.1.3 extraneous
                      ├── readdirp@3.6.0 extraneous
                      ├── readline-sync@1.4.10 extraneous
                      ├── readline@1.3.0 extraneous
                      ├── redis-commands@1.7.0 extraneous
                      ├── redis-errors@1.2.0 extraneous
                      ├── redis-parser@3.0.0 extraneous
                      ├── regenerator-runtime@0.14.1 extraneous
                      ├── regex-escape@3.4.10 extraneous
                      ├── regexp.prototype.flags@1.5.2 extraneous
                      ├── remove-trailing-separator@1.1.0 extraneous
                      ├── require-from-string@2.0.2 extraneous
                      ├── respjs@4.2.0 extraneous
                      ├── retry-axios@2.6.0 extraneous
                      ├── retry@0.12.0 extraneous
                      ├── revalidator@0.1.8 extraneous
                      ├── rrule@2.8.1 extraneous
                      ├── rrweb-cssom@0.6.0 extraneous
                      ├── safe-array-concat@1.1.2 extraneous
                      ├── safe-regex-test@1.0.3 extraneous
                      ├── safe-stable-stringify@2.4.3 extraneous
                      ├── saxes@6.0.0 extraneous
                      ├── secure-keys@1.0.0 extraneous
                      ├── semver@5.7.2
                      ├── seq-logging@1.1.2 extraneous
                      ├── set-function-name@2.0.2 extraneous
                      ├── setimmediate@1.0.5 extraneous
                      ├── signal-exit@4.1.0 extraneous
                      ├── simple-swizzle@0.2.2 extraneous
                      ├── smart-buffer@4.2.0 extraneous
                      ├── socks-proxy-agent@7.0.0 extraneous
                      ├── socks@2.8.3 extraneous
                      ├── speedtest-net@1.6.2 extraneous
                      ├── sprintf-js@1.1.3 extraneous
                      ├── ssri@9.0.1 extraneous
                      ├── stack-trace@0.0.10 extraneous
                      ├── stampit-event-bus@0.1.1 extraneous
                      ├── stampit-state-machine@0.2.1 extraneous
                      ├── stampit@2.1.2 extraneous
                      ├── standard-as-callback@2.1.0 extraneous
                      ├── stoppable@1.1.0 extraneous
                      ├── stream-combiner@0.2.2 extraneous
                      ├── streamsearch@1.1.0 extraneous
                      ├── streamx@2.18.0 extraneous
                      ├── string-argv@0.3.2 extraneous
                      ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                      ├── string-width@5.1.2 extraneous
                      ├── string.prototype.trim@1.2.9 extraneous
                      ├── string.prototype.trimend@1.0.8 extraneous
                      ├── string.prototype.trimstart@1.0.8 extraneous
                      ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                      ├── strnum@1.0.5 extraneous
                      ├── suncalc@1.9.0 extraneous
                      ├── suncalc2@1.8.1 extraneous
                      ├── supermixer@1.0.5 extraneous
                      ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                      ├── sweet-collections@1.1.0 extraneous
                      ├── symbol-tree@3.2.4 extraneous
                      ├── systeminformation@5.23.4 extraneous
                      ├── tar-fs@2.1.1 extraneous
                      ├── tar-stream@3.1.7 extraneous
                      ├── tcp-port-used@1.0.2 extraneous
                      ├── text-decoder@1.1.1 extraneous
                      ├── text-hex@1.0.0 extraneous
                      ├── thirty-two@1.0.2 extraneous
                      ├── through2@2.0.5 extraneous
                      ├── tiny-typed-emitter@2.1.0 extraneous
                      ├── tinycolor2@1.6.0 extraneous
                      ├── tr46@4.1.1 extraneous
                      ├── triple-beam@1.4.1 extraneous
                      ├── tsdav@2.1.1 extraneous
                      ├── tslib@2.3.0 extraneous
                      ├── typed-array-buffer@1.0.2 extraneous
                      ├── typed-array-byte-length@1.0.1 extraneous
                      ├── typed-array-byte-offset@1.0.2 extraneous
                      ├── typed-array-length@1.0.6 extraneous
                      ├── typedarray.prototype.slice@1.0.3 extraneous
                      ├── typescript@ extraneous
                      ├── tz-offset@0.0.1 extraneous
                      ├── unbox-primitive@1.0.2 extraneous
                      ├── unique-filename@2.0.1 extraneous
                      ├── unique-slug@3.0.0 extraneous
                      ├── unix-dgram@2.0.6 extraneous
                      ├── uri-js@4.4.1 extraneous
                      ├── url-join@4.0.1 extraneous
                      ├── url-template@2.0.8 extraneous
                      ├── virtual-tsc@0.6.2 extraneous
                      ├── vue-i18n@8.28.2 extraneous
                      ├── vuelidate-messages@0.1.2 extraneous
                      ├── vuelidate@0.7.7 extraneous
                      ├── vuex-map-fields@1.4.1 extraneous
                      ├── w3c-xmlserializer@4.0.0 extraneous
                      ├── wake_on_lan@1.0.0 extraneous
                      ├── weak-daemon@1.0.3 extraneous
                      ├── webdav@4.11.3 extraneous
                      ├── webidl-conversions@7.0.0 extraneous
                      ├── websocket-stream@5.5.2 extraneous
                      ├── whatwg-encoding@2.0.0 extraneous
                      ├── whatwg-mimetype@3.0.0 extraneous
                      ├── whatwg-url@12.0.1 extraneous
                      ├── which-boxed-primitive@1.0.2 extraneous
                      ├── which-typed-array@1.1.15 extraneous
                      ├── window-size@0.1.4 extraneous
                      ├── winston-daily-rotate-file@5.0.0 extraneous
                      ├── winston-seq-updated@1.0.4 extraneous
                      ├── winston-syslog@2.7.1 extraneous
                      ├── winston-transport@4.7.1 extraneous
                      ├── winston@3.14.2 extraneous
                      ├── worker-timers-broker@6.1.8 extraneous
                      ├── worker-timers-worker@7.0.71 extraneous
                      ├── worker-timers@7.1.8 extraneous
                      ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                      ├── wrap-ansi@8.1.0 extraneous
                      ├── xml-js@1.6.11 extraneous
                      ├── xml-name-validator@4.0.0 extraneous
                      ├── xmlchars@2.2.0 extraneous
                      ├── xregexp@2.0.0 extraneous
                      ├── yargs@7.1.2
                      ├── zip-stream@6.0.1 extraneous
                      └── zrender@ extraneous
                      npm error code ELSPROBLEMS
                      npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                      npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                      npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                      npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                      npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                      npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                      npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                      npm error extraneous: @azure/core-http-compat@2.1.2 /opt/iobroker/node_modules/@azure/core-http-compat
                      npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                      npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                      npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                      npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                      npm error extraneous: @azure/core-util@1.9.2 /opt/iobroker/node_modules/@azure/core-util
                      npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                      npm error extraneous: @azure/keyvault-keys@4.8.0 /opt/iobroker/node_modules/@azure/keyvault-keys
                      npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                      npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                      npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                      npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
                      npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                      npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                      npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                      npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                      npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                      npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                      npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                      npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                      npm error extraneous: @iobroker/db-base@6.0.10 /opt/iobroker/node_modules/@iobroker/db-base
                      npm error extraneous: @iobroker/db-objects-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-file
                      npm error extraneous: @iobroker/db-objects-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                      npm error extraneous: @iobroker/db-objects-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-redis
                      npm error extraneous: @iobroker/db-states-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-file
                      npm error extraneous: @iobroker/db-states-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                      npm error extraneous: @iobroker/db-states-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-redis
                      npm error extraneous: @iobroker/js-controller-adapter@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                      npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                      npm error extraneous: @iobroker/js-controller-common-db@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                      npm error extraneous: @iobroker/js-controller-common@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common
                      npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                      npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                      npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                      npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                      npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                      npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                      npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                      npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                      npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                      npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                      npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                      npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                      npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                      npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                      npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                      npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                      npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                      npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                      npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                      npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                      npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                      npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                      npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                      npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                      npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                      npm error extraneous: @sentry/node@5.30.0 /opt/iobroker/node_modules/@sentry/node
                      npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                      npm error extraneous: @sentry/types@5.30.0 /opt/iobroker/node_modules/@sentry/types
                      npm error extraneous: @sentry/utils@5.30.0 /opt/iobroker/node_modules/@sentry/utils
                      npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                      npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                      npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                      npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                      npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                      npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                      npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                      npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                      npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                      npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                      npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                      npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                      npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                      npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                      npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                      npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                      npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                      npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                      npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                      npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                      npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                      npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                      npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                      npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                      npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                      npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                      npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                      npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                      npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                      npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                      npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                      npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                      npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                      npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                      npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                      npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                      npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                      npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                      npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                      npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                      npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                      npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                      npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                      npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                      npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                      npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                      npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                      npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                      npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                      npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                      npm error extraneous: crc@4.1.1 /opt/iobroker/node_modules/crc
                      npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                      npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                      npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                      npm error extraneous: cssstyle@3.0.0 /opt/iobroker/node_modules/cssstyle
                      npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                      npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                      npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                      npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                      npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                      npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                      npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                      npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                      npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                      npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                      npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                      npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                      npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                      npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                      npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                      npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                      npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                      npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                      npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                      npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                      npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                      npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                      npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                      npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                      npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                      npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                      npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                      npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                      npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                      npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                      npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                      npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                      npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                      npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                      npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                      npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                      npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                      npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                      npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                      npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                      npm error extraneous: fast-unique-numbers@8.0.13 /opt/iobroker/node_modules/fast-unique-numbers
                      npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                      npm error extraneous: fast-xml-parser@4.4.1 /opt/iobroker/node_modules/fast-xml-parser
                      npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                      npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                      npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                      npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                      npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                      npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                      npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                      npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                      npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                      npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                      npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                      npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                      npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                      npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                      npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                      npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                      npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                      npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                      npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                      npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                      npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                      npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                      npm error extraneous: google-auth-library@8.9.0 /opt/iobroker/node_modules/google-auth-library
                      npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                      npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                      npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                      npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                      npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                      npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                      npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                      npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                      npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                      npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                      npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                      npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                      npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                      npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                      npm error extraneous: ical.js@1.5.0 /opt/iobroker/node_modules/ical.js
                      npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                      npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                      npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                      npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                      npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                      npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                      npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                      npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                      npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                      npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                      npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                      npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                      npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                      npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                      npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                      npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                      npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                      npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                      npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                      npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                      npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                      npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                      npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                      npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                      npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                      npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                      npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                      npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                      npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                      npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                      npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                      npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                      npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                      npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                      npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                      npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                      npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                      npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                      npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                      npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                      npm error extraneous: ioredis@4.28.5 /opt/iobroker/node_modules/ioredis
                      npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                      npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                      npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                      npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                      npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                      npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                      npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                      npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                      npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                      npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                      npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                      npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                      npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                      npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                      npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                      npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                      npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                      npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                      npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                      npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                      npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                      npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                      npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                      npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                      npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                      npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                      npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                      npm error extraneous: js-yaml@3.14.1 /opt/iobroker/node_modules/js-yaml
                      npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                      npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                      npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                      npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                      npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                      npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                      npm error extraneous: jsonata@2.0.5 /opt/iobroker/node_modules/jsonata
                      npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                      npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                      npm error extraneous: jszip@3.10.1 /opt/iobroker/node_modules/jszip
                      npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                      npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                      npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                      npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                      npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                      npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                      npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                      npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                      npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                      npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                      npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                      npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                      npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                      npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                      npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                      npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                      npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                      npm error extraneous: logform@2.6.1 /opt/iobroker/node_modules/logform
                      npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                      npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                      npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                      npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                      npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                      npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                      npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                      npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                      npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                      npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                      npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                      npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                      npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                      npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                      npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                      npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                      npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                      npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                      npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                      npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                      npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                      npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                      npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                      npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                      npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                      npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                      npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                      npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                      npm error extraneous: node-gyp@9.3.0 /opt/iobroker/node_modules/node-gyp
                      npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                      npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                      npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                      npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                      npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                      npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                      npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                      npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                      npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                      npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                      npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                      npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                      npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                      npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                      npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                      npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                      npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                      npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                      npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                      npm error extraneous: pako@1.0.11 /opt/iobroker/node_modules/pako
                      npm error extraneous: parse5@7.1.2 /opt/iobroker/node_modules/parse5
                      npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                      npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                      npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                      npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                      npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                      npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                      npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                      npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                      npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                      npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                      npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                      npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                      npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                      npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                      npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                      npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                      npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                      npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                      npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                      npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                      npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                      npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                      npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                      npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                      npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                      npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                      npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                      npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                      npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                      npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                      npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                      npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                      npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                      npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                      npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                      npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                      npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                      npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                      npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                      npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                      npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                      npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                      npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                      npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                      npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                      npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                      npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                      npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                      npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                      npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                      npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                      npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                      npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                      npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                      npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                      npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                      npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                      npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                      npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                      npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                      npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                      npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                      npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                      npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                      npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                      npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                      npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                      npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                      npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                      npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                      npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                      npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                      npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                      npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                      npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                      npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                      npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                      npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                      npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                      npm error extraneous: systeminformation@5.23.4 /opt/iobroker/node_modules/systeminformation
                      npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                      npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                      npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                      npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                      npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                      npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                      npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                      npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                      npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                      npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                      npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                      npm error extraneous: tsdav@2.1.1 /opt/iobroker/node_modules/tsdav
                      npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                      npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                      npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                      npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                      npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                      npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                      npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                      npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                      npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                      npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                      npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                      npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                      npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                      npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                      npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                      npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                      npm error extraneous: vue-i18n@8.28.2 /opt/iobroker/node_modules/vue-i18n
                      npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                      npm error extraneous: vuelidate@0.7.7 /opt/iobroker/node_modules/vuelidate
                      npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                      npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                      npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                      npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                      npm error extraneous: webdav@4.11.3 /opt/iobroker/node_modules/webdav
                      npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                      npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                      npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                      npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                      npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                      npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                      npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                      npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                      npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                      npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                      npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                      npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                      npm error extraneous: winston@3.14.2 /opt/iobroker/node_modules/winston
                      npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                      npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                      npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                      npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                      npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                      npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                      npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                      npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                      npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                      npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                      npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T20_35_20_689Z-debug-0.log
                      flo@ioBrokerdebian:/opt/iobroker$
                      @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                      npm ls node-waf
                      F 1 Antwort Letzte Antwort
                        npm ls node-waf
                        flommaster
                        @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                        npm ls node-waf
                        flo@ioBrokerdebian:/opt/iobroker$ npm ls node-waf
                        [sudo] Passwort für flo:
                        iobroker.inst@2.0.3 /opt/iobroker
                        └── (empty)
                        • F flommaster
                          npm ls node-waf
                          └── (empty)
                          @flommaster
                          npm i https://github.com/iobroker-community-adapters/ioBroker.ical
                          Könnte sein, das da recht viel Output bei rumkommt.
                            @flommaster
                            flommaster
                            @flommaster
                            flo@ioBrokerdebian:/opt/iobroker$ npm i https://github.com/iobroker-community-adapters/ioBroker.ical
                            npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                            npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                            npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                            npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                            npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                            npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                            npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                            npm warn deprecated har-validator@5.1.5: this library is no longer supported
                            npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                            npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                            npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                            npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                            npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                            npm warn deprecated
                            npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                            npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                            npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                            npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                            npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                            npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                            npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                            npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                            npm warn deprecated gauge@3.0.2: This package is no longer supported.
                            npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm warn deprecated gauge@4.0.4: This package is no longer supported.
                            npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                            npm error code 127
                            npm error path /opt/iobroker/node_modules/zlib
                            npm error command failed
                            npm error command sh -c node-waf clean || true; node-waf configure build
                            npm error sh: 1: node-waf: not found
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T21_40_39_197Z-debug-0.log
                            • F flommaster
                              @flommaster
                              npm warn deprecated
                              npm error code 127
                              @flommaster
                              Ist jetzt nur noch gerate von mir.
                              npm uninstall iobroker.mihome-vacuum
                              Ich glaube der war in dem anderen Fall der Verursacher. Bzw. eine der Dependencies.
                              • Thomas BraunT Online
                                npm ls zlib
                                  @flommaster
                                  flommaster
                                  Das hat leider nicht geklappt.
                                  Bevor die Deinstallation startet habe ich wieder ein Haufen an Hinweisen erhalten...
                                  flo@ioBrokerdebian:/opt/iobroker$ npm uninstall iobroker.mihome-vacuum
                                  npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                                  npm warn deprecated
                                  npm error code 1
                                  npm error path /opt/iobroker/node_modules/node-libcurl
                                  npm error command sh -c node-pre-gyp install --fallback-to-build
                                  npm error Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v115' (1)
                                  npm error node-pre-gyp info it worked if it ends with ok
                                  npm error node-pre-gyp info using node-pre-gyp@1.0.10
                                  npm error node-pre-gyp info using node@20.16.0 | linux | x64
                                  npm error node-pre-gyp info check checked for "/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" (not found)
                                  npm error node-pre-gyp http GET https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
                                  npm error node-pre-gyp ERR! install response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
                                  npm error node-pre-gyp WARN Pre-built binaries not installable for node-libcurl@3.0.0 and node@20.16.0 (node-v115 ABI, glibc) (falling back to source compile with node-gyp)
                                  npm error node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
                                  npm error gyp info it worked if it ends with ok
                                  npm error gyp info using node-gyp@10.1.0
                                  npm error gyp info using node@20.16.0 | linux | x64
                                  npm error gyp info ok
                                  npm error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                                  npm error gyp http GET https://nodejs.org/download/release/v20.16.0/node-v20.16.0-headers.tar.gz
                                  npm error gyp http 200 https://nodejs.org/download/release/v20.16.0/node-v20.16.0-headers.tar.gz
                                  npm error gyp http GET https://nodejs.org/download/release/v20.16.0/SHASUMS256.txt
                                  npm error gyp http 200 https://nodejs.org/download/release/v20.16.0/SHASUMS256.txt
                                  npm error gyp info spawn /usr/bin/python3
                                  npm error gyp info spawn args [
                                  npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
                                  npm error gyp info spawn args 'binding.gyp',
                                  npm error gyp info spawn args '-f',
                                  npm error gyp info spawn args 'make',
                                  npm error gyp info spawn args '-I',
                                  npm error gyp info spawn args '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',
                                  npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
                                  npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.16.0/include/node/common.gypi',
                                  npm error gyp info spawn args '-Dlibrary=shared_library',
                                  npm error gyp info spawn args '-Dvisibility=default',
                                  npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.16.0',
                                  npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
                                  npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.16.0/<(target_arch)/node.lib',
                                  npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',
                                  npm error gyp info spawn args '-Dnode_engine=v8',
                                  npm error gyp info spawn args '--depth=.',
                                  npm error gyp info spawn args '--no-parallel',
                                  npm error gyp info spawn args '--generator-output',
                                  npm error gyp info spawn args 'build',
                                  npm error gyp info spawn args '-Goutput_dir=.'
                                  npm error gyp info spawn args ]
                                  npm error Could not run curl-config, please make sure libcurl dev package is installed.
                                  npm error Output: /bin/sh: 1: curl-config: not found
                                  npm error
                                  npm error gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/scripts/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                                  npm error gyp ERR! configure error
                                  npm error gyp ERR! stack Error: `gyp` failed with exit code: 1
                                  npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:297:18)
                                  npm error gyp ERR! stack at ChildProcess.emit (node:events:519:28)
                                  npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)
                                  npm error gyp ERR! System Linux 6.1.0-23-amd64
                                  npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v115"
                                  npm error gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
                                  npm error gyp ERR! node -v v20.16.0
                                  npm error gyp ERR! node-gyp -v v10.1.0
                                  npm error gyp ERR! not ok
                                  npm error node-pre-gyp ERR! build error
                                  npm error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v115' (1)
                                  npm error node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-libcurl/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                                  npm error node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
                                  npm error node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1105:16)
                                  npm error node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:305:5)
                                  npm error node-pre-gyp ERR! System Linux 6.1.0-23-amd64
                                  npm error node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-libcurl/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                  npm error node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
                                  npm error node-pre-gyp ERR! node -v v20.16.0
                                  npm error node-pre-gyp ERR! node-pre-gyp -v v1.0.10
                                  npm error node-pre-gyp ERR! not ok
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-20T13_59_25_128Z-debug-0.log
                                    npm ls zlib
                                    flommaster
                                    npm ls zlib
                                    Hier ist noch das Ergebnis von npm ls zlib
                                    flo@ioBrokerdebian:/opt/iobroker$ npm ls zlib
                                    └─┬ iobroker.mihome-vacuum@3.11.0
                                      └── zlib@1.0.5
                                    • F flommaster
                                      npm ls zlib
                                        └── zlib@1.0.5
                                      @flommaster
                                      Du hast da nicht nur eine oder zwei Baustellen, das ist eine ausgewachsene Großbaustelle da bei dir...
                                      apt policy libcurl*
                                      apt policy libcurl*dev
                                      Es muss das entsprechende -dev-Paket zu der bei dir installierten Version von libcurl installiert werden.
                                      Zu mihome-vacuum versuch mal ein
                                      iob update
                                      iob upgrade iobroker.mihome-vacuum@4.2.0
                                      F 2 Antworten Letzte Antwort
                                        @flommaster
                                        apt policy libcurl*
                                        iob update
                                        flommaster
                                        apt policy libcurl*
                                        flo@ioBrokerdebian:/opt/iobroker$ apt policy libcurl*
                                        libcurl4-openssl-dev:
                                          Installiert:           (keine)
                                          Installationskandidat: 7.88.1-10+deb12u6
                                          Versionstabelle:
                                             7.88.1-10+deb12u6 500
                                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                             7.88.1-10+deb12u5 500
                                                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                                        libcurl3:
                                          Installationskandidat: (keine)
                                          Versionstabelle:
                                        libcurl4:
                                          Installiert:           7.88.1-10+deb12u6
                                          Versionstabelle:
                                         *** 7.88.1-10+deb12u6 500
                                        libcurl3-gnutls:
                                          Versionstabelle:
                                        libcurl-ocaml:
                                          Installationskandidat: 0.9.2-3
                                          Versionstabelle:
                                             0.9.2-3 500
                                        libcurl3-openssl-dev:
                                          Versionstabelle:
                                        libcurl3-gnutls-dev:
                                          Versionstabelle:
                                        libcurl4-gnutls-dev:
                                          Versionstabelle:
                                        libcurl-dev:
                                          Versionstabelle:
                                        libcurlpp0:
                                          Installationskandidat: 0.8.1-5.1
                                          Versionstabelle:
                                             0.8.1-5.1 500
                                        libcurl-ocaml-dev:
                                          Versionstabelle:
                                             0.9.2-3 500
                                        libcurl-ocaml-80io7:
                                          Versionstabelle:
                                        libcurlpp-dev:
                                          Versionstabelle:
                                             0.8.1-5.1 500
                                        libcurl-ssl-dev:
                                          Versionstabelle:
                                        libcurl3-nss-dev:
                                          Versionstabelle:
                                        libcurl3-dev:
                                          Versionstabelle:
                                        libcurl-ocaml-dev-80io7:
                                          Versionstabelle:
                                        libcurl4-dev:
                                          Versionstabelle:
                                        libcurl4-doc:
                                          Versionstabelle:
                                        libcurl3-nss:
                                          Versionstabelle:
                                        libcurl4-nss-dev:
                                          Versionstabelle:
                                          Versionstabelle:
                                          Versionstabelle:
                                          Versionstabelle:
                                          Versionstabelle:
                                        libcurl-dev:
                                          Versionstabelle:
                                        libcurl-ocaml-dev:
                                          Versionstabelle:
                                             0.9.2-3 500
                                        libcurlpp-dev:
                                          Versionstabelle:
                                             0.8.1-5.1 500
                                        libcurl-ssl-dev:
                                          Versionstabelle:
                                        libcurl3-nss-dev:
                                          Versionstabelle:
                                        libcurl3-dev:
                                          Versionstabelle:
                                        libcurl4-dev:
                                          Versionstabelle:
                                        libcurl4-nss-dev:
                                          Versionstabelle:
                                          @flommaster
                                          apt policy libcurl*
                                          iob update
                                          flommaster
                                          iob update iob upgrade iobroker.mihome-vacuum@4.2.0
                                          flo@ioBrokerdebian:/opt/iobroker$ iob update
                                          node:internal/modules/esm/resolve:215
                                            const resolvedOption = FSLegacyMainResolve(packageJsonUrlString, packageConfig.main, baseStringified);
                                          Error: Cannot find package '/opt/iobroker/node_modules/@iobroker/js-controller-cli/package.json' imported from /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                              at legacyMainResolve (node:internal/modules/esm/resolve:215:26)
                                              at packageResolve (node:internal/modules/esm/resolve:841:14)
                                              at moduleResolve (node:internal/modules/esm/resolve:927:18)
                                              at defaultResolve (node:internal/modules/esm/resolve:1169:11)
                                              at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
                                              at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
                                              at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
                                              at ModuleLoader.import (node:internal/modules/esm/loader:315:34)
                                              at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31)
                                              at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12) {
                                            code: 'ERR_MODULE_NOT_FOUND'
                                          Node.js v20.16.0
                                          Node.js v20.16.0
