  4. [GELÖST] Umzug vom Pin64 auf Proxmox schlägt fehl.
49 Beiträge 4 Kommentatoren 6.4k Aufrufe 3 Beobachtet
    @kurt_88
    iob diag
    kurt_88
    @thomas-braun Die lange Version
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: iobroker01
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.2.16-3-pve
        Architecture: x86-64
    model name      : Intel(R) Pentium(R) Silver J5005 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     19:28:57 up  3:56,  2 users,  load average: 0.03, 0.09, 0.13
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Wed 2024-08-07 19:28:57 UTC
               Universal time: Wed 2024-08-07 19:28:57 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    kurt
    HOME=/home/kurt
    GROUPS=kurt sudo users
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.3G        258M        3.6G        122K        425M        4.0G
    Swap:           1.1G          0B        1.1G
    Total:          5.4G        258M        4.7G
    Active iob-Instances:   2
             4096 M total memory
              247 M used memory
              220 M active memory
              391 M inactive memory
             3443 M free memory
                0 M buffer memory
              405 M swap cache
             1024 M total swap
                0 M used swap
             1024 M free swap
    top - 19:28:57 up  3:56,  2 users,  load average: 0.03, 0.09, 0.13
    Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,   3441.6 free,    248.8 used,    405.6 buff/cache
    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   3847.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    2 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       44G  4.6G   38G  11% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                                  SOURCE                           FSTYPE     OPTIONS
    /                                                       /dev/mapper/pve-vm--100--disk--0 ext4       rw,relatime,stripe=16
    |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=1588148k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
    | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
    | |-/dev/ttyUSB0                                        udev[/ttyACM0]                   devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
    | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
    | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
    | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
    | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
    | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
    | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
    | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
    | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
    | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
    | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
    | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    461M    /var/
    251M    /var/cache
    247M    /var/cache/apt
    171M    /var/cache/apt/archives
    146M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    3.9M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    299M    /opt/iobroker/iobroker-data/
    269M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/backitup.admin
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812141627-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    npm:                    N/A
    npx:                    N/A
    /usr/bin/corepack       0.28.2
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 20.16.0-1nodesource1
      Candidate: 20.16.0-1nodesource1
      Version table:
     *** 20.16.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.9
    admin:          6.3.5
    javascript:     6.1.4
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker01                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker01                               - disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker01                               - disabled
    + system.adapter.backitup.0               : backitup              : iobroker01                               -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker01                               - disabled
      system.adapter.devices.0                : devices               : iobroker01                               - disabled
      system.adapter.discovery.0              : discovery             : iobroker01                               - disabled
      system.adapter.history.0                : history               : iobroker01                               - disabled
      system.adapter.ical.0                   : ical                  : iobroker01                               - disabled
      system.adapter.jarvis.0                 : jarvis                : iobroker01                               - disabled
      system.adapter.javascript.0             : javascript            : iobroker01                               - disabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker01                               - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : iobroker01                               - disabled
      system.adapter.ping.0                   : ping                  : iobroker01                               - disabled
      system.adapter.sonoff.0                 : sonoff                : iobroker01                               - disabled, port: 1888, bind: 0.0.0.0
      system.adapter.telegram.0               : telegram              : iobroker01                               - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : iobroker01                               - disabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker01                               - disabled
      system.adapter.tuya.0                   : tuya                  : iobroker01                               - disabled
      system.adapter.web.0                    : web                   : iobroker01                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : iobroker01                               - disabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812141627-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 6.3.5  [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.23.2 [Updatable]
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.16   , installed 2.5.10 [Updatable]
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.4  [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
    Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.13.2 [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
    Adapter    "javascript"   : 8.7.6    , installed 6.1.4  [Updatable]
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "mqtt"         : 5.2.0    , installed 4.0.7  [Updatable]
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.1.0    , installed 2.5.1  [Updatable]
    Adapter    "telegram"     : 3.3.2    , installed 1.15.2 [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.17 [Updatable]
    Adapter    "trashschedule": 3.3.0    , installed 2.0.3  [Updatable]
    Adapter    "tuya"         : 3.15.0   , installed 3.12.1 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.10.3   , installed 1.8.10 [Updatable]
    Objects and States
    Objects:        8926
    States:         8169
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          499376     1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          499841     315/master
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       838771     33332/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       836556     33332/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          496489     1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          499378     1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          499842     315/master
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          496522     95/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          499377     1/init
    udp6       0      0 :::111                  :::*                                0          499379     1/init
    2024-08-07 19:09:19.252  - info: host.iobroker01 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2024-08-07 19:09:19.604  - info: host.iobroker01 21 instances found
    2024-08-07 19:09:19.619  - info: host.iobroker01 starting 2 instances
    2024-08-07 19:09:19.863  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.nodeCurrent"
    2024-08-07 19:09:19.883  - info: host.iobroker01 instance system.adapter.admin.0 in version "6.3.5" started with pid 33353
    2024-08-07 19:09:19.915  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.nodeNewest"
    2024-08-07 19:09:19.918  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.nodeNewestNext"
    2024-08-07 19:09:19.921  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.npmCurrent"
    2024-08-07 19:09:19.923  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.npmNewest"
    2024-08-07 19:09:19.925  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.npmNewestNext"
    2024-08-07 19:09:19.928  - info: host.iobroker01 Some obsolete host states deleted.
    2024-08-07 19:09:21.340  - info: admin.0 (33353) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.16.0, js-controller: 6.0.9
    2024-08-07 19:09:21.360  - info: admin.0 (33353) requesting all states
    2024-08-07 19:09:21.361  - info: admin.0 (33353) requesting all objects
    2024-08-07 19:09:21.674  - warn: admin.0 (33353) Cannot get current npm version: Cannot find npm version
    2024-08-07 19:09:22.251  - info: admin.0 (33353) received all objects
    2024-08-07 19:09:22.326  - error: admin.0 (33353) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
    2024-08-07 19:09:22.327  - info: admin.0 (33353) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-08-07 19:09:22.700  - error: admin.0 (33353) Cannot update news: TypeError: newNews.forEach is not a function
    2024-08-07 19:09:22.861  - info: admin.0 (33353) terminating http server on port 8081
    2024-08-07 19:09:22.904  - info: host.iobroker01 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2024-08-07 19:09:22.905  - info: host.iobroker01 Do not restart adapter system.adapter.admin.0 because desired by instance
    2024-08-07 19:09:23.838  - info: host.iobroker01 instance system.adapter.backitup.0 in version "2.5.10" started with pid 33371
    2024-08-07 19:09:25.051  - info: backitup.0 (33371) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.16.0, js-controller: 6.0.9
    2024-08-07 19:09:25.085  - info: backitup.0 (33371) [iobroker] backup was activated at 02:40 every 1 day(s)
    iob diag has finished.
    und die Zusammenfassung
                            v.2024-05-22
      Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Etc/UTC (UTC, +0000)
    User-ID:                1001
    Pending OS-Updates:     0
    Pending iob updates:    21
    Nodejs-Installation:
    npm:                    N/A
    npx:                    N/A
    Recommended versions are nodejs 16.20.2 and npm 8.19.4
    Wrong installation path detected. This needs to be fixed.
    Please execute
    iobroker nodejs-update
    to fix these errors.
    MEMORY:
    Mem:            4.3G        260M        3.6G        122K        425M        4.0G
    Swap:           1.1G          0B        1.1G
    Total:          5.4G        260M        4.7G
    ioBroker Core:          js-controller           6.0.9
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                8926
    States:                 8169
    Size of iob-Database:
    5.1M    /opt/iobroker/iobroker-data/states.jsonl
    • crunchipC Abwesend
      crunchipC Abwesend
      nen neuen LXC einrichten dauert 5 min, iobroker drauf und backup einspielen, oder man diskutiert und blödelt noch mehrere Stunden herum😜
      wie man einen LXC korrekt aufsetzt steht in der Doku
      • K kurt_88
        Skript v.2024-05-22
        *** BASE SYSTEM ***
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                         RTC time: n/a
                  RTC in local TZ: no
        kurt
        HOME=/home/kurt
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           1.1G          0B        1.1G
                 4096 M total memory
                  247 M used memory
                  220 M active memory
                 3443 M free memory
                    0 M buffer memory
                  405 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        *** FILESYSTEM ***
        /var:
        461M    /var/
        251M    /var/cache
        247M    /var/cache/apt
        146M    /var/lib
        USB-Devices by-id:
        HINT:
        npm:                    N/A
        npx:                    N/A
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        8926
        States:         8169
        Pending Updates: 0
                                v.2024-05-22
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        User-ID:                1001
        npm:                    N/A
        npx:                    N/A
        Please execute
        MEMORY:
        Swap:           1.1G          0B        1.1G
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                8926
        States:                 8169
        @kurt_88 sagte in Umzug vom Pin64 auf Proxmox schlägt fehl.:
        Zeitzone setzen.
        Boot Target: graphical.target
        sudo systemd set-default multi-user.target
        Setz den kurt in die Gruppe adm.
        nodejs:
        sudo apt update
        sudo apt install --reinstall nodejs
        Bring den ganzen ioBroker-Kram auf Stand.
          @crunchip sagte in Umzug vom Pin64 auf Proxmox schlägt fehl.:
          Ja, ist die beste Variante. Wer weiß was da sonst noch verrootet worden ist.
            kurt_88
            schrieb am zuletzt editiert von kurt_88
            @thomas-braun Es klappt jetzt.
            Ich habe einmal
            ausprobiert und es hat geklappt.
            Dann habe ich iobroker gestoppt und das momentane iobroker Verzeichnis umbenannt und iobroker noch mal installiert mit
            sudo curl -sL -v https://iobroker.net/install.sh | bash -
            Auf dem alten geupdateten iobroker Server nochmal ein Backup erstellt und auf den LXC Container übertragen und mit dem neuen iobroker das restore angestoßen.
            Es ist alles sauber durchgelaufen und die Admin Oberfläche ist auch erreichbar, anbei das kleine Diag.
                                    v.2024-05-22
              Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               64 bit
            User-ID:                0
            Pending iob updates:    0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            Recommended versions are nodejs 20.16.0 and npm 10.8.1
            MEMORY:
            Mem:            4.3G        918M        403M        122K        3.0G        3.4G
            Swap:           1.1G          0B        1.1G
            Total:          5.4G        918M        1.5G
            Active iob-Instances:   3
                                    admin                   7.0.22
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : iobroker01                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            Objects:                9030
            States:                 8093
            15M     /opt/iobroker/iobroker-data/objects.jsonl
            1.8M    /opt/iobroker/iobroker-data/states.jsonl
            Schönen Abend noch und ein großes Dankschön an Thomas und Crunchip
            Viele Grüße Kurt
            Thomas BraunT crunchipC 3 Antworten Letzte Antwort
            • K kurt_88
              Ich habe einmal
                                      v.2024-05-22
                Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               64 bit
              User-ID:                0
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              MEMORY:
              Swap:           1.1G          0B        1.1G
                                      admin                   7.0.22
              Objects type: jsonl
              States  type: jsonl
              Objects:                9030
              States:                 8093
              Viele Grüße Kurt
              Immer noch falsch. Das ist WICHTIG!
              sudo timedatectl set-timezone America/Los_Angeles
              oder wo auch immer du residierst.
              Boot Target auch nicht richtig gesetzt. Liest du eigentlich was man dir schreibt?
              UND DU HAMPELST DA SCHON WIEDER ALS ROOT UMHER!
              Echt, ich hab da KEINEN BOCK MEHR DRAUF!
              • K kurt_88
                Ich habe einmal
                                        v.2024-05-22
                  Virtualization: lxc
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               64 bit
                User-ID:                0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                MEMORY:
                Swap:           1.1G          0B        1.1G
                                        admin                   7.0.22
                Objects type: jsonl
                States  type: jsonl
                Objects:                9030
                States:                 8093
                Viele Grüße Kurt
                crunchipC Abwesend
                crunchipC Abwesend
                Es klappt jetzt.
                ne, nicht wirklich
                lies doch bitte mal die Doku, wie ein LXC aufgesetzt werden muss
                  kurt_88
                  @thomas-braun war ein bisschen viel heute, habe auch noch ander Sachen zu tun gehabt. Das mit root stimmt schon mal nicht ...
                  === Mark text until here for copying ===
                  kurt@iobroker01:/opt/iobroker$
                  Und das mit der Zeitzone habe ich noch auf den Schirm, morgen ist aber auch noch ein Tag ... :)
                  • K kurt_88
                    Ich habe einmal
                                            v.2024-05-22
                      Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               64 bit
                    User-ID:                0
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    MEMORY:
                    Swap:           1.1G          0B        1.1G
                                            admin                   7.0.22
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                9030
                    States:                 8093
                    Viele Grüße Kurt
                    User-ID: 0
                    Da bist du ROOT. Das sieht man.
                    Also hast du dich da schon mal nicht daran gehalten, das man sich gar nicht erst als root einloggt.
                    Ich muss mal wieder den root aussperren in dem Skript... Nervt mich.
                      User-ID: 0
                      kurt_88
                      @thomas-braun nob, ich habe sudo iob diag ausgeführt.
                      • K kurt_88
                        @kurt_88
                        Nächstes Ding...
                        ioBroker-Kommandos werden auch NIE, NIE, NIE als root / per sudo ausgeführt.
                        Also warst du doch root. Wenn auch nur für den Befehl.
                          @kurt_88
                          Nächstes Ding...
                          kurt_88
                          @thomas-braun Danke für den Tipp.
                          • K kurt_88
                            @kurt_88
                            Zum selberausprobieren:
                            whoami
                            sudo whoami
                            whoami
                            Gucken und staunen.
