  4. JavaScript
  5. [Vorlage] Generisches Fensteroffenskript + Vis
javascripttemplatemonitoring
768 Beiträge 81 Kommentatoren 308.8k Aufrufe 97 Beobachtet
  • U Offline
    U Offline
    UncleB
    schrieb am zuletzt editiert von UncleB
    #749
    Mahlzeit zusammen.
    Bin auch grad dabei das Script zu installieren, nur will es noch nicht laufen.
    Log:
    avascript.0
    2024-01-22 13:12:09.250	info	script.js.common.Zaehlen.Offene_Tueren_Fenster: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2024-01-22 13:12:09.242	info	script.js.common.Zaehlen.Offene_Tueren_Fenster: starting Fensterskript, Version 1.6.15
    javascript.0
    2024-01-22 13:12:09.222	info	Start javascript script.js.common.Zaehlen.Offene_Tueren_Fenster
    javascript.0
    2024-01-22 13:12:09.107	info	Stop script script.js.common.Zaehlen.Offene_Tueren_Fenster
    javascript.0
    2024-01-22 13:09:22.240	error	at processTimers (node:internal/timers:502:7)
    javascript.0
    2024-01-22 13:09:22.240	error	at listOnTimeout (node:internal/timers:559:17)
    javascript.0
    2024-01-22 13:09:22.240	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2777:34)
    javascript.0
    2024-01-22 13:09:22.239	error	at Object.<anonymous> (script.js.common.Zaehlen.Offene_Tueren_Fenster:1388:25)
    javascript.0
    2024-01-22 13:09:22.239	error	at CheckWindow (script.js.common.Zaehlen.Offene_Tueren_Fenster:1014:64)
    javascript.0
    2024-01-22 13:09:22.239	error	at Meldung (script.js.common.Zaehlen.Offene_Tueren_Fenster:387:25)
    javascript.0
    2024-01-22 13:09:22.238	error	Error in callback: ReferenceError: Say is not defined
    javascript.0
    2024-01-22 13:05:55.735	info	script.js.common.Zaehlen.Offene_Tueren_Fenster: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2024-01-22 13:05:55.729	info	script.js.common.Zaehlen.Offene_Tueren_Fenster: starting Fensterskript, Version 1.6.15
    javascript.0
    2024-01-22 13:05:55.710	info	Start javascript script.js.common.Zaehlen.Offene_Tueren_Fenster
    javascript.0
    2024-01-22 13:05:54.667	info	Stop script script.js.common.Zaehlen.Offene_Tueren_Fenster
    "Say" hab ich auf false gesetzt, weiß sowieso nicht genau was das ist 😛
    Zeile 1-71
    const Skriptversion = "1.6.15" //vom 22.11.2021 - https://github.com/Pittini/iobroker-Fensterauswertung - https://forum.iobroker.net/topic/31674/vorlage-generisches-fensteroffenskript-vis
    //Script um offene Fenster/Türen pro Raum und insgesamt zu zählen.
    //Möglichkeit eine Ansage nach x Minuten einmalig oder zyklisch bis Fensterschließung anzugeben
    //Dynamische erzeugung einer HTML Übersichtstabelle
    //WICHTIG!!!
    //Vorraussetzungen: Den Geräten müssen Räume zugewiesen sein, sowie die Funktion "Fenster" bzw "Tuer" für jeden entsprechenden Datenpunkt.
    //Grundeinstellungen
    const logging = false; //Erweiterte Logs ausgeben?
    const praefix = "javascript.0.FensterUeberwachung."; //Grundpfad für Script DPs - Muß innerhalb javascript.x sein.
    const PresenceDp = "" //Pfad zum Anwesenheitsdatenpunkt, leer lassen wenn nicht vorhanden
    const WhichWindowFunctionToUse = "Fenster"; // Legt fest nach welchem Begriff in Funktionen gesucht wird. Diese Funktion nur dem Datenpunkt zuweisen, NICHT dem ganzen Channel!
    const WhichDoorFunctionToUse = "Tuer"; // Legt fest nach welchem Begriff in Funktionen gesucht wird. Diese Funktion nur dem Datenpunkt zuweisen, NICHT dem ganzen Channel!
    const WindowIgnoreTime = 10000; // 10000 ms = 10 Sekunden - Zeit in ms für die kurzzeitiges öffnen/schliessen ignoriert wird
    const DoorIgnoreTime = 1000; // 1000 ms = 1 Sekunden - Zeit in ms für die kurzzeitiges öffnen/schliessen ignoriert wird
    const WhichEnumCategoryToUse = "functions"; // Legt fest in welcher Kategorie sich die Aufzählungen befinden! Nur ändern wer weis was er tut!
    //Nachrichteneinstellungen
    const TimeToWindowMsg = 900000 // 300000 ms = 5 Minuten - Zyklus- bzw. Ablaufzeit für Fenster-offenwarnung/en
    const TimeToDoorMsg = 300000 // 300000 ms = 5 Minuten - Zyklus- bzw. Ablaufzeit für Tür-offenwarnung/en
    const MaxMessages = 1; //Maximale Anzahl der Nachrichten pro Raum
    //Telegram
    const UseTelegram = false; // Sollen Nachrichten via Telegram gesendet werden?
    //Pushover
    const UsePushOver = false; // Sollen Nachrichten via PushOver gesendet werden?
    const PushOverInstance = "pushover.0"; //Pushoverinstanz welche genutzt werden soll angeben
    const PushOverDevice = "All"; //Welches Gerät soll die Nachricht bekommen
    const PushOverTitle = "Fensterüberwachung";
    const PushOverSound = "none"; //Welcher Sound soll abgespielt werden? "none" für kein Sound, "" für Standartsound, ansonsten Namen angeben z.B. "magic"
    //Alexa
    const UseAlexa = false; // Sollen Nachrichten via Alexa ausgegeben werden?
    const AlexaInstance = "alexa2.0";
    const AlexaId = ""; // Die Alexa Seriennummer.
    const AlexaVolume = "50"; // Lautstärke der Nachrichten. Wert von 1 bis 100
    //Other
    const UseMail = false; //Nachricht via Mail versenden?
    const UseSay = false; // Sollen Nachrichten via Say ausgegeben werden? Autorenfunktion, muß deaktiviert werden.
    const UseEventLog = true; // Sollen Nachrichten ins Eventlog geschreiben werden? Autorenfunktion, muß deaktiviert werden.
    const NoMsgAtPresence = false; //Sollen Nachrichten bei Anwesenheit unterdrückt werden?
    //Tabelleneinstellungen
    const DoorOpenImg = "/icons-mfd-svg/fts_door_open.svg"; //Icon für Tür offen
    const DoorCloseImg = "/icons-mfd-svg/fts_door.svg"; // Icon für Tür geschlossen
    const DoorTiltedImg = "/icons-mfd-svg/fts_door_tilt.svg" // Icon für Tür gekippt
    const WindowOpenImg = "/icons-mfd-svg/fts_window_1w_open.svg"; //Icon für Fenster offen
    const WindowCloseImg = "/icons-mfd-svg/fts_window_1w.svg"; // Icon für Fenster geschlossen
    const WindowTiltedImg = "/icons-mfd-svg/fts_window_1w_tilt.svg" //Icon für Fenster gekippt
    const WindowOpenTiltedImg = "/icons-mfd-svg/fts_window_2w_open_l_tilt_r.svg" //Icon für offen und gekippt in einem Raum gleichzeitig
    const VentImg = "/icons-mfd-svg/vent_ventilation.svg"; //Icon für Lüftungsinfo
    const ImgInvert = 1; // Bildfarben invertieren? Erlaubte Werte von 0 bis 1
    const OpenWindowColor = "#f44336"; // Farbe für Fenster offen
    const OpenDoorColor = "darkorange"; //Farbe für Tür offen
    const TiltedWindowColor = "#F56C62"; //Farbe für gekippte Fenster o. Tür/en
    const ClosedWindowColor = "#4caf50"; // Farbe für geschlossene Fenster o. Tür/en
    const VentWarnColor = "#ffc107"; // Farbe für Lüftungswarnung
    const ShowCaptionTbl = false; // Überschrift anzeigen?
    const ShowSummaryTbl = true; // Zusammenfassung anzeigen?
    const ShowDetailTbl = true; // Details anzeigen?
    const RoomSortMode = 1; //0= Raumliste unsortiert, 1= alpabetisch sortiert, 2= Benutzerdefinierte Sortierung
    //Logeinstellungen
    const MaxLogEntrys = 20; //Maximale Anzahl der zu speichernden Logeinträge
    const AutoAddTimestamp = true; //Soll den geloggten Nachrichten automatisch ein Zeitsempel zugeordnet werden?
    const LogTimeStampFormat = "TT.MM.JJJJ SS:mm:ss"; //Zeitformatierung für Log Zeitstempel
    const LogEntrySeparator = "<br>"; //Trennzeichen für Logeinträge
    Nachdem das Script ohne Fehlermeldung startet, und ich dann ein Fenster öffne:
    13:33:15.825	error	javascript.0 (11959) at Meldung (script.js.common.Zaehlen.Offene_Tueren_Fenster:395:17)
    13:33:15.825	error	javascript.0 (11959) at CheckWindow (script.js.common.Zaehlen.Offene_Tueren_Fenster:1014:64)
    13:33:15.826	error	javascript.0 (11959) at Object.<anonymous> (script.js.common.Zaehlen.Offene_Tueren_Fenster:1388:25)
    Zeile 395:
                    WriteEventLog(msg);
    Zeile 1014:
                        if (SendWindowOpenCloseMsg[TempRoomIndex]) Meldung(ReplaceChars(TempRoom) + " Fenster geöffnet!");
    Zeile 1388:
                            CheckWindow(x);
    JoJo58J 1 Antwort Letzte Antwort
    • U UncleB
      Mahlzeit zusammen.
      Log:
      avascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Zeile 1-71
      //WICHTIG!!!
      //Telegram
      //Pushover
      //Alexa
      //Other
      //Logeinstellungen
      Zeile 395:
                      WriteEventLog(msg);
      Zeile 1014:
      Zeile 1388:
                              CheckWindow(x);
      JoJo58J Online
      JoJo58J Online
      JoJo58
      #750
      @uncleb
      Du musst noch
      auf "false" setzen.
      Intel NUC i7 64GB 1TB SSD - Proxmox - Raspi 4 8GB 500 GB SSD - Raspi 4 4GB 500GB SSD - Qnap 16TB - CCU3 - Fritz 6591 Cable - Green Cell USV 1500VA
      Sonoff CC2652P - HUE Bridge - Broadlink RM4 pro u. RM3 mini - 5 x Echo - 1 x Samsung STab 8 - 54 x HM und HMIP - 32 x Zigbee - 2 x Shelly 3EM.
      Einfach ein tolles Hobby :-)
      U 1 Antwort Letzte Antwort
      • JoJo58J JoJo58
        @uncleb
        Du musst noch
        auf "false" setzen.
        U Offline
        U Offline
        UncleB
        #751
        @jojo58 ahh läuft.
        Vielen Dank :)
        • U UncleB
          @jojo58 ahh läuft.
          Vielen Dank :)
          dike1982
          schrieb am zuletzt editiert von dike1982
          #752
          Hallo Zusammen,
          nachdem das Skript jetzt einige Wochen lief habe ich wieder Fehler.
          Geändert habe ich nichts, lediglich die Aufzählungen waren leer, habe alle Fensterkontakte wieder hinzugefügt.
          Die Aufzählung ist auch nur bei STATE vorhanden:
          3.3.2024, 12:01:44.774	[info ]: javascript.0 (210052) Stop script script.js.common.Visu.Status_Fenster.Fenster
          3.3.2024, 12:01:44.906	[info ]: javascript.0 (210052) Start javascript script.js.common.Visu.Status_Fenster.Fenster
          3.3.2024, 12:01:44.936	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: starting Fensterskript, Version 1.6.15
          3.3.2024, 12:01:44.937	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 0 = DG Moritz hat Fenstersensor/en
          3.3.2024, 12:01:44.938	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 1 = OG Esszimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.943	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 2 = DG Bad hat Fenstersensor/en
          3.3.2024, 12:01:44.943	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 3 = OG Spielzimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.944	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 4 = DG Schlafzimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.944	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 5 = DG Laura hat Fenstersensor/en
          3.3.2024, 12:01:44.944	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 1 = OG Esszimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.945	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 6 = OG Speisekammer hat Fenstersensor/en
          3.3.2024, 12:01:44.945	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 7 = OG Wohnzimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.946	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 7 = OG Wohnzimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.946	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 1 = OG Esszimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.946	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 8 = OG Kueche hat Fenstersensor/en
          3.3.2024, 12:01:44.947	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 9 = OG Arbeitszimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.947	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 8 = OG Kueche hat Fenstersensor/en
          3.3.2024, 12:01:44.947	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 10 = OG Gästebad hat Fenstersensor/en
          3.3.2024, 12:01:44.948	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 11 = Treppenhaus hat Fenstersensor/en
          3.3.2024, 12:01:44.948	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 6 = OG Speisekammer hat Fenstersensor/en
          3.3.2024, 12:01:44.949	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 12 = OG Klo hat Fenstersensor/en
          3.3.2024, 12:01:44.949	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 4 = DG Schlafzimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.949	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 3 = OG Spielzimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.950	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 9 = OG Arbeitszimmer hat Fenstersensor/en
          3.3.2024, 12:01:44.950	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Raum- 13 = EG CrossFit hat Fenstersensor/en
          3.3.2024, 12:01:44.962	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          3.3.2024, 12:01:45.021	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: CreateStates fertig!
          3.3.2024, 12:01:45.023	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=0=DG Bad SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.023	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=1=DG Laura SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.024	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=2=DG Moritz SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.025	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=3=DG Schlafzimmer SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.025	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=4=EG CrossFit SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.026	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=5=OG Arbeitszimmer SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.027	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=6=OG Esszimmer SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.027	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=7=OG Gästebad SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.028	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=8=OG Klo SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.028	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=9=OG Kueche SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.029	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=10=OG Speisekammer SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.030	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=11=OG Spielzimmer SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.030	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=12=OG Wohnzimmer SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.031	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: x=13=Treppenhaus SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          3.3.2024, 12:01:45.035	[warn ]: javascript.0 (210052)     at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
          3.3.2024, 12:01:45.036	[warn ]: javascript.0 (210052)     at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
          3.3.2024, 12:01:45.036	[warn ]: javascript.0 (210052)     at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
          3.3.2024, 12:01:45.037	[warn ]: javascript.0 (210052)     at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
          3.3.2024, 12:01:45.039	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=0 Sensor[x]=hm-rpc.1.0000D8A991D66D.1.STATE
          3.3.2024, 12:01:45.040	[info ]: javascript.0 (210052) script.js.common.Visu.Status_Fenster.Fenster: hm-rpc.1.0000D8A991D66D.1.STATE hat Zustandstext undefined, Wert= null Wert wird durch Zustandstext ersetzt
          3.3.2024, 12:01:45.042	[error]: javascript.0 (210052)     at SimplyfyWindowStates (script.js.common.Visu.Status_Fenster.Fenster:1258:33)
          3.3.2024, 12:01:45.043	[error]: javascript.0 (210052)     at init (script.js.common.Visu.Status_Fenster.Fenster:334:24)
          3.3.2024, 12:01:45.043	[error]: javascript.0 (210052)     at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
          3.3.2024, 12:01:45.044	[error]: javascript.0 (210052)     at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
          3.3.2024, 12:01:45.044	[error]: javascript.0 (210052)     at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
          Kann mir jemand helfen?
          • D dike1982
            Hallo Zusammen,
            dike1982
            #753
            Hat keiner einen Lösungsvorschlag?
            • D dike1982
              dike1982
              #754
              eben nochmal probiert, hetzt geht es. Komisch.....
              • P Pittini
                Generisches Skript um offene Fenster pro Raum und insgesamt zu zählen sowie offen/zu States anzulegen.
                • Kann beliebige Tür/Fenster Kontakte verwenden.
                • Berücksichtigt mehrflügelige Fenster bzw. mehrere Fenster pro Raum und zählt diese.
                • Legt pro Raum zwei Datenpunkte an (Raumfensteroffenzähler und Raumfensterstatus), sowie vier Datenpunkte fürs gesamte.
                • Möglichkeit eine Meldung/Ansage via Telegram/Alexa nach x Minuten einmalig oder zyklisch bis Fensterschließung auszugeben.
                • Gibt dynamische HTML Tabelle mit Übersicht aller Räume aus.
                • Flexibel konfigurierbar, direkt integriert sind HM, HMIP und Xiaomi Tür-/Fensterkontakte bzw. Drehgriffe
                Genaueres in der readme beim Projekt auf Git.
                qqolliQ Offline
                qqolliQ Offline
                qqolli
                #755
                @pittini
                nutze das Skript schon recht lange erfolgreich. Gerade habe ich folgende Meldung im JS-Editor bekommen:
                javascript.0	17:08:31.901	warn	script.js.Olli.TFK_Zählen: clearInterval() => not found
                und
                javascript.0	17:08:32.129	warn	script.js.Olli.TFK_Zählen: More than 100 subscriptions registered. Check your script!
                woher ich jetzt echt nicht wüsste, woher die 100 Subscriptions auf einmal herkommen sollen.
                Vielleicht weiß ja jemand einen Rat :-)
                • crunchipC Offline
                  crunchipC Offline
                  #756
                  nach dem upgrade des javascript Adapter auf 8.7.6 nun
                  javascript.0	12:25:12.963	error	script.js.Benachrichtigung.FensterTür-Status: getObject has been called with id of type "function" but expects a string
                  javascript.0	12:25:12.965	error	script.js.Benachrichtigung.FensterTür-Status: TypeError: Cannot read properties of undefined (reading '0')
                  javascript.0	12:25:12.965	error	at script.js.Benachrichtigung.FensterTür-Status:154:77
                  javascript.0	12:25:12.965	error	at script.js.Benachrichtigung.FensterTür-Status:1468:3
                    schittl
                    #757
                    @crunchip Hast Du schon eine Lösung? Nach Update das gleiche Problem.
                    HW: Lenovo M920q (Proxmox, ioBroker, RaspMatic & Z2M), QNAP (Docker, Influx), Arduino Mega 2560 R3 (I2C DS18B20 + LED)
                    SW: CT IoBroker, VM RaspMatic(v3.79.6.20241122)
                    • S schittl
                      schittl
                      schrieb am zuletzt editiert von schittl
                      #758
                      @crunchip Ich habe es mal analysiert den Fehler. Problem ist das in den Funktionen (Tür/Fenster) zwei unsichtbare Funktionen enthalten sind.
                      4.8.2024, 17:35:21.675	[warn ]: javascript.0 (364) script.js.XSkripte.Verschlussauswertung: |alias.0.Hof.ACTUAL|
                      4.8.2024, 17:35:21.676	[warn ]: javascript.0 (364) script.js.XSkripte.Verschlussauswertung: |hm-rpc.0.xxxxxxxxxxx.1.STATE|
                      4.8.2024, 17:35:21.677	[warn ]: javascript.0 (364) script.js.XSkripte.Verschlussauswertung: |hm-rpc.0.xxxxxxxxxxx.1.STATE|
                      4.8.2024, 17:35:21.677	[warn ]: javascript.0 (364) script.js.XSkripte.Verschlussauswertung: |function() {
                          var l = this.length;
                          return l == 1 ? this[0]
                              : l == 0 && arguments.length > 0
                              ? undefined
                              : this;
                          return this.filter((e, pos) => this.indexOf(e) == pos);
                      4.8.2024, 17:35:21.678	[warn ]: javascript.0 (364) script.js.XSkripte.Verschlussauswertung: |hm-rpc.0.xxxxxxxxxxx.1.STATE|
                      4.8.2024, 17:35:21.678	[warn ]: javascript.0 (364) script.js.XSkripte.Verschlussauswertung: |zigbee2mqtt.0.xxxxxxxxxxx.opened|
                      **4.8.2024, 17:35:21.678	[warn ]: javascript.0 (364) script.js.XSkripte.Verschlussauswertung: |function() {
                              ? undefined
                              : this;
                      Ich habe es herausgefunden indem folgende Codezeilen ergänzt habe:
                          for (let x in Funktionen) {        // loop ueber alle Functions
                              let Funktion = Funktionen[x].name;
                              if (Funktionen[x].name == WhichWindowFunctionToUse || Funktionen[x].name == WhichDoorFunctionToUse) {
                                  let members = Funktionen[x].members;
                                  for (let y in members) { // Loop über alle Fenster/Tür Members
                                      let membern = members[y].toString();
                                      console.warn('|' + members[y] + '|');
                      Jetzt weiß ich nicht was sich mit der neuen Version geändert hat. Woher dieses stammen und wie man diese entfernt bzw. ausklammert :(
                      • crunchipC Offline
                        crunchipC Offline
                        #759
                        @schittl ne, javascript ist nicht meine Welt
                        • crunchipC Offline
                          crunchipC Offline
                          #760
                          @crunchip kann hier vllt jemand Hilfestellung geben zum Beitrag https://forum.iobroker.net/post/1186197
                          das Script dazu siehe https://github.com/Pittini/iobroker-Fensterauswertung/blob/master/Fensterauswertung.js
                          • P Pittini
                            qqolliQ Offline
                            qqolliQ Offline
                            qqolli
                            schrieb am zuletzt editiert von qqolli
                            #761
                            @pittini
                            Hi, ich nutze dein Skript schon ziemlich lange und erfolgreich. Jetzt bekomme ich folgende Warnung:
                            javascript.0	15:05:58.657	info	Stopping script script.js.Olli.TFK_Zählen
                            javascript.0	15:05:58.761	info	Start JavaScript script.js.Olli.TFK_Zählen (JavaScript/js)
                            javascript.0	15:05:58.763	info	script.js.Olli.TFK_Zählen: starting Fensterskript, Version 1.6.15
                            javascript.0	15:05:58.768	info	script.js.Olli.TFK_Zählen: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            javascript.0	15:05:58.820	warn	script.js.Olli.TFK_Zählen: More than 100 subscriptions registered. Check your script!
                            100 Subscriptions? Ich habe bei weitem nicht soviele Fenster und Türen :-) Woran könnte das liegen?
                            Nachtrag: Jetzt noch diese Fehlermeldungen:
                            avascript.0
                            2024-11-24 15:20:58.823	error	at processTimers (node:internal/timers:519:7)
                            javascript.0
                            2024-11-24 15:20:58.823	error	at listOnTimeout (node:internal/timers:581:17)
                            javascript.0
                            2024-11-24 15:20:58.823	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3185:34)
                            javascript.0
                            2024-11-24 15:20:58.823	error	at Object.<anonymous> (script.js.Olli.TFK_Zählen:1071:81)
                            javascript.0
                            2024-11-24 15:20:58.823	error	at Meldung (script.js.Olli.TFK_Zählen:388:25)
                            javascript.0
                            2024-11-24 15:20:58.822	error	Error in callback: ReferenceError: Say is not defined
                            javascript.0
                            2024-11-24 15:20:58.819	error	at processTimers (node:internal/timers:519:7)
                            javascript.0
                            2024-11-24 15:20:58.819	error	at listOnTimeout (node:internal/timers:581:17)
                            javascript.0
                            2024-11-24 15:20:58.819	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3185:34)
                            javascript.0
                            2024-11-24 15:20:58.819	error	at Object.<anonymous> (script.js.Olli.TFK_Zählen:1071:81)
                            javascript.0
                            2024-11-24 15:20:58.819	error	at Meldung (script.js.Olli.TFK_Zählen:388:25)
                            javascript.0
                            2024-11-24 15:20:58.819	error	Error in callback: ReferenceError: Say is not defined
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            2024-11-24 15:20:58.819	error	at Object.<anonymous> (script.js.Olli.TFK_Zählen:1033:83)
                            javascript.0
                            javascript.0
                            2024-11-24 15:20:58.818	error	Error in callback: ReferenceError: Say is not defined
                            javascript.0
                            2024-11-24 15:15:58.823	error	at processTimers (node:internal/timers:519:7)
                            javascript.0
                            2024-11-24 15:15:58.823	error	at listOnTimeout (node:internal/timers:581:17)
                            javascript.0
                            2024-11-24 15:15:58.823	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3185:34)
                            javascript.0
                            2024-11-24 15:15:58.823	error	at Object.<anonymous> (script.js.Olli.TFK_Zählen:1071:81)
                            javascript.0
                            2024-11-24 15:15:58.823	error	at Meldung (script.js.Olli.TFK_Zählen:388:25)
                            javascript.0
                            2024-11-24 15:15:58.822	error	Error in callback: ReferenceError: Say is not defined
                            javascript.0
                            2024-11-24 15:15:58.821	error	at processTimers (node:internal/timers:519:7)
                            javascript.0
                            2024-11-24 15:15:58.820	error	at listOnTimeout (node:internal/timers:581:17)
                            javascript.0
                            2024-11-24 15:15:58.820	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3185:34)
                            javascript.0
                            2024-11-24 15:15:58.820	error	at Object.<anonymous> (script.js.Olli.TFK_Zählen:1071:81)
                            javascript.0
                            2024-11-24 15:15:58.820	error	at Meldung (script.js.Olli.TFK_Zählen:388:25)
                            javascript.0
                            2024-11-24 15:15:58.820	error	Error in callback: ReferenceError: Say is not defined
                            javascript.0
                            2024-11-24 15:10:58.823	error	at processTimers (node:internal/timers:519:7)
                            javascript.0
                            2024-11-24 15:10:58.823	error	at listOnTimeout (node:internal/timers:581:17)
                            javascript.0
                            2024-11-24 15:10:58.823	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3185:34)
                            javascript.0
                            2024-11-24 15:10:58.823	error	at Object.<anonymous> (script.js.Olli.TFK_Zählen:1071:81)
                            javascript.0
                            2024-11-24 15:10:58.822	error	at Meldung (script.js.Olli.TFK_Zählen:388:25)
                            javascript.0
                            2024-11-24 15:10:58.822	error	Error in callback: ReferenceError: Say is not defined
                            javascript.0
                            2024-11-24 15:10:58.822	error	at processTimers (node:internal/timers:519:7)
                            javascript.0
                            2024-11-24 15:10:58.822	error	at listOnTimeout (node:internal/timers:581:17)
                            javascript.0
                            2024-11-24 15:10:58.822	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3185:34)
                            javascript.0
                            2024-11-24 15:10:58.822	error	at Object.<anonymous> (script.js.Olli.TFK_Zählen:1071:81)
                            javascript.0
                            javascript.0
                            2024-11-24 15:10:58.821	error	Error in callback: ReferenceError: Say is not defined
                            J QuarkmaxQ 2 Antworten Letzte Antwort
                            • qqolliQ qqolli
                              @pittini
                              avascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              JoergH
                              #762
                              @qqolli Hast Du mal gecheckt, ob Deine Eigenschaften "Fenster", "Tür" etc. noch korrekt gesetzt sind?
                              qqolliQ 1 Antwort Letzte Antwort
                              • qqolliQ qqolli
                                @pittini
                                avascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                QuarkmaxQ Offline
                                QuarkmaxQ Offline
                                Quarkmax
                                #763
                                @qqolli
                                • J JoergH
                                  qqolliQ Offline
                                  qqolliQ Offline
                                  qqolli
                                  #764
                                  @joergh
                                  Ja, habe ich gerade geprüft, da hatte ich auch nichts geändert. Abgesehen davon, werden im Skript selbst jede Menge "Fehler" angezeigt, wie z. B.:
                                  Warum weiß ich leider auch nicht.
                                  • QuarkmaxQ Quarkmax
                                    @qqolli
                                    qqolliQ Offline
                                    qqolliQ Offline
                                    qqolli
                                    #765
                                    @quarkmax
                                    Ja, war tatsächlich gesetzt, obwohl ich es nicht benutze. Hat aber leider auch nichts geändert.
                                    • qqolliQ qqolli
                                      @quarkmax
                                      JoergH
                                      #766
                                      @qqolli Wenn Du nichts geändert hast und es die ganze Zeit lief, dann liegt es wohl nicht am Skript.
                                      • J JoergH
                                        qqolliQ Offline
                                        qqolliQ Offline
                                        qqolli
                                        #767
                                        @joergh Sehr konstruktiv, Danke :-)
                                        Hättest du evtl. eine Idee, was es sonst sein könnte, oder in welcher Richtung ich mal schauen kann?
                                          crunchipC Offline
                                          crunchipC Offline
                                          #768
                                          @crunchip sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                                          ich hole das Thema nochmals vor
                                          gibt es jemanden der ebenfalls damit Probleme hat?
                                          Edit
                                          die Fehlermeldung ist ursprünglich wie im Link, jedoch hab ich mittlerweile alle Datenpunkte, welche vom script angelegt wurden gelöscht, alle Türen - und Fensterkontakte nochmals geprüft.
                                          identische Fehlermeldung die durchs löschen der Datenpunkte nun erscheinen,
                                          • dabei ist es egal ob alle Kontakte Raum und Funktion zugeordnet sind,
                                          • oder auch nur ein einziger,
                                          • oder auch gar keine Kontakte angelegt sind
                                          javascript.0	16:34:42.972	info
                                          Stopping script script.js.Benachrichtigung.FensterTür-Status
                                          javascript.0	16:34:43.075	info
                                          Start JavaScript script.js.Benachrichtigung.FensterTür-Status (Javascript/js)
                                          javascript.0	16:34:43.081	info
                                          javascript.0	16:34:43.083	warn
                                              at init (script.js.Benachrichtigung.FensterTür-Status:326:26)
                                              at main (script.js.Benachrichtigung.FensterTür-Status:350:5)
                                          javascript.0	16:34:43.084	warn
                                              at InitialSort (script.js.Benachrichtigung.FensterTür-Status:315:5)
                                              at Object.<anonymous> (script.js.Benachrichtigung.FensterTür-Status:279:13)
                                              at init (script.js.Benachrichtigung.FensterTür-Status:327:35)
                                              at init (script.js.Benachrichtigung.FensterTür-Status:328:37)
                                              at init (script.js.Benachrichtigung.FensterTür-Status:329:32)
                                              at init (script.js.Benachrichtigung.FensterTür-Status:330:30)
                                          javascript.0	16:34:43.085	warn
                                              at init (script.js.Benachrichtigung.FensterTür-Status:342:27)
                                          javascript.0	16:34:43.085	error
                                              at CreateRoomsWithOpenDoorsList (script.js.Benachrichtigung.FensterTür-Status:867:45)
                                          javascript.0	16:34:43.086	error
                                              at main (script.js.Benachrichtigung.FensterTür-Status:352:5)
                                          Ausgabe im Log
                                          javascript.0
                                          2025-04-23 16:34:43.086	error	at createState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2987:34)
                                          javascript.0
                                          2025-04-23 16:34:43.086	error	at Object.<anonymous> (script.js.Benachrichtigung.FensterTür-Status:279:13)
                                          javascript.0
                                          2025-04-23 16:34:43.086	error	at InitialSort (script.js.Benachrichtigung.FensterTür-Status:315:5)
                                          javascript.0
                                          2025-04-23 16:34:43.086	error	at main (script.js.Benachrichtigung.FensterTür-Status:352:5)
                                          javascript.0
                                          2025-04-23 16:34:43.085	error	at CreateRoomsWithOpenDoorsList (script.js.Benachrichtigung.FensterTür-Status:867:45)
                                          javascript.0
                                          2025-04-23 16:34:43.085	error	Error in callback: TypeError: Cannot set properties of undefined (setting '1')
                                          javascript.0
                                          2025-04-23 16:34:43.085	warn	at createState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2987:34)
                                          javascript.0
                                          2025-04-23 16:34:43.085	warn	at Object.<anonymous> (script.js.Benachrichtigung.FensterTür-Status:279:13)
                                          javascript.0
                                          2025-04-23 16:34:43.085	warn	at InitialSort (script.js.Benachrichtigung.FensterTür-Status:315:5)
                                          javascript.0
                                          2025-04-23 16:34:43.085	warn	at main (script.js.Benachrichtigung.FensterTür-Status:350:5)
                                          javascript.0
                                          2025-04-23 16:34:43.085	warn	at init (script.js.Benachrichtigung.FensterTür-Status:342:27)
                                          javascript.0
                                          2025-04-23 16:34:43.085	warn	getState "javascript.0.Benachrichtigung.FensterTuerUeberwachung..VentWarnTime" not found (3)
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	at init (script.js.Benachrichtigung.FensterTür-Status:330:30)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	getState "javascript.0.Benachrichtigung.FensterTuerUeberwachung..SendDoorWarnMsg" not found (3)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	at createState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2987:34)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	at Object.<anonymous> (script.js.Benachrichtigung.FensterTür-Status:279:13)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	at InitialSort (script.js.Benachrichtigung.FensterTür-Status:315:5)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	at main (script.js.Benachrichtigung.FensterTür-Status:350:5)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	at init (script.js.Benachrichtigung.FensterTür-Status:329:32)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	getState "javascript.0.Benachrichtigung.FensterTuerUeberwachung..SendWindowWarnMsg" not found (3)
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	at init (script.js.Benachrichtigung.FensterTür-Status:328:37)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	getState "javascript.0.Benachrichtigung.FensterTuerUeberwachung..SendWindowOpenCloseMsg" not found (3)
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	at init (script.js.Benachrichtigung.FensterTür-Status:327:35)
                                          javascript.0
                                          2025-04-23 16:34:43.084	warn	getState "javascript.0.Benachrichtigung.FensterTuerUeberwachung..SendDoorOpenCloseMsg" not found (3)
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          2025-04-23 16:34:43.083	warn	at main (script.js.Benachrichtigung.FensterTür-Status:350:5)
                                          javascript.0
                                          2025-04-23 16:34:43.083	warn	at init (script.js.Benachrichtigung.FensterTür-Status:326:26)
                                          javascript.0
                                          2025-04-23 16:34:43.083	warn	getState "javascript.0.Benachrichtigung.FensterTuerUeberwachung..SendVentMsg" not found (3)
                                          javascript.0
                                          2025-04-23 16:34:43.081	info	script.js.Benachrichtigung.FensterTür-Status: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          javascript.0
                                          2025-04-23 16:34:43.081	info	script.js.Benachrichtigung.FensterTür-Status: starting Fensterskript, Version 1.6.15
                                          javascript.0
                                          2025-04-23 16:34:43.075	info	Start JavaScript script.js.Benachrichtigung.FensterTür-Status (Javascript/js)
                                          javascript.0
                                          2025-04-23 16:34:42.972	info	Stopping script script.js.Benachrichtigung.FensterTür-Status
