  3. Einsteigerfragen
  4. komm nicht weiter..."dpkg was interrupted"
    5.4k
49 Beiträge 4 Kommentatoren 6.5k Aufrufe 3 Beobachtet
  • ralleR ralle
    vielen Dank das du dich dem annimmst
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    39 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ apt policy libgdk-pixbuf*
    libgdk-pixbuf2.0-bin:
      Installed: 2.42.2+dfsg-1+deb11u1
      Candidate: 2.42.2+dfsg-1+deb11u2
      Version table:
         2.42.2+dfsg-1+deb11u2 500
     *** 2.42.2+dfsg-1+deb11u1 100
    libgdk-pixbuf-xlib-2.0-0:
      Installed: 2.40.2-2
      Candidate: 2.40.2-2
      Version table:
     *** 2.40.2-2 500
    libgdk-pixbuf2.0-dev:
      Installed: (none)
      Candidate: 2.40.2-2
      Version table:
         2.40.2-2 500
    libgdk-pixbuf2.0-doc:
      Installed: (none)
      Version table:
    libgdk-pixbuf-2.0-0:
      Installed: 2.42.2+dfsg-1+deb11u2
      Version table:
     *** 2.42.2+dfsg-1+deb11u2 500
    libgdk-pixbuf2.0-0:
      Installed: 2.40.2-2
      Candidate: 2.40.2-2
      Version table:
     *** 2.40.2-2 500
    @ralle
    sudo apt install libgdk-pixbuf2.0-bin libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf-2.0-0
    ralleR 1 Antwort Letzte Antwort
      @ralle
      ralleR Offline
      ralleR Offline
      ralle
      gemacht....
      pi@raspberrypi:~ $ sudo apt install libgdk-pixbuf2.0-bin libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf-2.0-0
      libgdk-pixbuf-2.0-0 is already the newest version (2.42.2+dfsg-1+deb11u2).
      libgdk-pixbuf-2.0-0 set to manually installed.
      libgdk-pixbuf-xlib-2.0-0 is already the newest version (2.40.2-2).
      libgdk-pixbuf-xlib-2.0-0 set to manually installed.
      You might want to run 'apt --fix-broken install' to correct these.
      The following packages have unmet dependencies:
       libgdk-pixbuf-2.0-dev : Depends: gir1.2-gdkpixbuf-2.0 (= 2.42.2+dfsg-1+deb11u2) but 2.42.2+dfsg-1+deb11u1 is to be installed
      E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
      • ralleR ralle
        gemacht....
        @ralle sagte in komm nicht weiter..."dpkg was interrupted":
        sudo apt install gir1.2-gdkpixbuf-2.0=2.42.2+dfsg-1+deb11u2
          ralleR Offline
          ralleR Offline
          ralle
          pi@raspberrypi:~ $ sudo apt install gir1.2-gdkpixbuf-2.0=2.42.2+dfsg-1+deb11u2
           libgdk-pixbuf-2.0-dev : Depends: libgdk-pixbuf2.0-bin (= 2.42.2+dfsg-1+deb11u2) but 2.42.2+dfsg-1+deb11u1 is to be installed
          • ralleR ralle
            sudo apt install gir1.2-gdkpixbuf-2.0=2.42.2+dfsg-1+deb11u2 libgdk-pixbuf2.0-bin=2.42.2+dfsg-1+deb11u2
            ralleR 2 Antworten Letzte Antwort
              ralleR Offline
              ralleR Offline
              ralle
              @thomas-braun said in komm nicht weiter..."dpkg was interrupted":
                ralleR Offline
                ralleR Offline
                ralle
                hat soweit geklappt, lief ohne Fehler durch. und nun?
                • ralleR ralle
                  @ralle
                  sudo apt update
                  sudo apt full-upgrade
                  sagt nun?
                    @ralle
                    sudo apt update
                    sagt nun?
                    ralleR Offline
                    ralleR Offline
                    ralle
                    schrieb am zuletzt editiert von ralle
                    lief durch.. war es das?
                    pi@raspberrypi:~ $ sudo apt full-upgrade
                    Calculating upgrade... Done
                    The following packages were automatically installed and are no longer required:
                      libfuse2 raspinfo
                    Use 'sudo apt autoremove' to remove them.
                    The following packages will be upgraded:
                      gstreamer1.0-alsa gstreamer1.0-plugins-base gstreamer1.0-x libcurl3-gnutls
                      libgstreamer-gl1.0-0 libgstreamer-plugins-base1.0-0 libimlib2 libndp0
                      libqt5concurrent5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
                      libqt5test5 libqt5xml5 libvlc-bin libvlc5 libvlccore9 nodejs python3-idna
                      python3-pil qt5-gtk-platformtheme vlc vlc-bin vlc-data vlc-l10n
                      vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
                      vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output
                      vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xwayland
                    36 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 0 B/53.9 MB of archives.
                    After this operation, 16.4 kB of additional disk space will be used.
                    Do you want to continue? [Y/n] y
                    Reading changelogs... Done
                    Extracting templates from packages: 100%
                    (Reading database ... 117751 files and directories currently installed.)
                    Preparing to unpack .../00-libgstreamer-plugins-base1.0-0_1.18.4-2+deb11u2_armhf.deb ...
                    Unpacking libgstreamer-plugins-base1.0-0:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                    Preparing to unpack .../01-gstreamer1.0-alsa_1.18.4-2+deb11u2_armhf.deb ...
                    Unpacking gstreamer1.0-alsa:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                    Preparing to unpack .../02-gstreamer1.0-plugins-base_1.18.4-2+deb11u2_armhf.deb ...
                    Unpacking gstreamer1.0-plugins-base:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                    Preparing to unpack .../03-gstreamer1.0-x_1.18.4-2+deb11u2_armhf.deb ...
                    Unpacking gstreamer1.0-x:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                    Preparing to unpack .../04-libcurl3-gnutls_7.74.0-1.3+deb11u12_armhf.deb ...
                    Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u12) over (7.74.0-1.3+deb11u11) ...
                    Preparing to unpack .../05-libgstreamer-gl1.0-0_1.18.4-2+deb11u2_armhf.deb ...
                    Unpacking libgstreamer-gl1.0-0:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                    Preparing to unpack .../06-libimlib2_1.7.1-2+deb11u1_armhf.deb ...
                    Unpacking libimlib2:armhf (1.7.1-2+deb11u1) over (1.7.1-2) ...
                    Preparing to unpack .../07-libndp0_1.6-1+deb11u1_armhf.deb ...
                    Unpacking libndp0:armhf (1.6-1+deb11u1) over (1.6-1) ...
                    Preparing to unpack .../08-libqt5concurrent5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                    Unpacking libqt5concurrent5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                    Preparing to unpack .../09-libqt5printsupport5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                    Unpacking libqt5printsupport5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                    Preparing to unpack .../10-libqt5sql5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                    Unpacking libqt5sql5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                    Preparing to unpack .../11-libqt5sql5-sqlite_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                    Unpacking libqt5sql5-sqlite:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                    Preparing to unpack .../12-libqt5test5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                    Unpacking libqt5test5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                    Preparing to unpack .../13-libqt5xml5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                    Unpacking libqt5xml5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                    Preparing to unpack .../14-vlc_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../15-vlc-plugin-base_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-base:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../16-vlc-data_1%3a3.0.21-0+rpt1+deb11u1_all.deb ...
                    Unpacking vlc-data (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../17-libvlccore9_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking libvlccore9:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../18-vlc-plugin-skins2_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-skins2:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../19-vlc-plugin-qt_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-qt:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../20-vlc-plugin-video-output_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-video-output:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../21-libvlc5_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking libvlc5:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../22-vlc-bin_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-bin (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../23-libvlc-bin_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../24-nodejs_18.20.4-1nodesource1_armhf.deb ...
                    Detected old npm client, removing...
                    Unpacking nodejs (18.20.4-1nodesource1) over (18.20.2-1nodesource1) ...
                    Preparing to unpack .../25-python3-idna_2.10-1+deb11u1_all.deb ...
                    Unpacking python3-idna (2.10-1+deb11u1) over (2.10-1) ...
                    Preparing to unpack .../26-python3-pil_8.1.2+dfsg-0.3+deb11u2_armhf.deb ...
                    Unpacking python3-pil:armhf (8.1.2+dfsg-0.3+deb11u2) over (8.1.2+dfsg-0.3+deb11u1) ...
                    Preparing to unpack .../27-qt5-gtk-platformtheme_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                    Unpacking qt5-gtk-platformtheme:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                    Preparing to unpack .../28-vlc-l10n_1%3a3.0.21-0+rpt1+deb11u1_all.deb ...
                    Unpacking vlc-l10n (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../29-vlc-plugin-access-extra_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-access-extra:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../30-vlc-plugin-notify_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-notify:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../31-vlc-plugin-samba_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-samba:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../32-vlc-plugin-video-splitter_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-video-splitter:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../33-vlc-plugin-visualization_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                    Unpacking vlc-plugin-visualization:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                    Preparing to unpack .../34-wpasupplicant_2%3a2.9.0-21+deb11u1_armhf.deb ...
                    Unpacking wpasupplicant (2:2.9.0-21+deb11u1) over (2:2.9.0-21) ...
                    Preparing to unpack .../35-xwayland_2%3a1.20.11-1+rpt3+deb11u13_armhf.deb ...
                    Unpacking xwayland (2:1.20.11-1+rpt3+deb11u13) over (2:1.20.11-1+rpt3+deb11u11) ...
                    Setting up libgstreamer-plugins-base1.0-0:armhf (1.18.4-2+deb11u2) ...
                    Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u12) ...
                    Setting up vlc-l10n (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up nodejs (18.20.4-1nodesource1) ...
                    Setting up qt5-gtk-platformtheme:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                    Setting up libqt5sql5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                    Setting up wpasupplicant (2:2.9.0-21+deb11u1) ...
                    Setting up libqt5printsupport5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                    Setting up python3-pil:armhf (8.1.2+dfsg-0.3+deb11u2) ...
                    Setting up libqt5xml5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                    Setting up libgstreamer-gl1.0-0:armhf (1.18.4-2+deb11u2) ...
                    Setting up gstreamer1.0-plugins-base:armhf (1.18.4-2+deb11u2) ...
                    Setting up python3-idna (2.10-1+deb11u1) ...
                    Setting up libimlib2:armhf (1.7.1-2+deb11u1) ...
                    Setting up libvlccore9:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-plugin-qt:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up libndp0:armhf (1.6-1+deb11u1) ...
                    Setting up xwayland (2:1.20.11-1+rpt3+deb11u13) ...
                    Setting up libqt5test5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                    Setting up libqt5concurrent5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                    Setting up vlc-data (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-plugin-notify:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-plugin-video-output:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-plugin-samba:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up gstreamer1.0-x:armhf (1.18.4-2+deb11u2) ...
                    Setting up gstreamer1.0-alsa:armhf (1.18.4-2+deb11u2) ...
                    Setting up libqt5sql5-sqlite:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                    Setting up vlc-plugin-skins2:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-plugin-video-splitter:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up libvlc5:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-plugin-visualization:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-plugin-access-extra:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-plugin-base:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc-bin (1:3.0.21-0+rpt1+deb11u1) ...
                    Setting up vlc (1:3.0.21-0+rpt1+deb11u1) ...
                    Processing triggers for desktop-file-utils (0.26-1) ...
                    Processing triggers for hicolor-icon-theme (0.17-2) ...
                    Processing triggers for gnome-menus (3.36.0-1) ...
                    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u10) ...
                    Processing triggers for man-db (2.9.4-2) ...
                    Processing triggers for dbus (1.12.28-0+deb11u1) ...
                    Processing triggers for mailcap (3.69) ...
                    Processing triggers for libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                    • ralleR ralle
                        libfuse2 raspinfo
                      @ralle
                      Dann
                      iob stop
                      sudo reboot
                      und wenn die Kiste wieder oben ist die Ausgaben zu
                      sudo apt update
                      • ralleR ralle
                          libfuse2 raspinfo
                        @ralle
                        Schalt den Desktop-Krempel aus...
                        Je weniger unnützes Zeuch da mitrumpelt desto einfacher sind auch Paketupdates und deren Abhängigkeiten aufzulösen.
                          @ralle
                          ralleR Offline
                          ralleR Offline
                          ralle
                          Schalt den Desktop-Krempel aus... --- für dich leicht gesagt, ist das für mich auch möglich??
                          hier die Liste nach "Full-upgrade"
                          All packages are up to date.
                            libfuse2 raspinfo
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          pi@raspberrypi:~ $
                          • ralleR ralle
                              libfuse2 raspinfo
                            pi@raspberrypi:~ $
                            @ralle
                            Jetzt passt es. Bring das ganze noch auf
                            iob nodejs-update 20
                            Und in nächster Zeit per kompletter Neuinstallation (dann gleich ohne Desktop-Umgebung) auf Raspberry OS 12 'Bookworm'.
                              @ralle
                              ralleR Offline
                              ralleR Offline
                              ralle
                              kannst du mir in 2-3 Sätzen sagen was du da jetzt gemacht hast, worin das Problem lag...
                              vielen Dank für deine Hilfe.
                              Neuinstallation werde ich mal machen.... nächste Herrausforderung :)
                              • ralleR ralle
                                Aus irgendeinem Grund konnte der Paketmanager die Abhängigkeiten nicht mehr auflösen.
                                Da haben wir dem Blechheini jetzt abgenommen, eigentlich soll der das selber machen, dafür ist der Paketmanager bzw. dessen 'solver' ja da.
                                  @ralle
                                  ralleR Offline
                                  ralleR Offline
                                  ralle
                                  hab mal eben nachgeschaut, es gibt 3 OS Versionen 2x mit Desktop und einmal die light.
                                  ist es die Light die ich dann benötige?
                                  • ralleR ralle
                                    Ja, light in der 64Bit-Version.
                                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                    • H Online
                                      H Online
                                      Happyuser20
                                      Guten Morgen
                                      Ich schließe mich hier an.
                                      Habe ein ähnliches Problem auf meinem Raspi IOB Slave
                                      Bekomme im IOB Admin auch die Meldung das Updates verfügbar sind. funktioniert aber nicht.
                                      Ich bekomme folgende Ausgabe mit Putty
                                      pi@raspberrypi:~ $ iob stop
                                      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                      281 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                       dmsetup : Depends: libdevmapper1.02.1 (>= 2:1.02.138) but 2:1.02.137-2 is installed
                                      pi@raspberrypi:~ $
                                      Ich meine gelsen zu haben. Auf keinen Fall irgendwas mit FIX zu machen.
                                      Bitte um Hilfe
                                      HappyUser20
                                      • H Happyuser20
                                        Guten Morgen
                                        pi@raspberrypi:~ $
                                        Bitte um Hilfe
                                        HappyUser20
                                        @happyuser20 sagte in komm nicht weiter..."dpkg was interrupted":
                                        da warst du aber lange schon nicht mehr dran.
                                        ist so etwas von tot!
                                        da geht ein upgrade auf bookworm sowieso nicht
                                        Also komplett neu machen
                                        • H Online
                                          H Online
                                          Happyuser20
                                          Na prima, aber nutzt nichts.
                                          so alt ist das noch garnicht, Anfang des Jahres 😄
