  3. Einsteigerfragen
  4. komm nicht weiter..."dpkg was interrupted"
    5.4k
49 Beiträge 4 Kommentatoren 6.5k Aufrufe 3 Beobachtet
    @ralle
    sudo apt update
    sudo apt full-upgrade
    sagt nun?
    ralleR Offline
    ralleR Offline
    ralle
    schrieb am zuletzt editiert von ralle
    lief durch.. war es das?
    pi@raspberrypi:~ $ sudo apt full-upgrade
    Reading package lists... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      libfuse2 raspinfo
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      gstreamer1.0-alsa gstreamer1.0-plugins-base gstreamer1.0-x libcurl3-gnutls
      libgstreamer-gl1.0-0 libgstreamer-plugins-base1.0-0 libimlib2 libndp0
      libqt5concurrent5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
      libqt5test5 libqt5xml5 libvlc-bin libvlc5 libvlccore9 nodejs python3-idna
      python3-pil qt5-gtk-platformtheme vlc vlc-bin vlc-data vlc-l10n
      vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
      vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output
      vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xwayland
    36 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/53.9 MB of archives.
    After this operation, 16.4 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Reading changelogs... Done
    Extracting templates from packages: 100%
    (Reading database ... 117751 files and directories currently installed.)
    Preparing to unpack .../00-libgstreamer-plugins-base1.0-0_1.18.4-2+deb11u2_armhf.deb ...
    Unpacking libgstreamer-plugins-base1.0-0:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
    Preparing to unpack .../01-gstreamer1.0-alsa_1.18.4-2+deb11u2_armhf.deb ...
    Unpacking gstreamer1.0-alsa:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
    Preparing to unpack .../02-gstreamer1.0-plugins-base_1.18.4-2+deb11u2_armhf.deb ...
    Unpacking gstreamer1.0-plugins-base:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
    Preparing to unpack .../03-gstreamer1.0-x_1.18.4-2+deb11u2_armhf.deb ...
    Unpacking gstreamer1.0-x:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
    Preparing to unpack .../04-libcurl3-gnutls_7.74.0-1.3+deb11u12_armhf.deb ...
    Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u12) over (7.74.0-1.3+deb11u11) ...
    Preparing to unpack .../05-libgstreamer-gl1.0-0_1.18.4-2+deb11u2_armhf.deb ...
    Unpacking libgstreamer-gl1.0-0:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
    Preparing to unpack .../06-libimlib2_1.7.1-2+deb11u1_armhf.deb ...
    Unpacking libimlib2:armhf (1.7.1-2+deb11u1) over (1.7.1-2) ...
    Preparing to unpack .../07-libndp0_1.6-1+deb11u1_armhf.deb ...
    Unpacking libndp0:armhf (1.6-1+deb11u1) over (1.6-1) ...
    Preparing to unpack .../08-libqt5concurrent5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
    Unpacking libqt5concurrent5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
    Preparing to unpack .../09-libqt5printsupport5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
    Unpacking libqt5printsupport5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
    Preparing to unpack .../10-libqt5sql5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
    Unpacking libqt5sql5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
    Preparing to unpack .../11-libqt5sql5-sqlite_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
    Unpacking libqt5sql5-sqlite:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
    Preparing to unpack .../12-libqt5test5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
    Unpacking libqt5test5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
    Preparing to unpack .../13-libqt5xml5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
    Unpacking libqt5xml5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
    Preparing to unpack .../14-vlc_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../15-vlc-plugin-base_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-base:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../16-vlc-data_1%3a3.0.21-0+rpt1+deb11u1_all.deb ...
    Unpacking vlc-data (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../17-libvlccore9_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking libvlccore9:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../18-vlc-plugin-skins2_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-skins2:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../19-vlc-plugin-qt_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-qt:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../20-vlc-plugin-video-output_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-video-output:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../21-libvlc5_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking libvlc5:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../22-vlc-bin_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-bin (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../23-libvlc-bin_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../24-nodejs_18.20.4-1nodesource1_armhf.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.20.4-1nodesource1) over (18.20.2-1nodesource1) ...
    Preparing to unpack .../25-python3-idna_2.10-1+deb11u1_all.deb ...
    Unpacking python3-idna (2.10-1+deb11u1) over (2.10-1) ...
    Preparing to unpack .../26-python3-pil_8.1.2+dfsg-0.3+deb11u2_armhf.deb ...
    Unpacking python3-pil:armhf (8.1.2+dfsg-0.3+deb11u2) over (8.1.2+dfsg-0.3+deb11u1) ...
    Preparing to unpack .../27-qt5-gtk-platformtheme_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
    Unpacking qt5-gtk-platformtheme:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
    Preparing to unpack .../28-vlc-l10n_1%3a3.0.21-0+rpt1+deb11u1_all.deb ...
    Unpacking vlc-l10n (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../29-vlc-plugin-access-extra_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-access-extra:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../30-vlc-plugin-notify_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-notify:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../31-vlc-plugin-samba_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-samba:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../32-vlc-plugin-video-splitter_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-video-splitter:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../33-vlc-plugin-visualization_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
    Unpacking vlc-plugin-visualization:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
    Preparing to unpack .../34-wpasupplicant_2%3a2.9.0-21+deb11u1_armhf.deb ...
    Unpacking wpasupplicant (2:2.9.0-21+deb11u1) over (2:2.9.0-21) ...
    Preparing to unpack .../35-xwayland_2%3a1.20.11-1+rpt3+deb11u13_armhf.deb ...
    Unpacking xwayland (2:1.20.11-1+rpt3+deb11u13) over (2:1.20.11-1+rpt3+deb11u11) ...
    Setting up libgstreamer-plugins-base1.0-0:armhf (1.18.4-2+deb11u2) ...
    Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u12) ...
    Setting up vlc-l10n (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up nodejs (18.20.4-1nodesource1) ...
    Setting up qt5-gtk-platformtheme:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
    Setting up libqt5sql5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
    Setting up wpasupplicant (2:2.9.0-21+deb11u1) ...
    Setting up libqt5printsupport5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
    Setting up python3-pil:armhf (8.1.2+dfsg-0.3+deb11u2) ...
    Setting up libqt5xml5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
    Setting up libgstreamer-gl1.0-0:armhf (1.18.4-2+deb11u2) ...
    Setting up gstreamer1.0-plugins-base:armhf (1.18.4-2+deb11u2) ...
    Setting up python3-idna (2.10-1+deb11u1) ...
    Setting up libimlib2:armhf (1.7.1-2+deb11u1) ...
    Setting up libvlccore9:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-plugin-qt:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up libndp0:armhf (1.6-1+deb11u1) ...
    Setting up xwayland (2:1.20.11-1+rpt3+deb11u13) ...
    Setting up libqt5test5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
    Setting up libqt5concurrent5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
    Setting up vlc-data (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-plugin-notify:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-plugin-video-output:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-plugin-samba:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up gstreamer1.0-x:armhf (1.18.4-2+deb11u2) ...
    Setting up gstreamer1.0-alsa:armhf (1.18.4-2+deb11u2) ...
    Setting up libqt5sql5-sqlite:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
    Setting up vlc-plugin-skins2:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-plugin-video-splitter:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up libvlc5:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-plugin-visualization:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-plugin-access-extra:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-plugin-base:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc-bin (1:3.0.21-0+rpt1+deb11u1) ...
    Setting up vlc (1:3.0.21-0+rpt1+deb11u1) ...
    Processing triggers for desktop-file-utils (0.26-1) ...
    Processing triggers for hicolor-icon-theme (0.17-2) ...
    Processing triggers for gnome-menus (3.36.0-1) ...
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u10) ...
    Processing triggers for man-db (2.9.4-2) ...
    Processing triggers for dbus (1.12.28-0+deb11u1) ...
    Processing triggers for mailcap (3.69) ...
    Processing triggers for libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) ...
    • ralleR ralle
        libfuse2 raspinfo
      @ralle
      Dann
      iob stop
      sudo reboot
      und wenn die Kiste wieder oben ist die Ausgaben zu
      sudo apt update
      • ralleR ralle
          libfuse2 raspinfo
        @ralle
        Schalt den Desktop-Krempel aus...
        Je weniger unnützes Zeuch da mitrumpelt desto einfacher sind auch Paketupdates und deren Abhängigkeiten aufzulösen.
        ralleR 1 Antwort Letzte Antwort
          @ralle
          ralleR Offline
          ralleR Offline
          ralle
          @thomas-braun said in komm nicht weiter..."dpkg was interrupted":
          Schalt den Desktop-Krempel aus... --- für dich leicht gesagt, ist das für mich auch möglich??
          hier die Liste nach "Full-upgrade"
          pi@raspberrypi:~ $ sudo apt update
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          All packages are up to date.
            libfuse2 raspinfo
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          pi@raspberrypi:~ $
          • ralleR ralle
              libfuse2 raspinfo
            pi@raspberrypi:~ $
            @ralle
            Jetzt passt es. Bring das ganze noch auf
            iob nodejs-update 20
            Und in nächster Zeit per kompletter Neuinstallation (dann gleich ohne Desktop-Umgebung) auf Raspberry OS 12 'Bookworm'.
            ralleR 2 Antworten Letzte Antwort
              @ralle
              ralleR Offline
              ralleR Offline
              ralle
              kannst du mir in 2-3 Sätzen sagen was du da jetzt gemacht hast, worin das Problem lag...
              vielen Dank für deine Hilfe.
              Neuinstallation werde ich mal machen.... nächste Herrausforderung :)
              • ralleR ralle
                @ralle sagte in komm nicht weiter..."dpkg was interrupted":
                Aus irgendeinem Grund konnte der Paketmanager die Abhängigkeiten nicht mehr auflösen.
                Da haben wir dem Blechheini jetzt abgenommen, eigentlich soll der das selber machen, dafür ist der Paketmanager bzw. dessen 'solver' ja da.
                  @ralle
                  ralleR Offline
                  ralleR Offline
                  ralle
                  hab mal eben nachgeschaut, es gibt 3 OS Versionen 2x mit Desktop und einmal die light.
                  ist es die Light die ich dann benötige?
                  • ralleR ralle
                    Ja, light in der 64Bit-Version.
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    • H Online
                      H Online
                      Happyuser20
                      Guten Morgen
                      Ich schließe mich hier an.
                      Habe ein ähnliches Problem auf meinem Raspi IOB Slave
                      Bekomme im IOB Admin auch die Meldung das Updates verfügbar sind. funktioniert aber nicht.
                      Ich bekomme folgende Ausgabe mit Putty
                      pi@raspberrypi:~ $ iob stop
                      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      281 packages can be upgraded. Run 'apt list --upgradable' to see them.
                      You might want to run 'apt --fix-broken install' to correct these.
                      The following packages have unmet dependencies:
                       dmsetup : Depends: libdevmapper1.02.1 (>= 2:1.02.138) but 2:1.02.137-2 is installed
                      E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
                      pi@raspberrypi:~ $
                      Ich meine gelsen zu haben. Auf keinen Fall irgendwas mit FIX zu machen.
                      Bitte um Hilfe
                      HappyUser20
                      • H Happyuser20
                        Guten Morgen
                        pi@raspberrypi:~ $
                        Bitte um Hilfe
                        HappyUser20
                        @happyuser20 sagte in komm nicht weiter..."dpkg was interrupted":
                        da warst du aber lange schon nicht mehr dran.
                        ist so etwas von tot!
                        da geht ein upgrade auf bookworm sowieso nicht
                        Also komplett neu machen
                        • H Online
                          H Online
                          Happyuser20
                          Na prima, aber nutzt nichts.
                          so alt ist das noch garnicht, Anfang des Jahres 😄
                          • H Happyuser20
                            Anfang des Jahres
                            never!
                            buster ist Debian 10, bookworm ist Debian 12.
                            Pro Version etwa 2 Jahre.....
                            • H Happyuser20
                              Das war aber auch da schon abgekündigt. RaspberrryOS unterstüzt nur das aktuelle stable release (aka Version 12 'Bookworm') und die Vorversion 'Bullseye'.
                              Warum installiert man ein abgekündigtes Release?
                              Sprung zu weit, Änderungen zu groß -> Neuinstallation.
                              Und das neue System dann auch beständig aktuell halten.
                                @ralle
                                sudo apt update
                                sagt nun?
                                ralleR Offline
                                ralleR Offline
                                ralle
                                @thomas-braun Hallo, du hattes mir gestern geholfen, nun hab ich noch eine Frage zum Speicher. Jetzt gibt mir IOB an das mein Speicher voll ist, das war vor dem Update nicht so. Wie kann ich das aufräumen / Speicher freigeben, Ein paar Befehle hab ich ausprobiert die ich gefunden habe jedoch ohne Erfolg.
                                • ralleR ralle
                                  @ralle
                                  Schau mittels
                                  sudo ncdu /
                                  nach wo die dicken Dinger liegen.
                                    @ralle
                                    Schau mittels
                                    sudo ncdu /
                                    ralleR Offline
                                    ralleR Offline
                                    ralle
                                    sudo ncdu /
                                    vielen Dank, hab ich gemacht aber ich glaub das ich so nicht weiter kommen mit dem Wissen was ich zu linux habe. Ich möchte damit auch keinen belasten, gibt wichtigeres.
                                    Muss mich die Tage dran machen das System neu auf zu setzten..... Das wird wieder was geben, tzzzzzzz
                                    • ralleR ralle
                                      sudo ncdu /
                                      Und wo hast du jetzt große Verzeichnisse ausgemacht?
                                      Hat doch mit 'Linux' nix zu tun.
                                        ralleR Offline
                                        ralleR Offline
                                        ralle
                                        3.4 GiB [########  ] /usr
                                            2.0 GiB [#####     ] /var
                                            1.6 GiB [###       ] /home
                                            1.3 GiB [###       ] /etc
                                          244.5 MiB [          ] /root
                                           62.7 MiB [          ] /boot
                                           50.9 MiB [          ] /boot.bak
                                            5.4 MiB [          ] /dev
                                            1.1 MiB [          ] /run
                                           24.0 KiB [          ] /tmp
                                        e  16.0 KiB [          ] /lost+found
                                        e   4.0 KiB [          ] /srv
                                        e   4.0 KiB [          ] /mnt
                                        e   4.0 KiB [          ] /media
                                            0.0   B [          ] /sys
                                        .   0.0   B [          ] /proc
                                        @   0.0   B [          ]  sbin
                                        @   0.0   B [          ]  lib
                                        @   0.0   B [          ]  bin
                                        • ralleR ralle
                                              1.3 GiB [###       ] /etc
                                            244.5 MiB [          ] /root
                                             62.7 MiB [          ] /boot
                                              5.4 MiB [          ] /dev
                                              1.1 MiB [          ] /run
                                             24.0 KiB [          ] /tmp
                                          e   4.0 KiB [          ] /srv
                                          e   4.0 KiB [          ] /mnt
                                              0.0   B [          ] /sys
                                          .   0.0   B [          ] /proc
                                          @   0.0   B [          ]  sbin
                                          @   0.0   B [          ]  lib
                                          @   0.0   B [          ]  bin
                                          @ralle
                                          Tiefer rein gehen.
                                          Das wird eine Mischung aus npm und apt cache sein, vermute ich.
                                          Insgesamt scheint mir aber deine Partition nicht gerade luxuriös groß zu sein.
                                          df -PTh
                                          sagt?
