  4. js-controller 6.0.x jetzt für alle User im STABLE!
    1.0k
    6.1k
controllerjs-controllerkierastable
257 Beiträge 47 Kommentatoren 88.2k Aufrufe 45 Beobachtet
  • foxriver76F foxriver76
    @ofbeqnpolkkl6mby5e13 hm dann mal trotzdem einen der angemerkten zeigen mit der jeweiligen Meldung + source id am besten dann kann man schauen wo das Problem liegt.
    O Abwesend
    O Abwesend
    oFbEQnpoLKKl6mbY5e13
    @foxriver76
    Bleiben wir ruhig bei dem genannten Beispiel.
    Alias:
      "common": {
        "alias": {
          "id": {
            "read": "mqtt-client.0.stat.tasmota_A36501.POWER2",
            "write": "mqtt-client.0.cmnd.tasmota_A36501.POWER2"
          "read": "val == \"ON\" ? true : false",
          "write": "val == true ? 1 : 0"
        "name": "Strahler 2",
        "role": "switch",
        "type": "boolean",
        "unit": "",
        "min": null,
        "max": null,
        "read": true,
        "write": true,
        "smartName": {
          "de": "Strahler 2",
          "smartType": "SWITCH"
      "native": {},
      "type": "state",
      "_id": "alias.0.Haus.Erdgeschoss.Schlafzimmer.Strahler2.switch_on",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "user": "system.user.admin",
      "ts": 1680780507033
    Datenpunkt lesend:
      "type": "state",
      "role": "text",
      "common": {
        "name": "POWER2",
        "type": "mixed",
        "read": true,
        "write": true,
        "desc": "created from topic",
        "custom": {
          "mqtt-client.0": {
            "enabled": true,
            "topic": "stat/tasmota_A36501/POWER2",
            "publish": false,
            "pubChangesOnly": false,
            "pubAsObject": false,
            "qos": 0,
            "retain": false,
            "subscribe": true,
            "subChangesOnly": false,
            "subAsObject": false,
            "subQos": 0,
            "setAck": true
      "native": {
      "from": "system.adapter.mqtt-client.0",
      "ts": 1680698849842,
      "_id": "mqtt-client.0.stat.tasmota_A36501.POWER2",
      "acl": {
        "object": 1636,
        "state": 1636,
      "binary": true
    Datenpunkt schreibend:
      "type": "state",
      "role": "text",
      "common": {
        "name": "POWER2",
        "type": "mixed",
        "read": true,
        "write": true,
        "custom": {
          "mqtt-client.0": {
            "enabled": true,
            "topic": "cmnd/tasmota_A36501/POWER2",
            "publish": true,
            "qos": 0,
            "retain": false,
            "subscribe": true,
            "subQos": 0,
            "setAck": true
      "native": {
      "_id": "mqtt-client.0.cmnd.tasmota_A36501.POWER2",
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1680700517346,
      "binary": true
    Edit:
    Ich schätze, die Meldung kommt jeweils vom Javascript-Adapter und vom Influxdb-Adapter für jeden Alias, der eine Konvertierungsfunktion (lesend) aktiviert hat.
    foxriver76F 2 Antworten Letzte Antwort
      @fellpower sagte in Nach Update des JS Controllers einige Fehler:
      Und das heisst jetzt was?
      keine Ahnung!
      Docker ist mir zu komplex!
      fellpower
      Ahhhh, ja.
      Die Frage ist, ist der neuste Docker Container schon geupdatet, seitens iobroker? Dann bräuchte ich den "latest" ja nur neu ausrollen ^^
      • F fellpower
        Moin
        Habe heute Morgen gesehen, das es Updates für JS Controller rund Admin Adapter gab. Also brav erstmal im Forum gelesen, Backups gemacht und das Admin Interface geupdatet. Mein System war, laut Admin auf dem neusten Stand.
        Mein Iobroker läuft auf einem Proxmox Server im Docker.
        Es gab viele "Fetch Errors" und irgendwelche Dateien wurden nicht gefunden. Log dazu habe ich nicht - mehr.
        Wenn ich jetzt den iobroker stoppe und ein "iob upgrade self" mache, sagt er mir, das System wäre up to date. Ist es aber nicht, zumal sich Fehler eingeschlichen haben.
        Also habe ich mich per SSH in den Container aufgemacht - und das Update noch einmal mit "iob upgrade self" angestoßen.
        Leider ändert sich nichts. Ich sehe auch, das mein Node.js irgendwie nicht mehr up-to-date ist, obwohl es das vor dem JS Controller Update war.
        Wie kann ich jetzt vorgehen, damit ich es endlich wieder hinbekomme, das alles so funktioniert, wie es soll?
        Skript v.2024-05-22
        *** BASE SYSTEM ***
        Hardware Vendor : BESSTAR TECH LIMITED
        Kernel          : x86_64
        Userland        : 64 bit
        Docker          : v9.1.2
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         07:52:59 up 13 days, 56 min,  0 user,  load average: 0.20, 0.19, 0.34
        CPU threads: 16
        *** Time and Time Zones ***
        Fri Aug  2 05:52:59 UTC 2024
        Fri Aug  2 07:52:59 CEST 2024
        CEST +0200
        Etc/UTC
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        js-controller is not running
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             33G        2.6G         24G         45M        6.2G         30G
        Swap:           8.6G         27M        8.6G
        Total:           41G        2.6G         33G
        Active iob-Instances:   1
                31510 M total memory
                 2481 M used memory
                 3233 M active memory
                 3894 M inactive memory
                23356 M free memory
                  915 M buffer memory
                 5020 M swap cache
                 8191 M total swap
                   26 M used swap
                 8165 M free swap
        top - 07:52:59 up 13 days, 56 min,  0 user,  load average: 0.20, 0.19, 0.34
        Tasks:   9 total,   1 running,   8 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  31510.2 total,  23355.8 free,   2482.3 used,   5936.2 buff/cache
        MiB Swap:   8192.0 total,   8165.5 free,     26.5 used.  29027.9 avail Mem
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        overlay                          overlay    99G   24G   71G  25% /
        tmpfs                            tmpfs      64M     0   64M   0% /dev
        shm                              tmpfs      64M     0   64M   0% /dev/shm
        /dev/mapper/pve-vm--100--disk--1 ext4       99G   24G   71G  25% /opt/iobroker
        udev                             devtmpfs   16G     0   16G   0% /dev/tty
        tmpfs                            tmpfs      16G     0   16G   0% /proc/asound
        tmpfs                            tmpfs      16G     0   16G   0% /proc/acpi
        tmpfs                            tmpfs      16G     0   16G   0% /proc/scsi
        tmpfs                            tmpfs      16G     0   16G   0% /sys/firmware
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems:
        TARGET                  SOURCE        FSTYPE   OPTIONS
        /                       overlay        overlay  rw,relatime,lowerdir=/var/lib/docker/overlay2/l/4KPXFAGUWAEODLWHUYGYNR5XR2:/var/lib/docker/overlay2/l/YC6UZQNIEONNUHQWKUVFXMYBIO:/var/lib/docker/overlay2/l/YA2JPP53LLKZKSGUYBE42FKZJE:/var/lib/docker/overlay2/l/VBR7AFQD72SXGNIPFFVOUTCSQY:/var/lib/docker/overlay2/l/HDJXXYY2IKR2CE76ZE7M6IAEYI:/var/lib/docker/overlay2/l/WZTULCKPBXFHV7V4AGCNEVQHNP,upperdir=/var/lib/docker/overlay2/ac6eb89deeb1eaa4d1722dc1b7dd0db72a3d85341b49eb09705b4b2dca945f6c/diff,workdir=/var/lib/docker/overlay2/ac6eb89deeb1eaa4d1722dc1b7dd0db72a3d85341b49eb09705b4b2dca945f6c/work,redirect_dir=nofollow,userxattr
        |-/proc                 proc        proc     rw,nosuid,nodev,noexec,relatime
        | |-/proc/bus           proc[/bus]        proc     ro,nosuid,nodev,noexec,relatime
        | |-/proc/fs            proc[/fs]        proc     ro,nosuid,nodev,noexec,relatime
        | |-/proc/irq           proc[/irq]        proc     ro,nosuid,nodev,noexec,relatime
        | |-/proc/sys           proc[/sys]        proc     ro,nosuid,nodev,noexec,relatime
        | |-/proc/sysrq-trigger proc[/sysrq-trigger]        proc     ro,nosuid,nodev,noexec,relatime
        | |-/proc/asound        tmpfs        tmpfs    ro,relatime,uid=100000,gid=100000,inode64
        | |-/proc/acpi          tmpfs        tmpfs    ro,relatime,uid=100000,gid=100000,inode64
        | |-/proc/kcore         udev[/null]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | |-/proc/keys          udev[/null]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | |-/proc/latency_stats udev[/null]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | |-/proc/timer_list    udev[/null]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | `-/proc/scsi          tmpfs        tmpfs    ro,relatime,uid=100000,gid=100000,inode64
        |-/dev                  tmpfs        tmpfs    rw,nosuid,size=65536k,mode=755,uid=100000,gid=100000,inode64
        | |-/dev/pts            devpts        devpts   rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666
        | |-/dev/mqueue         mqueue        mqueue   rw,nosuid,nodev,noexec,relatime
        | |-/dev/shm            shm        tmpfs    rw,nosuid,nodev,noexec,relatime,size=65536k,uid=100000,gid=100000,inode64
        | |-/dev/null           udev[/null]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | |-/dev/random         udev[/random]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | |-/dev/full           udev[/full]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | |-/dev/tty            udev[/tty]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | |-/dev/zero           udev[/zero]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        | `-/dev/urandom        udev[/urandom]        devtmpfs rw,nosuid,relatime,size=16099388k,nr_inodes=4024847,mode=755,inode64
        |-/sys                  sysfs        sysfs    ro,nosuid,nodev,noexec,relatime
        | |-/sys/firmware       tmpfs        tmpfs    ro,relatime,uid=100000,gid=100000,inode64
        | `-/sys/fs/cgroup      cgroup        cgroup2  ro,nosuid,nodev,noexec,relatime
        |-/opt/iobroker         /dev/mapper/pve-vm--100--disk--1[/var/lib/docker/volumes/iobroker/_data]        ext4     rw,relatime,stripe=16
        |-/etc/resolv.conf      /dev/mapper/pve-vm--100--disk--1[/var/lib/docker/containers/9fef1c583e06bdab1ecc4fdbe95c0ff8cc1d9093bf29e592071670974b3736f8/resolv.conf] ext4     rw,relatime,stripe=16
        |-/etc/hostname         /dev/mapper/pve-vm--100--disk--1[/var/lib/docker/containers/9fef1c583e06bdab1ecc4fdbe95c0ff8cc1d9093bf29e592071670974b3736f8/hostname]    ext4     rw,relatime,stripe=16
        `-/etc/hosts            /dev/mapper/pve-vm--100--disk--1[/var/lib/docker/containers/9fef1c583e06bdab1ecc4fdbe95c0ff8cc1d9093bf29e592071670974b3736f8/hosts]       ext4     rw,relatime,stripe=16
        /var:
        34M     /var/
        32M     /var/lib
        19M     /var/lib/apt/lists
        19M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        18M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        636M    /opt/iobroker/iobroker-data/
        479M    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        16M     /opt/iobroker/iobroker-data/objects.jsonl
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.279d2690.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.4
        /usr/bin/node           v18.20.4
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 1001
               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.20.3-1nodesource1 1001
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.9
        admin:          7.0.22
        javascript:     8.7.6
        nodejs modules from github:     0
        Adapter State
          system.adapter.admin.0                  : admin                 : 383319daf2ee                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : 383319daf2ee                             -  enabled
          system.adapter.discovery.0              : discovery             : 383319daf2ee                             -  enabled
          system.adapter.history.0                : history               : 383319daf2ee                             -  enabled
          system.adapter.influxdb.0               : influxdb              : 383319daf2ee                             -  enabled, port: 8086
          system.adapter.javascript.0             : javascript            : 383319daf2ee                             -  enabled
          system.adapter.mqtt.0                   : mqtt                  : 383319daf2ee                             -  enabled, port: 1890, bind: 0.0.0.0
          system.adapter.node-red.0               : node-red              : 383319daf2ee                             -  enabled, port: 8082, bind: 0.0.0.0
          system.adapter.shelly.0                 : shelly                : 383319daf2ee                             -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.sonoff.0                 : sonoff                : 383319daf2ee                             -  enabled, port: 1886, bind: 0.0.0.0
        + instance is alive
        ioBroker-Repositories
        │ (index) │   name   │                           url                           │ auto upgrade │
        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.0.22   , installed 7.0.22
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Objects and States
        Objects:        938
        States:         661
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        2024-08-02 07:42:45.289  - info: node-red.0 (252) Node-RED exited with 0
        2024-08-02 07:42:45.401  - info: history.0 (237) Terminated (NO_ERROR): Without reason
        2024-08-02 07:42:45.459  - info: influxdb.0 (195) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-08-02 07:42:45.704  - info: javascript.0 (222) terminating
        2024-08-02 07:42:45.709  - info: sonoff.0 (290) terminating
        2024-08-02 07:42:45.710  - info: sonoff.0 (290) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-08-02 07:42:45.732  - info: discovery.0 (370) terminating
        2024-08-02 07:42:45.735  - info: mqtt.0 (338) terminating
        2024-08-02 07:42:45.741  - info: backitup.0 (355) terminating
        2024-08-02 07:42:45.742  - info: host.383319daf2ee instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-08-02 07:42:45.747  - info: shelly.0 (317) terminating
        2024-08-02 07:42:45.750  - info: admin.0 (153) terminating
        2024-08-02 07:42:45.792  - info: host.383319daf2ee instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-08-02 07:42:45.803  - info: host.383319daf2ee instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-08-02 07:42:45.834  - info: host.383319daf2ee instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-08-02 07:42:45.834  - info: host.383319daf2ee instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-08-02 07:42:45.838  - info: host.383319daf2ee instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-08-02 07:42:45.920  - info: host.383319daf2ee instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
        2024-08-02 07:42:45.983  - info: host.383319daf2ee instance system.adapter.influxdb.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-08-02 07:42:46.229  - info: host.383319daf2ee instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-08-02 07:42:50.192  - info: host.383319daf2ee stopInstance timeout 5000 system.adapter.node-red.0 killing pid 252
        2024-08-02 07:42:50.204  - warn: host.383319daf2ee instance system.adapter.node-red.0 terminated due to SIGKILL
        2024-08-02 07:42:50.204  - info: host.383319daf2ee instance system.adapter.node-red.0 terminated with code null ()
        2024-08-02 07:42:50.204  - info: host.383319daf2ee All instances are stopped.
        2024-08-02 07:42:50.214  - info: host.383319daf2ee terminated
                                v.2024-05-22
        model name      : AMD Ryzen 7 4800U with Radeon Graphics
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.1.2
        Installation:           Docker
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               CEST +0200
        User-ID:                0
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        Recommended versions are nodejs 20.16.0 and npm 10.8.1
        MEMORY:
        Swap:           8.6G         27M        8.6G
        Total:           41G        2.7G         33G
        ioBroker Core:          js-controller           6.0.9
                                admin                   7.0.22
        ioBroker Status:        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects:                938
        States:                 661
        Size of iob-Database:
        4.2M    /opt/iobroker/iobroker-data/states.jsonl
        Ich bin nicht so ein dicker Linux Freak - daher wäre ich erfreut zu erfahren, was ich jetzt machen sollte, damit wieder alles so ist, wie vorher.
        Chris
        CodierknechtC Online
        Codierknecht
        @fellpower
        Warum
        Proxmox bietet doch VM oder LXC als Virtualisierung an.
        Warum dann da noch Docker?
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        F 1 Antwort Letzte Antwort
          @crunchip und das passiert jedes Mal wieder?
          crunchipC Offline
          crunchipC Offline
          @foxriver76 muss ich testen, bisher nur einmal versucht
          @foxriver76 habe es soeben nochmal probiert, lief allerdings auf den gleichen Fehler hinaus
          • CodierknechtC Codierknecht
            @fellpower
            Warum
            fellpower
            @codierknecht
            Weil ich damit noch andere Sachen mache. Warum, oder wieso spielt doch keine Rolle für das Problem.
            Wie könnte man das jetzt lösen? Das Container Image neu downloaden und einfach neu ausrollen? Ist der denn schon up-to-date? Wie finde ich das raus?
            • F fellpower
              Ahhhh, ja.
              Codierknecht
              Ein neues Image gibt's nur, wenn sich am Unterbau (OS) etwas ändert.
              Updates des js-controllers oder der einzelnen Adapter muss man schon selbst ausführen.
                fellpower
                @codierknecht
                Okay, aber dann lese ich hier, das geht nicht im Docker. Wat denn nu?
                • F fellpower
                  @codierknecht
                  Codierknecht
                  Ich auch. Darum gibt's bei mir jeweils eigene LXC-Container (ioBroker, MariaDB, Grafana, AdGuard) bzw. VM's (Octoprint).
                  • F fellpower
                    @codierknecht
                    Codierknecht
                    "Geht nicht" ist so nicht korrekt. Gehen tut's schon - wenn damit z.B. ein Update von Node oder Packet-Updates gemeint ist - macht man aber nicht. Wäre ja beim re-launch auch weg.
                    Den js-controller und/oder die Adapter kann (und sollte) man sehr wohl aktuell halten.
                    Es sei denn, man wartet immer bis zur nächsten Version des Image. Das geht natürlich auch.
                    Wo läuft denn da Dein Docker?
                    Parallel zu Proxmox als weitere Virtualisierung?
                    Oder innerhalb einer VM/LXC?
                      fellpower
                      schrieb am zuletzt editiert von fellpower
                      @codierknecht
                      Mein Docker läuft auf einem Ubuntu LXC, welches aufm Proxmox läuft.
                      Wie bekomme ich denn jetzt den node.js Controller dauerhaft geupdatet? Das scheint ja noch/wieder die "alte" Version zu sein, weil ich den Container neu gestartet habe.
                      Oder geht das nur, wenn es von iobroker n neues Docker Image gibt?
                      • F fellpower
                        @codierknecht
                        Codierknecht
                        Richtig!
                        Was man im Container am OS bastelt, ist weg wenn der Container neu gestartet wird.
                        Das ist ja Sinn und Zweck von Containern.
                        Da musst Du warten, bis @buanet ein neues Image bereitstellt.
                        Docker in einem LXC hört sich irgendwie schräg an.
                        Virtualisierung in einer Virtualisierung 🤔
                          funktionieren meines Wissens bei Docker so nicht
                          crunchipC Offline
                          crunchipC Offline
                          @homoran doch
                          Der neuste(v10) beta bringt Nodejs v20 mit
                            Richtig!
                            fellpower
                            @codierknecht
                            Ja, wenn man ein Linux Profi ist, macht man das natürlich anders - bin ich aber nicht!
                            Und für das bisschen, was der machen soll, spielt es für mich keine Rolle, ob es virtualvirtualisiert ist ;)
                            • F fellpower
                              @codierknecht
                              Codierknecht
                              Ich mit Sicherheit auch nicht ;-)
                              • O oFbEQnpoLKKl6mbY5e13
                                @foxriver76
                                Alias:
                                  "common": {
                                    "alias": {
                                      "id": {
                                    "role": "switch",
                                    "type": "boolean",
                                    "unit": "",
                                    "min": null,
                                    "max": null,
                                    "read": true,
                                    "write": true,
                                    "smartName": {
                                      "de": "Strahler 2",
                                  "native": {},
                                  "type": "state",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "ts": 1680780507033
                                Datenpunkt lesend:
                                  "type": "state",
                                  "role": "text",
                                  "common": {
                                    "name": "POWER2",
                                    "type": "mixed",
                                    "read": true,
                                    "write": true,
                                    "custom": {
                                      "mqtt-client.0": {
                                        "enabled": true,
                                        "publish": false,
                                        "qos": 0,
                                        "retain": false,
                                        "subscribe": true,
                                        "subQos": 0,
                                        "setAck": true
                                  "native": {
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "binary": true
                                  "type": "state",
                                  "role": "text",
                                  "common": {
                                    "name": "POWER2",
                                    "type": "mixed",
                                    "read": true,
                                    "write": true,
                                    "custom": {
                                      "mqtt-client.0": {
                                        "enabled": true,
                                        "publish": true,
                                        "qos": 0,
                                        "retain": false,
                                        "subscribe": true,
                                        "subQos": 0,
                                        "setAck": true
                                  "native": {
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "binary": true
                                Edit:
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                @ofbeqnpolkkl6mby5e13 Hm schaut eigentlich ok aus, muss ich probieren nachzustellen.
                                Videotutorials & mehr
                                  fellpower
                                  @codierknecht
                                  Also fassen wir zusammen:
                                  Ich habe den js-controller geupdatet, das hat wohl funktioniert.
                                  Aufgrund der Docker "Problematik" kann ich mein node.js irgendwie nicht updaten.
                                  Wenn ich es mit den bekannten Befehlen versuche (Wie hier beschrieben: https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18), dann funktioniert das irgendwie nicht. node.js bleibt auf 18.20.4.
                                  Also muss ich warten, bis buanet was neues bringt - oder selbst n Container bauen, wäre noch ne Möglichkeit.
                                  Was ist mit den Node-Red Fehlern auf dem Bild? Woher kommen die - und wie löse ich das?
                                  • F fellpower
                                    @codierknecht
                                    crunchipC Offline
                                    crunchipC Offline
                                    Also muss ich warten, bis buanet was neues bringt?
                                    https://github.com/buanet/ioBroker.docker/releases/tag/v10.0.0-beta.1
                                      fellpower
                                      @crunchip
                                      Hab ich schon gesehen. Wollte aber warten, bis nicht mehr Beta. ;)
                                      Aber ich denke, dann ist ja eigentlich alles richtig gelaufen, nur node.js kann noch nicht geupdatet werden, bis ich das Image neu ausrolle.
                                      Was sind das für Fehler mit Node-Red? Weiß das jemand? Node-Red an sich funktioniert noch.
                                      • crunchipC Offline
                                        crunchipC Offline
                                        stimmt wohl die Verlinkung nicht
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          @crunchip Docker oder klassische Linux Installation?
