  4. Test Adapter Growatt v3.3.1
adaptergrowattpv-anlageshinesolartesttester
808 Beiträge 72 Kommentatoren 434.3k Aufrufe 63 Beobachtet
  • G G.Huber
    da komm das bei raus.
    PLCHome 0P Offline
    PLCHome 0P Offline
    PLCHome 0
    #680
    @g-huber da hat Nix neu gestartet, das waren 1,5 ein einwandfreie Läufe
    • G G.Huber
      so was ?
      2024-07-06 10:46:00.008 - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 2416
      2024-07-06 10:46:00.400 - info: powerfox2.0 (2416) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.15.0, js-controller: 5.0.19
      2024-07-06 10:46:00.795 - info: powerfox2.0 (2416) Terminated (NO_ERROR): Without reason
      2024-07-06 10:46:01.307 - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2024-07-06 10:46:03.849 - info: javascript.0 (1064) script.js.common.SolarGesamt: getState(id=growatt.0.2233589.plantData.eTotal, timerId=undefined) => {"val":2300.1,"ack":true,"ts":1720255533443,"q":0,"from":"system.adapter.growatt.0","user":"system.user.admin","lc":1720255503763}
      2024-07-06 10:46:03.849 - info: javascript.0 (1064) script.js.common.SolarGesamt: getState(id=growatt.0.319898.plantData.eTotal, timerId=undefined) => {"val":5036.5,"ack":true,"ts":1720255563846,"q":0,"from":"system.adapter.growatt.0","user":"system.user.admin","lc":1720255563846}
      2024-07-06 10:46:03.849 - info: javascript.0 (1064) script.js.common.SolarGesamt: setForeignState(id=javascript.0.SolarGesamt, state={"val":7336.6,"ack":true,"ts":1720255563849,"q":0,"from":"system.adapter.javascript.0","lc":1720255563849,"c":"script.js.common.SolarGesamt"})
      2024-07-06 10:47:00.008 - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 2431
      2024-07-06 10:47:00.379 - info: powerfox2.0 (2431) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.15.0, js-controller: 5.0.19
      2024-07-06 10:47:01.222 - info: powerfox2.0 (2431) Terminated (NO_ERROR): Without reason
      2024-07-06 10:47:01.731 - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2024-07-06 10:47:43.672 - info: admin.0 (1037) ==> Connected system.user.admin from ::ffff:192.168.100.156
      2024-07-06 10:47:50.871 - info: admin.0 (1037) <== Disconnect system.user.admin from ::ffff:192.168.100.156
      2024-07-06 10:48:00.008 - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 2446
      2024-07-06 10:48:00.387 - info: powerfox2.0 (2446) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.15.0, js-controller: 5.0.19
      2024-07-06 10:48:00.827 - info: powerfox2.0 (2446) Terminated (NO_ERROR): Without reason
      2024-07-06 10:48:01.340 - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2024-07-06 10:48:05.429 - info: host.iobroker stopInstance system.adapter.growatt.0 (force=false, process=true)
      2024-07-06 10:48:05.431 - info: growatt.0 (2401) Got terminate signal TERMINATE_YOURSELF
      2024-07-06 10:48:05.437 - info: growatt.0 (2401) terminating
      2024-07-06 10:48:05.437 - info: growatt.0 (2401) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-07-06 10:48:05.473 - info: host.iobroker stopInstance system.adapter.growatt.0 send kill signal
      2024-07-06 10:48:05.939 - info: growatt.0 (2401) terminating
      2024-07-06 10:48:05.959 - info: host.iobroker instance system.adapter.growatt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-07-06 10:48:08.490 - info: host.iobroker instance system.adapter.growatt.0 started with pid 2461
      2024-07-06 10:48:08.708 - debug: growatt.0 (2461) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-07-06 10:48:08.727 - debug: growatt.0 (2461) Objects client ready ... initialize now
      2024-07-06 10:48:08.769 - debug: growatt.0 (2461) Objects create System PubSub Client
      2024-07-06 10:48:08.770 - debug: growatt.0 (2461) Objects create User PubSub Client
      2024-07-06 10:48:08.782 - debug: growatt.0 (2461) Objects client initialize lua scripts
      2024-07-06 10:48:08.783 - debug: growatt.0 (2461) Objects connected to redis: 127.0.0.1:9001
      2024-07-06 10:48:08.789 - debug: growatt.0 (2461) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-07-06 10:48:08.792 - debug: growatt.0 (2461) States create System PubSub Client
      2024-07-06 10:48:08.792 - debug: growatt.0 (2461) States create User PubSub Client
      2024-07-06 10:48:08.841 - debug: growatt.0 (2461) States connected to redis: 127.0.0.1:9000
      2024-07-06 10:48:08.852 - debug: growatt.0 (2461) Plugin sentry Initialize Plugin (enabled=true)
      2024-07-06 10:48:08.918 - info: growatt.0 (2461) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.growatt, node: v20.15.0, js-controller: 5.0.19
      2024-07-06 10:48:08.928 - debug: growatt.0 (2461) Schedule restart: */15 * */1 * *
      2024-07-06 10:48:08.964 - debug: growatt.0 (2461) Enter growattData, Param: sessionHold:true
      2024-07-06 10:48:08.964 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:08.964 - debug: growatt.0 (2461) Growatt new API
      2024-07-06 10:48:08.965 - debug: growatt.0 (2461) Growatt isConnected() : false
      2024-07-06 10:48:08.965 - debug: growatt.0 (2461) Growatt login with user and password
      2024-07-06 10:48:08.965 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.143 - debug: growatt.0 (2461) Growatt isConnected() : true
      2024-07-06 10:48:09.144 - debug: growatt.0 (2461) Growatt time for login : 180ms
      2024-07-06 10:48:09.145 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.203 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.270 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.336 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.427 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.537 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.639 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.739 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.814 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.910 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:09.982 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:10.083 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:10.158 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:10.309 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:10.377 - debug: growatt.0 (2461) Growatt time for allPlantData : 1233ms
      2024-07-06 10:48:10.410 - debug: growatt.0 (2461) Growatt time for parseData : 33ms
      2024-07-06 10:48:10.410 - debug: growatt.0 (2461) Leave growattData :1446ms
      2024-07-06 10:48:38.964 - debug: growatt.0 (2461) Enter growattData, Param: sessionHold:true
      2024-07-06 10:48:38.965 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:38.965 - debug: growatt.0 (2461) Growatt isConnected() : true
      2024-07-06 10:48:39.025 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.089 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.148 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.209 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.320 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.414 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.476 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.559 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.629 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.698 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.759 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:39.860 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:40.004 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:48:40.109 - debug: growatt.0 (2461) Growatt time for allPlantData : 1143ms
      2024-07-06 10:48:40.142 - debug: growatt.0 (2461) Growatt time for parseData : 33ms
      2024-07-06 10:48:40.142 - debug: growatt.0 (2461) Leave growattData :1177ms
      2024-07-06 10:49:00.009 - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 2476
      2024-07-06 10:49:00.356 - info: powerfox2.0 (2476) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.15.0, js-controller: 5.0.19
      2024-07-06 10:49:00.901 - info: powerfox2.0 (2476) Terminated (NO_ERROR): Without reason
      2024-07-06 10:49:01.410 - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2024-07-06 10:49:08.965 - debug: growatt.0 (2461) Enter growattData, Param: sessionHold:true
      2024-07-06 10:49:08.965 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:08.965 - debug: growatt.0 (2461) Growatt isConnected() : true
      2024-07-06 10:49:09.304 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:09.393 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:09.478 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:09.572 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:09.688 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:09.780 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:09.849 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:09.957 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:10.023 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:10.091 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:10.170 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:10.235 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:10.371 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:10.454 - debug: growatt.0 (2461) Growatt time for allPlantData : 1489ms
      2024-07-06 10:49:10.479 - debug: growatt.0 (2461) Growatt time for parseData : 25ms
      2024-07-06 10:49:10.480 - debug: growatt.0 (2461) Leave growattData :1515ms
      2024-07-06 10:49:38.965 - debug: growatt.0 (2461) Enter growattData, Param: sessionHold:true
      2024-07-06 10:49:38.965 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:38.965 - debug: growatt.0 (2461) Growatt isConnected() : true
      2024-07-06 10:49:39.064 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.133 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.222 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.287 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.397 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.480 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.578 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.642 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.740 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.823 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:39.913 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:40.006 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:40.190 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:49:40.258 - debug: growatt.0 (2461) Growatt time for allPlantData : 1293ms
      2024-07-06 10:49:40.280 - debug: growatt.0 (2461) Growatt time for parseData : 22ms
      2024-07-06 10:49:40.280 - debug: growatt.0 (2461) Leave growattData :1315ms
      2024-07-06 10:50:00.009 - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 2492
      2024-07-06 10:50:00.406 - info: powerfox2.0 (2492) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.15.0, js-controller: 5.0.19
      2024-07-06 10:50:01.319 - info: powerfox2.0 (2492) Terminated (NO_ERROR): Without reason
      2024-07-06 10:50:01.825 - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2024-07-06 10:50:08.965 - debug: growatt.0 (2461) Enter growattData, Param: sessionHold:true
      2024-07-06 10:50:08.965 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:08.965 - debug: growatt.0 (2461) Growatt isConnected() : true
      2024-07-06 10:50:09.029 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.099 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.159 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.251 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.365 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.436 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.497 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.600 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.684 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.750 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.809 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:09.903 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:10.072 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:10.158 - debug: growatt.0 (2461) Growatt time for allPlantData : 1193ms
      2024-07-06 10:50:10.181 - debug: growatt.0 (2461) Growatt time for parseData : 22ms
      2024-07-06 10:50:10.181 - debug: growatt.0 (2461) Leave growattData :1216ms
      2024-07-06 10:50:38.965 - debug: growatt.0 (2461) Enter growattData, Param: sessionHold:true
      2024-07-06 10:50:38.966 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:38.966 - debug: growatt.0 (2461) Growatt isConnected() : true
      2024-07-06 10:50:39.033 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.096 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.156 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.219 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.332 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.423 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.510 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.597 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.661 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.725 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.806 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:39.872 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:40.043 - debug: growatt.0 (2461) Enter lifeSignCallback 600000ms
      2024-07-06 10:50:40.115 - debug: growatt.0 (2461) Growatt time for allPlantData : 1149ms
      2024-07-06 10:50:40.131 - debug: growatt.0 (2461) Growatt time for parseData : 15ms
      2024-07-06 10:50:40.131 - debug: growatt.0 (2461) Leave growattData :1165ms
      2024-07-06 10:51:00.010 - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 2507
      2024-07-06 10:51:00.376 - info: powerfox2.0 (2507) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.15.0, js-controller: 5.0.19
      2024-07-06 10:51:01.418 - info: powerfox2.0 (2507) Terminated (NO_ERROR): Without reason
      2024-07-06 10:51:01.927 - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      PLCHome 0P Offline
      PLCHome 0P Offline
      PLCHome 0
      schrieb am zuletzt editiert von PLCHome 0
      #681
      @g-huber also ich kann hier wirklich Nix entdecken. Ich sehe das da ein Host.ioBroker den powerfox2.0 startet. Der Powerfox2.0 startet regelmäßig und beendet sich wieder. Growatt läuft
      • R Ray 1
        ich habe jetzt doch ein Problem in meinem Growatt Adapter.
        Bisher hatte ich zwei Anlage in der ShinePhone App.
        Nachdem ich eine neue Anlage mit einem Noah 2000 hinzugefügt habe, ist im Adapter wieder ein Fehler.
        Kann mir jemand helfen den Fehler zu beseitigen, ohne die neue Anlage mit dem Noah 2000 in der ShinePhoneApp bei Growatt zu löschen?
        growatt.0. 2024-07-05 21:58:59.713 error Growatt exception: Error: {"result":2}
        PLCHome 0P Offline
        PLCHome 0P Offline
        PLCHome 0
        #682
        @ray-1 der müsste eigentlich irgendwo im Log eine Fehlermeldung geworfen haben wenn der Adapter terminiert. Kann sein das die noch unter dem Adapter sondern im Controller zu finden ist. Es kann passieren das wenn Daten fehlen er versucht ins leere zu greifen.
        • PLCHome 0P PLCHome 0
          @ray-1 stelle bitte die Instanz auf debug und schau mal nach ob man da sieht was er zuletzt abgefragt hat.
          Ray 1
          #683
          @plchome-0 said in Test Adapter Growatt v3.2.0:
          Leider kann ich das nicht mehr loggen.
          Ich habe gestern Abend in der ShinePhoneApp bei der neuen Anlage (mit dem NOAH2000) den NEO Wechselrichter als Datenlogger hinzugefügt. Das war zwar etwas fummelig, hat aber funktioniert.
          Mit dem neuen NEO Datenlogger am NOAH2000 ging die Instanz des Adapters sofort wieder auf "grün" bei "Verbunden mit Gerät oder Dienst" und er hat den neuen Datenlogger (NEO) in den Pfad des NOAH im ioBroker bei dem Objekt growatt.0.2759122 als "devices" hinzugefügt.
          Da ist jetzt ein Datenlogger mit der Seriennummer des NEO Wechselrichters.
          Den Umstand mit dem gestörten "Verbunden mit Gerät oder Dienst" kann ich aber reproduzieren, wenn ich eine neue Anlage über die ShinePhoneApp anlege, die keinen Datenlogger hat. Dann bekomme ich den Fehler bei "Verbunden mit Gerät oder Dienst".
          Ray
          PLCHome 0P 1 Antwort Letzte Antwort
          • R Ray 1
            Ray
            PLCHome 0P Offline
            PLCHome 0P Offline
            PLCHome 0
            #684
            @ray-1 oder halt so…
            R 1 Antwort Letzte Antwort
            • G Offline
              G.Huber
              #685
              @thomas-braun sagte in Test Adapter Growatt v3.2.0:
              Scheduled
              ich habe jetzt auch nach deinem Vorschlag den Scheduler eingestellt. Das hatte ich vorher noch nie gemacht. Den Adapter nutze ich schon seit 2021. jetzt ist erst mal ruhe.
              Den Powerfox Adapter stell ich auch mal um. Der läuft auch schon seit 2021 so. Funktioniert aber.
              Vielleicht werden es auch immer mehr Adapter im laufe der Zeit. Obwohl die Leistung der der VM Maschine ausreichend sein sollte.
              Ich warte jetzt mal ab was so nach 24 Std. wieder passiert.
              Vielen dank für deine Hilfe. ich melde mich wieder und Berichte.
              Schönes WE
              • G Offline
                G.Huber
                #686
                die Anzahl an Adapter sollte doch nicht zu viel sein oder?
                  Ray 1
                  schrieb am zuletzt editiert von Ray 1
                  #687
                  Viele NOAH Besitzer nutzen diesen ohne den von Growatt empfohlenen NEO800 Wechselrichter. Die können dann keinen Datenloggen zuordnen. Das kann man dann auf meine Weise nicht beheben. Die müssten die leere Anlage in der ShinePhoneApp entfernen.
                  Ich bin aber super froh das du dir die Mühe mit dem Adapter gemacht hast und uns hilfst über den ioBroker an die Growatt Daten zu kommen. Danke =)
                  Die Fehlermeldung im Log war:
                  • mcm1957M mcm1957
                    @plchome-0
                    Wenn du prio update fürs stable willst erstell bitte PR u verlinken hierher bzw schreib Grund für prio rein.
                    Schalte gerne rasch durch in so Situationen.
                    PLCHome 0P Offline
                    PLCHome 0P Offline
                    PLCHome 0
                    #688
                    @mcm1957:
                    https://github.com/ioBroker/ioBroker.repositories/pull/3789#issuecomment-2212369413
                    Ich hoffe, die Version kommt schnell ins Prod Repro. Wir haben aber schon 163 Installationen der Beta.
                    Ergänzung:
                    Leider gibt es Fehler im Adapter, die der Adapter Prüfer vorher nicht angezeigt hat.
                    Bin mir auch nicht sicher, was die verlangte Änderung für den Adapter bedeutet.
                    Ich werde mich darum kümmern, wenn ich Zeit habe. Solange gibt es dann keine stabile Version mehr.
                    mcm1957M 2 Antworten Letzte Antwort
                      @mcm1957:
                      Ergänzung:
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #689
                      @plchome-0
                      Hab einen aussertourlichen Update gestartet.sollte in ca 30 min im Stable verfügbar sein.
                      @updatewillige
                      Bitte Button Nach Updates suchen im Admin klicken. Admin liest per default nur 1x täglich die Daten vom Server.
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                        @mcm1957:
                        Ergänzung:
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        #690
                        @plchome-0
                        Theres only one error. Most likely common.subscribe can be safely removed as you might already use the actual way to subscribe to the message Box.
                        Only very old adapters might still subscribe to states (!) this way and need Adaption to Code.
                          bkw-user
                          #691
                          Hallo in die Runde,
                          erstmal vielen Dank für den Growatt-Adapter und die viele Arbeit, die da drin steckt. Ich habe, wie einige hier die Kombination aus Growatt Neo und Noah2000 und nutze den Adapter in der Version 3.2.4 (im Moment die Aktuelle Version, glaube ich). Ich habe in der ShinePhone App den Datalogger des Neo800 angelegt. Im Online-Portal von Growatt (server.growatt.com) sehe ich die zwei Datalogger (DeviceTypes Noah: PPSWiFi-Noah2000 und Neo: ShineWeFi).
                          Der Adapter in ioBroker wird bei mir auch Grün angezeigt und erzeugt ein Objekt growatt.0.<PLANTID>.devices.<NAME_DES_NEO> mit den Daten des Neo-Wechselrichters an. Sprich man sieht was der gerade entsprechend der Einstellungen der ShinePhone-App von Wechselrichter produziert. Das ist schonmal super. :)
                          Vielleicht liege ich falsch und habe den Adapter nicht verstanden: Kann man am den Lade-Status und die tatsächlich am Noah anliegende PV-Leistung, Ladeleistung und Ladezustand auslesen?
                          Wenn ich in die Instanz des Adapters gehe, dann werden mir auch zwei Datalogger angezeigt. Und ich konnte darüber für beide auch die Data_updat_interval von fünf auf eine Minute ändern. Also scheint der Adapter grundsätzlich mit dem Noah zu kommunizieren. Kommen "nur" die Daten den Noah nicht in den Adapter? Oder muss ich eine zweite Instanz des Adapters anlegen?
                          Es wäre super, wenn man unter growatt.0.<PLANTID> die zwei Datalogger hätte. Ich hatte den Gedanken mit den Daten die Einstellung der ShineApp im Operation-Mode entsprechend der PV-Leistung, die am Noah anliegt und dem an andere stelle ermittelten Bedarf im Haus für "Load First" automatisiert einzustellen.
                          Vielleicht etwas viel verlangt ...
                          Vielen dank nochmal für den Adapter, die Arbeit und die Unterstützung.
                          • liv-in-skyL Offline
                            liv-in-skyL Offline
                            #692
                            habe überlegt, das hier zu bestellen https://www.actec-solar.de/balkonkraftwerke/growatt/830wp-balkonkraftwerk-set-trina-vertex-s-full-black-2kwh-speicher-600-800-watt-microwechselrichter_8856360_5147
                            ist das brauchbar und kann ich das in den adapter nutzen oder muss ich noch was dazubestellen
                            bin ziemlich ahnungslos und bräuchte kurzen input
                            • Chris0706C Offline
                              Chris0706C Offline
                              Chris0706
                              #693
                              Hab grad den Thread überflogen. Gehe ich richtig in der Annahme, dass man aktuell die Leistungsdaten eines Growatt Noah 2000 nicht direkt auslesen kann? Höchstens wenn man einen extra Datenlogger oder WR von Growatt hat?
                              • Chris0706C Chris0706
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #694
                                @chris0706 sagte in Test Adapter Growatt v3.2.0:
                                würd mich auch interessieren :-)
                                ich habe den adapter installiert , nutze noah 2000 und bekomme diesen fehler
                                growatt.0
                                2024-08-11 08:07:30.412	debug	Enter growattLogout
                                growatt.0
                                2024-08-11 08:07:30.411	error	Growatt exception: Error: {"result":2}
                                growatt.0
                                2024-08-11 08:07:30.343	debug	Enter lifeSignCallback 600000ms
                                growatt.0
                                2024-08-11 08:07:30.294	debug	Enter lifeSignCallback 600000ms
                                growatt.0
                                2024-08-11 08:07:30.239	debug	Enter lifeSignCallback 600000ms
                                growatt.0
                                2024-08-11 08:07:30.170	debug	Enter lifeSignCallback 600000ms
                                growatt.0
                                2024-08-11 08:07:30.096	debug	Enter lifeSignCallback 600000ms
                                growatt.0
                                2024-08-11 08:07:30.096	debug	Growatt time for login : 209ms
                                growatt.0
                                2024-08-11 08:07:30.096	debug	Growatt isConnected() : true
                                growatt.0
                                2024-08-11 08:07:29.888	debug	Enter lifeSignCallback 600000ms
                                growatt.0
                                2024-08-11 08:07:29.888	debug	Growatt login with user and password
                                growatt.0
                                2024-08-11 08:07:29.888	debug	Growatt isConnected() : false
                                wird der adapter noch gepflegt ? oder gibt es nur ein zeitproblem des entwicklers?
                                @Ray-1 habe versucht, einen datenlogger für den neo800m-x einzurichten - geht irgendwie nicht - hast du evtl einen tipp für mich
                                • liv-in-skyL liv-in-sky
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  growatt.0
                                  PLCHome 0P Offline
                                  PLCHome 0P Offline
                                  PLCHome 0
                                  #695
                                  @liv-in-sky sagte in Test Adapter Growatt v3.2.0:
                                  Ja
                                  Der Adapter ist ein Hack der Webseite, ich kann nur das umsetzen, was ich sehe oder andere ausprobiert haben. Ich habe für diesen Wechselrichtertyp leider keinen Zugriff. Daher habe ich es mir auch noch nicht angeschaut.
                                  Ihr könnt mir gerne ein Token über PN senden, dann schaue ich mir das gerne an.
                                    Ja
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #696
                                    @plchome-0
                                    das wäre sehr nett von dir
                                    nehme an du meinst mit token den api key
                                    leider verwirrt mich das system etwas - ich habe auf mqtt.growatt.com einen zugang und kann auch den noah sehen - unter ENERGY - plant management kann ich das ausführen
                                    anschliessend bekomme ich eine mail welche auf die adresse server.growatt.com zeigt - darin sieht das ganze anders aus und ich finde keinen api key - was mache ich da falsch ?
                                      @plchome-0
                                      PLCHome 0P Offline
                                      PLCHome 0P Offline
                                      PLCHome 0
                                      #697
                                      In der Adresse in der E-Mail steht ein Buchstabengewirr, das ist der Key zum Key login
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #698
                                        @plchome-0
                                        habe dir das in den chat gelegt - ist das das richtige
                                          @plchome-0
                                          PLCHome 0P Offline
                                          PLCHome 0P Offline
                                          PLCHome 0
                                          #699
                                          @liv-in-sky
                                          Da ist nicht viel, das wird ihn wohl aktuell stören :-)
                                          Aber die Historie des Speichers sehe ich. Mal schauen...
                                          Sollte da noch mehr sein oder nur der Speicher?
