  4. Test Adapter Philips-TV v0.2.x
    6.7k
philipsphilips tv
550 Beiträge 84 Kommentatoren 185.7k Aufrufe 48 Beobachtet
  • teletapiT teletapi
    @foxriver76
    Cannot parse json data: 192.168.178.136 console.ts:40:19
        ot console.ts:40
        _onClick ConfigSendto.tsx:221
        onClick ConfigSendto.tsx:346
        React 11
        r helpers.ts:98
    OK console.ts:40:19
    Error: Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=undefined&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
        React 20
        onClick ConfigSendto.tsx:344
        React 11
        r helpers.ts:98
    console.ts:40:19
        ot console.ts:40
        React 15
        React 11
        r helpers.ts:98
    teletapiT Offline
    teletapiT Offline
    teletapi
    schrieb am zuletzt editiert von teletapi
    #500
    So der Adapter ist endlich grün
    Der Fehler bzw. die Lösung....
    Ein einfaches " iob upload all" brachte das in Ordnung
    Danke für eure Mühe, hätte ich eigentlich auch schon früher drauf kommen können.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     01:33:11 up 15:12,  1 user,  load average: 1.32, 0.86, 0.90
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-12-25 01:33:11 CET
               Universal time: Mon 2023-12-25 00:33:11 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        3.0G        1.1G        1.0M        3.7G        4.7G
    Swap:            99M          0B         99M
    Total:          7.9G        3.0G        1.2G
             7811 M total memory
             3022 M used memory
             5054 M active memory
             1437 M inactive memory
             1067 M free memory
              184 M buffer memory
             3536 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   12G   45G  21% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
    [Sun Dec 24 10:20:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Dec 24 10:20:58 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Dec 24 10:20:58 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Dec 24 10:20:59 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.9G    /var/
    1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
    1.1G    /var/log
    629M    /var/lib
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    1.5G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    352M    /opt/iobroker/iobroker-data/
    183M    /opt/iobroker/iobroker-data/files
    76M     /opt/iobroker/iobroker-data/backup-objects
    71M     /opt/iobroker/iobroker-data/node-red/node_modules
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.9
    javascript:     7.5.1
    Adapters from github:   2
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
    + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.13.9   , installed 6.13.9
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.5   , installed 1.13.5
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iopooleco"    : 0.5.1    , installed 0.5.1
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
    Adapter    "javascript"   : 7.5.1    , installed 7.5.1
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 5.0.2    , installed 5.0.2
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
    Adapter    "shelly"       : 6.7.0    , installed 6.7.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        9665
    States:         9732
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       16204      1300/io.hm-rpc.1
    tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       16953      1317/io.hm-rpc.2
    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       2425281    140650/io.simple-ap
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18345      1486/io.sonoff.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       16919      1212/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        1999       559/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17227      1511/io.shelly.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30562      3094/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21874      1876/io.jarvis.0
    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       14136      1278/io.hm-rpc.0
    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       17963      1375/io.hm-rpc.3
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15623      656/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15141      656/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2228473    128643/cupsd
    tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       22276      1910/io.nuki.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      116        2000       559/mosquitto
    tcp6       0      0 :::22                   :::*                    LISTEN      0          30564      3094/sshd: /usr/sbi
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       2421701    140580/io.socketio.
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15452      549/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2351329    136052/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2426005    140522/io.web.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2228472    128643/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        15499      655/grafana
    udp        0      0 0.0.0.0:48065           0.0.0.0:*                           108        14876      400/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15056      464/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2226608    128646/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14874      400/avahi-daemon: r
    udp6       0      0 :::36425                :::*                                108        14877      400/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15086      464/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14875      400/avahi-daemon: r
    2023-12-25 01:22:52.333  - info: philips-tv.0 (141369) Got terminate signal TERMINATE_YOURSELF
    2023-12-25 01:22:52.451  - info: host.iobroker stopInstance system.adapter.philips-tv.0 send kill signal
    2023-12-25 01:22:52.518  - info: philips-tv.0 (141369) terminating
    2023-12-25 01:22:52.520  - info: philips-tv.0 (141369) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-25 01:22:52.839  - info: philips-tv.0 (141369) terminating
    2023-12-25 01:22:53.150  - info: host.iobroker instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-25 01:22:55.591  - info: host.iobroker instance system.adapter.philips-tv.0 started with pid 141384
    2023-12-25 01:22:58.922  - info: philips-tv.0 (141384) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.19.0, js-controller: 5.0.17
    2023-12-25 01:22:58.948  - info: philips-tv.0 (141384) Starting with ip "192.168.178.136" (API v6 - Android)
    2023-12-25 01:23:01.146  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
    2023-12-25 01:23:02.120  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.23
    2023-12-25 01:26:35.217  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
    2023-12-25 01:26:40.999  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.23
    2023-12-25 01:27:24.211  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
    2023-12-25 01:30:00.200  - info: host.iobroker instance system.adapter.ical.0 started with pid 142393
    2023-12-25 01:30:03.335  - info: ical.0 (142393) starting. Version 1.13.5 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
    2023-12-25 01:30:09.489  - info: ical.0 (142393) Terminated (NO_ERROR): Without reason
    2023-12-25 01:30:10.076  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-12-25 01:32:39.084  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.63
    2023-12-25 01:33:57.940  - info: web.0 (140522) ==> Connected system.user.admin from ::ffff:192.168.178.63
    2023-12-25 01:34:21.433  - info: web.0 (140522) <== Disconnect system.user.admin from ::ffff:192.168.178.63
    • L Offline
      ltsalvatore
      #501
      hey, erst mal danke, dass dieser adapter zur verfügung gestellt wird.
      ich habe gestern etwas damit rumgespielt und es scheint alles einwandfrei zu funktionieren.
      ich muss sagen, so toll ich meinen Philips - 65OLED807-12 finde so wahr ist es aber auch, dass das OS der letzte rotz ist. es ist tatsächlich so negativ wie alle im netz behaupten.
      hinzu kommt auch noch, dass der alexa skill alles andere als nützlich ist. wenig bis keine funktionen und was die zuverlässigkeit angeht, da kann man auch lotto spielen.
      hinzu kommt noch, dass es auch wirklich keine einzige funktionierende android app gibt, welche man als virtuelle tastatur hätte nutzen können.
      umso erfreulicher, dass ich mit dem adapter hier beides mir jetzt selbst mit VIS und IoT Adapter zusammenbasteln kann.
      und jetzt zu meiner eigentlichen frage.. hat jemand zufälligerweise einen bereits fertigen VIS, den er bereit ist zu teilen? 😊🙏🏾
      L 1 Antwort Letzte Antwort
      • L ltsalvatore
        L Online
        L Online
        Lucky_ESA
        #502
        @ltsalvatore Schau mal hier nach. Die sind zwar für LG aber das kann man ja ändern.
        Gruß//Lucky
        • P Offline
          PrinzVonBillAir
          #503
          Ich erhalte folgenden Fehler beim Versuch das TV (55PUS8808) zu pairen. Ich hatte das TV vor einigen Monaten (8-10) bereits mal gepaired, aber dann den Adapter zwischenzeitlich nochmal gelöscht und soeben wieder neu installiert. Nun erscheint nur folgende Fehlermeldung, auch bei den Protokollen kommt keine Meldung eines Fehlers, selbst bei Logstufe "Alles/Silly". Mir scheint es so, als dass überhaupt nichts an das TV gesendet wird und daher auch kein Pairing-Code angezeigt wird. Oder muss ich irgendwo im TV zuerst das alte Pairing löschen? Wenn ja, wo? Ich habe in den TV-Einstellungen bestimmt über eine Stunde jedes Untermenü durchsucht und finde nichts.
          R 1 Antwort Letzte Antwort
          • P PrinzVonBillAir
            RappiRN
            #504
            @prinzvonbillair
            Hast du zufällig auch vor ein paar Tagen ein Update am TV gemacht? Bei mir kamen die Fehlermeldungen just in dem Moment, wo der TV nach dem Update neu gestartet ist.
            Habe auch schon ne ganze Menge probiert, das letzte, was ich jetzt noch machen könnte, wäre ein Downgrade am TV.
            Das Pairen (des TV) an sich scheint zu funktionieren, eine App hat sich angemeldet und es wurde ein Code am TV angezeigt.
            Enrico
            • R RappiRN
              @prinzvonbillair
              Enrico
              RappiRN
              #505
              @rappirn
              Also den TV habe ich mal auf die vorherige Version zurückgesetzt, es hat nichts gebracht.
              Habe auch noch einmal alle Adapterversionen ab 0.3.0 versucht, auch ohne Erfolg. Heute Abend werde ich nochmal versuchen, die Adapterversionen jeweils mit einer kompletten Neuinstallation zu installieren.
              Was mir mal immer wieder aufgefallen ist. Meist kam die Fehlermeldung sofort und manchmal, vielleicht nach einer Installation oder einem Adapterneustart (das kann ich noch nicht genau sagen), dauert es einige Sekunden, bis die Fehlermeldung kommt. Leider gibt es im log keine brauchbaren Infos.
              Enrico
              • R RappiRN
                @rappirn
                Enrico
                Dimi
                #506
                @rappirn
                Ich habe das selbe Problem mit meinem TV. Beim Pairing kommt die Fehlermeldung "Unknown message payload for "Pairing": null". Ich habe das Modell 65OLED854 mit dem seit kurzem verfügbaren Android TV 11. Ich habe es mit der Version 0.5.3 und mit der 0.5.2 probiert.
                Dimi
                • D Dimi
                  @rappirn
                  Dimi
                  Adri525
                  #507
                  ich habe einen 65OLED935/12 Philips TV mit der aktuellsten Software und Android 11, welcher via LAN verbunden ist.
                  Ohne MAC Adresse für WOL wird der Adapter grün und funktioniert einwandfrei.
                  Ich möchte den Adapter aber nur nutzen um das Ambilght einschalten zu können und dazu benötige ich WOL. Sobald ich die MAC (welche in den Netzwerkeinstellungen vom TV steht / Ethernet MAC Adresse) eintrage wird der Adapter nicht mehr grün.
                  Anbei der Log:
                  2024-07-02 20:30:15.001 - debug: philips-tv.0 (12498) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2024-07-02 20:30:15.122 - debug: philips-tv.0 (12498) Objects client ready ... initialize now
                  2024-07-02 20:30:15.159 - debug: philips-tv.0 (12498) Objects create System PubSub Client
                  2024-07-02 20:30:15.162 - debug: philips-tv.0 (12498) Objects create User PubSub Client
                  2024-07-02 20:30:15.337 - debug: philips-tv.0 (12498) Objects client initialize lua scripts
                  2024-07-02 20:30:15.351 - debug: philips-tv.0 (12498) Objects connected to redis: 127.0.0.1:9001
                  2024-07-02 20:30:15.457 - debug: philips-tv.0 (12498) Redis States: Use Redis connection: 127.0.0.1:9000
                  2024-07-02 20:30:15.512 - debug: philips-tv.0 (12498) States create System PubSub Client
                  2024-07-02 20:30:15.514 - debug: philips-tv.0 (12498) States create User PubSub Client
                  2024-07-02 20:30:15.618 - debug: philips-tv.0 (12498) States connected to redis: 127.0.0.1:9000
                  2024-07-02 20:30:16.290 - info: philips-tv.0 (12498) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.20.2, js-controller: 5.0.19
                  2024-07-02 20:30:16.324 - info: philips-tv.0 (12498) Starting with ip "192.168.1.50" (API v6 - Android)
                  2024-07-02 20:30:16.331 - error: philips-tv.0 (12498) Cannot create API client Provided MAC is not an MAC Address!
                  Der Log sagt ja dass die MAC keine MAC Adresse ist.
                  Habe die MAC Adresse auch nochmal in meiner Unifi Dream Machine Pro geprüft, Sie stimmt...
                  Hat jemand eine Idee und kann mir helfen?
                  Vielen Dank im Voraus!
                  Adri
                  • A Adri525
                    Anbei der Log:
                    Adri
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #508
                    @adri525 sagte in Test Adapter Philips-TV v0.2.x:
                    die MAC Adresse
                    zeig mal die MAC welche Du im Adapter einträgst bitte.
                    Lehrling seit 1975 !!!
                    • DJMarc75D DJMarc75
                      die MAC Adresse
                      Adri525
                      #509
                      @djmarc75
                      • A Adri525
                        @djmarc75
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #510
                        @adri525 hmmm... copy paste mit Leerzeichen am Ende ?
                        Sonst passt das ja eigentlich.
                          Adri525
                          #511
                          @djmarc75
                          Nein, es ist kein Leerzeichen o.ä. drin.
                          Habe die MAC händisch eingetragen und nicht kopiert...
                          • A Adri525
                            @djmarc75
                            ltsalvatore
                            #512
                            @djmarc75
                            bei mir hab ich alles mit großbuchstaben drin.. wäre ein versuch wert.
                            • L ltsalvatore
                              @djmarc75
                              Adri525
                              #513
                              @ltsalvatore
                              Vielen Dank!!!!
                              Der Adapter wird jetzt Grün :)
                              Teste jetzt noch WOL, sollte aber alles funktionieren.
                              Nochmals VIELEN DANK!!!!
                              L A 2 Antworten Letzte Antwort
                              • A Adri525
                                @ltsalvatore
                                Vielen Dank!!!!
                                ltsalvatore
                                #514
                                @ltsalvatore
                                Vielen Dank!!!!
                                😊 freut mich zu hören
                                • A Adri525
                                  @ltsalvatore
                                  Vielen Dank!!!!
                                  Adri525
                                  schrieb am zuletzt editiert von Adri525
                                  #515
                                  @adri525
                                  zu früh gefreut...
                                  Nachdem der TV in den Standby/Deep Standby gegangen ist war die Verbindung weg.
                                  Dann wollte ich den Adapter erneut mit dem TV pairen, was zur Folge hatte dass die Fehlermeldung "Unknown message payload for "pairing": null" gekommen ist (egal ob mit oder ohne MAC).
                                  Habe den Adapter dann gelöscht und neu installiert, der Fehler bleibt bestehen und der TV lässt sich nicht mehr pairen.
                                  Anbei der Log:
                                  2024-07-02 21:05:56.034 - info: philips-tv.0 (16240) Got terminate signal TERMINATE_YOURSELF
                                  2024-07-02 21:05:56.034 - info: host.raspberrypi stopInstance system.adapter.philips-tv.0 send kill signal
                                  2024-07-02 21:05:56.327 - info: philips-tv.0 (16240) terminating
                                  2024-07-02 21:05:56.329 - info: philips-tv.0 (16240) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2024-07-02 21:05:56.540 - info: philips-tv.0 (16240) terminating
                                  2024-07-02 21:05:57.059 - info: host.raspberrypi instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-07-02 21:05:59.369 - info: host.raspberrypi instance system.adapter.philips-tv.0 started with pid 16383
                                  2024-07-02 21:06:03.027 - info: philips-tv.0 (16383) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.20.2, js-controller: 5.0.19
                                  2024-07-02 21:06:03.053 - info: philips-tv.0 (16383) Starting with ip "192.168.1.50" (API v6 - Android)
                                  2024-07-02 21:06:03.058 - warn: philips-tv.0 (16383) Please authenticate via the adapter configuration page
                                  • A Adri525
                                    @adri525
                                    zu früh gefreut...
                                    Anbei der Log:
                                    L Online
                                    L Online
                                    Lucky_ESA
                                    #516
                                    @adri525 Poste mal den Inhalt von http://192.168.1.50:1925/system
                                    • L Lucky_ESA
                                      Adri525
                                      #517
                                      @lucky_esa
                                      Guten Morgen,
                                      anbei der Post:
                                      {"notifyChange":"http","menulanguage":"German","name":"65OLED935/12","country":"Germany","serialnumber_encrypted":"IMtBPlUPvjuZu4MewNVZhwBRJh8gXJQjyTYELR/YvO8=\n","softwareversion_encrypted":"3HskqLZKXeO0F1/l82USBd5af7no8gjkw4ZHaPk+9TxPz0n0+9slqidyeDWGDxkV\n","model_encrypted":"BO8N4c0hC+zuAVaOLZ0tan48fgC0Y6CC86cdhJY3Dgw=\n","deviceid_encrypted":"TsaoGV/o5uVb3Da4nHIF6ZlTicH/IdXhQWnpXlIDelo=\n","nettvversion":"9.0.0","epgsource":"broadcast","api_version":{"Major":6,"Minor":4,"Patch":0},"featuring":{"jsonfeatures":{"editfavorites":["TVChannels","SatChannels"],"recordings":["List","Schedule","Manage"],"ambilight":["LoungeLight","Hue","Ambilight","HueStreaming"],"menuitems":["Setup_Menu"],"textentry":["not_available"],"applications":["TV_Apps","TV_Games","TV_Settings"],"pointer":["not_available"],"inputkey":["key"],"activities":["intent"],"channels":["preset_string"],"mappings":["server_mapping"]},"systemfeatures":{"tvtype":"consumer","content":["dmr","pvr"],"tvsearch":"intent","pairing_type":"digest_auth_pairing","secured_transport":"true","companion_screen":"true"}},"os_type":"MSAF_2019_P"}
                                      • A Adri525
                                        @lucky_esa
                                        Guten Morgen,
                                        anbei der Post:
                                        L Online
                                        L Online
                                        Lucky_ESA
                                        #518
                                        @adri525 Das sieht gut aus.
                                        Wahrscheinlich ist dein Problem eher ein Fall für @Thomas-Braun und iob diag
                                        Vorab gesagt: Die MAC muss immer Großbuchstaben haben und der PIN darf nur Zahlen beinhalten.
                                        Welchen Browser nutzt du, welche Admin Version hast du und bist du mit Windows oder Linux unterwegs?
                                        Du kannst nun mehrere Möglichkeiten ausprobieren:
                                        Adapter löschen: Bitte links Adapter auswählen, dann den Expertmodus aktivieren, den Adapter suchen und die Mülltonnenzeichen drücken. Danach in deiner Konsole das eingeben
                                        iob stop
                                        iob fix
                                        iob start
                                        Danach am besten deinen Cache vom Browser leeren und eine neu Instanz von philips-tv unter adpter hinzufügen. Jetzt dann bitte nur deine IP eintragen und den Pairing Button drücken.
                                        Kommt dann wieder deine Fehlermeldung dann bitte mal das probieren.
                                        Javascript Adapter installieren und 2 Javascripte anlegen.
                                        Das erst mit diesem Inhalt füllen..ggf. deine IP anpassen.
                                        sendTo("philips-tv.0", "pairing", "192.168.1.50"
                                        , async function (result) {
                                            console.log(result);
                                        In das 2te diesen Inhalt kopieren und speichern. Hier musst du später die 0000 mit dem Code auf deinem Fernseher ersetzen.
                                        sendTo("philips-tv.0", "submitPin", "0000"
                                        Nun starte das erste Script mit deiner IP und deaktiviere es nach 3 Sekunden. Hier sollte nun der Code in deinem Fernseher erscheinen (hoffentlich)
                                        Dann die 0000 mit den Code ersetzen und dieses Script starten und den Adapter NICHT neu starten.
                                        Was kannst du im Log sehen?
                                        Gruß//Lucky
                                        A P paradoxe SituationP 3 Antworten Letzte Antwort
                                          Michaelnorge
                                          #519
                                          Hier das gleiche Problem, mein Philips hat sich auf Android 11 upgedated und seitdem funktioniert der Addapter nicht mehr.
                                          Could not poll API: {"statusCode":401,"body":"<html>\n<head>\n <title>Status page</title>\n</head>\n<body style=\"font-family: sans-serif;\">\n<p style=\"font-size: 1.2em;font-weight: bold;margin: 1em 0px;\">Unauthorized</p>\n<p>The request requires user authentication</p>\n<p>You can get technical details <a href=\"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.4.2\">here</a>.<br>\nPlease continue your visit at our <a href=\"/\">home page</a>.\n</p>\n</body>\n</html>\n","headers":{"date":"Wed, 03 Jul 2024 17:18:57 GMT","accept-ranges":"bytes","server":"Restlet-Framework/2.3.12","www-authenticate":"Digest realm=\"XTV\", domain=\"/\", nonce=\"MTcyMDAyNzEzNzA1Njo2MDVkMzI3ZjM5ZjNhZTdiNTk0OTE5YzE2NWJkNzhhNQ==\", algorithm=MD5, qop=\"auth\"","content-length":"424","content-type":"text/html; charset=UTF-8"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.177:1926","port":"1926","hostname":"192.168.178.177","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"https://192.168.178.177:1926/6/audio/volume"},"method":"GET","headers":{"authorization":"Digest username=\"thdRK4quOUoh9nGV\", realm=\"XTV\", nonce=\"MTcyMDAyNzEzNzAzNzpiMWU5NjZiMzhmNDFiNjFhN2JiOTE1ZTUwOTE2MTkxMA==\", uri=\"/6/audio/volume\", qop=auth, response=\"79fbee052dd5e76eeb4566b828565e7b\", nc=00000001, cnonce=\"f609e2997c8c4f74a99a45fb2266d454\", algorithm=MD5","referer":"https://192.168.178.177:1926/6/audio/volume"}}}
                                          Das ist was im Log steht....
                                          • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
