  4. Test Adapter Philips-TV v0.2.x
    6.7k
philipsphilips tv
550 Beiträge 84 Kommentatoren 185.7k Aufrufe 48 Beobachtet
  • foxriver76F foxriver76
    @teletapi Version von Admin Adapter?
    teletapiT Offline
    teletapiT Offline
    teletapi
    #492
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     01:45:02 up 14:07,  1 user,  load average: 1.59, 1.29, 1.12
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2023-12-24 01:45:02 CET
               Universal time: Sun 2023-12-24 00:45:02 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        3.0G        1.7G        1.0M        3.2G        4.7G
    Swap:            99M          0B         99M
    Total:          7.9G        3.0G        1.8G
             7811 M total memory
             2970 M used memory
             4998 M active memory
              912 M inactive memory
             1675 M free memory
              167 M buffer memory
             2997 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   12G   45G  21% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
    [Sat Dec 23 11:37:42 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Dec 23 11:37:44 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Dec 23 11:37:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Dec 23 11:37:45 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.9G    /var/
    1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
    1.1G    /var/log
    628M    /var/lib
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    1.5G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    372M    /opt/iobroker/iobroker-data/
    183M    /opt/iobroker/iobroker-data/files
    76M     /opt/iobroker/iobroker-data/backup-objects
    71M     /opt/iobroker/iobroker-data/node-red/node_modules
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.5
    javascript:     7.5.1
    Adapters from github:   2
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.13.5   , installed 6.13.5
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.5   , installed 1.13.5
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iopooleco"    : 0.5.1    , installed 0.5.1
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
    Adapter    "javascript"   : 7.5.1    , installed 7.5.1
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 5.0.2    , installed 5.0.2
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
    Adapter    "shelly"       : 6.7.0    , installed 6.7.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        9596
    States:         9714
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 https://apt.grafana.com stable InRelease
    Hit:3 http://deb.debian.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Reading package lists...
    Pending Updates: 7
    *** Listening Ports ***
    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       16842      1387/io.hm-rpc.3
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       14234      1221/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        12847      564/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18865      1534/io.shelly.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18198      1474/io.sonoff.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2000314    115224/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13060      656/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13053      656/iobroker.js-con
    tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       23322      1938/io.nuki.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       22873      1758/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15021      576/sshd: /usr/sbin
    tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       17658      1308/io.hm-rpc.1
    tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       14317      1326/io.hm-rpc.2
    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       24048      1988/io.simple-api.
    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       16681      1291/io.hm-rpc.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      116        12848      564/mosquitto
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15023      576/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2000313    115224/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16018      919/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20323      1661/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24389      2205/io.socketio.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15743      545/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        12972      655/grafana
    udp        0      0 0.0.0.0:44417           0.0.0.0:*                           108        13617      402/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15076      468/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1999509    115229/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13615      402/avahi-daemon: r
    udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       2283435    1582/io.discovery.0
    udp6       0      0 :::546                  :::*                                0          15130      468/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13616      402/avahi-daemon: r
    udp6       0      0 :::55042                :::*                                108        13618      402/avahi-daemon: r
    2023-12-24 01:41:37.760  - info: discovery.0 (1582) Done discovering mdns devices. 39 packages received
    2023-12-24 01:41:37.973  - info: discovery.0 (1582) Done discovering upnp devices. 368 packages received
    2023-12-24 01:41:38.036  - info: discovery.0 (1582) Found 72 addresses
    2023-12-24 01:41:46.254  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:42:01.537  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:42:04.777  - warn: ping.0 (1243) State "ping.0.iobroker.192_168_178_57" has no existing object, this might lead to an error in future versions
    2023-12-24 01:42:16.786  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:42:31.826  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:42:47.100  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:43:01.739  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:43:16.645  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:43:31.506  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:43:46.532  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:44:01.295  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:44:15.865  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:44:16.636  - warn: ping.0 (1243) State "ping.0.iobroker.192_168_178_57" has no existing object, this might lead to an error in future versions
    2023-12-24 01:44:30.546  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:44:46.073  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:45:00.604  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:45:16.173  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:45:31.106  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:45:45.950  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-12-24 01:45:58.369  - info: discovery.0 (1582) Discovery finished. Found new or modified 28 instances
    2023-12-24 01:45:59.269  - info: discovery.0 (1582) Discovery finished
    2023-12-24 01:46:00.981  - info: tr-064.0 (1269) forEachConfiguredDevice: in GetSpecificHostEntry 29(Ahoy-DTU-Epaper-knickohr/08:3A:F2:B8:CB:A4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    iob diag has finished.
    Press any key for a summary
    • teletapiT teletapi
      @foxriver76 Soweit komme ich ja schon garnicht mehr das war tatsächlich bei den ersten versuchen alle per lan. Aber seid gestern Nachmittag bekomme ich nur noch das hier sobald ich den Pairing Pin bestätige dann aktualisiere ich die webseite vom iobroker der startet auch neu und habe keine weiteren fehler im log vom iobroker
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #493
      @teletapi dann mal F12 Browser Konsole öffnen und schauen was da für ein Error steht und hier posten.
      Videotutorials & mehr
      teletapiT 2 Antworten Letzte Antwort
        teletapiT Offline
        teletapiT Offline
        teletapi
        #494
        @foxriver76 Danke für deine Hilfe mach ich aber morgen vormittag, für heute muss gut sein
          teletapiT Offline
          teletapiT Offline
          teletapi
          schrieb am zuletzt editiert von teletapi
          #495
          @foxriver76
          So jetzt mal den Fehler aus der Konsole, das ist jetzt Lan die IP mit der .136 am ende
          Cannot parse json data: 192.168.178.136 console.ts:40:19
          OK console.ts:40:19
          Error: Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=undefined&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings
          Und noch ein IOB Diag
          ```Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
           11:02:46 up 41 min,  1 user,  load average: 0.79, 0.77, 0.90
          CPU threads: 4
          Current issues:
                         Local time: Sun 2023-12-24 11:02:46 CET
                     Universal time: Sun 2023-12-24 10:02:46 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        2.4G        3.8G        1.0M        1.6G        5.3G
          Swap:            99M          0B         99M
          Total:          7.9G        2.4G        3.9G
                   7811 M total memory
                   2368 M used memory
                   3396 M active memory
                    412 M inactive memory
                   3826 M free memory
                    130 M buffer memory
                   1486 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          [Sun Dec 24 10:20:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Sun Dec 24 10:20:58 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Dec 24 10:20:58 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Sun Dec 24 10:20:59 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          /var:
          1.9G    /var/
          1.1G    /var/log
          631M    /var/lib
          366M    /opt/iobroker/iobroker-data/
          24M     /opt/iobroker/iobroker-data/objects.jsonl
          8.8M    /opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.13.5
          javascript:     7.5.1
          Adapter State
          + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
          + instance is alive
          Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
          Objects and States
          Objects:        9657
          States:         9725
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       16204      1300/io.hm-rpc.1
          tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       16953      1317/io.hm-rpc.2
          tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       24647      2135/io.simple-api.
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18345      1486/io.sonoff.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       16919      1212/node-red
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        1999       559/mosquitto
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17227      1511/io.shelly.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30562      3094/sshd: /usr/sbi
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21874      1876/io.jarvis.0
          tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       14136      1278/io.hm-rpc.0
          tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       17963      1375/io.hm-rpc.3
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15623      656/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15141      656/iobroker.js-con
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13693      541/cupsd
          tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       22276      1910/io.nuki.0
          tcp6       0      0 :::1883                 :::*                    LISTEN      116        2000       559/mosquitto
          tcp6       0      0 :::22                   :::*                    LISTEN      0          30564      3094/sshd: /usr/sbi
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23340      2184/io.socketio.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        15452      549/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13912      849/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20044      1638/io.web.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13692      541/cupsd
          tcp6       0      0 :::3000                 :::*                    LISTEN      117        15499      655/grafana
          udp        0      0 0.0.0.0:48065           0.0.0.0:*                           108        14876      400/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15056      464/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2012       614/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14874      400/avahi-daemon: r
          udp6       0      0 :::36425                :::*                                108        14877      400/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          15086      464/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14875      400/avahi-daemon: r
          2023-12-24 10:59:56.141  - debug: philips-tv.0 (9316) Objects client ready ... initialize now
          2023-12-24 10:59:56.144  - debug: philips-tv.0 (9316) Objects create System PubSub Client
          2023-12-24 10:59:56.145  - debug: philips-tv.0 (9316) Objects create User PubSub Client
          2023-12-24 10:59:56.228  - debug: philips-tv.0 (9316) Objects client initialize lua scripts
          2023-12-24 10:59:56.237  - debug: philips-tv.0 (9316) Objects connected to redis: 127.0.0.1:9001
          2023-12-24 10:59:56.241  - silly: philips-tv.0 (9316) redis psubscribe cfg.o.system.user.*
          2023-12-24 10:59:56.291  - silly: philips-tv.0 (9316) redis psubscribe cfg.o.enum.*
          2023-12-24 10:59:56.294  - silly: philips-tv.0 (9316) objectDB connected
          2023-12-24 10:59:56.298  - debug: philips-tv.0 (9316) Redis States: Use Redis connection: 127.0.0.1:9000
          2023-12-24 10:59:56.329  - debug: philips-tv.0 (9316) States create System PubSub Client
          2023-12-24 10:59:56.331  - debug: philips-tv.0 (9316) States create User PubSub Client
          2023-12-24 10:59:56.428  - debug: philips-tv.0 (9316) States connected to redis: 127.0.0.1:9000
          2023-12-24 10:59:56.429  - silly: philips-tv.0 (9316) statesDB connected
          2023-12-24 10:59:57.343  - info: philips-tv.0 (9316) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.19.0, js-controller: 5.0.17
          2023-12-24 10:59:57.379  - info: philips-tv.0 (9316) Starting with ip "192.168.178.136" (API v6 - Android)
          2023-12-24 10:59:57.387  - warn: philips-tv.0 (9316) Please authenticate via the adapter configuration page
          2023-12-24 10:59:57.416  - silly: philips-tv.0 (9316) States system redis pmessage system.adapter.philips-tv.0.logLevel/system.adapter.philips-tv.0.logLevel:{"val":"silly","ack":true,"ts":1703411997391,"q":0,"from":"system.adapter.philips-tv.0","lc":1703411997391}
          2023-12-24 11:00:00.163  - info: host.iobroker instance system.adapter.ical.0 started with pid 9335
          2023-12-24 11:00:03.622  - info: ical.0 (9335) starting. Version 1.13.5 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
          2023-12-24 11:00:09.909  - info: ical.0 (9335) Terminated (NO_ERROR): Without reason
          2023-12-24 11:00:10.444  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          L foxriver76F 2 Antworten Letzte Antwort
            @foxriver76
            OK console.ts:40:19
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                     2368 M used memory
                     3826 M free memory
                      130 M buffer memory
                     1486 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            1.9G    /var/
            1.1G    /var/log
            631M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.13.5
            javascript:     7.5.1
            Adapter State
            + instance is alive
            Objects and States
            Objects:        9657
            States:         9725
            Pending Updates: 0
            L Online
            L Online
            Lucky_ESA
            #496
            @teletapi Du must in der Instanzen Ansicht erst den Adapter aktivieren und dann in den Instanz EInstellungen die Pin eingeben.
            teletapiT 1 Antwort Letzte Antwort
            • L Lucky_ESA
              teletapiT Offline
              teletapiT Offline
              teletapi
              #497
              @lucky_esa Das versteh ich jetzt nicht, ohne das der Adapter aktiv ist ist doch der Button zum Pairen garnicht aktiv.
              Wenn ich auf Pairing starten gehe, kommt am Fernsehn der Pin den geb ich ein und gehe auf Pin bestätigen, im gleichen Moment stürzt der Adapter ab
              Aber das spielt auch keine Rolle der Adapter stürzt immer ab,egal ob ich einen Pin eingebe oder nicht sobald ich auf Pin bestätigen drücke wars das.
                @foxriver76
                OK console.ts:40:19
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         7811 M total memory
                         2368 M used memory
                         3826 M free memory
                          130 M buffer memory
                         1486 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.9G    /var/
                1.1G    /var/log
                631M    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.13.5
                javascript:     7.5.1
                Adapter State
                + instance is alive
                Objects and States
                Objects:        9657
                States:         9725
                Pending Updates: 0
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                #498
                @teletapi probier mal bitte während die Konsole offen ist den Error zu provozieren, evtl. wird die Meldung dann etwas aufschlussreicher.
                  teletapiT Offline
                  teletapiT Offline
                  teletapi
                  #499
                  @foxriver76
                      ot console.ts:40
                      _onClick ConfigSendto.tsx:221
                      onClick ConfigSendto.tsx:346
                      React 11
                      r helpers.ts:98
                  OK console.ts:40:19
                  Error: Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=undefined&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
                      React 20
                      onClick ConfigSendto.tsx:344
                      React 11
                      r helpers.ts:98
                  console.ts:40:19
                      ot console.ts:40
                      React 15
                      React 11
                      r helpers.ts:98
                    @foxriver76
                        ot console.ts:40
                        React 11
                        r helpers.ts:98
                    OK console.ts:40:19
                        React 20
                        React 11
                        r helpers.ts:98
                    console.ts:40:19
                        ot console.ts:40
                        React 15
                        React 11
                        r helpers.ts:98
                    teletapiT Offline
                    teletapiT Offline
                    teletapi
                    #500
                    So der Adapter ist endlich grün
                    Der Fehler bzw. die Lösung....
                    Ein einfaches " iob upload all" brachte das in Ordnung
                    Danke für eure Mühe, hätte ich eigentlich auch schon früher drauf kommen können.
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     01:33:11 up 15:12,  1 user,  load average: 1.32, 0.86, 0.90
                    CPU threads: 4
                    Current issues:
                                   Local time: Mon 2023-12-25 01:33:11 CET
                               Universal time: Mon 2023-12-25 00:33:11 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            7.8G        3.0G        1.1G        1.0M        3.7G        4.7G
                    Swap:            99M          0B         99M
                    Total:          7.9G        3.0G        1.2G
                             7811 M total memory
                             3022 M used memory
                             5054 M active memory
                             1437 M inactive memory
                             1067 M free memory
                              184 M buffer memory
                             3536 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.9G    /var/
                    1.1G    /var/log
                    629M    /var/lib
                    352M    /opt/iobroker/iobroker-data/
                    14M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.13.9
                    javascript:     7.5.1
                    Adapter State
                    + instance is alive
                    Adapter    "admin"        : 6.13.9   , installed 6.13.9
                    Objects and States
                    Objects:        9665
                    States:         9732
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Pending Updates: 0
                    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       2425281    140650/io.simple-ap
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2228473    128643/cupsd
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       2421701    140580/io.socketio.
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2351329    136052/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2426005    140522/io.web.0
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2228472    128643/cupsd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2226608    128646/cups-browsed
                    2023-12-25 01:22:52.333  - info: philips-tv.0 (141369) Got terminate signal TERMINATE_YOURSELF
                    2023-12-25 01:22:52.451  - info: host.iobroker stopInstance system.adapter.philips-tv.0 send kill signal
                    2023-12-25 01:22:52.518  - info: philips-tv.0 (141369) terminating
                    2023-12-25 01:22:52.520  - info: philips-tv.0 (141369) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-12-25 01:22:52.839  - info: philips-tv.0 (141369) terminating
                    2023-12-25 01:22:53.150  - info: host.iobroker instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-12-25 01:22:55.591  - info: host.iobroker instance system.adapter.philips-tv.0 started with pid 141384
                    2023-12-25 01:22:58.922  - info: philips-tv.0 (141384) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.19.0, js-controller: 5.0.17
                    2023-12-25 01:22:58.948  - info: philips-tv.0 (141384) Starting with ip "192.168.178.136" (API v6 - Android)
                    2023-12-25 01:23:01.146  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
                    2023-12-25 01:23:02.120  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.23
                    2023-12-25 01:26:35.217  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
                    2023-12-25 01:26:40.999  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.23
                    2023-12-25 01:27:24.211  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
                    2023-12-25 01:30:00.200  - info: host.iobroker instance system.adapter.ical.0 started with pid 142393
                    2023-12-25 01:30:03.335  - info: ical.0 (142393) starting. Version 1.13.5 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                    2023-12-25 01:30:09.489  - info: ical.0 (142393) Terminated (NO_ERROR): Without reason
                    2023-12-25 01:30:10.076  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-12-25 01:32:39.084  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.63
                    2023-12-25 01:33:57.940  - info: web.0 (140522) ==> Connected system.user.admin from ::ffff:192.168.178.63
                    2023-12-25 01:34:21.433  - info: web.0 (140522) <== Disconnect system.user.admin from ::ffff:192.168.178.63
                    • L Offline
                      ltsalvatore
                      #501
                      hey, erst mal danke, dass dieser adapter zur verfügung gestellt wird.
                      ich habe gestern etwas damit rumgespielt und es scheint alles einwandfrei zu funktionieren.
                      ich muss sagen, so toll ich meinen Philips - 65OLED807-12 finde so wahr ist es aber auch, dass das OS der letzte rotz ist. es ist tatsächlich so negativ wie alle im netz behaupten.
                      hinzu kommt auch noch, dass der alexa skill alles andere als nützlich ist. wenig bis keine funktionen und was die zuverlässigkeit angeht, da kann man auch lotto spielen.
                      hinzu kommt noch, dass es auch wirklich keine einzige funktionierende android app gibt, welche man als virtuelle tastatur hätte nutzen können.
                      umso erfreulicher, dass ich mit dem adapter hier beides mir jetzt selbst mit VIS und IoT Adapter zusammenbasteln kann.
                      und jetzt zu meiner eigentlichen frage.. hat jemand zufälligerweise einen bereits fertigen VIS, den er bereit ist zu teilen? 😊🙏🏾
                      L 1 Antwort Letzte Antwort
                      • L ltsalvatore
                        L Online
                        L Online
                        Lucky_ESA
                        #502
                        @ltsalvatore Schau mal hier nach. Die sind zwar für LG aber das kann man ja ändern.
                        Gruß//Lucky
                        • P Offline
                          PrinzVonBillAir
                          #503
                          Ich erhalte folgenden Fehler beim Versuch das TV (55PUS8808) zu pairen. Ich hatte das TV vor einigen Monaten (8-10) bereits mal gepaired, aber dann den Adapter zwischenzeitlich nochmal gelöscht und soeben wieder neu installiert. Nun erscheint nur folgende Fehlermeldung, auch bei den Protokollen kommt keine Meldung eines Fehlers, selbst bei Logstufe "Alles/Silly". Mir scheint es so, als dass überhaupt nichts an das TV gesendet wird und daher auch kein Pairing-Code angezeigt wird. Oder muss ich irgendwo im TV zuerst das alte Pairing löschen? Wenn ja, wo? Ich habe in den TV-Einstellungen bestimmt über eine Stunde jedes Untermenü durchsucht und finde nichts.
                          R 1 Antwort Letzte Antwort
                          • P PrinzVonBillAir
                            RappiRN
                            #504
                            @prinzvonbillair
                            Hast du zufällig auch vor ein paar Tagen ein Update am TV gemacht? Bei mir kamen die Fehlermeldungen just in dem Moment, wo der TV nach dem Update neu gestartet ist.
                            Habe auch schon ne ganze Menge probiert, das letzte, was ich jetzt noch machen könnte, wäre ein Downgrade am TV.
                            Das Pairen (des TV) an sich scheint zu funktionieren, eine App hat sich angemeldet und es wurde ein Code am TV angezeigt.
                            Enrico
                            • R RappiRN
                              @prinzvonbillair
                              Enrico
                              RappiRN
                              #505
                              @rappirn
                              Also den TV habe ich mal auf die vorherige Version zurückgesetzt, es hat nichts gebracht.
                              Habe auch noch einmal alle Adapterversionen ab 0.3.0 versucht, auch ohne Erfolg. Heute Abend werde ich nochmal versuchen, die Adapterversionen jeweils mit einer kompletten Neuinstallation zu installieren.
                              Was mir mal immer wieder aufgefallen ist. Meist kam die Fehlermeldung sofort und manchmal, vielleicht nach einer Installation oder einem Adapterneustart (das kann ich noch nicht genau sagen), dauert es einige Sekunden, bis die Fehlermeldung kommt. Leider gibt es im log keine brauchbaren Infos.
                              Enrico
                              • R RappiRN
                                @rappirn
                                Enrico
                                Dimi
                                #506
                                @rappirn
                                Ich habe das selbe Problem mit meinem TV. Beim Pairing kommt die Fehlermeldung "Unknown message payload for "Pairing": null". Ich habe das Modell 65OLED854 mit dem seit kurzem verfügbaren Android TV 11. Ich habe es mit der Version 0.5.3 und mit der 0.5.2 probiert.
                                Dimi
                                • D Dimi
                                  @rappirn
                                  Dimi
                                  Adri525
                                  #507
                                  ich habe einen 65OLED935/12 Philips TV mit der aktuellsten Software und Android 11, welcher via LAN verbunden ist.
                                  Ohne MAC Adresse für WOL wird der Adapter grün und funktioniert einwandfrei.
                                  Ich möchte den Adapter aber nur nutzen um das Ambilght einschalten zu können und dazu benötige ich WOL. Sobald ich die MAC (welche in den Netzwerkeinstellungen vom TV steht / Ethernet MAC Adresse) eintrage wird der Adapter nicht mehr grün.
                                  Anbei der Log:
                                  2024-07-02 20:30:15.001 - debug: philips-tv.0 (12498) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2024-07-02 20:30:15.122 - debug: philips-tv.0 (12498) Objects client ready ... initialize now
                                  2024-07-02 20:30:15.159 - debug: philips-tv.0 (12498) Objects create System PubSub Client
                                  2024-07-02 20:30:15.162 - debug: philips-tv.0 (12498) Objects create User PubSub Client
                                  2024-07-02 20:30:15.337 - debug: philips-tv.0 (12498) Objects client initialize lua scripts
                                  2024-07-02 20:30:15.351 - debug: philips-tv.0 (12498) Objects connected to redis: 127.0.0.1:9001
                                  2024-07-02 20:30:15.457 - debug: philips-tv.0 (12498) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2024-07-02 20:30:15.512 - debug: philips-tv.0 (12498) States create System PubSub Client
                                  2024-07-02 20:30:15.514 - debug: philips-tv.0 (12498) States create User PubSub Client
                                  2024-07-02 20:30:15.618 - debug: philips-tv.0 (12498) States connected to redis: 127.0.0.1:9000
                                  2024-07-02 20:30:16.290 - info: philips-tv.0 (12498) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.20.2, js-controller: 5.0.19
                                  2024-07-02 20:30:16.324 - info: philips-tv.0 (12498) Starting with ip "192.168.1.50" (API v6 - Android)
                                  2024-07-02 20:30:16.331 - error: philips-tv.0 (12498) Cannot create API client Provided MAC is not an MAC Address!
                                  Der Log sagt ja dass die MAC keine MAC Adresse ist.
                                  Habe die MAC Adresse auch nochmal in meiner Unifi Dream Machine Pro geprüft, Sie stimmt...
                                  Hat jemand eine Idee und kann mir helfen?
                                  Vielen Dank im Voraus!
                                  Adri
                                  • A Adri525
                                    Anbei der Log:
                                    Adri
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #508
                                    @adri525 sagte in Test Adapter Philips-TV v0.2.x:
                                    die MAC Adresse
                                    zeig mal die MAC welche Du im Adapter einträgst bitte.
                                    Lehrling seit 1975 !!!
                                    • DJMarc75D DJMarc75
                                      die MAC Adresse
                                      Adri525
                                      #509
                                      @djmarc75
                                      • A Adri525
                                        @djmarc75
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #510
                                        @adri525 hmmm... copy paste mit Leerzeichen am Ende ?
                                        Sonst passt das ja eigentlich.
                                          Adri525
                                          #511
                                          @djmarc75
                                          Nein, es ist kein Leerzeichen o.ä. drin.
                                          Habe die MAC händisch eingetragen und nicht kopiert...
