  4. Test Adapter Grünbeck v0.0.x
    1.0k
gruenbeckgrünbecksc18sc23
508 Beiträge 58 Kommentatoren 153.7k Aufrufe 53 Beobachtet
  • da_WoodyD da_Woody
    @fbueller76 nuja, ich glaub, du hast in der config einen fehler...
    sind das 2 SD anlagen? oder SC?
    mit den verkrüppelten screenshots und logs kann man nichts sagen.
    fbueller76
    schrieb am zuletzt editiert von fbueller76
    #482
    @da_woody
    Ja es handelt sich um zwei SD23
    2024-04-28 14:22:09.203 - info: gruenbeck.0 (1584) Websocket closed
    2024-04-28 14:22:09.473 - error: gruenbeck.0 (1584) https://prod-eu-gruenbeck-api.azurewebsites.net/api/devices/softliQ.D/BS60013877/realtime/leave?api-version=2020-08-03
    2024-04-28 14:22:09.473 - error: gruenbeck.0 (1584) AxiosError: Request failed with status code 500
    2024-04-28 14:22:09.474 - error: gruenbeck.0 (1584) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-28 14:22:09.474 - error: gruenbeck.0 (1584) unhandled promise rejection: undefined
    2024-04-28 14:22:09.679 - info: gruenbeck.0 (1584) terminating
    2024-04-28 14:22:09.708 - info: host.ips instance system.adapter.gruenbeck.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2024-04-28 14:22:09.708 - info: host.ips Do not restart adapter system.adapter.gruenbeck.0 because desired by instance
    2024-04-28 14:22:10.298 - info: host.ips iobroker exit 0
    2024-04-28 14:22:41.871 - info: host.ips iobroker add gruenbeck --host ips
    2024-04-28 14:22:43.262 - info: host.ips iobroker upload [5] gruenbeck.admin C:/ioBroker/node_modules/iobroker.gruenbeck/admin/admin.d.ts admin.d.ts video/mp2t
    2024-04-28 14:22:43.271 - info: host.ips iobroker upload [4] gruenbeck.admin C:/ioBroker/node_modules/iobroker.gruenbeck/admin/gruenbeck.png gruenbeck.png image/png
    2024-04-28 14:22:43.276 - info: host.ips iobroker upload [3] gruenbeck.admin C:/ioBroker/node_modules/iobroker.gruenbeck/admin/icon.png icon.png image/png
    2024-04-28 14:22:43.281 - info: host.ips iobroker upload [2] gruenbeck.admin C:/ioBroker/node_modules/iobroker.gruenbeck/admin/index_m.html index_m.html text/html
    2024-04-28 14:22:43.287 - info: host.ips iobroker upload [1] gruenbeck.admin C:/ioBroker/node_modules/iobroker.gruenbeck/admin/style.css style.css text/css
    2024-04-28 14:22:43.291 - info: host.ips iobroker upload [0] gruenbeck.admin C:/ioBroker/node_modules/iobroker.gruenbeck/admin/words.js words.js application/javascript
    2024-04-28 14:22:43.305 - info: host.ips iobroker host.ips create instance gruenbeck
    2024-04-28 14:22:43.312 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.alive created
    2024-04-28 14:22:43.315 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.connected created
    2024-04-28 14:22:43.318 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.compactMode created
    2024-04-28 14:22:43.321 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.cpu created
    2024-04-28 14:22:43.324 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.cputime created
    2024-04-28 14:22:43.328 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.memHeapUsed created
    2024-04-28 14:22:43.330 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.memHeapTotal created
    2024-04-28 14:22:43.333 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.memRss created
    2024-04-28 14:22:43.339 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.uptime created
    2024-04-28 14:22:43.342 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.inputCount created
    2024-04-28 14:22:43.345 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.outputCount created
    2024-04-28 14:22:43.348 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.eventLoopLag created
    2024-04-28 14:22:43.350 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.sigKill created
    2024-04-28 14:22:43.353 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0.logLevel created
    2024-04-28 14:22:43.355 - info: host.ips iobroker host.ips object gruenbeck.0.parameter created
    2024-04-28 14:22:43.359 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_D_1 created
    2024-04-28 14:22:43.361 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_A_4_1 created
    2024-04-28 14:22:43.364 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_A_4_2 created
    2024-04-28 14:22:43.366 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_A_4_3 created
    2024-04-28 14:22:43.368 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_1_1 created
    2024-04-28 14:22:43.371 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_2_1 created
    2024-04-28 14:22:43.373 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_5_1 created
    2024-04-28 14:22:43.375 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_4_1 created
    2024-04-28 14:22:43.378 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_4_2 created
    2024-04-28 14:22:43.380 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_4_3 created
    2024-04-28 14:22:43.382 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_6_1 created
    2024-04-28 14:22:43.385 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_7_1 created
    2024-04-28 14:22:43.387 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_B_1 created
    2024-04-28 14:22:43.390 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_M_3_3 created
    2024-04-28 14:22:43.393 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.resetSalz created
    2024-04-28 14:22:43.395 - info: host.ips iobroker host.ips object gruenbeck.0.info.connection created
    2024-04-28 14:22:43.397 - info: host.ips iobroker host.ips object gruenbeck.0.info created
    2024-04-28 14:22:43.399 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_A_2_2 created
    2024-04-28 14:22:43.402 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_A_2_3 created
    2024-04-28 14:22:43.404 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_8_2 created
    2024-04-28 14:22:43.408 - info: host.ips iobroker host.ips object gruenbeck.0.parameter.D_C_8_1 created
    2024-04-28 14:22:43.410 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_5 created
    2024-04-28 14:22:43.413 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_7 created
    2024-04-28 14:22:43.415 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_6 created
    2024-04-28 14:22:43.418 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_8_11 created
    2024-04-28 14:22:43.420 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_10_1 created
    2024-04-28 14:22:43.423 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_B_1 created
    2024-04-28 14:22:43.426 - info: host.ips iobroker host.ips object gruenbeck.0.network created
    2024-04-28 14:22:43.428 - info: host.ips iobroker host.ips object gruenbeck.0.network.D_C_3_6_1 created
    2024-04-28 14:22:43.431 - info: host.ips iobroker host.ips object gruenbeck.0.network.D_C_3_6_2 created
    2024-04-28 14:22:43.434 - info: host.ips iobroker host.ips object gruenbeck.0.network.D_C_3_6_3 created
    2024-04-28 14:22:43.438 - info: host.ips iobroker host.ips object gruenbeck.0.network.D_C_3_6_4 created
    2024-04-28 14:22:43.440 - info: host.ips iobroker host.ips object gruenbeck.0.network.D_C_3_6_5 created
    2024-04-28 14:22:43.443 - info: host.ips iobroker host.ips object gruenbeck.0.network.D_C_3_7_1 created
    2024-04-28 14:22:43.448 - info: host.ips iobroker host.ips object gruenbeck.0.network.D_C_3_7_2 created
    2024-04-28 14:22:43.450 - info: host.ips iobroker host.ips object gruenbeck.0.network.D_C_3_7_3 created
    2024-04-28 14:22:43.453 - info: host.ips iobroker host.ips object gruenbeck.0.error created
    2024-04-28 14:22:43.455 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_1 created
    2024-04-28 14:22:43.458 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_2 created
    2024-04-28 14:22:43.461 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_3 created
    2024-04-28 14:22:43.463 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_4 created
    2024-04-28 14:22:43.466 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_5 created
    2024-04-28 14:22:43.468 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_6 created
    2024-04-28 14:22:43.472 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_7 created
    2024-04-28 14:22:43.475 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_8 created
    2024-04-28 14:22:43.477 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_9 created
    2024-04-28 14:22:43.479 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_10 created
    2024-04-28 14:22:43.482 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_11 created
    2024-04-28 14:22:43.485 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_12 created
    2024-04-28 14:22:43.488 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_13 created
    2024-04-28 14:22:43.491 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_14 created
    2024-04-28 14:22:43.493 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_15 created
    2024-04-28 14:22:43.496 - info: host.ips iobroker host.ips object gruenbeck.0.error.D_K_10_16 created
    2024-04-28 14:22:43.498 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_A_1_1 created
    2024-04-28 14:22:43.501 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_A_1_2 created
    2024-04-28 14:22:43.505 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_A_1_3 created
    2024-04-28 14:22:43.507 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_A_2_1 created
    2024-04-28 14:22:43.510 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_A_3_1 created
    2024-04-28 14:22:43.513 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_A_3_2 created
    2024-04-28 14:22:43.516 - info: host.ips iobroker host.ips object gruenbeck.0.calculated created
    2024-04-28 14:22:43.520 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.newError created
    2024-04-28 14:22:43.523 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.schleichWasserAlarm created
    2024-04-28 14:22:43.525 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.allWaterJSON created
    2024-04-28 14:22:43.528 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.allErrorJSON created
    2024-04-28 14:22:43.531 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.aktuellerWasserverbrauch created
    2024-04-28 14:22:43.534 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Salzverbrauch created
    2024-04-28 14:22:43.536 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Salzstand created
    2024-04-28 14:22:43.539 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.SalzverbrauchGesamt created
    2024-04-28 14:22:43.541 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.DatumSalzverbrauch created
    2024-04-28 14:22:43.543 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_1 created
    2024-04-28 14:22:43.545 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_1 created
    2024-04-28 14:22:43.548 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_1 created
    2024-04-28 14:22:43.551 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_2 created
    2024-04-28 14:22:43.554 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_2 created
    2024-04-28 14:22:43.556 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_2 created
    2024-04-28 14:22:43.558 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_3 created
    2024-04-28 14:22:43.561 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_3 created
    2024-04-28 14:22:43.563 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_3 created
    2024-04-28 14:22:43.566 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_4 created
    2024-04-28 14:22:43.569 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_4 created
    2024-04-28 14:22:43.572 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_4 created
    2024-04-28 14:22:43.574 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_5 created
    2024-04-28 14:22:43.577 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_5 created
    2024-04-28 14:22:43.581 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_5 created
    2024-04-28 14:22:43.585 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_6 created
    2024-04-28 14:22:43.587 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_6 created
    2024-04-28 14:22:43.590 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_6 created
    2024-04-28 14:22:43.592 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_7 created
    2024-04-28 14:22:43.595 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_7 created
    2024-04-28 14:22:43.597 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_7 created
    2024-04-28 14:22:43.600 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_8 created
    2024-04-28 14:22:43.603 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_8 created
    2024-04-28 14:22:43.605 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_8 created
    2024-04-28 14:22:43.608 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_9 created
    2024-04-28 14:22:43.610 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_9 created
    2024-04-28 14:22:43.613 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_9 created
    2024-04-28 14:22:43.616 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_10 created
    2024-04-28 14:22:43.619 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_10 created
    2024-04-28 14:22:43.621 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_10 created
    2024-04-28 14:22:43.624 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_11 created
    2024-04-28 14:22:43.626 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_11 created
    2024-04-28 14:22:43.628 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_11 created
    2024-04-28 14:22:43.632 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_12 created
    2024-04-28 14:22:43.635 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_12 created
    2024-04-28 14:22:43.637 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_12 created
    2024-04-28 14:22:43.639 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_13 created
    2024-04-28 14:22:43.641 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_13 created
    2024-04-28 14:22:43.644 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_13 created
    2024-04-28 14:22:43.647 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_2_14 created
    2024-04-28 14:22:43.649 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Verschnittwasser_14 created
    2024-04-28 14:22:43.651 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_Y_4_14 created
    2024-04-28 14:22:43.653 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_K_1 created
    2024-04-28 14:22:43.660 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_K_2 created
    2024-04-28 14:22:43.664 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_K_3 created
    2024-04-28 14:22:43.666 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_K_4 created
    2024-04-28 14:22:43.668 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_K_7 created
    2024-04-28 14:22:43.670 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_K_8 created
    2024-04-28 14:22:43.673 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_K_9 created
    2024-04-28 14:22:43.677 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_F_5 created
    2024-04-28 14:22:43.679 - info: host.ips iobroker host.ips object gruenbeck.0.info.D_F_6 created
    2024-04-28 14:22:43.682 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.Wasserzaehler created
    2024-04-28 14:22:43.684 - info: host.ips iobroker host.ips object gruenbeck.0.calculated.DatumWasserzaehler created
    2024-04-28 14:22:43.686 - info: host.ips iobroker host.ips Set default value of gruenbeck.0.info.connection: false
    2024-04-28 14:22:43.727 - info: host.ips iobroker host.ips object system.adapter.gruenbeck.0 created
    2024-04-28 14:22:44.753 - info: host.ips iobroker exit 0
    2024-04-28 14:22:45.964 - info: admin.0 (5476) ==> Connected system.user.admin from ::1
    2024-04-28 14:22:46.739 - info: host.ips instance system.adapter.gruenbeck.0 started with pid 6440
    2024-04-28 14:22:48.260 - info: gruenbeck.0 (6440) starting. Version 0.0.42 in C:/ioBroker/node_modules/iobroker.gruenbeck, node: v18.20.2, js-controller: 5.0.19
    2024-04-28 14:22:48.273 - warn: gruenbeck.0 (6440) [START] No IP-address set
    2024-04-28 14:23:18.013 - info: host.ips stopInstance system.adapter.gruenbeck.0 (force=false, process=true)
    2024-04-28 14:23:18.015 - info: host.ips stopInstance system.adapter.gruenbeck.0 send kill signal
    2024-04-28 14:23:18.015 - info: gruenbeck.0 (6440) Got terminate signal TERMINATE_YOURSELF
    2024-04-28 14:23:18.017 - info: gruenbeck.0 (6440) terminating
    2024-04-28 14:23:18.018 - info: gruenbeck.0 (6440) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-04-28 14:23:18.148 - info: admin.0 (5476) <== Disconnect system.user.admin from ::1
    2024-04-28 14:23:18.518 - info: gruenbeck.0 (6440) terminating
    2024-04-28 14:23:18.542 - info: host.ips instance system.adapter.gruenbeck.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-04-28 14:23:21.032 - info: host.ips instance system.adapter.gruenbeck.0 started with pid 3052
    2024-04-28 14:23:22.568 - info: gruenbeck.0 (3052) starting. Version 0.0.42 in C:/ioBroker/node_modules/iobroker.gruenbeck, node: v18.20.2, js-controller: 5.0.19
    2024-04-28 14:23:22.586 - info: gruenbeck.0 (3052) Connection to SD Device with:
    2024-04-28 14:23:23.066 - info: gruenbeck.0 (3052) Login step 1
    2024-04-28 14:23:23.624 - info: gruenbeck.0 (3052) Login step 2
    2024-04-28 14:23:24.132 - info: gruenbeck.0 (3052) Login successful
    2024-04-28 14:23:24.294 - info: gruenbeck.0 (3052) Found 2 devices
    2024-04-28 14:23:24.294 - info: gruenbeck.0 (3052) Filtered to 2 devices
    2024-04-28 14:23:24.294 - info: gruenbeck.0 (3052) Using device softliQ.D/BS60013877
    ich hatte die Instanz jetzt einmal entfernt und neu hinzugefügt.
    was mir auffällt ist folgender Eintrag:
    gruenbeck.0
    2024-04-28 14:35:24.506	error	Failed enter SD
    gruenbeck.0
    2024-04-28 14:35:24.506	error	AxiosError: Request failed with status code 500
    gruenbeck.02024-04-28 14:35:24.505	error	https://prod-eu-gruenbeck-api.azurewebsites.net/api/devices/softliQ.D/BS60013877/realtime/enter?api-version=2020-08-03
    gruenbeck.02024-04-28 14:23:24.294	info	Using device softliQ.D/BS60013877
    • F fbueller76
      @da_woody
      gruenbeck.0
      gruenbeck.0
      da_WoodyD Online
      da_WoodyD Online
      #483
      @fbueller76 das zeug kann schon zickig sein. wie gesagt, mit 2 anlagen hab ich keine ahnung.
      bist du mit beiden lokal eingeloggt? deinste mal den adapter und schau ob du in der app beide getrennt drinnen hast. wenn da alles klappt, dann nochmal den adapter neu insten.
      ich hab nur eine DS18, da seh ich die daten wie du nachträglich eingefügt hast genauso.
      möglicherweise musst du eine 2. instanz anlegen und die anlagen mit verschiedenen passwörtern ansprechen. kann ich nicht sagen. eventuell auch mit 2 unterschiedlichen emailadrs.
      • F fbueller76
        @da_woody
        leider nicht, ist da eventuell beim anlegen etwas schief gegangen?
        kann ich das neue an Triggern oder muss ich dazu den Adapter deinstallieren und neu installieren?
        Da ich neu bin wollte ich das nicht einfach so machen, muss ich etwas beachten?
        tombox
        #484
        @fbueller76 zur zeit kann der adapter nur eine anlage pro Instanz.
        ich habe in die GitHub version eine Einstellungen gemacht da könntest du zwei Instanzen erzeugen und via index die gewünschte anlage auswählen
        F 1 Antwort Letzte Antwort
        • F Offline
          fbueller76
          #485
          @tombox
          Hallo tombox, herzlichen Dank dafür.
          ich versuche einmal herrauszufinden wie das geht :-)
          • T tombox
            fbueller76
            #486
            @tombox
            hat super funktioniert :-)
              martin_s
              #487
              bei mir wird seit ca. 2 Wochen kein Wert mehr für "mcurrent" geliefert. Der steht auch bei der Regeneration immer auf "0"
              Da ich aber keine zugehörige Fehlermeldung bekomme "Chlorstrom zu niedrig", stellt sich die Frage: Ist die Elektrode defekt und die Warnmeldung geht nicht (Warnung ist aber aktiviert) oder kommen nur keine Daten?
              Tritt noch wo das Problem auf, dass bei "mcurrent" kein Update kommt?
              Viele Grüße
              Martin
              O 1 Antwort Letzte Antwort
              • M martin_s
                Viele Grüße
                Martin
                O Offline
                O Offline
                oxident
                #488
                @martin_s Ja, das habe ich leider auch öfters mal. Da ich aber davon ausgehe, dass es ansonsten eine Warnung am Display geben würde (wo mir ja der "mcurrent"-Wert quasi live und nach wie vor angezeigt wird), denke ich, es ist einfach nur ein Server-Problem.
                Da hilft eigentlich nur abwarten oder evtl. die Netzwerkverbindung kurz zu kappen.
                • O oxident
                  martin_s
                  #489
                  @oxident
                  Das Rätsel mit den nicht mehr geloggten "mcurrent" konnte ich inzwischen lösen. Ich habe ein "refresh interval" von 600 Sekunden eingestellt. Da habe ich vermutlich einfach den Zeitraum verpasst, wo die Chlorierung stattfindet.
                  Was noch unklar ist: Warum hat es vor April den Zeitpunkt regelmäßig erwischt und dann nicht wieder. Da muss sich vom Timing etwas verschoben haben. Ich werden mal das "refersh interval" kürzer setzen.
                  • M martin_s
                    @oxident
                    O Offline
                    O Offline
                    oxident
                    #490
                    @martin_s Ich würde es sogar deutlich kürzer setzen. Mit leichten Hacks im Adapter fahre ich jetzt schon seit Monaten 30s ... und bin noch nie geblockt worden.
                    lamahgraL 1 Antwort Letzte Antwort
                    • O oxident
                      lamahgraL Offline
                      lamahgraL Offline
                      lamahgra
                      #491
                      ich habe den gruenbeck adapter in Einsatz mit cloud-Anbindung :-( (gruenbeck SD21)
                      habe im vis2 Angefangen mir die entsprechende Visualisierung zu "basteln"
                      ich brächte da mal Hilfe beim erstellen der Datenpunkte...das es am Ende grob aussieht wie in der gruenbeck APP
                      Als Datenpunkte werden ja "nur"
                      wie bekomme ich:
                      aktuellen Verbrauch / Durchfluss
                      Verbrauch pro Tag
                      Restmenge Salz
                      eingebunden?
                      Also was muss als "widget" mit welchem Datenpunkt hinterlegt werden...
                      madingM 1 Antwort Letzte Antwort
                      • da_WoodyD Online
                        da_WoodyD Online
                        #492
                        @tombox hab ein issue angelegt:
                        https://github.com/TA2k/ioBroker.gruenbeck/issues/64
                        • lamahgraL lamahgra
                          wie bekomme ich:
                          Verbrauch pro Tag
                          Restmenge Salz
                          eingebunden?
                          madingM Online
                          madingM Online
                          mading
                          #493
                          @lamahgra bei mir gibt es folgende DP (sc18):
                          Zudem wird der aktuelle Wasserverbrauch darin geloggt:
                          gruenbeck.0.calculated.aktuellerWasserverbrauch.
                          Die scheint es bei dir nicht zu geben?
                          • madingM mading
                            O Offline
                            O Offline
                            oxident
                            #494
                            @mading Leider gibt es bei der SD-Serie den "calculated"-Ordner nicht. Da geht halt nur Cloud :-(
                            @lamahgra Ich denke, Du musst da mit Hilfsmitteln wie z. B. SourceAnalytix arbeiten und da z. B. msaltusage tracken. Damit bekommst Du den Salzverbrauch pro Tag/Monat/Jahr.
                            Die Restmenge Salz könntest Du aber z. B. via msaltrange herausfinden. Hier habe ich aber die Erfahrung gemacht, dass es bei 99 bleibt und dann spontan auf 21 springt. Ab dann passt es aber recht gut.
                            Skyx3S 1 Antwort Letzte Antwort
                            • O oxident
                              Skyx3S Offline
                              Skyx3S Offline
                              Skyx3
                              #495
                              Gibt es zur SE Serie etwas Neues? Der Stream Ordner ist leider leer. Die Daten die unter Parameter zu sehen sind, sind leider nicht besonders spannend. Es fehlen Verbräuche, Restkapaziät usw.
                              • Skyx3S Skyx3
                                tombox
                                #496
                                @skyx3 bin 0.0.46 sollte es gehen
                                • T tombox
                                  Skyx3S Offline
                                  Skyx3S Offline
                                  Skyx3
                                  schrieb am zuletzt editiert von Skyx3
                                  #497
                                  @tombox
                                  Ist installiert, ändert aber nichts. :-( Der Ordner Stream bleibt leer.
                                  Benötigst du meinen Zugang um dir das anzuschauen?
                                  T L 2 Antworten Letzte Antwort
                                  • Skyx3S Skyx3
                                    @tombox
                                    tombox
                                    #498
                                    @skyx3 ja sollte eigentlich gehen aber ja
                                    tombox2020@gmail.com
                                    • T tombox
                                      Skyx3S Offline
                                      Skyx3S Offline
                                      Skyx3
                                      #499
                                      @tombox
                                      Danke, Mail ist raus.
                                      • Skyx3S Skyx3
                                        @tombox
                                        linos2
                                        #500
                                        Also bei meiner frisch installieren SD21 ist der Stream Ordner auch leer.
                                        Und in der iOS App kann ich keine Live Daten mehr sehen, wenn der Adapter eine Zeit lang im iobroker läuft.
                                        Es wirkt so, als wie wenn Grünbeck dann etwas sperrt.
                                        Kennt das noch jemand?
                                        • O Offline
                                          O Offline
                                          oxident
                                          #501
                                          Nach einem Komplettabsturz und anschließendem Restore bekomme ich leider keine Daten mehr. Es hagelt 404-Fehler ... aber Befehle (z.B. Leuchtring) kann ich absetzen.
                                          Habt ihr eine Idee oder einen Vorschlag für mich? ;-)
