  4. JavaScript
  5. Hilfe bei Skripte von request auf httpGet umbauen
132 Beiträge 16 Kommentatoren 25.0k Aufrufe 12 Beobachtet
  • OliverIOO OliverIO
    @liv-in-sky
    wo seht ihr nun einen unterschied?
    die beiden zeilen sind doch gleich?
    javascript.0	16:22:19.588	info	script.js.common.VolkszaehlerNeuTest: {"version":"0.3","data":[{"tuples":[[1716906115000,0,1]],"uuid":"bc3edcd0-24c4-11ea-b257-bdbd9553c516","from":1716906055000,"to":1716906115000,"min":[1716906115000,0],"max":[1716906115000,0],"average":0,"consumption":0,"rows":2},{"tuples":[[1716906115000,840,1]],"uuid":"deda8550-24c4-11ea-b402-275ee0956365","from":1716906085000,"to":1716906115000,"min":[1716906115000,840],"max":[1716906115000,840],"average":840,"consumption":7,"rows":2}]}
    javascript.0	16:22:19.590	info	script.js.common.VolkszaehlerNeuTest: ---------------------------
    javascript.0	16:22:19.590	info	script.js.common.VolkszaehlerNeuTest: {"version":"0.3","data":[{"tuples":[[1716906115000,0,1]],"uuid":"bc3edcd0-24c4-11ea-b257-bdbd9553c516","from":1716906055000,"to":1716906115000,"min":[1716906115000,0],"max":[1716906115000,0],"average":0,"consumption":0,"rows":2},{"tuples":[[1716906115000,840,1]],"uuid":"deda8550-24c4-11ea-b402-275ee0956365","from":1716906085000,"to":1716906115000,"min":[1716906115000,840],"max":[1716906115000,840],"average":840,"consumption":7,"rows":2}]}
    j
    liv-in-skyL Offline
    liv-in-skyL Offline
    #99
    @oliverio oh sorry - da ich nicht testen kann und das script etwas angepaßt habe, funktioniert es jetzt - dann kann ich mit @Negalein wiede weitermachen
    vorher stand bei max und min nur das wort [array] drin
    also so:
    javascript.0	16:22:19.590	info	script.js.common.VolkszaehlerNeuTest: {"version":"0.3","data":[{"tuples":[[1716906115000,0,1]],"uuid":"bc3edcd0-24c4-11ea-b257-bdbd9553c516","from":1716906055000,"to":1716906115000,"min":[array],"max":[array],"average":0,"consumption":0,"rows":2},{"tuples":[[1716906115000,840,1]],"uuid":"deda8550-24c4-11ea-b402-275ee0956365","from":1716906085000,"to":1716906115000,"min":[array],"max":[array],"average":840,"consumption":7,"rows":2}]}
    j
    • liv-in-skyL liv-in-sky
      also so:
      j
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      #100
      @liv-in-sky
      das kann eine funktion der log ausgabe sein, die ab einer bestimmten tiefe der objektverschachtelung nur noch den typ ausgibt, obwohl es da schon noch weitergeht.
      über die stringify ausgabe seht ihr ja, das da alles da ist.
      die reihenfolge der properties in einem json ist nicht standardisiert, führt aber immer zum gleichen objekt. daher ist ein textbasierter vergleich meist schwierig.
      Meine Adapter und Widgets
      Links im Profil
        kukoratsch
        schrieb am zuletzt editiert von kukoratsch
        #101
        neues Thema aufgemacht
        • R Offline
          Rushmed
          #102
          Hallo meine Herren,
          ich muss nochmal nach dem Thema:
          timeout of 2000ms exceeded
          fragen.
          Wenn ich diesen Block ausführe:
          bekomme ich diese Antwort:
          javascript.0	19:17:46.172	info	Start JavaScript script.js.Matrix_Displays (Blockly)
          javascript.0	19:17:46.207	info	script.js.Matrix_Displays: registered 69 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0	19:17:46.267	info	script.js.Matrix_Displays: {"Restart":"Restarting"}
          javascript.0	19:17:50.287	error	script.js.Matrix_Displays: timeout of 2000ms exceeded
          Der Befehl wird auf dem (Tasmota) Gerät ausgeführt und die Antwort kommt ja augenscheinlich auch im ioBroker an. Warum kommt dann hier der Error und kann ich etwas dagegen tun?
          Danke vorab.
          W R 2 Antworten Letzte Antwort
          • R Rushmed
            Hallo meine Herren,
            fragen.
            Danke vorab.
            W Online
            W Online
            Wildbill
            schrieb am zuletzt editiert von Wildbill
            #103
            @rushmed Vermutlich, weil das Gerät den Restart gleich ausführt, ohne darüber nochmal eine Rückmeldung zu geben. Also wird nach den 2 Sekunden eben der Timeout ins Log geschrieben.
            Ich meine, wenn ich bei (einigen zumindest) Tasmota-Geräten per Webinterface einen Restart auslöse, dass dann auch die Fehlerseite aufgeht, dass die Seite nicht erreichbar wäre. Bei anderen kommt vorher noch eine Seite mit „Success“. Woran das aber liegt, dass die Success-Seite mal kommt und mal nicht und ob das immer die gleichen Geräte sind habe ich nie verfolgt, weil es mich bisher auch nicht gestört hat.
            Gruss, Jürgen
            EDIT: Der Restart wird ammer in beiden Fällen jeweils problemlos ausgeführt.
            R 1 Antwort Letzte Antwort
            • W Wildbill
              Gruss, Jürgen
              Rushmed
              schrieb am zuletzt editiert von Rushmed
              #104
              @wildbill Ok, aber die Antwort von Tasmota:
              wird doch empfangen aber scheinbar nicht als Antwort interpretiert.
              Hat @haus-automatisierung hier evtl. einen Rat?
              W haus-automatisierungH 2 Antworten Letzte Antwort
              • R Rushmed
                W Online
                W Online
                Wildbill
                #105
                @rushmed Das stimmt allerdings, wenn man es so sieht. Keine Ahnung, ob da noch danach was „erwartet“ wird, was wegen des Reboots aber nicht kommt.
                Gruss, Jürgen
                • R Rushmed
                  haus-automatisierungH Offline
                  #106
                  @rushmed sagte in Hilfe bei Skripte von request auf httpGet umbauen:
                  Tasmota ist hier zumindest immer wieder auffällig. Bitte mal die gleiche URL mit curl aufrufen und verbose aktivieren -v damit man alle Header sieht.
                  📚 Meine Dokumentation
                    Rushmed
                    #107
                    ich habe:
                    Ausgeführt und es ist garnichts passiert. Weder wurde der Befehl ausgeführt, noch kam eine Antwort.
                    • R Rushmed
                      ich habe:
                      #108
                      @rushmed Mach das mal direkt per ssh oder auf einem anderen System. Also nicht aus Blockly heraus. Ansonsten müssen natürlich Anführungszeichen um die URL, damit die 1 am Ende noch dazu gehört (oder %20 dazwischen)
                        Rushmed
                        #109
                        pi@Smartazamba:~ $ curl -v http://192.168.178.138/cm?cmnd=Restart 1
                        *   Trying 192.168.178.138:80...
                        * Connected to 192.168.178.138 (192.168.178.138) port 80 (#0)
                        > GET /cm?cmnd=Restart HTTP/1.1
                        > Host: 192.168.178.138
                        > User-Agent: curl/7.88.1
                        > Accept: */*
                        < HTTP/1.1 200 OK
                        < Content-Type: application/json
                        < Server: Tasmota/14.1.0.1 (ESP8266EX)
                        < Cache-Control: no-cache, no-store, must-revalidate
                        < Pragma: no-cache
                        < Expires: -1
                        < Accept-Ranges: none
                        < Transfer-Encoding: chunked
                        < Connection: close
                        * Closing connection 0
                        {"Restart":"1 to restart, 2 to halt"}*   Trying 0.0.0.1:80...
                        Restart ist nicht erfolgt.
                        • R Rushmed
                          > Accept: */*
                          < HTTP/1.1 200 OK
                          < Pragma: no-cache
                          < Expires: -1
                          < Connection: close
                          #110
                          Weil Du wieder keine Anführungszeichen um die Url gemacht hast und die 1 am Ende für curl somit nicht zur Url gehört (sieht man auch im verbose)
                            Rushmed
                            #111
                            @haus-automatisierung Sorry.
                            pi@Smartazamba:~ $ curl -v "http://192.168.178.138/cm?cmnd=Restart 1"
                            * Closing connection -1
                            curl: (3) URL using bad/illegal format or missing URL
                            • R Rushmed
                              #112
                              @rushmed curl -v "http://192.168.178.138/cm?cmnd=Restart%201"
                              • R Offline
                                Rushmed
                                #113
                                @haus-automatisierung sagte in Hilfe bei Skripte von request auf httpGet umbauen:
                                pi@Smartazamba:~ $ curl -v "http://192.168.178.138/cm?cmnd=Restart%201"
                                > GET /cm?cmnd=Restart%201 HTTP/1.1
                                > Accept: */*
                                < HTTP/1.1 200 OK
                                < Pragma: no-cache
                                < Expires: -1
                                < Connection: close
                                {"Restart":"Restarting"}p
                                Restart wir ausgeführt.
                                Script sendet wieder:
                                javascript.0	22:20:34.986	error	script.js.Matrix_Displays: timeout of 2000ms exceeded
                                Das passiert ohne Scriptneustart o.ä.. Scheinbar lauscht das Script aber empfängt nichts.
                                Gesendet hab' ich den Befehl per Putty.
                                • R Rushmed
                                  > Accept: */*
                                  < HTTP/1.1 200 OK
                                  < Pragma: no-cache
                                  < Expires: -1
                                  < Connection: close
                                  #114
                                  Könnte sein dass axios denkt dass da noch mehr kommen müsste und deswegen wartet (bis timeout). Muss ich mir mal ein Test-Setup aufbauen. Eventuell auch eine blöde Kombination in Tasmota mit Restart, dass die Verbindung dann nicht richtig geschlossen wird, weil ESP neustartet.
                                  https://nothing-else.blog/blog/axios-timeout-for-chunked-responses
                                    Rushmed
                                    #115
                                    @haus-automatisierung Ich hab' noch eine Info:
                                    Bringt nur:
                                    javascript.0	22:26:05.158	error	script.js.Tasmota: timeout of 2000ms exceeded
                                    javascript.0	22:26:05.164	error	script.js.Tasmota: timeout of 2000ms exceeded
                                    bei drei angesprochenen Geräten von denen zwei offline sind. Hier kommt die Meldung für das Verfügbare gerät nicht. Das ist schlüssig.
                                    Wo liegt hier der Unterschied?
                                    • R Rushmed
                                      Bringt nur:
                                      #116
                                      Andere Tasmota-Version?
                                        Rushmed
                                        #117
                                        @haus-automatisierung Oha, da passiert was, ich prüfe kurz.
                                        Edit1:
                                        Tasmota Development Version" Tasmota 14.1.0.1 (display)" bringt den Error.
                                        Tasmota Master Version "Tasmota 14.1.0 (display)" bringt den Error nicht.
                                        Super!
                                        Werde die Devices auf die Tasmota Master umstellen.
                                        Vielen Dank!
                                        Edit2:
                                        Hab' mich zu früh gefreut. Der Error kommt wieder.
                                        Edit3:
                                        Jetzt sind zwei von drei Geräten angschlossen bei der Ausführung von:
                                        04efa019-1d5e-4192-a564-47c674fd6447-1718396830836-38e03a61-d73f-4ad4-b41f-71223e79a4e2-grafik.png
                                        und die Errormeldung kommt nurnoch einmal. Wieder schlüssig.
                                        • BananaJoeB Offline
                                          BananaJoeB Offline
                                          BananaJoe
                                          #118
                                          @rushmed Probiere mal
                                          Die %20 maskieren das Leerzeichen (URL-Encoding), vielleicht liegt es daran
