  3. Einsteigerfragen
  4. Installation
  5. node js Update - npm bad error EBADENGINE
    apollon77A
37 Beiträge 6 Kommentatoren 6.3k Aufrufe 5 Beobachtet
  • madjack84M madjack84
    @thomas-braun :D :D
    darum habe ich ja Nodejs aktualisiert :D
    $ iobroker upgrade mqtt-client@1.8.0 --debug
    Installing iobroker.mqtt-client@1.8.0... (System call)
    npm error code EBADENGINE
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-31T17_52_53_784Z-debug-0.log
    upload [17] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/custom.html custom.html text/html
    upload [10] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [9] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [0] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/words.js words.js application/javascript
    Process exited with code 0
    das hier bekomme ich wenn ich den MQTT adapter aktualisieren möchte
    madjack84M
    madjack84M
    madjack84
    @madjack84
    hier noch das NPM log
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: ioalbrecht
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.4.0-182-generic
          Architecture: x86-64
    model name	: Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     19:43:38 up 37 min,  1 user,  load average: 0.17, 0.11, 0.15
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Fri 2024-05-31 19:43:38 CEST
               Universal time: Fri 2024-05-31 17:43:38 UTC
                     RTC time: Fri 2024-05-31 17:43:39
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    upgrade
    HOME=/home/upgrade
    GROUPS=upgrade adm dialout cdrom sudo dip plugdev lxd iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video redis
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           3.9G        1.8G        1.3G        1.0M        866M        1.9G
    Swap:          3.9G          0B        3.9G
    Total:         7.9G        1.8G        5.2G
    Active iob-Instances: 	19
             3920 M total memory
             1760 M used memory
             1960 M active memory
              470 M inactive memory
             1293 M free memory
               90 M buffer memory
              775 M swap cache
             3935 M total swap
                0 M used swap
             3935 M free swap
    top - 19:43:39 up 37 min,  1 user,  load average: 0.17, 0.11, 0.15
    Tasks: 145 total,   1 running, 144 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3920.1 total,   1293.8 free,   1760.0 used,    866.4 buff/cache
    MiB Swap:   3936.0 total,   3936.0 free,      0.0 used.   1922.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                             LOAD   ACTIVE SUB    DESCRIPTION
    * snap.mosquitto.mosquitto.service loaded failed failed Service for snap application mosquitto.mosquitto
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                        Type      Size  Used Avail Use% Mounted on
    udev                              devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs                             tmpfs     393M  1.1M  391M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4       20G   15G  4.3G  78% /
    tmpfs                             tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs                             tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                             tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
    /dev/sda2                         ext4      974M  312M  595M  35% /boot
    /dev/loop0                        squashfs   56M   56M     0 100% /snap/core18/2823
    /dev/loop1                        squashfs   56M   56M     0 100% /snap/core18/2812
    /dev/loop2                        squashfs   64M   64M     0 100% /snap/core20/2318
    /dev/loop3                        squashfs  1.2M  1.2M     0 100% /snap/mosquitto/873
    /dev/loop4                        squashfs   92M   92M     0 100% /snap/lxd/24061
    /dev/loop5                        squashfs   64M   64M     0 100% /snap/core20/2264
    /dev/loop6                        squashfs  1.2M  1.2M     0 100% /snap/mosquitto/856
    /dev/loop7                        squashfs   92M   92M     0 100% /snap/lxd/23991
    /dev/loop8                        squashfs   39M   39M     0 100% /snap/snapd/21465
    /dev/loop9                        squashfs   39M   39M     0 100% /snap/snapd/21759
    tmpfs                             tmpfs     393M     0  393M   0% /run/user/1000
    [Fri May 31 19:06:31 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri May 31 19:06:32 2024] EXT4-fs (dm-0): re-mounted. Opts: (null)
    [Fri May 31 19:06:34 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    Show mounted filesystems:
    TARGET                                SOURCE                            FSTYPE      OPTIONS
    /                                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4        rw,relatime
    |-/sys                                sysfs                             sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs                             tmpfs       ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2                           cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/devices          cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,devices
    | | |-/sys/fs/cgroup/cpuset           cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/memory           cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,memory
    | | |-/sys/fs/cgroup/rdma             cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,rdma
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/freezer          cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/hugetlb          cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,hugetlb
    | | |-/sys/fs/cgroup/perf_event       cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
    | | |-/sys/fs/cgroup/pids             cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,pids
    | | `-/sys/fs/cgroup/blkio            cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,blkio
    | |-/sys/fs/pstore                    pstore                            pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                       none                              bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing               tracefs                           tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config                configfs                          configfs    rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections          fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
    |-/proc                               proc                              proc        rw,nosuid,nodev,noexec,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1                         autofs      rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15764
    |   `-/proc/sys/fs/binfmt_misc        binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                udev                              devtmpfs    rw,nosuid,noexec,relatime,size=1960344k,nr_inodes=490086,mode=755
    | |-/dev/pts                          devpts                            devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                          tmpfs                             tmpfs       rw,nosuid,nodev
    | |-/dev/hugepages                    hugetlbfs                         hugetlbfs   rw,relatime,pagesize=2M
    | `-/dev/mqueue                       mqueue                            mqueue      rw,nosuid,nodev,noexec,relatime
    |-/run                                tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=401424k,mode=755
    | |-/run/lock                         tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc                            rpc_pipefs  rw,relatime
    | |-/run/snapd/ns                     tmpfs[/snapd/ns]                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=401424k,mode=755
    | | |-/run/snapd/ns/lxd.mnt           nsfs[mnt:[4026532318]]            nsfs        rw
    | | `-/run/snapd/ns/mosquitto.mnt     nsfs[mnt:[4026532320]]            nsfs        rw
    | `-/run/user/1000                    tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=401420k,mode=700,uid=1000,gid=1000
    |-/boot                               /dev/sda2                         ext4        rw,relatime
    |-/snap/core18/2823                   /dev/loop0                        squashfs    ro,nodev,relatime
    |-/snap/core18/2812                   /dev/loop1                        squashfs    ro,nodev,relatime
    |-/snap/core20/2318                   /dev/loop2                        squashfs    ro,nodev,relatime
    |-/snap/mosquitto/873                 /dev/loop3                        squashfs    ro,nodev,relatime
    |-/snap/lxd/24061                     /dev/loop4                        squashfs    ro,nodev,relatime
    |-/snap/core20/2264                   /dev/loop5                        squashfs    ro,nodev,relatime
    |-/snap/mosquitto/856                 /dev/loop6                        squashfs    ro,nodev,relatime
    |-/snap/lxd/23991                     /dev/loop7                        squashfs    ro,nodev,relatime
    |-/snap/snapd/21465                   /dev/loop8                        squashfs    ro,nodev,relatime
    `-/snap/snapd/21759                   /dev/loop9                        squashfs    ro,nodev,relatime
    /var:
    2.4G	/var/
    1.2G	/var/lib
    926M	/var/lib/snapd
    901M	/var/log
    897M	/var/log/journal/9eafc192ff0e4f099ca8b43790018b7d
    Archived and active journals take up 896.1M in the file system.
    /opt/iobroker/backups:
    352M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G	/opt/iobroker/iobroker-data/
    726M	/opt/iobroker/iobroker-data/files
    511M	/opt/iobroker/iobroker-data/files/ring.0
    498M	/opt/iobroker/iobroker-data/files/ring.0/doorbell_91774976
    386M	/opt/iobroker/iobroker-data/backup-objects
    47M	/opt/iobroker/iobroker-data/states.jsonl
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    29M	/opt/iobroker/iobroker-data/objects.jsonl
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2473751-if00
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.14.0
    /usr/bin/node 		v20.14.0
    /usr/bin/npm 		10.7.0
    /usr/bin/npx 		10.7.0
    /usr/bin/corepack 	0.28.1
    nodejs:
      Installed: 20.14.0-1nodesource1
      Candidate: 20.14.0-1nodesource1
      Version table:
     *** 20.14.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         10.19.0~dfsg-3ubuntu1.6 500
            500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.12
    admin: 		6.13.16
    javascript: 	7.1.4
    nodejs modules from github: 	1
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioalbrecht                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioalbrecht                               -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioalbrecht                               -  enabled
    + system.adapter.backitup.0               : backitup              : ioalbrecht                               -  enabled
      system.adapter.daswetter.0              : daswetter             : ioalbrecht                               -  enabled
      system.adapter.devices.0                : devices               : ioalbrecht                               -  enabled
      system.adapter.discovery.0              : discovery             : ioalbrecht                               - disabled
      system.adapter.feiertage.0              : feiertage             : ioalbrecht                               -  enabled
      system.adapter.flot.0                   : flot                  : ioalbrecht                               - disabled
    + system.adapter.history.0                : history               : ioalbrecht                               -  enabled
    + system.adapter.info.0                   : info                  : ioalbrecht                               -  enabled
    + system.adapter.iot.0                    : iot                   : ioalbrecht                               -  enabled
    + system.adapter.javascript.0             : javascript            : ioalbrecht                               -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioalbrecht                               -  enabled, port: 54321
    + system.adapter.mihome.0                 : mihome                : ioalbrecht                               -  enabled, port: 9898, bind: 0.0.0.0
    + system.adapter.mqtt-client.0            : mqtt-client           : ioalbrecht                               -  enabled, port: 1883
    + system.adapter.mqtt-client.1            : mqtt-client           : ioalbrecht                               -  enabled, port: 1883
    + system.adapter.ping.0                   : ping                  : ioalbrecht                               -  enabled
      system.adapter.ring.0                   : ring                  : ioalbrecht                               - disabled
      system.adapter.samsung.0                : samsung               : ioalbrecht                               - disabled
    + system.adapter.simple-api.0             : simple-api            : ioalbrecht                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.telegram.0               : telegram              : ioalbrecht                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioalbrecht                               -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : ioalbrecht                               -  enabled
    + system.adapter.web.0                    : web                   : ioalbrecht                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : ioalbrecht                               - disabled
    + system.adapter.zigbee.0                 : zigbee                : ioalbrecht                               -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2473751-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "deconz"       : 1.4.1    , installed 1.3.19 [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.4.0    , installed 3.1.0  [Updatable]
    Adapter    "feiertage"    : 1.2.0    , installed 1.1.4  [Updatable]
    Adapter    "iot"          : 3.2.2    , installed 2.0.11 [Updatable]
    Adapter    "javascript"   : 8.3.1    , installed 7.1.4  [Updatable]
    Controller "js-controller": 5.0.19   , installed 5.0.12 [Updatable]
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.0.0  [Updatable]
    Adapter    "mqtt-client"  : 1.8.0    , installed 1.7.0  [Updatable]
    Adapter    "ring"         : 5.0.10   , installed 3.2.2  [Updatable]
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
    Adapter    "socketio"     : 6.7.0    , installed 6.6.1  [Updatable]
    Adapter    "telegram"     : 3.2.1    , installed 3.1.0  [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.1    , installed 2.5.11 [Updatable]
    Adapter    "zigbee"       : 1.10.3   , installed 1.8.24 [Updatable]
    Objects and States
    Objects: 	11401
    States: 	9587
    Hit:1 http://phoscon.de/apt/deconz focal InRelease
    Hit:2 http://ppa.launchpad.net/chris-lea/redis-server/ubuntu focal InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu focal InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:6 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
    Hit:7 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22411      648/systemd-resolve
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25267      721/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          24892      672/mosquitto
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27453      669/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27394      669/iobroker.js-con
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15775      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          25278      721/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       29602      1410/io.simple-api.
    tcp6       0      0 :::1883                 :::*                    LISTEN      0          24893      672/mosquitto
    tcp6       0      0 :::111                  :::*                    LISTEN      0          15783      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       27613      963/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31154      1569/io.web.0
    udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       28129      1093/io.mihome.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22410      648/systemd-resolve
    udp        0      0 192.168.188.74:68       0.0.0.0:*                           100        22414      646/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15778      1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       28081      1065/io.mihome-vacu
    udp6       0      0 :::111                  :::*                                0          15788      1/init
    udp6       0      0 fe80::e091:47ff:fe6:546 :::*                                100        22631      646/systemd-network
    2024-05-31 19:29:58.040  - info: host.ioalbrecht iobroker npm error code EBADENGINE
    2024-05-31 19:29:58.044  - info: host.ioalbrecht iobroker npm error engine Unsupported engine
    2024-05-31 19:29:58.046  - info: host.ioalbrecht iobroker npm error engine Not compatible with your version of node/npm: ring-client-api@11.7.1
    2024-05-31 19:29:58.047  - info: host.ioalbrecht iobroker npm error notsup Not compatible with your version of node/npm: ring-client-api@11.7.1npm error notsup Required: {"node":"^16 || ^18"}npm error notsup Actual:   {"npm":"10.7.0","node":"v20.14.0"}
    2024-05-31 19:29:58.051  - info: host.ioalbrecht iobroker
    2024-05-31 19:29:58.053  - info: host.ioalbrecht iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-31T17_29_55_322Z-debug-0.log
    2024-05-31 19:29:58.201  - info: host.ioalbrecht iobroker upload [17] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/custom.html custom.html text/html
    2024-05-31 19:29:58.209  - info: host.ioalbrecht iobroker upload [16] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/custom_m.html custom_m.html text/html
    2024-05-31 19:29:58.213  - info: host.ioalbrecht iobroker upload [15] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/de/translations.json i18n/de/translations.json application/json
    2024-05-31 19:29:58.218  - info: host.ioalbrecht iobroker upload [14] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/en/translations.json i18n/en/translations.json application/json
    2024-05-31 19:29:58.223  - info: host.ioalbrecht iobroker upload [13] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/es/translations.json i18n/es/translations.json application/json
    2024-05-31 19:29:58.228  - info: host.ioalbrecht iobroker upload [12] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    2024-05-31 19:29:58.233  - info: host.ioalbrecht iobroker upload [11] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/it/translations.json i18n/it/translations.json application/json
    2024-05-31 19:29:58.238  - info: host.ioalbrecht iobroker upload [10] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    2024-05-31 19:29:58.244  - info: host.ioalbrecht iobroker upload [9] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    2024-05-31 19:29:58.249  - info: host.ioalbrecht iobroker upload [8] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    2024-05-31 19:29:58.254  - info: host.ioalbrecht iobroker upload [7] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    2024-05-31 19:29:58.259  - info: host.ioalbrecht iobroker upload [6] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    2024-05-31 19:29:58.265  - info: host.ioalbrecht iobroker upload [5] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    2024-05-31 19:29:58.269  - info: host.ioalbrecht iobroker upload [4] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/index.html index.html text/html
    2024-05-31 19:29:58.274  - info: host.ioalbrecht iobroker upload [3] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/index_m.html index_m.html text/html
    2024-05-31 19:29:58.279  - info: host.ioalbrecht iobroker upload [2] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonCustom.json jsonCustom.json application/json
    2024-05-31 19:29:58.284  - info: host.ioalbrecht iobroker upload [1] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/mqtt-client.png mqtt-client.png image/png
    2024-05-31 19:29:58.289  - info: host.ioalbrecht iobroker upload [0] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/words.js words.js application/javascript
    2024-05-31 19:29:59.304  - info: host.ioalbrecht iobroker exit 0
    iob diag has finished.
    Press any key for a summary
    upgrade@ioalbrecht:~$ cd /home/iobroker/.npm/_logs/
    upgrade@ioalbrecht:/home/iobroker/.npm/_logs$ ls
    2024-05-31T04_51_03_286Z-debug-0.log 2024-05-31T16_51_03_282Z-debug-0.log 2024-05-31T17_10_24_820Z-debug-0.log 2024-05-31T17_29_55_322Z-debug-0.log
    2024-05-31T16_41_37_801Z-debug-0.log 2024-05-31T17_08_51_571Z-debug-0.log 2024-05-31T17_15_46_197Z-debug-0.log 2024-05-31T17_52_53_784Z-debug-0.log
    2024-05-31T16_41_38_253Z-debug-0.log 2024-05-31T17_09_50_211Z-debug-0.log 2024-05-31T17_24_54_814Z-debug-0.log
    upgrade@ioalbrecht:/home/iobroker/.npm/_logs$ nano /home/iobroker/.npm/_logs/2024-05-31T17_52_53_784Z-debug-0.log
    GNU nano 4.8 /home/iobroker/.npm/_logs/2024-05-31T17_52_53_784Z-debug-0.log
    12 silly logfile done cleaning log files
    13 silly idealTree buildDeps
    14 silly fetch manifest iobroker.mqtt-client@1.8.0
    15 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.alexa2
    16 http fetch GET 200 https://registry.npmjs.org/iobroker.mqtt-client 1407ms (cache revalidated)
    17 silly placeDep ROOT iobroker.mqtt-client@1.8.0 REPLACE for: iobroker.inst@3.0.0 want: 1.8.0
    18 verbose stack Error: Unsupported engine
    18 verbose stack at checkEngine (/usr/lib/node_modules/npm/node_modules/npm-install-checks/lib/index.js:14:25)
    18 verbose stack at #checkEngineAndPlatform (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:220:11)
    18 verbose stack at Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:206:41)
    18 verbose stack at async Promise.all (index 1)
    18 verbose stack at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:131:5)
    18 verbose stack at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
    18 verbose stack at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
    19 verbose pkgid ring-client-api@11.7.1
    20 verbose cwd /opt/iobroker
    21 verbose Linux 5.4.0-182-generic
    22 verbose node v20.14.0
    23 verbose npm v10.7.0
    24 error code EBADENGINE
    25 error engine Unsupported engine
    26 error engine Not compatible with your version of node/npm: ring-client-api@11.7.1
    27 error notsup Not compatible with your version of node/npm: ring-client-api@11.7.1
    27 error notsup Required: {"node":"^16 || ^18"}
    27 error notsup Actual: {"npm":"10.7.0","node":"v20.14.0"}
    28 verbose exit 1
    29 verbose code 1
    30 silly unfinished npm timer reify 1717177974152
    31 silly unfinished npm timer reify:loadTrees 1717177974174
    32 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-31T17_52_53_784Z-debug-0.log
    nuc i3, Proxmox, raspimatic (PI3), 15 shellies, shelly 4pro/25/RGB, wled sonoff, 7x xiaomi sensoren, 4xEchos, 4 Tasmota Steckdosen, motionEye, nspanel, Ring, hoymiles usw
      @madjack84
      iob update
      iob upgrade all -y
      madjack84M
      madjack84M
      madjack84
      @thomas-braun sagte in node js Update - npm bad error EBADENGINE:
      iob upgrade all -y
      läuft gerade und die ersten Adapter sind durchgelaufen....
      D.h. die Informationen für die Adapter bei mir auf der Platte waren veraltet und konjugiert damit wurden nun das repo aktualisiert??? oder was ist hier der Mechanismus?
        @thomas-braun :D :D
        Thomas BraunT
        Thomas BraunT
        Most Active Developer
        @madjack84 sagte in node js Update - npm bad error EBADENGINE:
        Da klemmt es bei dem ring-Adapter. Den zuerst aktualisieren.
          iob upgrade all -y
          Thomas BraunT
          Thomas BraunT
          Der Mechanismus ist, das dein gnadenlos abgesoffener ring-Adapter bzw. eine der Abhängigkeiten so alt war/ist, das der mit aktuellen nodejs-Versionen nicht mag. Deswegen hält man seine Kiste auch regelmäßig auf Stand, dann passiert das nicht (so leicht).
          madjack84M 1 Antwort Letzte Antwort
            madjack84M
            madjack84M
            madjack84
            ich hab heut dick gelesen:
            If it ain't broker, don't fix it :man-shrugging:
            aber ja,... ich hab den iobroker die letzten Monate stark vernachlässigt :(
            Dir schonmal größten Dank für die fixe Hilfe.... ich wühl mich mal durch ob alles funktioniert :)
              Thomas BraunT
              Thomas BraunT
              MOOOOOOOOOARRRRRR....
              Das ist der allergrößte BULLSHIT EVER!!!!!!!
              Wer erzählt so einen Schwachsinn immer????
              Es gilt: Halt die Kiste immer auf einem aktuellen, stabilen Stand.
              madjack84M 2 Antworten Letzte Antwort
                madjack84M
                madjack84M
                madjack84
                https://tasmota.github.io/docs/Upgrading/
                these guys :D :D :D hab vorhin ne Steckdose aktualisiert
                Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                  madjack84M
                  madjack84M
                  madjack84
                  @thomas-braun Lektion gelernt!
                  Und ich bin immer noch beeindruckt wie du das so schnell irgendwo rausgelesen hast. Hab eben die logs durch gescrollt und nix gefunden #shame
                  Danke nochmal :)
                    Thomas BraunT
                    Thomas BraunT
                    @madjack84
                    Joh, bei Tasmota sollst du auch nicht jede kleine Änderung in den Speicher dampfen. Aber so ab und an würde ich auch das auf die nächste Major-Version heben.
                    Für Server-(Dienste) gilt aber: Updaten, updaten, updaten.
                      Meister MopperM
                      Meister MopperM
                      Meister Mopper
                      these guys hab vorhin ne Steckdose aktualisiert
                      IOT ist ein großes Sicherheitsrisiko und bedarf ständiger Upgrades.
                      Das auch hier oftmals proklamierte Argument, "meine Geräte dürfen nicht ins Internet" greift aus meiner Sicht zu kurz, denn wenn ICH darauf zugreifen kann, kann ein anderer, der auf irgendeine Weise mein System kompromittiert hat, vortäuschen ICH zu sein.
                      Hier eine Startrampe für IOT-Sicherheit
                      Proxmox und HA ...
                        lobomauL
                        lobomauL
                        lobomau
                        Ich bin hier gelandet bei der Suche nach meinem Fehler:
                        Ich habe einen Adapter-Update-Stau seitdem ich auf node 22 geupdatet bin auf dem Pi4. Auf meinem Haupthost auf einem NUC habe ich die Probleme nicht. Es kann also nicht an den Adaptern liegen:
                        Admin Updateversuch:
                         $ iobroker upgrade device-watcher@2.12.6 --debug
                        Update device-watcher from @2.12.1 to @2.12.6
                        NPM version: 10.9.3
                        Installing iobroker.device-watcher@2.12.6... (System call)
                        npm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: hap-nodejs@1.1.0npm error notsup Not compatible with your version of node/npm: hap-nodejs@1.1.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.19.0"}
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-12T14_16_19_654Z-debug-0.log
                        Updating objects from io-package.json for adapter "device-watcher" with version "2.12.1"
                        upload [19] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/device-watcher.png device-watcher.png image/png
                        upload [18] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [17] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [16] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [15] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [14] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [13] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [12] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [11] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [10] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [9] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [8] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [7] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/add_blacklist.png images/add_blacklist.png image/png
                        upload [6] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list1.png images/list1.png image/png
                        upload [5] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list2.png images/list2.png image/png
                        upload [4] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list3.png images/list3.png image/png
                        upload [3] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/noti_push.jpeg images/noti_push.jpeg image/jpeg
                        upload [2] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/noti_push2.jpeg images/noti_push2.jpeg image/jpeg
                        upload [1] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                        upload [0] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/words.js words.js application/javascript
                        Device-Watcher Updateversuch:
                        NPM version: 10.9.3
                        npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: hap-nodejs@1.1.0npm error notsup Not compatible with your version of node/npm: hap-nodejs@1.1.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.19.0"}
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-12T14_17_21_747Z-debug-0.log
                        Host: NUC8i3 mit Proxmox:
                        • Slave: Pi4
                        • lobomauL lobomau
                          NPM version: 10.9.3
                          NPM version: 10.9.3
                          Thomas BraunT
                          Thomas BraunT
                          @lobomau sagte in node js Update - npm bad error EBADENGINE:
                          hap-nodejs
                          ist nicht kompatibel mit nodejs@22. Schau nach wo der in deiner Installation hängt und aktualisier den übergeordneten Adapter ggfls. nochmal frisch drüber.
                          cd /opt/iobroker && npm ls hap-nodejs
                          • lobomauL
                            lobomauL
                            lobomau
                            schrieb am zuletzt editiert von lobomau
                            @thomas-braun mit
                            npm1 hap-nodejs
                            kann er nichts anfangen. Von zu Hause kann ich besser die Fehlermeldungen posten. Bis später.
                            Im Mai hattet ihr schon das Thema 'hap-nodejs@1.1.0'
                            https://forum.iobroker.net/topic/81186/nodejs-update-post-install-check
                            • Slave: Pi4
                            • lobomauL lobomau
                              @thomas-braun mit
                              npm1 hap-nodejs
                              mit
                              npm1 hap-nodejs
                              das steht ja auch nicht bei @Thomas-Braun
                                mit
                                npm1 hap-nodejs
                                Thomas BraunT
                                Thomas BraunT
                                @homoran sagte in node js Update - npm bad error EBADENGINE:
                                Bei mir stand aber dafür anderer Quark... Jetzt passt es aber.
                                  hatte ich vermutet 😂
                                    lobomauL
                                    lobomauL
                                    lobomau
                                    @homoran ich auch :-D
                                    ich hatte auch "1" und "l" ausprobiert ;-)
                                    Nun lief schon mal der Befehl durch:
                                    pi@Pi4:~ $ cd /opt/iobroker && npm ls hap-nodejs
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    └─┬ iobroker.yahka@1.0.9
                                      └── hap-nodejs@1.1.0
                                    Ich habe anschließend einen reboot und update, upgrade ausgeführt.
                                    noch sind wir nicht am Ziel, Fehler ist geblieben:
                                    $ iobroker upgrade admin@7.7.2 --debug
                                    Update admin from @7.6.17 to @7.7.2
                                    host.Pi4 Adapter "system.adapter.admin.2" is stopped.
                                    NPM version: 10.9.3
                                    Installing iobroker.admin@7.7.2... (System call)
                                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-12T16_24_24_746Z-debug-0.log
                                    Updating objects from io-package.json for adapter "admin" with version "7.6.17"
                                    upload [171] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                    upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
                                    upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
                                    • Slave: Pi4
                                    HomoranH Thomas BraunT mcm1957M 3 Antworten Letzte Antwort
                                    • lobomauL lobomau
                                      NPM version: 10.9.3
                                      wie auch?
                                      hast du das vollständig gemacht?
                                      • lobomauL lobomau
                                        NPM version: 10.9.3
                                        Thomas BraunT
                                        Thomas BraunT
                                        @lobomau
                                        Du musst yahka auf Stand bringen...
                                        yahka
                                        github:	1.1.5
                                        latest:	1.1.5 for 65 days
                                        stable:	1.1.5 for 65 days
                                        • lobomauL lobomau
                                          NPM version: 10.9.3
                                          mcm1957M
                                          mcm1957M
                                          mcm1957
                                          @lobomau
                                          Wie Thomas schon schrieb:
                                          https://github.com/jensweigele/ioBroker.yahka#115-2025-07-09
                                          yahka MUSS aktualisisert werden. Blockiert sonst alle Updates.
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
                                          84.0k
