  4. Zigbee Conbee
Zigbee Conbee
23 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    @rccardany
    Dann zeig den Rest.
    rccardany
    Skript v.2024-04-21
    *** BASE SYSTEM ***
       Static hostname: zbox
             Icon name: computer-desktop
               Chassis: desktop
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-21-amd64
          Architecture: x86-64
    model name      : Intel(R) Celeron(R) CPU N3450 @ 1.10GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     09:16:46 up  1:15,  1 user,  load average: 1.46, 1.04, 0.91
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Fri 2024-05-10 09:16:47 CEST
               Universal time: Fri 2024-05-10 07:16:47 UTC
                     RTC time: Fri 2024-05-10 07:16:47
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    root
    JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64/jre/
    HOME=/root
    GROUPS=root dialout
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        3.8G        2.7G        0.0K        1.3G        3.8G
    Swap:           976M          0B        976M
    Total:          8.8G        3.8G        3.6G
    Active iob-Instances:   34
             7807 M total memory
             3848 M used memory
              460 M active memory
             4391 M inactive memory
             2650 M free memory
               82 M buffer memory
             1225 M swap cache
              976 M total swap
                0 M used swap
              976 M free swap
    top - 09:16:47 up  1:15,  1 user,  load average: 1.46, 1.04, 0.91
    Tasks: 163 total,   1 running, 162 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  7.7 us,  3.1 sy,  0.0 ni, 89.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7807.1 total,   2650.1 free,   3848.7 used,   1308.3 buff/cache
    MiB Swap:    977.0 total,    977.0 free,      0.0 used.   3846.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     781M  780K  780M   1% /run
    /dev/sda2      ext4      116G   15G   95G  14% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/sda1      vfat      511M   11M  501M   3% /boot/efi
    tmpfs          tmpfs     781M     0  781M   0% /run/user/1002
    [Fri May 10 08:01:33 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri May 10 08:01:35 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems:
    TARGET                        SOURCE     FSTYPE     OPTIONS
    /                             /dev/sda2  ext4       rw,relatime,errors=remount-ro
    |-/sys                        sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security      securityfs securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup            cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore            pstore     pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/firmware/efi/efivars efivarfs   efivarfs   rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf               none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug         debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing       tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections  fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config        configfs   configfs   rw,nosuid,nodev,noexec,relatime
    |-/proc                       proc       proc       rw,nosuid,nodev,noexec,relatime
    | `-/proc/sys/fs/binfmt_misc  systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=10697
    |-/dev                        udev       devtmpfs   rw,nosuid,relatime,size=3989856k,nr_inodes=997464,mode=755
    | |-/dev/pts                  devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                  tmpfs      tmpfs      rw,nosuid,nodev
    | |-/dev/hugepages            hugetlbfs  hugetlbfs  rw,relatime,pagesize=2M
    | `-/dev/mqueue               mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
    |-/run                        tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=799448k,mode=755
    | |-/run/lock                 tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs           sunrpc     rpc_pipefs rw,relatime
    | `-/run/user/1002            tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=799448k,nr_inodes=199862,mode=700,uid=1002,gid=1002
    `-/boot/efi                   /dev/sda1  vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    8.7G    /var/
    4.4G    /var/lib
    4.2G    /var/log
    4.0G    /var/log/journal/b8af39a4a3f84f64bf60ee5243aa6c0c
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    714M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    247M    /opt/iobroker/iobroker-data/
    111M    /opt/iobroker/iobroker-data/files
    63M     /opt/iobroker/iobroker-data/backup-objects
    36M     /opt/iobroker/iobroker-data/node-red
    35M     /opt/iobroker/iobroker-data/node-red/node_modules
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.ea6ad656.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.1d439ead.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2141436-if00
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            9.2.0
    /usr/bin/npx            9.2.0
    corepack:       N/A
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.2.23
    javascript:     5.7.0
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : zbox                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : zbox                                     -  enabled
    + system.adapter.backitup.0               : backitup              : zbox                                     -  enabled
      system.adapter.cloud.0                  : cloud                 : zbox                                     - disabled
      system.adapter.daswetter.0              : daswetter             : zbox                                     - disabled
    + system.adapter.discovery.0              : discovery             : zbox                                     - disabled
    + system.adapter.fakeroku.0               : fakeroku              : zbox                                     -  enabled
    + system.adapter.harmony.0                : harmony               : zbox                                     -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : zbox                                     -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : zbox                                     -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : zbox                                     -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : zbox                                     -  enabled
    + system.adapter.influxdb.0               : influxdb              : zbox                                     -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : zbox                                     -  enabled
    + system.adapter.javascript.0             : javascript            : zbox                                     -  enabled
      system.adapter.kodi.0                   : kodi                  : zbox                                     - disabled, port: 9090
      system.adapter.linux-control.0          : linux-control         : zbox                                     -  enabled
      system.adapter.mclighting.0             : mclighting            : zbox                                     - disabled, port: 81
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : zbox                                     - disabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : zbox                                     -  enabled
    + system.adapter.modbus.1                 : modbus                : zbox                                     -  enabled
    + system.adapter.modbus.2                 : modbus                : zbox                                     -  enabled
    + system.adapter.modbus.3                 : modbus                : zbox                                     -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : zbox                                     -  enabled, port: 1883, bind: 192.168.1.171
      system.adapter.mqtt.2                   : mqtt                  : zbox                                     -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.3                   : mqtt                  : zbox                                     -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.mqtt.4                   : mqtt                  : zbox                                     -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.5                   : mqtt                  : zbox                                     -  enabled, port: 1888, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : zbox                                     -  enabled
    + system.adapter.node-red.0               : node-red              : zbox                                     -  enabled, port: 1880, bind: 192.168.1.171
      system.adapter.octoprint.0              : octoprint             : zbox                                     - disabled
    + system.adapter.parser.0                 : parser                : zbox                                     -  enabled
    + system.adapter.ping.0                   : ping                  : zbox                                     -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : zbox                                     -  enabled
    + system.adapter.shelly.0                 : shelly                : zbox                                     -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.solax.0                  : solax                 : zbox                                     -  enabled
      system.adapter.sonoff.0                 : sonoff                : zbox                                     - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.spotify-premium.0        : spotify-premium       : zbox                                     - disabled
      system.adapter.telegram.0               : telegram              : zbox                                     -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.1               : telegram              : zbox                                     -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : zbox                                     -  enabled
    + system.adapter.tibberlink.0             : tibberlink            : zbox                                     -  enabled
      system.adapter.unifi.0                  : unifi                 : zbox                                     - disabled
      system.adapter.web.0                    : web                   : zbox                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : zbox                                     -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : zbox                                     -  enabled
    + system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : zbox                                     -  enabled
    + system.adapter.zigbee.0                 : zigbee                : zbox                                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2141436-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.2.23 [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.25.5 [Updatable]
    Adapter    "backitup"     : 2.11.0   , installed 2.5.4  [Updatable]
    Adapter    "bshb"         : 0.2.7    , installed 0.2.4  [Updatable]
    Adapter    "cloud"        : 5.0.1    , installed 4.3.0  [Updatable]
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.8  [Updatable]
    Adapter    "deconz"       : 1.4.0    , installed 1.3.21 [Updatable]
    Adapter    "discovergy"   : 0.5.13   , installed 0.5.8  [Updatable]
    Adapter    "discovery"    : 4.4.0    , installed 3.1.0  [Updatable]
    Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
    Adapter    "harmony"      : 1.4.0    , installed 1.2.2  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 3.0.40 [Updatable]
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.12 [Updatable]
    Adapter    "homeconnect"  : 1.3.0    , installed 1.1.1  [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 1.11.4 [Updatable]
    Adapter    "javascript"   : 7.8.0    , installed 5.7.0  [Updatable]
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "kodi"         : 3.0.0    , installed 2.0.8  [Updatable]
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 3.8.6  [Updatable]
    Adapter    "modbus"       : 6.1.0    , installed 4.0.4  [Updatable]
    Adapter    "mqtt"         : 5.2.0    , installed 3.0.6  [Updatable]
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "node-red"     : 5.2.1    , installed 3.3.0  [Updatable]
    Adapter    "octoprint"    : 5.1.0    , installed 3.2.0  [Updatable]
    Adapter    "opi"          : 0.1.2    , installed 0.1.1  [Updatable]
    Adapter    "parser"       : 2.1.0    , installed 1.1.8  [Updatable]
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.0  [Updatable]
    Adapter    "shelly"       : 6.9.0    , installed 5.3.2  [Updatable]
    Adapter    "socketio"     : 6.7.0    , installed 4.2.0  [Updatable]
    Adapter    "solax"        : 0.9.6    , installed 0.7.7  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 2.5.1  [Updatable]
    Adapter    "spotify-premium": 1.4.0  , installed 1.2.1  [Updatable]
    Adapter    "systeminfo"   : 1.1.0    , installed 0.3.1  [Updatable]
    Adapter    "telegram"     : 3.2.1    , installed 1.12.6 [Updatable]
    Adapter    "text2command" : 3.0.3    , installed 2.2.1  [Updatable]
    Adapter    "tibberlink"   : 2.3.2    , installed 1.4.2  [Updatable]
    Adapter    "tinker"       : 1.3.2    , installed 1.1.1  [Updatable]
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "unifi"        : 0.7.0    , installed 0.5.10 [Updatable]
    Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.6.1    , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        26883
    States:         21788
    E: The repository 'http://ftp.nl.debian.org/debian stretch Release' does not have a Release file.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D68FA50FEA312927
    Pending Updates: 419
    *** Listening Ports ***
    2024-05-10 09:16:47.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:16:52.167  - info: influxdb.0 (870) Store 51 buffered influxDB history points
    2024-05-10 09:16:52.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:16:57.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:01.898  - info: influxdb.0 (870) Store 51 buffered influxDB history points
    2024-05-10 09:17:02.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:07.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:09.299  - info: influxdb.0 (870) Store 52 buffered influxDB history points
    2024-05-10 09:17:12.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:15.544  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:18.954  - info: influxdb.0 (870) Store 51 buffered influxDB history points
    2024-05-10 09:17:22.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:27.086  - info: influxdb.0 (870) Store 51 buffered influxDB history points
    2024-05-10 09:17:27.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:32.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:35.680  - info: influxdb.0 (870) Store 51 buffered influxDB history points
    2024-05-10 09:17:37.394  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:42.005  - info: influxdb.0 (870) Store 51 buffered influxDB history points
    2024-05-10 09:17:42.425  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:47.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:50.094  - info: influxdb.0 (870) Store 51 buffered influxDB history points
    2024-05-10 09:17:52.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:17:57.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    2024-05-10 09:18:01.101  - info: influxdb.0 (870) Store 51 buffered influxDB history points
    2024-05-10 09:18:02.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
    iob diag has finished.
    R Thomas BraunT 2 Antworten Letzte Antwort
    • R rccardany
      Skript v.2024-04-21
      *** BASE SYSTEM ***
                 Chassis: desktop
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      root
      HOME=/root
      GROUPS=root dialout
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           976M          0B        976M
               7807 M total memory
               3848 M used memory
                460 M active memory
               2650 M free memory
                 82 M buffer memory
               1225 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      *** FILESYSTEM ***
      /var:
      8.7G    /var/
      4.4G    /var/lib
      4.2G    /var/log
      USB-Devices by-id:
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      corepack:       N/A
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.2.23
      javascript:     5.7.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        26883
      States:         21788
      rccardany
      @rccardany
      v.2024-04-21
      Chassis: desktop
      Installation: native
      Kernel: x86_64
      Userland: 64 bit
      Timezone: Europe/Berlin (CEST, +0200)
      User-ID: 0
      Boot Target: graphical.target
      Pending OS-Updates: 419
      Pending iob updates: 39
      Nodejs-Installation:
      /usr/bin/npm 9.2.0
      /usr/bin/npx 9.2.0
      corepack: N/A
      Recommended versions are nodejs 16.20.2 and npm 8.19.4
      Wrong installation path detected. This needs to be fixed
      Please execute
      iobroker nodejs-update
      to fix these errors.
      MEMORY:
      total used free shared buff/cache available
      Mem: 7.8G 3.9G 2.4G 0.0K 1.5G 3.8G
      Swap: 976M 0B 976M
      Total: 8.8G 3.9G 3.3G
      ioBroker Core: js-controller 5.0.19
      admin 6.2.23
      ioBroker Status: iobroker is running on this host.
      Objects type: jsonl
      States type: jsonl
      • system.adapter.admin.0 : admin : zbox - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Objects: 26883
      States: 21788
      Size of iob-Database:
      === Mark text until here for copying ===
      • R rccardany
        Skript v.2024-04-21
        *** BASE SYSTEM ***
                   Chassis: desktop
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        root
        HOME=/root
        GROUPS=root dialout
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           976M          0B        976M
                 7807 M total memory
                 3848 M used memory
                  460 M active memory
                 2650 M free memory
                   82 M buffer memory
                 1225 M swap cache
                  976 M total swap
                    0 M used swap
                  976 M free swap
        *** FILESYSTEM ***
        /var:
        8.7G    /var/
        4.4G    /var/lib
        4.2G    /var/log
        USB-Devices by-id:
        /usr/bin/npm            9.2.0
        /usr/bin/npx            9.2.0
        corepack:       N/A
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.2.23
        javascript:     5.7.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        26883
        States:         21788
        @rccardany
        Hampel da nicht als root herum. User anlegen und den verwenden.
        Falsches nodejs. Bring das auf die nodesource-Variante:
        iob nodejs-update
        Ist nicht dein Ernst, oder?
        Zeig mal die Datei /etc/apt/sources.list her.
        cat /etc/apt/sources.list
        R 1 Antwort Letzte Antwort
          @rccardany
          iob nodejs-update
          rccardany
          @thomas-braun said in Zigbee Conbee:
          ioBroker nodejs updater 2023-10-13
          Recommended nodejs-version is: 16.20.2
          Checking your installation now. Please be patient!
          Your current setup is:
          /usr/bin/npm            9.2.0
          /usr/bin/npx            9.2.0
          We found these nodejs versions available for installation:
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v18.19.0. Do you want to install recommended version 16.20.2?
          Press <y> to continue or any other key to quit
          We are not updating your installation. Exiting.
          root@zbox:/home/pi# cat /etc/apt/sources.list
          deb http://deb.debian.org/debian bookworm main non-free-firmware
          deb-src http://deb.debian.org/debian bookworm main non-free-firmware
          deb http://deb.debian.org/debian-security/ bookworm-security main non-free-firmware
          deb-src http://deb.debian.org/debian-security/ bookworm-security main non-free-firmware
          deb http://deb.debian.org/debian bookworm-updates main non-free-firmware
          deb-src http://deb.debian.org/debian bookworm-updates main non-free-firmware
          root@zbox:/home/pi#
          • R rccardany
            /usr/bin/npm            9.2.0
            /usr/bin/npx            9.2.0
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            root@zbox:/home/pi#
            @rccardany sagte in Zigbee Conbee:
            root@zbox:/home/pi
            Du hampelst ja immer noch als root herum...
            Ich bin dann raus. Meld dich als pi oder was auch immer da noch an usern vorhanden ist an und arbeite ordentlich mit dem System.
              root@zbox:/home/pi
              rccardany
              naja ich habe den iobroker installiert und wüsste nicht dass ich dazu einen passwort vergeben habe
              wenn ich mich als pi anmelde dann will er, dass ich den Befehl als admin ausführe:
              pi@zbox:~$ iob nodejs-update
              [sudo] Passwort für pi:
              Leider darf der Benutzer pi »/usr/bin/curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh« als iobroker auf zbox.default nicht ausführen.
              pi@zbox:~$
              • R rccardany
                pi@zbox:~$
                @rccardany
                Dann ist der pi nicht in den richtigen Gruppen enthalten. Also falsch konfiguriert worden...
                Ist der wenigstens bei 'sudo' drin?
                sudo usermod -a -G iobroker pi
                exit
                  @rccardany
                  exit
                  rccardany
                  exit
                  anbei dir RM
                  pi@zbox:~$ sudo usermod -a -G iobroker pi
                  Leider darf der Benutzer pi »/usr/sbin/usermod -a -G iobroker pi« als root auf z        box.default nicht ausführen.
                  • R rccardany
                    exit
                    anbei dir RM
                    @rccardany
                    apt policy sudo
                    groups
                    sagt?
                      @rccardany
                      apt policy sudo
                      groups
                      sagt?
                      rccardany
                      groups
                      pi@zbox:~$ apt policy sudo
                      sudo:
                        Installiert:           1.9.5p2-3+deb11u1
                        Installationskandidat: 1.9.13p3-1+deb12u1
                        Versionstabelle:
                           1.9.13p3-1+deb12u1 500
                       *** 1.9.5p2-3+deb11u1 100
                      pi@zbox:~$ groups
                      pi dialout iobroker
                      pi@zbox:~$
                      • R rccardany
                        groups
                        sudo:
                          Versionstabelle:
                        pi@zbox:~$ groups
                        pi dialout iobroker
                        pi@zbox:~$
                        @rccardany
                        Dann als root:
                        usermod -a -G sudo pi
                        Dann wieder als pi anmelden und den Mist mit dem root sein lassen.
                          @rccardany
                          Dann als root:
                          rccardany
                          @thomas-braun erledigt und nun?
                          Thomas BraunT R 2 Antworten Letzte Antwort
                          • R rccardany
                            @rccardany
                            sudo whoami
                            grep stretch -R /etc/apt/*
                            • R rccardany
                              rccardany
                              schrieb am zuletzt editiert von rccardany
                              @rccardany
                              pi@testpi:~ $ sudo whoami
                              root
                              pi@testpi:~ $ grep stretch -R /etc/apt/*
                              • R rccardany
                                @rccardany
                                root
                                @rccardany
                                sudo apt update
                                sudo apt full-upgrade
                                  @rccardany
                                  sudo apt update
                                  rccardany
                                  ich bin zwar nur ein Anwender ohne Fachkenntniss aber ich habe die Erfahrung gemacht dass ich nicht wirklich gut in der Vergangenheit mit Updaten auf latest greatest gefahren bin.
                                  Oft gehen Funktionen dann nicht mehr oder ich muss einiges neu einrichten / einstellen.
                                  Daher bin ich mit never change a running system eigentlich immer gut gefahren
                                  Wie bekomme ich den adapter zum laufen ohne das gesamte system auf neuesten stand zu bringen?
                                  • R rccardany
                                    Arrrrrrrrrrrrgh. NEIN.
                                    Halt die Kiste auf einem aktuellen Stand. Immer.
                                    Gar nicht.
