  4. Zigbee Conbee
Zigbee Conbee
23 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • Thomas BraunT Online
    @rccardany
    Dann zeig den Rest.
    R 1 Antwort Letzte Antwort
      @rccardany
      Dann zeig den Rest.
      rccardany
      Skript v.2024-04-21
      *** BASE SYSTEM ***
         Static hostname: zbox
               Icon name: computer-desktop
                 Chassis: desktop
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-21-amd64
            Architecture: x86-64
      model name      : Intel(R) Celeron(R) CPU N3450 @ 1.10GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       09:16:46 up  1:15,  1 user,  load average: 1.46, 1.04, 0.91
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Fri 2024-05-10 09:16:47 CEST
                 Universal time: Fri 2024-05-10 07:16:47 UTC
                       RTC time: Fri 2024-05-10 07:16:47
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      root
      JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64/jre/
      HOME=/root
      GROUPS=root dialout
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        3.8G        2.7G        0.0K        1.3G        3.8G
      Swap:           976M          0B        976M
      Total:          8.8G        3.8G        3.6G
      Active iob-Instances:   34
               7807 M total memory
               3848 M used memory
                460 M active memory
               4391 M inactive memory
               2650 M free memory
                 82 M buffer memory
               1225 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      top - 09:16:47 up  1:15,  1 user,  load average: 1.46, 1.04, 0.91
      Tasks: 163 total,   1 running, 162 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  7.7 us,  3.1 sy,  0.0 ni, 89.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7807.1 total,   2650.1 free,   3848.7 used,   1308.3 buff/cache
      MiB Swap:    977.0 total,    977.0 free,      0.0 used.   3846.8 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     781M  780K  780M   1% /run
      /dev/sda2      ext4      116G   15G   95G  14% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sda1      vfat      511M   11M  501M   3% /boot/efi
      tmpfs          tmpfs     781M     0  781M   0% /run/user/1002
      [Fri May 10 08:01:33 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Fri May 10 08:01:35 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems:
      TARGET                        SOURCE     FSTYPE     OPTIONS
      /                             /dev/sda2  ext4       rw,relatime,errors=remount-ro
      |-/sys                        sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security      securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup            cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore            pstore     pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/firmware/efi/efivars efivarfs   efivarfs   rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf               none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug         debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing       tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections  fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config        configfs   configfs   rw,nosuid,nodev,noexec,relatime
      |-/proc                       proc       proc       rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc  systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=10697
      |-/dev                        udev       devtmpfs   rw,nosuid,relatime,size=3989856k,nr_inodes=997464,mode=755
      | |-/dev/pts                  devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                  tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/hugepages            hugetlbfs  hugetlbfs  rw,relatime,pagesize=2M
      | `-/dev/mqueue               mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
      |-/run                        tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=799448k,mode=755
      | |-/run/lock                 tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs           sunrpc     rpc_pipefs rw,relatime
      | `-/run/user/1002            tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=799448k,nr_inodes=199862,mode=700,uid=1002,gid=1002
      `-/boot/efi                   /dev/sda1  vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      8.7G    /var/
      4.4G    /var/lib
      4.2G    /var/log
      4.0G    /var/log/journal/b8af39a4a3f84f64bf60ee5243aa6c0c
      Archived and active journals take up 3.9G in the file system.
      /opt/iobroker/backups:
      714M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      247M    /opt/iobroker/iobroker-data/
      111M    /opt/iobroker/iobroker-data/files
      63M     /opt/iobroker/iobroker-data/backup-objects
      36M     /opt/iobroker/iobroker-data/node-red
      35M     /opt/iobroker/iobroker-data/node-red/node_modules
      27M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/states.jsonl
      12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.ea6ad656.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      6.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.1d439ead.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2141436-if00
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      corepack:       N/A
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 18.19.0+dfsg-6~deb12u1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.2.23
      javascript:     5.7.0
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : zbox                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : zbox                                     -  enabled
      + system.adapter.backitup.0               : backitup              : zbox                                     -  enabled
        system.adapter.cloud.0                  : cloud                 : zbox                                     - disabled
        system.adapter.daswetter.0              : daswetter             : zbox                                     - disabled
      + system.adapter.discovery.0              : discovery             : zbox                                     - disabled
      + system.adapter.fakeroku.0               : fakeroku              : zbox                                     -  enabled
      + system.adapter.harmony.0                : harmony               : zbox                                     -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : zbox                                     -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : zbox                                     -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : zbox                                     -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : zbox                                     -  enabled
      + system.adapter.influxdb.0               : influxdb              : zbox                                     -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : zbox                                     -  enabled
      + system.adapter.javascript.0             : javascript            : zbox                                     -  enabled
        system.adapter.kodi.0                   : kodi                  : zbox                                     - disabled, port: 9090
        system.adapter.linux-control.0          : linux-control         : zbox                                     -  enabled
        system.adapter.mclighting.0             : mclighting            : zbox                                     - disabled, port: 81
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : zbox                                     - disabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : zbox                                     -  enabled
      + system.adapter.modbus.1                 : modbus                : zbox                                     -  enabled
      + system.adapter.modbus.2                 : modbus                : zbox                                     -  enabled
      + system.adapter.modbus.3                 : modbus                : zbox                                     -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : zbox                                     -  enabled, port: 1883, bind: 192.168.1.171
        system.adapter.mqtt.2                   : mqtt                  : zbox                                     -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.3                   : mqtt                  : zbox                                     -  enabled, port: 1885, bind: 0.0.0.0
        system.adapter.mqtt.4                   : mqtt                  : zbox                                     -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.5                   : mqtt                  : zbox                                     -  enabled, port: 1888, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : zbox                                     -  enabled
      + system.adapter.node-red.0               : node-red              : zbox                                     -  enabled, port: 1880, bind: 192.168.1.171
        system.adapter.octoprint.0              : octoprint             : zbox                                     - disabled
      + system.adapter.parser.0                 : parser                : zbox                                     -  enabled
      + system.adapter.ping.0                   : ping                  : zbox                                     -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : zbox                                     -  enabled
      + system.adapter.shelly.0                 : shelly                : zbox                                     -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.solax.0                  : solax                 : zbox                                     -  enabled
        system.adapter.sonoff.0                 : sonoff                : zbox                                     - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.spotify-premium.0        : spotify-premium       : zbox                                     - disabled
        system.adapter.telegram.0               : telegram              : zbox                                     -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.1               : telegram              : zbox                                     -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : zbox                                     -  enabled
      + system.adapter.tibberlink.0             : tibberlink            : zbox                                     -  enabled
        system.adapter.unifi.0                  : unifi                 : zbox                                     - disabled
        system.adapter.web.0                    : web                   : zbox                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : zbox                                     -  enabled
      + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : zbox                                     -  enabled
      + system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : zbox                                     -  enabled
      + system.adapter.zigbee.0                 : zigbee                : zbox                                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2141436-if00
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.2.23 [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.25.5 [Updatable]
      Adapter    "backitup"     : 2.11.0   , installed 2.5.4  [Updatable]
      Adapter    "bshb"         : 0.2.7    , installed 0.2.4  [Updatable]
      Adapter    "cloud"        : 5.0.1    , installed 4.3.0  [Updatable]
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.8  [Updatable]
      Adapter    "deconz"       : 1.4.0    , installed 1.3.21 [Updatable]
      Adapter    "discovergy"   : 0.5.13   , installed 0.5.8  [Updatable]
      Adapter    "discovery"    : 4.4.0    , installed 3.1.0  [Updatable]
      Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
      Adapter    "harmony"      : 1.4.0    , installed 1.2.2  [Updatable]
      Adapter    "hm-rega"      : 4.0.0    , installed 3.0.40 [Updatable]
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.12 [Updatable]
      Adapter    "homeconnect"  : 1.3.0    , installed 1.1.1  [Updatable]
      Adapter    "iot"          : 2.0.11   , installed 1.11.4 [Updatable]
      Adapter    "javascript"   : 7.8.0    , installed 5.7.0  [Updatable]
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "kodi"         : 3.0.0    , installed 2.0.8  [Updatable]
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 3.8.6  [Updatable]
      Adapter    "modbus"       : 6.1.0    , installed 4.0.4  [Updatable]
      Adapter    "mqtt"         : 5.2.0    , installed 3.0.6  [Updatable]
      Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "node-red"     : 5.2.1    , installed 3.3.0  [Updatable]
      Adapter    "octoprint"    : 5.1.0    , installed 3.2.0  [Updatable]
      Adapter    "opi"          : 0.1.2    , installed 0.1.1  [Updatable]
      Adapter    "parser"       : 2.1.0    , installed 1.1.8  [Updatable]
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.0  [Updatable]
      Adapter    "shelly"       : 6.9.0    , installed 5.3.2  [Updatable]
      Adapter    "socketio"     : 6.7.0    , installed 4.2.0  [Updatable]
      Adapter    "solax"        : 0.9.6    , installed 0.7.7  [Updatable]
      Adapter    "sonoff"       : 3.0.3    , installed 2.5.1  [Updatable]
      Adapter    "spotify-premium": 1.4.0  , installed 1.2.1  [Updatable]
      Adapter    "systeminfo"   : 1.1.0    , installed 0.3.1  [Updatable]
      Adapter    "telegram"     : 3.2.1    , installed 1.12.6 [Updatable]
      Adapter    "text2command" : 3.0.3    , installed 2.2.1  [Updatable]
      Adapter    "tibberlink"   : 2.3.2    , installed 1.4.2  [Updatable]
      Adapter    "tinker"       : 1.3.2    , installed 1.1.1  [Updatable]
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "unifi"        : 0.7.0    , installed 0.5.10 [Updatable]
      Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.6.1    , installed 1.3.0  [Updatable]
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        26883
      States:         21788
      E: The repository 'http://ftp.nl.debian.org/debian stretch Release' does not have a Release file.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D68FA50FEA312927
      Pending Updates: 419
      *** Listening Ports ***
      2024-05-10 09:16:47.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:16:52.167  - info: influxdb.0 (870) Store 51 buffered influxDB history points
      2024-05-10 09:16:52.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:16:57.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:01.898  - info: influxdb.0 (870) Store 51 buffered influxDB history points
      2024-05-10 09:17:02.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:07.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:09.299  - info: influxdb.0 (870) Store 52 buffered influxDB history points
      2024-05-10 09:17:12.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:15.544  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:18.954  - info: influxdb.0 (870) Store 51 buffered influxDB history points
      2024-05-10 09:17:22.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:27.086  - info: influxdb.0 (870) Store 51 buffered influxDB history points
      2024-05-10 09:17:27.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:32.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:35.680  - info: influxdb.0 (870) Store 51 buffered influxDB history points
      2024-05-10 09:17:37.394  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:42.005  - info: influxdb.0 (870) Store 51 buffered influxDB history points
      2024-05-10 09:17:42.425  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:47.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:50.094  - info: influxdb.0 (870) Store 51 buffered influxDB history points
      2024-05-10 09:17:52.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:17:57.384  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      2024-05-10 09:18:01.101  - info: influxdb.0 (870) Store 51 buffered influxDB history points
      2024-05-10 09:18:02.424  - error: parser.0 (2395) Cannot read link "http://192.168.178.80/json": Error: connect EHOSTUNREACH 192.168.178.80:80
      iob diag has finished.
      R Thomas BraunT 2 Antworten Letzte Antwort
      • R rccardany
        Skript v.2024-04-21
        *** BASE SYSTEM ***
                   Chassis: desktop
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        root
        HOME=/root
        GROUPS=root dialout
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           976M          0B        976M
                 7807 M total memory
                 3848 M used memory
                  460 M active memory
                 2650 M free memory
                   82 M buffer memory
                 1225 M swap cache
                  976 M total swap
                    0 M used swap
                  976 M free swap
        *** FILESYSTEM ***
        /var:
        8.7G    /var/
        4.4G    /var/lib
        4.2G    /var/log
        USB-Devices by-id:
        /usr/bin/npm            9.2.0
        /usr/bin/npx            9.2.0
        corepack:       N/A
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.2.23
        javascript:     5.7.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        26883
        States:         21788
        rccardany
        @rccardany
        v.2024-04-21
        Chassis: desktop
        Installation: native
        Kernel: x86_64
        Userland: 64 bit
        Timezone: Europe/Berlin (CEST, +0200)
        User-ID: 0
        Boot Target: graphical.target
        Pending OS-Updates: 419
        Pending iob updates: 39
        Nodejs-Installation:
        /usr/bin/npm 9.2.0
        /usr/bin/npx 9.2.0
        corepack: N/A
        Recommended versions are nodejs 16.20.2 and npm 8.19.4
        Wrong installation path detected. This needs to be fixed
        Please execute
        iobroker nodejs-update
        to fix these errors.
        MEMORY:
        total used free shared buff/cache available
        Mem: 7.8G 3.9G 2.4G 0.0K 1.5G 3.8G
        Swap: 976M 0B 976M
        Total: 8.8G 3.9G 3.3G
        ioBroker Core: js-controller 5.0.19
        admin 6.2.23
        ioBroker Status: iobroker is running on this host.
        Objects type: jsonl
        States type: jsonl
        • system.adapter.admin.0 : admin : zbox - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        Objects: 26883
        States: 21788
        Size of iob-Database:
        === Mark text until here for copying ===
        • R rccardany
          Skript v.2024-04-21
          *** BASE SYSTEM ***
                     Chassis: desktop
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          root
          HOME=/root
          GROUPS=root dialout
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           976M          0B        976M
                   7807 M total memory
                   3848 M used memory
                    460 M active memory
                   2650 M free memory
                     82 M buffer memory
                   1225 M swap cache
                    976 M total swap
                      0 M used swap
                    976 M free swap
          *** FILESYSTEM ***
          /var:
          8.7G    /var/
          4.4G    /var/lib
          4.2G    /var/log
          USB-Devices by-id:
          /usr/bin/npm            9.2.0
          /usr/bin/npx            9.2.0
          corepack:       N/A
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.2.23
          javascript:     5.7.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        26883
          States:         21788
          @rccardany
          Hampel da nicht als root herum. User anlegen und den verwenden.
          Falsches nodejs. Bring das auf die nodesource-Variante:
          iob nodejs-update
          Ist nicht dein Ernst, oder?
          Zeig mal die Datei /etc/apt/sources.list her.
          cat /etc/apt/sources.list
            @rccardany
            iob nodejs-update
            rccardany
            @thomas-braun said in Zigbee Conbee:
            ioBroker nodejs updater 2023-10-13
            Recommended nodejs-version is: 16.20.2
            Checking your installation now. Please be patient!
            Your current setup is:
            /usr/bin/npm            9.2.0
            /usr/bin/npx            9.2.0
            We found these nodejs versions available for installation:
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            Nothing to do - Your installation is using the correct paths.
            You are running nodejs v18.19.0. Do you want to install recommended version 16.20.2?
            Press <y> to continue or any other key to quit
            We are not updating your installation. Exiting.
            root@zbox:/home/pi# cat /etc/apt/sources.list
            deb http://deb.debian.org/debian bookworm main non-free-firmware
            deb-src http://deb.debian.org/debian bookworm main non-free-firmware
            deb http://deb.debian.org/debian-security/ bookworm-security main non-free-firmware
            deb-src http://deb.debian.org/debian-security/ bookworm-security main non-free-firmware
            deb http://deb.debian.org/debian bookworm-updates main non-free-firmware
            deb-src http://deb.debian.org/debian bookworm-updates main non-free-firmware
            root@zbox:/home/pi#
            • R rccardany
              /usr/bin/npm            9.2.0
              /usr/bin/npx            9.2.0
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              root@zbox:/home/pi#
              @rccardany sagte in Zigbee Conbee:
              root@zbox:/home/pi
              Du hampelst ja immer noch als root herum...
              Ich bin dann raus. Meld dich als pi oder was auch immer da noch an usern vorhanden ist an und arbeite ordentlich mit dem System.
                root@zbox:/home/pi
                rccardany
                naja ich habe den iobroker installiert und wüsste nicht dass ich dazu einen passwort vergeben habe
                wenn ich mich als pi anmelde dann will er, dass ich den Befehl als admin ausführe:
                pi@zbox:~$ iob nodejs-update
                [sudo] Passwort für pi:
                Leider darf der Benutzer pi »/usr/bin/curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh« als iobroker auf zbox.default nicht ausführen.
                pi@zbox:~$
                • R rccardany
                  pi@zbox:~$
                  @rccardany
                  Dann ist der pi nicht in den richtigen Gruppen enthalten. Also falsch konfiguriert worden...
                  Ist der wenigstens bei 'sudo' drin?
                  sudo usermod -a -G iobroker pi
                  exit
                    @rccardany
                    exit
                    rccardany
                    exit
                    anbei dir RM
                    pi@zbox:~$ sudo usermod -a -G iobroker pi
                    Leider darf der Benutzer pi »/usr/sbin/usermod -a -G iobroker pi« als root auf z        box.default nicht ausführen.
                    • R rccardany
                      exit
                      anbei dir RM
                      @rccardany
                      apt policy sudo
                      groups
                      sagt?
                        @rccardany
                        apt policy sudo
                        groups
                        sagt?
                        rccardany
                        groups
                        pi@zbox:~$ apt policy sudo
                        sudo:
                          Installiert:           1.9.5p2-3+deb11u1
                          Installationskandidat: 1.9.13p3-1+deb12u1
                          Versionstabelle:
                             1.9.13p3-1+deb12u1 500
                         *** 1.9.5p2-3+deb11u1 100
                        pi@zbox:~$ groups
                        pi dialout iobroker
                        pi@zbox:~$
                        • R rccardany
                          groups
                          sudo:
                            Versionstabelle:
                          pi@zbox:~$ groups
                          pi dialout iobroker
                          pi@zbox:~$
                          @rccardany
                          Dann als root:
                          usermod -a -G sudo pi
                          Dann wieder als pi anmelden und den Mist mit dem root sein lassen.
                            @rccardany
                            Dann als root:
                            rccardany
                            @thomas-braun erledigt und nun?
                            Thomas BraunT R 2 Antworten Letzte Antwort
                            • R rccardany
                              @rccardany
                              sudo whoami
                              grep stretch -R /etc/apt/*
                              • R rccardany
                                rccardany
                                schrieb am zuletzt editiert von rccardany
                                @rccardany
                                pi@testpi:~ $ sudo whoami
                                root
                                pi@testpi:~ $ grep stretch -R /etc/apt/*
                                • R rccardany
                                  @rccardany
                                  root
                                  @rccardany
                                  sudo apt update
                                  sudo apt full-upgrade
                                    @rccardany
                                    sudo apt update
                                    rccardany
                                    ich bin zwar nur ein Anwender ohne Fachkenntniss aber ich habe die Erfahrung gemacht dass ich nicht wirklich gut in der Vergangenheit mit Updaten auf latest greatest gefahren bin.
                                    Oft gehen Funktionen dann nicht mehr oder ich muss einiges neu einrichten / einstellen.
                                    Daher bin ich mit never change a running system eigentlich immer gut gefahren
                                    Wie bekomme ich den adapter zum laufen ohne das gesamte system auf neuesten stand zu bringen?
                                    • R rccardany
                                      Arrrrrrrrrrrrgh. NEIN.
                                      Halt die Kiste auf einem aktuellen Stand. Immer.
                                      Gar nicht.
