  4. JavaScript
  5. HowTo: Zusatz-Programme fuer jarvis v3
    1.0k
javascript
899 Beiträge 33 Kommentatoren 326.0k Aufrufe 36 Beobachtet
  • wolfi913W wolfi913
    @mcu sagte in HowTo: Zusatz-Programme fuer jarvis v3:
    @wolfi913 Genau.
    Nimm mal bitte count raus:
    // count: dataLimitValue
    Send: 502 of: 501 in: 70ms
    0_userdata.0.PV.SignedBat17150970902550.21461031104686312 getHistory message: {"id":"0_userdata.0.PV.SignedBat","options":{"start":1715010686903,"end":1715097086903,"aggregate":"onchange","limit":5000,"ignoreNull":true}}
    Query to execute: from(bucket: "iobroker_short") |> range(start: 2024-05-06T15:51:26.903Z, stop: 2024-05-07T15:51:26.903Z) |> filter(fn: (r) => r["_field"] == "value") |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.PV.SignedBat" and contains(value: r._value, set: [true, false])) |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group()
    Query to execute: from(bucket: "iobroker_short") |> range(start: 2024-02-04T15:51:26.903Z, stop: 2024-05-06T15:51:26.902Z) |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.PV.SignedBat") |> last() |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
    Query to execute: from(bucket: "iobroker_short") |> range(start: 2024-05-06T15:51:26.903Z, stop: 2024-05-07T15:51:26.903Z) |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.PV.SignedBat") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group() |> sort(columns:["_time"], desc: false) |> limit(n: 500)
    Query to execute: from(bucket: "iobroker_short") |> range(start: 2024-05-07T15:51:26.904Z) |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.PV.SignedBat") |> first() |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
    Send: 502 of: 501 in: 64ms
    MCU
    #592
    @wolfi913 Ja und das darf laut Programm (main.js iobroker.influxDB) gar nicht passieren.
    https://github.com/ioBroker/ioBroker.influxdb/blob/a7214d819f29556d8f1b3e7cf5b4c1d506a1ff1f/main.js#L1964
    wolfi913W 1 Antwort Letzte Antwort
    • M MCU
      wolfi913W Offline
      wolfi913W Offline
      wolfi913
      #593
      Scheint also so, dass der Bug im influx-Adapter liegt? Ich stellt auf alle Fälle bei mir momentan mal den Chart auf history um.
        MCU
        #594
        @wolfi913 Du könntest nochmal ein Upload für die influxDB versuchen und wieder umstellen auf info, sonst haut es dir das LOG voll.
        wolfi913W 2 Antworten Letzte Antwort
        • M MCU
          wolfi913W Offline
          wolfi913W Offline
          wolfi913
          #595
          Hab ich schon umgestellt
          • M MCU
            wolfi913W Offline
            wolfi913W Offline
            wolfi913
            schrieb am zuletzt editiert von wolfi913
            #596
            @mcu
            Mir ist gerade zwischendrin im Log noch was aufgefallen. Hatte ich vorher nie gesehen. Denke ein warn wär mir normalerweise aufgefallen
            warn	script.js.jarvis.eChartsHistoryGetData: Timeout -> DP 0_userdata.0.PV.SignedBat nicht vorhanden in DB: influxdb.1
            Ziemlich sonderbar. Es werden ja scheinbar trotzdem Daten geliefert und der DP ist definitiv in der InfluxDB da.
            Ergänzung:
            Hab jetzt kurz nochmal auf influx zurückgestellt. Die warn ist nicht nochmal aufgetaucht. Trotz mehrmaligem F5.
            Möglicherweise tatsächlich nur einmalig vorgekommen.
              @mcu
              Ergänzung:
              MCU
              #597
              @wolfi913 Taucht auch nur als "Hinweis" auf, wenn history-Abfrage einen timeout produziert. Kann auch evtl mit der Anzahl der Werte zusammenhängen?
              Hattest du mal ein Upload gemacht um danach nochmal die nur limit für influx zu testen?
              iob upload influxdb
              • M MCU
                iob upload influxdb
                wolfi913W Offline
                wolfi913W Offline
                wolfi913
                #598
                @mcu
                ok 👍
                Mach ich gleich noch, bin nur zwischendrin aufgehalten worden
                Upload gemacht und nochmal mit Limit: 5000 ohne Count getestet. Weiterhin nur 502 Werte
                  @mcu
                  ok 👍
                  MCU
                  #599
                  @wolfi913 Problem erkannt. Der Adapter setzt schon selbst count auf 500
                  https://github.com/ioBroker/ioBroker.influxdb/blob/a7214d819f29556d8f1b3e7cf5b4c1d506a1ff1f/main.js#L1978
                  und fragt noch ab, ob options.count gesetzt wurde.
                  https://github.com/ioBroker/ioBroker.influxdb/blob/a7214d819f29556d8f1b3e7cf5b4c1d506a1ff1f/main.js#L1995
                  Ist es damit aber schon und somit geht er gar nicht in die entscheidende Abfrage.
                  Issue aufgemacht:
                  https://github.com/ioBroker/ioBroker.influxdb/issues/391
                  • M MCU
                    Issue aufgemacht:
                    wolfi913W Offline
                    wolfi913W Offline
                    wolfi913
                    #600
                    @mcu
                    Dann schauen wir mal ob sich da im Adapter was ändert. Ich bleib ich momentan mal für den Chart auf der historyDB. Wenn sich im influx-Adapter was Neues tut kann ich ja nochmal durchprobieren.
                    • M MCU
                      @wolfi913
                      Das ist ja nicht zielführend, da, wenn du 2 Tage wählst, wieder nicht alles angezeigt wird?
                      EDIT: Du kannst mal die influxDB-Instanz auf debug stellen, und dann bei jarvis ein Refresh durchführen.
                      -> LOG query Aufruf zu DB wird angezeigt.
                      // Es kommen Einträge mit
                      History-Queries to execute:
                      @apollon77 limit zieht nicht für influxDB? (Bei historyDB ist alles ok)
                      Es werden bei limit: 5000, nur 502 angzeigt. Setzt man zusätzlich count: 5000, werden auch aus influxDB 5000 geholt, aber wenn mehr vorhanden sind wird die Kurve abgebrochen.
                      -> limit scheint fest im Adapter definiert zu sein bei influxDB.
                      Issue aufmachen?
                      // Hiernach sollte es egal sein, ob limit oder count gesetzt wird
                      limit:      parseInt(msg.message.options.limit, 10) || parseInt(msg.message.options.count, 10) || adapter.config.limit || 2000,
                      // hiernach sollte er bei onchange limit nutzen, wenn count nicht gesetzt
                      if (!options.count || isNaN(options.count)) {
                              if (options.aggregate === 'none' || options.aggregate === 'onchange') {
                                  options.count = options.limit;
                              } else {
                                  options.count = 500;
                      #601
                      @mcu Da gibts brlaube ein known issue in influxdb adapter ... kam ich bisher noch nicht dazu final zu fixen ... Bitte mal schauen obs da sgleiche oder was anderes ist
                        MCU
                        #602
                        @apollon77 Ich hatte den Issue dort eingetragen nachdem ich den Fehler feststellen konnte.
                        • M MCU
                          #603
                          @mcu Cool, auch danke für die Infos und Links. Willst du mal Fix versuchen und PR machen wenn Du die stelle und Vergleich zu History schon hast? Oder soll ich schauen das ich die tage zeit finde?
                          • apollon77A apollon77
                            MCU
                            #604
                            @apollon77 Gibt es igrendwo eine Anleitung dazu, wie man ein PR erstellt?
                            Gefunden:
                            https://www.youtube.com/watch?v=l8MZCnrSeQQ
                            • M MCU
                              Gefunden:
                              #605
                              @mcu Am Ende sehr einfach: GitHub Webseite ... datei auswählen und oben rechts auf den Stift klicken. Änderung machen, runter scrollen. Infos angeben zur Änderung, Absenden, Nächste Seite "PR erstellen" klicken und "fertig"
                                MCU
                                #606
                                @apollon77 Ich hoffe richtig erstellt.
                                https://github.com/ioBroker/ioBroker.influxdb/pull/392
                                • M MCU
                                  #607
                                  @mcu Jupp schaue ich mir an die Tage
                                    MCU
                                    #608
                                    @Bernd1967 Bitte hier weitermachen.
                                    • P Offline
                                      pingo
                                      #609
                                      Mein TibberHTMLTomorrow ist seit einiger Zeit auch am Nachmittag leer:
                                      z.B. heute 16.53:
                                      Habe ich da irgendein Update verpasst?
                                      • P pingo
                                        z.B. heute 16.53:
                                        MCU
                                        #610
                                        @pingo
                                        Vielleicht hat sich die Datenstruktur geändert? Ich selber habe kein Tibber und brauche somit die Daten, um es prüfen zu können. Bitte einmal Daten exportieren und die ID rausnehmen. Immer so bekommen
                                        P 1 Antwort Letzte Antwort
                                        • M MCU
                                          @pingo
                                          pingo
                                          #611
                                          @mcu
                                          tibberlink.0.Homes.pingo.json
                                          Danke für die schnelle Reaktion und Hilfe
