  4. Iobroker startet nicht mehr nach Restore
59 Beiträge 5 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • B Bill S. Preston
    Kann es sein, dass sich das Backup vom alten System mit dem neuen beißt?
    Hier
    iob start web
    vom alten noch laufenden System.
    Skript v.2024-04-21
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     11:23:56 up 11:39,  2 users,  load average: 1.59, 1.08, 0.89
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-05-06 11:23:56 CEST
               Universal time: Mon 2024-05-06 09:23:56 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    XDG_CONFIG_HOME=/home/pi/.config
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker myftp
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video bluetooth gpio i2c myftp
    *** Display-Server-Setup ***
    Display-Server: true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           3.8G        2.0G        260M         92M        1.6G        1.8G
    Swap:           99M         42M         57M
    Total:         3.9G        2.0G        317M
    Active iob-Instances: 	34
             3838 M total memory
             1980 M used memory
              788 M active memory
             2619 M inactive memory
              259 M free memory
              272 M buffer memory
             1325 M swap cache
               99 M total swap
               42 M used swap
               57 M free swap
    top - 11:23:57 up 11:39,  2 users,  load average: 1.59, 1.08, 0.89
    Tasks: 209 total,   1 running, 207 sleeping,   0 stopped,   1 zombie
    %Cpu(s):  7.2 us,  5.8 sy,  0.0 ni, 87.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3838.7 total,    259.5 free,   1980.4 used,   1598.8 buff/cache
    MiB Swap:    100.0 total,     57.7 free,     42.2 used.   1826.4 avail Mem
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   22G   34G  40% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  864K  1.9G   1% /dev/shm
    tmpfs          tmpfs     1.9G   57M  1.9G   3% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      ext4       57G   33G   21G  61% /backup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M  4.0K  384M   1% /run/user/1000
    [Sun May  5 23:44:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1024x768M@60D smsc95xx.macaddr=DC:A6:32:30:EB:D6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5cd8a1b8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sun May  5 23:44:19 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun May  5 23:44:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun May  5 23:44:22 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Sun May  5 23:44:25 2024] EXT4-fs (sda1): recovery complete
    [Sun May  5 23:44:25 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    Show mounted filesystems:
    TARGET                                SOURCE         FSTYPE          OPTIONS
    /                                     /dev/mmcblk0p2 ext4            rw,noatime
    |-/dev                                devtmpfs       devtmpfs        rw,relatime,size=1800568k,nr_inodes=84157,mode=755
    | |-/dev/shm                          tmpfs          tmpfs           rw,nosuid,nodev
    | |-/dev/pts                          devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                       mqueue         mqueue          rw,relatime
    |-/sys                                sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs          tmpfs           ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/blkio            cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,blkio
    | | |-/sys/fs/cgroup/pids             cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,pids
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/freezer          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,perf_event
    | | |-/sys/fs/cgroup/devices          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,devices
    | | `-/sys/fs/cgroup/cpuset           cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpuset
    | |-/sys/fs/bpf                       none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs        debugfs         rw,relatime
    | |-/sys/kernel/config                configfs       configfs        rw,relatime
    | `-/sys/fs/fuse/connections          fusectl        fusectl         rw,relatime
    |-/proc                               proc           proc            rw,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs          rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/run                                tmpfs          tmpfs           rw,nosuid,nodev,mode=755
    | |-/run/lock                         tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs      rw,relatime
    | `-/run/user/1000                    tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
    |   `-/run/user/1000/gvfs             gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/backup                             /dev/sda1      ext4            rw,relatime
    `-/boot                               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.9G	/var/
    1.4G	/var/lib
    1.2G	/var/lib/influxdb/data
    1.1G	/var/lib/influxdb/data/iobroker
    Archived and active journals take up 55.9M in the file system.
    /opt/iobroker/backups:
    6.3G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    414M	/opt/iobroker/iobroker-data/
    195M	/opt/iobroker/iobroker-data/files
    132M	/opt/iobroker/iobroker-data/backup-objects
    51M	/opt/iobroker/iobroker-data/files/javascript.admin
    33M	/opt/iobroker/iobroker-data/files/web.admin/static
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M	/opt/iobroker/iobroker-data/objects.jsonl
    18M	/opt/iobroker/iobroker-data/states.jsonl
    9.7M	/opt/iobroker/iobroker-data/objects.json.migrated
    9.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100FNC-if03
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100FNC-if00
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.20.2
    /usr/bin/node 		v18.20.2
    /usr/bin/npm 		10.5.0
    /usr/bin/npx 		10.5.0
    /usr/bin/corepack 	0.25.2
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.13.16
    javascript: 	6.1.4
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.23
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled
    + system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "cloud"        : 5.0.1    , installed 4.1.0  [Updatable]
    Adapter    "discovery"    : 4.4.0    , installed 2.6.1  [Updatable]
    Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
    Adapter    "email"        : 1.2.2    , installed 1.0.9  [Updatable]
    Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
    Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
    Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
    Adapter    "heatingcontrol": 2.12.5  , installed 2.3.2  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.16 [Updatable]
    Adapter    "ical"         : 1.14.3   , installed 1.7.4  [Updatable]
    Adapter    "icons-mfd-svg": 1.2.0    , installed 1.0.2  [Updatable]
    Adapter    "javascript"   : 7.8.0    , installed 6.1.4  [Updatable]
    Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
    Adapter    "lgtv"         : 2.2.0    , installed 2.1.1  [Updatable]
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.0.0  [Updatable]
    Adapter    "mqtt"         : 5.2.0    , installed 2.4.0  [Updatable]
    Adapter    "onvif"        : 1.1.3    , installed 0.4.4  [Updatable]
    Adapter    "openweathermap": 1.0.4   , installed 0.3.3  [Updatable]
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "sayit"        : 3.0.5    , installed 1.12.3 [Updatable]
    Adapter    "shelly"       : 6.9.0    , installed 6.3.1  [Updatable]
    Adapter    "socketio"     : 6.7.0    , installed 6.6.1  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
    Adapter    "telegram"     : 3.2.1    , installed 1.8.1  [Updatable]
    Adapter    "text2command" : 3.0.3    , installed 2.3.0  [Updatable]
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
    Adapter    "vis-icontwo"  : 1.5.0    , installed 0.93.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
    Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
    Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.6.1    , installed 2.5.11 [Updatable]
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects: 	11713
    States: 	10121
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Get:2 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Err:2 https://repos.influxdata.com/debian buster InRelease
    Fetched 12.9 kB in 2s (8498 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.23:2001     0.0.0.0:*               LISTEN      1001       536573     3566/io.hm-rpc.3
    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      117        19738      705/proftpd: (accep
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18287      559/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          41534      3077/cupsd
    tcp        0      0 0.0.0.0:5656            0.0.0.0:*               LISTEN      0          18860      779/motion
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        19649      517/influxd
    tcp        0      0 192.168.178.23:2010     0.0.0.0:*               LISTEN      1001       539134     3448/io.hm-rpc.1
    tcp        0      0 192.168.178.23:1882     0.0.0.0:*               LISTEN      1001       539067     3394/io.mqtt.0
    tcp        0      0 0.0.0.0:9595            0.0.0.0:*               LISTEN      0          18861      779/motion
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       539216     3521/io.sonoff.0
    tcp        0      0 192.168.178.23:8701     0.0.0.0:*               LISTEN      1001       539127     3441/io.hm-rpc.0
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          18979      428/python2
    tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14225      526/anydesk
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          18862      779/motion
    tcp        0      0 0.0.0.0:38149           0.0.0.0:*               LISTEN      0          525839     526/anydesk
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       536192     3307/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       536185     3307/iobroker.js-co
    tcp        0      0 192.168.178.23:9292     0.0.0.0:*               LISTEN      1001       541006     3463/io.hm-rpc.2
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       541910     3710/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        22642      517/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18289      559/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          41533      3077/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      110        20755      513/grafana-server
    tcp6       0      0 :::7777                 :::*                    LISTEN      1001       538566     3325/io.admin.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       540354     3502/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19750      445/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          41552      3079/cups-browsed
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       541081     3536/io.mihome-vacu
    udp        0      0 192.168.178.23:5353     0.0.0.0:*                           1001       539137     3420/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17531      374/avahi-daemon: r
    udp        0      0 0.0.0.0:47875           0.0.0.0:*                           108        17533      374/avahi-daemon: r
    udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          22556      526/anydesk
    udp6       0      0 :::5353                 :::*                                108        17532      374/avahi-daemon: r
    udp6       0      0 :::33120                :::*                                108        17534      374/avahi-daemon: r
    2024-05-06 11:24:16.473  - warn: javascript.0 (3382)     at processImmediate (node:internal/timers:476:21)
    2024-05-06 11:24:16.473  - warn: javascript.0 (3382) State "javascript.0.Stromverbrauch.Stromkosten_vorheriger_Tag" not found
    2024-05-06 11:24:16.475  - warn: javascript.0 (3382)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
    2024-05-06 11:24:16.475  - warn: javascript.0 (3382)     at Object.<anonymous> (script.js.Verbräuche.Stromverbrauch_gestern:5:3)
    2024-05-06 11:24:16.477  - warn: javascript.0 (3382)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    2024-05-06 11:24:16.477  - warn: javascript.0 (3382)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    2024-05-06 11:24:16.478  - warn: javascript.0 (3382)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
    2024-05-06 11:24:16.478  - warn: javascript.0 (3382)     at processImmediate (node:internal/timers:476:21)
    2024-05-06 11:24:21.813  - info: meross.0 (3483) Can not get Data for Device 1909127883156625186348e1e9034905: Error: Timeout
    2024-05-06 11:24:21.814  - warn: meross.0 (3483) Can not get Data for Device 1909127883156625186348e1e9034905: undefined
    2024-05-06 11:24:21.835  - info: meross.0 (3483) Can not get Data for Device 1801301547342725131134298f115e90: Error: Timeout
    2024-05-06 11:24:21.836  - warn: meross.0 (3483) Can not get Data for Device 1801301547342725131134298f115e90: undefined
    2024-05-06 11:24:21.864  - info: meross.0 (3483) Can not get Data for Device 1801306356734125131134298f115f59: Error: Timeout
    2024-05-06 11:24:21.865  - warn: meross.0 (3483) Can not get Data for Device 1801306356734125131134298f115f59: undefined
    2024-05-06 11:24:21.899  - info: meross.0 (3483) Can not get Data for Device 1801300540186725131134298f115ef4: Error: Timeout
    2024-05-06 11:24:21.900  - warn: meross.0 (3483) Can not get Data for Device 1801300540186725131134298f115ef4: undefined
    2024-05-06 11:24:40.484  - debug: onvif.0 (3778) startCameras
    2024-05-06 11:24:40.521  - debug: onvif.0 (3778) getDevices: [{"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
    2024-05-06 11:24:40.522  - debug: onvif.0 (3778) setCameras: [{"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
    2024-05-06 11:24:40.523  - debug: onvif.0 (3778) classCam: item = {"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2024-05-06 11:24:43.681  - error: onvif.0 (3778) classCam. Camera/NVT: "192.168.178.47:8899" Error: connect EHOSTUNREACH 192.168.178.47:8899
    2024-05-06 11:24:43.682  - debug: onvif.0 (3778) startCameras. cameras: {}
    2024-05-06 11:24:43.682  - warn: onvif.0 (3778) startCameras: Cameras/NVT unavailables
    2024-05-06 11:24:52.570  - warn: mqtt.0 (3394) Client [shelly1-E8DB84D496EE] has invalid password(h65cgi) or username(iobroker)
    2024-05-06 11:25:08.865  - warn: telegram.0 (3790) 1 of 1 recipients are unknown!
    Hier läuft noch der js-controller: 4.0.24. Im neuen ist der 5.0.19.
    Wie update ich den ?
    @bill-s-preston sagte in Iobroker startet nicht mehr nach Restore:
    Das kann schon sein. Das Alt-System verdient sich diesen Namen ja ganz besonders...
    Bring das zuerst mal auf Stand und dann ziehst du mit einem aktuellen Backup um.
      Bill S. Preston
      Wieso aktualisiert sich der js-controller mit
      obroker stop
      iobroker update
      iobroker upgrade self
      iobroker start
      nicht?
      • B Bill S. Preston
        obroker stop
        iobroker update
        iobroker start
        nicht?
        @bill-s-preston
        Ohne Meldungen kann dir das keiner sagen.
        • B Bill S. Preston
          @crunchip said in Iobroker startet nicht mehr nach Restore:
          motioneye.service loaded failed failed
          So viel ich weiß, müssen ggf Ports angepasst werden um Motioneye und iobroker zusammen auf einen Rechner laufen zu lassen
          Unabhängig davon, reichen 4GB RAM da eh nicht aus
          MoitonEye und Iobroker laufen seit zwei Jahren ohne Probleme zusammen auf einem 4GB Pi.
          Aber ich habe jetzt bei dem Neuen System versucht MotionEye zu öffnen. Leider ebenfalls Still.
          MotionEye lläuft aber auf Port 8765. Und wie gesagt, bis gestern vor dem Restore auch ohne Probleme.
          crunchipC Offline
          crunchipC Offline
          korrekt, die Benutzeroberfläche, die cams selbst aber dann 8081, 8082, 8083 usw
          daher auch auf deinem Alt System
            Bill S. Preston
            @crunchip
            cd /opt/iobroker
            sudo iobroker set admin.0 --port 7777
            hat geholfen. Iobroker kann wieder erreicht werden. 👍
            Nun fehlt noch MotionEye .
            Hier bekomme ich folgende meldung
            herke@raspberrypi:~ $ sudo systemctl status motioneye
            × motioneye.service - motionEye Server
                 Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; preset: en>
                 Active: failed (Result: exit-code) since Tue 2024-05-07 07:55:23 CEST; 18s>
               Duration: 1.494s
                Process: 1403 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioney>
               Main PID: 1403 (code=exited, status=255/EXCEPTION)
                    CPU: 1.493s
            May 07 07:55:22 raspberrypi systemd[1]: Started motioneye.service - motionEye S>
            May 07 07:55:23 raspberrypi meyectl[1403]: configure_logging cmd motioneye: Fal>
            May 07 07:55:23 raspberrypi meyectl[1403]: configure logging to file: None
            May 07 07:55:23 raspberrypi meyectl[1403]:     INFO: hello! this is motionEye s>
            May 07 07:55:23 raspberrypi meyectl[1403]: CRITICAL: pid directory "/var/run" d>
            May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Main process exited,>
            May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Failed with result '>
            May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Consumed 1.493s CPU >
            lines 1-16/16 (END)
                 Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; preset: enabled)
                 Active: failed (Result: exit-code) since Tue 2024-05-07 07:55:23 CEST; 18s ago
               Duration: 1.494s
                Process: 1403 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioneye/moti>
                    CPU: 1.493s
            Thomas BraunT crunchipC 3 Antworten Letzte Antwort
            • B Bill S. Preston
              @crunchip
              cd /opt/iobroker
                 Duration: 1.494s
                      CPU: 1.493s
              lines 1-16/16 (END)
                 Duration: 1.494s
                      CPU: 1.493s
              @bill-s-preston
              Bitte NIE, NIE, NIE das iobroker-Kommando per sudo anpacken.
              iob stop
              iob fix
              iob start
              • B Bill S. Preston
                @crunchip
                cd /opt/iobroker
                   Duration: 1.494s
                        CPU: 1.493s
                lines 1-16/16 (END)
                   Duration: 1.494s
                        CPU: 1.493s
                @bill-s-preston
                Und mach das Fenster von deinem Terminal groß. In der Ausgabe fehlen die Zeilenenden.
                  @bill-s-preston
                  iob stop
                  iob fix
                  iob start
                  Bill S. Preston
                  @thomas-braun said in Iobroker startet nicht mehr nach Restore:
                  @bill-s-preston
                  iob stop
                  iob fix
                  iob start
                  Alles klar. Was kann passieren wenn sudo benutzt wird?
                  • Thomas BraunT Online
                    Alles, weil der root halt alles darf.
                    Du verbiegst dir damit aber die vorgesehenen Rechte für die anderen user.
                      Bill S. Preston
                      Danke für die Info und für die Gedult!
                      Ich werde Shinobi installieren auf dem neuen System. Motioneye wird nicht mehr weiterentwickelt .
                      • B Bill S. Preston
                        @crunchip
                        cd /opt/iobroker
                           Duration: 1.494s
                                CPU: 1.493s
                        lines 1-16/16 (END)
                           Duration: 1.494s
                                CPU: 1.493s
                        crunchipC Offline
                        crunchipC Offline
                        @bill-s-preston eventuell
                        https://github.com/motioneye-project/motioneye/issues/2657
                        • B Bill S. Preston
                          crunchipC Offline
                          crunchipC Offline
                          Doch es wird an einer neuen Version gearbeitet
                            Bill S. Preston
                            schrieb am zuletzt editiert von Bill S. Preston
                            @crunchip
                            MotionEye deinstalieren funktionier nicht
                            herke@raspberrypi:~ $ pip uninstall motioneye
                            Found existing installation: motioneye 0.43.1b1
                            Uninstalling motioneye-0.43.1b1:
                              Would remove:
                                /usr/local/bin/motioneye_init
                                /usr/local/lib/python3.11/dist-packages/motioneye-0.43.1b1.dist-info/*
                                /usr/local/lib/python3.11/dist-packages/motioneye/*
                            Proceed (Y/n)? y
                            ERROR: Exception:
                            Traceback (most recent call last):
                              File "/usr/lib/python3.11/shutil.py", line 825, in move
                                os.rename(src, real_dst)
                            PermissionError: [Errno 13] Permission denied: '/usr/local/bin/meyectl' -> '/tmp/pip-uninstall-eit5jf_4/meyectl'
                            During handling of the above exception, another exception occurred:
                              File "/usr/local/lib/python3.11/dist-packages/pip/_internal/cli/base_command.py", line 180, in exc_logging_wrapper
                                status = run_func(*args)
                              File "/usr/local/lib/python3.11/dist-packages/pip/_internal/commands/uninstall.py", line 105, in run
                                uninstall_pathset = req.uninstall(
                              File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_install.py", line 727, in uninstall
                                uninstalled_pathset.remove(auto_confirm, verbose)
                              File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_uninstall.py", line 380, in remove
                                moved.stash(path)
                              File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_uninstall.py", line 271, in stash
                                renames(path, new_path)
                              File "/usr/local/lib/python3.11/dist-packages/pip/_internal/utils/misc.py", line 358, in renames
                                shutil.move(old, new)
                              File "/usr/lib/python3.11/shutil.py", line 846, in move
                                os.unlink(src)
                            und
                            Shinobi wird nach der Installation auch nicht erreicht über 192.168.178.68:8080
                            herke@raspberrypi:~ $ bash <(curl -s https://gitlab.com/Shinobi-Systems/Shinobi-        Installer/raw/master/shinobi-install.sh)
                            Opening Install Location : "/home"
                            *Shinobi requires being run as root.
                            *Do you want to continue without being root?
                            (Y)es or (n)o? Default : Yes
                            y
                            Install the Development branch?
                            (y)es or (N)o? Default : No
                            n
                            Getting the Master Branch
                            Cloning into 'Shinobi'...
                            remote: Enumerating objects: 23189, done.
                            remote: Counting objects: 100% (148/148), done.
                            remote: Compressing objects: 100% (113/113), done.
                            remote: Total 23189 (delta 61), reused 78 (delta 35), pack-reused 23041 (from 1)
                            Receiving objects: 100% (23189/23189), 16.76 MiB | 11.07 MiB/s, done.
                            Resolving deltas: 100% (15552/15552), done.
                            fatal: detected dubious ownership in repository at '/home/Shinobi'
                            To add an exception for this directory, call:
                                    git config --global --add safe.directory /home/Shinobi
                            ---------- Shinobi Systems ----------
                            Repository : https://gitlab.com/Shinobi-Systems/Shinobi
                            Product : Shinobi Professional (Pro)
                            Branch : master
                            Version :
                            Date : Tue  7 May 10:20:37 CEST 2024
                            Shinobi Installer
                            Select your OS
                            If your OS is not on the list please refer to the docs.
                            1. Ubuntu - Fast and Touchless
                            2. Ubuntu - Advanced
                            3. Alma Linux 9.2 / Rocky 9 / CentOS 8 - Fast and Touchless (Red Hat)
                            4. CentOS
                            5. MacOS
                            6. FreeBSD
                            7. OpenSUSE
                            ==!! Shinobi : The Open Source CCTV and NVR Solution !!==
                            To answer yes type the letter (y) in lowercase and press ENTER.
                            Default is no (N). Skip any components you already have or don't need.
                             Detecting Ubuntu Version
                             Ubuntu Version: 12
                            Shinobi - Do you want to temporarily disable IPv6?
                            Sometimes IPv6 causes Ubuntu package updates to fail. Only do this if your machi        ne doesn't rely on IPv6.
                            (y)es or (N)o
                            y
                            net.ipv6.conf.all.disable_ipv6 = 1
                            net.ipv6.conf.default.disable_ipv6 = 1
                            net.ipv6.conf.lo.disable_ipv6 = 1
                            Reading package lists... Done
                            gcc is already the newest version (4:12.2.0-3).
                            g++ is already the newest version (4:12.2.0-3).
                            g++ set to manually installed.
                            cmake is already the newest version (3.25.1-1).
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            update-alternatives: error: alternative path /usr/bin/gcc-8 doesn't exist
                            Default Superuser : admin@shinobi.video
                            Default Password : admin
                            * You can edit these settings in "super.json" located in the Shinobi directory.
                            Shinobi - Installing Node.js
                            Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
                            Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                            Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
                            Get:5 https://repos.influxdata.com/debian stable InRelease [6,907 B]
                            Get:6 https://apt.grafana.com stable InRelease [7,660 B]
                            Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Get:8 http://deb.debian.org/debian-security bookworm-security/main arm64 Package        s [153 kB]
                            Get:9 http://deb.debian.org/debian-security bookworm-security/main armhf Package        s [150 kB]
                            Get:10 http://deb.debian.org/debian-security bookworm-security/main Translation-        en [95.1 kB]
                            Get:11 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [387 k        B]
                            Get:12 https://apt.grafana.com stable/main arm64 Packages [194 kB]
                            Get:13 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [397 k        B]
                            Get:14 https://apt.grafana.com stable/main armhf Packages [171 kB]
                            Get:15 https://repos.influxdata.com/debian stable/main arm64 Packages [10.7 kB]
                            Fetched 1,699 kB in 2s (1,023 kB/s)
                            ca-certificates is already the newest version (20230311).
                            curl is already the newest version (7.88.1-10+deb12u5).
                            gnupg is already the newest version (2.2.40-1.1).
                            File '/etc/apt/keyrings/nodesource.gpg' exists. Overwrite? (y/N) n
                            Enter new filename: shinobigeil
                            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node        _18.x nodistro main
                            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:5 https://repos.influxdata.com/debian stable InRelease
                            Hit:6 https://apt.grafana.com stable InRelease
                            nodejs is already the newest version (18.20.2-1nodesource1).
                            make is already the newest version (4.3-4.1).
                            make set to manually installed.
                            zip is already the newest version (3.0-13).
                            FFmpeg Found...
                            Version : ffmpeg version 5.1.4-0+rpt3+deb12u1 Copyright (c) 2000-2023 the FFmpeg        developers
                            built with gcc 12 (Debian 12.2.0-14)
                            configuration: --prefix=/usr --extra-version=0+rpt3+deb12u1 --toolchain=hardened        --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --disa        ble-mmal --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enabl        e-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec        2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetyp        e --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enab        le-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-        libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-libr        ist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr        --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-l        ibtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-lib        vpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable        -libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-ope        nal --enable-opencl --enable-opengl --enable-sand --enable-sdl2 --disable-sndio        --enable-libjxl --enable-neon --enable-v4l2-request --enable-libudev --enable-ep        oxy --libdir=/usr/lib/aarch64-linux-gnu --arch=arm64 --enable-pocketsphinx --ena        ble-librsvg --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec        61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo        --enable-librav1e --enable-shared
                            libavutil      57. 28.100 / 57. 28.100
                            libavcodec     59. 37.100 / 59. 37.100
                            libavformat    59. 27.100 / 59. 27.100
                            libavdevice    59.  7.100 / 59.  7.100
                            libavfilter     8. 44.100 /  8. 44.100
                            libswscale      6.  7.100 /  6.  7.100
                            libswresample   4.  7.100 /  4.  7.100
                            libpostproc    56.  6.100 / 56.  6.100
                            Shinobi - Installing MariaDB
                            MariaDB will be installed with no password.
                            The following additional packages will be installed:
                              galera-4 gawk libcgi-fast-perl libcgi-pm-perl libclone-perl
                              libconfig-inifiles-perl libdaxctl1 libdbd-mariadb-perl libdbi-perl
                              libencode-locale-perl libfcgi-bin libfcgi-perl libfcgi0ldbl libgpm2
                              libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl
                              libhttp-date-perl libhttp-message-perl libio-html-perl
                              liblwp-mediatypes-perl libncurses6 libndctl6 libpmem1 libregexp-ipv6-perl
                              libsigsegv2 libterm-readkey-perl libtimedate-perl liburi-perl liburing2 lsof
                              mariadb-client mariadb-client-core mariadb-plugin-provider-bzip2
                              mariadb-plugin-provider-lz4 mariadb-plugin-provider-lzma
                              mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy
                              mariadb-server-core pv socat
                            Suggested packages:
                              gawk-doc libmldbm-perl libnet-daemon-perl libsql-statement-perl gpm
                              libdata-dump-perl libipc-sharedcache-perl libbusiness-isbn-perl libwww-perl
                              mailx mariadb-test netcat-openbsd doc-base
                            The following NEW packages will be installed:
                              mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy mariadb-server
                            0 upgraded, 42 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 18.1 MB of archives.
                            After this operation, 196 MB of additional disk space will be used.
                            Get:1 http://deb.debian.org/debian bookworm/main arm64 libsigsegv2 arm64 2.14-1        [37.0 kB]
                            Get:2 http://deb.debian.org/debian bookworm/main arm64 gawk arm64 1:5.2.1-2 [640        kB]
                            Get:3 http://deb.debian.org/debian bookworm/main arm64 galera-4 arm64 26.4.13-1        [702 kB]
                            Get:4 http://deb.debian.org/debian bookworm/main arm64 libdbi-perl arm64 1.643-4        [767 kB]
                            Get:5 http://deb.debian.org/debian bookworm/main arm64 lsof arm64 4.95.0-1 [313        kB]
                            Get:6 http://deb.debian.org/debian bookworm/main arm64 libconfig-inifiles-perl a        ll 3.000003-2 [45.9 kB]
                            Get:7 http://deb.debian.org/debian bookworm/main arm64 libncurses6 arm64 6.4-4 [        93.9 kB]
                            Get:8 http://deb.debian.org/debian bookworm/main arm64 mariadb-client-core arm64        1:10.11.6-0+deb12u1 [846 kB]
                            Get:9 http://deb.debian.org/debian bookworm/main arm64 mariadb-client arm64 1:10        .11.6-0+deb12u1 [2,865 kB]
                            Get:10 http://deb.debian.org/debian bookworm/main arm64 libdaxctl1 arm64 76.1-1        [19.8 kB]
                            Get:11 http://deb.debian.org/debian bookworm/main arm64 libndctl6 arm64 76.1-1 [        57.4 kB]
                            Get:12 http://deb.debian.org/debian bookworm/main arm64 libpmem1 arm64 1.12.1-2        [45.7 kB]
                            Get:13 http://deb.debian.org/debian bookworm/main arm64 liburing2 arm64 2.3-3 [1        2.6 kB]
                            Get:14 http://deb.debian.org/debian bookworm/main arm64 mariadb-server-core arm6        4 1:10.11.6-0+deb12u1 [6,734 kB]
                            Get:15 http://deb.debian.org/debian bookworm/main arm64 socat arm64 1.7.4.4-2 [3        66 kB]
                            Get:16 http://deb.debian.org/debian bookworm/main arm64 mariadb-server arm64 1:1        0.11.6-0+deb12u1 [3,447 kB]
                            Get:17 http://deb.debian.org/debian bookworm/main arm64 libhtml-tagset-perl all        3.20-6 [11.7 kB]
                            Get:18 http://deb.debian.org/debian bookworm/main arm64 libregexp-ipv6-perl all        0.03-3 [5,212 B]
                            Get:19 http://deb.debian.org/debian bookworm/main arm64 liburi-perl all 5.17-1 [        90.4 kB]
                            Get:20 http://deb.debian.org/debian bookworm/main arm64 libhtml-parser-perl arm6        4 3.81-1 [98.6 kB]
                            Get:21 http://deb.debian.org/debian bookworm/main arm64 libcgi-pm-perl all 4.55-        1 [220 kB]
                            Get:22 http://deb.debian.org/debian bookworm/main arm64 libfcgi0ldbl arm64 2.4.2        -2 [25.3 kB]
                            Get:23 http://deb.debian.org/debian bookworm/main arm64 libfcgi-perl arm64 0.82+        ds-2 [24.4 kB]
                            Get:24 http://deb.debian.org/debian bookworm/main arm64 libcgi-fast-perl all 1:2        .15-1 [12.1 kB]
                            Get:25 http://deb.debian.org/debian bookworm/main arm64 libclone-perl arm64 0.46        -1 [13.5 kB]
                            Get:26 http://deb.debian.org/debian bookworm/main arm64 libdbd-mariadb-perl arm6        4 1.22-1+b1 [89.1 kB]
                            Get:27 http://deb.debian.org/debian bookworm/main arm64 libencode-locale-perl al        l 1.05-3 [12.9 kB]
                            Get:28 http://deb.debian.org/debian bookworm/main arm64 libfcgi-bin arm64 2.4.2-        2 [12.5 kB]
                            Get:29 http://deb.debian.org/debian bookworm/main arm64 libgpm2 arm64 1.20.7-10+        b1 [14.4 kB]
                            Get:30 http://deb.debian.org/debian bookworm/main arm64 libhtml-template-perl al        l 2.97-2 [66.5 kB]
                            Get:31 http://deb.debian.org/debian bookworm/main arm64 libtimedate-perl all 2.3        300-2 [39.3 kB]
                            Get:32 http://deb.debian.org/debian bookworm/main arm64 libhttp-date-perl all 6.        05-2 [10.5 kB]
                            Get:33 http://deb.debian.org/debian bookworm/main arm64 libio-html-perl all 1.00        4-3 [16.2 kB]
                            Get:34 http://deb.debian.org/debian bookworm/main arm64 liblwp-mediatypes-perl a        ll 6.04-2 [20.2 kB]
                            Get:35 http://deb.debian.org/debian bookworm/main arm64 libhttp-message-perl all        6.44-1 [81.7 kB]
                            Get:36 http://deb.debian.org/debian bookworm/main arm64 libterm-readkey-perl arm        64 2.38-2+b1 [24.1 kB]
                            Get:37 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        bzip2 arm64 1:10.11.6-0+deb12u1 [24.9 kB]
                            Get:38 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lz4 arm64 1:10.11.6-0+deb12u1 [24.8 kB]
                            Get:39 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lzma arm64 1:10.11.6-0+deb12u1 [24.9 kB]
                            Get:40 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lzo arm64 1:10.11.6-0+deb12u1 [24.8 kB]
                            Get:41 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        snappy arm64 1:10.11.6-0+deb12u1 [24.9 kB]
                            Get:42 http://deb.debian.org/debian bookworm/main arm64 pv arm64 1.6.20-1 [58.6        kB]
                            Fetched 18.1 MB in 2s (10.3 MB/s)
                            Extracting templates from packages: 100%
                            Preconfiguring packages ...
                            Selecting previously unselected package libsigsegv2:arm64.
                            (Reading database ... 103045 files and directories currently installed.)
                            Preparing to unpack .../libsigsegv2_2.14-1_arm64.deb ...
                            Unpacking libsigsegv2:arm64 (2.14-1) ...
                            Setting up libsigsegv2:arm64 (2.14-1) ...
                            Selecting previously unselected package gawk.
                            (Reading database ... 103054 files and directories currently installed.)
                            Preparing to unpack .../00-gawk_1%3a5.2.1-2_arm64.deb ...
                            Unpacking gawk (1:5.2.1-2) ...
                            Selecting previously unselected package galera-4.
                            Preparing to unpack .../01-galera-4_26.4.13-1_arm64.deb ...
                            Unpacking galera-4 (26.4.13-1) ...
                            Selecting previously unselected package libdbi-perl:arm64.
                            Preparing to unpack .../02-libdbi-perl_1.643-4_arm64.deb ...
                            Unpacking libdbi-perl:arm64 (1.643-4) ...
                            Selecting previously unselected package lsof.
                            Preparing to unpack .../03-lsof_4.95.0-1_arm64.deb ...
                            Unpacking lsof (4.95.0-1) ...
                            Selecting previously unselected package libconfig-inifiles-perl.
                            Preparing to unpack .../04-libconfig-inifiles-perl_3.000003-2_all.deb ...
                            Unpacking libconfig-inifiles-perl (3.000003-2) ...
                            Selecting previously unselected package libncurses6:arm64.
                            Preparing to unpack .../05-libncurses6_6.4-4_arm64.deb ...
                            Unpacking libncurses6:arm64 (6.4-4) ...
                            Selecting previously unselected package mariadb-client-core.
                            Preparing to unpack .../06-mariadb-client-core_1%3a10.11.6-0+deb12u1_arm64.deb .        ..
                            Unpacking mariadb-client-core (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package mariadb-client.
                            Preparing to unpack .../07-mariadb-client_1%3a10.11.6-0+deb12u1_arm64.deb ...
                            Unpacking mariadb-client (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package libdaxctl1:arm64.
                            Preparing to unpack .../08-libdaxctl1_76.1-1_arm64.deb ...
                            Unpacking libdaxctl1:arm64 (76.1-1) ...
                            Selecting previously unselected package libndctl6:arm64.
                            Preparing to unpack .../09-libndctl6_76.1-1_arm64.deb ...
                            Unpacking libndctl6:arm64 (76.1-1) ...
                            Selecting previously unselected package libpmem1:arm64.
                            Preparing to unpack .../10-libpmem1_1.12.1-2_arm64.deb ...
                            Unpacking libpmem1:arm64 (1.12.1-2) ...
                            Selecting previously unselected package liburing2:arm64.
                            Preparing to unpack .../11-liburing2_2.3-3_arm64.deb ...
                            Unpacking liburing2:arm64 (2.3-3) ...
                            Selecting previously unselected package mariadb-server-core.
                            Preparing to unpack .../12-mariadb-server-core_1%3a10.11.6-0+deb12u1_arm64.deb .        ..
                            Unpacking mariadb-server-core (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package socat.
                            Preparing to unpack .../13-socat_1.7.4.4-2_arm64.deb ...
                            Unpacking socat (1.7.4.4-2) ...
                            Selecting previously unselected package mariadb-server.
                            Preparing to unpack .../14-mariadb-server_1%3a10.11.6-0+deb12u1_arm64.deb ...
                            Unpacking mariadb-server (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package libhtml-tagset-perl.
                            Preparing to unpack .../15-libhtml-tagset-perl_3.20-6_all.deb ...
                            Unpacking libhtml-tagset-perl (3.20-6) ...
                            Selecting previously unselected package libregexp-ipv6-perl.
                            Preparing to unpack .../16-libregexp-ipv6-perl_0.03-3_all.deb ...
                            Unpacking libregexp-ipv6-perl (0.03-3) ...
                            Selecting previously unselected package liburi-perl.
                            Preparing to unpack .../17-liburi-perl_5.17-1_all.deb ...
                            Unpacking liburi-perl (5.17-1) ...
                            Selecting previously unselected package libhtml-parser-perl:arm64.
                            Preparing to unpack .../18-libhtml-parser-perl_3.81-1_arm64.deb ...
                            Unpacking libhtml-parser-perl:arm64 (3.81-1) ...
                            Selecting previously unselected package libcgi-pm-perl.
                            Preparing to unpack .../19-libcgi-pm-perl_4.55-1_all.deb ...
                            Unpacking libcgi-pm-perl (4.55-1) ...
                            Selecting previously unselected package libfcgi0ldbl:arm64.
                            Preparing to unpack .../20-libfcgi0ldbl_2.4.2-2_arm64.deb ...
                            Unpacking libfcgi0ldbl:arm64 (2.4.2-2) ...
                            Selecting previously unselected package libfcgi-perl.
                            Preparing to unpack .../21-libfcgi-perl_0.82+ds-2_arm64.deb ...
                            Unpacking libfcgi-perl (0.82+ds-2) ...
                            Selecting previously unselected package libcgi-fast-perl.
                            Preparing to unpack .../22-libcgi-fast-perl_1%3a2.15-1_all.deb ...
                            Unpacking libcgi-fast-perl (1:2.15-1) ...
                            Selecting previously unselected package libclone-perl:arm64.
                            Preparing to unpack .../23-libclone-perl_0.46-1_arm64.deb ...
                            Unpacking libclone-perl:arm64 (0.46-1) ...
                            Selecting previously unselected package libdbd-mariadb-perl.
                            Preparing to unpack .../24-libdbd-mariadb-perl_1.22-1+b1_arm64.deb ...
                            Unpacking libdbd-mariadb-perl (1.22-1+b1) ...
                            Selecting previously unselected package libencode-locale-perl.
                            Preparing to unpack .../25-libencode-locale-perl_1.05-3_all.deb ...
                            Unpacking libencode-locale-perl (1.05-3) ...
                            Selecting previously unselected package libfcgi-bin.
                            Preparing to unpack .../26-libfcgi-bin_2.4.2-2_arm64.deb ...
                            Unpacking libfcgi-bin (2.4.2-2) ...
                            Selecting previously unselected package libgpm2:arm64.
                            Preparing to unpack .../27-libgpm2_1.20.7-10+b1_arm64.deb ...
                            Unpacking libgpm2:arm64 (1.20.7-10+b1) ...
                            Selecting previously unselected package libhtml-template-perl.
                            Preparing to unpack .../28-libhtml-template-perl_2.97-2_all.deb ...
                            Unpacking libhtml-template-perl (2.97-2) ...
                            Selecting previously unselected package libtimedate-perl.
                            Preparing to unpack .../29-libtimedate-perl_2.3300-2_all.deb ...
                            Unpacking libtimedate-perl (2.3300-2) ...
                            Selecting previously unselected package libhttp-date-perl.
                            Preparing to unpack .../30-libhttp-date-perl_6.05-2_all.deb ...
                            Unpacking libhttp-date-perl (6.05-2) ...
                            Selecting previously unselected package libio-html-perl.
                            Preparing to unpack .../31-libio-html-perl_1.004-3_all.deb ...
                            Unpacking libio-html-perl (1.004-3) ...
                            Selecting previously unselected package liblwp-mediatypes-perl.
                            Preparing to unpack .../32-liblwp-mediatypes-perl_6.04-2_all.deb ...
                            Unpacking liblwp-mediatypes-perl (6.04-2) ...
                            Selecting previously unselected package libhttp-message-perl.
                            Preparing to unpack .../33-libhttp-message-perl_6.44-1_all.deb ...
                            Unpacking libhttp-message-perl (6.44-1) ...
                            Selecting previously unselected package libterm-readkey-perl.
                            Preparing to unpack .../34-libterm-readkey-perl_2.38-2+b1_arm64.deb ...
                            Unpacking libterm-readkey-perl (2.38-2+b1) ...
                            Selecting previously unselected package mariadb-plugin-provider-bzip2.
                            Preparing to unpack .../35-mariadb-plugin-provider-bzip2_1%3a10.11.6-0+deb12u1_a        rm64.deb ...
                            Unpacking mariadb-plugin-provider-bzip2 (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package mariadb-plugin-provider-lz4.
                            Preparing to unpack .../36-mariadb-plugin-provider-lz4_1%3a10.11.6-0+deb12u1_arm        64.deb ...
                            Unpacking mariadb-plugin-provider-lz4 (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package mariadb-plugin-provider-lzma.
                            Preparing to unpack .../37-mariadb-plugin-provider-lzma_1%3a10.11.6-0+deb12u1_ar        m64.deb ...
                            Unpacking mariadb-plugin-provider-lzma (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package mariadb-plugin-provider-lzo.
                            Preparing to unpack .../38-mariadb-plugin-provider-lzo_1%3a10.11.6-0+deb12u1_arm        64.deb ...
                            Unpacking mariadb-plugin-provider-lzo (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package mariadb-plugin-provider-snappy.
                            Preparing to unpack .../39-mariadb-plugin-provider-snappy_1%3a10.11.6-0+deb12u1_        arm64.deb ...
                            Unpacking mariadb-plugin-provider-snappy (1:10.11.6-0+deb12u1) ...
                            Selecting previously unselected package pv.
                            Preparing to unpack .../40-pv_1.6.20-1_arm64.deb ...
                            Unpacking pv (1.6.20-1) ...
                            Setting up libconfig-inifiles-perl (3.000003-2) ...
                            Setting up galera-4 (26.4.13-1) ...
                            Setting up libgpm2:arm64 (1.20.7-10+b1) ...
                            Setting up libfcgi0ldbl:arm64 (2.4.2-2) ...
                            Setting up gawk (1:5.2.1-2) ...
                            Setting up libclone-perl:arm64 (0.46-1) ...
                            Setting up libhtml-tagset-perl (3.20-6) ...
                            Setting up liblwp-mediatypes-perl (6.04-2) ...
                            Setting up libfcgi-bin (2.4.2-2) ...
                            Setting up libencode-locale-perl (1.05-3) ...
                            Setting up socat (1.7.4.4-2) ...
                            Setting up libncurses6:arm64 (6.4-4) ...
                            Setting up libio-html-perl (1.004-3) ...
                            Setting up libdaxctl1:arm64 (76.1-1) ...
                            Setting up lsof (4.95.0-1) ...
                            Setting up libtimedate-perl (2.3300-2) ...
                            Setting up libregexp-ipv6-perl (0.03-3) ...
                            Setting up pv (1.6.20-1) ...
                            Setting up libndctl6:arm64 (76.1-1) ...
                            Setting up libfcgi-perl (0.82+ds-2) ...
                            Setting up libterm-readkey-perl (2.38-2+b1) ...
                            Setting up liburing2:arm64 (2.3-3) ...
                            Setting up libpmem1:arm64 (1.12.1-2) ...
                            Setting up liburi-perl (5.17-1) ...
                            Setting up libdbi-perl:arm64 (1.643-4) ...
                            Setting up libhttp-date-perl (6.05-2) ...
                            Setting up mariadb-client-core (1:10.11.6-0+deb12u1) ...
                            Setting up libdbd-mariadb-perl (1.22-1+b1) ...
                            Setting up libhtml-parser-perl:arm64 (3.81-1) ...
                            Setting up mariadb-server-core (1:10.11.6-0+deb12u1) ...
                            Setting up libhttp-message-perl (6.44-1) ...
                            Setting up mariadb-client (1:10.11.6-0+deb12u1) ...
                            Setting up libcgi-pm-perl (4.55-1) ...
                            Setting up libhtml-template-perl (2.97-2) ...
                            Setting up mariadb-server (1:10.11.6-0+deb12u1) ...
                            Created symlink /etc/systemd/system/multi-user.target.wants/mariadb.service → /l        ib/systemd/system/mariadb.service.
                            Setting up mariadb-plugin-provider-bzip2 (1:10.11.6-0+deb12u1) ...
                            Setting up mariadb-plugin-provider-lzma (1:10.11.6-0+deb12u1) ...
                            Setting up mariadb-plugin-provider-lzo (1:10.11.6-0+deb12u1) ...
                            Setting up mariadb-plugin-provider-lz4 (1:10.11.6-0+deb12u1) ...
                            Setting up libcgi-fast-perl (1:2.15-1) ...
                            Setting up mariadb-plugin-provider-snappy (1:10.11.6-0+deb12u1) ...
                            Processing triggers for man-db (2.11.2-2) ...
                            Processing triggers for libc-bin (2.36-9+rpt2+deb12u6) ...
                            Processing triggers for mariadb-server (1:10.11.6-0+deb12u1) ...
                            Shinobi - Installing Database...
                            Shinobi - Install NPM Libraries
                            npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#dep        recated
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprec        ated
                            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
                            npm WARN deprecated @discordjs/form-data@3.0.1: Package no longer supported. Con        tact Support at https://www.npmjs.com/support for more info.
                            npm WARN deprecated @discordjs/collection@0.1.6: no longer supported
                            npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
                            npm WARN deprecated discord.js@12.2.0: no longer supported
                            added 762 packages, and audited 763 packages in 1m
                            45 packages are looking for funding
                              run `npm fund` for details
                            18 vulnerabilities (16 moderate, 2 critical)
                            To address issues that do not require attention, run:
                              npm audit fix
                            To address all issues (including breaking changes), run:
                              npm audit fix --force
                            Run `npm audit` for details.
                            npm notice
                            npm notice New minor version of npm available! 10.5.0 -> 10.7.0
                            npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.7.0
                            npm notice Run npm install -g npm@10.7.0 to update!
                            npm notice
                            Shinobi - Install PM2
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            added 162 packages in 18s
                            14 packages are looking for funding
                            Shinobi - Finished
                            dos2unix: converting file INSTALL/shinobi to Unix format...
                            Shinobi - Randomizing cron key
                            addToConfig: [object Object]
                            Changes Complete. Here is what it is now.
                              "port": 8080,
                              "debugLog": false,
                              "enableFaceManager": false,
                              "videosDir": "__DIR__/videos",
                              "passwordType": "sha256",
                              "detectorMergePamRegionTriggers": true,
                              "wallClockTimestampAsDefault": true,
                              "useBetterP2P": true,
                              "smtpServerOptions": {
                                "allowInsecureAuth": true
                              "addStorage": [
                                  "name": "second",
                                  "path": "__DIR__/videos2"
                              "db": {
                                "host": "127.0.0.1",
                                "user": "majesticflame",
                                "password": "",
                                "database": "ccio",
                                "port": 3306
                              "mail": {
                                "service": "gmail",
                                "auth": {
                                  "user": "your_email@gmail.com",
                                  "pass": "your_password_or_app_specific_password"
                              "cron": {
                                "key": "09e6aa3f65ca6ef81d120889f44dec94e8efc9d92c90615f26a06177af5a"
                              "pluginKeys": {}
                            Shinobi - Starting Shinobi and setting to start on boot
                            __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
                             _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
                              _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
                               _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                                _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                                 _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                                  _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                                   _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                                    _\///______________\///______________\///__\///////////////__
                                                      Runtime Edition
                                    PM2 is a Production Process Manager for Node.js applications
                                                 with a built-in Load Balancer.
                                            Start and Daemonize any application:
                                            $ pm2 start app.js
                                            Load Balance 4 instances of api.js:
                                            $ pm2 start api.js -i 4
                                            Monitor in production:
                                            $ pm2 monitor
                                            Make pm2 auto-boot at server restart:
                                            $ pm2 startup
                                            To go further checkout:
                                            http://pm2.io/
                            [PM2] Spawning PM2 daemon with pm2_home=/root/.pm2
                            [PM2] PM2 Successfully daemonized
                            [PM2] Starting /home/Shinobi/camera.js in fork_mode (1 instance)
                            [PM2] Done.
                            │ id │ name      │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                            │ 0  │ camera    │ default     │ 2.0.0   │ fork    │ 4133     │ 0s     │ 0    │ online    │ 0%       │ 38.8mb   │ root     │ disabled │
                            [PM2] Init System found: systemd
                            Platform systemd
                            Template
                            [Unit]
                            Description=PM2 process manager
                            Documentation=https://pm2.keymetrics.io/
                            After=network.target
                            [Service]
                            Type=forking
                            User=root
                            LimitNOFILE=infinity
                            LimitNPROC=infinity
                            LimitCORE=infinity
                            Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                            Environment=PM2_HOME=/root/.pm2
                            PIDFile=/root/.pm2/pm2.pid
                            Restart=on-failure
                            ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                            ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                            ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                            [Install]
                            WantedBy=multi-user.target
                            Target path
                            /etc/systemd/system/pm2-root.service
                            Command list
                            [ 'systemctl enable pm2-root' ]
                            [PM2] Writing init configuration in /etc/systemd/system/pm2-root.service
                            [PM2] Making script booting at startup...
                            [PM2] [-] Executing: systemctl enable pm2-root...
                            Created symlink /etc/systemd/system/multi-user.target.wants/pm2-root.service → /etc/systemd/system/pm2-root.service.
                            [PM2] [v] Command successfully executed.
                            [PM2] Freeze a process list on reboot via:
                            $ pm2 save
                            [PM2] Remove init script via:
                            $ pm2 unstartup systemd
                            [PM2] Saving current process list...
                            [PM2] Successfully saved in /root/.pm2/dump.pm2
                            │ 0  │ camera    │ default     │ 2.0.0   │ fork    │ 4133     │ 4s     │ 0    │ online    │ 0%       │ 111.5mb  │ root     │ disabled │
                            ||=====   Install Completed   =====||
                            || Login with the Superuser and create a new user!!
                            || Open http://192.168.178.68:8080/super in your web browser.
                            System nochmal neu aufsetzen? Da ist doch was faul
                            • B Bill S. Preston
                              @crunchip
                                Would remove:
                              Proceed (Y/n)? y
                              ERROR: Exception:
                                  moved.stash(path)
                                  os.unlink(src)
                              und
                              y
                              n
                              Branch : master
                              Version :
                              Shinobi Installer
                              Select your OS
                              4. CentOS
                              5. MacOS
                              6. FreeBSD
                              7. OpenSUSE
                               Ubuntu Version: 12
                              (y)es or (N)o
                              y
                              FFmpeg Found...
                              Suggested packages:
                                npm audit fix
                              npm notice
                              npm notice
                              Shinobi - Finished
                                "port": 8080,
                                "debugLog": false,
                                "addStorage": [
                                    "name": "second",
                                "db": {
                                  "password": "",
                                  "database": "ccio",
                                  "port": 3306
                                "mail": {
                                  "service": "gmail",
                                  "auth": {
                                "cron": {
                                "pluginKeys": {}
                                                        Runtime Edition
                                              $ pm2 start app.js
                                              $ pm2 monitor
                                              $ pm2 startup
                                              http://pm2.io/
                              [PM2] Done.
                              Platform systemd
                              Template
                              [Unit]
                              [Service]
                              Type=forking
                              User=root
                              LimitNPROC=infinity
                              LimitCORE=infinity
                              Restart=on-failure
                              [Install]
                              Target path
                              Command list
                              $ pm2 save
                              crunchipC Offline
                              crunchipC Offline
                              @bill-s-preston dann mach mal ein
                              sudo pip....
                                sudo pip....
                                Bill S. Preston
                                sudo pip....
                                herke@raspberrypi:~ $ sudo pip
                                Usage:
                                  pip <command> [options]
                                Commands:
                                  install                     Install packages.
                                  download                    Download packages.
                                  uninstall                   Uninstall packages.
                                  freeze                      Output installed packages in requirements format.
                                  inspect                     Inspect the python environment.
                                  list                        List installed packages.
                                  show                        Show information about installed packages.
                                  check                       Verify installed packages have compatible dependen        cies.
                                  config                      Manage local and global configuration.
                                  search                      Search PyPI for packages.
                                  cache                       Inspect and manage pip's wheel cache.
                                  index                       Inspect information available from package indexes        .
                                  wheel                       Build wheels from your requirements.
                                  hash                        Compute hashes of package archives.
                                  completion                  A helper command used for command completion.
                                  debug                       Show information useful for debugging.
                                  help                        Show help for commands.
                                General Options:
                                  -h, --help                  Show help.
                                  --debug                     Let unhandled exceptions propagate outside the
                                                              main subroutine, instead of logging them to
                                                              stderr.
                                  --isolated                  Run pip in an isolated mode, ignoring
                                                              environment variables and user configuration.
                                  --require-virtualenv        Allow pip to only run in a virtual environment;
                                                              exit with an error otherwise.
                                  --python <python>           Run pip with the specified Python interpreter.
                                  -v, --verbose               Give more output. Option is additive, and can be
                                                              used up to 3 times.
                                  -V, --version               Show version and exit.
                                  -q, --quiet                 Give less output. Option is additive, and can be
                                                              used up to 3 times (corresponding to WARNING,
                                                              ERROR, and CRITICAL logging levels).
                                  --log <path>                Path to a verbose appending log.
                                  --no-input                  Disable prompting for input.
                                  --keyring-provider <keyring_provider>
                                                              Enable the credential lookup via the keyring
                                                              library if user input is allowed. Specify which
                                                              mechanism to use [disabled, import, subprocess].
                                                              (default: disabled)
                                  --proxy <proxy>             Specify a proxy in the form
                                                              scheme://[user:passwd@]proxy.server:port.
                                  --retries <retries>         Maximum number of retries each connection should
                                                              attempt (default 5 times).
                                  --timeout <sec>             Set the socket timeout (default 15 seconds).
                                  --exists-action <action>    Default action when a path already exists:
                                                              (s)witch, (i)gnore, (w)ipe, (b)ackup, (a)bort.
                                  --trusted-host <hostname>   Mark this host or host:port pair as trusted,
                                                              even though it does not have valid or any HTTPS.
                                  --cert <path>               Path to PEM-encoded CA certificate bundle. If
                                                              provided, overrides the default. See 'SSL
                                                              Certificate Verification' in pip documentation
                                                              for more information.
                                  --client-cert <path>        Path to SSL client certificate, a single file
                                                              containing the private key and the certificate
                                                              in PEM format.
                                  --cache-dir <dir>           Store the cache data in <dir>.
                                  --no-cache-dir              Disable the cache.
                                  --disable-pip-version-check
                                                              Don't periodically check PyPI to determine
                                                              whether a new version of pip is available for
                                                              download. Implied with --no-index.
                                  --no-color                  Suppress colored output.
                                  --no-python-version-warning
                                                              Silence deprecation warnings for upcoming
                                                              unsupported Pythons.
                                  --use-feature <feature>     Enable new functionality, that may be backward
                                                              incompatible.
                                  --use-deprecated <feature>  Enable deprecated functionality, that will be
                                                              removed in the future.
                                  crunchipC Offline
                                  crunchipC Offline
                                  @crunchip sagte in Iobroker startet nicht mehr nach Restore:
                                  @Bill-S-Preston
                                  Wollt ich noch mal anmerken
                                  Da auch noch Influx und Grafana laufen
                                  • B Bill S. Preston
                                    sudo pip....
                                    Usage:
                                    Commands:
                                    General Options:
        stderr.
        used up to 3 times.
        (default: disabled)
        in PEM format.
        incompatible.
                                    crunchipC Offline
                                    crunchipC Offline
                                    @bill-s-preston natürlich das ganze Kommando, hatte nur abgekürzt, da ich am Handy tippe
                                      @Bill-S-Preston
                                      Bill S. Preston
                                      @crunchip
                                      Ein neuer Pi4 mit 8GB und M2 SSD wird heute geliefert.
                                      Da werde ich dann nochmal komplett neu anfangen
                                        Bill S. Preston
                                        Du meinst
                                        sudo pip uninstall
                                        • B Bill S. Preston
                                          Du meinst
                                          sudo pip uninstall
                                          crunchipC Offline
                                          crunchipC Offline
                                          @bill-s-preston ja, dein motioneye
