  4. Homebridge Fehler Code 243
41 Beiträge 4 Kommentatoren 7.8k Aufrufe 3 Beobachtet
    @marcelinho
    Gib mal die Ausgabe von
    iob diag
    bekannt. Bevorzugt die Langfassung.
    M
    M
    marcelinho
    Copy text starting here:
                            v.2023-10-10
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     180
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v20.11.0
                            /usr/local/bin/node             v21.1.0
                            /usr/local/bin/npm              10.2.0
                            /usr/local/bin/npx              10.2.0
                            /usr/local/bin/corepack         0.22.0
    Recommended versions are nodejs 18.20.2 and npm 10.5.0
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            4.0G        3.4G        101M         14M        601M        608M
    Swap:           104M        104M        221K
    Total:          4.1G        3.5G        101M
    Active iob-Instances:   24
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.19
                            admin                   6.13.16
    Objects type: jsonl
    States  type: jsonl
    Objects:                14990
    States:                 13387
    Size of iob-Database:
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    4.0M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    • M marcelinho
      @thomas-braun said in Homebridge Fehler Code 243:
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       11:24:00 up 69 days, 16:18,  4 users,  load average: 0.34, 0.23, 0.36
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2024-04-23 11:24:01 CEST
                 Universal time: Tue 2024-04-23 09:24:01 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        3.3G        232M         14M        502M        640M
      Swap:           104M        104M        270K
      Total:          4.1G        3.4G        232M
               3793 M total memory
               3182 M used memory
               1041 M active memory
               2284 M inactive memory
                221 M free memory
                 56 M buffer memory
                423 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.3M  379M   1% /run
      /dev/mmcblk0p2 ext4       29G   26G  2.1G  93% /
      tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
      tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
      [Tue Feb 13 18:05:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bc        m2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_me        m.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1e048ecb-02 rootfstyp        e=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Tue Feb 13 18:05:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Feb 13 18:05:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/mmcblk0p2 ext4        rw,noatime
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortnam        e=mixed,errors=remount-ro
      /var:
      17G     /var/
      16G     /var/lib
      15G     /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
      Archived and active journals take up 699.9M in the file system.
      /opt/iobroker/backups:
      213M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      302M    /opt/iobroker/iobroker-data/
      191M    /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      52M     /opt/iobroker/iobroker-data/backup-objects
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
      *** NodeJS-Installation ***
      nodejs:
        Installed: 20.11.0-1nodesource1
        Candidate: 20.12.2-1nodesource1
        Version table:
           20.12.2-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
       *** 20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   3
      Adapter State
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
      + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
      + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smart-eq.0               : smart-eq              : raspberrypi                              -  enabled
      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
      Adapter    "node-red"     : 5.2.0    , installed 5.2.0
      Adapter    "openhab"      : 1.1.0    , installed 1.1.0
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
      Objects and States
      Objects:        14990
      States:         13387
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:8 https://repo.homebridge.io stable InRelease
      Reading package lists...
      Pending Updates: 180
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:39715         0.0.0.0:*               LISTEN      112        46457213   2097759/homebridge:
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5021298    228976/iobroker.js-
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5021312    228976/iobroker.js-
      tcp        0      0 127.0.0.1:39639         0.0.0.0:*               LISTEN      112        46457242   2097771/homebridge:
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          46142328   2081606/cupsd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17032      803/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:43327         0.0.0.0:*               LISTEN      112        46458116   2097772/homebridge:
      tcp        0      0 127.0.0.1:45013         0.0.0.0:*               LISTEN      112        46455694   2097765/homebridge:
      tcp        0      0 127.0.0.1:34425         0.0.0.0:*               LISTEN      112        46480613   2097757/homebridge:
      tcp        0      0 127.0.0.1:34275         0.0.0.0:*               LISTEN      112        46457194   2097778/homebridge:
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       684423     32124/node
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       33174888   1491043/node-red
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       28392686   1277149/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        17024      779/mosquitto
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       5023995    229264/io.mqtt.0
      tcp        0      0 127.0.0.1:44081         0.0.0.0:*               LISTEN      112        46456352   2097758/homebridge:
      tcp        0      0 127.0.0.1:33795         0.0.0.0:*               LISTEN      112        46457227   2097785/homebridge:
      tcp6       0      0 :::8581                 :::*                    LISTEN      112        46418999   2094723/hb-service
      tcp6       0      0 :::45391                :::*                    LISTEN      112        46458125   2097771/homebridge:
      tcp6       0      0 :::37166                :::*                    LISTEN      112        46456334   2097758/homebridge:
      tcp6       0      0 :::53299                :::*                    LISTEN      112        46456339   2097772/homebridge:
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17034      803/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      113        19873      1596/grafana
      tcp6       0      0 :::52120                :::*                    LISTEN      112        46455673   2097785/homebridge:
      tcp6       0      0 :::47961                :::*                    LISTEN      112        46455615   2097757/homebridge:
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          46142327   2081606/cupsd
      tcp6       0      0 :::39667                :::*                    LISTEN      112        46456297   2097759/homebridge:
      tcp6       0      0 :::51798                :::*                    LISTEN      112        46457171   2097719/homebridge
      tcp6       0      0 :::44253                :::*                    LISTEN      112        46455623   2097778/homebridge:
      tcp6       0      0 :::52403                :::*                    LISTEN      112        46456301   2097765/homebridge:
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5021363    229001/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38441274   1730388/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        19857      1400/influxd
      tcp6       0      0 :::1883                 :::*                    LISTEN      114        17025      779/mosquitto
      udp        0      0 0.0.0.0:47202           0.0.0.0:*                           104        13649      516/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5021645    229175/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5021646    229175/io.tuya.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          46142333   2081608/cups-browse
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46458119   2097759/homebridge:
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46418996   2094723/hb-service
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13647      516/avahi-daemon: r
      udp6       0      0 :::39317                :::*                                104        13650      516/avahi-daemon: r
      udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          20485      651/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        13648      516/avahi-daemon: r
      2024-04-23 11:25:31.610  - warn: influxdb.0 (229070) Error on writePoint("{"value":4294,"time":"2024-04-23T09:25:19.093Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 11:25:31.610  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=4
      2024-04-23 11:25:31.619  - warn: influxdb.0 (229070) Point could not be written to database: admin
      2024-04-23 11:25:31.619  - warn: influxdb.0 (229070) Error on writePoint("{"value":5.3333,"time":"2024-04-23T09:25:20.001Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 11:25:31.620  - info: influxdb.0 (229070) Discard point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh, error-count=10
      2024-04-23 11:25:31.624  - warn: influxdb.0 (229070) Point could not be written to database: admin
      2024-04-23 11:25:31.624  - warn: influxdb.0 (229070) Error on writePoint("{"value":0.3733310000000001,"time":"2024-04-23T09:25:20.007Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 11:25:31.625  - info: influxdb.0 (229070) Add point that had error for Netzeinspeisung_Tag_Euro to buffer again, error-count=6
      2024-04-23 11:25:34.932  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 closed: null
      2024-04-23 11:25:39.931  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 reconnected
      2024-04-23 11:25:40.155  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 connected
      2024-04-23 11:25:56.900  - warn: influxdb.0 (229070) Point could not be written to database: admin
      2024-04-23 11:25:56.901  - warn: influxdb.0 (229070) Error on writePoint("{"value":2360,"time":"2024-04-23T09:25:46.607Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 11:25:56.902  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=5
      2024-04-23 11:25:56.908  - warn: influxdb.0 (229070) Point could not be written to database: admin
      2024-04-23 11:25:56.913  - warn: influxdb.0 (229070) Error on writePoint("{"value":7474,"time":"2024-04-23T09:25:40.968Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 11:25:56.914  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_Power to buffer again, error-count=7
      2024-04-23 11:25:56.923  - warn: influxdb.0 (229070) Point could not be written to database: admin
      2024-04-23 11:25:56.934  - warn: influxdb.0 (229070) Error on writePoint("{"value":2360,"time":"2024-04-23T09:25:46.603Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 11:25:56.934  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
      2024-04-23 11:26:00.245  - info: meross.0 (229216) Can not get Data for Device 2103163856729736101148e1e9629220: Error: Timeout
      2024-04-23 11:26:00.246  - warn: meross.0 (229216) Can not get Data for Device 2103163856729736101148e1e9629220: undefined
      2024-04-23 11:26:04.933  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 closed: null
      2024-04-23 11:26:09.934  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 reconnected
      2024-04-23 11:26:10.115  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 connected
      iob diag has finished.
      Thomas BraunT
      Thomas BraunT
      @marcelinho sagte in Homebridge Fehler Code 243:
      Boot Target: graphical.target
      Stell da um auf multi-user.
      sudo systemctl set-default multi-user.target
      Dein root-Verzeichnis läuft voll.
      Räum da auf.
      nodejs ist hinten und vorne falsch installiert.
      iob nodejs-update
      und nodejs18 darüber sauber installieren lassen.
      System regelmäßig (bzw. überhaupt) pflegen.
      Mit der influxdb gibt es wohl auch Trouble.
        Räum da auf.
        iob nodejs-update
        M
        M
        marcelinho
        iob nodejs-update
        Danke Dir, wie kann ich root-Verzeichnis aufräumen?
        Influxdb läuft bisher problemlos - was kann ich da tun?
        Thomas BraunT Marc BergM 3 Antworten Letzte Antwort
        • M marcelinho
          iob nodejs-update
          Thomas BraunT
          Thomas BraunT
          Erstmal schauen, was da so dickes drin liegt und wo man ansetzen muss.
          Ich mach das immer per
          sudo ncdu /
          ncdu muss u. U. noch nachinstalliert werden.
          • M marcelinho
            iob nodejs-update
            Thomas BraunT
            Thomas BraunT
            Wenn es problemlos liefe hättest du nicht die ganzen Meldungen im LogFile.
            Ich setze influxdb aber nicht ein, muss dir vielleicht wer anders helfen.
            @Marc-Berg ist hier der DB-Spezialist.
            • M marcelinho
              iob nodejs-update
              Marc BergM
              Marc BergM
              Marc Berg
              Ich würde sagen, unter normalen Bedingungen bekommt man eine InfluxDB kaum in solche Größenordnungen wie bei dir. Der Klassiker ist, dass man versehentlich das Logging von Performancedaten aktiviert hat. Du kannst mal diesen Thread anschauen, ob das bei dir der Fall ist:
              https://forum.iobroker.net/topic/73784/speicherplatzbelegung-influxdb2-nach-containerisierung
                M
                M
                marcelinho
                @thomas-braun also nodejs habe ich hinbekommen laut iob diag. Aber in Homebridge funktioniert es noch nicht...
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 12:51:12 up 69 days, 17:46,  4 users,  load average: 0.92, 0.67, 1.32
                CPU threads: 4
                Current issues:
                               Local time: Tue 2024-04-23 12:51:12 CEST
                           Universal time: Tue 2024-04-23 10:51:12 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            4.0G        2.9G        321M         17M        878M        1.1G
                Swap:           104M        104M        389K
                Total:          4.1G        3.0G        322M
                         3793 M total memory
                         2740 M used memory
                         1102 M active memory
                         2016 M inactive memory
                          306 M free memory
                           36 M buffer memory
                          801 M swap cache
                           99 M total swap
                           99 M used swap
                            0 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/mmcblk0p2 ext4       29G   27G  1.2G  96% /
                tmpfs          tmpfs     1.9G  140K  1.9G   1% /dev/shm
                [Tue Feb 13 18:05:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bc_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200s rootwait quiet splash plymouth.ignore-serial-consoles
                /var:
                18G     /var/
                16G     /var/lib
                308M    /opt/iobroker/iobroker-data/
                21M     /opt/iobroker/iobroker-data/objects.jsonl
                8.7M    /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                /usr/bin/nodejs         v18.20.2
                /usr/bin/node           v18.20.2
                /usr/bin/npm            10.5.0
                /usr/bin/npx            10.5.0
                /usr/bin/corepack       0.25.2
                nodejs:
                  Installed: 18.20.2-1nodesource1
                  Candidate: 18.20.2-1nodesource1
                  Version table:
                 *** 18.20.2-1nodesource1 600
                        500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                     18.20.1-1nodesource1 600
                     18.20.0-1nodesource1 600
                     18.19.1-1nodesource1 600
                     18.19.0-1nodesource1 600
                     18.18.2-1nodesource1 600
                     18.18.1-1nodesource1 600
                     18.18.0-1nodesource1 600
                     18.17.1-1nodesource1 600
                     18.17.0-1nodesource1 600
                     18.16.1-1nodesource1 600
                     18.16.0-1nodesource1 600
                     18.15.0-1nodesource1 600
                     18.14.2-1nodesource1 600
                     18.14.1-1nodesource1 600
                     18.14.0-1nodesource1 600
                     18.13.0+dfsg1-1 500
                     18.13.0-1nodesource1 600
                     18.12.0-1nodesource1 600
                     18.11.0-1nodesource1 600
                     18.10.0-1nodesource1 600
                     18.9.1-1nodesource1 600
                     18.9.0-1nodesource1 600
                     18.8.0-1nodesource1 600
                     18.7.0-1nodesource1 600
                     18.6.0-1nodesource1 600
                     18.5.0-1nodesource1 600
                     18.4.0-1nodesource1 600
                     18.3.0-1nodesource1 600
                     18.2.0-1nodesource1 600
                     18.1.0-1nodesource1 600
                     18.0.0-1nodesource1 600
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.13.16
                javascript:     7.8.0
                Adapter State
                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled
                + instance is alive
                Objects and States
                Objects:        14990
                States:         13387
                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       46540273   2123199/iobroker.
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46539313   2123199/iobroker.
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       46540528   2123279/node-red
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       46541106   2123467/io.shelly
                tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       46541132   2123482/io.mqtt.0
                tcp6       0      0 :::3000                 :::*                    LISTEN      113        46530636   2107469/grafana
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46538428   2123223/io.admin.
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46541385   2123559/io.web.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       46543999   2123507/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       46544000   2123507/io.tuya.0
                2024-04-23 12:51:34.173  - error: zigbee2mqtt.0 (2123452) Publish 'get' 'color' to 'Nachtlicht Schlafzimmer' failed: 'E
                2024-04-23 12:52:46.833  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                2024-04-23 12:52:46.836  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:35.89unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                2024-04-23 12:52:46.836  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
                2024-04-23 12:52:46.849  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                2024-04-23 12:52:46.850  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:36.51unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                2024-04-23 12:52:46.850  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_P
                2024-04-23 12:53:05.267  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                2024-04-23 12:53:05.270  - warn: influxdb.0 (2123264) Error on writePoint("{"value":3495,"time":"2024-04-23T10:52:53.02r: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                2024-04-23 12:53:05.270  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
                2024-04-23 12:53:09.343  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                2024-04-23 12:53:09.349  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7381,"time":"2024-04-23T10:52:53.11unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                2024-04-23 12:53:09.350  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
                2024-04-23 12:53:11.700  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                2024-04-23 12:53:11.701  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7,"time":"2024-04-23T10:52:55.155Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                2024-04-23 12:53:11.701  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
                2024-04-23 12:53:13.275  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                2024-04-23 12:53:13.276  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8,"time":"2024-04-23T10:52:59.725Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                2024-04-23 12:53:13.276  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
                2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Error on writePoint("{"value":0.6175750000000001,"time":"2024-04-se}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: t
                2024-04-23 12:53:13.287  - info: influxdb.0 (2123264) Add point that had error for Netzeinspeisung_Tag_Euro to buffer a
                2024-04-23 12:53:13.290  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                2024-04-23 12:53:13.291  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8.8225,"time":"2024-04-23T10:53:00.ror: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                2024-04-23 12:53:13.291  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
                • M marcelinho
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                           3793 M total memory
                           2740 M used memory
                            306 M free memory
                             36 M buffer memory
                            801 M swap cache
                             99 M total swap
                             99 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  18G     /var/
                  16G     /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        14990
                  States:         13387
                  Pending Updates: 0
                  Thomas BraunT
                  Thomas BraunT
                  @marcelinho
                  Bei den Updates war ein Kernel-Update dabei:
                  Neustart der Kiste erforderlich!
                  iob stop
                  sudo reboot
                  M 2 Antworten Letzte Antwort
                  • Marc BergM Marc Berg
                    M
                    M
                    marcelinho
                    @marc-berg ja das ist bei mir in der Tat so, ich schreibe viele Datenpunkte in die influxdb (siehe screenshot) die Scrapers habe ich nun gelöscht - wie kann ich nun die Daten bereinigen ? Danke auch Dir für deine Mühe/Hilfe. Screenshot 2024-04-23 130336.png
                      @marcelinho
                      iob stop
                      sudo reboot
                      M
                      M
                      marcelinho
                      @thomas-braun danke habe ich gemacht - Fehler bleibt bestehen :(
                      • M marcelinho
                        Marc BergM
                        Marc BergM
                        Marc Berg
                        Ja da hast du jetzt ein kleines Problem. Dadurch, dass die zu löschenden Daten mit in deinem ioBroker Bucket gelandet sind (so habe ich es verstanden), musst du diese einzeln auf der Kommandozeile löschen (Bucketname, Organisation und Measurement anpassen)
                        influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home
                        bzw.:
                        influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home -t <token>
                        Ich würde aber dringend empfehlen, die Daten dort rauszulöschen, da man ja in deinen Logs schon sieht, dass die Datenbank Probleme und Timeouts hat.
                        EDIT: hier ein kleines Script zum Löschen der Daten:
                        delete_scraper_data.sh
                          bzw.:
                          M
                          M
                          marcelinho
                          @marc-berg Danke nochmal, Nodered funktioniert jetzt auch - hat nur etwas Zeit gebraucht.
                          Bist der beste - Schönen Abend noch Marc :)
                            @marcelinho
                            iob stop
                            sudo reboot
                            M
                            M
                            marcelinho
                            @thomas-braun wie besprochen die neue Auslesung / Fehler Homebridge bleibt bestehen:
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             15:54:39 up 22:08,  3 users,  load average: 0.21, 0.31, 0.27
                            CPU threads: 4
                            Current issues:
                                           Local time: Wed 2024-04-24 15:54:39 CEST
                                       Universal time: Wed 2024-04-24 13:54:39 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.0G        2.9G        288M         86K        858M        1.1G
                            Swap:           104M         15M         89M
                            Total:          4.1G        2.9G        378M
                                     3793 M total memory
                                     2774 M used memory
                                     2927 M active memory
                                      374 M inactive memory
                                      274 M free memory
                                       93 M buffer memory
                                      726 M swap cache
                                       99 M total swap
                                       14 M used swap
                                       85 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            tmpfs          tmpfs     380M  1.2M  379M   1% /run
                            /dev/mmcblk0p2 ext4       29G   20G  8.0G  71% /
                            tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                            tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                            [Tue Apr 23 17:46:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
                            [Tue Apr 23 17:46:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                            [Tue Apr 23 17:46:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            11G     /var/
                            8.9G    /var/lib
                            8.3G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
                            Archived and active journals take up 739.9M in the file system.
                            215M    /opt/iobroker/backups/
                            320M    /opt/iobroker/iobroker-data/
                            32M     /opt/iobroker/iobroker-data/objects.jsonl
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                            22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
                            9.8M    /opt/iobroker/iobroker-data/states.jsonl
                            8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s
                            USB-Devices by-id:
                            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
                            /usr/bin/npm            10.5.0
                            /usr/bin/npx            10.5.0
                            nodejs:
                              Version table:
                                    500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                                 18.13.0+dfsg1-1 500
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.13.16
                            javascript:     7.8.0
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                            + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                            + instance is alive
                            Objects and States
                            Objects:        14989
                            States:         13387
                            Pending Updates: 3
                            tcp        0      0 127.0.0.1:38691         0.0.0.0:*               LISTEN      112        17194      1300/homebridge: @0
                            tcp        0      0 127.0.0.1:38543         0.0.0.0:*               LISTEN      112        17159      1317/homebridge: ho
                            tcp        0      0 127.0.0.1:40315         0.0.0.0:*               LISTEN      112        17110      1290/homebridge: ho
                            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26211      1952/node-red
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        16746      786/mosquitto
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19125      1561/io.shelly.0
                            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20031      1576/io.mqtt.0
                            tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      112        21533      1634/homebridge: ho
                            tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21580      1617/node
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16938      1082/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17920      1082/iobroker.js-co
                            tcp        0      0 127.0.0.1:37849         0.0.0.0:*               LISTEN      112        19798      1298/homebridge: ho
                            tcp        0      0 127.0.0.1:35727         0.0.0.0:*               LISTEN      112        17154      1291/homebridge: ho
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17543      792/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          343770     9169/cupsd
                            tcp        0      0 127.0.0.1:45139         0.0.0.0:*               LISTEN      112        18280      1293/homebridge: ho
                            tcp        0      0 127.0.0.1:39007         0.0.0.0:*               LISTEN      112        19738      1319/homebridge: ho
                            tcp6       0      0 :::52403                :::*                    LISTEN      112        19754      1298/homebridge: ho
                            tcp6       0      0 :::44253                :::*                    LISTEN      112        19726      1317/homebridge: ho
                            tcp6       0      0 :::1883                 :::*                    LISTEN      114        16747      786/mosquitto
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19538      1140/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21629      1690/io.web.0
                            tcp6       0      0 :::8086                 :::*                    LISTEN      999        16913      892/influxd
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          343769     9169/cupsd
                            tcp6       0      0 :::37166                :::*                    LISTEN      112        18883      1291/homebridge: ho
                            tcp6       0      0 :::45391                :::*                    LISTEN      112        18903      1300/homebridge: @0
                            tcp6       0      0 :::8581                 :::*                    LISTEN      112        17952      1058/hb-service
                            tcp6       0      0 :::53299                :::*                    LISTEN      112        19213      1634/homebridge: ho
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          17545      792/sshd: /usr/sbin
                            tcp6       0      0 :::47961                :::*                    LISTEN      112        18841      1290/homebridge: ho
                            tcp6       0      0 :::3000                 :::*                    LISTEN      113        15360      1081/grafana
                            tcp6       0      0 :::52120                :::*                    LISTEN      112        17120      1319/homebridge: ho
                            tcp6       0      0 :::51798                :::*                    LISTEN      112        18821      1147/homebridge
                            tcp6       0      0 :::39667                :::*                    LISTEN      112        18857      1293/homebridge: ho
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        18887      1293/homebridge: ho
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17949      1058/hb-service
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14012      549/avahi-daemon: r
                            udp        0      0 0.0.0.0:38879           0.0.0.0:*                           104        14014      549/avahi-daemon: r
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20514      1467/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20515      1467/io.tuya.0
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          343790     9192/cups-browsed
                            udp6       0      0 :::5353                 :::*                                104        14013      549/avahi-daemon: r
                            udp6       0      0 :::49377                :::*                                104        14015      549/avahi-daemon: r
                            udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          17593      652/NetworkManager
                            2024-04-24 15:56:16.028  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=1
                            2024-04-24 15:56:16.031  - warn: influxdb.0 (1208) Point could not be written to database: admin
                            2024-04-24 15:56:16.032  - warn: influxdb.0 (1208) Error on writePoint("{"value":-2,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-24 15:56:16.032  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=2
                            2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Point could not be written to database: admin
                            2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Error on writePoint("{"value":0,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-24 15:56:16.037  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=1
                            2024-04-24 15:56:16.132  - warn: influxdb.0 (1208) Point could not be written to database: admin
                            2024-04-24 15:56:16.133  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.088Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-24 15:56:16.134  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
                            2024-04-24 15:56:16.154  - warn: influxdb.0 (1208) Point could not be written to database: admin
                            2024-04-24 15:56:16.155  - warn: influxdb.0 (1208) Error on writePoint("{"value":96,"time":"2024-04-24T13:55:59.437Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-24 15:56:16.155  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=1
                            2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Point could not be written to database: admin
                            2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.091Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-24 15:56:16.165  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=3
                            2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Point could not be written to database: admin
                            2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Error on writePoint("{"value":24.5,"time":"2024-04-24T13:55:02.852Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-24 15:56:16.174  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=1
                            2024-04-24 15:56:16.180  - warn: influxdb.0 (1208) Point could not be written to database: admin
                            2024-04-24 15:56:16.181  - warn: influxdb.0 (1208) Error on writePoint("{"value":98,"time":"2024-04-24T13:50:00.207Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-24 15:56:16.181  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=2
                            2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Point could not be written to database: admin
                            2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Error on writePoint("{"value":24,"time":"2024-04-24T13:56:01.967Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-24 15:56:16.203  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=2
                            • M marcelinho
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           104M         15M         89M
                                       3793 M total memory
                                       2774 M used memory
                                        274 M free memory
                                         93 M buffer memory
                                        726 M swap cache
                                         99 M total swap
                                         14 M used swap
                                         85 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              11G     /var/
                              8.9G    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.13.16
                              javascript:     7.8.0
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        14989
                              States:         13387
                              Pending Updates: 3
                              Thomas BraunT
                              Thomas BraunT
                              Pending Updates: 3
                              Hau die noch rein.
                              Und deiner influxdb geht es immer noch nicht so richtig gut, würde ich sagen.
                              Wenn die da im Millisekundenbereich auf Fehler läuft kann das nicht gesund sein.
                              Zu Homebridge: Mit ist immer noch nicht klar was genau du da machen willst.
                                Pending Updates: 3
                                Hau die noch rein.
                                M
                                M
                                marcelinho
                                @thomas-braun mit sudo apt update & upgrade sollte das gehen oder?
                                Ich möchte Homebridge aktualisieren bzw alte plugins die nicht mehr benötigt werden löschen.
                                Influxdb habe ich gestern mit @Marc-Berg bereinigt. Wüsste nicht was da falsch gehen sollte in grafana wird alles korrekt angezeigt.
                                Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
                                • M marcelinho
                                  Thomas BraunT
                                  Thomas BraunT
                                  Dann schau in das Log:
                                  Sieht für mich nicht gesund aus. Insbesondere nicht in der Frequenz mit der da Zeug geloggt wird. Das bläst dir alleine das Logfile in kürzester Zeit auf unnötige Größen auf.
                                  Homebridge über den ham-Adapter? Der ist aber gar nicht installiert bei dir.
                                  • M marcelinho
                                    Marc BergM
                                    Marc BergM
                                    Marc Berg
                                    Jain. Du hattest den Speicherzeitraum der InfluxDB auf 90 Tage gesetzt und wir haben gesagt, dass die ungewollt geloggten Daten nach 90 Tagen endgültig raus sind.
                                    Du könntest des Speicherzeitraum jetzt auch noch weiter verkürzen, um den Effekt zu beschleunigen.
                                    Weiterhin kannst du in den Datenpunkteinstellungen des InfluxDB Adapters prüfen, ob du weniger Daten wegschreibst, indem du z.B. die Blockierzeit auf 30 Sekunden setzt.
                                      M
                                      M
                                      marcelinho
                                      ham-Adapter
                                      Homebridge habe ich über die SD-Karte über ein Image installiert gehabt
                                      https://smartapfel.de/homebridge/installieren/
                                        M
                                        M
                                        marcelinho
                                        @marc-berg ich habe im influx.db Adapter nun auch 90 Tage geändert und die Blockzeit auf 30 gesetzt - ist dies so korrekt?Screenshot 2024-04-25 075854.png
                                        • M marcelinho
                                          ham-Adapter
                                          Thomas BraunT
                                          Thomas BraunT
                                          @marcelinho
                                          Und wo ist da jetzt die Verbindung zum ioBroker?
                                          Marc BergM M 2 Antworten Letzte Antwort
