  4. Homebridge Fehler Code 243
41 Beiträge 4 Kommentatoren 7.8k Aufrufe 3 Beobachtet
    @marcelinho
    Und wer ruft da mit welchem Befehl was genau auf?
    M
    M
    marcelinho
    @thomas-braun was meinst du genau ? mein Username = homebridge
    wollte jediglich udaten aber dann kam die Fehlermeldung. Danke Dir
      @marcelinho
      M
      M
      marcelinho
      @thomas-braun wenn ich ein Plugin löschen will kommt folgendes:
      USER: homebridge
      DIR: /var/lib/homebridge
      CMD: npm uninstall --save homebridge-lay-z-spa
      npm ERR! code EACCES
      npm ERR! syscall mkdir
      npm ERR! path /nonexistent
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, mkdir '/nonexistent'
      npm ERR! [Error: EACCES: permission denied, mkdir '/nonexistent'] {
      npm ERR! errno: -13,
      npm ERR! code: 'EACCES',
      npm ERR! syscall: 'mkdir',
      npm ERR! path: '/nonexistent',
      npm ERR! requiredBy: 'node_modules/homebridge-deebotecovacs/node_modules/node-xmpp-core'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR! Log files were not written due to an error writing to the directory: /nonexistent/.npm/_logs
      npm ERR! You can rerun the command with --loglevel=verbose to see the logs in your terminal
      Operation failed with code 243.
      You can download this log file for future reference.
      See https://github.com/homebridge/homebridge-config-ui-x/wiki/Troubleshooting for help.
      • M marcelinho
        Thomas BraunT
        Thomas BraunT
        @marcelinho sagte in Homebridge Fehler Code 243:
        Wie? In der GUI? Über die Kommandozeile?
          M
          M
          marcelinho
          @thomas-braun beides in der GUI - habe schon via putty versucht aber bekomme es irgendwie nicht hin.
          • M marcelinho
            Thomas BraunT
            Thomas BraunT
            @marcelinho
            Gib mal die Ausgabe von
            iob diag
            bekannt. Bevorzugt die Langfassung.
            M 2 Antworten Letzte Antwort
              @marcelinho
              iob diag
              M
              M
              marcelinho
              @thomas-braun said in Homebridge Fehler Code 243:
              iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
                        Kernel: Linux 6.1.0-rpi7-rpi-v8
                  Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               11:24:00 up 69 days, 16:18,  4 users,  load average: 0.34, 0.23, 0.36
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Tue 2024-04-23 11:24:01 CEST
                         Universal time: Tue 2024-04-23 09:24:01 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.0G        3.3G        232M         14M        502M        640M
              Swap:           104M        104M        270K
              Total:          4.1G        3.4G        232M
                       3793 M total memory
                       3182 M used memory
                       1041 M active memory
                       2284 M inactive memory
                        221 M free memory
                         56 M buffer memory
                        423 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  1.6G     0  1.6G   0% /dev
              tmpfs          tmpfs     380M  1.3M  379M   1% /run
              /dev/mmcblk0p2 ext4       29G   26G  2.1G  93% /
              tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
              /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
              tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
              [Tue Feb 13 18:05:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bc        m2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_me        m.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1e048ecb-02 rootfstyp        e=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Tue Feb 13 18:05:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Tue Feb 13 18:05:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET               SOURCE         FSTYPE      OPTIONS
              /                    /dev/mmcblk0p2 ext4        rw,noatime
              |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortnam        e=mixed,errors=remount-ro
              /var:
              17G     /var/
              16G     /var/lib
              15G     /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
              Archived and active journals take up 699.9M in the file system.
              /opt/iobroker/backups:
              213M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              302M    /opt/iobroker/iobroker-data/
              191M    /opt/iobroker/iobroker-data/files
              57M     /opt/iobroker/iobroker-data/files/javascript.admin
              52M     /opt/iobroker/iobroker-data/backup-objects
              38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
              20M     /opt/iobroker/iobroker-data/objects.jsonl
              8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
              8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.11.0
              /usr/local/bin/node             v21.1.0
              /usr/local/bin/npm              10.2.0
              /usr/local/bin/npx              10.2.0
              /usr/local/bin/corepack         0.22.0
              *** nodejs is NOT correctly installed ***
              nodejs:
                Installed: 20.11.0-1nodesource1
                Candidate: 20.12.2-1nodesource1
                Version table:
                   20.12.2-1nodesource1 600
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                   20.12.1-1nodesource1 600
                   20.12.0-1nodesource1 600
                   20.11.1-1nodesource1 600
               *** 20.11.0-1nodesource1 600
                   20.10.0-1nodesource1 600
                   20.9.0-1nodesource1 600
                   20.8.1-1nodesource1 600
                   20.8.0-1nodesource1 600
                   20.7.0-1nodesource1 600
                   20.6.1-1nodesource1 600
                   20.6.0-1nodesource1 600
                   20.5.1-1nodesource1 600
                   20.5.0-1nodesource1 600
                   20.4.0-1nodesource1 600
                   20.3.1-1nodesource1 600
                   20.3.0-1nodesource1 600
                   20.2.0-1nodesource1 600
                   20.1.0-1nodesource1 600
                   20.0.0-1nodesource1 600
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                   18.13.0+dfsg1-1 500
                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          6.13.16
              javascript:     7.8.0
              Adapters from github:   3
              Adapter State
              + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
              + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
              + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
              + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
              + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
              + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
              + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
              + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
              + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
              + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.smart-eq.0               : smart-eq              : raspberrypi                              -  enabled
              + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
              + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
              + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.13.16  , installed 6.13.16
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
              Adapter    "daikin"       : 1.4.2    , installed 1.4.2
              Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
              Adapter    "discovery"    : 4.4.0    , installed 4.4.0
              Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
              Adapter    "homekit-controller": 0.5.10, installed 0.5.10
              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
              Controller "js-controller": 5.0.19   , installed 5.0.19
              Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
              Adapter    "meross"       : 1.17.0   , installed 1.17.0
              Adapter    "modbus"       : 6.1.0    , installed 6.1.0
              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
              Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
              Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
              Adapter    "node-red"     : 5.2.0    , installed 5.2.0
              Adapter    "openhab"      : 1.1.0    , installed 1.1.0
              Adapter    "shelly"       : 6.8.0    , installed 6.8.0
              Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
              Adapter    "socketio"     : 6.6.1    , installed 6.6.1
              Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
              Adapter    "tuya"         : 3.15.0   , installed 3.15.0
              Adapter    "web"          : 6.2.5    , installed 6.2.5
              Adapter    "ws"           : 2.5.11   , installed 2.5.11
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
              Objects and States
              Objects:        14990
              States:         13387
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://apt.grafana.com stable InRelease
              Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:8 https://repo.homebridge.io stable InRelease
              Reading package lists...
              Pending Updates: 180
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:39715         0.0.0.0:*               LISTEN      112        46457213   2097759/homebridge:
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5021298    228976/iobroker.js-
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5021312    228976/iobroker.js-
              tcp        0      0 127.0.0.1:39639         0.0.0.0:*               LISTEN      112        46457242   2097771/homebridge:
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          46142328   2081606/cupsd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17032      803/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:43327         0.0.0.0:*               LISTEN      112        46458116   2097772/homebridge:
              tcp        0      0 127.0.0.1:45013         0.0.0.0:*               LISTEN      112        46455694   2097765/homebridge:
              tcp        0      0 127.0.0.1:34425         0.0.0.0:*               LISTEN      112        46480613   2097757/homebridge:
              tcp        0      0 127.0.0.1:34275         0.0.0.0:*               LISTEN      112        46457194   2097778/homebridge:
              tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       684423     32124/node
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       33174888   1491043/node-red
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       28392686   1277149/io.shelly.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        17024      779/mosquitto
              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       5023995    229264/io.mqtt.0
              tcp        0      0 127.0.0.1:44081         0.0.0.0:*               LISTEN      112        46456352   2097758/homebridge:
              tcp        0      0 127.0.0.1:33795         0.0.0.0:*               LISTEN      112        46457227   2097785/homebridge:
              tcp6       0      0 :::8581                 :::*                    LISTEN      112        46418999   2094723/hb-service
              tcp6       0      0 :::45391                :::*                    LISTEN      112        46458125   2097771/homebridge:
              tcp6       0      0 :::37166                :::*                    LISTEN      112        46456334   2097758/homebridge:
              tcp6       0      0 :::53299                :::*                    LISTEN      112        46456339   2097772/homebridge:
              tcp6       0      0 :::22                   :::*                    LISTEN      0          17034      803/sshd: /usr/sbin
              tcp6       0      0 :::3000                 :::*                    LISTEN      113        19873      1596/grafana
              tcp6       0      0 :::52120                :::*                    LISTEN      112        46455673   2097785/homebridge:
              tcp6       0      0 :::47961                :::*                    LISTEN      112        46455615   2097757/homebridge:
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          46142327   2081606/cupsd
              tcp6       0      0 :::39667                :::*                    LISTEN      112        46456297   2097759/homebridge:
              tcp6       0      0 :::51798                :::*                    LISTEN      112        46457171   2097719/homebridge
              tcp6       0      0 :::44253                :::*                    LISTEN      112        46455623   2097778/homebridge:
              tcp6       0      0 :::52403                :::*                    LISTEN      112        46456301   2097765/homebridge:
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5021363    229001/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38441274   1730388/io.web.0
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        19857      1400/influxd
              tcp6       0      0 :::1883                 :::*                    LISTEN      114        17025      779/mosquitto
              udp        0      0 0.0.0.0:47202           0.0.0.0:*                           104        13649      516/avahi-daemon: r
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5021645    229175/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5021646    229175/io.tuya.0
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          46142333   2081608/cups-browse
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46458119   2097759/homebridge:
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46418996   2094723/hb-service
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13647      516/avahi-daemon: r
              udp6       0      0 :::39317                :::*                                104        13650      516/avahi-daemon: r
              udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          20485      651/NetworkManager
              udp6       0      0 :::5353                 :::*                                104        13648      516/avahi-daemon: r
              2024-04-23 11:25:31.610  - warn: influxdb.0 (229070) Error on writePoint("{"value":4294,"time":"2024-04-23T09:25:19.093Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
              2024-04-23 11:25:31.610  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=4
              2024-04-23 11:25:31.619  - warn: influxdb.0 (229070) Point could not be written to database: admin
              2024-04-23 11:25:31.619  - warn: influxdb.0 (229070) Error on writePoint("{"value":5.3333,"time":"2024-04-23T09:25:20.001Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
              2024-04-23 11:25:31.620  - info: influxdb.0 (229070) Discard point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh, error-count=10
              2024-04-23 11:25:31.624  - warn: influxdb.0 (229070) Point could not be written to database: admin
              2024-04-23 11:25:31.624  - warn: influxdb.0 (229070) Error on writePoint("{"value":0.3733310000000001,"time":"2024-04-23T09:25:20.007Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
              2024-04-23 11:25:31.625  - info: influxdb.0 (229070) Add point that had error for Netzeinspeisung_Tag_Euro to buffer again, error-count=6
              2024-04-23 11:25:34.932  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 closed: null
              2024-04-23 11:25:39.931  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 reconnected
              2024-04-23 11:25:40.155  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 connected
              2024-04-23 11:25:56.900  - warn: influxdb.0 (229070) Point could not be written to database: admin
              2024-04-23 11:25:56.901  - warn: influxdb.0 (229070) Error on writePoint("{"value":2360,"time":"2024-04-23T09:25:46.607Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
              2024-04-23 11:25:56.902  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=5
              2024-04-23 11:25:56.908  - warn: influxdb.0 (229070) Point could not be written to database: admin
              2024-04-23 11:25:56.913  - warn: influxdb.0 (229070) Error on writePoint("{"value":7474,"time":"2024-04-23T09:25:40.968Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
              2024-04-23 11:25:56.914  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_Power to buffer again, error-count=7
              2024-04-23 11:25:56.923  - warn: influxdb.0 (229070) Point could not be written to database: admin
              2024-04-23 11:25:56.934  - warn: influxdb.0 (229070) Error on writePoint("{"value":2360,"time":"2024-04-23T09:25:46.603Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
              2024-04-23 11:25:56.934  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
              2024-04-23 11:26:00.245  - info: meross.0 (229216) Can not get Data for Device 2103163856729736101148e1e9629220: Error: Timeout
              2024-04-23 11:26:00.246  - warn: meross.0 (229216) Can not get Data for Device 2103163856729736101148e1e9629220: undefined
              2024-04-23 11:26:04.933  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 closed: null
              2024-04-23 11:26:09.934  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 reconnected
              2024-04-23 11:26:10.115  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 connected
              iob diag has finished.
                @marcelinho
                iob diag
                M
                M
                marcelinho
                Copy text starting here:
                                        v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
                Kernel:                 aarch64
                Userland:               arm64
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     180
                Pending iob updates:    0
                Nodejs-Installation:    /usr/bin/nodejs         v20.11.0
                Recommended versions are nodejs 18.20.2 and npm 10.5.0
                Wrong installation path detected. This needs to be fixed.
                Please check
                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                for more information on how to fix these errors.
                MEMORY:
                Mem:            4.0G        3.4G        101M         14M        601M        608M
                Swap:           104M        104M        221K
                Total:          4.1G        3.5G        101M
                Active iob-Instances:   24
                ioBroker Core:          js-controller           5.0.19
                                        admin                   6.13.16
                Objects type: jsonl
                States  type: jsonl
                Objects:                14990
                States:                 13387
                Size of iob-Database:
                4.0M    /opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===
                • M marcelinho
                  iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                           3793 M total memory
                           3182 M used memory
                            221 M free memory
                             56 M buffer memory
                            423 M swap cache
                             99 M total swap
                             99 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  17G     /var/
                  16G     /var/lib
                  USB-Devices by-id:
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        14990
                  States:         13387
                  Thomas BraunT
                  Thomas BraunT
                  Boot Target: graphical.target
                  Stell da um auf multi-user.
                  sudo systemctl set-default multi-user.target
                  Dein root-Verzeichnis läuft voll.
                  Räum da auf.
                  nodejs ist hinten und vorne falsch installiert.
                  iob nodejs-update
                  und nodejs18 darüber sauber installieren lassen.
                  System regelmäßig (bzw. überhaupt) pflegen.
                  Mit der influxdb gibt es wohl auch Trouble.
                    Räum da auf.
                    iob nodejs-update
                    M
                    M
                    marcelinho
                    iob nodejs-update
                    Danke Dir, wie kann ich root-Verzeichnis aufräumen?
                    Influxdb läuft bisher problemlos - was kann ich da tun?
                    Thomas BraunT Marc BergM 3 Antworten Letzte Antwort
                    • M marcelinho
                      iob nodejs-update
                      Thomas BraunT
                      Thomas BraunT
                      Erstmal schauen, was da so dickes drin liegt und wo man ansetzen muss.
                      Ich mach das immer per
                      sudo ncdu /
                      ncdu muss u. U. noch nachinstalliert werden.
                      • M marcelinho
                        iob nodejs-update
                        Thomas BraunT
                        Thomas BraunT
                        Wenn es problemlos liefe hättest du nicht die ganzen Meldungen im LogFile.
                        Ich setze influxdb aber nicht ein, muss dir vielleicht wer anders helfen.
                        @Marc-Berg ist hier der DB-Spezialist.
                        • M marcelinho
                          iob nodejs-update
                          Marc BergM
                          Marc BergM
                          Marc Berg
                          Ich würde sagen, unter normalen Bedingungen bekommt man eine InfluxDB kaum in solche Größenordnungen wie bei dir. Der Klassiker ist, dass man versehentlich das Logging von Performancedaten aktiviert hat. Du kannst mal diesen Thread anschauen, ob das bei dir der Fall ist:
                          https://forum.iobroker.net/topic/73784/speicherplatzbelegung-influxdb2-nach-containerisierung
                            M
                            M
                            marcelinho
                            @thomas-braun also nodejs habe ich hinbekommen laut iob diag. Aber in Homebridge funktioniert es noch nicht...
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             12:51:12 up 69 days, 17:46,  4 users,  load average: 0.92, 0.67, 1.32
                            CPU threads: 4
                            Current issues:
                                           Local time: Tue 2024-04-23 12:51:12 CEST
                                       Universal time: Tue 2024-04-23 10:51:12 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            4.0G        2.9G        321M         17M        878M        1.1G
                            Swap:           104M        104M        389K
                            Total:          4.1G        3.0G        322M
                                     3793 M total memory
                                     2740 M used memory
                                     1102 M active memory
                                     2016 M inactive memory
                                      306 M free memory
                                       36 M buffer memory
                                      801 M swap cache
                                       99 M total swap
                                       99 M used swap
                                        0 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/mmcblk0p2 ext4       29G   27G  1.2G  96% /
                            tmpfs          tmpfs     1.9G  140K  1.9G   1% /dev/shm
                            [Tue Feb 13 18:05:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bc_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200s rootwait quiet splash plymouth.ignore-serial-consoles
                            /var:
                            18G     /var/
                            16G     /var/lib
                            308M    /opt/iobroker/iobroker-data/
                            21M     /opt/iobroker/iobroker-data/objects.jsonl
                            8.7M    /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            /usr/bin/nodejs         v18.20.2
                            /usr/bin/node           v18.20.2
                            /usr/bin/npm            10.5.0
                            /usr/bin/npx            10.5.0
                            /usr/bin/corepack       0.25.2
                            nodejs:
                              Installed: 18.20.2-1nodesource1
                              Candidate: 18.20.2-1nodesource1
                              Version table:
                             *** 18.20.2-1nodesource1 600
                                    500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                 18.20.1-1nodesource1 600
                                 18.20.0-1nodesource1 600
                                 18.19.1-1nodesource1 600
                                 18.19.0-1nodesource1 600
                                 18.18.2-1nodesource1 600
                                 18.18.1-1nodesource1 600
                                 18.18.0-1nodesource1 600
                                 18.17.1-1nodesource1 600
                                 18.17.0-1nodesource1 600
                                 18.16.1-1nodesource1 600
                                 18.16.0-1nodesource1 600
                                 18.15.0-1nodesource1 600
                                 18.14.2-1nodesource1 600
                                 18.14.1-1nodesource1 600
                                 18.14.0-1nodesource1 600
                                 18.13.0+dfsg1-1 500
                                 18.13.0-1nodesource1 600
                                 18.12.0-1nodesource1 600
                                 18.11.0-1nodesource1 600
                                 18.10.0-1nodesource1 600
                                 18.9.1-1nodesource1 600
                                 18.9.0-1nodesource1 600
                                 18.8.0-1nodesource1 600
                                 18.7.0-1nodesource1 600
                                 18.6.0-1nodesource1 600
                                 18.5.0-1nodesource1 600
                                 18.4.0-1nodesource1 600
                                 18.3.0-1nodesource1 600
                                 18.2.0-1nodesource1 600
                                 18.1.0-1nodesource1 600
                                 18.0.0-1nodesource1 600
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.13.16
                            javascript:     7.8.0
                            Adapter State
                            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled
                            + instance is alive
                            Objects and States
                            Objects:        14990
                            States:         13387
                            Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       46540273   2123199/iobroker.
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46539313   2123199/iobroker.
                            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       46540528   2123279/node-red
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       46541106   2123467/io.shelly
                            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       46541132   2123482/io.mqtt.0
                            tcp6       0      0 :::3000                 :::*                    LISTEN      113        46530636   2107469/grafana
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46538428   2123223/io.admin.
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46541385   2123559/io.web.0
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       46543999   2123507/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       46544000   2123507/io.tuya.0
                            2024-04-23 12:51:34.173  - error: zigbee2mqtt.0 (2123452) Publish 'get' 'color' to 'Nachtlicht Schlafzimmer' failed: 'E
                            2024-04-23 12:52:46.833  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                            2024-04-23 12:52:46.836  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:35.89unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-23 12:52:46.836  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
                            2024-04-23 12:52:46.849  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                            2024-04-23 12:52:46.850  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:36.51unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-23 12:52:46.850  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_P
                            2024-04-23 12:53:05.267  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                            2024-04-23 12:53:05.270  - warn: influxdb.0 (2123264) Error on writePoint("{"value":3495,"time":"2024-04-23T10:52:53.02r: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-23 12:53:05.270  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
                            2024-04-23 12:53:09.343  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                            2024-04-23 12:53:09.349  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7381,"time":"2024-04-23T10:52:53.11unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-23 12:53:09.350  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
                            2024-04-23 12:53:11.700  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                            2024-04-23 12:53:11.701  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7,"time":"2024-04-23T10:52:55.155Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-23 12:53:11.701  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
                            2024-04-23 12:53:13.275  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                            2024-04-23 12:53:13.276  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8,"time":"2024-04-23T10:52:59.725Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-23 12:53:13.276  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
                            2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                            2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Error on writePoint("{"value":0.6175750000000001,"time":"2024-04-se}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: t
                            2024-04-23 12:53:13.287  - info: influxdb.0 (2123264) Add point that had error for Netzeinspeisung_Tag_Euro to buffer a
                            2024-04-23 12:53:13.290  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                            2024-04-23 12:53:13.291  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8.8225,"time":"2024-04-23T10:53:00.ror: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                            2024-04-23 12:53:13.291  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
                            • M marcelinho
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                                       3793 M total memory
                                       2740 M used memory
                                        306 M free memory
                                         36 M buffer memory
                                        801 M swap cache
                                         99 M total swap
                                         99 M used swap
                                          0 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              18G     /var/
                              16G     /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.13.16
                              javascript:     7.8.0
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        14990
                              States:         13387
                              Pending Updates: 0
                              Thomas BraunT
                              Thomas BraunT
                              @marcelinho
                              Bei den Updates war ein Kernel-Update dabei:
                              Neustart der Kiste erforderlich!
                              iob stop
                              sudo reboot
                              • Marc BergM Marc Berg
                                M
                                M
                                marcelinho
                                @marc-berg ja das ist bei mir in der Tat so, ich schreibe viele Datenpunkte in die influxdb (siehe screenshot) die Scrapers habe ich nun gelöscht - wie kann ich nun die Daten bereinigen ? Danke auch Dir für deine Mühe/Hilfe. Screenshot 2024-04-23 130336.png
                                  @marcelinho
                                  iob stop
                                  sudo reboot
                                  M
                                  M
                                  marcelinho
                                  @thomas-braun danke habe ich gemacht - Fehler bleibt bestehen :(
                                  • M marcelinho
                                    Marc BergM
                                    Marc BergM
                                    Marc Berg
                                    Ja da hast du jetzt ein kleines Problem. Dadurch, dass die zu löschenden Daten mit in deinem ioBroker Bucket gelandet sind (so habe ich es verstanden), musst du diese einzeln auf der Kommandozeile löschen (Bucketname, Organisation und Measurement anpassen)
                                    influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home
                                    bzw.:
                                    influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home -t <token>
                                    Ich würde aber dringend empfehlen, die Daten dort rauszulöschen, da man ja in deinen Logs schon sieht, dass die Datenbank Probleme und Timeouts hat.
                                    EDIT: hier ein kleines Script zum Löschen der Daten:
                                    delete_scraper_data.sh
                                      bzw.:
                                      M
                                      M
                                      marcelinho
                                      @marc-berg Danke nochmal, Nodered funktioniert jetzt auch - hat nur etwas Zeit gebraucht.
                                      Bist der beste - Schönen Abend noch Marc :)
                                        @marcelinho
                                        iob stop
                                        sudo reboot
                                        M
                                        M
                                        marcelinho
                                        @thomas-braun wie besprochen die neue Auslesung / Fehler Homebridge bleibt bestehen:
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : arm64
                                         15:54:39 up 22:08,  3 users,  load average: 0.21, 0.31, 0.27
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Wed 2024-04-24 15:54:39 CEST
                                                   Universal time: Wed 2024-04-24 13:54:39 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            4.0G        2.9G        288M         86K        858M        1.1G
                                        Swap:           104M         15M         89M
                                        Total:          4.1G        2.9G        378M
                                                 3793 M total memory
                                                 2774 M used memory
                                                 2927 M active memory
                                                  374 M inactive memory
                                                  274 M free memory
                                                   93 M buffer memory
                                                  726 M swap cache
                                                   99 M total swap
                                                   14 M used swap
                                                   85 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        tmpfs          tmpfs     380M  1.2M  379M   1% /run
                                        /dev/mmcblk0p2 ext4       29G   20G  8.0G  71% /
                                        tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                                        tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                                        [Tue Apr 23 17:46:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
                                        [Tue Apr 23 17:46:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                                        [Tue Apr 23 17:46:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        11G     /var/
                                        8.9G    /var/lib
                                        8.3G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
                                        Archived and active journals take up 739.9M in the file system.
                                        215M    /opt/iobroker/backups/
                                        320M    /opt/iobroker/iobroker-data/
                                        32M     /opt/iobroker/iobroker-data/objects.jsonl
                                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                                        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
                                        9.8M    /opt/iobroker/iobroker-data/states.jsonl
                                        8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
                                        /usr/bin/npm            10.5.0
                                        /usr/bin/npx            10.5.0
                                        nodejs:
                                          Version table:
                                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                                             18.13.0+dfsg1-1 500
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.13.16
                                        javascript:     7.8.0
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                                        + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                                        + instance is alive
                                        Objects and States
                                        Objects:        14989
                                        States:         13387
                                        Pending Updates: 3
                                        tcp        0      0 127.0.0.1:38691         0.0.0.0:*               LISTEN      112        17194      1300/homebridge: @0
                                        tcp        0      0 127.0.0.1:38543         0.0.0.0:*               LISTEN      112        17159      1317/homebridge: ho
                                        tcp        0      0 127.0.0.1:40315         0.0.0.0:*               LISTEN      112        17110      1290/homebridge: ho
                                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26211      1952/node-red
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        16746      786/mosquitto
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19125      1561/io.shelly.0
                                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20031      1576/io.mqtt.0
                                        tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      112        21533      1634/homebridge: ho
                                        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21580      1617/node
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16938      1082/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17920      1082/iobroker.js-co
                                        tcp        0      0 127.0.0.1:37849         0.0.0.0:*               LISTEN      112        19798      1298/homebridge: ho
                                        tcp        0      0 127.0.0.1:35727         0.0.0.0:*               LISTEN      112        17154      1291/homebridge: ho
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17543      792/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          343770     9169/cupsd
                                        tcp        0      0 127.0.0.1:45139         0.0.0.0:*               LISTEN      112        18280      1293/homebridge: ho
                                        tcp        0      0 127.0.0.1:39007         0.0.0.0:*               LISTEN      112        19738      1319/homebridge: ho
                                        tcp6       0      0 :::52403                :::*                    LISTEN      112        19754      1298/homebridge: ho
                                        tcp6       0      0 :::44253                :::*                    LISTEN      112        19726      1317/homebridge: ho
                                        tcp6       0      0 :::1883                 :::*                    LISTEN      114        16747      786/mosquitto
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19538      1140/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21629      1690/io.web.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        16913      892/influxd
                                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          343769     9169/cupsd
                                        tcp6       0      0 :::37166                :::*                    LISTEN      112        18883      1291/homebridge: ho
                                        tcp6       0      0 :::45391                :::*                    LISTEN      112        18903      1300/homebridge: @0
                                        tcp6       0      0 :::8581                 :::*                    LISTEN      112        17952      1058/hb-service
                                        tcp6       0      0 :::53299                :::*                    LISTEN      112        19213      1634/homebridge: ho
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          17545      792/sshd: /usr/sbin
                                        tcp6       0      0 :::47961                :::*                    LISTEN      112        18841      1290/homebridge: ho
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      113        15360      1081/grafana
                                        tcp6       0      0 :::52120                :::*                    LISTEN      112        17120      1319/homebridge: ho
                                        tcp6       0      0 :::51798                :::*                    LISTEN      112        18821      1147/homebridge
                                        tcp6       0      0 :::39667                :::*                    LISTEN      112        18857      1293/homebridge: ho
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        18887      1293/homebridge: ho
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17949      1058/hb-service
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14012      549/avahi-daemon: r
                                        udp        0      0 0.0.0.0:38879           0.0.0.0:*                           104        14014      549/avahi-daemon: r
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20514      1467/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20515      1467/io.tuya.0
                                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          343790     9192/cups-browsed
                                        udp6       0      0 :::5353                 :::*                                104        14013      549/avahi-daemon: r
                                        udp6       0      0 :::49377                :::*                                104        14015      549/avahi-daemon: r
                                        udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          17593      652/NetworkManager
                                        2024-04-24 15:56:16.028  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=1
                                        2024-04-24 15:56:16.031  - warn: influxdb.0 (1208) Point could not be written to database: admin
                                        2024-04-24 15:56:16.032  - warn: influxdb.0 (1208) Error on writePoint("{"value":-2,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                        2024-04-24 15:56:16.032  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=2
                                        2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Point could not be written to database: admin
                                        2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Error on writePoint("{"value":0,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                        2024-04-24 15:56:16.037  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=1
                                        2024-04-24 15:56:16.132  - warn: influxdb.0 (1208) Point could not be written to database: admin
                                        2024-04-24 15:56:16.133  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.088Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                        2024-04-24 15:56:16.134  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
                                        2024-04-24 15:56:16.154  - warn: influxdb.0 (1208) Point could not be written to database: admin
                                        2024-04-24 15:56:16.155  - warn: influxdb.0 (1208) Error on writePoint("{"value":96,"time":"2024-04-24T13:55:59.437Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                        2024-04-24 15:56:16.155  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=1
                                        2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Point could not be written to database: admin
                                        2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.091Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                        2024-04-24 15:56:16.165  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=3
                                        2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Point could not be written to database: admin
                                        2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Error on writePoint("{"value":24.5,"time":"2024-04-24T13:55:02.852Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                        2024-04-24 15:56:16.174  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=1
                                        2024-04-24 15:56:16.180  - warn: influxdb.0 (1208) Point could not be written to database: admin
                                        2024-04-24 15:56:16.181  - warn: influxdb.0 (1208) Error on writePoint("{"value":98,"time":"2024-04-24T13:50:00.207Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                        2024-04-24 15:56:16.181  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=2
                                        2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Point could not be written to database: admin
                                        2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Error on writePoint("{"value":24,"time":"2024-04-24T13:56:01.967Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                        2024-04-24 15:56:16.203  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=2
                                        • M marcelinho
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : arm64
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:           104M         15M         89M
                                                   3793 M total memory
                                                   2774 M used memory
                                                    274 M free memory
                                                     93 M buffer memory
                                                    726 M swap cache
                                                     99 M total swap
                                                     14 M used swap
                                                     85 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          11G     /var/
                                          8.9G    /var/lib
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.5.0
                                          /usr/bin/npx            10.5.0
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.13.16
                                          javascript:     7.8.0
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        14989
                                          States:         13387
                                          Pending Updates: 3
                                          Thomas BraunT
                                          Thomas BraunT
                                          Pending Updates: 3
                                          Hau die noch rein.
                                          Und deiner influxdb geht es immer noch nicht so richtig gut, würde ich sagen.
                                          Wenn die da im Millisekundenbereich auf Fehler läuft kann das nicht gesund sein.
                                          Zu Homebridge: Mit ist immer noch nicht klar was genau du da machen willst.
