  4. [gelöst] Sporadische Neustarts des iobroker
26 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • M m.schalk
    @thomas-braun root :-)
    1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
    @m-schalk
    Und den wichtigsten Part hast unterschlagen. Die Rechte stehen ganz am Anfang.
    So soll das aussehen:
    echad@chet:/opt/iobroker $ ls -la /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
    lrwxrwxrwx 1 root root 13 Apr  8 17:19 /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
      @m-schalk
      m.schalk
      ---------- 1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
      • M m.schalk
        @m-schalk
        Ja, das hat mit dem Durchreichen in den Container zu tun. Hab ich aber keine Ahnung von.
          @m-schalk
          m.schalk
          @thomas-braun ok, trotzdem Danke, ich schau mal wie es läuft.
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: BU02SMART02-iobroker
                 Icon name: computer-container
                   Chassis: container
            Virtualization: lxc
          Operating System: Ubuntu 22.04.4 LTS
                    Kernel: Linux 6.2.16-18-pve
              Architecture: x86-64
          model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           22:13:26 up  1:20,  2 users,  load average: 5.88, 4.78, 4.63
          CPU threads: 4
          *** Time and Time Zones ***
                         Local time: Tue 2024-04-16 22:13:26 CEST
                     Universal time: Tue 2024-04-16 20:13:26 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** User and Groups ***
          mario
          /home/mario
          mario sudo iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.2G        4.0G        1.9G        0.0K        2.3G        4.2G
          Swap:           7.8G        0.0K        7.8G
          Total:           15G        4.0G        9.6G
                   8192 M total memory
                   4020 M used memory
                    844 M active memory
                   5138 M inactive memory
                   1879 M free memory
                      0 M buffer memory
                   2292 M swap cache
                   7759 M total swap
                      0 M used swap
                   7759 M free swap
          *** FAILED SERVICES ***
            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          1 loaded units listed.
          *** FILESYSTEM ***
          Filesystem     Type   Size  Used Avail Use% Mounted on
          /dev/loop0     ext4    26G   21G  4.6G  82% /
          none           tmpfs  492K  4.0K  488K   1% /dev
          tmpfs          tmpfs  7.8G     0  7.8G   0% /dev/shm
          tmpfs          tmpfs  3.1G  152K  3.1G   1% /run
          tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/1001
          dmesg: read kernel buffer failed: Operation not permitted
          TARGET SOURCE     FSTYPE OPTIONS
          /      /dev/loop0 ext4   rw,relatime
          /var:
          4.0G    /var/
          2.8G    /var/log
          2.7G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
          781M    /var/lib
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          713M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          7.9G    /opt/iobroker/iobroker-data/
          6.5G    /opt/iobroker/iobroker-data/history
          627M    /opt/iobroker/iobroker-data/files
          487M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
          49M     /opt/iobroker/iobroker-data/objects.jsonl
          41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          28M     /opt/iobroker/iobroker-data/states.jsonl
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.2
          /usr/bin/node           v18.20.2
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.25.2
          nodejs:
            Installed: 18.20.2-1nodesource1
            Candidate: 18.20.2-1nodesource1
            Version table:
           *** 18.20.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.9~dfsg-1ubuntu3.5 500
                  500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                  500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
               12.22.9~dfsg-1ubuntu3 500
                  500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          At least one iobroker host is running.
          Objects type: redis
          States  type: redis
          Core adapters versions
          js-controller:  5.0.19
          admin:          6.17.3
          javascript:     8.0.3
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
          + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
          + system.adapter.backitup.0               : backitup              : BU02SMART02-iobroker                     -  enabled
          + system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     -  enabled
          + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
          + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
          + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
            system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
            system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
          + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
          + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
            system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
            system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
          + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
          + system.adapter.ford.0                   : ford                  : BU02SMART02-iobroker                     -  enabled
          + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
          + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
            system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
          + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : BU02SMART02-iobroker                     -  enabled
          + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
          + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
          + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
            system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
          + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     -  enabled
            system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
          + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
          + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
            system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
            system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-iobroker                     - disabled
          + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
            system.adapter.proxmox.0                : proxmox               : BU02SMART02-iobroker                     - disabled, port: 8006
          + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
          + system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     -  enabled
          + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
          + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
            system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-iobroker                     - disabled
          + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
          + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
            system.adapter.snmp.0                   : snmp                  : BU02SMART02-iobroker                     - disabled
            system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
          + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
          + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
            system.adapter.tuya.1                   : tuya                  : BU02SMART02-iobroker                     - disabled
            system.adapter.unifi.0                  : unifi                 : BU02SMART02-iobroker                     - disabled
          + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
            system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
          + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.ws.0                     : ws                    : BU02SMART02-iobroker                     - disabled, port: 8087, bind: 192.168.2.166, run as: admin
          + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
            system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
          + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          Stable (default): http://download.iobroker.net/sources-dist.json
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Active repo(s): Beta (latest)
          Installed ioBroker-Instances
          Used repository: Beta (latest)
          Adapter    "admin"        : 6.17.3   , installed 6.17.3
          Adapter    "alarm"        : 3.6.0    , installed 3.6.0
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "apcups"       : 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
          Adapter    "daikin"       : 1.4.2    , installed 1.4.2
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "device-watcher": 2.12.0  , installed 2.12.0
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
          Adapter    "ems-esp"      : 3.1.1    , installed 3.1.1
          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
          Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "followthesun" : 0.5.0    , installed 0.5.0
          Adapter    "ford"         : 0.2.0    , installed 0.2.0
          Adapter    "hass-mqtt"    : 0.0.7    , installed 0.0.7
          Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
          Adapter    "ical"         : 1.14.3   , installed 1.14.3
          Adapter    "info"         : 2.0.0    , installed 2.0.0
          Adapter    "iot"          : 3.2.2    , installed 3.2.2
          Adapter    "javascript"   : 8.0.3    , installed 8.0.3
          Controller "js-controller": 5.0.19   , installed 5.0.19
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
          Adapter    "mercedesme"   : 0.2.2    , installed 0.2.2
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
          Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "openweathermap": 1.0.4   , installed 1.0.4
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
          Adapter    "ring"         : 5.0.10   , installed 5.0.10
          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
          Adapter    "shelly"       : 6.9.0    , installed 6.9.0
          Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
          Adapter    "slideshow"    : 0.1.4    , installed 0.1.4
          Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
          Adapter    "snmp"         : 3.2.0    , installed 3.2.0
          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "telegram"     : 3.2.1    , installed 3.2.1
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
          Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
          Adapter    "vis"          : 1.5.5    , installed 1.5.5
          Adapter    "vis-2"        : 2.9.49   , installed 2.9.49
          Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
          Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
          Adapter    "vis-2-widgets-material": 1.3.27, installed 1.3.27
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "web"          : 6.2.5    , installed 6.2.5
          Adapter    "ws"           : 2.5.11   , installed 2.5.11
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        49451
          States:         42960
          Hit:1 https://repos.influxdata.com/debian stable InRelease
          Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
          Hit:3 https://apt.grafana.com stable InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          134632524  1/init
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       134767830  3724/io.mqtt.0
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          134635725  283/master
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        134631393  100/systemd-resolve
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        134635550  116/redis-server 12
          tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1001       134826590  5717/sshd: mario@pt
          tcp        0      0 0.0.0.0:39227           0.0.0.0:*               LISTEN      1000       134773301  4042/io.yahka.0
          tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       134769007  3803/io.shelly.1
          tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       134770223  3841/io.mqtt.1
          tcp6       0      0 :::111                  :::*                    LISTEN      0          134632526  1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          134632859  1/init
          tcp6       0      0 :::3000                 :::*                    LISTEN      112        134639723  339/grafana
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          134635726  283/master
          tcp6       0      0 ::1:6379                :::*                    LISTEN      113        134635551  116/redis-server 12
          tcp6       0      0 ::1:6011                :::*                    LISTEN      1001       134826589  5717/sshd: mario@pt
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       134762300  3585/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134782529  4319/io.web.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       134775091  4042/io.yahka.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       134773821  3917/io.shelly.0
          udp        0      0 0.0.0.0:55014           0.0.0.0:*                           1000       135249274  3917/io.shelly.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134765342  3672/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134765343  3672/io.tuya.0
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        134631392  100/systemd-resolve
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          134632525  1/init
          udp6       0      0 :::111                  :::*                                0          134632527  1/init
          2024-04-16 21:49:27.283  - info: zigbee.0 (13050) 0x84182600000d798a (addr 50622): AB3257001NJ - OSRAM Smart+ plug (Router)
          2024-04-16 21:49:27.285  - info: zigbee.0 (13050) 0x7cb03eaa00ad4adf (addr 48445): AB3257001NJ - OSRAM Smart+ plug (Router)
          2024-04-16 21:49:27.287  - info: zigbee.0 (13050) 0x7cb03eaa00ad1661 (addr 64742): AB3257001NJ - OSRAM Smart+ plug (Router)
          2024-04-16 21:49:27.289  - info: zigbee.0 (13050) 0x8418260000cab6da (addr 26679): 4052899926110 - OSRAM Flex RGBW (Router)
          2024-04-16 21:49:27.291  - info: zigbee.0 (13050) 0x5c0272fffe6e55ea (addr 38364): E1746 - IKEA TRADFRI signal repeater (Router)
          2024-04-16 21:49:27.294  - info: zigbee.0 (13050) 0x54ef4410005b43d3 (addr 45208): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
          2024-04-16 21:49:27.297  - info: zigbee.0 (13050) 0x5c0272fffe5b723b (addr 27218): E1746 - IKEA TRADFRI signal repeater (Router)
          2024-04-16 21:49:27.298  - info: zigbee.0 (13050) 0x7cb03eaa0a068fec (addr 16021): AB3257001NJ - OSRAM Smart+ plug (Router)
          2024-04-16 21:49:27.306  - info: zigbee.0 (13050) 0x00158d0008a6bd14 (addr 37504): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
          2024-04-16 21:49:27.308  - info: zigbee.0 (13050) 0x00158d0008834af4 (addr 53958): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
          2024-04-16 21:49:27.309  - info: zigbee.0 (13050) Zigbee started
          2024-04-16 21:49:27.379  - info: zigbee.0 (13050) debug devices set to []
          2024-04-16 21:49:35.454  - info: admin.0 (3585) ==> Connected system.user.admin from ::ffff:192.168.2.160
          2024-04-16 21:49:35.812  - info: zigbee.0 (13050) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}]
          2024-04-16 21:50:03.153  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa0a068fec Plug 01
          2024-04-16 21:59:03.751  - info: feiertage.0 (14906) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
          2024-04-16 21:59:03.864  - info: feiertage.0 (14906) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
          2024-04-16 21:59:03.874  - info: feiertage.0 (14906) all objects written
          2024-04-16 21:59:03.883  - info: feiertage.0 (14906) Terminated (NO_ERROR): Without reason
          2024-04-16 22:00:09.226  - info: feiertage.0 (15092) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
          2024-04-16 22:00:09.729  - info: feiertage.0 (15092) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
          2024-04-16 22:00:09.875  - info: feiertage.0 (15092) all objects written
          2024-04-16 22:00:09.889  - info: feiertage.0 (15092) Terminated (NO_ERROR): Without reason
          2024-04-16 22:00:21.817  - warn: netatmo-crawler.0 (15192) slow connection to objects DB. Still waiting ...
          2024-04-16 22:06:45.998  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa00ad1661 Plug 01
          • M m.schalk
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Chassis: container
              Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                             RTC time: n/a
                      RTC in local TZ: no
            mario
            /home/mario
            mario sudo iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                     8192 M total memory
                     4020 M used memory
                      844 M active memory
                     1879 M free memory
                        0 M buffer memory
                     2292 M swap cache
                     7759 M total swap
                        0 M used swap
                     7759 M free swap
            *** FILESYSTEM ***
            /var:
            4.0G    /var/
            2.8G    /var/log
            781M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.5.0
            /usr/bin/npx            10.5.0
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: redis
            States  type: redis
            admin:          6.17.3
            javascript:     8.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        49451
            States:         42960
            Pending Updates: 0
            @m-schalk sagte in Sporadische Neustarts des iobroker:
            Wenn die Kiste jetzt nicht stabiler läuft:
            Ich vermute hier ein Skript, das ungünstig angelegt wurde.
              m.schalk
              @thomas-braun Hallo Thomas, die Restarts sind weniger geworden, aber leider sind es immer noch 2 am Tag. Was kann ich noch prüfen? Skripte?
              Thomas BraunT ? 2 Antworten Letzte Antwort
              • M m.schalk
                @m-schalk
                Ja, i.d.R. ist dann ein Skript falsch/ungünstig angelegt.
                  @m-schalk
                  m.schalk
                  @thomas-braun leider weiß ich nicht, wie ich das überprüfen kann.
                  • M m.schalk
                    @m-schalk
                    Ich auch nicht.
                    M 2 Antworten Letzte Antwort
                    • M m.schalk
                      oder Backup? Backups fressen Speicher und Ressourcen.. nicht, dass hier die Luft aus geht..?
                      Bei den Skripten bleibt nur eins, der Reihe nach ausschalten oder alle Aus, und dann der Reihe nach ein..
                      Es hilft auch, die Uhrzeiten zu protokollieren, und dann im Log zu sehen, was vorher passiert ist.. auch Skripte, die kurz vorher starten, mal anschauen..
                        @m-schalk
                        Ich auch nicht.
                        m.schalk
                        @thomas-braun was kannst du dazu sagen? Das habe ich ca 1000
                        2024-04-19 21:30:47.475  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2024-04-19 21:30:47.475  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.475  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                           at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                           at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                        2024-04-19 21:30:47.823  - error: shelly.0 (470312) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.829  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.833  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.835  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.841  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.843  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.846  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.850  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.851  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.855  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.859  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.861  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.862  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.864  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.866  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.869  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.870  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.872  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.875  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.876  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.877  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.879  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.881  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.884  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.886  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.887  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.888  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.889  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.892  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.893  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.894  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.897  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.899  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.901  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.831  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2024-04-19 21:30:47.831  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        2024-04-19 21:30:47.831  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                          @m-schalk
                          Ich auch nicht.
                          m.schalk
                          schrieb am zuletzt editiert von m.schalk
                          @thomas-braun das ist als letztes im log vor dem Restart, mindestens 10.000 mal
                          der Logfile ist 35Mb groß
                          2024-04-19 21:31:36.745  - error: javascript.0 (499664) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                          2024-04-19 21:31:36.745  - error: javascript.0 (499664) Error: write EPIPE
                              at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                              at writeGeneric (node:internal/stream_base_commons:151:3)
                              at Socket._writeGeneric (node:net:962:11)
                              at Socket._write (node:net:974:8)
                              at writeOrBuffer (node:internal/streams/writable:392:12)
                              at _write (node:internal/streams/writable:333:10)
                              at Socket.Writable.write (node:internal/streams/writable:337:10)
                              at console.value (node:internal/console/constructor:305:16)
                              at console.warn (node:internal/console/constructor:385:26)
                              at /opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:15:13
                          • ? Offline
                            @m-schalk
                            Dann schau mal in das Redis log, da stimmt was nicht..
                            • M m.schalk
                              Irgendwas mit redis. Und/oder mit dem Dateisystem vielleicht.
                                @m-schalk
                                m.schalk
                                @ilovegym wo liegt das?
                                • M m.schalk
                                  https://www.digitalocean.com/community/tutorials/how-to-find-redis-logs-on-ubuntu
                                    m.schalk
                                    @ilovegym hallo, scheint ein Problem bei Redis zu sein.
                                    === REDIS BUG REPORT START: Cut & paste starting from here ===
                                    535888:C 19 Apr 2024 21:30:47.166 # Redis 6.0.16 crashed by signal: 11, si_code: 1
                                    535888:C 19 Apr 2024 21:30:47.166 # Crashed running the instruction at: 0x562658427528
                                    535888:C 19 Apr 2024 21:30:47.166 # Accessing address: 0x76
                                    535888:C 19 Apr 2024 21:30:47.166 # Failed assertion: <no assertion failed> (<no file>:0)
                                    ------ STACK TRACE ------
                                    EIP:
                                    redis-rdb-bgsave 127.0.0.1:6379(lzf_compress+0x238)[0x562658427528]
                                    Backtrace:
                                    redis-rdb-bgsave 127.0.0.1:6379(logStackTrace+0x5c)[0x56265847d83c]
                                    redis-rdb-bgsave 127.0.0.1:6379(sigsegvHandler+0xd0)[0x562658480320]
                                    /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7ff189042520]
                                    redis-rdb-bgsave 127.0.0.1:6379(+0x7543c)[0x56265845543c]
                                    redis-rdb-bgsave 127.0.0.1:6379(rdbSaveRawString+0x115)[0x56265844ab05]
                                    redis-rdb-bgsave 127.0.0.1:6379(rdbSaveKeyValuePair+0x74)[0x56265844fea4]
                                    redis-rdb-bgsave 127.0.0.1:6379(rdbSaveRio+0x25d)[0x56265845028d]
                                    redis-rdb-bgsave 127.0.0.1:6379(rdbSave+0x117)[0x5626584508c7]
                                    redis-rdb-bgsave 127.0.0.1:6379(rdbSaveBackground+0xf3)[0x562658450be3]
                                    redis-rdb-bgsave 127.0.0.1:6379(serverCron+0x6ff)[0x56265841fd2f]
                                    redis-rdb-bgsave 127.0.0.1:6379(aeProcessEvents+0x477)[0x562658416ca7]
                                    redis-rdb-bgsave 127.0.0.1:6379(aeMain+0x1d)[0x562658416edd]
                                    redis-rdb-bgsave 127.0.0.1:6379(main+0x466)[0x5626584125f6]
                                    /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7ff189029d90]
                                    /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7ff189029e40]
                                    redis-rdb-bgsave 127.0.0.1:6379(_start+0x25)[0x5626584129d5]
                                    ------ INFO OUTPUT ------
                                    # Server
                                    redis_version:6.0.16
                                    redis_git_sha1:00000000
                                    redis_git_dirty:0
                                    redis_build_id:a3fdef44459b3ad6
                                    redis_mode:standalone
                                    os:Linux 6.2.16-18-pve x86_64
                                    arch_bits:64
                                    multiplexing_api:epoll
                                    atomicvar_api:atomic-builtin
                                    gcc_version:11.2.0
                                    process_id:535888
                                    run_id:dd81208470d24e21da30c3db467aa897a35ea818
                                    tcp_port:6379
                                    uptime_in_seconds:261470
                                    uptime_in_days:3
                                    hz:10
                                    configured_hz:10
                                    lru_clock:2279014
                                    executable:/usr/bin/redis-server
                                    config_file:/etc/redis/redis.conf
                                    io_threads_active:0
                                    # Clients
                                    connected_clients:256
                                    client_recent_max_input_buffer:8
                                    client_recent_max_output_buffer:0
                                    blocked_clients:0
                                    tracking_clients:0
                                    clients_in_timeout_table:0
                                    # Memory
                                    used_memory:775250136
                                    used_memory_human:739.34M
                                    used_memory_rss:245919744
                                    used_memory_rss_human:234.53M
                                    used_memory_peak:881964608
                                    used_memory_peak_human:841.11M
                                    used_memory_peak_perc:87.90%
                                    used_memory_overhead:13684328
                                    used_memory_startup:809688
                                    used_memory_dataset:761565808
                                    used_memory_dataset_perc:98.34%
                                    allocator_allocated:775604592
                                    allocator_active:792817664
                                    allocator_resident:800509952
                                    total_system_memory:16581869568
                                    total_system_memory_human:15.44G
                                    used_memory_lua:109568
                                    used_memory_lua_human:107.00K
                                    used_memory_scripts:6136
                                    used_memory_scripts_human:5.99K
                                    number_of_cached_scripts:9
                                    maxmemory:0
                                    maxmemory_human:0B
                                    maxmemory_policy:noeviction
                                    allocator_frag_ratio:1.02
                                    allocator_frag_bytes:17213072
                                    allocator_rss_ratio:1.01
                                    allocator_rss_bytes:7692288
                                    rss_overhead_ratio:0.31
                                    rss_overhead_bytes:-554590208
                                    mem_fragmentation_ratio:0.32
                                    mem_fragmentation_bytes:-529328744
                                    mem_not_counted_for_evict:0
                                    mem_replication_backlog:0
                                    mem_clients_slaves:0
                                    mem_clients_normal:5250392
                                    mem_aof_buffer:0
                                    mem_allocator:jemalloc-5.2.1
                                    active_defrag_running:0
                                    lazyfree_pending_objects:0
                                    # Persistence
                                    loading:0
                                    rdb_changes_since_last_save:24388
                                    rdb_bgsave_in_progress:0
                                    rdb_last_save_time:1713554985
                                    rdb_last_bgsave_status:ok
                                    rdb_last_bgsave_time_sec:17
                                    rdb_current_bgsave_time_sec:-1
                                    rdb_last_cow_size:18829312
                                    aof_enabled:0
                                    aof_rewrite_in_progress:0
                                    aof_rewrite_scheduled:0
                                    aof_last_rewrite_time_sec:-1
                                    aof_current_rewrite_time_sec:-1
                                    aof_last_bgrewrite_status:ok
                                    aof_last_write_status:ok
                                    aof_last_cow_size:0
                                    module_fork_in_progress:0
                                    module_fork_last_cow_size:0
                                    # Stats
                                    total_connections_received:14976
                                    total_commands_processed:449758358
                                    instantaneous_ops_per_sec:2860
                                    total_net_input_bytes:58896855285
                                    total_net_output_bytes:214360874435
                                    instantaneous_input_kbps:435.56
                                    instantaneous_output_kbps:1362.81
                                    rejected_connections:0
                                    sync_full:0
                                    sync_partial_ok:0
                                    sync_partial_err:0
                                    expired_keys:24495
                                    expired_stale_perc:0.12
                                    expired_time_cap_reached_count:8
                                    expire_cycle_cpu_milliseconds:15200
                                    evicted_keys:0
                                    keyspace_hits:285673939
                                    keyspace_misses:127276
                                    pubsub_channels:2
                                    pubsub_patterns:1262
                                    latest_fork_usec:13497
                                    migrate_cached_sockets:0
                                    slave_expires_tracked_keys:0
                                    active_defrag_hits:0
                                    active_defrag_misses:0
                                    active_defrag_key_hits:0
                                    active_defrag_key_misses:0
                                    tracking_total_keys:0
                                    tracking_total_items:0
                                    tracking_total_prefixes:0
                                    unexpected_error_replies:0
                                    total_reads_processed:274021057
                                    total_writes_processed:390387317
                                    io_threaded_reads_processed:0
                                    io_threaded_writes_processed:0
                                    # Replication
                                    role:master
                                    connected_slaves:0
                                    master_replid:6337f54d611b8afb4d7975cbb532388dde9afb63
                                    master_replid2:0000000000000000000000000000000000000000
                                    master_repl_offset:0
                                    second_repl_offset:-1
                                    repl_backlog_active:0
                                    repl_backlog_size:1048576
                                    repl_backlog_first_byte_offset:0
                                    repl_backlog_histlen:0
                                    # CPU
                                    used_cpu_sys:0.135472
                                    used_cpu_user:0.617154
                                    used_cpu_sys_children:0.000000
                                    used_cpu_user_children:0.000000
                                    # Modules
                                    # Commandstats
                                    cmdstat_config:calls=5033,usec=42748,usec_per_call=8.49
                                    cmdstat_srem:calls=314,usec=2890,usec_per_call=9.20
                                    cmdstat_info:calls=14974,usec=1485972,usec_per_call=99.24
                                    cmdstat_get:calls=272987760,usec=16400864140,usec_per_call=60.08
                                    cmdstat_subscribe:calls=5040,usec=31871,usec_per_call=6.32
                                    cmdstat_del:calls=869,usec=25238,usec_per_call=29.04
                                    cmdstat_script:calls=2521,usec=14960,usec_per_call=5.93
                                    cmdstat_publish:calls=79624645,usec=12933656279,usec_per_call=162.43
                                    cmdstat_punsubscribe:calls=15348,usec=588714,usec_per_call=38.36
                                    cmdstat_exists:calls=6388310,usec=9550202,usec_per_call=1.49
                                    cmdstat_sadd:calls=50301,usec=150896,usec_per_call=3.00
                                    cmdstat_client:calls=14884,usec=44135,usec_per_call=2.97
                                    cmdstat_sscan:calls=4510522,usec=3550650881,usec_per_call=787.19
                                    cmdstat_psubscribe:calls=43946,usec=563994,usec_per_call=12.83
                                    cmdstat_eval:calls=7,usec=146,usec_per_call=20.86
                                    cmdstat_mget:calls=15049,usec=3330837,usec_per_call=221.33
                                    cmdstat_exec:calls=1025,usec=23588,usec_per_call=23.01
                                    cmdstat_keys:calls=2495,usec=65446235,usec_per_call=26230.96
                                    cmdstat_setex:calls=8017443,usec=33961328,usec_per_call=4.24
                                    cmdstat_multi:calls=1025,usec=831,usec_per_call=0.81
                                    cmdstat_scan:calls=2283566,usec=780487989,usec_per_call=341.78
                                    cmdstat_set:calls=71254075,usec=272358535,usec_per_call=3.82
                                    cmdstat_evalsha:calls=4519206,usec=5476911394,usec_per_call=1211.92
                                    # Cluster
                                    cluster_enabled:0
                                    # Keyspace
                                    db0:keys=137336,expires=464,avg_ttl=16479
                                    ------ CLIENT LIST OUTPUT ------
                                    id=13183 addr=127.0.0.1:39196 fd=141 name=device-reminder.0(470397) age=33997 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13154 addr=127.0.0.1:45368 fd=130 name=zigbee.0(470296) age=34019 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13222 addr=127.0.0.1:59174 fd=192 name=mercedesme.0(470506) age=33970 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13223 addr=127.0.0.1:59186 fd=193 name=mercedesme.0(470506) age=33970 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13224 addr=127.0.0.1:59190 fd=194 name=mercedesme.0(470506) age=33970 idle=25805 flags=P db=0 sub=0 psub=9 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13155 addr=127.0.0.1:45372 fd=131 name=zigbee.0(470296) age=34019 idle=65 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13052 addr=127.0.0.1:36000 fd=40 name=influxdb.0(469983) age=34090 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13053 addr=127.0.0.1:36016 fd=41 name=influxdb.0(469983) age=34090 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13096 addr=127.0.0.1:35420 fd=84 name=daikin.0(470131) age=34059 idle=59 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=14152 addr=127.0.0.1:52682 fd=24 name=telegram.0(503220) age=16613 idle=647 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13084 addr=127.0.0.1:42226 fd=72 name=alexa2.0(470089) age=34067 idle=16 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13282 addr=127.0.0.1:59872 fd=246 name=followthesun.0(470656) age=33924 idle=15 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13085 addr=127.0.0.1:42228 fd=73 name=alexa2.0(470089) age=34067 idle=34066 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13207 addr=127.0.0.1:55612 fd=179 name=smartthings.0(470485) age=33982 idle=60 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13214 addr=127.0.0.1:53582 fd=184 name=alarm.0(470466) age=33976 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13215 addr=127.0.0.1:53598 fd=185 name=alarm.0(470466) age=33976 idle=628 flags=P db=0 sub=0 psub=14 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13240 addr=127.0.0.1:60810 fd=210 name=discovery.0(470599) age=33958 idle=33942 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13241 addr=127.0.0.1:60818 fd=211 name=discovery.0(470599) age=33958 idle=33947 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13242 addr=127.0.0.1:60824 fd=212 name=discovery.0(470599) age=33958 idle=33958 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=14173 addr=127.0.0.1:43172 fd=123 name=ecovacs-deebot.0(503417) age=16528 idle=12 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=14174 addr=127.0.0.1:43184 fd=124 name=ecovacs-deebot.0(503417) age=16528 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14175 addr=127.0.0.1:43196 fd=125 name=ecovacs-deebot.0(503417) age=16528 idle=24 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13086 addr=127.0.0.1:42242 fd=74 name=alexa2.0(470089) age=34067 idle=1214 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13031 addr=127.0.0.1:52088 fd=19 name=history.0(469942) age=34103 idle=34102 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13087 addr=127.0.0.1:42258 fd=75 name=alexa2.0(470089) age=34066 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13174 addr=127.0.0.1:58878 fd=150 name=pvforecast.0(470374) age=34007 idle=44 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13205 addr=127.0.0.1:55582 fd=177 name=sourceanalytix.0(470442) age=33983 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13206 addr=127.0.0.1:55598 fd=178 name=sourceanalytix.0(470442) age=33983 idle=2 flags=P db=0 sub=0 psub=33 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13246 addr=127.0.0.1:35880 fd=186 name=web.0(470634) age=33950 idle=557 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13247 addr=127.0.0.1:35892 fd=187 name=web.0(470634) age=33950 idle=26233 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13248 addr=127.0.0.1:35900 fd=188 name=web.0(470634) age=33950 idle=34 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13088 addr=127.0.0.1:42272 fd=76 name=alexa2.0(470089) age=34066 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13089 addr=127.0.0.1:42278 fd=77 name=alexa2.0(470089) age=34066 idle=16 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13153 addr=127.0.0.1:45358 fd=129 name=zigbee.0(470296) age=34019 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13032 addr=127.0.0.1:52104 fd=20 name=history.0(469942) age=34103 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13102 addr=127.0.0.1:35470 fd=90 name=shelly.1(470150) age=34055 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13273 addr=127.0.0.1:35616 fd=237 name=ring.0(470618) age=33934 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13301 addr=127.0.0.1:51126 fd=267 name=ford.0(470702) age=33916 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13302 addr=127.0.0.1:51136 fd=268 name=ford.0(470702) age=33916 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=285 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13274 addr=127.0.0.1:35632 fd=238 name=ring.0(470618) age=33934 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13275 addr=127.0.0.1:35634 fd=239 name=ring.0(470618) age=33934 idle=65 flags=P db=0 sub=0 psub=10 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13103 addr=127.0.0.1:35480 fd=91 name=shelly.1(470150) age=34055 idle=34054 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13104 addr=127.0.0.1:35492 fd=92 name=shelly.1(470150) age=34055 idle=34055 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13253 addr=127.0.0.1:35940 fd=217 name=ring.0(470618) age=33949 idle=33934 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13254 addr=127.0.0.1:35954 fd=218 name=ring.0(470618) age=33949 idle=33948 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13213 addr=127.0.0.1:53574 fd=183 name=alarm.0(470466) age=33976 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13135 addr=127.0.0.1:41296 fd=111 name=bosesoundtouch.0(470241) age=34035 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13136 addr=127.0.0.1:41302 fd=112 name=bosesoundtouch.0(470241) age=34035 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13137 addr=127.0.0.1:41304 fd=113 name=bosesoundtouch.0(470241) age=34035 idle=545 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13090 addr=127.0.0.1:42282 fd=78 name=net-tools.0(470107) age=34063 idle=34062 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=exists user=default
                                    id=13091 addr=127.0.0.1:42292 fd=79 name=net-tools.0(470107) age=34063 idle=34062 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13204 addr=127.0.0.1:55568 fd=176 name=sourceanalytix.0(470442) age=33983 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13092 addr=127.0.0.1:42306 fd=80 name=net-tools.0(470107) age=34063 idle=34063 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13025 addr=127.0.0.1:52036 fd=13 name=admin.0(469915) age=34107 idle=34107 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13138 addr=127.0.0.1:36250 fd=114 name=samsung.0(470260) age=34030 idle=34029 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13139 addr=127.0.0.1:36258 fd=115 name=samsung.0(470260) age=34030 idle=34030 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13140 addr=127.0.0.1:36270 fd=116 name=samsung.0(470260) age=34030 idle=34030 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13316 addr=127.0.0.1:48924 fd=253 name=info.0(470787) age=33904 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13317 addr=127.0.0.1:48930 fd=254 name=info.0(470787) age=33904 idle=33904 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13027 addr=127.0.0.1:52052 fd=15 name=admin.0(469915) age=34107 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13028 addr=127.0.0.1:52056 fd=16 name=admin.0(469915) age=34107 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13029 addr=127.0.0.1:52072 fd=17 name=admin.0(469915) age=34107 idle=2 flags=P db=0 sub=0 psub=27 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13300 addr=127.0.0.1:51116 fd=266 name=ford.0(470702) age=33917 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=4 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                    id=13030 addr=127.0.0.1:52084 fd=18 name=history.0(469942) age=34103 idle=34102 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20568 events=r cmd=evalsha user=default
                                    id=13026 addr=127.0.0.1:52046 fd=14 name=admin.0(469915) age=34107 idle=33 flags=P db=0 sub=0 psub=8 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13099 addr=127.0.0.1:35442 fd=87 name=daikin.0(470131) age=34058 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13252 addr=127.0.0.1:35938 fd=216 name=ring.0(470618) age=33949 idle=65 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13100 addr=127.0.0.1:35454 fd=88 name=daikin.0(470131) age=34058 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14059 addr=127.0.0.1:38274 fd=33 name=javascript.0(499664) age=18386 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                    id=14060 addr=127.0.0.1:38288 fd=34 name=javascript.0(499664) age=18386 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14061 addr=127.0.0.1:38292 fd=35 name=javascript.0(499664) age=18386 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13286 addr=127.0.0.1:51006 fd=250 name=virtualpowermeter.0(470758) age=33921 idle=33908 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13287 addr=127.0.0.1:51010 fd=251 name=virtualpowermeter.0(470758) age=33921 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13101 addr=127.0.0.1:35456 fd=89 name=daikin.0(470131) age=34058 idle=59 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13121 addr=127.0.0.1:34590 fd=97 name=mqtt.1(470205) age=34043 idle=34043 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13122 addr=127.0.0.1:34596 fd=98 name=mqtt.1(470205) age=34043 idle=34043 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13075 addr=127.0.0.1:58572 fd=63 name=mqtt.0(470053) age=34074 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13076 addr=127.0.0.1:58582 fd=64 name=mqtt.0(470053) age=34074 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13193 addr=127.0.0.1:55464 fd=165 name=sourceanalytix.0(470442) age=33990 idle=33983 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13194 addr=127.0.0.1:55480 fd=166 name=sourceanalytix.0(470442) age=33990 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13077 addr=127.0.0.1:58598 fd=65 name=mqtt.0(470053) age=34074 idle=2 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13057 addr=127.0.0.1:36058 fd=45 name=tuya.0(470002) age=34085 idle=4 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13058 addr=127.0.0.1:36066 fd=46 name=tuya.0(470002) age=34085 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13059 addr=127.0.0.1:36080 fd=47 name=tuya.0(470002) age=34085 idle=56 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13171 addr=127.0.0.1:58850 fd=147 name=iot.0(470354) age=34009 idle=15 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13202 addr=127.0.0.1:55548 fd=174 name=yahka.0(470426) age=33984 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13203 addr=127.0.0.1:55560 fd=175 name=yahka.0(470426) age=33984 idle=1 flags=P db=0 sub=0 psub=43 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13315 addr=127.0.0.1:48918 fd=252 name=info.0(470787) age=33904 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13172 addr=127.0.0.1:58856 fd=148 name=iot.0(470354) age=34009 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13173 addr=127.0.0.1:58866 fd=149 name=iot.0(470354) age=34009 idle=4312 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13020 addr=127.0.0.1:51992 fd=8 name=host.BU02SMART02-iobroker age=34110 idle=29 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20536 events=r cmd=evalsha user=default
                                    id=13120 addr=127.0.0.1:34578 fd=96 name=mqtt.1(470205) age=34043 idle=1546 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13021 addr=127.0.0.1:52008 fd=9 name=host.BU02SMART02-iobroker age=34109 idle=6 flags=P db=0 sub=2 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13168 addr=127.0.0.1:58826 fd=144 name=iot.0(470354) age=34011 idle=4312 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13169 addr=127.0.0.1:58834 fd=145 name=iot.0(470354) age=34011 idle=34009 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13195 addr=127.0.0.1:55482 fd=167 name=linkeddevices.0(470413) age=33988 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13196 addr=127.0.0.1:55486 fd=168 name=linkeddevices.0(470413) age=33988 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13197 addr=127.0.0.1:55498 fd=169 name=linkeddevices.0(470413) age=33988 idle=1 flags=P db=0 sub=0 psub=51 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13192 addr=127.0.0.1:55456 fd=164 name=sourceanalytix.0(470442) age=33990 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13170 addr=127.0.0.1:58846 fd=146 name=iot.0(470354) age=34011 idle=34 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13201 addr=127.0.0.1:55536 fd=173 name=yahka.0(470426) age=33985 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13022 addr=127.0.0.1:52016 fd=10 name=host.BU02SMART02-iobroker age=34109 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13129 addr=127.0.0.1:41266 fd=105 name=ems-esp.0(470223) age=34039 idle=3 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13130 addr=127.0.0.1:41270 fd=106 name=ems-esp.0(470223) age=34039 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13131 addr=127.0.0.1:41272 fd=107 name=ems-esp.0(470223) age=34039 idle=6 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13259 addr=127.0.0.1:36002 fd=223 name=followthesun.0(470656) age=33944 idle=33924 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13260 addr=127.0.0.1:36004 fd=224 name=followthesun.0(470656) age=33944 idle=33944 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13105 addr=127.0.0.1:35494 fd=93 name=shelly.1(470150) age=34054 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                    id=13117 addr=127.0.0.1:34552 fd=69 name=homeconnect.0(470186) age=34047 idle=10 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13118 addr=127.0.0.1:34556 fd=70 name=homeconnect.0(470186) age=34047 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13119 addr=127.0.0.1:34572 fd=71 name=homeconnect.0(470186) age=34047 idle=28323 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13277 addr=127.0.0.1:35660 fd=241 name=vis-inventwo.0(470717) age=33933 idle=33911 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13278 addr=127.0.0.1:35674 fd=242 name=vis-inventwo.0(470717) age=33933 idle=33933 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13106 addr=127.0.0.1:35500 fd=94 name=shelly.1(470150) age=34054 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13107 addr=127.0.0.1:35516 fd=95 name=shelly.1(470150) age=34054 idle=1 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13156 addr=127.0.0.1:45378 fd=132 name=shelly.0(470312) age=34019 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                    id=13270 addr=127.0.0.1:35588 fd=234 name=web.0(470634) age=33935 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13271 addr=127.0.0.1:35592 fd=235 name=web.0(470634) age=33935 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13272 addr=127.0.0.1:35600 fd=236 name=web.0(470634) age=33935 idle=0 flags=P db=0 sub=0 psub=400 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14170 addr=127.0.0.1:43140 fd=120 name=ecovacs-deebot.0(503417) age=16528 idle=24 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=14171 addr=127.0.0.1:43156 fd=121 name=ecovacs-deebot.0(503417) age=16528 idle=16528 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14172 addr=127.0.0.1:43170 fd=122 name=ecovacs-deebot.0(503417) age=16528 idle=16528 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13255 addr=127.0.0.1:35964 fd=219 name=discovery.0(470599) age=33947 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13256 addr=127.0.0.1:35970 fd=220 name=discovery.0(470599) age=33947 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13257 addr=127.0.0.1:35982 fd=221 name=discovery.0(470599) age=33947 idle=33947 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13157 addr=127.0.0.1:45388 fd=133 name=shelly.0(470312) age=34019 idle=34016 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13158 addr=127.0.0.1:45392 fd=134 name=shelly.0(470312) age=34019 idle=34019 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13023 addr=127.0.0.1:52018 fd=11 name=host.BU02SMART02-iobroker age=34109 idle=2 flags=P db=0 sub=2 psub=8 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13073 addr=127.0.0.1:58550 fd=61 name=mqtt.0(470053) age=34074 idle=34074 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13226 addr=127.0.0.1:59206 fd=196 name=slideshow.0(470538) age=33969 idle=33960 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13258 addr=127.0.0.1:35988 fd=222 name=followthesun.0(470656) age=33944 idle=76 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13227 addr=127.0.0.1:59216 fd=197 name=slideshow.0(470538) age=33969 idle=33969 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13150 addr=127.0.0.1:45318 fd=126 name=zigbee.0(470296) age=34020 idle=65 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13276 addr=127.0.0.1:35650 fd=240 name=vis-inventwo.0(470717) age=33933 idle=33910 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13151 addr=127.0.0.1:45332 fd=127 name=zigbee.0(470296) age=34020 idle=34019 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13285 addr=127.0.0.1:59886 fd=249 name=virtualpowermeter.0(470758) age=33922 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13152 addr=127.0.0.1:45348 fd=128 name=zigbee.0(470296) age=34020 idle=34020 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13074 addr=127.0.0.1:58566 fd=62 name=mqtt.0(470053) age=34074 idle=34074 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13069 addr=127.0.0.1:58516 fd=57 name=device-watcher.1(470034) age=34077 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13070 addr=127.0.0.1:58522 fd=58 name=device-watcher.1(470034) age=34077 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13177 addr=127.0.0.1:58912 fd=155 name=pvforecast.0(470374) age=34003 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13178 addr=127.0.0.1:58914 fd=156 name=pvforecast.0(470374) age=34003 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13179 addr=127.0.0.1:58916 fd=157 name=pvforecast.0(470374) age=34003 idle=44 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13199 addr=127.0.0.1:55514 fd=171 name=alarm.0(470466) age=33985 idle=33976 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13200 addr=127.0.0.1:55530 fd=172 name=alarm.0(470466) age=33985 idle=33985 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13071 addr=127.0.0.1:58528 fd=59 name=device-watcher.1(470034) age=34077 idle=2 flags=P db=0 sub=0 psub=178 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13024 addr=127.0.0.1:52020 fd=12 name=admin.0(469915) age=34107 idle=685 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13072 addr=127.0.0.1:58536 fd=60 name=mqtt.0(470053) age=34074 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13297 addr=127.0.0.1:51100 fd=263 name=info.0(470787) age=33917 idle=1497 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13298 addr=127.0.0.1:51102 fd=264 name=info.0(470787) age=33917 idle=33904 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13299 addr=127.0.0.1:51112 fd=265 name=info.0(470787) age=33917 idle=33917 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13048 addr=127.0.0.1:35962 fd=36 name=influxdb.0(469983) age=34090 idle=34088 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20568 events=r cmd=evalsha user=default
                                    id=13049 addr=127.0.0.1:35972 fd=37 name=influxdb.0(469983) age=34090 idle=34089 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13050 addr=127.0.0.1:35974 fd=38 name=influxdb.0(469983) age=34090 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13220 addr=127.0.0.1:53636 fd=190 name=smartthings.0(470485) age=33973 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13221 addr=127.0.0.1:53642 fd=191 name=smartthings.0(470485) age=33973 idle=60 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13229 addr=127.0.0.1:59236 fd=199 name=energiefluss.0(470561) age=33966 idle=33956 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13230 addr=127.0.0.1:59240 fd=200 name=energiefluss.0(470561) age=33966 idle=33966 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13186 addr=127.0.0.1:39218 fd=158 name=linkeddevices.0(470413) age=33992 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13280 addr=127.0.0.1:59850 fd=244 name=hass-mqtt.0(470737) age=33927 idle=33910 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13281 addr=127.0.0.1:59866 fd=245 name=hass-mqtt.0(470737) age=33927 idle=33927 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13187 addr=127.0.0.1:39228 fd=159 name=linkeddevices.0(470413) age=33992 idle=33988 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13188 addr=127.0.0.1:39232 fd=160 name=linkeddevices.0(470413) age=33992 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14155 addr=127.0.0.1:52694 fd=27 name=telegram.0(503220) age=16612 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=14156 addr=127.0.0.1:52698 fd=28 name=telegram.0(503220) age=16612 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14157 addr=127.0.0.1:52708 fd=29 name=telegram.0(503220) age=16612 idle=5 flags=P db=0 sub=0 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13033 addr=127.0.0.1:52118 fd=21 name=history.0(469942) age=34103 idle=4 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13034 addr=127.0.0.1:52128 fd=22 name=history.0(469942) age=34103 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14056 addr=127.0.0.1:38240 fd=30 name=javascript.0(499664) age=18386 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                    id=14057 addr=127.0.0.1:38252 fd=31 name=javascript.0(499664) age=18386 idle=18384 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14058 addr=127.0.0.1:38262 fd=32 name=javascript.0(499664) age=18386 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13061 addr=127.0.0.1:36104 fd=49 name=ping.0(470017) age=34083 idle=34082 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13141 addr=127.0.0.1:36276 fd=117 name=samsung.0(470260) age=34030 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13142 addr=127.0.0.1:36292 fd=118 name=samsung.0(470260) age=34030 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13211 addr=127.0.0.1:53552 fd=154 name=mercedesme.0(470506) age=33978 idle=33970 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13212 addr=127.0.0.1:53564 fd=182 name=mercedesme.0(470506) age=33978 idle=33978 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13143 addr=127.0.0.1:36298 fd=119 name=samsung.0(470260) age=34030 idle=34029 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13198 addr=127.0.0.1:55504 fd=170 name=alarm.0(470466) age=33985 idle=883 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13062 addr=127.0.0.1:36118 fd=50 name=ping.0(470017) age=34083 idle=34083 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13054 addr=127.0.0.1:36028 fd=42 name=tuya.0(470002) age=34086 idle=56 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13225 addr=127.0.0.1:59204 fd=195 name=slideshow.0(470538) age=33970 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13055 addr=127.0.0.1:36044 fd=43 name=tuya.0(470002) age=34086 idle=34085 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13056 addr=127.0.0.1:36056 fd=44 name=tuya.0(470002) age=34086 idle=34086 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13228 addr=127.0.0.1:59222 fd=198 name=energiefluss.0(470561) age=33966 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                    id=13235 addr=127.0.0.1:59300 fd=205 name=energiefluss.1(470579) age=33962 idle=33949 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13238 addr=127.0.0.1:60792 fd=208 name=slideshow.0(470538) age=33960 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13239 addr=127.0.0.1:60800 fd=209 name=slideshow.0(470538) age=33960 idle=33957 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13267 addr=127.0.0.1:35562 fd=231 name=ford.0(470702) age=33937 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                    id=13268 addr=127.0.0.1:35578 fd=232 name=ford.0(470702) age=33937 idle=33917 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13269 addr=127.0.0.1:35580 fd=233 name=ford.0(470702) age=33937 idle=33937 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13236 addr=127.0.0.1:59312 fd=206 name=energiefluss.1(470579) age=33962 idle=33962 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13219 addr=127.0.0.1:53628 fd=189 name=smartthings.0(470485) age=33973 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13133 addr=127.0.0.1:41282 fd=109 name=bosesoundtouch.0(470241) age=34035 idle=34035 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13134 addr=127.0.0.1:41290 fd=110 name=bosesoundtouch.0(470241) age=34035 idle=34035 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13060 addr=127.0.0.1:36090 fd=48 name=ping.0(470017) age=34083 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13066 addr=127.0.0.1:58484 fd=54 name=device-watcher.1(470034) age=34079 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13067 addr=127.0.0.1:58496 fd=55 name=device-watcher.1(470034) age=34079 idle=34077 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13189 addr=127.0.0.1:55424 fd=161 name=yahka.0(470426) age=33991 idle=5366 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13190 addr=127.0.0.1:55432 fd=162 name=yahka.0(470426) age=33991 idle=33985 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13191 addr=127.0.0.1:55444 fd=163 name=yahka.0(470426) age=33991 idle=33991 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13127 addr=127.0.0.1:41248 fd=103 name=ems-esp.0(470223) age=34039 idle=34039 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13303 addr=127.0.0.1:48822 fd=269 name=vis-inventwo.0(470717) age=33911 idle=10 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13304 addr=127.0.0.1:48826 fd=270 name=vis-inventwo.0(470717) age=33911 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13305 addr=127.0.0.1:48834 fd=271 name=vis-inventwo.0(470717) age=33911 idle=33910 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13306 addr=127.0.0.1:48840 fd=272 name=hass-mqtt.0(470737) age=33910 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13307 addr=127.0.0.1:48848 fd=273 name=hass-mqtt.0(470737) age=33910 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13308 addr=127.0.0.1:48852 fd=274 name=hass-mqtt.0(470737) age=33910 idle=33908 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13210 addr=127.0.0.1:53548 fd=153 name=mercedesme.0(470506) age=33978 idle=1565 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13160 addr=127.0.0.1:45396 fd=136 name=shelly.0(470312) age=34016 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13244 addr=127.0.0.1:60828 fd=214 name=energiefluss.0(470561) age=33956 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13245 addr=127.0.0.1:60844 fd=215 name=energiefluss.0(470561) age=33956 idle=0 flags=P db=0 sub=0 psub=13 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13161 addr=127.0.0.1:45408 fd=137 name=shelly.0(470312) age=34016 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13128 addr=127.0.0.1:41264 fd=104 name=ems-esp.0(470223) age=34039 idle=34039 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13068 addr=127.0.0.1:58508 fd=56 name=device-watcher.1(470034) age=34079 idle=34 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13114 addr=127.0.0.1:34524 fd=66 name=homeconnect.0(470186) age=34047 idle=28323 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13115 addr=127.0.0.1:34536 fd=67 name=homeconnect.0(470186) age=34047 idle=34047 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13116 addr=127.0.0.1:34546 fd=68 name=homeconnect.0(470186) age=34047 idle=34047 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13279 addr=127.0.0.1:59838 fd=243 name=hass-mqtt.0(470737) age=33928 idle=33898 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20496 events=r cmd=mget user=default
                                    id=13310 addr=127.0.0.1:48866 fd=276 name=virtualpowermeter.0(470758) age=33908 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13311 addr=127.0.0.1:48872 fd=277 name=virtualpowermeter.0(470758) age=33908 idle=5 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13250 addr=127.0.0.1:35926 fd=202 name=energiefluss.1(470579) age=33949 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13251 addr=127.0.0.1:35932 fd=203 name=energiefluss.1(470579) age=33949 idle=0 flags=P db=0 sub=0 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13237 addr=127.0.0.1:60782 fd=207 name=slideshow.0(470538) age=33960 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13132 addr=127.0.0.1:41278 fd=108 name=bosesoundtouch.0(470241) age=34035 idle=545 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13181 addr=127.0.0.1:39176 fd=139 name=device-reminder.0(470397) age=34001 idle=33997 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13182 addr=127.0.0.1:39180 fd=140 name=device-reminder.0(470397) age=34001 idle=34001 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13035 addr=127.0.0.1:52136 fd=23 name=history.0(469942) age=34103 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13063 addr=127.0.0.1:36126 fd=51 name=ping.0(470017) age=34082 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13126 addr=127.0.0.1:41246 fd=102 name=ems-esp.0(470223) age=34039 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13159 addr=127.0.0.1:45394 fd=135 name=shelly.0(470312) age=34016 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                    id=13064 addr=127.0.0.1:36132 fd=52 name=ping.0(470017) age=34082 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13093 addr=127.0.0.1:42316 fd=81 name=net-tools.0(470107) age=34062 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13097 addr=127.0.0.1:35428 fd=85 name=daikin.0(470131) age=34059 idle=34058 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13243 addr=127.0.0.1:60826 fd=213 name=energiefluss.0(470561) age=33956 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                    id=13184 addr=127.0.0.1:39202 fd=142 name=device-reminder.0(470397) age=33997 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13185 addr=127.0.0.1:39214 fd=143 name=device-reminder.0(470397) age=33997 idle=33997 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13123 addr=127.0.0.1:34602 fd=99 name=mqtt.1(470205) age=34043 idle=6 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13124 addr=127.0.0.1:34614 fd=100 name=mqtt.1(470205) age=34043 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13125 addr=127.0.0.1:34620 fd=101 name=mqtt.1(470205) age=34043 idle=1546 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14153 addr=127.0.0.1:52684 fd=25 name=telegram.0(503220) age=16613 idle=16612 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=14154 addr=127.0.0.1:52688 fd=26 name=telegram.0(503220) age=16613 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13249 addr=127.0.0.1:35916 fd=201 name=energiefluss.1(470579) age=33949 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                    id=13098 addr=127.0.0.1:35432 fd=86 name=daikin.0(470131) age=34059 idle=34059 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13094 addr=127.0.0.1:42320 fd=82 name=net-tools.0(470107) age=34062 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13309 addr=127.0.0.1:48856 fd=275 name=virtualpowermeter.0(470758) age=33908 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    id=13234 addr=127.0.0.1:59292 fd=204 name=energiefluss.1(470579) age=33962 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                    id=13283 addr=127.0.0.1:59880 fd=247 name=followthesun.0(470656) age=33924 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13284 addr=127.0.0.1:59884 fd=248 name=followthesun.0(470656) age=33924 idle=33917 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13208 addr=127.0.0.1:55620 fd=180 name=smartthings.0(470485) age=33982 idle=33973 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13209 addr=127.0.0.1:55622 fd=181 name=smartthings.0(470485) age=33982 idle=33982 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13095 addr=127.0.0.1:42330 fd=83 name=net-tools.0(470107) age=34062 idle=34062 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13180 addr=127.0.0.1:58924 fd=138 name=device-reminder.0(470397) age=34002 idle=33993 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                    id=13175 addr=127.0.0.1:58894 fd=151 name=pvforecast.0(470374) age=34007 idle=34003 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                    id=13176 addr=127.0.0.1:58908 fd=152 name=pvforecast.0(470374) age=34007 idle=34007 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13065 addr=127.0.0.1:36146 fd=53 name=ping.0(470017) age=34082 idle=34082 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                    id=13051 addr=127.0.0.1:35986 fd=39 name=influxdb.0(469983) age=34090 idle=9 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                    ------ REGISTERS ------
                                    535888:C 19 Apr 2024 21:30:47.271 #
                                    RAX:0000000000000076 RBX:00007ffc3041ee00
                                    RCX:00007ff1781ef1e1 RDX:00007ff15d50b514
                                    RDI:0000000000000063 RSI:00007ff1781ef1e0
                                    RBP:00007ff1781ef1c0 RSP:00007ffc3041ede0
                                    R8 :00007ff15d509b43 R9 :00007ff15d509b63
                                    R10:00007ff1781ef212 R11:00007ff15d509b97
                                    R12:0000000065766963 R13:0000000000000020
                                    R14:0000000000000000 R15:00007ff15d509b99
                                    RIP:0000562658427528 EFL:0000000000010246
                                    CSGSFS:002b000000000033
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edef) -> 00002b930000085b
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edee) -> 00000076000009df
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041eded) -> 0000236e00006365
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edec) -> 00000ea500001126
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edeb) -> 0000531800000a34
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edea) -> 000010ed00000e2e
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede9) -> 00007f3f00003d25
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede8) -> 00004e90000012c4
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede7) -> 0000029a00000965
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede6) -> 000000a800000242
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede5) -> 0000002e00001599
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede4) -> 0000068800001aed
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede3) -> 00007ff172a30f8b
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede2) -> 00007ff1714583a0
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede1) -> 0000000000000030
                                    535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede0) -> 0000000000000000
                                    ------ MODULES INFO OUTPUT ------
                                      @m-schalk sagte in Sporadische Neustarts des iobroker:
                                      @ilovegym wo liegt das?
                                      https://www.digitalocean.com/community/tutorials/how-to-find-redis-logs-on-ubuntu
                                      m.schalk
                                      @ilovegym und @Thomas-Braun so, ich denke es lag an redis und der Einstellung in der Redis config.
                                      ALT:
                                      save 900 1
                                      save 300 10
                                      save 60 10000
                                      NEU:
                                      save 900 1
                                      #save 300 10
                                      #save 60 10000
                                      Diskbelastung ist merklich reduziert und auch keine Reboots mehr zu sehen.
                                      • M m.schalk
                                        ALT:
                                        save 900 1
                                        save 300 10
                                        save 60 10000
                                        NEU:
                                        save 900 1
                                        #save 300 10
                                        #save 60 10000
                                        @m-schalk
                                        Damit macht Redis weniger snapshots und verbraucht weniger Ressourcen.
