  4. [gelöst] Sporadische Neustarts des iobroker
26 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    m.schalk
    schrieb am zuletzt editiert von m.schalk
    Ich habe folgendes Problem, ich habe tägliche Reboots des Adminadapters, wie kann ich herausfinden was das verursacht.
    iob diag ausgabe.txt
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: BU02SMART02-iobroker
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.16-18-pve
        Architecture: x86-64
    model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     19:18:24 up 6 days, 12 min,  3 users,  load average: 2.46, 3.33, 3.33
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Tue 2024-04-16 19:18:24 CEST
               Universal time: Tue 2024-04-16 17:18:24 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    mario
    /home/mario
    mario sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.1G        4.0G         40M        0.0K        1.1G        1.1G
    Swap:           5.1G        1.5G        3.6G
    Total:           10G        5.5G        3.6G
             5120 M total memory
             4007 M used memory
             1507 M active memory
             3250 M inactive memory
               40 M free memory
                0 M buffer memory
             1071 M swap cache
             5120 M total swap
             1535 M used swap
             3584 M free swap
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    /dev/loop0     ext4    26G   21G  4.5G  82% /
    none           tmpfs  492K  4.0K  488K   1% /dev
    tmpfs          tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs          tmpfs  3.1G  152K  3.1G   1% /run
    tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE     FSTYPE OPTIONS
    /      /dev/loop0 ext4   rw,relatime
    /var:
    4.2G    /var/
    2.9G    /var/log
    2.8G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
    981M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    713M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    7.9G    /opt/iobroker/iobroker-data/
    6.5G    /opt/iobroker/iobroker-data/history
    627M    /opt/iobroker/iobroker-data/files
    487M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
    49M     /opt/iobroker/iobroker-data/objects.jsonl
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.ma        p
    28M     /opt/iobroker/iobroker-data/states.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.ma        p
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade        6914f1d69213e-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.18.0
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3.5 500
            500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Package        s
            500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packag        es
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.17.3
    javascript:     8.0.3
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : BU02SMART02-i        obroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alarm.0                  : alarm                 : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.daikin.0                 : daikin                : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.discovery.0              : discovery             : BU02SMART02-i        obroker                     -  enabled
      system.adapter.dwd.0                    : dwd                   : BU02SMART02-i        obroker                     -  enabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-i        obroker                     - disabled
      system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-i        obroker                     - disabled
    + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-i        obroker                     -  enabled
      system.adapter.feiertage.0              : feiertage             : BU02SMART02-i        obroker                     -  enabled
      system.adapter.flot.0                   : flot                  : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.followthesun.0           : followthesun          : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.ford.0                   : ford                  : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.history.0                : history               : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-i        obroker                     -  enabled
      system.adapter.ical.0                   : ical                  : BU02SMART02-i        obroker                     -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02        SMART02-iobroker                     -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-i        obroker                     -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-i        obroker                     -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-i        obroker                     -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-i        obroker                     -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02        SMART02-iobroker                     -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.influxdb.0               : influxdb              : BU02SMART02-i        obroker                     -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.iot.0                    : iot                   : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.javascript.0             : javascript            : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-i        obroker                     -  enabled
      system.adapter.material.0               : material              : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-i        obroker                     -  enabled
      system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-i        obroker                     - disabled, port: 1892
    + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-i        obroker                     -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-i        obroker                     -  enabled, port: 1891, bind: 192.168.2.166
    + system.adapter.net-tools.0              : net-tools             : BU02SMART02-i        obroker                     -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-i        obroker                     -  enabled
      system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-i        obroker                     -  enabled
      system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-i        obroker                     - disabled
    + system.adapter.ping.0                   : ping                  : BU02SMART02-i        obroker                     -  enabled
      system.adapter.proxmox.0                : proxmox               : BU02SMART02-i        obroker                     - disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.ring.0                   : ring                  : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.samsung.0                : samsung               : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.shelly.0                 : shelly                : BU02SMART02-i        obroker                     -  enabled, port: 1890, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : BU02SMART02-i        obroker                     -  enabled, port: 1890, bind: 192.168.2.166
      system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-i        obroker                     - disabled
    + system.adapter.slideshow.0              : slideshow             : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.smartthings.0            : smartthings           : BU02SMART02-i        obroker                     -  enabled
      system.adapter.snmp.0                   : snmp                  : BU02SMART02-i        obroker                     - disabled
      system.adapter.socketio.0               : socketio              : BU02SMART02-i        obroker                     - disabled, port: 8084, bind: 192.168.2.166, run as:        admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.telegram.0               : telegram              : BU02SMART02-i        obroker                     -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : BU02SMART02-i        obroker                     -  enabled
      system.adapter.tuya.1                   : tuya                  : BU02SMART02-i        obroker                     - disabled
      system.adapter.unifi.0                  : unifi                 : BU02SMART02-i        obroker                     - disabled
    + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-i        obroker                     - disabled
      system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-history.0            : vis-history           : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-material.0           : vis-material          : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-i        obroker                     -  enabled
      system.adapter.vis.0                    : vis                   : BU02SMART02-i        obroker                     -  enabled
    + system.adapter.web.0                    : web                   : BU02SMART02-i        obroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.ws.0                     : ws                    : BU02SMART02-i        obroker                     - disabled, port: 8087, bind: 192.168.2.166, run as:        admin
    + system.adapter.yahka.0                  : yahka                 : BU02SMART02-i        obroker                     -  enabled
      system.adapter.yahka.1                  : yahka                 : BU02SMART02-i        obroker                     - disabled
    + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-i        obroker                     -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.17.3   , installed 6.17.3
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "apcups"       : 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 2.11.0   , installed 2.9.9  [Updatable]
    Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.0  , installed 2.12.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "ems-esp"      : 3.1.1    , installed 3.1.1
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "ford"         : 0.2.0    , installed 0.2.0
    Adapter    "hass-mqtt"    : 0.0.7    , installed 0.0.7
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 3.2.2    , installed 3.2.2
    Adapter    "javascript"   : 8.0.3    , installed 8.0.3
    Controller "js-controller": 5.0.19   , installed 5.0.17 [Updatable]
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
    Adapter    "mercedesme"   : 0.2.2    , installed 0.2.2
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "ring"         : 5.0.10   , installed 5.0.10
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "shelly"       : 6.9.0    , installed 6.9.0
    Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
    Adapter    "slideshow"    : 0.1.4    , installed 0.1.4
    Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "telegram"     : 3.2.1    , installed 3.2.1
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
    Adapter    "vis"          : 1.5.5    , installed 1.5.5
    Adapter    "vis-2"        : 2.9.49   , installed 2.9.49
    Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
    Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
    Adapter    "vis-2-widgets-material": 1.3.27, installed 1.3.27
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        49416
    States:         42924
    W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /        etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /et        c/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Translations (main/i18n/Translation-en) is configured multiple times in        /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:        2
    W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/        sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/so        urces.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://deb.nodesource.com/node_18.x jammy InRelease
    Reading package lists...
    Pending Updates: 98
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       U        ser       Inode      PID/Program name
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1        000       132599104  1264635/io.mqtt.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0        64314729   281/master
    tcp        0      0 0.0.0.0:42723           0.0.0.0:*               LISTEN      1        000       132605813  1264901/io.yahka.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      1        06        64316436   99/systemd-resolved
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0        64312195   1/init
    tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1        000       132598062  1264542/io.shelly.1
    tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1        000       132597639  1264558/io.mqtt.1
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1        001       133820253  1293171/sshd: mario
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      1        13        64314560   113/redis-server 12
    tcp6       0      0 :::22                   :::*                    LISTEN      0        64315524   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0        64312197   1/init
    tcp6       0      0 :::3000                 :::*                    LISTEN      1        12        64315297   118/grafana
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0        64314730   281/master
    tcp6       0      0 ::1:6379                :::*                    LISTEN      1        13        64314561   113/redis-server 12
    tcp6       0      0 :::8082                 :::*                    LISTEN      1        000       132615242  1265507/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1        000       132594694  1264383/io.admin.0
    tcp6       0      0 ::1:6010                :::*                    LISTEN      1        001       133820252  1293171/sshd: mario
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           1        06        64316435   99/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0        64312196   1/init
    udp        0      0 0.0.0.0:34136           0.0.0.0:*                           1        000       132602193  1264717/io.shelly.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1        000       132605810  1264901/io.yahka.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1        000       132602180  1264717/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1        000       132596964  1264462/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1        000       132596965  1264462/io.tuya.0
    udp6       0      0 :::111                  :::*                                0        64312198   1/init
    2024-04-16 18:43:26.914  - debug: ring.0 (1264817) Device 95880122 ("Haustür"): U        pdate Snapshot Object
    2024-04-16 18:43:26.914  - debug: ring.0 (1264817) Device 95880122 ("Haustür"): U        pdate HD Snapshot Object
    2024-04-16 18:43:27.252  - debug: ring.0 (1264817) Device 95880122 ("Haustür"): U        pdate Health Callback
    2024-04-16 18:45:05.389  - info: ring.0 (1264817) Got terminate signal TERMINATE_        YOURSELF
    2024-04-16 18:45:05.391  - info: ring.0 (1264817) terminating
    2024-04-16 18:45:05.392  - info: ring.0 (1264817) Terminated (ADAPTER_REQUESTED_T        ERMINATION): Without reason
    2024-04-16 18:45:05.896  - info: ring.0 (1264817) terminating
    2024-04-16 18:47:01.349  - warn: zigbee.0 (1264627) DeviceAvailability:Failed to        ping 0x8418260000cab6da Flex RGBW
    2024-04-16 18:52:28.297  - warn: javascript.0 (1264421) You are assigning a boole        an to the state "javascript.0.Taster_und_Schalter.Beschattung_West" which expects        a object. Please fix your code to use a object or change the state type to boole        an. This warning might become an error in future versions.
    2024-04-16 18:52:29.433  - warn: javascript.0 (1264421)     at setState (/opt/iob        roker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
    2024-04-16 18:52:29.434  - warn: javascript.0 (1264421)     at Object.<anonymous>        (script.js.07_Rollladen.Beschattung_West:41:3)
    2024-04-16 18:52:29.435  - warn: javascript.0 (1264421)     at Object.<anonymous>        (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1691:34)
    2024-04-16 18:52:29.439  - warn: javascript.0 (1264421)     at Timeout._onTimeout        (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3031:34)
    2024-04-16 18:52:29.440  - warn: javascript.0 (1264421)     at listOnTimeout (nod        e:internal/timers:569:17)
    2024-04-16 18:52:29.440  - warn: javascript.0 (1264421)     at processTimers (nod        e:internal/timers:512:7)
    2024-04-16 18:59:04.437  - info: feiertage.0 (1290817) starting. Version 1.2.0 in        /opt/iobroker/node_modules/iobroker.feiertage, node: v18.17.1, js-controller: 5.        0.17
    2024-04-16 18:59:04.524  - info: feiertage.0 (1290817) Next holiday: Tag der Arbe        it is in 15 days on 01.05.2024
    2024-04-16 18:59:04.534  - info: feiertage.0 (1290817) all objects written
    2024-04-16 18:59:04.539  - info: feiertage.0 (1290817) Terminated (NO_ERROR): Wit        hout reason
    2024-04-16 19:00:05.038  - info: feiertage.0 (1291015) starting. Version 1.2.0 in        /opt/iobroker/node_modules/iobroker.feiertage, node: v18.17.1, js-controller: 5.        0.17
    2024-04-16 19:00:05.314  - info: feiertage.0 (1291015) Next holiday: Tag der Arbe        it is in 15 days on 01.05.2024
    2024-04-16 19:00:05.340  - info: feiertage.0 (1291015) all objects written
    2024-04-16 19:00:05.355  - info: feiertage.0 (1291015) Terminated (NO_ERROR): Wit        hout reason
    2024-04-16 19:05:47.882  - warn: zigbee.0 (1264627) DeviceAvailability:Stopping t        o ping 0x84182600000daf7a Plug 01 after 4 ping attempts
    2024-04-16 19:17:25.311  - warn: zigbee.0 (1264627) DeviceAvailability:Failed to        ping 0x5c0272fffe6e55ea TRADFRI Signal Repeater
    • M m.schalk
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      mario
      /home/mario
      mario sudo iobroker
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               5120 M total memory
               4007 M used memory
                 40 M free memory
                  0 M buffer memory
               1071 M swap cache
               5120 M total swap
               1535 M used swap
               3584 M free swap
      *** FILESYSTEM ***
      /var:
      4.2G    /var/
      2.9G    /var/log
      981M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: redis
      States  type: redis
      admin:          6.17.3
      javascript:     8.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        49416
      States:         42924
      Pending Updates: 98
      @m-schalk sagte in Sporadische Neustarts des iobroker:
      Deine grafana.list hat Doubletten.
      Schmeiß die doppelten Einträge dort raus.
      Dein nodejs ist veraltet. Per
      iob nodejs-update
      auf Stand bringen.
      Dann wird es wohl so sein, dass du für redis/redis zu wenig RAM hast. redis läuft ja komplett im RAM und deswegen braucht es da halt reichlich von.
      Pending Updates: 98
      Updaten. Die iob-Adapter auch.
        iob nodejs-update
        auf Stand bringen.
        Pending Updates: 98
        m.schalk
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.4 LTS
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
         21:19:03 up 26 min,  3 users,  load average: 3.10, 4.57, 4.47
        CPU threads: 4
                       Local time: Tue 2024-04-16 21:19:03 CEST
                   Universal time: Tue 2024-04-16 19:19:03 UTC
                         RTC time: n/a
                  RTC in local TZ: no
        mario
        /home/mario
        mario sudo iobroker
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            8.2G        3.6G        2.6G        0.0K        2.0G        4.6G
        Swap:           7.8G        0.0K        7.8G
        Total:           15G        3.6G         10G
                 8192 M total memory
                 3619 M used memory
                  565 M active memory
                 4778 M inactive memory
                 2612 M free memory
                    0 M buffer memory
                 1959 M swap cache
                 7759 M total swap
                    0 M used swap
                 7759 M free swap
        *** FILESYSTEM ***
        /dev/loop0     ext4    26G   20G  4.6G  82% /
        tmpfs          tmpfs  3.1G  172K  3.1G   1% /run
        tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/0
        /var:
        4.0G    /var/
        2.8G    /var/log
        2.7G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
        781M    /var/lib
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
        /usr/bin/nodejs         v18.20.2
        /usr/bin/node           v18.20.2
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        /usr/bin/corepack       0.25.2
        nodejs:
          Installed: 18.20.2-1nodesource1
          Candidate: 18.20.2-1nodesource1
          Version table:
         *** 18.20.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
        Errors in npm tree:
        ioBroker Status
        Objects type: redis
        States  type: redis
        js-controller:  5.0.19
        admin:          6.17.3
        javascript:     8.0.3
        Adapter State
        + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
        + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
        + system.adapter.backitup.0               : backitup              : BU02SMART02-iobroker                     -  enabled
        + system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
        + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
          system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
          system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     - disabled
        + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
        + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
          system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
          system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
        + system.adapter.ford.0                   : ford                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
          system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
        + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
        + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
          system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
        + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
        + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
        + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
          system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
          system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-iobroker                     - disabled
        + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.proxmox.0                : proxmox               : BU02SMART02-iobroker                     - disabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
        + system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
          system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-iobroker                     - disabled
        + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
          system.adapter.snmp.0                   : snmp                  : BU02SMART02-iobroker                     - disabled
          system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
        + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.tuya.1                   : tuya                  : BU02SMART02-iobroker                     - disabled
          system.adapter.unifi.0                  : unifi                 : BU02SMART02-iobroker                     - disabled
        + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
          system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
        + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.ws.0                     : ws                    : BU02SMART02-iobroker                     - disabled, port: 8087, bind: 192.168.2.166, run as: admin
        + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
          system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
        + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
        + instance is alive
        Controller "js-controller": 5.0.19   , installed 5.0.19
        Objects and States
        Objects:        49449
        States:         43067
        Hit:1 https://repos.influxdata.com/debian stable InRelease
        Hit:2 https://apt.grafana.com stable InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Pending Updates: 0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          134632524  1/init
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       134767830  3724/io.mqtt.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          134635725  283/master
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        134631393  100/systemd-resolve
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        134635550  116/redis-server 12
        tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      0          134652904  935/sshd: root@pts/
        tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1001       134826590  5717/sshd: mario@pt
        tcp        0      0 0.0.0.0:39227           0.0.0.0:*               LISTEN      1000       134773301  4042/io.yahka.0
        tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       134769007  3803/io.shelly.1
        tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       134770223  3841/io.mqtt.1
        tcp6       0      0 :::111                  :::*                    LISTEN      0          134632526  1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          134632859  1/init
        tcp6       0      0 :::3000                 :::*                    LISTEN      112        134639723  339/grafana
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          134635726  283/master
        tcp6       0      0 ::1:6379                :::*                    LISTEN      113        134635551  116/redis-server 12
        tcp6       0      0 ::1:6010                :::*                    LISTEN      0          134652903  935/sshd: root@pts/
        tcp6       0      0 ::1:6011                :::*                    LISTEN      1001       134826589  5717/sshd: mario@pt
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       134762300  3585/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134782529  4319/io.web.0
        udp        0      0 0.0.0.0:50492           0.0.0.0:*                           1000       134778743  3917/io.shelly.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       134775091  4042/io.yahka.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       134773821  3917/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134765342  3672/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134765343  3672/io.tuya.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        134631392  100/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          134632525  1/init
        udp6       0      0 :::111                  :::*                                0          134632527  1/init
        2024-04-16 21:14:16.270  - info: sourceanalytix.0 (4060) Initialising (24 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay1.gesamt"
        2024-04-16 21:14:17.088  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay1.gesamt successfully
        2024-04-16 21:14:17.089  - info: sourceanalytix.0 (4060) Initialising (25 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay0.gesamt"
        2024-04-16 21:14:18.113  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay0.gesamt successfully
        2024-04-16 21:14:18.114  - info: sourceanalytix.0 (4060) Initialising (26 of 34) "javascript.0.ShellyVerbrauch.SHPLG-S#1D409A#1.Relay0.gesamt"
        2024-04-16 21:14:18.812  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#1D409A#1.Relay0.gesamt successfully
        2024-04-16 21:14:18.812  - info: sourceanalytix.0 (4060) Initialising (27 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E571#1.Relay1.gesamt"
        2024-04-16 21:14:19.828  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E571#1.Relay1.gesamt successfully
        2024-04-16 21:14:19.828  - info: sourceanalytix.0 (4060) Initialising (28 of 34) "linkeddevices.0.Solarleistung.Summe-Solar-kwh"
        2024-04-16 21:14:20.982  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Solarleistung.Summe-Solar-kwh successfully
        2024-04-16 21:14:20.982  - info: sourceanalytix.0 (4060) Initialising (29 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC49C48#1.Relay0.gesamt"
        2024-04-16 21:14:21.914  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC49C48#1.Relay0.gesamt successfully
        2024-04-16 21:14:21.914  - info: sourceanalytix.0 (4060) Initialising (30 of 34) "linkeddevices.0.Solarleistung.open-DTU-612W"
        2024-04-16 21:14:22.613  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Solarleistung.open-DTU-612W successfully
        2024-04-16 21:14:22.614  - info: sourceanalytix.0 (4060) Initialising (31 of 34) "javascript.0.ShellyVerbrauch.shellyplus1pm#4855199d4330#1.Relay0.gesamt"
        2024-04-16 21:14:23.863  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.shellyplus1pm#4855199d4330#1.Relay0.gesamt successfully
        2024-04-16 21:14:23.863  - info: sourceanalytix.0 (4060) Initialising (32 of 34) "javascript.0.ShellyVerbrauch.SHEM-3#C45BBE783E1A#1.Total.gesamt"
        2024-04-16 21:14:24.861  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHEM-3#C45BBE783E1A#1.Total.gesamt successfully
        2024-04-16 21:14:24.861  - info: sourceanalytix.0 (4060) Initialising (33 of 34) "linkeddevices.0.Gesamt"
        2024-04-16 21:14:25.916  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Gesamt successfully
        2024-04-16 21:14:25.916  - info: sourceanalytix.0 (4060) Initialising (34 of 34) "javascript.0.ShellyVerbrauch.SHPLG-S#E868E7C38CAD#1.Relay0.gesamt"
        2024-04-16 21:14:27.233  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#E868E7C38CAD#1.Relay0.gesamt successfully
        2024-04-16 21:14:27.245  - warn: sourceanalytix.0 (4060) Cannot handle calculations for 1 of 34 enabled states, check error messages
        2024-04-16 21:14:27.245  - info: sourceanalytix.0 (4060) Successfully activated SourceAnalytix for 33 of 34 states, will do my Job until you stop me!
        2024-04-16 21:14:58.300  - error: daikin.0 (3782) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
        • M m.schalk
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          mario
          /home/mario
          mario sudo iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Total:           15G        3.6G         10G
                   8192 M total memory
                   3619 M used memory
                    565 M active memory
                   2612 M free memory
                      0 M buffer memory
                   1959 M swap cache
                   7759 M total swap
                      0 M used swap
                   7759 M free swap
          *** FILESYSTEM ***
          /var:
          4.0G    /var/
          2.8G    /var/log
          781M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: redis
          States  type: redis
          admin:          6.17.3
          javascript:     8.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        49449
          States:         43067
          Pending Updates: 0
          CPU threads: 4
          Irgendwas haut dir da aber auch die Load in ungesunde Bereiche. Bei 4 ist die Kiste dicht.
          Ausschalten:
          Boot Target: graphical.target
          sudo systemctl set-default multi-user.target
          Das Dateisystem droht dir auch in absehbarer Zeit vollzulaufen:
          Trag im zigbee-Adapter statt /dev/ttyUSB0
          besser
          ein.
          Und meld dich NICHT als root an.
          Hier läuft eine root shell:
          Mach es einfach nicht.
          Und bring die Adapter auf Stand.
            CPU threads: 4
            Ausschalten:
            besser
            ein.
            m.schalk
            @thomas-braun said in Sporadische Neustarts des iobroker:
            also Zigbee läuft nicht mehr, habe zurückgestellt.
            Starting zigbee-herdsman problem : "Error: Permission denied, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0"
            • M m.schalk
              Und welche Rechte wären erforderlich?
              ls -la /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
              Kann aber auch mit dem Container zusammenhängen. Die Dinger ticken ja anders.
                m.schalk
                @thomas-braun root :-)
                1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
                • M m.schalk
                  @m-schalk
                  Und den wichtigsten Part hast unterschlagen. Die Rechte stehen ganz am Anfang.
                  So soll das aussehen:
                  echad@chet:/opt/iobroker $ ls -la /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
                  lrwxrwxrwx 1 root root 13 Apr  8 17:19 /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                    @m-schalk
                    m.schalk
                    ---------- 1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
                    • M m.schalk
                      @m-schalk
                      Ja, das hat mit dem Durchreichen in den Container zu tun. Hab ich aber keine Ahnung von.
                        @m-schalk
                        m.schalk
                        @thomas-braun ok, trotzdem Danke, ich schau mal wie es läuft.
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Chassis: container
                          Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                         22:13:26 up  1:20,  2 users,  load average: 5.88, 4.78, 4.63
                        CPU threads: 4
                                       Local time: Tue 2024-04-16 22:13:26 CEST
                                   Universal time: Tue 2024-04-16 20:13:26 UTC
                                         RTC time: n/a
                                  RTC in local TZ: no
                        mario
                        /home/mario
                        mario sudo iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            8.2G        4.0G        1.9G        0.0K        2.3G        4.2G
                        Total:           15G        4.0G        9.6G
                                 8192 M total memory
                                 4020 M used memory
                                  844 M active memory
                                 5138 M inactive memory
                                 1879 M free memory
                                    0 M buffer memory
                                 2292 M swap cache
                                 7759 M total swap
                                    0 M used swap
                                 7759 M free swap
                        *** FILESYSTEM ***
                        /dev/loop0     ext4    26G   21G  4.6G  82% /
                        /var:
                        4.0G    /var/
                        2.8G    /var/log
                        781M    /var/lib
                        USB-Devices by-id:
                        /usr/bin/npm            10.5.0
                        /usr/bin/npx            10.5.0
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: redis
                        States  type: redis
                        admin:          6.17.3
                        javascript:     8.0.3
                        Adapter State
                        + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
                        + instance is alive
                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                        Objects and States
                        Objects:        49451
                        States:         42960
                        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                        Hit:3 https://apt.grafana.com stable InRelease
                        Pending Updates: 0
                        udp        0      0 0.0.0.0:55014           0.0.0.0:*                           1000       135249274  3917/io.shelly.0
                        2024-04-16 21:49:27.283  - info: zigbee.0 (13050) 0x84182600000d798a (addr 50622): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2024-04-16 21:49:27.285  - info: zigbee.0 (13050) 0x7cb03eaa00ad4adf (addr 48445): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2024-04-16 21:49:27.287  - info: zigbee.0 (13050) 0x7cb03eaa00ad1661 (addr 64742): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2024-04-16 21:49:27.289  - info: zigbee.0 (13050) 0x8418260000cab6da (addr 26679): 4052899926110 - OSRAM Flex RGBW (Router)
                        2024-04-16 21:49:27.291  - info: zigbee.0 (13050) 0x5c0272fffe6e55ea (addr 38364): E1746 - IKEA TRADFRI signal repeater (Router)
                        2024-04-16 21:49:27.294  - info: zigbee.0 (13050) 0x54ef4410005b43d3 (addr 45208): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
                        2024-04-16 21:49:27.297  - info: zigbee.0 (13050) 0x5c0272fffe5b723b (addr 27218): E1746 - IKEA TRADFRI signal repeater (Router)
                        2024-04-16 21:49:27.298  - info: zigbee.0 (13050) 0x7cb03eaa0a068fec (addr 16021): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2024-04-16 21:49:27.306  - info: zigbee.0 (13050) 0x00158d0008a6bd14 (addr 37504): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-04-16 21:49:27.308  - info: zigbee.0 (13050) 0x00158d0008834af4 (addr 53958): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-04-16 21:49:27.309  - info: zigbee.0 (13050) Zigbee started
                        2024-04-16 21:49:27.379  - info: zigbee.0 (13050) debug devices set to []
                        2024-04-16 21:49:35.454  - info: admin.0 (3585) ==> Connected system.user.admin from ::ffff:192.168.2.160
                        2024-04-16 21:49:35.812  - info: zigbee.0 (13050) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}]
                        2024-04-16 21:50:03.153  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa0a068fec Plug 01
                        2024-04-16 21:59:03.751  - info: feiertage.0 (14906) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
                        2024-04-16 21:59:03.864  - info: feiertage.0 (14906) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
                        2024-04-16 21:59:03.874  - info: feiertage.0 (14906) all objects written
                        2024-04-16 21:59:03.883  - info: feiertage.0 (14906) Terminated (NO_ERROR): Without reason
                        2024-04-16 22:00:09.226  - info: feiertage.0 (15092) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
                        2024-04-16 22:00:09.729  - info: feiertage.0 (15092) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
                        2024-04-16 22:00:09.875  - info: feiertage.0 (15092) all objects written
                        2024-04-16 22:00:09.889  - info: feiertage.0 (15092) Terminated (NO_ERROR): Without reason
                        2024-04-16 22:00:21.817  - warn: netatmo-crawler.0 (15192) slow connection to objects DB. Still waiting ...
                        2024-04-16 22:06:45.998  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa00ad1661 Plug 01
                        • M m.schalk
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          mario
                          /home/mario
                          mario sudo iobroker
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                                   8192 M total memory
                                   4020 M used memory
                                    844 M active memory
                                   1879 M free memory
                                      0 M buffer memory
                                   2292 M swap cache
                                   7759 M total swap
                                      0 M used swap
                                   7759 M free swap
                          *** FILESYSTEM ***
                          /var:
                          4.0G    /var/
                          2.8G    /var/log
                          781M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.5.0
                          /usr/bin/npx            10.5.0
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: redis
                          States  type: redis
                          admin:          6.17.3
                          javascript:     8.0.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        49451
                          States:         42960
                          Pending Updates: 0
                          Wenn die Kiste jetzt nicht stabiler läuft:
                          Ich vermute hier ein Skript, das ungünstig angelegt wurde.
                            m.schalk
                            @thomas-braun Hallo Thomas, die Restarts sind weniger geworden, aber leider sind es immer noch 2 am Tag. Was kann ich noch prüfen? Skripte?
                            Thomas BraunT ? 2 Antworten Letzte Antwort
                            • M m.schalk
                              @m-schalk
                              Ja, i.d.R. ist dann ein Skript falsch/ungünstig angelegt.
                                @m-schalk
                                m.schalk
                                @thomas-braun leider weiß ich nicht, wie ich das überprüfen kann.
                                • M m.schalk
                                  @m-schalk
                                  Ich auch nicht.
                                  M 2 Antworten Letzte Antwort
                                  • M m.schalk
                                    oder Backup? Backups fressen Speicher und Ressourcen.. nicht, dass hier die Luft aus geht..?
                                    Bei den Skripten bleibt nur eins, der Reihe nach ausschalten oder alle Aus, und dann der Reihe nach ein..
                                    Es hilft auch, die Uhrzeiten zu protokollieren, und dann im Log zu sehen, was vorher passiert ist.. auch Skripte, die kurz vorher starten, mal anschauen..
                                      @m-schalk
                                      Ich auch nicht.
                                      m.schalk
                                      @thomas-braun was kannst du dazu sagen? Das habe ich ca 1000
                                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                         at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                                         at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                      2024-04-19 21:30:47.823  - error: shelly.0 (470312) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.829  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.833  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.835  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.841  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.843  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.846  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.850  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.851  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.855  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.859  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.861  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.862  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.864  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.866  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.869  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.870  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.872  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.875  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.876  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.877  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.879  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.881  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.884  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.886  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.887  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.888  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.889  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.892  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.893  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.894  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.897  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.899  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.901  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        @m-schalk
                                        Ich auch nicht.
                                        m.schalk
                                        schrieb am zuletzt editiert von m.schalk
                                        @thomas-braun das ist als letztes im log vor dem Restart, mindestens 10.000 mal
                                        der Logfile ist 35Mb groß
                                        2024-04-19 21:31:36.745  - error: javascript.0 (499664) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                                        2024-04-19 21:31:36.745  - error: javascript.0 (499664) Error: write EPIPE
                                            at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                                            at writeGeneric (node:internal/stream_base_commons:151:3)
                                            at Socket._writeGeneric (node:net:962:11)
                                            at Socket._write (node:net:974:8)
                                            at writeOrBuffer (node:internal/streams/writable:392:12)
                                            at _write (node:internal/streams/writable:333:10)
                                            at Socket.Writable.write (node:internal/streams/writable:337:10)
                                            at console.value (node:internal/console/constructor:305:16)
                                            at console.warn (node:internal/console/constructor:385:26)
                                            at /opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:15:13
                                        • ? Offline
                                          @m-schalk
                                          Dann schau mal in das Redis log, da stimmt was nicht..
