  4. [gelöst] Sporadische Neustarts des iobroker
26 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • M m.schalk
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: BU02SMART02-iobroker
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
    Operating System: Ubuntu 22.04.4 LTS
              Kernel: Linux 6.2.16-18-pve
        Architecture: x86-64
    model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     21:19:03 up 26 min,  3 users,  load average: 3.10, 4.57, 4.47
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Tue 2024-04-16 21:19:03 CEST
               Universal time: Tue 2024-04-16 19:19:03 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    mario
    /home/mario
    mario sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.2G        3.6G        2.6G        0.0K        2.0G        4.6G
    Swap:           7.8G        0.0K        7.8G
    Total:           15G        3.6G         10G
             8192 M total memory
             3619 M used memory
              565 M active memory
             4778 M inactive memory
             2612 M free memory
                0 M buffer memory
             1959 M swap cache
             7759 M total swap
                0 M used swap
             7759 M free swap
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    /dev/loop0     ext4    26G   20G  4.6G  82% /
    none           tmpfs  492K  4.0K  488K   1% /dev
    tmpfs          tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs          tmpfs  3.1G  172K  3.1G   1% /run
    tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/0
    tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE     FSTYPE OPTIONS
    /      /dev/loop0 ext4   rw,relatime
    /var:
    4.0G    /var/
    2.8G    /var/log
    2.7G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
    781M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    713M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    7.9G    /opt/iobroker/iobroker-data/
    6.5G    /opt/iobroker/iobroker-data/history
    627M    /opt/iobroker/iobroker-data/files
    487M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
    49M     /opt/iobroker/iobroker-data/objects.jsonl
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    28M     /opt/iobroker/iobroker-data/states.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.9~dfsg-1ubuntu3.5 500
            500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.17.3
    javascript:     8.0.3
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
    + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
    + system.adapter.backitup.0               : backitup              : BU02SMART02-iobroker                     -  enabled
    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     -  enabled
    + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
    + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
    + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
      system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
      system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     - disabled
    + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
      system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
      system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
    + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
    + system.adapter.ford.0                   : ford                  : BU02SMART02-iobroker                     -  enabled
    + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
    + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
      system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
    + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : BU02SMART02-iobroker                     -  enabled
    + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
    + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
      system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
    + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     -  enabled
      system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
    + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
    + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
    + system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
      system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
      system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-iobroker                     - disabled
    + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
      system.adapter.proxmox.0                : proxmox               : BU02SMART02-iobroker                     - disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
    + system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     -  enabled
    + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
    + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
      system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-iobroker                     - disabled
    + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
    + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
      system.adapter.snmp.0                   : snmp                  : BU02SMART02-iobroker                     - disabled
      system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
    + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
      system.adapter.tuya.1                   : tuya                  : BU02SMART02-iobroker                     - disabled
      system.adapter.unifi.0                  : unifi                 : BU02SMART02-iobroker                     - disabled
    + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
      system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
      system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
    + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.ws.0                     : ws                    : BU02SMART02-iobroker                     - disabled, port: 8087, bind: 192.168.2.166, run as: admin
    + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
      system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
    + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.17.3   , installed 6.17.3
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "apcups"       : 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 2.11.0   , installed 2.9.9  [Updatable]
    Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.0  , installed 2.12.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "ems-esp"      : 3.1.1    , installed 3.1.1
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "ford"         : 0.2.0    , installed 0.2.0
    Adapter    "hass-mqtt"    : 0.0.7    , installed 0.0.7
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 3.2.2    , installed 3.2.2
    Adapter    "javascript"   : 8.0.3    , installed 8.0.3
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
    Adapter    "mercedesme"   : 0.2.2    , installed 0.2.2
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "ring"         : 5.0.10   , installed 5.0.10
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "shelly"       : 6.9.0    , installed 6.9.0
    Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
    Adapter    "slideshow"    : 0.1.4    , installed 0.1.4
    Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "telegram"     : 3.2.1    , installed 3.2.1
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
    Adapter    "vis"          : 1.5.5    , installed 1.5.5
    Adapter    "vis-2"        : 2.9.49   , installed 2.9.49
    Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
    Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
    Adapter    "vis-2-widgets-material": 1.3.27, installed 1.3.27
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        49449
    States:         43067
    Hit:1 https://repos.influxdata.com/debian stable InRelease
    Hit:2 https://apt.grafana.com stable InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          134632524  1/init
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       134767830  3724/io.mqtt.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          134635725  283/master
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        134631393  100/systemd-resolve
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        134635550  116/redis-server 12
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      0          134652904  935/sshd: root@pts/
    tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1001       134826590  5717/sshd: mario@pt
    tcp        0      0 0.0.0.0:39227           0.0.0.0:*               LISTEN      1000       134773301  4042/io.yahka.0
    tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       134769007  3803/io.shelly.1
    tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       134770223  3841/io.mqtt.1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          134632526  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          134632859  1/init
    tcp6       0      0 :::3000                 :::*                    LISTEN      112        134639723  339/grafana
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          134635726  283/master
    tcp6       0      0 ::1:6379                :::*                    LISTEN      113        134635551  116/redis-server 12
    tcp6       0      0 ::1:6010                :::*                    LISTEN      0          134652903  935/sshd: root@pts/
    tcp6       0      0 ::1:6011                :::*                    LISTEN      1001       134826589  5717/sshd: mario@pt
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       134762300  3585/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134782529  4319/io.web.0
    udp        0      0 0.0.0.0:50492           0.0.0.0:*                           1000       134778743  3917/io.shelly.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       134775091  4042/io.yahka.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       134773821  3917/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134765342  3672/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134765343  3672/io.tuya.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        134631392  100/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          134632525  1/init
    udp6       0      0 :::111                  :::*                                0          134632527  1/init
    2024-04-16 21:14:16.270  - info: sourceanalytix.0 (4060) Initialising (24 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay1.gesamt"
    2024-04-16 21:14:17.088  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay1.gesamt successfully
    2024-04-16 21:14:17.089  - info: sourceanalytix.0 (4060) Initialising (25 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay0.gesamt"
    2024-04-16 21:14:18.113  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay0.gesamt successfully
    2024-04-16 21:14:18.114  - info: sourceanalytix.0 (4060) Initialising (26 of 34) "javascript.0.ShellyVerbrauch.SHPLG-S#1D409A#1.Relay0.gesamt"
    2024-04-16 21:14:18.812  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#1D409A#1.Relay0.gesamt successfully
    2024-04-16 21:14:18.812  - info: sourceanalytix.0 (4060) Initialising (27 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E571#1.Relay1.gesamt"
    2024-04-16 21:14:19.828  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E571#1.Relay1.gesamt successfully
    2024-04-16 21:14:19.828  - info: sourceanalytix.0 (4060) Initialising (28 of 34) "linkeddevices.0.Solarleistung.Summe-Solar-kwh"
    2024-04-16 21:14:20.982  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Solarleistung.Summe-Solar-kwh successfully
    2024-04-16 21:14:20.982  - info: sourceanalytix.0 (4060) Initialising (29 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC49C48#1.Relay0.gesamt"
    2024-04-16 21:14:21.914  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC49C48#1.Relay0.gesamt successfully
    2024-04-16 21:14:21.914  - info: sourceanalytix.0 (4060) Initialising (30 of 34) "linkeddevices.0.Solarleistung.open-DTU-612W"
    2024-04-16 21:14:22.613  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Solarleistung.open-DTU-612W successfully
    2024-04-16 21:14:22.614  - info: sourceanalytix.0 (4060) Initialising (31 of 34) "javascript.0.ShellyVerbrauch.shellyplus1pm#4855199d4330#1.Relay0.gesamt"
    2024-04-16 21:14:23.863  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.shellyplus1pm#4855199d4330#1.Relay0.gesamt successfully
    2024-04-16 21:14:23.863  - info: sourceanalytix.0 (4060) Initialising (32 of 34) "javascript.0.ShellyVerbrauch.SHEM-3#C45BBE783E1A#1.Total.gesamt"
    2024-04-16 21:14:24.861  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHEM-3#C45BBE783E1A#1.Total.gesamt successfully
    2024-04-16 21:14:24.861  - info: sourceanalytix.0 (4060) Initialising (33 of 34) "linkeddevices.0.Gesamt"
    2024-04-16 21:14:25.916  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Gesamt successfully
    2024-04-16 21:14:25.916  - info: sourceanalytix.0 (4060) Initialising (34 of 34) "javascript.0.ShellyVerbrauch.SHPLG-S#E868E7C38CAD#1.Relay0.gesamt"
    2024-04-16 21:14:27.233  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#E868E7C38CAD#1.Relay0.gesamt successfully
    2024-04-16 21:14:27.245  - warn: sourceanalytix.0 (4060) Cannot handle calculations for 1 of 34 enabled states, check error messages
    2024-04-16 21:14:27.245  - info: sourceanalytix.0 (4060) Successfully activated SourceAnalytix for 33 of 34 states, will do my Job until you stop me!
    2024-04-16 21:14:58.300  - error: daikin.0 (3782) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
    @m-schalk sagte in Sporadische Neustarts des iobroker:
    CPU threads: 4
    Irgendwas haut dir da aber auch die Load in ungesunde Bereiche. Bei 4 ist die Kiste dicht.
    Ausschalten:
    Boot Target: graphical.target
    sudo systemctl set-default multi-user.target
    Das Dateisystem droht dir auch in absehbarer Zeit vollzulaufen:
    Trag im zigbee-Adapter statt /dev/ttyUSB0
    besser
    ein.
    Und meld dich NICHT als root an.
    Hier läuft eine root shell:
    Mach es einfach nicht.
    Und bring die Adapter auf Stand.
      CPU threads: 4
      Ausschalten:
      besser
      ein.
      m.schalk
      @thomas-braun said in Sporadische Neustarts des iobroker:
      also Zigbee läuft nicht mehr, habe zurückgestellt.
      Starting zigbee-herdsman problem : "Error: Permission denied, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0"
      • M m.schalk
        Und welche Rechte wären erforderlich?
        ls -la /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
        Kann aber auch mit dem Container zusammenhängen. Die Dinger ticken ja anders.
          m.schalk
          @thomas-braun root :-)
          1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
          • M m.schalk
            @m-schalk
            Und den wichtigsten Part hast unterschlagen. Die Rechte stehen ganz am Anfang.
            So soll das aussehen:
            echad@chet:/opt/iobroker $ ls -la /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
            lrwxrwxrwx 1 root root 13 Apr  8 17:19 /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
              @m-schalk
              m.schalk
              ---------- 1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
              • M m.schalk
                @m-schalk
                Ja, das hat mit dem Durchreichen in den Container zu tun. Hab ich aber keine Ahnung von.
                  @m-schalk
                  m.schalk
                  @thomas-braun ok, trotzdem Danke, ich schau mal wie es läuft.
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Chassis: container
                    Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                   22:13:26 up  1:20,  2 users,  load average: 5.88, 4.78, 4.63
                  CPU threads: 4
                                 Local time: Tue 2024-04-16 22:13:26 CEST
                             Universal time: Tue 2024-04-16 20:13:26 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  mario
                  /home/mario
                  mario sudo iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            8.2G        4.0G        1.9G        0.0K        2.3G        4.2G
                  Total:           15G        4.0G        9.6G
                           8192 M total memory
                           4020 M used memory
                            844 M active memory
                           5138 M inactive memory
                           1879 M free memory
                              0 M buffer memory
                           2292 M swap cache
                           7759 M total swap
                              0 M used swap
                           7759 M free swap
                  *** FILESYSTEM ***
                  /dev/loop0     ext4    26G   21G  4.6G  82% /
                  tmpfs          tmpfs  3.1G  152K  3.1G   1% /run
                  /var:
                  4.0G    /var/
                  2.8G    /var/log
                  781M    /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: redis
                  States  type: redis
                  admin:          6.17.3
                  javascript:     8.0.3
                  Adapter State
                  + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
                  + instance is alive
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                  Objects and States
                  Objects:        49451
                  States:         42960
                  Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                  Hit:3 https://apt.grafana.com stable InRelease
                  Pending Updates: 0
                  udp        0      0 0.0.0.0:55014           0.0.0.0:*                           1000       135249274  3917/io.shelly.0
                  2024-04-16 21:49:27.283  - info: zigbee.0 (13050) 0x84182600000d798a (addr 50622): AB3257001NJ - OSRAM Smart+ plug (Router)
                  2024-04-16 21:49:27.285  - info: zigbee.0 (13050) 0x7cb03eaa00ad4adf (addr 48445): AB3257001NJ - OSRAM Smart+ plug (Router)
                  2024-04-16 21:49:27.287  - info: zigbee.0 (13050) 0x7cb03eaa00ad1661 (addr 64742): AB3257001NJ - OSRAM Smart+ plug (Router)
                  2024-04-16 21:49:27.289  - info: zigbee.0 (13050) 0x8418260000cab6da (addr 26679): 4052899926110 - OSRAM Flex RGBW (Router)
                  2024-04-16 21:49:27.291  - info: zigbee.0 (13050) 0x5c0272fffe6e55ea (addr 38364): E1746 - IKEA TRADFRI signal repeater (Router)
                  2024-04-16 21:49:27.294  - info: zigbee.0 (13050) 0x54ef4410005b43d3 (addr 45208): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
                  2024-04-16 21:49:27.297  - info: zigbee.0 (13050) 0x5c0272fffe5b723b (addr 27218): E1746 - IKEA TRADFRI signal repeater (Router)
                  2024-04-16 21:49:27.298  - info: zigbee.0 (13050) 0x7cb03eaa0a068fec (addr 16021): AB3257001NJ - OSRAM Smart+ plug (Router)
                  2024-04-16 21:49:27.306  - info: zigbee.0 (13050) 0x00158d0008a6bd14 (addr 37504): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                  2024-04-16 21:49:27.308  - info: zigbee.0 (13050) 0x00158d0008834af4 (addr 53958): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                  2024-04-16 21:49:27.309  - info: zigbee.0 (13050) Zigbee started
                  2024-04-16 21:49:27.379  - info: zigbee.0 (13050) debug devices set to []
                  2024-04-16 21:49:35.454  - info: admin.0 (3585) ==> Connected system.user.admin from ::ffff:192.168.2.160
                  2024-04-16 21:49:35.812  - info: zigbee.0 (13050) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}]
                  2024-04-16 21:50:03.153  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa0a068fec Plug 01
                  2024-04-16 21:59:03.751  - info: feiertage.0 (14906) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
                  2024-04-16 21:59:03.864  - info: feiertage.0 (14906) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
                  2024-04-16 21:59:03.874  - info: feiertage.0 (14906) all objects written
                  2024-04-16 21:59:03.883  - info: feiertage.0 (14906) Terminated (NO_ERROR): Without reason
                  2024-04-16 22:00:09.226  - info: feiertage.0 (15092) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
                  2024-04-16 22:00:09.729  - info: feiertage.0 (15092) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
                  2024-04-16 22:00:09.875  - info: feiertage.0 (15092) all objects written
                  2024-04-16 22:00:09.889  - info: feiertage.0 (15092) Terminated (NO_ERROR): Without reason
                  2024-04-16 22:00:21.817  - warn: netatmo-crawler.0 (15192) slow connection to objects DB. Still waiting ...
                  2024-04-16 22:06:45.998  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa00ad1661 Plug 01
                  • M m.schalk
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    mario
                    /home/mario
                    mario sudo iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                             8192 M total memory
                             4020 M used memory
                              844 M active memory
                             1879 M free memory
                                0 M buffer memory
                             2292 M swap cache
                             7759 M total swap
                                0 M used swap
                             7759 M free swap
                    *** FILESYSTEM ***
                    /var:
                    4.0G    /var/
                    2.8G    /var/log
                    781M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: redis
                    States  type: redis
                    admin:          6.17.3
                    javascript:     8.0.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        49451
                    States:         42960
                    Pending Updates: 0
                    Wenn die Kiste jetzt nicht stabiler läuft:
                    Ich vermute hier ein Skript, das ungünstig angelegt wurde.
                      m.schalk
                      @thomas-braun Hallo Thomas, die Restarts sind weniger geworden, aber leider sind es immer noch 2 am Tag. Was kann ich noch prüfen? Skripte?
                      Thomas BraunT ? 2 Antworten Letzte Antwort
                      • M m.schalk
                        @m-schalk
                        Ja, i.d.R. ist dann ein Skript falsch/ungünstig angelegt.
                          @m-schalk
                          m.schalk
                          @thomas-braun leider weiß ich nicht, wie ich das überprüfen kann.
                          • M m.schalk
                            @m-schalk
                            Ich auch nicht.
                            M 2 Antworten Letzte Antwort
                            • M m.schalk
                              oder Backup? Backups fressen Speicher und Ressourcen.. nicht, dass hier die Luft aus geht..?
                              Bei den Skripten bleibt nur eins, der Reihe nach ausschalten oder alle Aus, und dann der Reihe nach ein..
                              Es hilft auch, die Uhrzeiten zu protokollieren, und dann im Log zu sehen, was vorher passiert ist.. auch Skripte, die kurz vorher starten, mal anschauen..
                                @m-schalk
                                Ich auch nicht.
                                m.schalk
                                @thomas-braun was kannst du dazu sagen? Das habe ich ca 1000
                                2024-04-19 21:30:47.475  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2024-04-19 21:30:47.475  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.475  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                   at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                                   at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                2024-04-19 21:30:47.823  - error: shelly.0 (470312) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.829  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.833  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.835  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.841  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.843  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.846  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.850  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.851  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.855  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.859  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.861  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.862  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.864  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.866  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.869  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.870  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.872  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.875  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.876  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.877  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.879  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.881  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.884  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.886  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.887  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.888  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.889  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.892  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.893  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.894  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.897  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.899  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.901  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.831  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2024-04-19 21:30:47.831  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                2024-04-19 21:30:47.831  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                  @m-schalk
                                  Ich auch nicht.
                                  m.schalk
                                  schrieb am zuletzt editiert von m.schalk
                                  @thomas-braun das ist als letztes im log vor dem Restart, mindestens 10.000 mal
                                  der Logfile ist 35Mb groß
                                  2024-04-19 21:31:36.745  - error: javascript.0 (499664) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                                  2024-04-19 21:31:36.745  - error: javascript.0 (499664) Error: write EPIPE
                                      at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                                      at writeGeneric (node:internal/stream_base_commons:151:3)
                                      at Socket._writeGeneric (node:net:962:11)
                                      at Socket._write (node:net:974:8)
                                      at writeOrBuffer (node:internal/streams/writable:392:12)
                                      at _write (node:internal/streams/writable:333:10)
                                      at Socket.Writable.write (node:internal/streams/writable:337:10)
                                      at console.value (node:internal/console/constructor:305:16)
                                      at console.warn (node:internal/console/constructor:385:26)
                                      at /opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:15:13
                                  • ? Offline
                                    @m-schalk
                                    Dann schau mal in das Redis log, da stimmt was nicht..
                                    • M m.schalk
                                      Irgendwas mit redis. Und/oder mit dem Dateisystem vielleicht.
                                        @m-schalk
                                        m.schalk
                                        @ilovegym wo liegt das?
                                        • M m.schalk
                                          https://www.digitalocean.com/community/tutorials/how-to-find-redis-logs-on-ubuntu
