  4. [gelöst] Sporadische Neustarts des iobroker
26 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    @m-schalk
    Und den wichtigsten Part hast unterschlagen. Die Rechte stehen ganz am Anfang.
    So soll das aussehen:
    echad@chet:/opt/iobroker $ ls -la /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
    lrwxrwxrwx 1 root root 13 Apr  8 17:19 /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
    m.schalk
    ---------- 1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
    • M m.schalk
      @m-schalk
      Ja, das hat mit dem Durchreichen in den Container zu tun. Hab ich aber keine Ahnung von.
        @m-schalk
        m.schalk
        @thomas-braun ok, trotzdem Danke, ich schau mal wie es läuft.
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: BU02SMART02-iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 6.2.16-18-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         22:13:26 up  1:20,  2 users,  load average: 5.88, 4.78, 4.63
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Tue 2024-04-16 22:13:26 CEST
                   Universal time: Tue 2024-04-16 20:13:26 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        mario
        /home/mario
        mario sudo iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            8.2G        4.0G        1.9G        0.0K        2.3G        4.2G
        Swap:           7.8G        0.0K        7.8G
        Total:           15G        4.0G        9.6G
                 8192 M total memory
                 4020 M used memory
                  844 M active memory
                 5138 M inactive memory
                 1879 M free memory
                    0 M buffer memory
                 2292 M swap cache
                 7759 M total swap
                    0 M used swap
                 7759 M free swap
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        /dev/loop0     ext4    26G   21G  4.6G  82% /
        none           tmpfs  492K  4.0K  488K   1% /dev
        tmpfs          tmpfs  7.8G     0  7.8G   0% /dev/shm
        tmpfs          tmpfs  3.1G  152K  3.1G   1% /run
        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/1001
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE     FSTYPE OPTIONS
        /      /dev/loop0 ext4   rw,relatime
        /var:
        4.0G    /var/
        2.8G    /var/log
        2.7G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
        781M    /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        713M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        7.9G    /opt/iobroker/iobroker-data/
        6.5G    /opt/iobroker/iobroker-data/history
        627M    /opt/iobroker/iobroker-data/files
        487M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
        49M     /opt/iobroker/iobroker-data/objects.jsonl
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        28M     /opt/iobroker/iobroker-data/states.jsonl
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.2
        /usr/bin/node           v18.20.2
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        /usr/bin/corepack       0.25.2
        nodejs:
          Installed: 18.20.2-1nodesource1
          Candidate: 18.20.2-1nodesource1
          Version table:
         *** 18.20.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.9~dfsg-1ubuntu3.5 500
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: redis
        States  type: redis
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.17.3
        javascript:     8.0.3
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
        + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
        + system.adapter.backitup.0               : backitup              : BU02SMART02-iobroker                     -  enabled
        + system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
        + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
          system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
        + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
        + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
          system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
          system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
        + system.adapter.ford.0                   : ford                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
          system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
        + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
        + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
          system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
        + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
        + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
        + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
          system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
          system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-iobroker                     - disabled
        + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.proxmox.0                : proxmox               : BU02SMART02-iobroker                     - disabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
        + system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
          system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-iobroker                     - disabled
        + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
          system.adapter.snmp.0                   : snmp                  : BU02SMART02-iobroker                     - disabled
          system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
        + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.tuya.1                   : tuya                  : BU02SMART02-iobroker                     - disabled
          system.adapter.unifi.0                  : unifi                 : BU02SMART02-iobroker                     - disabled
        + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
          system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
        + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.ws.0                     : ws                    : BU02SMART02-iobroker                     - disabled, port: 8087, bind: 192.168.2.166, run as: admin
        + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
          system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
        + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Beta (latest)
        Installed ioBroker-Instances
        Used repository: Beta (latest)
        Adapter    "admin"        : 6.17.3   , installed 6.17.3
        Adapter    "alarm"        : 3.6.0    , installed 3.6.0
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "apcups"       : 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.12.0  , installed 2.12.0
        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "ems-esp"      : 3.1.1    , installed 3.1.1
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
        Adapter    "ford"         : 0.2.0    , installed 0.2.0
        Adapter    "hass-mqtt"    : 0.0.7    , installed 0.0.7
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "ical"         : 1.14.3   , installed 1.14.3
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "iot"          : 3.2.2    , installed 3.2.2
        Adapter    "javascript"   : 8.0.3    , installed 8.0.3
        Controller "js-controller": 5.0.19   , installed 5.0.19
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
        Adapter    "mercedesme"   : 0.2.2    , installed 0.2.2
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "openweathermap": 1.0.4   , installed 1.0.4
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "ring"         : 5.0.10   , installed 5.0.10
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "shelly"       : 6.9.0    , installed 6.9.0
        Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
        Adapter    "slideshow"    : 0.1.4    , installed 0.1.4
        Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "telegram"     : 3.2.1    , installed 3.2.1
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
        Adapter    "vis"          : 1.5.5    , installed 1.5.5
        Adapter    "vis-2"        : 2.9.49   , installed 2.9.49
        Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
        Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
        Adapter    "vis-2-widgets-material": 1.3.27, installed 1.3.27
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "ws"           : 2.5.11   , installed 2.5.11
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        49451
        States:         42960
        Hit:1 https://repos.influxdata.com/debian stable InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:3 https://apt.grafana.com stable InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          134632524  1/init
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       134767830  3724/io.mqtt.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          134635725  283/master
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        134631393  100/systemd-resolve
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        134635550  116/redis-server 12
        tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1001       134826590  5717/sshd: mario@pt
        tcp        0      0 0.0.0.0:39227           0.0.0.0:*               LISTEN      1000       134773301  4042/io.yahka.0
        tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       134769007  3803/io.shelly.1
        tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       134770223  3841/io.mqtt.1
        tcp6       0      0 :::111                  :::*                    LISTEN      0          134632526  1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          134632859  1/init
        tcp6       0      0 :::3000                 :::*                    LISTEN      112        134639723  339/grafana
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          134635726  283/master
        tcp6       0      0 ::1:6379                :::*                    LISTEN      113        134635551  116/redis-server 12
        tcp6       0      0 ::1:6011                :::*                    LISTEN      1001       134826589  5717/sshd: mario@pt
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       134762300  3585/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134782529  4319/io.web.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       134775091  4042/io.yahka.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       134773821  3917/io.shelly.0
        udp        0      0 0.0.0.0:55014           0.0.0.0:*                           1000       135249274  3917/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134765342  3672/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134765343  3672/io.tuya.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        134631392  100/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          134632525  1/init
        udp6       0      0 :::111                  :::*                                0          134632527  1/init
        2024-04-16 21:49:27.283  - info: zigbee.0 (13050) 0x84182600000d798a (addr 50622): AB3257001NJ - OSRAM Smart+ plug (Router)
        2024-04-16 21:49:27.285  - info: zigbee.0 (13050) 0x7cb03eaa00ad4adf (addr 48445): AB3257001NJ - OSRAM Smart+ plug (Router)
        2024-04-16 21:49:27.287  - info: zigbee.0 (13050) 0x7cb03eaa00ad1661 (addr 64742): AB3257001NJ - OSRAM Smart+ plug (Router)
        2024-04-16 21:49:27.289  - info: zigbee.0 (13050) 0x8418260000cab6da (addr 26679): 4052899926110 - OSRAM Flex RGBW (Router)
        2024-04-16 21:49:27.291  - info: zigbee.0 (13050) 0x5c0272fffe6e55ea (addr 38364): E1746 - IKEA TRADFRI signal repeater (Router)
        2024-04-16 21:49:27.294  - info: zigbee.0 (13050) 0x54ef4410005b43d3 (addr 45208): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
        2024-04-16 21:49:27.297  - info: zigbee.0 (13050) 0x5c0272fffe5b723b (addr 27218): E1746 - IKEA TRADFRI signal repeater (Router)
        2024-04-16 21:49:27.298  - info: zigbee.0 (13050) 0x7cb03eaa0a068fec (addr 16021): AB3257001NJ - OSRAM Smart+ plug (Router)
        2024-04-16 21:49:27.306  - info: zigbee.0 (13050) 0x00158d0008a6bd14 (addr 37504): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        2024-04-16 21:49:27.308  - info: zigbee.0 (13050) 0x00158d0008834af4 (addr 53958): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        2024-04-16 21:49:27.309  - info: zigbee.0 (13050) Zigbee started
        2024-04-16 21:49:27.379  - info: zigbee.0 (13050) debug devices set to []
        2024-04-16 21:49:35.454  - info: admin.0 (3585) ==> Connected system.user.admin from ::ffff:192.168.2.160
        2024-04-16 21:49:35.812  - info: zigbee.0 (13050) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}]
        2024-04-16 21:50:03.153  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa0a068fec Plug 01
        2024-04-16 21:59:03.751  - info: feiertage.0 (14906) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
        2024-04-16 21:59:03.864  - info: feiertage.0 (14906) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
        2024-04-16 21:59:03.874  - info: feiertage.0 (14906) all objects written
        2024-04-16 21:59:03.883  - info: feiertage.0 (14906) Terminated (NO_ERROR): Without reason
        2024-04-16 22:00:09.226  - info: feiertage.0 (15092) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
        2024-04-16 22:00:09.729  - info: feiertage.0 (15092) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
        2024-04-16 22:00:09.875  - info: feiertage.0 (15092) all objects written
        2024-04-16 22:00:09.889  - info: feiertage.0 (15092) Terminated (NO_ERROR): Without reason
        2024-04-16 22:00:21.817  - warn: netatmo-crawler.0 (15192) slow connection to objects DB. Still waiting ...
        2024-04-16 22:06:45.998  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa00ad1661 Plug 01
        • M m.schalk
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          mario
          /home/mario
          mario sudo iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   8192 M total memory
                   4020 M used memory
                    844 M active memory
                   1879 M free memory
                      0 M buffer memory
                   2292 M swap cache
                   7759 M total swap
                      0 M used swap
                   7759 M free swap
          *** FILESYSTEM ***
          /var:
          4.0G    /var/
          2.8G    /var/log
          781M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: redis
          States  type: redis
          admin:          6.17.3
          javascript:     8.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        49451
          States:         42960
          Pending Updates: 0
          @m-schalk sagte in Sporadische Neustarts des iobroker:
          Wenn die Kiste jetzt nicht stabiler läuft:
          Ich vermute hier ein Skript, das ungünstig angelegt wurde.
            m.schalk
            @thomas-braun Hallo Thomas, die Restarts sind weniger geworden, aber leider sind es immer noch 2 am Tag. Was kann ich noch prüfen? Skripte?
            Thomas BraunT ? 2 Antworten Letzte Antwort
            • M m.schalk
              @m-schalk
              Ja, i.d.R. ist dann ein Skript falsch/ungünstig angelegt.
                @m-schalk
                m.schalk
                @thomas-braun leider weiß ich nicht, wie ich das überprüfen kann.
                • M m.schalk
                  @m-schalk
                  Ich auch nicht.
                  M 2 Antworten Letzte Antwort
                  • M m.schalk
                    oder Backup? Backups fressen Speicher und Ressourcen.. nicht, dass hier die Luft aus geht..?
                    Bei den Skripten bleibt nur eins, der Reihe nach ausschalten oder alle Aus, und dann der Reihe nach ein..
                    Es hilft auch, die Uhrzeiten zu protokollieren, und dann im Log zu sehen, was vorher passiert ist.. auch Skripte, die kurz vorher starten, mal anschauen..
                      @m-schalk
                      Ich auch nicht.
                      m.schalk
                      @thomas-braun was kannst du dazu sagen? Das habe ich ca 1000
                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                         at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                         at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                      2024-04-19 21:30:47.823  - error: shelly.0 (470312) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.829  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.833  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.835  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.841  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.843  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.846  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.850  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.851  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.855  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.859  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.861  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.862  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.864  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.866  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.869  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.870  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.872  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.875  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.876  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.877  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.879  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.881  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.884  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.886  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.887  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.888  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.889  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.892  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.893  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.894  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.897  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.899  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.901  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                        @m-schalk
                        Ich auch nicht.
                        m.schalk
                        schrieb am zuletzt editiert von m.schalk
                        @thomas-braun das ist als letztes im log vor dem Restart, mindestens 10.000 mal
                        der Logfile ist 35Mb groß
                        2024-04-19 21:31:36.745  - error: javascript.0 (499664) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                        2024-04-19 21:31:36.745  - error: javascript.0 (499664) Error: write EPIPE
                            at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                            at writeGeneric (node:internal/stream_base_commons:151:3)
                            at Socket._writeGeneric (node:net:962:11)
                            at Socket._write (node:net:974:8)
                            at writeOrBuffer (node:internal/streams/writable:392:12)
                            at _write (node:internal/streams/writable:333:10)
                            at Socket.Writable.write (node:internal/streams/writable:337:10)
                            at console.value (node:internal/console/constructor:305:16)
                            at console.warn (node:internal/console/constructor:385:26)
                            at /opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:15:13
                        • ? Offline
                          @m-schalk
                          Dann schau mal in das Redis log, da stimmt was nicht..
                          • M m.schalk
                            Irgendwas mit redis. Und/oder mit dem Dateisystem vielleicht.
                              @m-schalk
                              m.schalk
                              @ilovegym wo liegt das?
                              • M m.schalk
                                https://www.digitalocean.com/community/tutorials/how-to-find-redis-logs-on-ubuntu
                                  m.schalk
                                  @ilovegym hallo, scheint ein Problem bei Redis zu sein.
                                  === REDIS BUG REPORT START: Cut & paste starting from here ===
                                  535888:C 19 Apr 2024 21:30:47.166 # Redis 6.0.16 crashed by signal: 11, si_code: 1
                                  535888:C 19 Apr 2024 21:30:47.166 # Crashed running the instruction at: 0x562658427528
                                  535888:C 19 Apr 2024 21:30:47.166 # Accessing address: 0x76
                                  535888:C 19 Apr 2024 21:30:47.166 # Failed assertion: <no assertion failed> (<no file>:0)
                                  ------ STACK TRACE ------
                                  EIP:
                                  redis-rdb-bgsave 127.0.0.1:6379(lzf_compress+0x238)[0x562658427528]
                                  Backtrace:
                                  redis-rdb-bgsave 127.0.0.1:6379(logStackTrace+0x5c)[0x56265847d83c]
                                  redis-rdb-bgsave 127.0.0.1:6379(sigsegvHandler+0xd0)[0x562658480320]
                                  /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7ff189042520]
                                  redis-rdb-bgsave 127.0.0.1:6379(+0x7543c)[0x56265845543c]
                                  redis-rdb-bgsave 127.0.0.1:6379(rdbSaveRawString+0x115)[0x56265844ab05]
                                  redis-rdb-bgsave 127.0.0.1:6379(rdbSaveKeyValuePair+0x74)[0x56265844fea4]
                                  redis-rdb-bgsave 127.0.0.1:6379(rdbSaveRio+0x25d)[0x56265845028d]
                                  redis-rdb-bgsave 127.0.0.1:6379(rdbSave+0x117)[0x5626584508c7]
                                  redis-rdb-bgsave 127.0.0.1:6379(rdbSaveBackground+0xf3)[0x562658450be3]
                                  redis-rdb-bgsave 127.0.0.1:6379(serverCron+0x6ff)[0x56265841fd2f]
                                  redis-rdb-bgsave 127.0.0.1:6379(aeProcessEvents+0x477)[0x562658416ca7]
                                  redis-rdb-bgsave 127.0.0.1:6379(aeMain+0x1d)[0x562658416edd]
                                  redis-rdb-bgsave 127.0.0.1:6379(main+0x466)[0x5626584125f6]
                                  /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7ff189029d90]
                                  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7ff189029e40]
                                  redis-rdb-bgsave 127.0.0.1:6379(_start+0x25)[0x5626584129d5]
                                  ------ INFO OUTPUT ------
                                  # Server
                                  redis_version:6.0.16
                                  redis_git_sha1:00000000
                                  redis_git_dirty:0
                                  redis_build_id:a3fdef44459b3ad6
                                  redis_mode:standalone
                                  os:Linux 6.2.16-18-pve x86_64
                                  arch_bits:64
                                  multiplexing_api:epoll
                                  atomicvar_api:atomic-builtin
                                  gcc_version:11.2.0
                                  process_id:535888
                                  run_id:dd81208470d24e21da30c3db467aa897a35ea818
                                  tcp_port:6379
                                  uptime_in_seconds:261470
                                  uptime_in_days:3
                                  hz:10
                                  configured_hz:10
                                  lru_clock:2279014
                                  executable:/usr/bin/redis-server
                                  config_file:/etc/redis/redis.conf
                                  io_threads_active:0
                                  # Clients
                                  connected_clients:256
                                  client_recent_max_input_buffer:8
                                  client_recent_max_output_buffer:0
                                  blocked_clients:0
                                  tracking_clients:0
                                  clients_in_timeout_table:0
                                  # Memory
                                  used_memory:775250136
                                  used_memory_human:739.34M
                                  used_memory_rss:245919744
                                  used_memory_rss_human:234.53M
                                  used_memory_peak:881964608
                                  used_memory_peak_human:841.11M
                                  used_memory_peak_perc:87.90%
                                  used_memory_overhead:13684328
                                  used_memory_startup:809688
                                  used_memory_dataset:761565808
                                  used_memory_dataset_perc:98.34%
                                  allocator_allocated:775604592
                                  allocator_active:792817664
                                  allocator_resident:800509952
                                  total_system_memory:16581869568
                                  total_system_memory_human:15.44G
                                  used_memory_lua:109568
                                  used_memory_lua_human:107.00K
                                  used_memory_scripts:6136
                                  used_memory_scripts_human:5.99K
                                  number_of_cached_scripts:9
                                  maxmemory:0
                                  maxmemory_human:0B
                                  maxmemory_policy:noeviction
                                  allocator_frag_ratio:1.02
                                  allocator_frag_bytes:17213072
                                  allocator_rss_ratio:1.01
                                  allocator_rss_bytes:7692288
                                  rss_overhead_ratio:0.31
                                  rss_overhead_bytes:-554590208
                                  mem_fragmentation_ratio:0.32
                                  mem_fragmentation_bytes:-529328744
                                  mem_not_counted_for_evict:0
                                  mem_replication_backlog:0
                                  mem_clients_slaves:0
                                  mem_clients_normal:5250392
                                  mem_aof_buffer:0
                                  mem_allocator:jemalloc-5.2.1
                                  active_defrag_running:0
                                  lazyfree_pending_objects:0
                                  # Persistence
                                  loading:0
                                  rdb_changes_since_last_save:24388
                                  rdb_bgsave_in_progress:0
                                  rdb_last_save_time:1713554985
                                  rdb_last_bgsave_status:ok
                                  rdb_last_bgsave_time_sec:17
                                  rdb_current_bgsave_time_sec:-1
                                  rdb_last_cow_size:18829312
                                  aof_enabled:0
                                  aof_rewrite_in_progress:0
                                  aof_rewrite_scheduled:0
                                  aof_last_rewrite_time_sec:-1
                                  aof_current_rewrite_time_sec:-1
                                  aof_last_bgrewrite_status:ok
                                  aof_last_write_status:ok
                                  aof_last_cow_size:0
                                  module_fork_in_progress:0
                                  module_fork_last_cow_size:0
                                  # Stats
                                  total_connections_received:14976
                                  total_commands_processed:449758358
                                  instantaneous_ops_per_sec:2860
                                  total_net_input_bytes:58896855285
                                  total_net_output_bytes:214360874435
                                  instantaneous_input_kbps:435.56
                                  instantaneous_output_kbps:1362.81
                                  rejected_connections:0
                                  sync_full:0
                                  sync_partial_ok:0
                                  sync_partial_err:0
                                  expired_keys:24495
                                  expired_stale_perc:0.12
                                  expired_time_cap_reached_count:8
                                  expire_cycle_cpu_milliseconds:15200
                                  evicted_keys:0
                                  keyspace_hits:285673939
                                  keyspace_misses:127276
                                  pubsub_channels:2
                                  pubsub_patterns:1262
                                  latest_fork_usec:13497
                                  migrate_cached_sockets:0
                                  slave_expires_tracked_keys:0
                                  active_defrag_hits:0
                                  active_defrag_misses:0
                                  active_defrag_key_hits:0
                                  active_defrag_key_misses:0
                                  tracking_total_keys:0
                                  tracking_total_items:0
                                  tracking_total_prefixes:0
                                  unexpected_error_replies:0
                                  total_reads_processed:274021057
                                  total_writes_processed:390387317
                                  io_threaded_reads_processed:0
                                  io_threaded_writes_processed:0
                                  # Replication
                                  role:master
                                  connected_slaves:0
                                  master_replid:6337f54d611b8afb4d7975cbb532388dde9afb63
                                  master_replid2:0000000000000000000000000000000000000000
                                  master_repl_offset:0
                                  second_repl_offset:-1
                                  repl_backlog_active:0
                                  repl_backlog_size:1048576
                                  repl_backlog_first_byte_offset:0
                                  repl_backlog_histlen:0
                                  # CPU
                                  used_cpu_sys:0.135472
                                  used_cpu_user:0.617154
                                  used_cpu_sys_children:0.000000
                                  used_cpu_user_children:0.000000
                                  # Modules
                                  # Commandstats
                                  cmdstat_config:calls=5033,usec=42748,usec_per_call=8.49
                                  cmdstat_srem:calls=314,usec=2890,usec_per_call=9.20
                                  cmdstat_info:calls=14974,usec=1485972,usec_per_call=99.24
                                  cmdstat_get:calls=272987760,usec=16400864140,usec_per_call=60.08
                                  cmdstat_subscribe:calls=5040,usec=31871,usec_per_call=6.32
                                  cmdstat_del:calls=869,usec=25238,usec_per_call=29.04
                                  cmdstat_script:calls=2521,usec=14960,usec_per_call=5.93
                                  cmdstat_publish:calls=79624645,usec=12933656279,usec_per_call=162.43
                                  cmdstat_punsubscribe:calls=15348,usec=588714,usec_per_call=38.36
                                  cmdstat_exists:calls=6388310,usec=9550202,usec_per_call=1.49
                                  cmdstat_sadd:calls=50301,usec=150896,usec_per_call=3.00
                                  cmdstat_client:calls=14884,usec=44135,usec_per_call=2.97
                                  cmdstat_sscan:calls=4510522,usec=3550650881,usec_per_call=787.19
                                  cmdstat_psubscribe:calls=43946,usec=563994,usec_per_call=12.83
                                  cmdstat_eval:calls=7,usec=146,usec_per_call=20.86
                                  cmdstat_mget:calls=15049,usec=3330837,usec_per_call=221.33
                                  cmdstat_exec:calls=1025,usec=23588,usec_per_call=23.01
                                  cmdstat_keys:calls=2495,usec=65446235,usec_per_call=26230.96
                                  cmdstat_setex:calls=8017443,usec=33961328,usec_per_call=4.24
                                  cmdstat_multi:calls=1025,usec=831,usec_per_call=0.81
                                  cmdstat_scan:calls=2283566,usec=780487989,usec_per_call=341.78
                                  cmdstat_set:calls=71254075,usec=272358535,usec_per_call=3.82
                                  cmdstat_evalsha:calls=4519206,usec=5476911394,usec_per_call=1211.92
                                  # Cluster
                                  cluster_enabled:0
                                  # Keyspace
                                  db0:keys=137336,expires=464,avg_ttl=16479
                                  ------ CLIENT LIST OUTPUT ------
                                  id=13183 addr=127.0.0.1:39196 fd=141 name=device-reminder.0(470397) age=33997 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13154 addr=127.0.0.1:45368 fd=130 name=zigbee.0(470296) age=34019 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13222 addr=127.0.0.1:59174 fd=192 name=mercedesme.0(470506) age=33970 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13223 addr=127.0.0.1:59186 fd=193 name=mercedesme.0(470506) age=33970 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13224 addr=127.0.0.1:59190 fd=194 name=mercedesme.0(470506) age=33970 idle=25805 flags=P db=0 sub=0 psub=9 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13155 addr=127.0.0.1:45372 fd=131 name=zigbee.0(470296) age=34019 idle=65 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13052 addr=127.0.0.1:36000 fd=40 name=influxdb.0(469983) age=34090 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13053 addr=127.0.0.1:36016 fd=41 name=influxdb.0(469983) age=34090 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13096 addr=127.0.0.1:35420 fd=84 name=daikin.0(470131) age=34059 idle=59 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=14152 addr=127.0.0.1:52682 fd=24 name=telegram.0(503220) age=16613 idle=647 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13084 addr=127.0.0.1:42226 fd=72 name=alexa2.0(470089) age=34067 idle=16 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13282 addr=127.0.0.1:59872 fd=246 name=followthesun.0(470656) age=33924 idle=15 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13085 addr=127.0.0.1:42228 fd=73 name=alexa2.0(470089) age=34067 idle=34066 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13207 addr=127.0.0.1:55612 fd=179 name=smartthings.0(470485) age=33982 idle=60 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13214 addr=127.0.0.1:53582 fd=184 name=alarm.0(470466) age=33976 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13215 addr=127.0.0.1:53598 fd=185 name=alarm.0(470466) age=33976 idle=628 flags=P db=0 sub=0 psub=14 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13240 addr=127.0.0.1:60810 fd=210 name=discovery.0(470599) age=33958 idle=33942 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13241 addr=127.0.0.1:60818 fd=211 name=discovery.0(470599) age=33958 idle=33947 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13242 addr=127.0.0.1:60824 fd=212 name=discovery.0(470599) age=33958 idle=33958 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=14173 addr=127.0.0.1:43172 fd=123 name=ecovacs-deebot.0(503417) age=16528 idle=12 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=14174 addr=127.0.0.1:43184 fd=124 name=ecovacs-deebot.0(503417) age=16528 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14175 addr=127.0.0.1:43196 fd=125 name=ecovacs-deebot.0(503417) age=16528 idle=24 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13086 addr=127.0.0.1:42242 fd=74 name=alexa2.0(470089) age=34067 idle=1214 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13031 addr=127.0.0.1:52088 fd=19 name=history.0(469942) age=34103 idle=34102 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13087 addr=127.0.0.1:42258 fd=75 name=alexa2.0(470089) age=34066 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13174 addr=127.0.0.1:58878 fd=150 name=pvforecast.0(470374) age=34007 idle=44 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13205 addr=127.0.0.1:55582 fd=177 name=sourceanalytix.0(470442) age=33983 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13206 addr=127.0.0.1:55598 fd=178 name=sourceanalytix.0(470442) age=33983 idle=2 flags=P db=0 sub=0 psub=33 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13246 addr=127.0.0.1:35880 fd=186 name=web.0(470634) age=33950 idle=557 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13247 addr=127.0.0.1:35892 fd=187 name=web.0(470634) age=33950 idle=26233 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13248 addr=127.0.0.1:35900 fd=188 name=web.0(470634) age=33950 idle=34 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13088 addr=127.0.0.1:42272 fd=76 name=alexa2.0(470089) age=34066 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13089 addr=127.0.0.1:42278 fd=77 name=alexa2.0(470089) age=34066 idle=16 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13153 addr=127.0.0.1:45358 fd=129 name=zigbee.0(470296) age=34019 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13032 addr=127.0.0.1:52104 fd=20 name=history.0(469942) age=34103 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13102 addr=127.0.0.1:35470 fd=90 name=shelly.1(470150) age=34055 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13273 addr=127.0.0.1:35616 fd=237 name=ring.0(470618) age=33934 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13301 addr=127.0.0.1:51126 fd=267 name=ford.0(470702) age=33916 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13302 addr=127.0.0.1:51136 fd=268 name=ford.0(470702) age=33916 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=285 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13274 addr=127.0.0.1:35632 fd=238 name=ring.0(470618) age=33934 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13275 addr=127.0.0.1:35634 fd=239 name=ring.0(470618) age=33934 idle=65 flags=P db=0 sub=0 psub=10 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13103 addr=127.0.0.1:35480 fd=91 name=shelly.1(470150) age=34055 idle=34054 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13104 addr=127.0.0.1:35492 fd=92 name=shelly.1(470150) age=34055 idle=34055 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13253 addr=127.0.0.1:35940 fd=217 name=ring.0(470618) age=33949 idle=33934 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13254 addr=127.0.0.1:35954 fd=218 name=ring.0(470618) age=33949 idle=33948 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13213 addr=127.0.0.1:53574 fd=183 name=alarm.0(470466) age=33976 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13135 addr=127.0.0.1:41296 fd=111 name=bosesoundtouch.0(470241) age=34035 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13136 addr=127.0.0.1:41302 fd=112 name=bosesoundtouch.0(470241) age=34035 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13137 addr=127.0.0.1:41304 fd=113 name=bosesoundtouch.0(470241) age=34035 idle=545 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13090 addr=127.0.0.1:42282 fd=78 name=net-tools.0(470107) age=34063 idle=34062 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=exists user=default
                                  id=13091 addr=127.0.0.1:42292 fd=79 name=net-tools.0(470107) age=34063 idle=34062 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13204 addr=127.0.0.1:55568 fd=176 name=sourceanalytix.0(470442) age=33983 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13092 addr=127.0.0.1:42306 fd=80 name=net-tools.0(470107) age=34063 idle=34063 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13025 addr=127.0.0.1:52036 fd=13 name=admin.0(469915) age=34107 idle=34107 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13138 addr=127.0.0.1:36250 fd=114 name=samsung.0(470260) age=34030 idle=34029 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13139 addr=127.0.0.1:36258 fd=115 name=samsung.0(470260) age=34030 idle=34030 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13140 addr=127.0.0.1:36270 fd=116 name=samsung.0(470260) age=34030 idle=34030 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13316 addr=127.0.0.1:48924 fd=253 name=info.0(470787) age=33904 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13317 addr=127.0.0.1:48930 fd=254 name=info.0(470787) age=33904 idle=33904 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13027 addr=127.0.0.1:52052 fd=15 name=admin.0(469915) age=34107 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13028 addr=127.0.0.1:52056 fd=16 name=admin.0(469915) age=34107 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13029 addr=127.0.0.1:52072 fd=17 name=admin.0(469915) age=34107 idle=2 flags=P db=0 sub=0 psub=27 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13300 addr=127.0.0.1:51116 fd=266 name=ford.0(470702) age=33917 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=4 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                  id=13030 addr=127.0.0.1:52084 fd=18 name=history.0(469942) age=34103 idle=34102 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20568 events=r cmd=evalsha user=default
                                  id=13026 addr=127.0.0.1:52046 fd=14 name=admin.0(469915) age=34107 idle=33 flags=P db=0 sub=0 psub=8 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13099 addr=127.0.0.1:35442 fd=87 name=daikin.0(470131) age=34058 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13252 addr=127.0.0.1:35938 fd=216 name=ring.0(470618) age=33949 idle=65 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13100 addr=127.0.0.1:35454 fd=88 name=daikin.0(470131) age=34058 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14059 addr=127.0.0.1:38274 fd=33 name=javascript.0(499664) age=18386 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                  id=14060 addr=127.0.0.1:38288 fd=34 name=javascript.0(499664) age=18386 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14061 addr=127.0.0.1:38292 fd=35 name=javascript.0(499664) age=18386 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13286 addr=127.0.0.1:51006 fd=250 name=virtualpowermeter.0(470758) age=33921 idle=33908 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13287 addr=127.0.0.1:51010 fd=251 name=virtualpowermeter.0(470758) age=33921 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13101 addr=127.0.0.1:35456 fd=89 name=daikin.0(470131) age=34058 idle=59 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13121 addr=127.0.0.1:34590 fd=97 name=mqtt.1(470205) age=34043 idle=34043 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13122 addr=127.0.0.1:34596 fd=98 name=mqtt.1(470205) age=34043 idle=34043 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13075 addr=127.0.0.1:58572 fd=63 name=mqtt.0(470053) age=34074 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13076 addr=127.0.0.1:58582 fd=64 name=mqtt.0(470053) age=34074 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13193 addr=127.0.0.1:55464 fd=165 name=sourceanalytix.0(470442) age=33990 idle=33983 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13194 addr=127.0.0.1:55480 fd=166 name=sourceanalytix.0(470442) age=33990 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13077 addr=127.0.0.1:58598 fd=65 name=mqtt.0(470053) age=34074 idle=2 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13057 addr=127.0.0.1:36058 fd=45 name=tuya.0(470002) age=34085 idle=4 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13058 addr=127.0.0.1:36066 fd=46 name=tuya.0(470002) age=34085 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13059 addr=127.0.0.1:36080 fd=47 name=tuya.0(470002) age=34085 idle=56 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13171 addr=127.0.0.1:58850 fd=147 name=iot.0(470354) age=34009 idle=15 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13202 addr=127.0.0.1:55548 fd=174 name=yahka.0(470426) age=33984 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13203 addr=127.0.0.1:55560 fd=175 name=yahka.0(470426) age=33984 idle=1 flags=P db=0 sub=0 psub=43 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13315 addr=127.0.0.1:48918 fd=252 name=info.0(470787) age=33904 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13172 addr=127.0.0.1:58856 fd=148 name=iot.0(470354) age=34009 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13173 addr=127.0.0.1:58866 fd=149 name=iot.0(470354) age=34009 idle=4312 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13020 addr=127.0.0.1:51992 fd=8 name=host.BU02SMART02-iobroker age=34110 idle=29 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20536 events=r cmd=evalsha user=default
                                  id=13120 addr=127.0.0.1:34578 fd=96 name=mqtt.1(470205) age=34043 idle=1546 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13021 addr=127.0.0.1:52008 fd=9 name=host.BU02SMART02-iobroker age=34109 idle=6 flags=P db=0 sub=2 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13168 addr=127.0.0.1:58826 fd=144 name=iot.0(470354) age=34011 idle=4312 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13169 addr=127.0.0.1:58834 fd=145 name=iot.0(470354) age=34011 idle=34009 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13195 addr=127.0.0.1:55482 fd=167 name=linkeddevices.0(470413) age=33988 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13196 addr=127.0.0.1:55486 fd=168 name=linkeddevices.0(470413) age=33988 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13197 addr=127.0.0.1:55498 fd=169 name=linkeddevices.0(470413) age=33988 idle=1 flags=P db=0 sub=0 psub=51 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13192 addr=127.0.0.1:55456 fd=164 name=sourceanalytix.0(470442) age=33990 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13170 addr=127.0.0.1:58846 fd=146 name=iot.0(470354) age=34011 idle=34 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13201 addr=127.0.0.1:55536 fd=173 name=yahka.0(470426) age=33985 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13022 addr=127.0.0.1:52016 fd=10 name=host.BU02SMART02-iobroker age=34109 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13129 addr=127.0.0.1:41266 fd=105 name=ems-esp.0(470223) age=34039 idle=3 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13130 addr=127.0.0.1:41270 fd=106 name=ems-esp.0(470223) age=34039 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13131 addr=127.0.0.1:41272 fd=107 name=ems-esp.0(470223) age=34039 idle=6 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13259 addr=127.0.0.1:36002 fd=223 name=followthesun.0(470656) age=33944 idle=33924 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13260 addr=127.0.0.1:36004 fd=224 name=followthesun.0(470656) age=33944 idle=33944 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13105 addr=127.0.0.1:35494 fd=93 name=shelly.1(470150) age=34054 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                  id=13117 addr=127.0.0.1:34552 fd=69 name=homeconnect.0(470186) age=34047 idle=10 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13118 addr=127.0.0.1:34556 fd=70 name=homeconnect.0(470186) age=34047 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13119 addr=127.0.0.1:34572 fd=71 name=homeconnect.0(470186) age=34047 idle=28323 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13277 addr=127.0.0.1:35660 fd=241 name=vis-inventwo.0(470717) age=33933 idle=33911 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13278 addr=127.0.0.1:35674 fd=242 name=vis-inventwo.0(470717) age=33933 idle=33933 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13106 addr=127.0.0.1:35500 fd=94 name=shelly.1(470150) age=34054 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13107 addr=127.0.0.1:35516 fd=95 name=shelly.1(470150) age=34054 idle=1 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13156 addr=127.0.0.1:45378 fd=132 name=shelly.0(470312) age=34019 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                  id=13270 addr=127.0.0.1:35588 fd=234 name=web.0(470634) age=33935 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13271 addr=127.0.0.1:35592 fd=235 name=web.0(470634) age=33935 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13272 addr=127.0.0.1:35600 fd=236 name=web.0(470634) age=33935 idle=0 flags=P db=0 sub=0 psub=400 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14170 addr=127.0.0.1:43140 fd=120 name=ecovacs-deebot.0(503417) age=16528 idle=24 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=14171 addr=127.0.0.1:43156 fd=121 name=ecovacs-deebot.0(503417) age=16528 idle=16528 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14172 addr=127.0.0.1:43170 fd=122 name=ecovacs-deebot.0(503417) age=16528 idle=16528 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13255 addr=127.0.0.1:35964 fd=219 name=discovery.0(470599) age=33947 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13256 addr=127.0.0.1:35970 fd=220 name=discovery.0(470599) age=33947 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13257 addr=127.0.0.1:35982 fd=221 name=discovery.0(470599) age=33947 idle=33947 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13157 addr=127.0.0.1:45388 fd=133 name=shelly.0(470312) age=34019 idle=34016 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13158 addr=127.0.0.1:45392 fd=134 name=shelly.0(470312) age=34019 idle=34019 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13023 addr=127.0.0.1:52018 fd=11 name=host.BU02SMART02-iobroker age=34109 idle=2 flags=P db=0 sub=2 psub=8 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13073 addr=127.0.0.1:58550 fd=61 name=mqtt.0(470053) age=34074 idle=34074 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13226 addr=127.0.0.1:59206 fd=196 name=slideshow.0(470538) age=33969 idle=33960 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13258 addr=127.0.0.1:35988 fd=222 name=followthesun.0(470656) age=33944 idle=76 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13227 addr=127.0.0.1:59216 fd=197 name=slideshow.0(470538) age=33969 idle=33969 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13150 addr=127.0.0.1:45318 fd=126 name=zigbee.0(470296) age=34020 idle=65 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13276 addr=127.0.0.1:35650 fd=240 name=vis-inventwo.0(470717) age=33933 idle=33910 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13151 addr=127.0.0.1:45332 fd=127 name=zigbee.0(470296) age=34020 idle=34019 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13285 addr=127.0.0.1:59886 fd=249 name=virtualpowermeter.0(470758) age=33922 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13152 addr=127.0.0.1:45348 fd=128 name=zigbee.0(470296) age=34020 idle=34020 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13074 addr=127.0.0.1:58566 fd=62 name=mqtt.0(470053) age=34074 idle=34074 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13069 addr=127.0.0.1:58516 fd=57 name=device-watcher.1(470034) age=34077 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13070 addr=127.0.0.1:58522 fd=58 name=device-watcher.1(470034) age=34077 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13177 addr=127.0.0.1:58912 fd=155 name=pvforecast.0(470374) age=34003 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13178 addr=127.0.0.1:58914 fd=156 name=pvforecast.0(470374) age=34003 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13179 addr=127.0.0.1:58916 fd=157 name=pvforecast.0(470374) age=34003 idle=44 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13199 addr=127.0.0.1:55514 fd=171 name=alarm.0(470466) age=33985 idle=33976 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13200 addr=127.0.0.1:55530 fd=172 name=alarm.0(470466) age=33985 idle=33985 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13071 addr=127.0.0.1:58528 fd=59 name=device-watcher.1(470034) age=34077 idle=2 flags=P db=0 sub=0 psub=178 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13024 addr=127.0.0.1:52020 fd=12 name=admin.0(469915) age=34107 idle=685 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13072 addr=127.0.0.1:58536 fd=60 name=mqtt.0(470053) age=34074 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13297 addr=127.0.0.1:51100 fd=263 name=info.0(470787) age=33917 idle=1497 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13298 addr=127.0.0.1:51102 fd=264 name=info.0(470787) age=33917 idle=33904 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13299 addr=127.0.0.1:51112 fd=265 name=info.0(470787) age=33917 idle=33917 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13048 addr=127.0.0.1:35962 fd=36 name=influxdb.0(469983) age=34090 idle=34088 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20568 events=r cmd=evalsha user=default
                                  id=13049 addr=127.0.0.1:35972 fd=37 name=influxdb.0(469983) age=34090 idle=34089 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13050 addr=127.0.0.1:35974 fd=38 name=influxdb.0(469983) age=34090 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13220 addr=127.0.0.1:53636 fd=190 name=smartthings.0(470485) age=33973 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13221 addr=127.0.0.1:53642 fd=191 name=smartthings.0(470485) age=33973 idle=60 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13229 addr=127.0.0.1:59236 fd=199 name=energiefluss.0(470561) age=33966 idle=33956 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13230 addr=127.0.0.1:59240 fd=200 name=energiefluss.0(470561) age=33966 idle=33966 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13186 addr=127.0.0.1:39218 fd=158 name=linkeddevices.0(470413) age=33992 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13280 addr=127.0.0.1:59850 fd=244 name=hass-mqtt.0(470737) age=33927 idle=33910 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13281 addr=127.0.0.1:59866 fd=245 name=hass-mqtt.0(470737) age=33927 idle=33927 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13187 addr=127.0.0.1:39228 fd=159 name=linkeddevices.0(470413) age=33992 idle=33988 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13188 addr=127.0.0.1:39232 fd=160 name=linkeddevices.0(470413) age=33992 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14155 addr=127.0.0.1:52694 fd=27 name=telegram.0(503220) age=16612 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=14156 addr=127.0.0.1:52698 fd=28 name=telegram.0(503220) age=16612 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14157 addr=127.0.0.1:52708 fd=29 name=telegram.0(503220) age=16612 idle=5 flags=P db=0 sub=0 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13033 addr=127.0.0.1:52118 fd=21 name=history.0(469942) age=34103 idle=4 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13034 addr=127.0.0.1:52128 fd=22 name=history.0(469942) age=34103 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14056 addr=127.0.0.1:38240 fd=30 name=javascript.0(499664) age=18386 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                  id=14057 addr=127.0.0.1:38252 fd=31 name=javascript.0(499664) age=18386 idle=18384 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14058 addr=127.0.0.1:38262 fd=32 name=javascript.0(499664) age=18386 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13061 addr=127.0.0.1:36104 fd=49 name=ping.0(470017) age=34083 idle=34082 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13141 addr=127.0.0.1:36276 fd=117 name=samsung.0(470260) age=34030 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13142 addr=127.0.0.1:36292 fd=118 name=samsung.0(470260) age=34030 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13211 addr=127.0.0.1:53552 fd=154 name=mercedesme.0(470506) age=33978 idle=33970 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13212 addr=127.0.0.1:53564 fd=182 name=mercedesme.0(470506) age=33978 idle=33978 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13143 addr=127.0.0.1:36298 fd=119 name=samsung.0(470260) age=34030 idle=34029 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13198 addr=127.0.0.1:55504 fd=170 name=alarm.0(470466) age=33985 idle=883 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13062 addr=127.0.0.1:36118 fd=50 name=ping.0(470017) age=34083 idle=34083 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13054 addr=127.0.0.1:36028 fd=42 name=tuya.0(470002) age=34086 idle=56 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13225 addr=127.0.0.1:59204 fd=195 name=slideshow.0(470538) age=33970 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13055 addr=127.0.0.1:36044 fd=43 name=tuya.0(470002) age=34086 idle=34085 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13056 addr=127.0.0.1:36056 fd=44 name=tuya.0(470002) age=34086 idle=34086 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13228 addr=127.0.0.1:59222 fd=198 name=energiefluss.0(470561) age=33966 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                  id=13235 addr=127.0.0.1:59300 fd=205 name=energiefluss.1(470579) age=33962 idle=33949 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13238 addr=127.0.0.1:60792 fd=208 name=slideshow.0(470538) age=33960 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13239 addr=127.0.0.1:60800 fd=209 name=slideshow.0(470538) age=33960 idle=33957 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13267 addr=127.0.0.1:35562 fd=231 name=ford.0(470702) age=33937 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                  id=13268 addr=127.0.0.1:35578 fd=232 name=ford.0(470702) age=33937 idle=33917 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13269 addr=127.0.0.1:35580 fd=233 name=ford.0(470702) age=33937 idle=33937 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13236 addr=127.0.0.1:59312 fd=206 name=energiefluss.1(470579) age=33962 idle=33962 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13219 addr=127.0.0.1:53628 fd=189 name=smartthings.0(470485) age=33973 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13133 addr=127.0.0.1:41282 fd=109 name=bosesoundtouch.0(470241) age=34035 idle=34035 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13134 addr=127.0.0.1:41290 fd=110 name=bosesoundtouch.0(470241) age=34035 idle=34035 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13060 addr=127.0.0.1:36090 fd=48 name=ping.0(470017) age=34083 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13066 addr=127.0.0.1:58484 fd=54 name=device-watcher.1(470034) age=34079 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13067 addr=127.0.0.1:58496 fd=55 name=device-watcher.1(470034) age=34079 idle=34077 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13189 addr=127.0.0.1:55424 fd=161 name=yahka.0(470426) age=33991 idle=5366 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13190 addr=127.0.0.1:55432 fd=162 name=yahka.0(470426) age=33991 idle=33985 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13191 addr=127.0.0.1:55444 fd=163 name=yahka.0(470426) age=33991 idle=33991 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13127 addr=127.0.0.1:41248 fd=103 name=ems-esp.0(470223) age=34039 idle=34039 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13303 addr=127.0.0.1:48822 fd=269 name=vis-inventwo.0(470717) age=33911 idle=10 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13304 addr=127.0.0.1:48826 fd=270 name=vis-inventwo.0(470717) age=33911 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13305 addr=127.0.0.1:48834 fd=271 name=vis-inventwo.0(470717) age=33911 idle=33910 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13306 addr=127.0.0.1:48840 fd=272 name=hass-mqtt.0(470737) age=33910 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13307 addr=127.0.0.1:48848 fd=273 name=hass-mqtt.0(470737) age=33910 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13308 addr=127.0.0.1:48852 fd=274 name=hass-mqtt.0(470737) age=33910 idle=33908 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13210 addr=127.0.0.1:53548 fd=153 name=mercedesme.0(470506) age=33978 idle=1565 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13160 addr=127.0.0.1:45396 fd=136 name=shelly.0(470312) age=34016 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13244 addr=127.0.0.1:60828 fd=214 name=energiefluss.0(470561) age=33956 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13245 addr=127.0.0.1:60844 fd=215 name=energiefluss.0(470561) age=33956 idle=0 flags=P db=0 sub=0 psub=13 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13161 addr=127.0.0.1:45408 fd=137 name=shelly.0(470312) age=34016 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13128 addr=127.0.0.1:41264 fd=104 name=ems-esp.0(470223) age=34039 idle=34039 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13068 addr=127.0.0.1:58508 fd=56 name=device-watcher.1(470034) age=34079 idle=34 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13114 addr=127.0.0.1:34524 fd=66 name=homeconnect.0(470186) age=34047 idle=28323 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13115 addr=127.0.0.1:34536 fd=67 name=homeconnect.0(470186) age=34047 idle=34047 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13116 addr=127.0.0.1:34546 fd=68 name=homeconnect.0(470186) age=34047 idle=34047 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13279 addr=127.0.0.1:59838 fd=243 name=hass-mqtt.0(470737) age=33928 idle=33898 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20496 events=r cmd=mget user=default
                                  id=13310 addr=127.0.0.1:48866 fd=276 name=virtualpowermeter.0(470758) age=33908 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13311 addr=127.0.0.1:48872 fd=277 name=virtualpowermeter.0(470758) age=33908 idle=5 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13250 addr=127.0.0.1:35926 fd=202 name=energiefluss.1(470579) age=33949 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13251 addr=127.0.0.1:35932 fd=203 name=energiefluss.1(470579) age=33949 idle=0 flags=P db=0 sub=0 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13237 addr=127.0.0.1:60782 fd=207 name=slideshow.0(470538) age=33960 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13132 addr=127.0.0.1:41278 fd=108 name=bosesoundtouch.0(470241) age=34035 idle=545 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13181 addr=127.0.0.1:39176 fd=139 name=device-reminder.0(470397) age=34001 idle=33997 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13182 addr=127.0.0.1:39180 fd=140 name=device-reminder.0(470397) age=34001 idle=34001 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13035 addr=127.0.0.1:52136 fd=23 name=history.0(469942) age=34103 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13063 addr=127.0.0.1:36126 fd=51 name=ping.0(470017) age=34082 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13126 addr=127.0.0.1:41246 fd=102 name=ems-esp.0(470223) age=34039 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13159 addr=127.0.0.1:45394 fd=135 name=shelly.0(470312) age=34016 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                  id=13064 addr=127.0.0.1:36132 fd=52 name=ping.0(470017) age=34082 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13093 addr=127.0.0.1:42316 fd=81 name=net-tools.0(470107) age=34062 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13097 addr=127.0.0.1:35428 fd=85 name=daikin.0(470131) age=34059 idle=34058 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13243 addr=127.0.0.1:60826 fd=213 name=energiefluss.0(470561) age=33956 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                  id=13184 addr=127.0.0.1:39202 fd=142 name=device-reminder.0(470397) age=33997 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13185 addr=127.0.0.1:39214 fd=143 name=device-reminder.0(470397) age=33997 idle=33997 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13123 addr=127.0.0.1:34602 fd=99 name=mqtt.1(470205) age=34043 idle=6 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13124 addr=127.0.0.1:34614 fd=100 name=mqtt.1(470205) age=34043 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13125 addr=127.0.0.1:34620 fd=101 name=mqtt.1(470205) age=34043 idle=1546 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14153 addr=127.0.0.1:52684 fd=25 name=telegram.0(503220) age=16613 idle=16612 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=14154 addr=127.0.0.1:52688 fd=26 name=telegram.0(503220) age=16613 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13249 addr=127.0.0.1:35916 fd=201 name=energiefluss.1(470579) age=33949 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default
                                  id=13098 addr=127.0.0.1:35432 fd=86 name=daikin.0(470131) age=34059 idle=34059 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13094 addr=127.0.0.1:42320 fd=82 name=net-tools.0(470107) age=34062 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13309 addr=127.0.0.1:48856 fd=275 name=virtualpowermeter.0(470758) age=33908 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  id=13234 addr=127.0.0.1:59292 fd=204 name=energiefluss.1(470579) age=33962 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default
                                  id=13283 addr=127.0.0.1:59880 fd=247 name=followthesun.0(470656) age=33924 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13284 addr=127.0.0.1:59884 fd=248 name=followthesun.0(470656) age=33924 idle=33917 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13208 addr=127.0.0.1:55620 fd=180 name=smartthings.0(470485) age=33982 idle=33973 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13209 addr=127.0.0.1:55622 fd=181 name=smartthings.0(470485) age=33982 idle=33982 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13095 addr=127.0.0.1:42330 fd=83 name=net-tools.0(470107) age=34062 idle=34062 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13180 addr=127.0.0.1:58924 fd=138 name=device-reminder.0(470397) age=34002 idle=33993 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default
                                  id=13175 addr=127.0.0.1:58894 fd=151 name=pvforecast.0(470374) age=34007 idle=34003 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default
                                  id=13176 addr=127.0.0.1:58908 fd=152 name=pvforecast.0(470374) age=34007 idle=34007 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13065 addr=127.0.0.1:36146 fd=53 name=ping.0(470017) age=34082 idle=34082 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default
                                  id=13051 addr=127.0.0.1:35986 fd=39 name=influxdb.0(469983) age=34090 idle=9 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default
                                  ------ REGISTERS ------
                                  535888:C 19 Apr 2024 21:30:47.271 #
                                  RAX:0000000000000076 RBX:00007ffc3041ee00
                                  RCX:00007ff1781ef1e1 RDX:00007ff15d50b514
                                  RDI:0000000000000063 RSI:00007ff1781ef1e0
                                  RBP:00007ff1781ef1c0 RSP:00007ffc3041ede0
                                  R8 :00007ff15d509b43 R9 :00007ff15d509b63
                                  R10:00007ff1781ef212 R11:00007ff15d509b97
                                  R12:0000000065766963 R13:0000000000000020
                                  R14:0000000000000000 R15:00007ff15d509b99
                                  RIP:0000562658427528 EFL:0000000000010246
                                  CSGSFS:002b000000000033
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edef) -> 00002b930000085b
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edee) -> 00000076000009df
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041eded) -> 0000236e00006365
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edec) -> 00000ea500001126
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edeb) -> 0000531800000a34
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edea) -> 000010ed00000e2e
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede9) -> 00007f3f00003d25
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede8) -> 00004e90000012c4
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede7) -> 0000029a00000965
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede6) -> 000000a800000242
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede5) -> 0000002e00001599
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede4) -> 0000068800001aed
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede3) -> 00007ff172a30f8b
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede2) -> 00007ff1714583a0
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede1) -> 0000000000000030
                                  535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede0) -> 0000000000000000
                                  ------ MODULES INFO OUTPUT ------
                                    @m-schalk sagte in Sporadische Neustarts des iobroker:
                                    @ilovegym wo liegt das?
                                    https://www.digitalocean.com/community/tutorials/how-to-find-redis-logs-on-ubuntu
                                    m.schalk
                                    @ilovegym und @Thomas-Braun so, ich denke es lag an redis und der Einstellung in der Redis config.
                                    ALT:
                                    save 900 1
                                    save 300 10
                                    save 60 10000
                                    NEU:
                                    save 900 1
                                    #save 300 10
                                    #save 60 10000
                                    Diskbelastung ist merklich reduziert und auch keine Reboots mehr zu sehen.
                                    • M m.schalk
                                      ALT:
                                      save 900 1
                                      save 300 10
                                      save 60 10000
                                      NEU:
                                      save 900 1
                                      #save 300 10
                                      #save 60 10000
                                      @m-schalk
                                      Damit macht Redis weniger snapshots und verbraucht weniger Ressourcen.
