Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
@skb Alles klar. Im Java-Adapter. Erledigt. LÄUFT!
Danke!
und was bedeutet das?
No overload matches this call. The last overload gave the following error. Type 'boolean' has no properties in common with type 'Partial<StateCommon>'.(2769) javascript.d.ts(1527, 11): The last overload is declared here.
habe auch den Speedtest Adapter installiert, über ssh werden auch korrekte Ergebnisse geliefert.
Dann habe ich das js Skript importiert, Pfad angepasst und bekomme folgende Fehlermeldung:2024-01-17 22:23:50.140 - error: javascript.0 (32246) script.js.common.Speedtest: SyntaxError: Unexpected end of JSON input 2024-01-17 22:23:50.141 - error: javascript.0 (32246) at JSON.parse () 2024-01-17 22:23:50.142 - error: javascript.0 (32246) at generiere_array (script.js.common.Speedtest:181:18) 2024-01-17 22:23:50.142 - error: javascript.0 (32246) at script.js.common.Speedtest:229:28 2024-01-17 22:23:50.142 - error: javascript.0 (32246) at ChildProcess.exithandler (node:child_process:414:7) 2024-01-17 22:23:50.143 - error: javascript.0 (32246) at ChildProcess.emit (node:events:517:28) 2024-01-17 22:23:50.143 - error: javascript.0 (32246) at ChildProcess.emit (node:domain:489:12) 2024-01-17 22:23:50.143 - error: javascript.0 (32246) at maybeClose (node:internal/child_process:1098:16) 2024-01-17 22:23:50.143 - error: javascript.0 (32246) at Process.ChildProcess._handle.onexit (node:internal/child_process:303:5)
Kann mir da jemand helfen?
pi@iobroker:~ $ sudo apt update OK:1 http://archive.raspberrypi.org/debian buster InRelease Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB] OK:3 https://repos.influxdata.com/debian stable InRelease OK:4 https://packages.grafana.com/oss/deb stable InRelease OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease Ign:6 https://packagecloud.io/ookla/speedtest-cli/raspbian buster InRelease Fehl:7 https://packagecloud.io/ookla/speedtest-cli/raspbian buster Release 404 Not Found [IP: 2600:1f1c:2e5:6900:e12:7a5d:4cf3:3662 443] Paketlisten werden gelesen... Fertig E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/raspbian buster Release« enthält keine Release-Datei. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). pi@iobroker:~ $ apt policy speedtest-cli speedtest-cli: Installiert: 2.0.2-1+deb10u2 Installationskandidat: 2.0.2-1+deb10u2 Versionstabelle: *** 2.0.2-1+deb10u2 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages 100 /var/lib/dpkg/status
@cyqx13
Da haben wir den Fehler auch schon.
Falsches Paket und dein Betriebssystem ist auch tot...Installier da was lebendiges. Debian 12 'Bookworm' bzw. Raspberry OS 12 'Bookworm'. In der 64Bit Lite-Version.
Funktionierend sähe das so aus:
echad@chet:~ $ apt policy speedtest* speedtest: Installed: 1.2.0.84-1.ea6b6773cf Candidate: 1.2.0.84-1.ea6b6773cf Version table: *** 1.2.0.84-1.ea6b6773cf 500 500 https://packagecloud.io/ookla/speedtest-cli/debian trixie/main arm64 Packages 100 /var/lib/dpkg/status speedtest-cli: Installed: (none) Candidate: 2.1.3-2 Version table: 2.1.3-2 500 500 http://deb.debian.org/debian testing/main arm64 Packages 500 http://deb.debian.org/debian testing/main armhf Packages
ok danke, Betriebssystem mache ich mal die Tage, steht auf meiner ToDo Liste, aber wieso falsches Paket? Müsste doch trotzdem zu installieren sein?
Bei sudo apt install speedtest
funktioniert auch nur speedtest-cli -
@cyqx13 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
Weil das Paket 'speedtest' heißt (und aus dem extra dafür angelegten Repo kommt) und nicht 'speedtest-cli'.
Deswegen steht auch im ersten Posting:
Zunächst den falschen Kram deinstallieren:sudo apt remove speedtest-cli speedtest
funktioniert auch nur speedtest-cliLogisch. Das richtige Repo wird für dein totes OS ja nicht mehr angeboten. Daher: OS frisch neuinstallieren.
Hallo, seit einigen Tagen stimmen die Werte vom Speedtest nicht mehr.
Hatte immer 400 Down- und 200 Upload, nun nur noch zw. 80 und 90.
Auch der Aufruf im Cli bringt nur noch diese niedrigen Werte. Was mir aber
aufgefallen ist, ein Error bei Aufruf von speedtest.jack@ioBroker:~$ speedtest Speedtest by Ookla [error] Error: [0] Cannot read from socket: Server: ITbyHF / Alec H. - Dusseldorf (id: 51708) ISP: Deutsche Glasfaser Idle Latency: 4.43 ms (jitter: 2.24ms, low: 3.06ms, high: 7.70ms) Download: 91.01 Mbps (data used: 46.7 MB) 63.97 ms (jitter: 23.70ms, low: 9.63ms, high: 434.04ms) Upload: 92.77 Mbps (data used: 90.1 MB) 12.29 ms (jitter: 2.20ms, low: 10.01ms, high: 48.52ms) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/e0acc694-c4a3-41b6-88b2-35a3d5dd7086
@nashra sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
hast du mal einen anderen Server versucht?
Bei mir passt alles. -
@negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
Bei mir passt alles.Ja habe ich. Wenn ich im Browser Ookla direkt aufrufe und starte, dann kommen die richtigen Werte.
Komme nicht dahinter warum das auf einmal so ist. -
Erledigt, Fehler gefunden bzw. hätte ich direkt nachsehen sollen. Switch im Netzwerk wars
Und der Error beim Aufruf im CLI ist auch weg.
