  4. [geklärt]Sonoff-Adapter plötzlich gelb
15 Beiträge 7 Kommentatoren 1.7k Aufrufe 6 Beobachtet
  • docadamsD docadams
    @djmarc75
    Oh-ha.... Ich weiß, System ist hoffnungslos veraltet. Die Bemühungen dienen schon, es wieder auf Vordermann zu bringen. Aber es gibt öfters solche Rückschläge und Verzögerungen.... Und ich kann es leider nicht kontinuierlich durchziehen.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker4
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 4.19.75-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     17:06:37 up 5 min,  1 user,  load average: 6.83, 4.45, 1.90
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2024-03-21 17:06:38 CET
               Universal time: Thu 2024-03-21 16:06:38 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:           3.9G        1.7G        1.7G         24M        502M        2.5G
    Swap:           99M          0B         99M
    Total:         4.0G        1.7G        1.8G
             3906 M total memory
             1676 M used memory
             1311 M active memory
              711 M inactive memory
             1727 M free memory
               63 M buffer memory
              439 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT           LOAD   ACTIVE SUB    DESCRIPTION
    * owftpd.service loaded failed failed Anonymous FTP server for 1-wire access
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       15G  5.9G  8.1G  43% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     2.0G   25M  1.9G   2% /run
    tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
    tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
    tmpfs          tmpfs     4.0M   96K  4.0M   3% /home/pi/ramdisk
    /dev/sda1      ext4       15G  7.8G  6.1G  56% /media/usbstick2
    /dev/sdb1      fuseblk    60G   46G   15G  77% /media/pishrink
    /dev/mmcblk0p1 vfat      253M   52M  201M  21% /boot
    tmpfs          tmpfs     391M     0  391M   0% /run/user/1000
    [Thu Mar 21 17:01:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:41:9D:C4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Thu Mar 21 17:01:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Mar 21 17:01:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Mar 21 17:01:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Thu Mar 21 17:01:38 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    TARGET             SOURCE         FSTYPE    OPTIONS
    /                  /dev/mmcblk0p2 ext4      rw,noatime
    |-/run/owfs        OWFS           fuse.OWFS rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/media/usbstick2 /dev/sda1      ext4      rw,relatime
    |-/media/pishrink  /dev/sdb1      fuseblk   rw,nosuid,nodev,noexec,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096
    `-/boot            /dev/mmcblk0p1 vfat      rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    668M    /var/
    413M    /var/cache
    407M    /var/cache/apt
    348M    /var/cache/apt/archives
    140M    /var/lib
    Archived and active journals take up 24.0M in the file system.
    /opt/iobroker/backups:
    435M    /opt/iobroker/backups/
    10M     /opt/iobroker/backups/skripte
    5.5M    /opt/iobroker/backups/skripte/AllgemeinProgramme
    2.5M    /opt/iobroker/backups/skripte/VolkersÜbungen
    2.5M    /opt/iobroker/backups/skripte/AllgemeinProgramme/5_SOLAR
    /opt/iobroker/iobroker-data:
    657M    /opt/iobroker/iobroker-data/
    401M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    65M     /opt/iobroker/iobroker-data/files/javascript.admin
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    36M     /opt/iobroker/iobroker-data/objects.json.bak
    26M     /opt/iobroker/iobroker-data/objects.json.old
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191391-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v12.18.2
    /usr/bin/node           v12.18.2
    /usr/bin/npm            6.14.5
    /usr/bin/npx            6.14.5
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.18.2-1nodesource1
      Candidate: 12.22.12-deb-1nodesource1
      Version table:
         12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
     *** 12.18.2-1nodesource1 100
         10.21.0~dfsg-1~deb10u1+rpi1 500
    No problems detected
    Errors in npm tree:
    npm ERR! extraneous: @serialport/binding-mock /opt/iobroker/node_modules/@serialport/binding-mock
    npm ERR! error in /opt/iobroker/node_modules/@serialport/binding-mock: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/@serialport/binding-mock/package.json'
    npm ERR! extraneous: serialport /opt/iobroker/node_modules/serialport
    npm ERR! error in /opt/iobroker/node_modules/serialport: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/serialport/package.json'
    npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
    npm ERR! extraneous: fsevents@2.1.2 /opt/iobroker/node_modules/fsevents
    npm ERR! extraneous: iobroker.wetty@0.1.1 /opt/iobroker/node_modules/iobroker.wetty
    npm ERR! extraneous: soef@0.4.15 /opt/iobroker/node_modules/soef
    npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
    npm ERR! missing: @serialport/bindings-interface@1.2.2, required by @serialport/bindings-cpp@10.8.0
    npm ERR! missing: @serialport/bindings-interface@1.2.2, required by @serialport/stream@10.5.0
    npm ERR! missing: @serialport/bindings-interface@^1.2.1, required by @serialport/binding-mock@10.2.2
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: file
    States  type: file
    Core adapters versions
    js-controller:  3.2.16
    admin:          4.2.1
    javascript:     5.1.3
    Adapters from github:   6
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker4                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker4                                -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker4                                - disabled
      system.adapter.awattar.0                : awattar               : iobroker4                                -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker4                                -  enabled
      system.adapter.bluelink.0               : bluelink              : iobroker4                                - disabled
      system.adapter.bydbatt.0                : bydbatt               : iobroker4                                - disabled
    + system.adapter.bydhvs.0                 : bydhvs                : iobroker4                                -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker4                                -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker4                                -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker4                                -  enabled, port: 8090
      system.adapter.devices.0                : devices               : iobroker4                                - disabled
    + system.adapter.discovery.0              : discovery             : iobroker4                                -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker4                                -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker4                                -  enabled
      system.adapter.flot.0                   : flot                  : iobroker4                                - disabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker4                                -  enabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker4                                - disabled
    + system.adapter.fronius.0                : fronius               : iobroker4                                -  enabled
    + system.adapter.fronius.1                : fronius               : iobroker4                                -  enabled
      system.adapter.go-e-charger.0           : go-e-charger          : iobroker4                                - disabled
    + system.adapter.go-e.0                   : go-e                  : iobroker4                                -  enabled
    + system.adapter.history.0                : history               : iobroker4                                -  enabled
      system.adapter.ical.0                   : ical                  : iobroker4                                -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker4                                - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker4                                - disabled
    + system.adapter.info.0                   : info                  : iobroker4                                -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker4                                -  enabled
      system.adapter.material.0               : material              : iobroker4                                - disabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker4                                - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker4                                -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker4                                -  enabled, port: 1881, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker4                                -  enabled
    + system.adapter.owfs.0                   : owfs                  : iobroker4                                -  enabled, port: 4304
    + system.adapter.parser.0                 : parser                : iobroker4                                -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker4                                -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker4                                -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker4                                -  enabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker4                                -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker4                                -  enabled, port: 1888, bind: 192.168.178.100
    + system.adapter.shelly.1                 : shelly                : iobroker4                                -  enabled, port: 1883, bind: 192.168.178.100
    + system.adapter.simple-api.0             : simple-api            : iobroker4                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker4                                -  enabled, port: 1888, bind: 192.168.178.100
      system.adapter.sql.0                    : sql                   : iobroker4                                - disabled, port: 0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker4                                -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker4                                -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker4                                -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker4                                -  enabled
    + system.adapter.tronity.0                : tronity               : iobroker4                                -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker4                                - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker4                                - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker4                                - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker4                                - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker4                                - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker4                                -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker4                                - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker4                                - disabled
      system.adapter.vis-material.0           : vis-material          : iobroker4                                - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker4                                - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker4                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker4                                - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker4                                - disabled
      system.adapter.vis.0                    : vis                   : iobroker4                                -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker4                                -  enabled
    + system.adapter.web.0                    : web                   : iobroker4                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wetty.0                  : wetty                 : iobroker4                                - disabled, port: 8089, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    stable      : http://download.iobroker.net/sources-dist.json
    beta        : http://download.iobroker.net/sources-dist-latest.json
    Active repo: stable
    Installed ioBroker-Instances
    Used repository: stable
    hash changed or no sources cached => force download of new sources
    Cannot get any information of "_repoInfo". Ignored.
    update done
    Adapter    "admin"         : 6.13.16  , installed 4.2.1 [Updateable]
    Adapter    "alexa2"        : 3.26.4   , installed 3.9.3 [Updateable]
    Adapter    "alias-manager" : 1.2.6    , installed 1.2.6
    Adapter    "awattar"       : 1.0.6    , installed 1.0.6
    Adapter    "backitup"      : 2.10.11  , installed 2.1.13 [Updateable]
    Adapter    "bluelink"      : 2.3.6    , installed 2.3.6
    Adapter    "bydbatt"       : 1.1.0    , installed 1.0.8 [Updateable]
    Adapter    "bydhvs"        : 1.5.0    , installed 1.4.0 [Updateable]
    Adapter    "coronavirus-statistics": 0.9.0   , installed 0.8.7 [Updateable]
    Adapter    "daswetter"     : 3.1.13   , installed 3.1.10 [Updateable]
    Adapter    "deconz"        : 1.4.0    , installed 1.3.16 [Updateable]
    Adapter    "devices"       : 1.1.5    , installed 0.3.16 [Updateable]
    Adapter    "discovery"     : 4.4.0    , installed 3.1.0 [Updateable]
    Adapter    "dwd"           : 2.8.5    , installed 2.8.5
    Adapter    "feiertage"     : 1.1.4    , installed 1.1.0 [Updateable]
    Adapter    "flot"          : 1.12.0   , installed 1.12.0
    Adapter    "fritzdect"     : 2.5.9    , installed 2.2.6 [Updateable]
    Adapter    "fronius"       : 2.0.2    , installed 1.1.3 [Updateable]
    Adapter    "fronius-solarweb": 0.0.3   , installed 0.0.3
    Adapter    "go-e"          : 1.0.29   , installed 1.0.27 [Updateable]
    Adapter    "history"       : 3.0.1    , installed 1.9.13 [Updateable]
    Adapter    "ical"          : 1.13.3   , installed 1.12.1 [Updateable]
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
    Adapter    "javascript"    : 7.8.0    , installed 5.1.3 [Updateable]
    Controller "js-controller" : 5.0.19   , installed 3.2.16 [Updateable]
    Adapter    "material"      : 1.3.1    , installed 1.3.1
    Adapter    "mqtt"          : 5.2.0    , installed 2.4.0 [Updateable]
    Adapter    "netatmo-crawler": 0.8.1   , installed 0.8.1
    Adapter    "node-red"      : 5.1.0    , installed 2.4.0 [Updateable]
    Adapter    "openweathermap": 1.0.4    , installed 0.1.0 [Updateable]
    Adapter    "owfs"          : 0.7.0    , installed 0.7.0
    Adapter    "parser"        : 2.1.0    , installed 1.3.2 [Updateable]
    Adapter    "ping"          : 1.6.2    , installed 1.6.2
    Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
    Adapter    "scenes"        : 2.3.9    , installed 2.3.9
    Adapter    "schoolfree"    : 1.1.4    , installed 1.0.1 [Updateable]
    Adapter    "shelly"        : 6.6.1    , installed 4.0.7 [Updateable]
    Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
    Adapter    "socketio"      : 6.6.0    , installed 3.1.4 [Updateable]
    Adapter    "sonoff"        : 3.0.3    , installed 2.5.3 [Updateable]
    Adapter    "sql"           : 2.2.0    , installed 1.15.7 [Updateable]
    Adapter    "tankerkoenig"  : 3.3.7    , installed 2.1.1 [Updateable]
    Adapter    "telegram"      : 3.1.0    , installed 1.10.0 [Updateable]
    Adapter    "text2command"  : 3.0.3    , installed 3.0.2 [Updateable]
    Adapter    "tr-064"        : 4.2.18   , installed 4.2.18
    Adapter    "tronity"       : 1.1.1    , installed 1.1.1
    Adapter    "vis"           : 1.5.4    , installed 1.4.16 [Updateable]
    Adapter    "vis-colorpicker": 2.0.3   , installed 2.0.3
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"   : 1.5.0    , installed 0.90.0 [Updateable]
    Adapter    "vis-inventwo"  : 3.3.3    , installed 3.3.3
    Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"       : 1.0.5    , installed 1.0.4 [Updateable]
    Adapter    "vis-material"  : 0.1.3    , installed 0.1.3
    Adapter    "vis-materialdesign": 0.5.9   , installed 0.3.19 [Updateable]
    Adapter    "vis-metro"     : 1.2.0    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.2.2   , installed 1.2.2
    Adapter    "vis-weather"   : 2.5.9    , installed 2.5.6 [Updateable]
    Adapter    "weatherunderground": 3.6.0   , installed 3.4.2 [Updateable]
    Adapter    "web"           : 6.2.3    , installed 3.4.1 [Updateable]
    Objects and States
    Objects:        30637
    States:         29813
    E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldoldstable'
    E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldoldstable'
    Pending Updates: 121
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       23252      2412/node-red
    tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      1000       16568      339/deCONZ
    tcp        0      0 192.168.178.100:1883    0.0.0.0:*               LISTEN      1001       26425      2524/io.shelly.1
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16570      339/deCONZ
    tcp        0      0 192.168.178.100:1888    0.0.0.0:*               LISTEN      1001       25469      2413/io.shelly.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17824      688/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17817      688/iobroker.js-con
    tcp        0      0 0.0.0.0:2121            0.0.0.0:*               LISTEN      109        14819      503/owhttpd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18519      693/sshd
    tcp6       0      0 :::80                   :::*                    LISTEN      1001       24932      2412/node-red
    tcp6       0      0 :::4304                 :::*                    LISTEN      0          13623      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16658      830/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       29714      3144/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18521      693/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       26320      2537/io.simple-api.
    udp        0      0 192.168.178.100:5353    0.0.0.0:*                           1001       29294      2830/io.tr-064.0
    udp        0      0 192.168.178.100:5353    0.0.0.0:*                           1001       29293      2830/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14783      440/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24933      2412/node-red
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16944      1261/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16599      339/deCONZ
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16561      685/dhcpcd
    udp        0      0 0.0.0.0:34930           0.0.0.0:*                           108        14785      440/avahi-daemon: r
    udp6       0      0 :::46739                :::*                                108        14786      440/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14784      440/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       16948      1261/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       16947      1261/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       16946      1261/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       16945      1261/io.deconz.0
    udp6       0      0 :::546                  :::*                                0          15203      685/dhcpcd
    2024-03-21 17:08:05.467  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.126 (Sonoff-Relais6-TV / Sonoff-Relais6-TV-Ecke / undefined#Ecke#1) for MQTT does not exist!
    2024-03-21 17:08:05.679  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.156 (Sonoff / Sonoff-POW1_Waschmaschine / undefined#POW1_Waschmaschine#1) for MQTT does not exist!
    2024-03-21 17:08:06.167  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.125 (Sonoff / Sonoff-Relais5 / undefined#Relais5#1) for MQTT does not exist!
    2024-03-21 17:08:06.271  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.122 (Sonoff / Sonoff-Relais2 / undefined#Relais2#1) for MQTT does not exist!
    2024-03-21 17:08:06.704  - warn: parser.0 (2076) Cannot read link "/home/pi/ramdisk/export-strom.txt": File does not exist
    2024-03-21 17:08:07.072  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.177 (Gosund / Gosund-2 / undefined#2#1) for MQTT does not exist!
    2024-03-21 17:08:08.437  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.121 (Sonoff / Sonoff-Relais1 / undefined#Relais1#1) for MQTT does not exist!
    2024-03-21 17:08:09.409  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.178 (Gosund / Gosund-3 / undefined#3#1) for MQTT does not exist!
    2024-03-21 17:08:15.060  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.123 (Sonoff / Sonoff-Relais3 / undefined#Relais3#1) for MQTT does not exist!
    2024-03-21 17:08:16.044  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.173 (Sonoff / Sonoff-Basic03 / undefined#Basic03#1) for MQTT does not exist!
    2024-03-21 17:08:16.449  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.126 (Sonoff-Relais6-TV / Sonoff-Relais6-TV-Ecke / undefined#Ecke#1) for MQTT does not exist!
    2024-03-21 17:08:16.657  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.156 (Sonoff / Sonoff-POW1_Waschmaschine / undefined#POW1_Waschmaschine#1) for MQTT does not exist!
    2024-03-21 17:08:16.705  - warn: parser.0 (2076) Cannot read link "/home/pi/ramdisk/export-strom.txt": File does not exist
    2024-03-21 17:08:17.171  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.125 (Sonoff / Sonoff-Relais5 / undefined#Relais5#1) for MQTT does not exist!
    2024-03-21 17:08:17.291  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.122 (Sonoff / Sonoff-Relais2 / undefined#Relais2#1) for MQTT does not exist!
    2024-03-21 17:08:18.059  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.177 (Gosund / Gosund-2 / undefined#2#1) for MQTT does not exist!
    2024-03-21 17:08:19.462  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.121 (Sonoff / Sonoff-Relais1 / undefined#Relais1#1) for MQTT does not exist!
    2024-03-21 17:08:19.745  - error: javascript.0 (1806) script.js.AllgemeinProgramme.5_SOLAR.4_Stromabgabe-a: Oma aus
    2024-03-21 17:08:19.893  - warn: sonoff.0 (2596) Client "Gosund-3" not connected
    2024-03-21 17:08:20.427  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.178 (Gosund / Gosund-3 / undefined#3#1) for MQTT does not exist!
    2024-03-21 17:08:26.073  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.123 (Sonoff / Sonoff-Relais3 / undefined#Relais3#1) for MQTT does not exist!
    2024-03-21 17:08:26.706  - warn: parser.0 (2076) Cannot read link "/home/pi/ramdisk/export-strom.txt": File does not exist
    2024-03-21 17:08:27.066  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.173 (Sonoff / Sonoff-Basic03 / undefined#Basic03#1) for MQTT does not exist!
    2024-03-21 17:08:27.468  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.126 (Sonoff-Relais6-TV / Sonoff-Relais6-TV-Ecke / undefined#Ecke#1) for MQTT does not exist!
    2024-03-21 17:08:27.670  - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.156 (Sonoff / Sonoff-POW1_Waschmaschine / undefined#POW1_Waschmaschine#1) for MQTT does not exist!
    iob diag has finished.
    Press any key for a summary
    @docadams
    Gnadenlos veraltet.
    Installier da NEU! ein aktuelles Raspberry OS 12 'Bookworm' in der 64Bit Lite Version.
    Zuvor den ioBroker vollumfänglich auf einen aktuellen Stand bringen und dann mit einem Backup davon umziehen.
    • docadamsD Offline
      docadamsD Offline
      docadams
      Diesen Ansatz hatte ich schon mal gestartet. Aber das Einspielen des Backups hing sich auf.
      Manche Adapter lassen sich auch nicht mehr aktueller machen, als sie jetzt sind, da sie bereits ein aktuelleres ioB erwarten.
      Leider muss ich zwischendurch immer wieder längere Pausen machen. Und dabei passierte mir jetzt das.
      Wie gesagt, heute früh lief es noch. Bevor ich heute weitere Aktualisierungen vornehmen wollte, habe ich zur Sicherheit ein Image gezogen und nach dem Neustart läuft Sonoff nicht mehr.
      Da ich nichts weiter gemacht hatte, hatte ich schon die Shellys im Verdacht und vorhin mit erwähnt.
      DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @docadams Wenn Du da nicht auf alles aktualisieren setzt, dann kann man leider auch nicht helfen.
        Nicht falsch verstehen, aber wenn man das System nicht pflegt dann fällt Dir das auf die Füße.
        Woran hängt es denn ?
        Lehrling seit 1975 !!!
        docadamsD 1 Antwort Letzte Antwort
        • DJMarc75D DJMarc75
          docadamsD Offline
          docadamsD Offline
          docadams
          @djmarc75 Keine Angst, ich verstehe hier nichts falsch ;-) Ich lerne seit 1956 immer mehr dazu, war aber lange Zeit krank. Gehört aber nicht hierher.
          Kann man in einem Ruck "alles aktualisieren"? Oder hab ich das falsch verstanden?
          docadamsD Meister MopperM 2 Antworten Letzte Antwort
            docadamsD Offline
            docadamsD Offline
            docadams
            Jetzt kam im Terminal noch ein Nachschlag, weil ich vorhin nicht gleich eine Taste drückte.
            Nur der Vollständigkeit halber hier der Rest:
                                    v.2023-10-10
                     Icon name: computer
                  Architecture: arm
            Kernel:                 armv7l
            Userland:               armhf
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     121
            Pending iob updates:    38
            Nodejs-Installation:    /usr/bin/nodejs         v12.18.2
                                    /usr/bin/npm            6.14.5
                                    /usr/bin/npx            6.14.5
            /home/iobroker/.diag.sh: line 490: corepack: command not found
            Recommended versions are nodejs  Cannot load "custom": Connection is closed.
             Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed.
            Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected string in JSON at position 35953691. Try last Backup!
            No connection to databases possible ... and npm
            Wrong installation path detected. This needs to be fixed
            Please check
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            for more information on how to fix these errors.
            MEMORY:
            Mem:           3.9G        2.3G        727M         24M        855M        1.9G
            Swap:           99M          0B         99M
            Total:         4.0G        2.3G        827M
            Active iob-Instances:   31
            Active repo: stable
            ioBroker Core:          js-controller           3.2.16
                                    admin                   4.2.1
            Objects type: file
            States  type: file
            Objects:                30637
            States:                 29813
            Size of iob-Database:
            6.2M    /opt/iobroker/iobroker-data/states.json.bak
            4.3M    /opt/iobroker/iobroker-data/states.json.old
              Meister MopperM Offline
              Meister Mopper
              schrieb am zuletzt editiert von Meister Mopper
              @docadams sagte in Sonoff-Adapter plötzlich gelb:
              Ja, kann man.
              Es funktioniert mit Linux und dem ioBroker etwas kreativer. Die Systeme müssen regelmäßig gewartet werden!
              Interessanterweise beachten es alle, die einen Garten haben. Dort achtet man auf fortführende Pflege, aber im IT-Bereich tun sie es wesentlich seltener, obwohl sehr viele Parallelen zu beobachten sind.
              Ich z. B. pflege täglich (wöchentlich reicht wahrscheinlich auch):
              1. Prüfung mit apticron, ob die Linux-Systeme noch up to date sind. Ansonsten werden sie aktualisiert.
              2. Überwachung des eol von Linux-Distributionen => deutlich vor Ablauf mache ich ein Upgrade auf das neue (lts) System (manchmal ist ein Neuaufsetzten erforderlich - das bekomme ich hier im Forum mit den Beiträgen von @Thomas-Braun mit, der sich wirklich im Bereich Support den A... aufreißt - sorry für die Assoziation).
              3. Prüfung und Durchführung von vorhandenen (stable) Adapterupdates und dem js-controller
              Auf diese Weise ist man immer mit der Nase und dem System vorne und für unangenehme Überraschungen weitestgehend gefeit.
              Proxmox und HA ...
                nach einem Neustart des RasPi sind meine ganzen Tasmota-Geräte nicht mehr ansprechbar. Ich nutze sie zum Ansteuern der Rollos, aber auch zum Messen einiger Verbraucher.
                Verbunden mit Host und Lebenszeichen sind wahr, aber verbunden mit Sonoff ist falsch.
                Außer Neustart habe ich nichts gemacht oder verändert.
                Vor einiger Zeit habe ich versucht, einen älteren Shelly2.5 und einen ShellyPlus einzubinden. Das gelang mir nicht, vermutlich weil mein System zu alt ist. Jetzt laufen sie im Haus erst mal ohne Anbindung in ioBroker nur mit der Handy-App.
                Könnten die trotzdem irgendwie stören? Wenn ja, aber erst seit dem Neustart heute.
                Falls es wichtig ist, mqtt ist im ioBroker deaktiviert und auch in den beiden Shellys habe ich mqtt deaktiviert.
                Wo könnte ich noch suchen oder zentral im WLAN was prüfen?
                crunchipC Offline
                crunchipC Offline
                Na ja, du hast bind auf die IP und nutzt die falschen Ports
                Folgt man der shelly Doku, Port 1882.
                Der mqtt Adapter läuft in der Regel auf 1883.
                Sonoff kannst daher auf z. B. 1885 legen
                Damit sich die Ports nicht in die Quere kommen, weil ja letztendlich alle drei Adapter mqtt nutzen
                Natürlich musst du entsprechend die Ip:Port auch in den Jeweiligen Geräten hinterlegen
                  Und genau deswegen lässt man das Ding nämlich nicht so gnadenlos versumpfen.
                  iob stop
                  iob fix
                  iob nodejs-update
                  sudo apt update
                  sudo apt upgrade
                  sudo reboot
                  iob update
                  iob upgrade
                  iob stop
                  iob upgrade-self
                  iob start
                  sollte dich einigermaßen in die Gegenwart katapultieren.
                    iob stop
                    iob fix
                    iob nodejs-update
                    sudo apt update
                    sudo apt upgrade
                    sudo reboot
                    iob update
                    iob upgrade
                    iob stop
                    iob upgrade-self
                    iob start
                    docadamsD Offline
                    docadamsD Offline
                    docadams
                    mein längeres Schweigen bedeutete, dass ich mehrere Versuche gestartet hatte.
                    Zunächst einmal, mein eigentliches Problem bleibt"seltsam". Zunächst hatte ich wieder ein Image der SD gemacht und nach dem Neustrart ähnliches Phänomen, nur anders rum.
                    Warum auch immer, die Sonoffs lassen sich nach dem Neustart wieder ansprechen.
                    Nun aber zu deiner Aufgabenliste.
                    Die Befehle 1 bis 6 liefen durch, allerdings tauchten bei iob fix auch diese Zeilen auf:
                    OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                    E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wur        de der »Suite«-Wert von »stable« in »oldoldstable« geändert.
                    N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot        angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie we        itere Informationen benötigen.
                    E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde        der »Suite«-Wert von »testing« in »oldoldstable« geändert.
                    Der Rest lief anstandslos durch.
                    Nach dem Reboot stehe ich aber weiterhin bei:
                     cat /etc/os-release
                    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                    NAME="Raspbian GNU/Linux"
                    VERSION_ID="10"
                    VERSION="10 (buster)"
                    VERSION_CODENAME=buster
                    ID=raspbian
                    ID_LIKE=debian
                    HOME_URL="http://www.raspbian.org/"
                    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                    Ab Befehl 8 gibt es aber Probleme:
                    ar 24 14:56:07 2024 from 192.168.178.25
                    pi@iobroker4:~ $ iob update
                     Cannot read system.config: undefined (OK when migrating or restoring)
                     Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
                     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                    Error: Object "system.config" not found
                    iob upgrade
                    Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
                    Tja.... da bin ich am Ende....
                    haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                       cat /etc/os-release
                      VERSION_ID="10"
                      ID=raspbian
                      ID_LIKE=debian
                      iob upgrade
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @docadams
                      Dein System leider auch...
                      OS veraltet und Node ebenso...
                      Bring das mal auf Stand, dann können wir weitermachen
                      Edit:
                      @Thomas-Braun hat Dir schon die Befehle gepostet. Ansonsten gibt das Forum und das Internet auch noch interessante Lösungsmöglichkeiten bezüglich Deiner Updates.
                      Edit 2:
                      Wenn ich das im Nachhinein so betrachte und Deine Logs so sehe, macht vielleicht doch ne Neuinstallation mit Backup mehr Sinn.
                         cat /etc/os-release
                        VERSION_ID="10"
                        ID=raspbian
                        ID_LIKE=debian
                        iob upgrade
                        buster
                        Komplett veraltet...
                        Installier das NEU!
                        Als Raspberry OS 12 'Bookworm' in der 64Bit Lite Version.
