  4. Amazon Dash Button für ioBroker nutzen
385 Beiträge 86 Kommentatoren 163.6k Aufrufe 1 Beobachtet
  • kmxakK
    kmxakK
    kmxak
    #262
    Wenn du eingeloggt bist oben rechts new issue
    Gruß Alex
    • C
      C
      Chauffeur
      #263
      Ich würde auch hier auf die Schnelle noch eine MAC weitergeben:
      78E103
      • T
        T
        Tobi81
        #264
        Ich habe gerade ioBroker neu von einem Image installiert:
        http://www.iobroker.net/docu/?page_id=7241&lang=de
        Danach habe ich:
        sudo raspi-config
        sudo apt-get update
        sudo apt-get upgrade
        sudo apt-get install libpcap-dev
        sudo apt-get install git
        sudo apt-get install git-core
        Beim Installieren von Dash Button bekomme ich dann folgende Ausgabe:
        $ ./iobroker add amazon-dash
        npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)
        npm WARN lifecycle iobroker.amazon-dash@0.2.4~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.4 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
        ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::New(const Nan::FunctionCallbackInfo<v8::value>&)’:../socket_watcher.cpp:104:49: warning: ‘v8::Local <v8::object>v8::Function::NewInstance() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             info.GetReturnValue().Set(cons->NewInstance());
        In file included from /root/.node-gyp/6.11.3/include/node/v8.h:25:0,
                         from /root/.node-gyp/6.11.3/include/node/node.h:42,
                         from ../../nan/nan.h:49,
                         from ../socket_watcher.hpp:8,
                         from ../socket_watcher.cpp:5:
        /root/.node-gyp/6.11.3/include/node/v8.h:3276:52: note: declared here
           V8_DEPRECATED("Use maybe version", Local <object>NewInstance() const);
        /root/.node-gyp/6.11.3/include/node/v8config.h:333:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../pcap_session.cc: In static member function ‘static void PcapSession::New(const Nan::FunctionCallbackInfo<v8::value>&)’:../pcap_session.cc:46:49: warning: ‘v8::Local <v8::object>v8::Function::NewInstance() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        In file included from /root/.node-gyp/6.11.3/include/node/v8.h:25:0,                 from /root/.node-gyp/6.11.3/include/node/node.h:42,
                         from ../pcap_session.h:4,
                         from ../pcap_session.cc:7:
        host.iobroker install adapter amazon-dash
        npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.amazon-dash"
        npm
         WARN
         lifecycle iobroker.amazon-dash@0.2.4~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.4 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/iobroker.amazon-dash
        Stimmt etwas nicht mit meiner node Version?
        Unter Objekte sehe ich keine Dash Buttons. :-(
        Danke,
        Tobi</object></v8::object></v8::value></object></v8::object></v8::value></object></v8::object></v8::value>
        • E
          E
          easy
          #265
          @meome:
          Kurze Frage: Kann man den Adapter irgendwie unter Windows 10 zum Laufen bringen?
          Habe mir jetzt alles hier durchgelesen, bin mir aber nich tsicher, ob ich alles zuordnen konnte.
          Meine eigenen Installation habe ich upgedated: npm = 3.10.10, node = 6.10.2
          Auch WinPcap 4.1.3 installiert (die .exe).
          Python 2.7. läuft auch.
          Ich bekomme aber immer die Fehlermeldung:
          ich bin Alex, komme aus Berlin und versuche mich grad an ioBroker.
          Geile Software, macht richtig Spass und der heftige Frustlevel den ich bei FHEM relativ schnell erlebt habe ist hier (noch) nicht in Sicht.
          Konnte, in überraschend schneller Zeit, meine IOT-Systeme und div. Adapter installieren und konfigurieren. Bin echt begeistert!!!
          Nun versuche ich den Dash Adapter auf meinem WIN7 System zu installieren. Leider läuft die Installation nicht durch. Ohne jetzt das Problem näher zu beschreiben…
          Gibt es ioBroker-User die den Dash Button erfolgreich auf ihrem WIN System zum laufen gebracht haben?
          Vielen Dank!
          @lex
          • E
            E
            easy
            #266
            Hat sich erledigt!
            Windows hat das Gerät verlassen! ;)
            Nun ist es Lubuntu, was super performant läuft UND meine Dash Buttons funktionieren ohne Probleme.
            @lex
            • N
              N
              Nabla
              #267
              Ist jetzt nicht wirklich dramatisch, aber ich habe heute einen neuen Dash-Button hinzugefügt.
              Statt lediglich dem neuen Button, wurden aber gleich 2 weitere Dash-Buttons als Objekt angelegt.
              "Last Pressed 30.10. 2:35 Uhr"
              Diese exitieren hier nicht, meine Amazon-App zeigt die Button auch korrekt an.
              (Die MAC-Adresse ist auch jeweils unterschiedlich.)
              • WebrangerW
                WebrangerW
                Webranger
                #268
                @PArt:
                Der Adapter benötigt zusätzlich noch pcap auf eurem System.
                In der Regel lässt sich dieser durch apt-get install libpcap-dev installieren `
                So! Wollte mich jetzt auch mal an den Dash Button ran trauen.
                Hab aber schon der erste problem auf meinen pi
                folgender fehler erscheint:
                root@ioBroker-RasPi:/home/pi# apt-get install libpcap-de
                E: Paket libpcap-de kann nicht gefunden werden.
                Jemand eine Idee für mich?
                edit mein fehler selber gefunden! v vergessen
                Gruss Danyel
                Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                • V
                  V
                  VANTOM
                  #269
                  leider wird einer meiner Dash-Buttons nicht erkannt, hab sie schon in die main.js eingetragen wie die anderen aber es ändert sich nichts. MAC wäre 00:FC:8B
                  • Espace0401E
                    Espace0401E
                    Espace0401
                    #270
                    @VANTOM:
                    leider wird einer meiner Dash-Buttons nicht erkannt, hab sie schon in die main.js eingetragen wie die anderen aber es ändert sich nichts. MAC wäre 00:FC:8B `
                    Das Problem hatte ich auch. Mac Adresse selbst eingetragen, brachte aber leider auch nichts. Ich habe den Adapter dann wieder gelöscht. Habe jetzt hier halt einen hübschen Taster an der Wand hängen.
                    Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
                    • J
                      J
                      Jan201
                      #271
                      Hallo, ich wollte meinen dash installieren und irgendwie klappt garnix. Den adapter habe ich mir paar fehlermeldungen installiert. Was für eine PCAP muss ich da eingeben? Mein PI ist mit LAN verbunden. Habe dann den Dash mit der App via smartphone installiert und bei der produktwahl abgebrochen. Dann den adapter in iobrocker installiert und nun komme ich nicht mehr weiter. Anbei ein paar Bilder
                      |Hardwaresystem:| NUC|
                      |Arbeitsspeicher:| 8GB |
                      |Festplattenart:| 250gb SSD |
                      |Betriebssystem:| Proxmox , Ubuntu 21.10 |
                      |Node-Version:| vv20.15.1 |
                      |Nodejs-Version:| vv20.15.1 |
                      |NPM-Version:| 10.7.0 |
                      • arteckA
                        arteckA
                        arteck
                        #272
                        @Espace0401:
                        @VANTOM:
                        Das Problem hatte ich auch. Mac Adresse selbst eingetragen, brachte aber leider auch nichts. Ich habe den Adapter dann wieder gelöscht. Habe jetzt hier halt einen hübschen Taster an der Wand hängen. `
                        hast den io broker gestoppt….
                        dann mac addresse eintragen
                        da stehen schon welche .. also erstmal schauen ob die nicht schon da steht..
                        wenn nicht nach dem gleichen schema eintragen
                        iobroker starten
                        WARTEN.... es dauert bis der Adapter den Button findet ..wenn nicht knopp drücken wieder WARTEN
                        • arteckA
                          arteckA
                          arteck
                          #273
                          @Jan201:
                          Hallo, ich wollte meinen dash installieren und irgendwie klappt garnix. Den adapter habe ich mir paar fehlermeldungen installiert. Was für eine PCAP muss ich da eingeben? Mein PI ist mit LAN verbunden. Habe dann den Dash mit der App via smartphone installiert und bei der produktwahl abgebrochen. Dann den adapter in iobrocker installiert und nun komme ich nicht mehr weiter. Anbei ein paar Bilder `
                          stoppe den adapter mal.. und dann neu starten.. schau im LOG ob da jetzt was an fehler auftaucht…
                          wenn nicht..
                          welche MAC adresse hat der Knopp
                          • J
                            J
                            Jan201
                            #274
                            Hallo, also der Knopf hat: 00:FC:8B:34:AF:41
                            Habe den Adapter neu gestartet und es kam folgendes:
                            amazon-dash.0 2017-12-20 15:41:25.253 info starting pcap session on interface wlan0
                            amazon-dash.0 2017-12-20 15:41:25.243 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v6.12.0
                            amazon-dash.0 2017-12-20 15:41:25.185 info States connected to redis: 127.0.0.1:6379
                            host.ioBroker-Pi 2017-12-20 15:41:23.503 info instance system.adapter.amazon-dash.0 started with pid 10227
                            host.ioBroker-Pi 2017-12-20 15:41:23.456 info object change system.adapter.amazon-dash.0
                            host.ioBroker-Pi 2017-12-20 15:41:07.040 info instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                            amazon-dash.0 2017-12-20 15:41:06.904 info terminating
                            amazon-dash.0 2017-12-20 15:41:06.881 info cleaned everything up…
                            host.ioBroker-Pi 2017-12-20 15:41:06.875 info stopInstance system.adapter.amazon-dash.0 killing pid 3657
                            host.ioBroker-Pi 2017-12-20 15:41:06.872 info stopInstance system.adapter.amazon-dash.0
                            Das mit der MAC manuell eintragen in der main.js habe ich noch nicht so richtig verstanden. Wo kann ich das machen?
                            • J
                              J
                              Jan201
                              #275
                              @arteck:
                              die MAC ist so wie ich das sehe nicht im Adapter eingetragen
                              du könntest probeweise diesen erweitern
                              stoppe den iobroker
                              öffne die datei /iobroker/node_modules/iobroker.amazon-dash/main.js
                              dort findest du ein array mit den MAC adressen ganz am anfang
                              var MACs = [
                                  "747548",
                                  "F0D2F1",
                                  "8871E5",
                                  "74C246",
                                  "F0272D",
                                  "34D270",
                                  "0C47C9",
                                  "A002DC",
                                  "AC63BE",
                                  "44650D",
                                  "50F5DA",
                                  "84D6D0",
                                  "B47C9C",
                                  "FCA667"
                              ersetzte es durch diese
                              var MACs = [
                                  "747548",
                                  "F0D2F1",
                                  "8871E5",
                                  "74C246",
                                  "F0272D",
                                  "34D270",
                                  "0C47C9",
                                  "A002DC",
                                  "AC63BE",
                                  "44650D",
                                  "50F5DA",
                                  "84D6D0",
                                  "B47C9C",
                                  "FCA667",
                                  "40B4CD"
                              speichern und iobroker wieder starten…
                              der adapter sollte jetzt auch deine MAC kennen
                              bedenke bitte aktualisierst du diesen Adapter ist deine Änderung wieder futsch `
                              Wie kann ich die Datei mit einem Windows10 rechner öffen? muss ich dazu die karte aus dem PI nehmen? habe jetzt alles durchgelesen aber keine antwort gefunden. Die sechs zahlen/Buchstaben, sind das die ersten von meiner MAC adresse nur ohne ":" ? Wird der ordner "amazon-dash.0" automatisch erzeugt wenn er ein objekt findet? Ich habe auch einen Echo am laufen der wird auch nicht gefunden.
                              • arteckA
                                arteckA
                                arteck
                                #276
                                log dich an der konsole an
                                sudo nano /opt/iobroker/node_modules/iobroker.amazon-dash/main.js
                                dor deine MAC adresse hinten drann eintragen
                                00FC8B
                                komma nicht vergessen…
                                mit strg+x kannst du den editor verlassen..speichern nicht vergessen
                                • J
                                  J
                                  Jan201
                                  #277
                                  Hat super geklappt, vielen dank :)
                                  • J
                                    J
                                    j3sk0
                                    #278
                                    Hallo Zusammen,
                                    würde gerne meinen Amazon Dash nicht nur für Hundefutter nutzen bekommen den adapter aber nicht zum Laufen, ich habe bereits die https://github.com/PArns/ioBroker.amazo … /README.md befolgt sowie http://www.iobroker.net/docu/?page_id=5510&lang=de versucht leider ohne Erfolg. Python 3, node v6.11.2, npm v3.10.10.
                                    Synology DS 216play ohne Docker
                                    npm
                                     WARN lifecycle iobroker.amazon-dash@0.2.7~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.7 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
                                    gyp
                                     ERR! build error
                                    gyp ERR! stack Error: not found: makegyp ERR! stack
                                         at getNotFoundError (/usr/local/lib/node_modules/npm/node_modules/which/which.js:14:12)gyp ERR! stack     at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:69:19)
                                    gyp
                                    ERR! stack     at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:81:29)gyp ERR! stack
                                         at /usr/local/lib/node_modules/npm/node_modules/which/which.js:90:16gyp ERR!
                                     stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                                    gyp ERR!
                                     stack     at FSReqWrap.oncomplete (fs.js:123:15)gyp
                                    ERR! System
                                     Linux 3.10.102gyp ERR! command "/volume1/@appstore/Node.js_v6/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                    gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
                                    gyp ERR! node -v v6.11.2
                                    gyp ERR! node-gyp -v v3.4.0
                                    gyp ERR! not ok
                                    node-pre-gyp
                                    ERR!
                                    Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
                                     node-pre-gyp
                                     ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.2 (node-v48 ABI) (falling back to source compile with node-gyp)
                                    gyp
                                    ERR!
                                     build error gyp ERR! stack Error: not found: make
                                    gyp ERR! stack     at getNotFoundError (/volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/which/which.js:14:12)
                                    gyp ERR! stack
                                         at F (/volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/which/which.js:69:19)
                                    gyp ERR! stack     at E (/volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/which/which.js:81:29)gyp ERR! stack     at /volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/which/which.js:90:16
                                    gyp ERR! stack     at /volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                                    gyp ERR! stack     at /volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                                    gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:123:15)
                                    gyp ERR! System Linux 3.10.102
                                    gyp ERR! command "/volume1/@appstore/Node.js_v6/usr/local/bin/node" "/volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
                                    gyp ERR! cwd /opt/iobroker/node_modules/serialport
                                    gyp ERR! not ok
                                    node-pre-gyp ERR! build error
                                    node-pre-gyp ERR! stack Error: Failed to execute '/volume1/@appstore/Node.js_v6/usr/local/bin/node /volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)
                                    node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                    node-pre-gyp ERR! stack     at emitTwo (events.js:106:13)
                                    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
                                    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:891:16)
                                    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                                    node-pre-gyp ERR! System Linux 3.10.102
                                    node-pre-gyp ERR! command "/volume1/@appstore/Node.js_v6/usr/local/bin/node" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialport
                                    node-pre-gyp ERR! node -v v6.11.2
                                    node-pre-gyp ERR! node-pre-gyp -v v0.6.32
                                    node-pre-gyp ERR! not ok
                                    gyp
                                    ERR!
                                    build error
                                    gyp ERR! stack Error: not found: makegyp ERR! stack     at getNotFoundError (/usr/local/lib/node_modules/npm/node_modules/which/which.js:14:12)
                                    gyp ERR! stack     at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:81:29)
                                    gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/which.js:90:16
                                    gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                                    gyp ERR! cwd /opt/iobroker/node_modules/socketwatcher
                                    gyp ERR! not ok
                                    npm
                                     WARN
                                     optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
                                    npm WARN
                                    optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1npm WARN
                                    optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/serialport):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 install: `node-pre-gyp install --fallback-to-build`
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                    npm
                                     ERR! Linux 3.10.102
                                    npm
                                     ERR!
                                    argv "/volume1/@appstore/Node.js_v6/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/opt/iobroker"npm ERR!
                                     node v6.11.2npm ERR! npm  v3.10.10
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! socketwatcher@0.3.0 install: `node-gyp rebuild`
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the socketwatcher@0.3.0 install script 'node-gyp rebuild'.
                                    npm ERR! Make sure you have the latest version of node.js and npm installed.
                                    npm ERR! If you do, this is most likely a problem with the socketwatcher package,
                                    npm ERR! not with npm itself.
                                    npm ERR!
                                     Tell the author that this fails on your system:npm ERR!     node-gyp rebuild
                                    npm ERR! You can get information on how to open an issue for this project with:
                                    npm ERR!     npm bugs socketwatcher
                                    npm ERR! Or if that isn't available, you can get their info via:
                                    npm ERR!     npm owner ls socketwatchernpm ERR! There is likely additional logging output above.
                                    npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
                                    host.NAS0815 install adapter amazon-dash
                                    npm WARN lifecycle iobroker.amazon-dash@0.2.7~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.7 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
                                    gyp
                                     ERR! build error gyp ERR! stack Error: not found: make
                                    gyp ERR! not ok
                                    node-pre-gyp
                                     ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.2 (node-v48 ABI) (falling back to source compile with node-gyp)
                                    gyp
                                    gyp ERR! stack     at F (/volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/which/which.js:69:19)
                                    gyp ERR! not ok
                                    gyp
                                    gyp ERR! not ok
                                    npm
                                     WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/serialport):
                                    npm ERR! Linux 3.10.102
                                    npm ERR! argv "/volume1/@appstore/Node.js_v6/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.2
                                    npm ERR! code
                                     ELIFECYCLE
                                    npm ERR!
                                    npm ERR! Tell the author that this fails on your system:
                                    npm
                                    gyp
                                    gyp ERR! not ok
                                    node-pre-gyp
                                    gyp ERR! stack Error: not found: makegyp ERR! stack     at getNotFoundError (/volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/which/which.js:14:12)
                                    gyp ERR! not ok
                                    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/volume1/@appstore/Node.js_v6/usr/local/bin/node /volume1/@appstore/Node.js_v6/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)
                                    gyp
                                    ERR!
                                    build error
                                    gyp ERR! not ok
                                    npm
                                    npm ERR!
                                    npm ERR!
                                         /npm-debug.log
                                    ERROR: host.NAS0815 Cannot install amazon-dash
                                    ERROR: process exited with code 13</anonymous></anonymous></anonymous>
                                    vielen DAnk
                                    • cvidalC
                                      cvidalC
                                      cvidal
                                      Forum Testing
                                      #279
                                      @j3sk0:
                                      Hallo Zusammen,
                                      vielen DAnk `
                                      Verusch mal
                                      Gruß Christian
                                      • J
                                        J
                                        j3sk0
                                        #280
                                        Verusch mal
                                        Gruß Christian
                                        Hab ich bereits da es so auch in der redme von GitHub steht… Leider ohne Erfolg
                                        • S
                                          S
                                          SigiMOE
                                          #281
                                          ! @arteck:
                                          ! > die MAC ist so wie ich das sehe nicht im Adapter eingetragen
                                          stoppe den iobroker
                                          var MACs = [
                                              "747548",
                                              "F0D2F1",
                                              "8871E5",
                                              "74C246",
                                              "F0272D",
                                              "34D270",
                                              "0C47C9",
                                              "A002DC",
                                              "AC63BE",
                                              "44650D",
                                              "50F5DA",
                                              "84D6D0",
                                              "B47C9C",
                                              "FCA667"
                                          var MACs = [
                                              "747548",
                                              "F0D2F1",
                                              "8871E5",
                                              "74C246",
                                              "F0272D",
                                              "34D270",
                                              "0C47C9",
                                              "A002DC",
                                              "AC63BE",
                                              "44650D",
                                              "50F5DA",
                                              "84D6D0",
                                              "B47C9C",
                                              "FCA667",
                                              "40B4CD"
                                          ! <size size="100">habe gerade einen Button neu geliefert bekommen und in die main.js eintragen müssen….
                                          ! FC65DE
                                          ! Vielleicht kann es jemand in das nächste Update einpflegen ?!</size>
                                          33.2k
                                          84.3k
