  3. Einsteigerfragen
  4. Backup auf Fritzbox klappt nicht
45 Beiträge 5 Kommentatoren 6.3k Aufrufe 4 Beobachtet
  • P Pistus
    Das wird im Backupfenster, während Backup läuft angezeigt
    Started iobroker ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
    mount error(13): Permission denied
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
    [DEBUG] [iobroker] - host.raspberrypi 343 states saved
    [DEBUG] [iobroker] - host.raspberrypi 472 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_03_21-10_11_24_backupiobroker.tar.gz
    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
    [DEBUG] [iobroker] - done
    [DEBUG] [cifs] - used copy path: /fritz.nas/TREKSTOR/Backup-ioBroker
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    2024-03-21 10:11:11.280 - info: backitup.0 (8467) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2024-03-21 10:11:13.359 - error: backitup.0 (8467) Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
    2024-03-21 10:11:23.988 - error: backitup.0 (8467) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
    2024-03-21 10:11:23.991 - error: backitup.0 (8467) [iobroker/mount] mount error(13): Permission denied
    2024-03-21 10:11:23.992 - error: backitup.0 (8467) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    2024-03-21 10:11:36.003 - error: backitup.0 (8467) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    2024-03-21 10:14:50.630 - info: admin.0 (7773) <== Disconnect system.user.admin from ::ffff:192.168.178.37
    @pistus du hast für die Fritzbox noserverino und cache loose nicht angehakt.
    Für die Synoligy brauchst du das nicht!
    warum bist du hier im Syno Thread?
    P 1 Antwort Letzte Antwort
      Pistus
      schrieb am zuletzt editiert von Pistus
      Wenn ich die Häkchen einfüge passiert überhaupt nichts. Die waren vorher drin.
      Häkchen eingefügt.
      Er bleibt immer an der gleichen Stelle im Backup hängen.
      [DEBUG] [iobroker] - host.raspberrypi 341 states saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_03_21-10_35_22_backupiobroker.tar.gz
      Die Bacupdatei ist dann nur 1MB groß
      HomoranH P 2 Antworten Letzte Antwort
      • P Pistus
        Häkchen eingefügt.
        @pistus und was steht jetzt im debug log?
        • P Pistus
          Häkchen eingefügt.
          Pistus
          @Homoran
          2024-03-21 10:35:11.198 - error: backitup.0 (8720) Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
          2024-03-21 10:35:22.599 - error: backitup.0 (8720) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
          2024-03-21 10:35:22.601 - error: backitup.0 (8720) [iobroker/mount] mount error(13): Permission denied
          2024-03-21 10:35:22.602 - error: backitup.0 (8720) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
          2024-03-21 10:35:34.639 - error: backitup.0 (8720) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
          2024-03-21 10:42:39.863 - info: admin.0 (7773) <== Disconnect system.user.admin from ::ffff:192.168.178.37
          • P Pistus
            @Homoran
            @pistus
            Leg dir auf der FritzBox einen user für das Backup an und vergib dem die entsprechenden Rechte auf das NAS zuzugreifen.
            Die Optionen 'noserverino' und 'cache loose' müssen bei Verwendung des FritzNAS gesetzt werden.
            Und im Pfad dürfte das Volume fehlen.
            • P Pistus
              @Homoran
              @pistus sagte in Backup auf Fritzbox klappt nicht:
              auch wenn das kein debug-log ist, jetzt steht das wenigstens drin.
              Ist denn das Verzeichnis für den User freigegeben?
                @pistus
                @thomas-braun sagte in Backup auf Fritzbox klappt nicht:
                Den hat @Pistus leider abgeschnitten 😡
                  @homoran sagte in Backup auf Fritzbox klappt nicht:
                  Deswegen ja auch nur eine Vermutung. Im Log steht der Pfad aber auch falsch drin.
                    Pistus
                    Diese Backups sind nicht auf der Festplatte angekommen
                    Hier ist die festplatte zu zehen und das die automatischen früheren Backups funktioniert haben
                    • P Pistus
                      Pistus
                      @Thomas-Braun
                      192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker/opt/iobroker/backups
                      Hallo Thomas, wo kommt denn jetzt in dem Pfad zum speichern am Ende das
                      her
                      Richtig ist doch
                      • P Pistus
                        @Thomas-Braun
                        her
                        Richtig ist doch
                        Copy to Clipboard/opt/iobroker/backups
                        her
                        Das ist der Mountpunkt, an dem das Dateisystem der FritzBox eingehängt wird.
                        €dit: Typos
                          her
                          €dit: Typos
                          Pistus
                          Ich raffe das einfach nicht.
                          der Pfad vom Trekstor ist doch
                          und nicht
                          siehe oben im Bild Festplatte
                          HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                          • P Pistus
                            und nicht
                            wenn das so ist, wird dieser über /opt/iobroker/backups "verlinkt" (korrekt: gemountet)
                            • P Pistus
                              und nicht
                              und nicht
                              Das steht ja auch nicht da. Es steht
                              drin. Man beachte das Leerzeichen.
                              • P Pistus
                                und nicht
                                @pistus
                                Hier mal reingeschaut?
                                https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup
                                Da gibt es einen Punkt für FritzNAS.
                                  @pistus
                                  Pistus
                                  Hatte ich und auch gemacht. Das Backup hatte doch auch immer funktioniert siehe Bilder wo die Dateien auf dem NAS abgelegt sind.
                                  Ich denke gerade darüber nach, dass ich ja mit zwei Raspberry im gleichen Verzeichnis Backups ablegen will. Könnte das ein Grund sein?
                                  Thomas BraunT P 2 Antworten Letzte Antwort
                                  • P Pistus
                                    Gleichzeitig über zwei verschiedene Protokolle geht das natürlich nicht. Ist da auch noch FTP im Spiel?
                                    Ich würde auch pro System ein eigenes Verzeichnis anlegen und da rein sichern.
                                    • P Pistus
                                      Pistus
                                      Ich versuche ja das Backup unter
                                      Backup / Systemsicherung / ioBroker Backup starten
                                      Das erscheint am Bildschirm
                                      und das in der Log
                                      backitup.0
                                      2024-03-21 13:06:31.554	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                      backitup.0
                                      2024-03-21 13:06:19.265	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                      backitup.0
                                      2024-03-21 13:06:19.264	error	[iobroker/mount] mount error(13): Permission denied
                                      backitup.0
                                      2024-03-21 13:06:19.255	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
                                      • P Pistus
                                        und das in der Log
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        @pistus
                                        Wenn du schon einen user für das Backup hast, warum verwendest du ihn nicht?
                                          @pistus
                                          @thomas-braun sach ens ;-) muss das fritz.nas im Pfad sein?
