  3. Einsteigerfragen
  4. Backup auf Fritzbox klappt nicht
45 Beiträge 5 Kommentatoren 6.3k Aufrufe 4 Beobachtet
  • P Pistus
    Wenn ich die Häkchen einfüge passiert überhaupt nichts. Die waren vorher drin.
    Häkchen eingefügt.
    Er bleibt immer an der gleichen Stelle im Backup hängen.
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    [DEBUG] [iobroker] - host.raspberrypi 341 states saved
    [DEBUG] [iobroker] - host.raspberrypi 472 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_03_21-10_35_22_backupiobroker.tar.gz
    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
    [DEBUG] [iobroker] - done
    [DEBUG] [cifs] - used copy path: /fritz.nas/TREKSTOR/Backup-ioBroker
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    Die Bacupdatei ist dann nur 1MB groß
    @pistus und was steht jetzt im debug log?
    • P Pistus
      Häkchen eingefügt.
      Pistus
      @Homoran
      2024-03-21 10:35:11.198 - error: backitup.0 (8720) Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
      mount error(13): Permission denied
      2024-03-21 10:35:22.599 - error: backitup.0 (8720) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
      2024-03-21 10:35:22.601 - error: backitup.0 (8720) [iobroker/mount] mount error(13): Permission denied
      2024-03-21 10:35:22.602 - error: backitup.0 (8720) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      2024-03-21 10:35:34.639 - error: backitup.0 (8720) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      2024-03-21 10:42:39.863 - info: admin.0 (7773) <== Disconnect system.user.admin from ::ffff:192.168.178.37
      • P Pistus
        @Homoran
        @pistus
        Leg dir auf der FritzBox einen user für das Backup an und vergib dem die entsprechenden Rechte auf das NAS zuzugreifen.
        Die Optionen 'noserverino' und 'cache loose' müssen bei Verwendung des FritzNAS gesetzt werden.
        Und im Pfad dürfte das Volume fehlen.
        • P Pistus
          @Homoran
          @pistus sagte in Backup auf Fritzbox klappt nicht:
          auch wenn das kein debug-log ist, jetzt steht das wenigstens drin.
          Ist denn das Verzeichnis für den User freigegeben?
            @pistus
            @thomas-braun sagte in Backup auf Fritzbox klappt nicht:
            Den hat @Pistus leider abgeschnitten 😡
              @homoran sagte in Backup auf Fritzbox klappt nicht:
              Deswegen ja auch nur eine Vermutung. Im Log steht der Pfad aber auch falsch drin.
              P 1 Antwort Letzte Antwort
                Pistus
                Diese Backups sind nicht auf der Festplatte angekommen
                Hier ist die festplatte zu zehen und das die automatischen früheren Backups funktioniert haben
                • P Pistus
                  Pistus
                  @Thomas-Braun
                  192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker/opt/iobroker/backups
                  Hallo Thomas, wo kommt denn jetzt in dem Pfad zum speichern am Ende das
                  her
                  Richtig ist doch
                  • P Pistus
                    @Thomas-Braun
                    her
                    Richtig ist doch
                    Copy to Clipboard/opt/iobroker/backups
                    her
                    Das ist der Mountpunkt, an dem das Dateisystem der FritzBox eingehängt wird.
                    €dit: Typos
                      her
                      €dit: Typos
                      Pistus
                      schrieb am zuletzt editiert von Pistus
                      Ich raffe das einfach nicht.
                      der Pfad vom Trekstor ist doch
                      und nicht
                      siehe oben im Bild Festplatte
                      HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                      • P Pistus
                        und nicht
                        wenn das so ist, wird dieser über /opt/iobroker/backups "verlinkt" (korrekt: gemountet)
                        • P Pistus
                          und nicht
                          und nicht
                          Das steht ja auch nicht da. Es steht
                          drin. Man beachte das Leerzeichen.
                          • P Pistus
                            und nicht
                            @pistus
                            Hier mal reingeschaut?
                            https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup
                            Da gibt es einen Punkt für FritzNAS.
                              @pistus
                              Pistus
                              Hatte ich und auch gemacht. Das Backup hatte doch auch immer funktioniert siehe Bilder wo die Dateien auf dem NAS abgelegt sind.
                              Ich denke gerade darüber nach, dass ich ja mit zwei Raspberry im gleichen Verzeichnis Backups ablegen will. Könnte das ein Grund sein?
                              Thomas BraunT P 2 Antworten Letzte Antwort
                              • P Pistus
                                Gleichzeitig über zwei verschiedene Protokolle geht das natürlich nicht. Ist da auch noch FTP im Spiel?
                                Ich würde auch pro System ein eigenes Verzeichnis anlegen und da rein sichern.
                                • P Pistus
                                  Pistus
                                  Ich versuche ja das Backup unter
                                  Backup / Systemsicherung / ioBroker Backup starten
                                  Das erscheint am Bildschirm
                                  und das in der Log
                                  backitup.0
                                  2024-03-21 13:06:31.554	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                  backitup.0
                                  2024-03-21 13:06:19.265	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                  backitup.0
                                  2024-03-21 13:06:19.264	error	[iobroker/mount] mount error(13): Permission denied
                                  backitup.0
                                  2024-03-21 13:06:19.255	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
                                  • P Pistus
                                    und das in der Log
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    @pistus
                                    Wenn du schon einen user für das Backup hast, warum verwendest du ihn nicht?
                                      @pistus
                                      @thomas-braun sach ens ;-) muss das fritz.nas im Pfad sein?
                                        sach ens muss das fritz.nas im Pfad sein?
                                        Ja. Bei mir ist es drin.
                                        €dit:
                                        Ich mounte ja etwas anders und in meiner /etc/fstab steht das ganze so drin:
                                        //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,cache=loose,noauto,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 0 0
                                          €dit:
                                          Pistus
                                          @thomas-braun und alle, die helfen wollten
                                          Bevor ich heute meinen neuen RaspberryPi 4 neu installiert habe, bin ich gestern noch einmal in die Einstellungen für die USB-Festplatte in den Router Fritz7490 gegangen. Auf der Seite im Router, wo der USB Anschluss aktiviert wird, steht die Adresse FRITZ.NAS in großen Buchstaben.
                                          Der Pfad ist somit
                                          FRITZ.NAS/TREKSTOR/Backup-ioBroker
                                          und nicht
                                          Danke noch mal an alle für Eure Hilfe und Geduld mit mir.
                                          Die Wiederherstellung von ioBroker von der USB-Festplatte an der Fritzbox funktionierte einwandfrei.
                                          Ein schönes Wochenende
                                          Franz
                                          E 1 Antwort Letzte Antwort
