  4. Zigbee Probleme
Zigbee Probleme
16 Beiträge 5 Kommentatoren 1.8k Aufrufe 4 Beobachtet
  • manuxiM manuxi
    @thomas-braun sagte in Zigbee Probleme:
    iob diag
    So, da wäre ein Ausschnitt des Logs:
    2024-03-04 00:25:24.545  - [31merror[39m: zigbee.0 (2553) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-03-04 00:25:24.546  - [31merror[39m: zigbee.0 (2553) unhandled promise rejection: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240))
    2024-03-04 00:25:24.547  - [31merror[39m: zigbee.0 (2553) Error: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240))
        at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:347:23)
        at async Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:20)
        at async Request.send (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/helpers/request.js:69:20)
        at async Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:572:28)
        at async Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js:101:13)
    2024-03-04 00:25:24.547  - [31merror[39m: zigbee.0 (2553) Exception-Code: 240: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240))
    2024-03-04 00:25:24.554  - [32minfo[39m: zigbee.0 (2553) cleaned everything up...
    2024-03-04 00:25:24.556  - [32minfo[39m: zigbee.0 (2553) Zigbee: disabling joining new devices.
    2024-03-04 00:25:25.054  - [32minfo[39m: zigbee.0 (2553) terminating
    2024-03-04 00:25:25.055  - [33mwarn[39m: zigbee.0 (2553) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-03-04 00:25:25.690  - [31merror[39m: host.iobroker-v8 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-03-04 00:25:25.691  - [32minfo[39m: host.iobroker-v8 Restart adapter system.adapter.zigbee.0 because enabled
    2024-03-04 00:25:55.765  - [32minfo[39m: host.iobroker-v8 instance system.adapter.zigbee.0 started with pid 29089
    2024-03-04 00:26:01.641  - [32minfo[39m: zigbee.0 (29089) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.19
    2024-03-04 00:26:01.927  - [32minfo[39m: zigbee.0 (29089) delete old Backup files. keep only last 10
    2024-03-04 00:26:01.929  - [32minfo[39m: zigbee.0 (29089) Starting Zigbee  npm ...
    2024-03-04 00:26:02.436  - [32minfo[39m: zigbee.0 (29089) Installed Version: iobroker.zigbee@1.10.1
    2024-03-04 00:26:03.443  - [32minfo[39m: javascript.0 (22208) script.js.common.Messages.MessageStateCreator: [MessageStateCreator] postMessage('DECONZ_WARNING', 'Zigbee offline! Adapter nicht verbunden!', 0)
    2024-03-04 00:26:03.923  - [32minfo[39m: zigbee.0 (29089) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
    2024-03-04 00:26:03.934  - [32minfo[39m: zigbee.0 (29089) Unable to disable LED, unsupported function.
    2024-03-04 00:26:03.936  - [32minfo[39m: zigbee.0 (29089)   --> transmitPower : high+
    2024-03-04 00:26:03.951  - [32minfo[39m: zigbee.0 (29089) Currently 22 devices are joined:
    2024-03-04 00:26:04.063  - [32minfo[39m: zigbee.0 (29089) 0xa4c138c3f54d3f1f (addr 14887): WSD500A - TuYa Temperature & humidity sensor (EndDevice)
    2024-03-04 00:26:04.068  - [32minfo[39m: zigbee.0 (29089) 0x84182600000d5240 (addr 15528): AB3257001NJ - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.070  - [32minfo[39m: zigbee.0 (29089) 0x00158d00083a6711 (addr 23501): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-03-04 00:26:04.071  - [32minfo[39m: zigbee.0 (29089) 0x7cb03eaa0a0c4b12 (addr 11146): AB3257001NJ - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.072  - [32minfo[39m: zigbee.0 (29089) 0xf0d1b8000013227c (addr 41013): AC10691 - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.073  - [32minfo[39m: zigbee.0 (29089) 0xf0d1b80000133e75 (addr 60765): AC10691 - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.074  - [32minfo[39m: zigbee.0 (29089) 0x00158d0008304103 (addr 26997): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-03-04 00:26:04.075  - [32minfo[39m: zigbee.0 (29089) 0x00158d000832a479 (addr 40749): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-03-04 00:26:04.076  - [32minfo[39m: zigbee.0 (29089) 0x7cb03eaa0a0ad2aa (addr 24605): AB3257001NJ - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.077  - [32minfo[39m: zigbee.0 (29089) 0x00158d000832a30a (addr 1675): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-03-04 00:26:04.078  - [32minfo[39m: zigbee.0 (29089) 0x00158d000913bf34 (addr 11596): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2024-03-04 00:26:04.079  - [32minfo[39m: zigbee.0 (29089) 0x7cb03eaa0a0ada8d (addr 12191): AB3257001NJ - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.080  - [32minfo[39m: zigbee.0 (29089) 0x00158d0008480d40 (addr 15921): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-03-04 00:26:04.082  - [32minfo[39m: zigbee.0 (29089) 0x00158d0008378d7a (addr 11521): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-03-04 00:26:04.084  - [32minfo[39m: zigbee.0 (29089) 0x7cb03eaa00a75dfa (addr 39278): AB3257001NJ - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.084  - [32minfo[39m: zigbee.0 (29089) 0x00158d00094d76ff (addr 34786): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
    2024-03-04 00:26:04.085  - [32minfo[39m: zigbee.0 (29089) 0x00158d000836e4b2 (addr 16960): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-03-04 00:26:04.087  - [32minfo[39m: zigbee.0 (29089) 0x00158d000830e5a5 (addr 30668): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-03-04 00:26:04.087  - [32minfo[39m: zigbee.0 (29089) 0x84182600000d0d1a (addr 17592): AB3257001NJ - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.089  - [32minfo[39m: zigbee.0 (29089) 0x7cb03eaa0a0c1fa9 (addr 21900): AB3257001NJ - OSRAM Smart+ plug (Router)
    2024-03-04 00:26:04.092  - [32minfo[39m: zigbee.0 (29089) 0xa4c1387267ac600e (addr 61457): ZTH08-E - TuYa Temperature and humidity sensor (EndDevice)
    2024-03-04 00:26:04.094  - [32minfo[39m: zigbee.0 (29089) 0xa4c1388dd402be3e (addr 4147): ZP01 - TuYa Motion sensor (EndDevice)
    2024-03-04 00:26:04.095  - [32minfo[39m: zigbee.0 (29089) Zigbee started
    2024-03-04 00:26:04.189  - [32minfo[39m: zigbee.0 (29089) deregister device Ping for deactivated device "0xa4c1388dd402be3e"
    2024-03-04 00:26:04.197  - [32minfo[39m: zigbee.0 (29089) debug devices set to []
    2024-03-04 00:26:04.225  - [32minfo[39m: javascript.0 (22208) script.js.common.Messages.MessageStateCreator: [MessageStateCreator] removeMessage('DECONZ_WARNING', 'Zigbee offline! Adapter nicht verbunden!')
    2024-03-04 00:26:30.579  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:28:29.777  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:30:34.159  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:30:59.106  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:33:15.606  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:35:19.481  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:37:24.023  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:39:28.573  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:41:33.092  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:43:37.810  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:47:53.434  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:49:51.410  - [32minfo[39m: zigbee.0 (29089) Device '0xa4c1387267ac600e' announced itself
    2024-03-04 00:50:32.567  - [31merror[39m: zigbee.0 (29089) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-03-04 00:50:32.567  - [31merror[39m: zigbee.0 (29089) unhandled promise rejection: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 51 - 61184 - 11 after 10000ms)
    2024-03-04 00:50:32.568  - [31merror[39m: zigbee.0 (29089) Error: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 51 - 61184 - 11 after 10000ms)
        at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:40:23)
        at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:423:47)
    2024-03-04 00:50:32.569  - [31merror[39m: zigbee.0 (29089) Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 51 - 61184 - 11 after 10000ms)
    2024-03-04 00:50:32.577  - [32minfo[39m: zigbee.0 (29089) cleaned everything up...
    2024-03-04 00:50:32.580  - [32minfo[39m: zigbee.0 (29089) Zigbee: disabling joining new devices.
    2024-03-04 00:50:33.079  - [32minfo[39m: zigbee.0 (29089) terminating
    2024-03-04 00:50:33.080  - [33mwarn[39m: zigbee.0 (29089) Terminated (UNCAUGHT_EXCEPTION): Without reason
    Der Tuya mit der id '0xa4c1387267ac600e' announced recht häufig...
    Ausgabe von iob diag:
    [snip]
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: moment@2.29.4 /opt/iobroker/node_modules/moment
    npm ERR! missing: moment-duration-format@^2.3.2, required by iobroker.javascript@7.8.0
    npm ERR! missing: moment-duration@^0.0.6, required by iobroker.javascript@7.8.0
    npm ERR! invalid: moment-timezone@0.5.43 /opt/iobroker/node_modules/moment-timezone
    [/snip]
    Die NPM-Erros hatte ich bis eben noch nicht bemerkt.
    Aber das ist letztens schonmal passiert:
    Hatte ein paar Bugs der Vis-2 reportet und auf Vis-2 2.9.35 gewechselt. Um die neue Version zu bekommen, hatte ich auf das Beta-Repo gewechselt und "iob update", danach "iob upgrade self" ausgeführt, um die 2.9.35 zu bekommen. Nach der Installation brav wieder auf das Stable Repo gewechselt.
    Ich bekam dann einen js-Fehler: moment.duration(...).format ist keine Funktion innerhalb eines Skripts. Es stellte sich heraus, dass ich moment-duration-format aus dem js-Adapter entfernen und wieder hinzufügen musste. Da die 2.9.35 etwas buggy war, habe ich dasselbe nochmal mit der 3.9.36 gemacht. Hab wohl das Entfernen & neu Hinzufügen der Module vergessen. Meine Scripte hatten sich nicht beschwert, daher hab ich das nicht mehr beachtet...
    Also gerade dann Module/Syntaxhilfe gerade wieder entfernt, JS-Instanz neu gestartet, wieder hinzugefügt und JS-Instanz neu gestartet.
    iob diag meldet jetzt keinen npm-Fehler mehr - vielleicht hat das ja die zigbee-Instanz gestört? Sehe da aber keinen Zusammenhang...
    (Kann ich diese npm-Fehler irgendwie vermeiden? Woher kommen die? Wechsel des Repos?)
    Hier die Kurzausgabe von iob diag nach dem Modul-Fix:
                            v.2023-10-10
    model name      : Intel(R) Atom(TM) CPU C3538 @ 2.10GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.0.1
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     28
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            /usr/bin/corepack       0.18.0
    Recommended versions are nodejs 18.19.1 and npm 10.2.4
    MEMORY:
    Mem:             19G         10G        950M        583M        8.4G        8.3G
    Swap:            14G        4.5G        9.6G
    Total:           34G         15G         10G
    Active iob-Instances:   49
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.19
                            admin                   6.13.16
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    + system.adapter.admin.0                  : admin                 : iobroker-v8                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : iobroker-v8                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : iobroker-v8                              -  enabled, port: 9082, bind: 0.0.0.0 (SSL), run as: ft
    + system.adapter.web.2                    : web                   : iobroker-v8                              -  enabled, port: 9084, bind: 0.0.0.0 (SSL), run as: gt
    Objects:                42941
    States:                 44027
    Size of iob-Database:
    51M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/states.jsonl
    @manuxi sagte in Zigbee Probleme:
    Die Langfassung bitte.
    Den Docker kannste aber schon mal auf einen aktuellen Stand bringen.
    manuxiM 1 Antwort Letzte Antwort
      manuxiM Offline
      manuxiM Offline
      manuxi
      @thomas-braun Docker dauert noch was, hab grad keine Zeit. Hier die iob diag Ausgabe:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Hardware Vendor : Synology Inc.
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.0.1
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       17:46:26 up 10 days, 18:25,  0 users,  load average: 3.24, 3.59, 3.66
      CPU threads: 4
      *** Time and Time Zones ***
      Wed Mar  6 16:46:26 UTC 2024
      Wed Mar  6 17:46:26 CET 2024
      CET +0100
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             19G         10G        1.1G        629M        7.9G        7.9G
      Swap:            14G        4.5G        9.6G
      Total:           34G         15G         10G
              19974 M total memory
              10990 M used memory
               8856 M active memory
               6477 M inactive memory
               1132 M free memory
                 73 M buffer memory
               7778 M swap cache
              14035 M total swap
               4467 M used swap
               9568 M free swap
      *** FILESYSTEM ***
      Filesystem             Type   Size  Used Avail Use% Mounted on
      /dev/mapper/cachedev_0 btrfs  214G  126G   88G  60% /
      tmpfs                  tmpfs   64M     0   64M   0% /dev
      tmpfs                  tmpfs  9.8G     0  9.8G   0% /sys/fs/cgroup
      shm                    tmpfs   64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev_0 btrfs  214G  126G   88G  60% /opt/iobroker
      /dev/mapper/cachedev_0 btrfs  214G  126G   88G  60% /etc/hosts
      sudo: unable to resolve host iobroker-v8: Name or service not known
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/bf0c59a675385d6269dbb83490810a1a4adb8c1bfb2b933357f738a870a23f2f]       btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=1238,subvol=/@syno/@docker/btrfs/subvolumes/bf0c59a675385d6269dbb83490810a1a4adb8c1bfb2b933357f738a870a23f2f
      |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker/data]        btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=258,subvol=/@syno/docker
      |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/54d552e5c72586629f085e0fba7641d05ff15e9d404b852905805f9af2c535ab/resolv.conf] btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/54d552e5c72586629f085e0fba7641d05ff15e9d404b852905805f9af2c535ab/hostname]    btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/54d552e5c72586629f085e0fba7641d05ff15e9d404b852905805f9af2c535ab/hosts]       btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      /var:
      33M     /var/
      31M     /var/lib
      18M     /var/lib/apt/lists
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      1.4G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      573M    /opt/iobroker/iobroker-data/
      500M    /opt/iobroker/iobroker-data/files
      90M     /opt/iobroker/iobroker-data/files/echarts.admin
      69M     /opt/iobroker/iobroker-data/files/vis.0
      58M     /opt/iobroker/iobroker-data/files/echarts
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: redis
      States  type: redis
      Core adapters versions
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   2
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker-v8                              -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-v8                              -  enabled
      + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker-v8                              -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker-v8                              -  enabled
        system.adapter.devices.0                : devices               : iobroker-v8                              - disabled
      + system.adapter.discovery.0              : discovery             : iobroker-v8                              - disabled
        system.adapter.dwd.0                    : dwd                   : iobroker-v8                              -  enabled
        system.adapter.echarts.0                : echarts               : iobroker-v8                              - disabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-v8                              -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker-v8                              -  enabled
        system.adapter.firetv.0                 : firetv                : iobroker-v8                              - disabled
      + system.adapter.followthesun.0           : followthesun          : iobroker-v8                              -  enabled
        system.adapter.ford.0                   : ford                  : iobroker-v8                              - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-v8                              -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker-v8                              - disabled
      + system.adapter.history.0                : history               : iobroker-v8                              -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : iobroker-v8                              -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker-v8                              -  enabled, port: 443
      + system.adapter.hue.1                    : hue                   : iobroker-v8                              -  enabled, port: 443
      + system.adapter.hue.2                    : hue                   : iobroker-v8                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.ical.1                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.ical.2                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.ical.3                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.ical.4                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker-v8                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-v8                              - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker-v8                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker-v8                              -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-v8                              -  enabled
      + system.adapter.logparser.0              : logparser             : iobroker-v8                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-v8                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.musiccast.0              : musiccast             : iobroker-v8                              - disabled
      + system.adapter.net-tools.0              : net-tools             : iobroker-v8                              -  enabled
      + system.adapter.nina.0                   : nina                  : iobroker-v8                              -  enabled
      + system.adapter.nut.0                    : nut                   : iobroker-v8                              -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker-v8                              - disabled
        system.adapter.parcel.0                 : parcel                : iobroker-v8                              - disabled
      + system.adapter.pi-hole.0                : pi-hole               : iobroker-v8                              -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker-v8                              -  enabled
        system.adapter.plex.0                   : plex                  : iobroker-v8                              - disabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker-v8                              -  enabled
        system.adapter.pushover.0               : pushover              : iobroker-v8                              - disabled
      + system.adapter.ring.0                   : ring                  : iobroker-v8                              -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : iobroker-v8                              -  enabled, port: 45000, bind: 0.0.0.0
      + system.adapter.sayit.0                  : sayit                 : iobroker-v8                              -  enabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker-v8                              -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker-v8                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iobroker-v8                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.slideshow.0              : slideshow             : iobroker-v8                              -  enabled
      + system.adapter.snmp.0                   : snmp                  : iobroker-v8                              -  enabled
      + system.adapter.socketio.0               : socketio              : iobroker-v8                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sony-bravia.0            : sony-bravia           : iobroker-v8                              - disabled
      + system.adapter.spotify-premium.0        : spotify-premium       : iobroker-v8                              -  enabled
      + system.adapter.statistics.0             : statistics            : iobroker-v8                              -  enabled
      + system.adapter.synology.0               : synology              : iobroker-v8                              -  enabled, port: 5441
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-v8                              -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker-v8                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker-v8                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker-v8                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker-v8                              -  enabled
      + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-v8                              -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker-v8                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-v8                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-v8                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-v8                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-v8                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-v8                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-v8                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-v8                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-v8                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-v8                              - disabled
        system.adapter.vis.0                    : vis                   : iobroker-v8                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-v8                              -  enabled
      + system.adapter.yamaha.0                 : yamaha                : iobroker-v8                              - disabled
        system.adapter.yr.0                     : yr                    : iobroker-v8                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker-v8                              -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "bosch-ebike"  : 0.0.3    , installed 0.1.5
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.3  [Updatable]
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "firetv"       : 2.0.2    , installed 2.0.2
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "ford"         : 0.0.14   , installed 0.0.14
      Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "hue"          : 3.10.2   , installed 3.10.2
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "plex"         : 1.1.4    , installed 1.1.4
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "ring"         : 5.0.10   , installed 5.0.10
      Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "snmp"         : 3.1.0    , installed 3.1.0
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
      Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.36
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        42133
      States:         43627
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 28
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:16509         0.0.0.0:*               LISTEN      0          146594     -
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          51894      -
      tcp        0      0 0.0.0.0:4190            0.0.0.0:*               LISTEN      0          218602357  -
      tcp        0      0 0.0.0.0:9086            0.0.0.0:*               LISTEN      0          108235     -
      tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          127574     -
      tcp        0      0 0.0.0.0:8800            0.0.0.0:*               LISTEN      0          112762     -
      tcp        0      0 0.0.0.0:5440            0.0.0.0:*               LISTEN      0          45392      -
      tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      0          218602431  -
      tcp        0      0 0.0.0.0:7777            0.0.0.0:*               LISTEN      0          134249     -
      tcp        0      0 0.0.0.0:5441            0.0.0.0:*               LISTEN      0          45394      -
      tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          43736      -
      tcp        0      0 0.0.0.0:20002           0.0.0.0:*               LISTEN      0          140358273  -
      tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          189967     -
      tcp        0      0 0.0.0.0:3010            0.0.0.0:*               LISTEN      0          113523     -
      tcp        0      0 0.0.0.0:7010            0.0.0.0:*               LISTEN      0          100791     -
      tcp        0      0 0.0.0.0:20003           0.0.0.0:*               LISTEN      0          140358275  -
      tcp        0      0 0.0.0.0:7011            0.0.0.0:*               LISTEN      0          100793     -
      tcp        0      0 127.0.0.1:37316         0.0.0.0:*               LISTEN      297536     47407154   -
      tcp        0      0 127.0.0.1:11332         0.0.0.0:*               LISTEN      0          397322     -
      tcp        0      0 0.0.0.0:2020            0.0.0.0:*               LISTEN      0          134251     -
      tcp        0      0 127.0.0.1:11333         0.0.0.0:*               LISTEN      0          397335     -
      tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          36874      -
      tcp        0      0 127.0.0.1:11334         0.0.0.0:*               LISTEN      0          397330     -
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      0          219838045  -
      tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1000       103592157  1721/io.sainlogic.0
      tcp        0      0 127.0.0.1:46632         0.0.0.0:*               LISTEN      297536     47417515   -
      tcp        0      0 0.0.0.0:9800            0.0.0.0:*               LISTEN      0          109849     -
      tcp        0      0 0.0.0.0:2249            0.0.0.0:*               LISTEN      0          287500594  -
      tcp        0      0 127.0.0.1:33833         0.0.0.0:*               LISTEN      297536     47418857   -
      tcp        0      0 0.0.0.0:9353            0.0.0.0:*               LISTEN      0          134247     -
      tcp        0      0 0.0.0.0:8010            0.0.0.0:*               LISTEN      0          106925     -
      tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN      0          140358271  -
      tcp        0      0 0.0.0.0:587             0.0.0.0:*               LISTEN      0          303744     -
      tcp        0      0 0.0.0.0:3307            0.0.0.0:*               LISTEN      66         121959     -
      tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      0          109887     -
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          51895      -
      tcp        0      0 127.0.0.1:2380          0.0.0.0:*               LISTEN      0          105477     -
      tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          167240     -
      tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      0          218602430  -
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          45396      -
      tcp        0      0 0.0.0.0:31313           0.0.0.0:*               LISTEN      0          287500590  -
      tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      297536     47395761   -
      tcp        0      0 0.0.0.0:465             0.0.0.0:*               LISTEN      0          303738     -
      tcp        0      0 127.0.0.1:2385          0.0.0.0:*               LISTEN      0          154472     -
      tcp        0      0 127.0.0.1:5555          0.0.0.0:*               LISTEN      0          182337     -
      tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN      0          143463     -
      tcp        0      0 0.0.0.0:12340           0.0.0.0:*               LISTEN      0          218605575  -
      tcp        0      0 0.0.0.0:8500            0.0.0.0:*               LISTEN      259775     149142     -
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          219838039  -
      tcp        0      0 127.0.0.1:8181          0.0.0.0:*               LISTEN      0          219839124  -
      tcp        0      0 192.168.178.10:8181     0.0.0.0:*               LISTEN      0          219839123  -
      tcp        0      0 0.0.0.0:24245           0.0.0.0:*               LISTEN      0          218602440  -
      tcp        0      0 0.0.0.0:9526            0.0.0.0:*               LISTEN      1          388633     -
      tcp        0      0 0.0.0.0:5590            0.0.0.0:*               LISTEN      0          178510     -
      tcp        0      0 0.0.0.0:8502            0.0.0.0:*               LISTEN      259775     151634     -
      tcp        0      0 0.0.0.0:8086            0.0.0.0:*               LISTEN      0          110435     -
      tcp        0      0 0.0.0.0:5591            0.0.0.0:*               LISTEN      0          178512     -
      tcp        0      0 127.0.0.1:38008         0.0.0.0:*               LISTEN      0          140358269  -
      tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      297536     47407209   -
      tcp        0      0 0.0.0.0:8088            0.0.0.0:*               LISTEN      0          108906     -
      tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         93671      -
      tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          34828      -
      tcp        0      0 127.0.0.1:8505          0.0.0.0:*               LISTEN      259775     390672     -
      tcp        0      0 0.0.0.0:9529            0.0.0.0:*               LISTEN      1          388634     -
      tcp        0      0 0.0.0.0:25              0.0.0.0:*               LISTEN      0          303729     -
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       103557099  515/io.shelly.0
      tcp        0      0 0.0.0.0:9530            0.0.0.0:*               LISTEN      259775     389205     -
      tcp        0      0 127.0.0.1:8506          0.0.0.0:*               LISTEN      0          289683     -
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       103554540  436/io.mqtt.0
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          45398      -
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       103554541  436/io.mqtt.0
      tcp        0      0 127.0.0.1:41980         0.0.0.0:*               LISTEN      297536     47417255   -
      tcp        0      0 127.0.0.1:41436         0.0.0.0:*               LISTEN      297536     47417242   -
      tcp        0      0 127.0.0.1:30300         0.0.0.0:*               LISTEN      0          158784     -
      tcp6       0      0 :::3261                 :::*                    LISTEN      0          49934      -
      tcp6       0      0 :::445                  :::*                    LISTEN      0          51892      -
      tcp6       0      0 :::4190                 :::*                    LISTEN      0          218602358  -
      tcp6       0      0 :::9086                 :::*                    LISTEN      0          108238     -
      tcp6       0      0 :::5566                 :::*                    LISTEN      0          78523      -
      tcp6       0      0 :::3263                 :::*                    LISTEN      0          49932      -
      tcp6       0      0 :::8000                 :::*                    LISTEN      1000       103607829  1902/io.upnp.0
      tcp6       0      0 :::8800                 :::*                    LISTEN      0          111717     -
      tcp6       0      0 :::3264                 :::*                    LISTEN      0          49935      -
      tcp6       0      0 :::5440                 :::*                    LISTEN      0          45393      -
      tcp6       0      0 :::3265                 :::*                    LISTEN      0          218579924  -
      tcp6       0      0 :::7777                 :::*                    LISTEN      0          134250     -
      tcp6       0      0 :::5441                 :::*                    LISTEN      0          45395      -
      tcp6       0      0 :::20002                :::*                    LISTEN      0          140358274  -
      tcp6       0      0 :::6690                 :::*                    LISTEN      0          189968     -
      tcp6       0      0 :::3010                 :::*                    LISTEN      0          114116     -
      tcp6       0      0 :::7010                 :::*                    LISTEN      0          100792     -
      tcp6       0      0 :::20003                :::*                    LISTEN      0          140358276  -
      tcp6       0      0 :::7011                 :::*                    LISTEN      0          100794     -
      tcp6       0      0 :::2020                 :::*                    LISTEN      0          134252     -
      tcp6       0      0 ::1:4711                :::*                    LISTEN      0          219838046  -
      tcp6       0      0 :::9800                 :::*                    LISTEN      0          112732     -
      tcp6       0      0 :::2249                 :::*                    LISTEN      0          287500596  -
      tcp6       0      0 :::6281                 :::*                    LISTEN      0          181331025  -
      tcp6       0      0 :::9353                 :::*                    LISTEN      0          134248     -
      tcp6       0      0 :::8010                 :::*                    LISTEN      0          105886     -
      tcp6       0      0 ::1:38443               :::*                    LISTEN      0          140358272  -
      tcp6       0      0 :::587                  :::*                    LISTEN      0          303745     -
      tcp6       0      0 :::6379                 :::*                    LISTEN      0          109888     -
      tcp6       0      0 :::139                  :::*                    LISTEN      0          51893      -
      tcp6       0      0 :::5357                 :::*                    LISTEN      0          167241     -
      tcp6       0      0 :::32400                :::*                    LISTEN      297536     47395759   -
      tcp6       0      0 :::80                   :::*                    LISTEN      0          45397      -
      tcp6       0      0 :::31313                :::*                    LISTEN      0          287500592  -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       103535165  151/io.admin.0
      tcp6       0      0 :::465                  :::*                    LISTEN      0          303739     -
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       103608111  2014/io.web.0
      tcp6       0      0 :::12340                :::*                    LISTEN      0          218605576  -
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       103598522  1802/io.socketio.0
      tcp6       0      0 :::8500                 :::*                    LISTEN      259775     149143     -
      tcp6       0      0 :::53                   :::*                    LISTEN      0          219838041  -
      tcp6       0      0 :::8181                 :::*                    LISTEN      0          219839125  -
      tcp6       0      0 :::5590                 :::*                    LISTEN      0          178511     -
      tcp6       0      0 :::8502                 :::*                    LISTEN      259775     151635     -
      tcp6       0      0 :::8086                 :::*                    LISTEN      0          110440     -
      tcp6       0      0 :::5591                 :::*                    LISTEN      0          178513     -
      tcp6       0      0 ::1:38008               :::*                    LISTEN      0          140358270  -
      tcp6       0      0 :::8504                 :::*                    LISTEN      0          152312     -
      tcp6       0      0 :::8088                 :::*                    LISTEN      0          106933     -
      tcp6       0      0 :::25                   :::*                    LISTEN      0          303730     -
      tcp6       0      0 :::9082                 :::*                    LISTEN      1000       103611733  2032/io.web.1
      tcp6       0      0 :::8507                 :::*                    LISTEN      0          153880     -
      tcp6       0      0 :::443                  :::*                    LISTEN      0          45399      -
      tcp6       0      0 :::9084                 :::*                    LISTEN      1000       103614829  2049/io.web.2
      udp        0      0 0.0.0.0:40969           0.0.0.0:*                           1000       103604655  1902/io.upnp.0
      udp        0      0 0.0.0.0:8502            0.0.0.0:*                           259775     151638     -
      udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          34128      -
      udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          34127      -
      udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          34126      -
      udp        0      0 0.0.0.0:42795           0.0.0.0:*                           1000       103604656  1902/io.upnp.0
      udp        0      0 169.254.115.203:43843   0.0.0.0:*                           297536     47407175   -
      udp        0      0 192.168.178.10:43878    0.0.0.0:*                           297536     47407173   -
      udp        0      0 10.0.1.3:60919          0.0.0.0:*                           297536     47407174   -
      udp        0      0 0.0.0.0:47530           0.0.0.0:*                           1000       103604654  1902/io.upnp.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          219838038  -
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          33126      -
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          39004      -
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          310033777  -
      udp        0      0 192.168.178.10:137      0.0.0.0:*                           0          310033776  -
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          310033680  -
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          310033779  -
      udp        0      0 192.168.178.10:138      0.0.0.0:*                           0          310033778  -
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          310033681  -
      udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          43735      -
      udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          39002      -
      udp        0      0 0.0.0.0:33772           0.0.0.0:*                           1000       103596159  1785/io.snmp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       103607792  1902/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       103607791  1902/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       103607790  1902/io.upnp.0
      udp        0      0 0.0.0.0:1901            0.0.0.0:*                           297536     47407172   -
      udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         163698     -
      udp        0      0 0.0.0.0:37219           0.0.0.0:*                           0          37205      -
      udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       103563491  642/io.tr-064.0
      udp        0      0 172.18.0.1:5353         0.0.0.0:*                           1000       103563490  642/io.tr-064.0
      udp        0      0 192.168.178.10:5353     0.0.0.0:*                           1000       103563489  642/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          37203      -
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       103559458  544/io.shelly.1
      udp6       0      0 :::55825                :::*                                0          37206      -
      udp6       0      0 :::8502                 :::*                                259775     151639     -
      udp6       0      0 :::8503                 :::*                                0          153861     -
      udp6       0      0 :::53                   :::*                                0          219838040  -
      udp6       0      0 :::123                  :::*                                0          39005      -
      udp6       0      0 ::1:323                 :::*                                0          39003      -
      udp6       0      0 fe80::211:32ff:fe9b:546 :::*                                0          310018732  -
      udp6       0      0 :::3702                 :::*                                99         163700     -
      udp6       0      0 :::5353                 :::*                                0          37204      -
      2024-03-06 17:46:52.261  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:46:57.346  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:00.277  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:03.178  - info: mqtt.0 (436) Client [SL3P_35972DE4] connected with secret 1709743623178_4207
      2024-03-06 17:47:04.325  - info: mqtt.0 (436) Client [SL3P_35972DE4] subscribes on "mqtt.0.nuki.35972DE4.lockAction"
      2024-03-06 17:47:04.436  - info: mqtt.0 (436) Client [SL3P_35972DE4] subscribes on "mqtt.0.nuki.35972DE4.lock"
      2024-03-06 17:47:04.525  - info: mqtt.0 (436) Client [SL3P_35972DE4] publishOnSubscribe
      2024-03-06 17:47:04.532  - info: mqtt.0 (436) Client [SL3P_35972DE4] subscribes on "mqtt.0.nuki.35972DE4.unlock"
      2024-03-06 17:47:04.636  - info: mqtt.0 (436) Client [SL3P_35972DE4] publishOnSubscribe
      2024-03-06 17:47:04.732  - info: mqtt.0 (436) Client [SL3P_35972DE4] publishOnSubscribe
      2024-03-06 17:47:05.357  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:08.283  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:13.369  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:15.204  - info: javascript.0 (3093) script.js.common.Status.device_power: Vis battery level set to 6.
      2024-03-06 17:47:15.205  - info: javascript.0 (3093) script.js.common.Status.device_power: Galaxy Note 10.1 2014 Edition: BatteryLevel: 28, PlugEnabled: true.
      2024-03-06 17:47:16.335  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:17.490  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:20.318  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:22.423  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:25.350  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:28.427  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:31.356  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:35.419  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:38.370  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      • manuxiM manuxi
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.0.1
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
        CET +0100
        Etc/UTC
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:            14G        4.5G        9.6G
        Total:           34G         15G         10G
                10990 M used memory
                 1132 M free memory
                   73 M buffer memory
                 7778 M swap cache
                14035 M total swap
                 4467 M used swap
                 9568 M free swap
        *** FILESYSTEM ***
        /var:
        33M     /var/
        31M     /var/lib
        18M     /var/lib/apt
        13M     /var/lib/dpkg
        USB-Devices by-id:
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: redis
        States  type: redis
        admin:          6.13.16
        javascript:     7.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        42133
        States:         43627
        Pending Updates: 28
        @manuxi
        Ich hab Zeit.
          @manuxi
          Ich hab Zeit.
          manuxiM Offline
          manuxiM Offline
          manuxi
          schrieb am zuletzt editiert von manuxi
          @thomas-braun Aktuelle Fehlermeldung
          zigbee.0
          2024-03-07 00:10:16.551	error	Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 18 - 61184 - 11 after 10000ms)
          zigbee.0
          2024-03-07 00:10:16.551	error	Error: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 18 - 61184 - 11 after 10000ms) at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:40:23) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:423:47) at async Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:20) at async Request.send (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/helpers/request.js:69:20) at async Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:572:28) at async Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js:101:13)
          zigbee.0
          2024-03-07 00:10:16.550	error	unhandled promise rejection: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 18 - 61184 - 11 after 10000ms)
          zigbee.0
          2024-03-07 00:10:16.550	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          Scheint wohl der Tuya zu sein - bzw. die nicht gefangene Exception...
          • manuxiM manuxi
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            arteckA Offline
            arteckA Offline
            arteck
            @manuxi installier mal die GIT version
            manuxiM 2 Antworten Letzte Antwort
            • arteckA arteck
              manuxiM Offline
              manuxiM Offline
              manuxi
              @arteck Alles klar, werd ich machen (und berichten).
              • arteckA arteck
                manuxiM Offline
                manuxiM Offline
                manuxi
                @arteck Hats leider nicht gebracht, eben wieder abgeschmiert. Meldung "Restart loop detected"
                • manuxiM manuxi
                  manuxiM Offline
                  manuxiM Offline
                  manuxi
                  Ich habe jetzt ein Script erstellt, was erkennen sollte, wenn die Instanz hängt und nach 20s erneut startet. Ich konnte noch nicht verifizieren, dass das auch klappt.
                  const idInst = 'system.adapter.zigbee.0';
                  const idAlive = idInst + '.alive';
                  on({id: idAlive, change: 'ne', val: false}, function() {
                      setTimeout(function() {
                          // Adapter nach 20 Sekunden starten
                          setState(idAlive, true);
                          sendTo("telegram", "send", {
                              text: 'Zigbee Instance has been restarted!'
                      }, 20000);
                  @Thomas-Braun mein ioBroker ist jetzt auf dem neuesten Stand. Werde iob diag posten, wenn das alles nix bringt.
                  Ralla66R 1 Antwort Letzte Antwort
                  • manuxiM manuxi
                        }, 20000);
                    Ralla66R Offline
                    Ralla66R Offline
                    Ralla66
                    @manuxi
                    Dann lösche den TuYa ZTH08_E aus dem Adapter und mache den Stromlos.
                    Dann weißte doch ob das der Fehler ist.
                    Einmal dabei, den ZP01 direkt mit weg.
                    • Ralla66R Ralla66
                      @manuxi
                      manuxiM Offline
                      manuxiM Offline
                      manuxi
                      So, das Script scheint zu laufen, alelrdings in sehr regelmäßigen Abständen - das kann kein Zufall sein. Telegram meldet seit heute Nacht im Abstand von genau einer Stunde jeweils, dass der Adapter neu gestartet wurde:
                      00:26 Zigbee Instance has been restarted!
                      01:26 Zigbee Instance has been restarted!
                      02:26 Zigbee Instance has been restarted!
                      0926 Zigbee Instance has been restarted!
                      @Ralla66 der ZP01 ist bereits abgeschaltet. Werde das wohl für den Tuya auch machen.
                      Allerdings bin ich der Meinung, dass das bereits im Code abgefangen werden müsste...
                      • manuxiM manuxi
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        Da hast du prinzipiell recht. Allerdings steht dem das Geschäftsmodell von TuYa entgegen:
                        Sie liefern Bausteine damit eine Firma eigene zigbee Geräte bauen kann. Dabei haben die zigbee Module gewisse Eigenschaften, von denen der OEM Hersteller einige anpassen muss. Das geschieht mal besser / mal schlechter und führt dazu das sich Geräte mit unterschiedlichen Fähigkeiten fast identisch bei Zigbee anmelden. Die meisten TuYa Zigbee Geräte nutzen zusätzlich leider nicht die fest vorgegebenen Zigbee Cluster sondern bilden identische Funktionen über einen TuYa spezifischen Cluster ab bei dem fast alles möglich ist.
                        An dieser Stelle entsteht auch dein Fehler - der Zigbee Adapter erwartet eine bestimmte Antwort vom Gerät, bekommt diese aber nicht.
                        Eigentlich müsste geprüft werden was an deinen Geräten anders ist als bei denen die eingebunden wurden. Das ist aber nicht trivial und benötigt Zugriff auf die Geräte.
                        A.
