  4. Login funktioniert nach Backup-Wiederherstellung nicht mehr
19 Beiträge 5 Kommentatoren 764 Aufrufe 4 Beobachtet
  • P Offline
    Pauli290787
    *** iob diag is starting up, please wait ***
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: rsp-automation
           Icon name: computer
              Kernel: Linux 6.1.0-rpi8-rpi-v8
        Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     10:13:11 up 11:58,  2 users,  load average: 0.23, 0.33, 0.54
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-03-09 10:13:11 CET
               Universal time: Sat 2024-03-09 09:13:11 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            4.0G        742M        1.1G        1.2M        2.2G        3.2G
    Swap:           104M          0B        104M
    Total:          4.1G        742M        1.2G
             3792 M total memory
              708 M used memory
              861 M active memory
             1536 M inactive memory
             1080 M free memory
              154 M buffer memory
             1925 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/sda2      ext4       56G  5.5G   49G  11% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Mar  8 22:15:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:50:4B:F4 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=31733faa-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Mar  8 22:15:04 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Mar  8 22:15:06 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    695M	/var/
    376M	/var/cache
    370M	/var/cache/apt
    258M	/var/cache/apt/archives
    169M	/var/lib
    Archived and active journals take up 49.2M in the file system.
    /opt/iobroker/backups:
    11M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    500M	/opt/iobroker/iobroker-data/
    451M	/opt/iobroker/iobroker-data/files
    89M	/opt/iobroker/iobroker-data/files/echarts.admin
    57M	/opt/iobroker/iobroker-data/files/javascript.admin
    57M	/opt/iobroker/iobroker-data/files/echarts
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    USB-Devices by-id:
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.1
    /usr/bin/node 		v18.19.1
    /usr/bin/npm 		10.2.4
    /usr/bin/npx 		10.2.4
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.19
    admin: 		6.13.16
    javascript: 	7.8.0
    Adapters from github: 	6
    Adapter State
    + system.adapter.admin.0                  : admin                 : rsp-automation                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : rsp-automation                           - disabled
      system.adapter.awtrix-light.0           : awtrix-light          : rsp-automation                           - disabled
    + system.adapter.backitup.0               : backitup              : rsp-automation                           -  enabled
      system.adapter.birthdays.0              : birthdays             : rsp-automation                           - disabled
      system.adapter.ble.0                    : ble                   : rsp-automation                           - disabled
      system.adapter.device-reminder.0        : device-reminder       : rsp-automation                           - disabled
      system.adapter.devices.0                : devices               : rsp-automation                           - disabled
      system.adapter.discovery.0              : discovery             : rsp-automation                           - disabled
      system.adapter.echarts.0                : echarts               : rsp-automation                           - disabled
      system.adapter.email.0                  : email                 : rsp-automation                           - disabled
      system.adapter.enigma2.0                : enigma2               : rsp-automation                           - disabled
      system.adapter.feiertage.0              : feiertage             : rsp-automation                           - disabled
      system.adapter.fhem.0                   : fhem                  : rsp-automation                           - disabled, port: 7072
      system.adapter.harmony.0                : harmony               : rsp-automation                           - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : rsp-automation                           - disabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : rsp-automation                           - disabled, port: 0
      system.adapter.homeconnect.0            : homeconnect           : rsp-automation                           - disabled
      system.adapter.ical.0                   : ical                  : rsp-automation                           - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : rsp-automation                           - disabled
      system.adapter.influxdb.0               : influxdb              : rsp-automation                           - disabled, port: 3004
      system.adapter.info.0                   : info                  : rsp-automation                           - disabled
      system.adapter.iot.0                    : iot                   : rsp-automation                           - disabled
      system.adapter.jarvis.0                 : jarvis                : rsp-automation                           - disabled
      system.adapter.javascript.0             : javascript            : rsp-automation                           - disabled
      system.adapter.klipper-moonraker.0      : klipper-moonraker     : rsp-automation                           - disabled
      system.adapter.knx.0                    : knx                   : rsp-automation                           - disabled, bind: 10.0.0.37
      system.adapter.life360.0                : life360               : rsp-automation                           - disabled
      system.adapter.linux-control.0          : linux-control         : rsp-automation                           - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : rsp-automation                           - disabled, port: 54321
      system.adapter.milight-smart-light.0    : milight-smart-light   : rsp-automation                           - disabled
      system.adapter.mqtt.0                   : mqtt                  : rsp-automation                           - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.mytime.0                 : mytime                : rsp-automation                           - disabled
      system.adapter.netatmo.0                : netatmo               : rsp-automation                           - disabled
      system.adapter.notification-manager.0   : notification-manager  : rsp-automation                           - disabled
      system.adapter.nuki-extended.0          : nuki-extended         : rsp-automation                           - disabled
      system.adapter.openknx.0                : openknx               : rsp-automation                           - disabled
      system.adapter.owntracks.0              : owntracks             : rsp-automation                           - disabled, port: 1885, bind: 0.0.0.0
      system.adapter.pi-hole.0                : pi-hole               : rsp-automation                           - disabled
      system.adapter.ping.0                   : ping                  : rsp-automation                           - disabled
      system.adapter.pjlinkv2.0               : pjlinkv2              : rsp-automation                           - disabled, port: 3461
      system.adapter.pushover.0               : pushover              : rsp-automation                           - disabled
      system.adapter.rpi2.0                   : rpi2                  : rsp-automation                           - disabled
      system.adapter.sayit.0                  : sayit                 : rsp-automation                           - disabled, port: 0
      system.adapter.scenes.0                 : scenes                : rsp-automation                           - disabled
      system.adapter.shelly.0                 : shelly                : rsp-automation                           - disabled, port: 1889, bind: 10.0.0.37
      system.adapter.shelly.1                 : shelly                : rsp-automation                           - disabled, port: 1899, bind: 10.0.0.37
      system.adapter.shuttercontrol.0         : shuttercontrol        : rsp-automation                           - disabled
      system.adapter.signal-cmb.0             : signal-cmb            : rsp-automation                           - disabled
      system.adapter.simple-api.0             : simple-api            : rsp-automation                           - disabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartcontrol.0           : smartcontrol          : rsp-automation                           - disabled
      system.adapter.smartmeter.0             : smartmeter            : rsp-automation                           - disabled
      system.adapter.sonoff.0                 : sonoff                : rsp-automation                           - disabled, port: 1898, bind: 0.0.0.0
      system.adapter.sonos.0                  : sonos                 : rsp-automation                           - disabled
      system.adapter.synology.0               : synology              : rsp-automation                           - disabled, port: 5001
      system.adapter.tado.0                   : tado                  : rsp-automation                           - disabled
      system.adapter.telegram.0               : telegram              : rsp-automation                           - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : rsp-automation                           - disabled
      system.adapter.tr-064.0                 : tr-064                : rsp-automation                           - disabled
      system.adapter.trashschedule.0          : trashschedule         : rsp-automation                           - disabled
      system.adapter.unifi.0                  : unifi                 : rsp-automation                           - disabled
      system.adapter.vis-players.0            : vis                   : rsp-automation                           - disabled
      system.adapter.vis.0                    : vis                   : rsp-automation                           - disabled
      system.adapter.web-speedy.0             : web-speedy            : rsp-automation                           - disabled
      system.adapter.web.0                    : web                   : rsp-automation                           - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wiobrowser.0             : wiobrowser            : rsp-automation                           - disabled, port: 5000
      system.adapter.wled.0                   : wled                  : rsp-automation                           - disabled
      system.adapter.worx.0                   : worx                  : rsp-automation                           - disabled
      system.adapter.zigbee.0                 : zigbee                : rsp-automation                           - disabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "awtrix-light" : 0.13.1   , installed 0.15.0
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fhem"         : 2.0.5    , installed 2.0.5
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "knx"          : 2.0.24   , installed 2.0.24
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
    Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "notification-manager": 1.0.0, installed 1.0.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "openknx"      : 0.7.2    , installed 0.7.2
    Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "sayit"        : 3.0.5    , installed 4.0.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "tado"         : 0.5.3    , installed 0.5.3
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects: 	18459
    States: 	14746
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:6 https://apt.debmatic.de/debmatic stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1999            0.0.0.0:*               LISTEN      0          30578      5870/lighttpd
    tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      0          30584      5870/lighttpd
    tcp        0      0 0.0.0.0:2000            0.0.0.0:*               LISTEN      0          30586      5870/lighttpd
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      0          30580      5870/lighttpd
    tcp        0      0 0.0.0.0:8181            0.0.0.0:*               LISTEN      0          30576      5870/lighttpd
    tcp        0      0 0.0.0.0:8183            0.0.0.0:*               LISTEN      0          34710      7410/ReGaHss.commun
    tcp        0      0 0.0.0.0:31999           0.0.0.0:*               LISTEN      0          35389      7410/ReGaHss.commun
    tcp        0      0 127.0.0.1:30080         0.0.0.0:*               LISTEN      0          34645      7287/lighttpd
    tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      0          30582      5870/lighttpd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53580      13989/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53587      13989/iobroker.js-c
    tcp        0      0 0.0.0.0:88              0.0.0.0:*               LISTEN      0          30575      5870/lighttpd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13285      767/sshd: /usr/sbin
    tcp6       0      0 :::1999                 :::*                    LISTEN      0          30579      5870/lighttpd
    tcp6       0      0 :::2001                 :::*                    LISTEN      0          30585      5870/lighttpd
    tcp6       0      0 :::2000                 :::*                    LISTEN      0          30587      5870/lighttpd
    tcp6       0      0 :::2010                 :::*                    LISTEN      0          30581      5870/lighttpd
    tcp6       0      0 :::8181                 :::*                    LISTEN      0          30577      5870/lighttpd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       56380      14014/io.admin.0
    tcp6       0      0 :::9292                 :::*                    LISTEN      0          30583      5870/lighttpd
    tcp6       0      0 :::39292                :::*                    LISTEN      0          37306      7331/java
    tcp6       0      0 :::88                   :::*                    LISTEN      0          30574      5870/lighttpd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13287      767/sshd: /usr/sbin
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          35249      7267/ssdpd
    udp        0      0 127.0.0.1:1998          0.0.0.0:*                           0          34711      7410/ReGaHss.commun
    udp        0      0 127.0.0.1:8182          0.0.0.0:*                           0          34644      7275/hss_led
    udp        0      0 0.0.0.0:43439           0.0.0.0:*                           0          34629      7252/eq3configd
    udp        0      0 0.0.0.0:55861           0.0.0.0:*                           104        12185      542/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12183      542/avahi-daemon: r
    udp6       0      0 :::55181                :::*                                0          37299      7331/java
    udp6       0      0 :::33071                :::*                                104        12186      542/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        12184      542/avahi-daemon: r
    2024-03-09 09:37:53.785  - info: host.rsp-automation iobroker install mytime@0.7.12 using installedFrom
    2024-03-09 09:37:54.648  - info: host.rsp-automation instance system.adapter.backitup.0 started with pid 14038
    2024-03-09 09:37:55.457  - info: admin.0 (14014) received all objects
    2024-03-09 09:37:56.272  - info: admin.0 (14014) Request actual repository...
    2024-03-09 09:37:56.634  - info: admin.0 (14014) socket.io server listening on port 8081
    2024-03-09 09:37:56.640  - info: admin.0 (14014) http server listening on port 8081
    2024-03-09 09:37:56.640  - info: admin.0 (14014) Use link "http://127.0.0.1:8081" to configure.
    2024-03-09 09:37:56.968  - info: host.rsp-automation Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2024-03-09 09:37:58.321  - info: backitup.0 (14038) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2024-03-09 09:37:58.738  - error: host.rsp-automation iobroker npm-install: host.rsp-automation Unknown packetName mytime. Please install packages from outside the repository using npm!
    2024-03-09 09:37:59.339  - info: admin.0 (14014) Repository received successfully.
    2024-03-09 09:37:59.355  - info: backitup.0 (14038) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.1, js-controller: 5.0.19
    2024-03-09 09:37:59.447  - info: backitup.0 (14038) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2024-03-09 09:38:00.175  - info: host.rsp-automation iobroker npm-install: exit 12
    2024-03-09 09:38:01.176  - warn: host.rsp-automation startInstance cannot find adapter "vis-players@1.5.4". Try to install it... 1 attempt
    2024-03-09 09:38:01.177  - info: host.rsp-automation iobroker install vis@1.5.4 using installedFrom
    2024-03-09 09:38:03.073  - info: host.rsp-automation iobroker npm-install: adapter "vis" already installed. Use "upgrade" to upgrade to a newer version.
    2024-03-09 09:38:04.099  - info: host.rsp-automation iobroker npm-install: exit 51
    2024-03-09 09:38:05.101  - warn: host.rsp-automation startInstance cannot find adapter "web-speedy@0.2.0". Try to install it... 1 attempt
    2024-03-09 09:38:05.101  - info: host.rsp-automation iobroker install web-speedy@0.2.0 using installedFrom
    2024-03-09 09:38:07.745  - error: host.rsp-automation iobroker npm-install: host.rsp-automation Unknown packetName web-speedy. Please install packages from outside the repository using npm!
    2024-03-09 09:38:08.795  - info: host.rsp-automation iobroker npm-install: exit 12
    2024-03-09 09:38:11.915  - error: backitup.0 (14038) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.0.0.175/ioBroker-Backup /opt/iobroker/backups
    mount error(113): could not connect to 10.0.0.175Unable to find suitable address.
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
    			v.2023-10-10
           Icon name: computer
        Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		arm64
    Timezone: 		Europe/Vienna (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
    			/usr/bin/npm 		10.2.4
    			/usr/bin/npx 		10.2.4
    Recommended versions are nodejs 18.19.1 and npm 10.2.4
    MEMORY:
    Mem:            4.0G        752M        1.1G        1.2M        2.2G        3.2G
    Swap:           104M          0B        104M
    Total:          4.1G        752M        1.2G
    Active iob-Instances: 	3
    ioBroker Core: 		js-controller 		5.0.19
    			admin 			6.13.16
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		18459
    States: 		14746
    Size of iob-Database:
    21M	/opt/iobroker/iobroker-data/objects.jsonl
    4.3M	/opt/iobroker/iobroker-data/states.jsonl
    • P Pauli290787
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3792 M total memory
                708 M used memory
                861 M active memory
               1080 M free memory
                154 M buffer memory
               1925 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      695M	/var/
      376M	/var/cache
      370M	/var/cache/apt
      169M	/var/lib
      USB-Devices by-id:
      /usr/bin/npm 		10.2.4
      /usr/bin/npx 		10.2.4
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.13.16
      javascript: 	7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	18459
      States: 	14746
      Pending Updates: 0
      			v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Kernel: 		aarch64
      Userland: 		arm64
      User-ID: 		1000
      X-Server: 		false
      			/usr/bin/npm 		10.2.4
      			/usr/bin/npx 		10.2.4
      MEMORY:
      Swap:           104M          0B        104M
      			admin 			6.13.16
      Objects type: jsonl
      States  type: jsonl
      Objects: 		18459
      States: 		14746
      HomoranH Offline
      HomoranH Offline
      @pauli290787
      benutzt du Windows Editoren?
      das darf man mit Linuxdaten nie machen (wenn man sie wieder in Linux verwenden will! )
      Der Admin läuft, und sollte auch erreichbar sein.
      Da wir es die Tage gerade erst hatten: läuft eine Firewall?
      • P Offline
        Pauli290787
        Windows edition von was?
        Firewall läuft keine.
        Der Admin ist auch erreichbar aber der Login funktioniert nicht.
        P HomoranH 2 Antworten Letzte Antwort
        • P Pauli290787
          Pauli290787
          Sorry hab mich verlesen... Editoren ... Ja
          • P Pauli290787
            HomoranH Offline
            HomoranH Offline
            @pauli290787 sagte in Login funktioniert nach Backup-Wiederherstellung nicht mehr:
            aber nicht per https, was imho für die Authentifizierung notwendig wäre.
            • P Offline
              Pauli290787
              Wieso brauche ich im selben Netz für die Authentifizierung HTTPS?
              Hatte ich bis jetzt intern nie verwendet
              • P Offline
                Pauli290787
                Habe jetzt testweise iobroker noch einmal komplett gelöscht und neu installiert.
                Unmittelbar nach der Installation alles bestens.
                Dann bin ich die Ersteintrichtung durchlaufen und habe das Backup wieder eingespielt und zur Sicherheit per PuTTY noch ein passwd gemacht.
                Dann den Admin wieder aufgerufen --> gleicher Fehler "Benutzername oder Passwort sind falsch" egal was ich eingebe :-(
                • P Pauli290787
                  HomoranH Offline
                  HomoranH Offline
                  @pauli290787 Das "unbekannte" Passwort kommt doch aus dem Restore.
                  Was ist denn in dem Backup drin gewesen?
                  Hostname gleich geblieben?
                  • P Offline
                    Pauli290787
                    Ja das kommt aus dem Backup aber ich hätte es ja sogar versucht per passwd zu ändern.
                    Das mit dem Hostname kann ich jetzt gar nicht zu 100 % sagen. Könnte das die Ursache sein ?
                    • P Offline
                      Pauli290787
                      schrieb am zuletzt editiert von Pauli290787
                      Habe es gerade kontrolliert der Hostname ist gleich.
                      • P Pauli290787
                        @pauli290787
                        passwd ist auf Betriebssystemebene, hat mit dem ioBroker/Admin nix zu tun.
                        • P Offline
                          Pauli290787
                          ich meinte
                          iobroker passwd admin
                          W 1 Antwort Letzte Antwort
                          • P Pauli290787
                            ich meinte
                            W Offline
                            W Offline
                            Wildbill
                            @pauli290787 Hast Du nach dem restore auch lang genug gewartet, bis alle Adapter aus dem Backup installiert wurden? Wenn nach dem restore die Vollzugsmeldung kommt, dann startet erst der eigentliche Vorgang und dann wird erst nach und nach wieder alles installiert und die ganzen Objekte geschrieben. Nicht, dass Du da im laufenden Vorgang bereits versuchst das Passwort zu ändern oder so. Kann, je nach Hardware schon so 20min-1Stunde dauern.
                            Gruss, Jürgen
                            • P Offline
                              Pauli290787
                              Heute hat es geklappt, aber die Ursache ist mir bis jetzt unklar.
                              Ich habe den iobroker noch einmal neu installiert und dann gleich per Konsole das Backup eingespielt.
