  4. Hilfe! Nach Update des javascript Adapters 404
21 Beiträge 3 Kommentatoren 2.9k Aufrufe 3 Beobachtet
  • M Mika 0
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: Pi400
           Icon name: computer
    Operating System: Raspbian GNU/Linux 12 (bookworm)
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 400 Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     20:45:21 up 8 min,  4 users,  load average: 1.68, 2.41, 1.50
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-03-02 20:45:22 CET
               Universal time: Sat 2024-03-02 19:45:22 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin redis gpio i
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        2.0G        1.0G         61M        1.1G        2.0G
    Swap:           104M          0B        104M
    Total:          4.1G        2.0G        1.1G
             3792 M total memory
             1929 M used memory
             2094 M active memory
              458 M inactive memory
              956 M free memory
               90 M buffer memory
              949 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    * rc-local.service      loaded failed failed /etc/rc.local Compatibility
    2 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  7.2M  373M   2% /run
    /dev/sda2      ext4       35G   11G   23G  32% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    /dev/sda3      ext4       75G   25G   46G  35% /home/iobroker/Kamera
    /dev/sda1      vfat      510M  113M  398M  23% /boot/firmware
    log2ram        tmpfs      50M   18M   33M  35% /var/log
    tmpfs          tmpfs     380M   56K  380M   1% /run/user/1000
    [Sat Mar  2 20:36:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:16:A9:81 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff0000115200 console=tty1 root=PARTUUID=a6c93f24-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-se80211.ieee80211_regdom=DE
    [Sat Mar  2 20:36:41 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Mar  2 20:36:43 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    [Sat Mar  2 20:36:46 2024] EXT4-fs (sda3): recovery complete
    [Sat Mar  2 20:36:46 2024] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
    TARGET                  SOURCE              FSTYPE OPTIONS
    /                       /dev/sda2           ext4   rw,noatime
    |-/home/iobroker/Kamera /dev/sda3           ext4   rw,noatime
    |-/boot/firmware        /dev/sda1           vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shors=remount-ro
    `-/var/log.bak          /dev/sda2[/var/log] ext4   rw,noatime
    /var:
    2.9G    /var/
    2.3G    /var/opt/emoncms
    2.3G    /var/opt
    2.0G    /var/opt/emoncms/phpfina
    272M    /var/lib
    Archived and active journals take up 4.7M in the file system.
    /opt/iobroker/backups:
    29M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    902M    /opt/iobroker/iobroker-data/
    693M    /opt/iobroker/iobroker-data/files
    143M    /opt/iobroker/iobroker-data/backup-objects
    138M    /opt/iobroker/iobroker-data/files/vis-2
    78M     /opt/iobroker/iobroker-data/files/vis-2/static
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    20M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.4fb08967.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE4X89GM-if00-port0
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
         18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.19.0+dfsg-6~deb12u1+rpi1 500
            500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
     *** 18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : Pi400                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : Pi400                                    - disabled
      system.adapter.alias-manager.0          : alias-manager         : Pi400                                    - disabled
      system.adapter.asterisk.0               : asterisk              : Pi400                                    - disabled, port: 5038
      system.adapter.awattar.0                : awattar               : Pi400                                    -  enabled
    + system.adapter.backitup.0               : backitup              : Pi400                                    -  enabled
      system.adapter.countdown.0              : countdown             : Pi400                                    - disabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : Pi400                                    -  enabled
      system.adapter.daswetter.0              : daswetter             : Pi400                                    -  enabled
    + system.adapter.discovery.0              : discovery             : Pi400                                    -  enabled
      system.adapter.dwd.0                    : dwd                   : Pi400                                    -  enabled
    + system.adapter.enigma2.0                : enigma2               : Pi400                                    -  enabled
    + system.adapter.enigma2.1                : enigma2               : Pi400                                    -  enabled
      system.adapter.feiertage.0              : feiertage             : Pi400                                    -  enabled
    + system.adapter.harmony.0                : harmony               : Pi400                                    -  enabled
    + system.adapter.history.0                : history               : Pi400                                    -  enabled
      system.adapter.ical.0                   : ical                  : Pi400                                    -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Pi400                                    - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : Pi400                                    - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : Pi400                                    - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : Pi400                                    - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : Pi400                                    - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Pi400                                    - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Pi400                                    - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Pi400                                    - disabled
    + system.adapter.info.0                   : info                  : Pi400                                    -  enabled
    + system.adapter.jarvis.0                 : jarvis                : Pi400                                    -  enabled
      system.adapter.javascript.0             : javascript            : Pi400                                    - disabled
      system.adapter.material.0               : material              : Pi400                                    - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Pi400                                    -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : Pi400                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : Pi400                                    -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.pollenflug.0             : pollenflug            : Pi400                                    -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : Pi400                                    -  enabled
    + system.adapter.s7.0                     : s7                    : Pi400                                    -  enabled
    + system.adapter.s7.1                     : s7                    : Pi400                                    -  enabled
    + system.adapter.s7.2                     : s7                    : Pi400                                    -  enabled
    + system.adapter.scheduler.0              : scheduler             : Pi400                                    -  enabled
      system.adapter.shuttercontrol.0         : shuttercontrol        : Pi400                                    - disabled
      system.adapter.solarwetter.0            : solarwetter           : Pi400                                    -  enabled
      system.adapter.telegram-menu.0          : telegram-menu         : Pi400                                    - disabled
    + system.adapter.telegram.0               : telegram              : Pi400                                    -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : Pi400                                    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : Pi400                                    -  enabled
      system.adapter.tibberlink.0             : tibberlink            : Pi400                                    - disabled
      system.adapter.time-switch.0            : time-switch           : Pi400                                    - disabled
    + system.adapter.tr-064.0                 : tr-064                : Pi400                                    -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : Pi400                                    -  enabled
      system.adapter.vis-2.0                  : vis-2                 : Pi400                                    - disabled
      system.adapter.vis-bars.0               : vis-bars              : Pi400                                    - disabled
      system.adapter.vis-history.0            : vis-history           : Pi400                                    - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Pi400                                    - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : Pi400                                    -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Pi400                                    - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : Pi400                                    - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : Pi400                                    - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : Pi400                                    - disabled
      system.adapter.vis-metro.0              : vis-metro             : Pi400                                    - disabled
      system.adapter.vis-players.0            : vis-players           : Pi400                                    - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : Pi400                                    - disabled
      system.adapter.vis-weather.0            : vis-weather           : Pi400                                    - disabled
      system.adapter.vis.0                    : vis                   : Pi400                                    -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : Pi400                                    -  enabled
    + system.adapter.web.0                    : web                   : Pi400                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : Pi400                                    -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "awattar"      : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
    Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.1
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "s7"           : 1.4.2    , installed 1.4.2
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "shuttercontrol": 1.7.0   , installed 1.6.3  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tibberlink"   : 2.2.2    , installed 2.0.1  [Updatable]
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.11 [Updatable]
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        21646
    States:         18855
    W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
    Hit:2 https://linux.teamviewer.com/deb stable InRelease
    Hit:3 https://packages.sury.org/php bookworm InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 138
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:45227           0.0.0.0:*               LISTEN      102        21713      1387/rpc.statd
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          23637      1681/smbd
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       43540      3120/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19594      880/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      115        22755      1465/proftpd: (acce
    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          22720      -
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11382      1/init
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          23636      1681/smbd
    tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          21933      1397/teamviewerd
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        18149      997/mariadbd
    tcp        0      0 0.0.0.0:39707           0.0.0.0:*               LISTEN      0          20272      -
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18803      823/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       22851      923/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       22909      923/iobroker.js-con
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        18858      830/redis-server 12
    tcp        0      0 0.0.0.0:42935           0.0.0.0:*               LISTEN      0          22633      1393/rpc.mountd
    tcp        0      0 0.0.0.0:44969           0.0.0.0:*               LISTEN      0          22675      1393/rpc.mountd
    tcp        0      0 0.0.0.0:51113           0.0.0.0:*               LISTEN      0          22654      1393/rpc.mountd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        17991      889/mosquitto
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       24573      2463/node-red
    tcp6       0      0 :::139                  :::*                    LISTEN      0          23635      1681/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          19607      880/sshd: /usr/sbin
    tcp6       0      0 :::2049                 :::*                    LISTEN      0          22724      -
    tcp6       0      0 :::111                  :::*                    LISTEN      0          11383      1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          18842      915/apache2
    tcp6       0      0 :::445                  :::*                    LISTEN      0          23634      1681/smbd
    tcp6       0      0 :::47383                :::*                    LISTEN      0          22666      1393/rpc.mountd
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       48050      3205/io.harmony.0
    tcp6       0      0 :::37815                :::*                    LISTEN      0          20274      -
    tcp6       0      0 :::37857                :::*                    LISTEN      102        21717      1387/rpc.statd
    tcp6       0      0 :::58325                :::*                    LISTEN      0          22639      1393/rpc.mountd
    tcp6       0      0 ::1:6379                :::*                    LISTEN      113        18859      830/redis-server 12
    tcp6       0      0 :::44397                :::*                    LISTEN      0          22683      1393/rpc.mountd
    tcp6       0      0 :::8083                 :::*                    LISTEN      1000       67764      3735/io.web.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       40827      2996/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       25990      2291/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       57699      3361/io.terminal.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18802      823/cupsd
    tcp6       0      0 :::1883                 :::*                    LISTEN      114        17992      889/mosquitto
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1017       1/init
    udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          20479      1460/nmbd
    udp        0      0 192.168.2.4:137         0.0.0.0:*                           0          20478      1460/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          20304      1460/nmbd
    udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          23553      1460/nmbd
    udp        0      0 192.168.2.4:138         0.0.0.0:*                           0          20480      1460/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          20305      1460/nmbd
    udp        0      0 0.0.0.0:47259           0.0.0.0:*                           102        21711      1387/rpc.statd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       51809      3285/io.mihome-vacu
    udp        0      0 0.0.0.0:41153           0.0.0.0:*                           0          20271      -
    udp        0      0 0.0.0.0:57605           0.0.0.0:*                           104        12131      666/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       48051      3205/io.harmony.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20877      1369/cups-browsed
    udp        0      0 127.0.0.1:715           0.0.0.0:*                           0          21707      1387/rpc.statd
    udp        0      0 0.0.0.0:56328           0.0.0.0:*                           0          22651      1393/rpc.mountd
    udp        0      0 0.0.0.0:50270           0.0.0.0:*                           0          22621      1393/rpc.mountd
    udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1000       36455      2499/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12129      666/avahi-daemon: r
    udp        0      0 0.0.0.0:38825           0.0.0.0:*                           0          22672      1393/rpc.mountd
    udp6       0      0 :::111                  :::*                                0          1018       1/init
    udp6       0      0 :::47311                :::*                                0          22636      1393/rpc.mountd
    udp6       0      0 fe80::b6b0:25d8:733:546 :::*                                0          22951      797/NetworkManager
    udp6       0      0 :::43885                :::*                                0          20273      -
    udp6       0      0 :::37921                :::*                                104        12132      666/avahi-daemon: r
    udp6       0      0 :::44220                :::*                                0          22657      1393/rpc.mountd
    udp6       0      0 :::5353                 :::*                                104        12130      666/avahi-daemon: r
    udp6       0      0 :::54863                :::*                                102        21715      1387/rpc.statd
    udp6       0      0 :::47056                :::*                                0          22678      1393/rpc.mountd
    2024-03-02 20:46:39.096  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog2.pip.acin" has to be type "string" but received type "number"
    2024-03-02 20:46:39.106  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog2.pip.acoutw" has been written without ack-flag with value "1096"
    2024-03-02 20:46:39.875  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:39 - [info] [rpi-gpio out:Relay Heizung Stufe Poti GPIO27-13] out: 1
    2024-03-02 20:46:39.877  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:39 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
    2024-03-02 20:46:39.881  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:39 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
    2024-03-02 20:46:40.076  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog.pip.acin" has to be type "string" but received type "number"
    2024-03-02 20:46:40.082  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog.pip.acoutw" has been written without ack-flag with value "1122"
    2024-03-02 20:46:44.096  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog2.pip.acin" has to be type "string" but received type "number"
    2024-03-02 20:46:44.101  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog2.pip.acoutw" has been written without ack-flag with value "1110"
    2024-03-02 20:46:44.537  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:44 - [info] [rpi-gpio out:GPIO06 - Pin 31 Ansteuerung Zusatzrelais Lüfter (hinter Pi)] out: 0
    2024-03-02 20:46:44.878  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:44 - [info] [rpi-gpio out:Relay Heizung Stufe Poti GPIO27-13] out: 1
    2024-03-02 20:46:44.883  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:44 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
    2024-03-02 20:46:44.889  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:44 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
    2024-03-02 20:46:44.967  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog.pip.acin" has to be type "string" but received type "number"
    2024-03-02 20:46:45.045  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog.pip.acoutw" has been written without ack-flag with value "1133"
    2024-03-02 20:46:49.114  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog2.pip.acin" has to be type "string" but received type "number"
    2024-03-02 20:46:49.168  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog2.pip.acoutw" has been written without ack-flag with value "1138"
    2024-03-02 20:46:49.889  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:49 - [info] [rpi-gpio out:Relay Heizung Stufe Poti GPIO27-13] out: 1
    2024-03-02 20:46:49.892  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:49 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
    2024-03-02 20:46:49.895  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:49 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
    2024-03-02 20:46:49.941  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog.pip.acin" has to be type "string" but received type "number"
    2024-03-02 20:46:49.953  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog.pip.acoutw" has been written without ack-flag with value "1148"
    2024-03-02 20:46:54.068  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog2.pip.acin" has to be type "string" but received type "number"
    2024-03-02 20:46:54.070  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog2.pip.acoutw" has been written without ack-flag with value "1144"
    2024-03-02 20:46:54.548  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:54 - [info] [rpi-gpio out:GPIO06 - Pin 31 Ansteuerung Zusatzrelais Lüfter (hinter Pi)] out: 0
    iob diag has finished.
    Copy text starting here:
                            v.2023-10-10
           Icon name: computer
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               true
    Pending OS-Updates:     138
    Pending iob updates:    3
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
    Recommended versions are nodejs 18.19.1 and npm 10.2.4
    MEMORY:
    Mem:            4.0G        2.0G        1.2G         63M        912M        2.0G
    Swap:           104M          0B        104M
    Total:          4.1G        2.0G        1.4G
    Active iob-Instances:   28
    ioBroker Core:          js-controller           5.0.19
                            admin                   6.13.16
    Objects type: jsonl
    States  type: jsonl
    Objects:                21646
    States:                 18855
    Size of iob-Database:
    11M     /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    Nachdem ich Javaspript Instanz aktiviert habe, ist Ram voll gelaufen und Swap Partition auch voll gelaufen. Leider konnte ich nicht mehr stoppen und der Pi ist abgeschmiert. 20 min warten oder Stromversorgung trennen. Ich muss nach Restart gleich wieder die Java Insanz stoppen.
    @mika-0 sagte in Hilfe! Nach Java Update Skripte 404:
    Kernel: aarch64 Userland: armhf
    Installier das Betriebssystem NEU als reine 64Bit-Version in der Lite-Variante, ohne Desktop und dem TeamViewer-Quark.
    Hau die 138 Updates für das OS rein und die 3 iob-Updates.
      Mika 0
      @thomas-braun Ähhhh das geht nicht. Ich habe PV 32bit Programme die eine Desktop Oberfläche benötigen. Um gelegentlich diese PV Programme remote bedienen zu können war früher VNC drauf. Das geht aber nicht bei Bookworm mit 32bit. Daher Teamviewer drauf.
      ging das Java schief? Kann ich was machen damit ich das System retten kann?
      Aufsetzen auf gleichem Stand vor Update wäre möglich, aber aufwändig
      • M Mika 0
        Falsches Setup...
          Falsches Setup...
          Mika 0
          @thomas-braun Da gibt es leider kein Setup was ich auswählen könnte. Die laufen halt nur auf ner GUI. Die ganze Zeit lief es ja auch stabil. Bis nach dem Update vorhin. Sorry, aber ich bin kein Experte, sonst würde ich hier nicht fragen. Daher nochmal. Kann ich das aktuelle System retten und wenn ja mit welchen Befehlen?
          • M Mika 0
            @mika-0
            Und die beiden ominösen Programme verhindern auch, das du die Kiste auf einem aktuellen Stand hältst?
            Da zuerst ran.
            Offenbar nicht. Dann würdest du nämlich nicht so ein strubbeliges System fahren.
              @mika-0
              Da zuerst ran.
              Mika 0
              schrieb am zuletzt editiert von Mika 0
              @thomas-braun Also die OS Updates laufen. Währenddessen.... Was wäre denn aus deiner Sicht ein besseres "Setup"? Lieber die PV Programme auf einem kleinen Pi laufen und iobroker auf dem anderen der direkt neben dran liegt?
              Mir war die Reihenfolge nicht bekannt, erst OS Updates, dann iobroker Updates. Kann ich aber gerne in Zukunft so machen.
              Gibt es denn eine zeitliche Regel, nach den OS Updates zu suchen? Täglich, weekly?
              Edit: Von der Leistung des Pi 4 bin ich absolut zufrieden. Da gab es bisher nie irgend eine Performancelücke
              Thomas BraunT mrbungle64M 2 Antworten Letzte Antwort
              • M Mika 0
                wie oben bereits gesagt: Reines 64Bit-System ohne Desktop-Geraffel.
                Wurscht, hauptsache regelmäßig. So alle 2 Wochen.
                • M Mika 0
                  mrbungle64M Offline
                  mrbungle64M Offline
                  mrbungle64
                  @mika-0
                  Man erhöht grundsätzlich die Wahrscheinlichkeit auf ein stabiles ioBroker-System, wenn es ein dediziertes System für den ioBroker ist - ohne weitere Software nebenbei (auch wenn es die Performance hergeben würde).
                  Auf einem dedizierten ioBroker-System läuft dann eben auch keine Desktop-Umgebung.
                  Btw.: ändere bitte mal den Betreff auf "Nach Update des javascript Adapters 404".
                  Java ist beim ioBroker nämlich irrelevant.
                  • mrbungle64M mrbungle64
                    @mika-0
                    Mika 0
                    @mrbungle64 Auch dir Danke für den Input. Muss ich schauen wie ich das HW seitig umsetzen kann. Gerne ändern ich den Betreff, aber wo ist da ein Bearbeiten Button?
                    & an @Thomas-Braun
                    OS Updates sind drauf. Der RAM läuft immer noch voll. Kann es sein, dass durch das Update ein Skript schuld sein könnte? Kann man das herausfinden welches es sein könnte?
                    Edit: Thread Titel ändern geschafft. ;-)
                    • M Mika 0
                      & an @Thomas-Braun
                      Mika 0
                      Wäre folgender Vorschlag eine bessere Vorgehensweise mit iobroker:
                      iobroker auf SSD am Pi 4 mit Bookworm 64bit ohne GUI und steuert auch GPIO Pins
                      PV Programme auf SSD am Pi 3 mit Bookworm / Bullseye 32bit und GUI
                      Und wo sollte ich dann die Datalogger Grafana / Emoncms laufen lassen? Daten kommen aber von beiden Pi´s
                      • M Mika 0
                        Mika 0
                        Leider kam zu meinem Vorschlag zu einer richtigen Umsetzung kein Vorschlag. Also habe ich es so umgesetzt.
                        ioBroker ist nun auf einem ganz frischen Raspberry Pi 4 Bookworm 64 bit lite aufgesetzt. Kein Desktop, keiner weiteren Programme.
                        Ich habe ein älteres backup restored. Zack RAM vollgelaufen und der Pi hat sich aufgehängt.
                        Ich bin nun trotz Aufwand der letzten Tage keinen Schritt weiter.
                        @mrbungle64 @Thomas-Braun oder andere Experten. Wer kann mir bitte helfen?
                        • M Mika 0
                          @mika-0 sagte in Hilfe! Nach Update des javascript Adapters 404:
                          Da wirst du selber ran müssen. Wird wohl ein Skript sein, das da ausflippt.
                            Mika 0
                            @thomas-braun OK Danke, auf die Idee bin ich auch schon gekommen und deaktiviere alle. Dann wird nach und nach zugeschaltet.
                            Wenigstens ist der iobroker nun separat zu den PV Programmen, was ja definitiv nicht schaden kann ;-) Melde mich wenn ich Erfolg hatte.
                              Mika 0
                              @thomas-braun Also ich habe den info adapter ausfindig gemacht. Seit dem ich den deaktiviert habe, kam der RAM Überlauf nicht mehr. Habe ich deinstalliert.
                              Nun kam vom Javaskript die Update Meldung
                              Das ging ca, 5 min gut, dann kam es während dem Update zum Überlauf und schlussendlich zum Crash.
                              Alle anderen Adapter sind aktuell.
                              Kann man aus dem bisschen Text etwas heraus lesen an was das liegen könnte?
                              • M Mika 0
                                @mika-0
                                iob diag
                                anschauen.
                                  @mika-0
                                  iob diag
                                  anschauen.
                                  Mika 0
                                  @thomas-braun ```
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                   Static hostname: iobroker
                                         Icon name: computer
                                            Kernel: Linux 6.1.0-rpi8-rpi-v8
                                      Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                   22:16:22 up 6 min,  2 users,  load average: 4.49, 3.59, 1.69
                                  CPU threads: 4
                                  Current issues:
                                  ~ Under-voltage detected
                                  ~ Arm frequency capped
                                  ~ Under-voltage has occurred
                                  ~ Arm frequency capping has occurred
                                                 Local time: Thu 2024-03-07 22:16:22 CET
                                             Universal time: Thu 2024-03-07 21:16:22 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  iobroker
                                  /home/iobroker
                                  iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  Boot Target:    multi-user.target
                                  *** MEMORY ***
                                  Mem:            4.0G        2.4G        903M        1.2M        731M        1.6G
                                  Swap:           104M          0B        104M
                                  Total:          4.1G        2.4G        1.0G
                                           3792 M total memory
                                           2310 M used memory
                                           2347 M active memory
                                            434 M inactive memory
                                            860 M free memory
                                             70 M buffer memory
                                            627 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs     380M  1.2M  379M   1% /run
                                  /dev/sda2      ext4      110G  5.4G   99G   6% /
                                  /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
                                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                  [sudo] password for iobroker:
                                  [Thu Mar  7 22:09:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:16:A9:81 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=8488418b-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                  [Thu Mar  7 22:10:00 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Thu Mar  7 22:10:01 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                  `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  523M    /var/
                                  202M    /var/cache
                                  197M    /var/cache/apt
                                  164M    /var/lib
                                  132M    /var/lib/apt/lists
                                  Archived and active journals take up 55.6M in the file system.
                                  808M    /opt/iobroker/iobroker-data/
                                  730M    /opt/iobroker/iobroker-data/files
                                  142M    /opt/iobroker/iobroker-data/files/vis-2
                                  81M     /opt/iobroker/iobroker-data/files/vis-2/static
                                  80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                                  51M     /opt/iobroker/iobroker-data/objects.jsonl
                                  21M     /opt/iobroker/iobroker-data/states.jsonl
                                  USB-Devices by-id:
                                  find: '/dev/serial/by-id/': No such file or directory
                                  /usr/bin/nodejs         v18.19.1
                                  /usr/bin/node           v18.19.1
                                  /usr/bin/npm            10.2.4
                                  /usr/bin/npx            10.2.4
                                  nodejs:
                                    Installed: 18.19.1-1nodesource1
                                    Version table:
                                   *** 18.19.1-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                       18.19.0+dfsg-6~deb12u1 500
                                          500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                       18.13.0+dfsg1-1 500
                                          500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                  Errors in npm tree:
                                  npm ERR! code ELSPROBLEMS
                                  npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                  npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                  npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                                  npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
                                  npm ERR! extraneous: jsonata@2.0.4 /opt/iobroker/node_modules/jsonata
                                  npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                  npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                  npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                  npm ERR! extraneous: typescript@5.3.3 /opt/iobroker/node_modules/typescript
                                  npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                  npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                  npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                                  npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker
                                  npm ERR! extraneous: @types/linkify-it@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/linkify-it
                                  npm ERR! extraneous: @types/mdurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/mdurl
                                  npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                                  npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                                  npm ERR! invalid: asynckit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-07T21_16_55_302Z-debug-0.log
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.13.16
                                  javascript:     7.8.0
                                  Adapters from github:   0
                                  Adapter State
                                    system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                    system.adapter.asterisk.0               : asterisk              : iobroker                                 - disabled, port: 5038
                                    system.adapter.awattar.0                : awattar               : iobroker                                 - disabled
                                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    system.adapter.countdown.0              : countdown             : iobroker                                 - disabled
                                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                    system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                    system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                  + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
                                  + system.adapter.enigma2.1                : enigma2               : iobroker                                 -  enabled
                                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                  + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                                    system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                    system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                                  + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    system.adapter.material.0               : material              : iobroker                                 - disabled
                                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                                  + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                                  + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                  + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                                  + system.adapter.s7.1                     : s7                    : iobroker                                 -  enabled
                                  + system.adapter.s7.2                     : s7                    : iobroker                                 -  enabled
                                    system.adapter.scheduler.0              : scheduler             : iobroker                                 - disabled
                                    system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
                                    system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
                                    system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
                                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                                  + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                    system.adapter.tibberlink.0             : tibberlink            : iobroker                                 - disabled
                                    system.adapter.time-switch.0            : time-switch           : iobroker                                 - disabled
                                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                    system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                    system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                    system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                                    system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                    system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                                  + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                                  Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                                  Adapter    "tibberlink"   : 2.2.2    , installed 2.2.2
                                  Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                                  Objects and States
                                  Objects:        19580
                                  States:         17301
                                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       21187      1360/node-red
                                  tcp        0      0 0.0.0.0:56101           0.0.0.0:*               LISTEN      103        21179      1525/rpc.statd
                                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       22118      1481/io.jarvis.0
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21151      1/init
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16500      708/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       13869      695/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       13907      695/iobroker.js-con
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       18272      979/io.admin.0
                                  tcp6       0      0 :::8083                 :::*                    LISTEN      1000       23665      1617/io.web.1
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       22918      1610/io.web.0
                                  tcp6       0      0 :::42753                :::*                    LISTEN      103        21183      1525/rpc.statd
                                  tcp6       0      0 :::61991                :::*                    LISTEN      1000       23576      1463/io.harmony.0
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          21155      1/init
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          16502      708/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       23577      1463/io.harmony.0
                                  udp        0      0 0.0.0.0:39575           0.0.0.0:*                           104        14516      504/avahi-daemon: r
                                  udp        0      0 127.0.0.1:854           0.0.0.0:*                           0          21173      1525/rpc.statd
                                  udp        0      0 192.168.2.40:5353       0.0.0.0:*                           1000       22893      1352/io.tr-064.0
                                  udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1000       22892      1352/io.tr-064.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14514      504/avahi-daemon: r
                                  udp        0      0 0.0.0.0:53294           0.0.0.0:*                           103        21177      1525/rpc.statd
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          21153      1/init
                                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       19034      1169/io.mihome-vacu
                                  udp6       0      0 fe80::1cf:9104:829e:546 :::*                                0          16573      633/NetworkManager
                                  udp6       0      0 fe80::4419:5dba:1b6:546 :::*                                0          16132      633/NetworkManager
                                  udp6       0      0 :::5353                 :::*                                104        14515      504/avahi-daemon: r
                                  udp6       0      0 :::54748                :::*                                104        14517      504/avahi-daemon: r
                                  udp6       0      0 :::57020                :::*                                103        21181      1525/rpc.statd
                                  udp6       0      0 :::111                  :::*                                0          21157      1/init
                                  2024-03-07 22:19:27.121  - info: javascript.0 (1676) script.js.SynologyPhotos.Photos_zählen: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:27.123  - info: javascript.0 (1676) Start javascript script.js.System.Neustart_Fritzbox
                                  2024-03-07 22:19:27.146  - info: javascript.0 (1676) script.js.System.Neustart_Fritzbox: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:27.147  - info: javascript.0 (1676) Start javascript script.js.System.Partition_Kamera_reinigen
                                  2024-03-07 22:19:27.185  - info: javascript.0 (1676) script.js.System.Partition_Kamera_reinigen: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:27.186  - info: javascript.0 (1676) Start javascript script.js.System.Pi_einmalig_neustarten
                                  2024-03-07 22:19:27.248  - info: javascript.0 (1676) script.js.System.Pi_einmalig_neustarten: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:27.705  - warn: javascript.0 (1676) script.js.Fritzbox.Klingel_Bild_Telegram: Fehler beim Bild speichern: Error: ENOENT: no such file or directory, open '/home/iobroker/Kamera/Klingel/Klingel_0.jpg'
                                  2024-03-07 22:19:29.249  - info: javascript.0 (1676) Start javascript script.js.System.Speicherplatz_umrechnen
                                  2024-03-07 22:19:29.266  - info: javascript.0 (1676) script.js.System.Speicherplatz_umrechnen: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:29.268  - info: javascript.0 (1676) Start javascript script.js.System.Uptime
                                  2024-03-07 22:19:29.330  - info: javascript.0 (1676) script.js.System.Uptime: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:29.332  - info: javascript.0 (1676) Start javascript script.js.System.Vis_Funktions_Buttons
                                  2024-03-07 22:19:29.433  - info: javascript.0 (1676) script.js.System.Vis_Funktions_Buttons: registered 14 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:29.434  - info: javascript.0 (1676) Start javascript script.js.Telegram.Briefkasten_Bild_Telegram
                                  2024-03-07 22:19:29.570  - info: javascript.0 (1676) script.js.Telegram.Briefkasten_Bild_Telegram: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:29.572  - info: javascript.0 (1676) Start javascript script.js.Telegram.Telegram-Menu.HILFE_ANLEITUNG
                                  2024-03-07 22:19:29.587  - info: javascript.0 (1676) script.js.Telegram.Telegram-Menu.HILFE_ANLEITUNG: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:29.588  - info: javascript.0 (1676) Start javascript script.js.Telegram.Telegram-Menu.Start-Menu
                                  2024-03-07 22:19:29.609  - info: javascript.0 (1676) script.js.Telegram.Telegram-Menu.Start-Menu: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:29.611  - info: javascript.0 (1676) Start javascript script.js.Visualisierung.MyMüll
                                  2024-03-07 22:19:29.641  - info: javascript.0 (1676) script.js.Visualisierung.MyMüll: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:29.643  - info: javascript.0 (1676) Start javascript script.js.Visualisierung.Vis_Änderung_Telegram
                                  2024-03-07 22:19:29.659  - info: javascript.0 (1676) script.js.Visualisierung.Vis_Änderung_Telegram: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  2024-03-07 22:19:30.266  - warn: javascript.0 (1676) script.js.Telegram.Briefkasten_Bild_Telegram: Fehler beim Bild speichern: Error: ENOENT: no such file or directory, open '/home/iobroker/Kamera/Briefkasten/Briefkasten_0.jpg'
                                  • M Mika 0
                                    @thomas-braun ```
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    iobroker
                                    /home/iobroker
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           104M          0B        104M
                                             3792 M total memory
                                             2310 M used memory
                                              860 M free memory
                                               70 M buffer memory
                                              627 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    523M    /var/
                                    202M    /var/cache
                                    197M    /var/cache/apt
                                    164M    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.4
                                    /usr/bin/npx            10.2.4
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.13.16
                                    javascript:     7.8.0
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        19580
                                    States:         17301
                                    Pending Updates: 0
                                    @mika-0
                                    Besorg dir ein stabileres Netzteil.
                                    Und schau nach asynckit. Das Modul ist falsch installiert, installier das nochmal. Oder den javaskript-Adapter. Jenachdem wo es genau klemmt.
                                    cd /opt/iobroker
                                    npm ls asynckit@
                                      @mika-0
                                      cd /opt/iobroker
                                      npm ls asynckit@
                                      Mika 0
                                      @thomas-braun @thomas-braun sagte in Hilfe! Nach Update des javascript Adapters 404:
                                      cd /opt/iobroker
                                      npm ls asynckit@
                                      Das mit dem Netzteil habe ich auch gelesen. Das war im Kauf Bundle damals dabei (ist ein originales) OK dann muss ein neues her, habe vorübergehend ein anderes genommen, das zeigt bei nochmaligem Durchlauf von iob diag keinen Fehler an.
                                      Danke der Info, hier das Ergebnis:
                                      npm ls asynckit@
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      ├─┬ @types/request@2.48.12 extraneous
                                      │ └─┬ form-data@2.5.1 extraneous
                                      │   └── asynckit@0.4.0
                                      ├─┬ iobroker.admin@6.13.16
                                      │ └─┬ axios@1.6.7
                                      │   └─┬ form-data@4.0.0
                                      │     └── asynckit@0.4.0 deduped
                                      ├─┬ iobroker.javascript@7.8.0
                                      │ ├─┬ @types/request@2.48.12
                                      │ │ └─┬ form-data@2.5.1
                                      │ │   └── asynckit@0.4.0
                                      │ ├─┬ axios@1.6.7
                                      │ │ └─┬ form-data@4.0.0
                                      │ └─┬ request@2.88.2
                                      │   └─┬ form-data@2.3.3
                                      ├─┬ iobroker.mihome-vacuum@4.1.1
                                      └─┬ iobroker.telegram@3.1.0
                                        └─┬ node-telegram-bot-api@0.64.0
                                          └─┬ @cypress/request@3.0.1
                                            └─┬ form-data@2.3.3
                                      Also von einem asynckit habe ich noch nichts gelesen, was das ist oder wozu ich das installiert haben könnte.
                                      Kann man daran erkennen ob ein asynckit oder javaskript fehlerhaft installiert wurden und ein Hinweis wäre nett, wie ich das neu installieren kann. Ich möchte nichts falsches drücken. Besten Dank vorab.
