  4. Test Adapter Zendure Solarflow
2.6k Beiträge 129 Kommentatoren 1.3m Aufrufe 128 Beobachtet
  • L lesiflo
    hier der Blockly-Code für die Umrechnung in kWh
      <variables>
        <variable id="gn:HU~SCGvnqbRCRMSCy">Neustart</variable>
        <variable id="H`8%Q[C];S#Po%f%^,*[">energie</variable>
        <variable id="B].n@]e_d8kNxs]d-Ky|">Laden_Akku</variable>
        <variable id="Ua?)Az%)A;%j}Z?Y(@qh">Entladen_Akku</variable>
        <variable id="rNmt]Ylyn6~w3v(K59#b">Abgabe_Haus</variable>
        <variable id="6-EW?O6)X$_9j`r)iuXZ">energie_start</variable>
      </variables>
      <block type="comment" id="j2:aNxn%Er`8Q_}@!!P$" x="488" y="1388">
        <field name="COMMENT">Reset Tageswerte</field>
        <next>
          <block type="schedule" id="]L}6=Uyw4CKieYA8qo*{">
            <field name="SCHEDULE">2 0 * * *</field>
            <statement name="STATEMENT">
              <block type="control" id="wO]+tfPu:O]@8vg4)@^w">
                <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.packInputPower_kWh</field>
                <value name="VALUE">
                  <block type="math_number" id="0-8b%VD~nqwRqI#LWXFs">
                    <field name="NUM">0</field>
                  </block>
                </value>
                <next>
                  <block type="control" id=":Xx0TE*B2+5{)MCyETx9">
                    <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.outputPackPower_kWh</field>
                      <block type="math_number" id="%F@$?A{uLGsZVc@9nVkI">
                      </block>
                    </value>
                    <next>
                      <block type="control" id="!Ssd`Ac.tsL+mEscm.y!">
                        <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.solarInputPower_kWh</field>
                          <block type="math_number" id="B.yO.QUgA{;$4X?-g8,h">
                          </block>
                        </value>
                        <next>
                          <block type="control" id="EW#t.vr$F-%Xm}DI79r$">
                            <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.outputHomePower_kWh</field>
                              <block type="math_number" id=")~K]8GK6@)ZJoFk(PTjL">
                              </block>
                            </value>
                            <next>
                              <block type="variables_set" id="RfP%gUCE_#E^hZzbQAYj">
                                <field name="VAR" id="H`8%Q[C];S#Po%f%^,*[">energie</field>
                                  <block type="get_object" id="fhJ-zn1s(d8_~@ror)Ga">
                                  </block>
                                </value>
                                <next>
                                  <block type="variables_set" id="gw70B~d](MZS^tlJL$ZE">
                                    <field name="VAR" id="B].n@]e_d8kNxs]d-Ky|">Laden_Akku</field>
                                      <block type="get_object" id="nvgxO+GU:/NYyfGjd(T7">
                                      </block>
                                    </value>
                                    <next>
                                      <block type="variables_set" id="(HL3sW/GTkqUWTykp!IY">
                                        <field name="VAR" id="Ua?)Az%)A;%j}Z?Y(@qh">Entladen_Akku</field>
                                          <block type="get_object" id="k8M@bC*%_F78uSqVwepP">
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id=".j`=}xOL2?JBtSp_b6LK">
                                            <field name="VAR" id="rNmt]Ylyn6~w3v(K59#b">Abgabe_Haus</field>
                                              <block type="get_object" id="c[)j_kHXIV/jwf7+(%gs">
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
            <next>
              <block type="variables_set" id="A.e$V`ynjg0#}qJnFF)w">
                <field name="VAR" id="gn:HU~SCGvnqbRCRMSCy">Neustart</field>
                  <block type="logic_boolean" id="9Lm!l6t-vOXOddA~3mJg">
                  </block>
                </value>
                <next>
                  <block type="comment" id="RV+eO`6:RC~uyK=4f_nx">
                    <field name="COMMENT">Produktion PV</field>
                    <next>
                      <block type="variables_set" id="AgB0uh?CsFR}.}ii/]lj">
                          <block type="get_object" id="LHEv}In-fr%NySNK.%#/">
                          </block>
                        </value>
                        <next>
                          <block type="on_ext" id="TZZI45[#ikP]~r)[F#^K">
                            <value name="OID0">
                              <shadow type="field_oid" id="FYq7rQr_UY1$l*O%mT96">
                                <field name="oid">zendure-solarflow.0.73bkTV.7rk1nVD9.solarInputPower</field>
                              </shadow>
                            </value>
                              <block type="controls_if" id="9ONCtcSN=;/2qz9[DzO~">
                                <value name="IF0">
                                  <block type="logic_compare" id="4EEJBi[?ILa5iGd=EP**">
                                    <field name="OP">GT</field>
                                    <value name="A">
                                      <block type="on_source" id="^t~l#qd|9b]s|+=[u^;5">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="math_number" id="pmxSrG=-GuXXA_}`$X1D">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <statement name="DO0">
                                  <block type="math_change" id="4l|3nJK3ab*a;%4oOEr:">
                                    <value name="DELTA">
                                      <shadow type="math_number" id=",5ZCZx[AyTZPJRCD4}~t">
                                        <field name="NUM">1</field>
                                      </shadow>
                                      <block type="math_arithmetic" id="*TjAL)Qm[^ij,1^%-zFp" inline="false">
                                        <field name="OP">DIVIDE</field>
                                        <value name="A">
                                          <shadow type="math_number" id="7TDAa@37OuJ`vcT;P%*S">
                                          </shadow>
                                          <block type="math_arithmetic" id="f-yO-QtK`#*o44p4l~(z" inline="false">
                                            <field name="OP">MULTIPLY</field>
                                            <value name="A">
                                              <shadow type="math_number" id="5~%F;bHMxZ^filO5NJlP">
                                              </shadow>
                                              <block type="on_source" id=":[cP3-xt`]9uOyB~EA0|">
                                                <field name="ATTR">oldState.val</field>
                                              </block>
                                            </value>
                                            <value name="B">
                                              <shadow type="math_number" id="pL#ugPnA,fA?t^ZJgf.Y">
                                              </shadow>
                                              <block type="math_arithmetic" id="Lg(3A*d,5?1Nb.q|gM=s">
                                                <value name="A">
                                                  <shadow type="math_number" id="vD5aC,I(S]J9iOZ+c4J-">
                                                  </shadow>
                                                  <block type="on_source" id="Znb.rqcqheWmt5$ect[t">
                                                    <field name="ATTR">state.lc</field>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <shadow type="math_number" id="RlrE5saDi)]Sef;L+Ayu">
                                                  </shadow>
                                                  <block type="on_source" id="sC$AGCU(o~$];AuwLfa_">
                                                    <field name="ATTR">oldState.lc</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow type="math_number" id="f6(R_NuM*Zwyrg-(qhk}">
                                            <field name="NUM">3600000000</field>
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="update" id="CII[{jcsb@hcMs[d|BQ(">
                                          <block type="math_rndfixed" id="~?Jqw`YNch87/XxEuB~~">
                                            <field name="n">3</field>
                                            <value name="x">
                                              <shadow type="math_number" id="${2/m,%T*ULKInSPhEs;">
                                                <field name="NUM">3.1234</field>
                                              </shadow>
                                              <block type="variables_get" id=";gMk*PhZzVvIU5*ye4Zc">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="control" id="Q!_jCcJF^7_-(qn6CvZ,">
                                            <field name="OID">mqtt.0.openWB.set.pv.2.WhCounter</field>
                                              <block type="math_arithmetic" id="Ea`xv/s7NDugI.AC@N@g" inline="false">
                                                <value name="A">
                                                  <shadow type="math_number" id="N=7tsj%3fV7yT+T#m[MR">
                                                  </shadow>
                                                  <block type="get_value" id="pmeKMtFb8gwAO1?l@QVQ">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <shadow type="math_number" id="w`C6H+RV?nMM32v2P^09">
                                                    <field name="NUM">1000</field>
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="controls_if" id="l?PM69}O3Ny(k|n,4W!q" collapsed="true" disabled="true">
                                                <value name="IF0">
                                                  <block type="logic_compare" id="dxSHTy}..dX]31ELC?+*">
                                                    <field name="OP">EQ</field>
                                                    <value name="A">
                                                      <block type="variables_get" id="n5dslA_mI9Ou])Gyt:6A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="logic_boolean" id="+uGx@r9=;yzVQ77vRIlg">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="update" id="+|K^3$jkXW`=X}0xU/bc">
                                                      <block type="math_arithmetic" id="-fCShKtoQ)Ha2}/)PnuI">
                                                        <field name="OP">ADD</field>
                                                        <value name="A">
                                                          <shadow type="math_number" id="OgbG}/M{KA~DNG^NVzQd">
                                                          </shadow>
                                                          <block type="variables_get" id="oo#pN(_vd0J(fEiw~B_x">
                                                            <field name="VAR" id="6-EW?O6)X$_9j`r)iuXZ">energie_start</field>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <shadow type="math_number" id="wPrBhM!5:VdrFq{;y9MF">
                                                          </shadow>
                                                          <block type="math_rndfixed" id="=Ztd-ze#r??+IaxSV}ua">
                                                            <value name="x">
                                                              </shadow>
                                                              <block type="variables_get" id="v^;XU0)KEjM9-|/K~Bo4">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="variables_set" id="jGEZLQ^+h]kw.X(h]dO!">
                                                          <block type="logic_boolean" id="w+YH-t6C!S|2;e.pm;aQ">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </statement>
                            <next>
                              <block type="comment" id="S[uq}2B1D)vx]H[TnOay">
                                <field name="COMMENT">Berechnung Akku laden in kWh</field>
                                <next>
                                  <block type="variables_set" id="Vx{@=gl.R24%PVZg^HjH">
                                      <block type="get_object" id="}PPbjk$IqE~P,cG)tO;Z">
                                      </block>
                                    </value>
                                    <next>
                                      <block type="on_ext" id="tA7mP|%Y5`?gn6w1L-|D">
                                        <value name="OID0">
                                          <shadow type="field_oid" id="N7O~V4f9c?ea+dU1L`:X">
                                            <field name="oid">zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower</field>
                                          </shadow>
                                        </value>
                                          <block type="controls_if" id=")7LDT=K6QU!2Mi~2:ch[">
                                            <value name="IF0">
                                              <block type="logic_compare" id="~|FCyyy5ewSEEN=g(M/.">
                                                <value name="A">
                                                  <block type="on_source" id="P-hhEf#);IW^2rvTpOl~">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <block type="math_number" id="b[5`?J9:V/-r9#MPS,I~">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                              <block type="math_change" id="3D[l(^?)Z9jp74dD.IzF">
                                                  </shadow>
                                                  <block type="math_arithmetic" id="3KN-HkP.|^dECn0i2/5#" inline="false">
                                                    <value name="A">
                                                      </shadow>
                                                      <block type="math_arithmetic" id="@Sf}+Gea0jl=,%LWIFo2" inline="false">
                                                        <value name="A">
                                                          </shadow>
                                                          <block type="on_source" id="$^@Qa.}3uMQQJvd+da*1">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </shadow>
                                                          <block type="math_arithmetic" id="#WpJ!YOf-_7#7PC5pBa5">
                                                            <value name="A">
                                                              </shadow>
                                                              <block type="on_source" id="{n03WD2#*3bft/ra((e5">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </shadow>
                                                              <block type="on_source" id="4*MM-y!,o-]x%L{|$FGf">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <shadow type="math_number" id="BZE$ono{@LG}q4`:/JE6">
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="update" id="qXnE^jarf]|@.iM]pXSN">
                                                      <block type="math_rndfixed" id="As^GC*c3c#/ovcCj[Izk">
                                                        <value name="x">
                                                          </shadow>
                                                          <block type="variables_get" id="DVvB(,~+n;u?KX$i-3+{">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="control" id="[)VC.[VO$|K8PP2]tY67">
                                                        <field name="OID">mqtt.0.openWB.set.houseBattery.WhImported</field>
                                                          <block type="math_arithmetic" id="AhC[[X(wwlT`p31ph@gH" inline="false">
                                                            <value name="A">
                                                              </shadow>
                                                              <block type="get_value" id="?,B:`OZ!(-V](MS~Z[jR">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="095(Ty8?(Bn804.AK%N@">
                                                              </shadow>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="control" id="Z.d+spg1v98-k{7QJ@39">
                                                            <field name="OID">mqtt.0.openWB.housebattery.DailyYieldImportKwh</field>
                                                              <block type="get_value" id="APZmsgLZl?fAgf?xyAEd">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="comment" id="c=~;P.ij`)3VXFF.QfJ9">
                                            <field name="COMMENT">Berechnung Akku entladen in kWh</field>
                                            <next>
                                              <block type="variables_set" id=".iXLd,+o.#.:FMuVq*:F">
                                                  <block type="get_object" id="5#B%R6?L%PE)#VFhs8wc">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="on_ext" id="!BqpT6L5Jt9!dy}Om1f_">
                                                    <value name="OID0">
                                                      <shadow type="field_oid" id="-$}N.4QXm{r96x(/6LPZ">
                                                        <field name="oid">zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower</field>
                                                      </shadow>
                                                    </value>
                                                      <block type="controls_if" id="8v:aj[g:]uaMl].C1`_.">
                                                        <value name="IF0">
                                                          <block type="logic_compare" id="H3slbvS[c!1Lq#r^W74f">
                                                            <value name="A">
                                                              <block type="on_source" id="f.E$s3*Wp/UKOokR7Lob">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="math_number" id="#~(=zoaXW2j_5O/GTH$U">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                          <block type="math_change" id="riS3c}TAcXe_!!.plM@F">
                                                              </shadow>
                                                              <block type="math_arithmetic" id="hT!A95o{|l`Dl-*L8~w0" inline="false">
        <value name="A">
        </shadow>
        <block type="math_arithmetic" id="7h1m+`RNUVw,v~tSaaM8" inline="false">
        <value name="A">
        </shadow>
        <block type="on_source" id="nb4yu%3.-{i95)0NjX?q">
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="math_arithmetic" id="(k3DD)L{Sr1[9px73+zv">
        <value name="A">
        </shadow>
        <block type="on_source" id="[d3)`-(trr7]Jc,DR!vG">
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="on_source" id="!WejTQC/;ZkuwWS[LORL">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="rshwP?x0IX=aDOk|T6qZ">
        </shadow>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="update" id=";^JXx3vl[5u[6j}uIq(0">
        <block type="math_rndfixed" id="o4%pJbXN;{br1M}:2,Sa">
        <value name="x">
        </shadow>
        <block type="variables_get" id="e6xZibt(AEyrALe;?(`j">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="control" id="(06jUc?xnQ,eg+64uDv`">
        <field name="OID">mqtt.0.openWB.set.houseBattery.WhExported</field>
        <block type="math_arithmetic" id="G%YwXy}:JLdYme*1aOEN" inline="false">
        <value name="A">
        </shadow>
        <block type="get_value" id="PH#Ytw3L8+aUa)$O|p3m">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="D|T1ZM^54Ur/]np;jQ~L">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <block type="control" id="Y9A7~$-]]w7U3_Q~8{z." disabled="true">
        <field name="OID">mqtt.0.openWB.housebattery.DailyYieldExportKwh</field>
        <block type="get_value" id="eu()*N4cXr):1jd}|iRA">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </statement>
                                                      </block>
                                                    </statement>
                                                    <next>
                                                      <block type="comment" id="!Rz`~!wnwyL0;![Qh:}p">
                                                        <field name="COMMENT">Berechnung Abgabe Haus in kWh</field>
                                                        <next>
                                                          <block type="variables_set" id="m5[7D*Dasi6r#F2/!+c!">
                                                              <block type="get_object" id="0;Fed2($nZ._EJVqt_hI">
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="on_ext" id="lu.)LCKv`g8i-n#_TISE">
        <value name="OID0">
        <shadow type="field_oid" id="N3{ZrX7f+OsMsIP#/U9i">
        <field name="oid">zendure-solarflow.0.73bkTV.7rk1nVD9.outputHomePower</field>
        </shadow>
        </value>
        <block type="controls_if" id="+G8hcCGY@}X{m=_./ZS9">
        <value name="IF0">
        <block type="logic_compare" id="6?gQo4NovHN[5^(I,XC4">
        <value name="A">
        <block type="on_source" id="/),v0q8DTHi1duT7Tgk2">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="BB)1-0}6e._yDF76=WOt">
        </block>
        </value>
        </block>
        </value>
        <block type="math_change" id="fOOtZ|OD;Zg^wc=%q-vu">
        </shadow>
        <block type="math_arithmetic" id="6`d(*2r1-^(nDnP22u}Y" inline="false">
        <value name="A">
        </shadow>
        <block type="math_arithmetic" id=":(v{J5s[tylm.H@s?]DL" inline="false">
        <value name="A">
        </shadow>
        <block type="on_source" id="H$z%4dk~6,]g.tJqB{L5">
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="math_arithmetic" id="=~~6_;L{LVTuz+}g!4.p">
        <value name="A">
        </shadow>
        <block type="on_source" id="?Fp$bU#F^_Hg*XTrF]`^">
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="on_source" id="L^%o@Qx+t:=j#mGtra=E">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="_[!N:%RqJ25HdZ}=i7=-">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="NVg/pYOb]:Z0#~Y4x~^c">
        <block type="math_rndfixed" id="uT1DuxRN5JQjq:xj(%`+">
        <value name="x">
        </shadow>
        <block type="variables_get" id="/AI?+5SzC8*}70Yiw`In">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    diet99
    #105
    @lesiflo danke erstmal! Ich hab allerdings noch nicht ganz verstanden, was Du damit genau machst. Wo laufen die Daten hin bzw. wie werden die später dann visualisiert?
    Danke für ein paar mehr Details!
    L 1 Antwort Letzte Antwort
    • D diet99
      L Online
      L Online
      lesiflo
      #106
      @diet99 z.B. dafür:
      Widget oben links und unten rechts
      • L Online
        L Online
        lesiflo
        schrieb am zuletzt editiert von lesiflo
        #107
        @nograx: Hi, ich habe heute ein Firmware-Update vom Master auf V2.0.38 gemacht, seit dem kommen keine Daten mehr für pvPower1 und pwPower2 rein. Hat sich da eventuell etwas in der Datenstruktur/Namen verändert? Auf Github steht solarPower1 und solarPower2. Oder hast du das für den Adapter umbenannt?
        nograxN 2 Antworten Letzte Antwort
        • L lesiflo
          nograxN Online
          nograxN Online
          nograx
          #108
          @lesiflo Hi, ich habe die beiden Eingänge nur getauscht, weil Zendure in der App das auch so macht... kann das gerade leider nicht verifizieren, habe das Update noch nicht drauf - und lasse mir in der Regel immer etwas Zeit damit. Gab zuletzt ja auch öfters Probleme mit den Updates, und aktuell läuft mein System sehr zuverlässig. Never change a running system ;-)
          Können das andere auch nachvollziehen?
          D L 2 Antworten Letzte Antwort
          • nograxN nograx
            diet99
            #109
            @nograx Kann ich bestätigen. Die einzelnen Solarleistungen werden nicht mehr angezeigt:
            • nograxN nograx
              L Online
              L Online
              lesiflo
              #110
              @nograx OK, dann warte ich bis du auch so weit bist. Der Rest funktioniert ja.
              Eventuell kannst du ja noch die Berechnung in kWh von mir mit aufnehmen, nur so als Vorschlag. Die API liefert das ja nicht. Die errechneten Werte stimmen ziemlich genau mit denen der App überein.
              • L Online
                L Online
                lesiflo
                #111
                Klappt bei euch die Ausgabe der Lade/Entladezeit? Da ich hier keine Werte bekomme errechne ich mir das selber.
                Akkukapazität in Ah = Akkuanzahl x Kapazität/Ah: 2 x 20 Ah = 40 Ah (bei 2 x AB1000)
                Spannung_PV_Panel = Spannung des Moduls bei max. Leistung (aus Datenblatt vom Panel)
                Die Variablen für "remainInputTime" und "remainOutTime" müsst ihr am besten unter 0_userdata.0 selber anlegen. Evtl. eigene Namen vergeben.
                Ladezeit:
                Entladezeit:
                Export Blockly
                  <variables>
                    <variable id="y{EyYfI6aqO8WcNtPY2w">Akkukapazität</variable>
                    <variable id="JcbPVIO%aKu!SI`JU!JD">Spannung_PV_Panel</variable>
                    <variable id="!sszI/Un!f$3Hn!1tk]B">Restakku</variable>
                    <variable id="}bL170$YMV{_n7LhpGBh">Ladestrom</variable>
                    <variable id="`lOge52h.+zOY`PGJnbm">Ladezeit</variable>
                    <variable id="O^EBe~zb4T$B=87LqdjD">ladezeit_min</variable>
                    <variable id="=VOm[,NN_4Fw5ed:086w">ladezeit_std</variable>
                  </variables>
                  <block type="comment" id="0^!mX,ag|{B$l?KZ}|UK" x="775" y="539">
                    <field name="COMMENT">Ladezeit berechnen</field>
                    <next>
                      <block type="variables_set" id="%Vl9XZ[$GMcs[`qohyq?">
                        <field name="VAR" id="y{EyYfI6aqO8WcNtPY2w">Akkukapazität</field>
                          <block type="math_number" id="V^nvYM1W~tFYLcrSW%?r">
                            <field name="NUM">38.4</field>
                          </block>
                        </value>
                        <next>
                          <block type="variables_set" id="pg#LClGOjY,#MY7d0jzj">
                            <field name="VAR" id="JcbPVIO%aKu!SI`JU!JD">Spannung_PV_Panel</field>
                              <block type="math_number" id="PA8C_0?Qc{R8fas-hV1q">
                                <field name="NUM">31.21</field>
                              </block>
                            </value>
                            <next>
                              <block type="on_ext" id="-*eavH]~|+T`*5!_u%e;">
                                <value name="OID0">
                                  <shadow type="field_oid" id="`_;Zkj?K=RLIsH)Hx2K/">
                                  </shadow>
                                </value>
                                  <block type="variables_set" id="s/YcoZ4hO]7s2=r0JtL^">
                                    <field name="VAR" id="!sszI/Un!f$3Hn!1tk]B">Restakku</field>
                                      <block type="math_arithmetic" id="l2hqe6uq%QR)HjLZp[:)">
                                        <value name="A">
                                          <shadow type="math_number" id="U.3*7Od6k;ghubO(hNz8">
                                          </shadow>
                                          <block type="variables_get" id="[fcQlzl5H[rk]Q.oM[t0">
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow type="math_number" id="tNY#^EVgu|?FCRcVcqRr">
                                          </shadow>
                                          <block type="math_arithmetic" id="c#6mk`@C`ErD^`Fqk}Sg" inline="false">
                                            <value name="A">
                                              <shadow type="math_number" id="3e_E)w^DLR.[*$|bYW!6">
                                              </shadow>
                                              <block type="math_arithmetic" id="X/:pi@s:YDVIz14asd1?" inline="false">
                                                <value name="A">
                                                  <shadow type="math_number" id="z=JnJ[KV?c^5m{Rb,msG">
                                                  </shadow>
                                                  <block type="variables_get" id="C#O;Z){J.o#{DIpd6N?y">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <shadow type="math_number" id="*`j,@!H9ujzx3_f=l4cl">
                                                  </shadow>
                                                  <block type="get_value" id="_I:nxP70pMkv;kI^u66j">
                                                    <field name="OID">zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                              <shadow type="math_number" id="(4xaN|=t8Ba`uD%{U/H+">
                                                <field name="NUM">100</field>
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="controls_if" id=":UFbeKem?j7-OimUDh3c">
                                        <value name="IF0">
                                          <block type="logic_compare" id=".pvE#7x[T{-RFL?|/70P">
                                            <value name="A">
                                              <block type="get_value" id="H)fS@0:/ZD0qnCcS(Cu5">
                                                <field name="OID">zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower</field>
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="math_number" id=").TzP*5M$S[VM]%sH6xx">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="variables_set" id="h(N?0XJj6L*4Ih,k?-Wb">
                                            <field name="VAR" id="}bL170$YMV{_n7LhpGBh">Ladestrom</field>
                                              <block type="math_arithmetic" id="Diq[[l,%jJoK~SEH%mgV">
                                                <value name="A">
                                                  <shadow type="math_number" id="`s}jI^~:y:H{K?lfg__K">
                                                  </shadow>
                                                  <block type="math_arithmetic" id="}_!SwYmvLqys9]5tA0];">
                                                    <value name="A">
                                                      <shadow type="math_number" id="llxw:a{n~#0Eyqq4NYy6">
                                                      </shadow>
                                                      <block type="get_value" id="FRt=/;a{aDwSfX3PV8nx">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <shadow type="math_number" id="NL#5MAp_EEg_m4,GUmv+">
                                                      </shadow>
                                                      <block type="variables_get" id="2#|hmH%)^Z,;4b;rg0t)">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <shadow type="math_number" id="`ZA/6w^SAfpI61756S74">
                                                    <field name="NUM">2</field>
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="variables_set" id="Xr5g_mKP!2ms[;a!F7t*">
                                                <field name="VAR" id="`lOge52h.+zOY`PGJnbm">Ladezeit</field>
                                                  <block type="math_arithmetic" id="Y2EkD?z!ii7znx{8tzUQ">
                                                    <value name="A">
                                                      <shadow type="math_number" id="I:}-3F3h(R,9Lr:TVQ3`">
                                                      </shadow>
                                                      <block type="math_arithmetic" id=";oFfIK[AcS_$Y*0/I,*X" inline="false">
                                                        <value name="A">
                                                          <shadow type="math_number" id="VZ2Ra3A*87J[t{Y2vCm7">
                                                          </shadow>
                                                          <block type="math_arithmetic" id="ha|yev/:juj*Mz3K]4~j" inline="false">
                                                            <value name="A">
                                                              <shadow type="math_number" id="X2A9GcU3zX_vWAb_Z%3P">
                                                              </shadow>
                                                              <block type="variables_get" id="}zAgf*nJ%Hvt{w_Oc,=I">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="s(bc]%.$C|CI21HcOf1K">
        <field name="NUM">1.3</field>
                                                              </shadow>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <shadow type="math_number" id="A9K?p@IIdLLxXDS1S:Rd">
                                                          </shadow>
                                                          <block type="variables_get" id="xbU:n8FrM:JzTOvc]XCV">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <shadow type="math_number" id="U-s@rqdzd|J{mO|tLsZN">
                                                        <field name="NUM">60</field>
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="variables_set" id="Cu62qYG.pn{)]-7k?Dk_">
                                                    <field name="VAR" id="O^EBe~zb4T$B=87LqdjD">ladezeit_min</field>
                                                      <block type="math_modulo" id="`?T]=8CW9!`l65y9_lA:">
                                                        <value name="DIVIDEND">
                                                          <shadow type="math_number" id="QZ|BCq[:AYInR?K:plOz">
                                                            <field name="NUM">64</field>
                                                          </shadow>
                                                          <block type="variables_get" id="wK;;QlJJ?8TI@KVKpECi">
                                                          </block>
                                                        </value>
                                                        <value name="DIVISOR">
                                                          <shadow type="math_number" id="Mx_LMHgznO/jsh)a_YvO">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="variables_set" id="`%3^%]{=n=omnx//?r.D">
                                                        <field name="VAR" id="=VOm[,NN_4Fw5ed:086w">ladezeit_std</field>
                                                          <block type="math_arithmetic" id="$8Em0!,(ju2X8:X7?F-f">
                                                            <value name="A">
                                                              <shadow type="math_number" id="#)P@)|RD%,^l[4mXA)Qg">
                                                              </shadow>
                                                              <block type="math_arithmetic" id="6Nph4BRdjMeR7ypb/h;x" inline="false">
        <value name="A">
        <shadow type="math_number" id="gk(bxszYj-8oicyU^3X}">
        </shadow>
        <block type="variables_get" id="(h(/9QZc@^$Ibtp@dLR4">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="]4~#=gBD*RDDL_(m}ug/">
        </shadow>
        <block type="variables_get" id="E/!m;U7e@*%{qxgTRXN#">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="Dy!xFuu-eU4pQ-:%=-57">
                                                              </shadow>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="controls_if" id="6d-pWm-burHQ.*sRJC+9">
                                                            <value name="IF0">
                                                              <block type="logic_compare" id="5u$zbiWX0Tb(4Xsnx#.x">
        <field name="OP">LT</field>
        <value name="A">
        <block type="variables_get" id="p=wFsc/w|@vus?R?$dUJ">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="`-[L)p@1J(NF(,A{g8(Q">
        <field name="NUM">10</field>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                              <block type="control" id="rQz^Bw5l3hI#=EhTBkTs">
        <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
        <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime</field>
        <field name="DELAY_MS">1000</field>
        <field name="UNIT">ms</field>
        <block type="text_join" id="*A5Ks]vzGT4Q|+Z~v`%d">
        <mutation items="4"></mutation>
        <value name="ADD0">
        <block type="variables_get" id="~;NB[W.,7VV^nBTL:iXm">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="AXN-`:E6N[c*r*v#^RAH">
        <field name="TEXT">:</field>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id=":~CD`PfoOYsHvQ=_7-$,">
        <field name="TEXT">0</field>
        </block>
        </value>
        <value name="ADD3">
        <block type="math_round" id="#6.cB,SUy]patR)*5$Cv">
        <field name="OP">ROUND</field>
        <value name="NUM">
        <shadow type="math_number" id="U+ZA*?oz60S#xQ]rsx0V">
        <field name="NUM">3.1</field>
        </shadow>
        <block type="variables_get" id="xmgR9jeJEG47+FVO!he.">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </statement>
                                                            <statement name="ELSE">
                                                              <block type="control" id="|w!Rr2kx+Pe0Yn,w.PsE">
        <block type="text_join" id="%I|CjdFI!yn`hZ9ZYUAr">
        <value name="ADD0">
        <block type="variables_get" id="V;h9~k{YnG_nY(/09sb$">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="tA:JP+r(/3;rkg6be:j-">
        </block>
        </value>
        <value name="ADD2">
        <block type="math_round" id="~^WNC8MZCwi*w.F?,t9B">
        <value name="NUM">
        </shadow>
        <block type="variables_get" id="M6E4q7eD;^fram%+FS%1">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </statement>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                        <value name="IF1">
                                          <block type="logic_compare" id="3g;pUDzNW0w3#WSXsB=B">
                                            <value name="A">
                                              <block type="get_value" id="QGQ81pMxTZUo40StjM%V">
                                                <field name="OID">zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower</field>
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="math_number" id="@3v$5PeaR=g)XHY@1#9#">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <statement name="DO1">
                                          <block type="control" id="c6d6_.DK05Af^A4qw}($">
                                              <block type="text" id=":3Dt+0b{~?o*xK#zl@2I">
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                                <next>
                                  <block type="comment" id="/kKDTf.b[BXI;3@z?S^U">
                                    <field name="COMMENT">Endladezeit berechnen</field>
                                    <next>
                                      <block type="on_ext" id="-VY6uVv5|qV1,,%-c0ts">
                                        <value name="OID0">
                                          <shadow type="field_oid" id="RVw37Xv/+_l0a|vhZC@D">
                                          </shadow>
                                        </value>
                                          <block type="variables_set" id="5}r@EE1q%$TVm}M@z!J2">
                                              <block type="math_arithmetic" id="Mi.Sl*eD:fiWEr*E;`4B" inline="false">
                                                <value name="A">
                                                  </shadow>
                                                  <block type="math_arithmetic" id="nV=oWUzXOc@Z^EocV:,~" inline="false">
                                                    <value name="A">
                                                      </shadow>
                                                      <block type="variables_get" id="A3DFN1|%W7[ZHsAw{/fK">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </shadow>
                                                      <block type="get_value" id="u%RzP+MN-@Z3q#|jH@p)">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <shadow type="math_number" id="J/edd2*@!L%W~x0czzO1">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="controls_if" id="1.TOTFI#-9W]$,Aly6JT">
                                                <value name="IF0">
                                                  <block type="logic_compare" id="*y6Nrn`Y2t40FWw}r)A?">
                                                    <value name="A">
                                                      <block type="get_value" id="2qmOAlmhWKm2XMB1p4tH">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="math_number" id="QmHkzMr5vTTx8j49{CK}">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="variables_set" id="Bk2jv4495@cW(2?w1pv_">
                                                      <block type="math_arithmetic" id="a{DVP6E%%Ps]qEp;Qz0}">
                                                        <value name="A">
                                                          </shadow>
                                                          <block type="math_arithmetic" id="X0B/biEcj{Z0Dc=K$%Qe">
                                                            <value name="A">
                                                              </shadow>
                                                              <block type="get_value" id="C96_lVEC{G[tN[],:1D/">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </shadow>
                                                              <block type="variables_get" id="Hs/#G!wi4nf+RG!lxO8/">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <shadow type="math_number" id="7|w^L7BJPsr@kg^Q,-3A">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="variables_set" id="/)vg;u/FD2HB?f4*Dnk:">
                                                          <block type="math_arithmetic" id="G@,1szYHo|[!!?REb[TT">
                                                            <value name="A">
                                                              </shadow>
                                                              <block type="math_arithmetic" id="_llKaN,--nmtiv|gW*sP" inline="false">
        <value name="A">
        </shadow>
        <block type="math_arithmetic" id="BGhn@o3w5yLD_Nohz7H-" inline="false">
        <value name="A">
        </shadow>
        <block type="variables_get" id="ab)5sQn$b5Rh}VYB~|$G">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="TS,XL3fPev?{(w{*gf14">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="variables_get" id="bqg^%unIv/[5Rx%2t+Qq">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="#[M{Gx!_HOq:#N#c3ua9">
                                                              </shadow>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="variables_set" id="Ny%ib{Z~rw*`tp|I73gN">
                                                              <block type="math_modulo" id="$#I07pq%nO)(-zn.y7qI">
        </shadow>
        <block type="variables_get" id="5N;b6|/v-bKAKq;AT6dZ">
        </block>
        </value>
        <shadow type="math_number" id="Uz)%aWJHTk)LQk#jQ!,E">
        </shadow>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="variables_set" id="!41QYhGM9mn=V$qn%o5q">
        <block type="math_arithmetic" id="P*(8pIt)19s4W@F_Mj09">
        <value name="A">
        </shadow>
        <block type="math_arithmetic" id="f.~-COZ?GmtTiO(xsPh!" inline="false">
        <value name="A">
        </shadow>
        <block type="variables_get" id="?vYIGU^EaY9z^4FWXmm3">
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="variables_get" id="cL($n5^l2;o.n]{X,XIg">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="@nnKwenc8Y?$5{DNJa]U">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <block type="controls_if" id="+MrOC$PJ.s:XW*NKYU:8">
        <value name="IF0">
        <block type="logic_compare" id="@Dv]ZZnB-`1igoLsT)yQ">
        <value name="A">
        <block type="variables_get" id="~s2X^Ek_uF^Gh(PpqLrU">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="c+QVI{~dH_o`z7P6L?iK">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="wOk#YxmO2P(RKBUI~z(T">
        <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime</field>
        <block type="text_join" id="kV0VQ#=Z?7@Ke,g=O!Hr">
        <value name="ADD0">
        <block type="variables_get" id="lepo)3#*;{!Be[!1bw!t">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="G9E)4`[9t;;fS6/+m3NM">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="U}0?xB^$R5D2RHJaN5q*">
        </block>
        </value>
        <value name="ADD3">
        <block type="math_round" id=",Sy[/DxUI{2t7ab},%E2">
        <value name="NUM">
        </shadow>
        <block type="variables_get" id="rvUPj@!|eC7~tE/^:1yh">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <block type="control" id="FJ#j^#R1/W,tjPMeMnlY">
        <block type="text_join" id="QjjLSj$P0uPc(@sIG;U]">
        <value name="ADD0">
        <block type="variables_get" id="U@;AtX-e6*IW4s.jbpX+">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="GSZAzCP^huon7J/G(;5r">
        </block>
        </value>
        <value name="ADD2">
        <block type="math_round" id="k4C8?@`!m#r.InCJL[%r">
        <value name="NUM">
        </shadow>
        <block type="variables_get" id="a$/wx}bNig,jH8M_^CqP">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                                <value name="IF1">
                                                  <block type="logic_compare" id="$4$UB$5N*porfZX$pFBH">
                                                    <value name="A">
                                                      <block type="get_value" id=";nP^D`kw35;XmX.UKq)U">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="math_number" id="?KbNiIWARUQf4zd_;m7}">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="control" id="zSGxcU6SMNsk1T~_8f9%">
                                                      <block type="text" id="*YGgeihzw5n:LX/n/b!s">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </xml>
                nograxN 1 Antwort Letzte Antwort
                • L lesiflo
                  Ladezeit:
                  Entladezeit:
                  Export Blockly
                    <variables>
                    </variables>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                              <next>
                                  <value name="OID0">
                                    </shadow>
                                  </value>
                                          <value name="A">
                                            </shadow>
                                            </block>
                                          </value>
                                          <value name="B">
                                            </shadow>
                                              <value name="A">
                                                </shadow>
                                                  <value name="A">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                  <value name="A">
                                                    </shadow>
                                                      <value name="A">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                      <value name="A">
                                                        </shadow>
                                                          <value name="A">
                                                            </shadow>
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </shadow>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                            </shadow>
                                                            </block>
                                                          </value>
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                              <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
                                                              <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
                                                              </value>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        <value name="NUM">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </statement>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        <value name="NUM">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </statement>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                  <next>
                                      <next>
                                          <value name="OID0">
                                            </shadow>
                                          </value>
                                                  <value name="A">
                                                    </shadow>
                                                      <value name="A">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                  <value name="IF0">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                          <value name="A">
                                                            </shadow>
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                              <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
        </shadow>
        </block>
        </value>
        </shadow>
        </value>
        </block>
                                                              </value>
                                                              <next>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        <value name="NUM">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        <value name="NUM">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </statement>
                                                  <value name="IF1">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </xml>
                  nograxN Online
                  nograxN Online
                  nograx
                  schrieb am zuletzt editiert von nograx
                  #112
                  @lesiflo Ist seit gestern in einem ersten Ansatz in der Latest Version drin.
                  Kannst du mir das Blockly mal als Javascript umwandeln (sollte ein Blockly/Javascript Button geben) dann kann ich sicher was davon verwenden. Danke.
                  Mal schauen ggf. traue ich mich ja dieses Wochenende das Update durchzuführen ;-) Dann schaue ich mal was Zendure da geändert hat. Meine Vermutung ist das sie durch das Vertauschen nun 2 neue Namen für die Werte genommen haben.
                  • nograxN nograx
                    L Online
                    L Online
                    lesiflo
                    #113
                    @nograx Bitte schön, Berechnung in kWh
                    var timeout, timeout2, timeout3, Entladen_Soll, Akkukapazit_C3_A4t, Spannung_PV_Panel, Restakku, Ladestrom, Ladezeit, ladezeit_min, ladezeit_std;
                    // Aktuelle PV-Leistung [W]
                    on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.solarInputPower']), change: 'ne' }, async (obj) => {
                      let value = obj.state.val;
                      let oldValue = obj.oldState.val;
                      if ((obj.state ? obj.state.val : '') > 0) {
                        setStateDelayed('mqtt.0.openWB.set.pv.2.W' /* W */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.solarInputPower').val * -1), 50, false);
                        (() => { if (timeout) { clearTimeout(timeout); timeout = null; }})();
                      } else if ((obj.state ? obj.state.val : '') == 0) {
                        timeout = setTimeout(async () => {
                          timeout = null;
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 0);
                          setState('mqtt.0.openWB.set.pv.2.W' /* W */, 0);
                        }, 60000);
                    // Ladeleistung in Akku [W]
                    on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower']), change: 'ne' }, async (obj) => {
                        setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 1);
                        setState('mqtt.0.openWB.set.houseBattery.W' /* W */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val);
                        if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val > 0) {
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val);
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Wh' /* InOutPackPower_Wh */, (Math.round(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packInputPower_kWh').val * 1000)));
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val * -1));
                          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, 0, true, 1000, false);
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Laden [W]');
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus_Wh' /* Ladestatus_Wh */, 'Geladen [Wh]');
                        if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, 0);
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, 0);
                          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, 0, true, 1000, false);
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Standby');
                        (() => { if (timeout2) { clearTimeout(timeout2); timeout2 = null; }})();
                        timeout2 = setTimeout(async () => {
                          timeout2 = null;
                          setState('mqtt.0.openWB.set.houseBattery.W' /* W */, 0);
                        }, 30000);
                    // Entnahmeleistung aus Akku [W]
                    on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower']), change: 'ne' }, async (obj) => {
                        setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 2);
                        setState('mqtt.0.openWB.set.houseBattery.W' /* W */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val * -1));
                        if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val > 0) {
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val);
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Wh' /* InOutPackPower_Wh */, (Math.round(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.outputPackPower_kWh').val * 1000)));
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val);
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Entladen [W]');
                          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus_Wh' /* Ladestatus_Wh */, 'Geliefert [Wh]');
                        (() => { if (timeout3) { clearTimeout(timeout3); timeout3 = null; }})();
                        timeout3 = setTimeout(async () => {
                          timeout3 = null;
                        }, 30000);
                    // Aktueller Ladestand des Akkus [%] und Ausgangsleistung auf 0 setzen
                    on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel']), change: 'ne' }, async (obj) => {
                      setState('mqtt.0.openWB.set.houseBattery.%Soc' /* %Soc */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val);
                      if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val <= getState('zendure-solarflow.0.73bkTV.7rk1nVD9.minSoc').val) {
                        setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 0);
                    // Ausgangsleistung einstellen - Variabel
                    on({ id: [].concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus']).concat(['mqtt.0.openWB.global.WHouseConsumption']).concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu']), change: 'ne' }, async (obj) => {
                      if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 1 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val) {
                        if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 1 || getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2 && compareTime(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.AkkuOut_Start').val, '06:00', 'between', null)) {
                          Entladen_Soll = getState('mqtt.0.openWB.global.WHouseConsumption').val + getState('mqtt.0.openWB.pv.W').val;
                          if (Entladen_Soll > 50) {
                            setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 50);
                          } else if (Entladen_Soll > 100) {
                            setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 100);
                          } else if (Entladen_Soll > 200) {
                            setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 200);
                          } else if (Entladen_Soll > 300) {
                            setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 300);
                          } else if (Entladen_Soll > 400) {
                            setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 400);
                          } else if (Entladen_Soll > 500) {
                            setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 500);
                          } else if (Entladen_Soll > 600) {
                            setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 600);
                          } else if (Entladen_Soll <= 0) {
                            setStateDelayed('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 0, 30000, false);
                    // Ausgangsleistung einstellen - Fest sofort
                    on({ id: [].concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus']).concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu']), change: 'ne' }, async (obj) => {
                      if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val) {
                        if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 1) {
                          setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.SetOutputPower').val);
                        } else if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 0 || getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2) {
                    // Ausgangsleistung einstellen - Fest nach Zeit
                    schedule("2,17,32,47 17-22 * * *", async () => {
                      if ((getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2 && compareTime(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.AkkuOut_Start').val, '23:00', 'between', null) && getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val)) {
                    // Ladezeit berechnen
                    Akkukapazit_C3_A4t = 38.4;
                    Spannung_PV_Panel = 31.21;
                      Restakku = Akkukapazit_C3_A4t - (Akkukapazit_C3_A4t * getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val) / 100;
                        Ladestrom = (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val / Spannung_PV_Panel) / 2;
                        Ladezeit = ((Restakku / 1.3) / Ladestrom) * 60;
                        ladezeit_min = Ladezeit % 60;
                        ladezeit_std = (Ladezeit - ladezeit_min) / 60;
                        if (ladezeit_min < 10) {
                          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, ([ladezeit_std,':','0',Math.round(ladezeit_min)].join('')), 1000, false);
                        } else {
                          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, ([ladezeit_std,':',Math.round(ladezeit_min)].join('')), 1000, false);
                      } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
                        setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, '0', 1000, false);
                    // Endladezeit berechnen
                      Restakku = (Akkukapazit_C3_A4t * getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val) / 100;
                        Ladestrom = (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val / Spannung_PV_Panel) / 2;
                          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, ([ladezeit_std,':','0',Math.round(ladezeit_min)].join('')), 1000, false);
                        } else {
                          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, ([ladezeit_std,':',Math.round(ladezeit_min)].join('')), 1000, false);
                        setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, '0', 1000, false);
                    on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower']).concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower']), change: 'ne' }, async (obj) => {
                        setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime').val, 1000, false);
                      } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val > 0) {
                        setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime').val, 1000, false);
                      } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
                        setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, '0:00', 1000, false);
                    // Akkuheizung
                    on({ id: [].concat(['hm-rpc.0.LEQ0122954.1.TEMPERATURE']), change: 'ne' }, async (obj) => {
                      if ((obj.state ? obj.state.val : '') < 10 && compareTime('07:00', '17:00', 'between', null) || (obj.state ? obj.state.val : '') < 8 && (compareTime('17:01', '23:59', 'between', null) || compareTime('00:00', '06:59', 'between', null))) {
                        setState('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, true);
                        setStateDelayed('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, false, 2700000, false);
                      } else if ((obj.state ? obj.state.val : '') >= 15) {
                        setState('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, false);
                    • nograxN nograx
                      L Online
                      L Online
                      lesiflo
                      #114
                      @nograx Du solltest noch warten mit dem Update. Bei mir passen die Leistungsdaten in der App seit dem nicht mehr.
                      Meine Akku's sind voll, 1920 Wh. An Solar wurde aber nur 1.53 kWh erzeugt. Die Akkus waren vorher auf 1%. Immerhin passen aber die errechneten Wert im iobroker.
                      • L lesiflo
                          <variables>
                          </variables>
                            <next>
                                      </block>
                                    </value>
                                    <next>
                                          </block>
                                        </value>
                                        <next>
                                              </block>
                                            </value>
                                            <next>
                                                  </block>
                                                </value>
                                                <next>
                                                      </block>
                                                    </value>
                                                    <next>
                                                          </block>
                                                        </value>
                                                        <next>
                                                              </block>
                                                            </value>
                                                            <next>
        </block>
        </value>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                                <next>
                                      </block>
                                    </value>
                                    <next>
                                        <next>
                                              </block>
                                            </value>
                                            <next>
                                                <value name="OID0">
                                                  </shadow>
                                                </value>
                                                    <value name="IF0">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                          </shadow>
                                                            <value name="A">
                                                              </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </shadow>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
        <value name="x">
        </shadow>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </statement>
                                                <next>
                                                    <next>
                                                          </block>
                                                        </value>
                                                        <next>
                                                            <value name="OID0">
                                                              </shadow>
                                                            </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
                                                              </block>
                                                            </statement>
                                                            <next>
        <next>
        </block>
        </value>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <next>
        </block>
        </value>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </xml>
                        diet99
                        #115
                        @lesiflo super - dankeschön!
                        Was muß ich da jetzt alles auf mein System anpassen? Nur die vier Werte Solarleistung, Ladeleistung, Entladeleistung und Ausgangsleistung?
                        • L lesiflo
                          diet99
                          #116
                          @lesiflo Das scheint ein serverseitiges Problem zu sein. Wird im PV-Forum auch bereits diskutiert und trat wohl schon einige Tage vor der Auslieferung des Updates auf.
                          • D diet99
                            diet99
                            #117
                            @lesiflo da kommen beim Start jetzt diese Fehlermeldungen. Muß ich die Variablen zuerst bei mir anlegen? So ganz habe ich das Prinzip irgendwie noch nicht verstanden.
                            Danke!
                            • D diet99
                              Danke!
                              L Online
                              L Online
                              lesiflo
                              #118
                              @diet99 Ja, genau. Die 4 angemeckerten Variablen musst du bei dir am besten unter 0_userdata.0. in einem eigenen Ordner anlegen und dann im Script an der jeweiligen Stelle eintragen.
                              Alles was gelb markiert ist kann du rauslöschen, ist für meine Wallbox.
                              • D diet99
                                L Online
                                L Online
                                lesiflo
                                #119
                                gelöscht
                                • D diet99
                                  L Online
                                  L Online
                                  lesiflo
                                  #120
                                  @diet99 sagte in Test Adapter Zendure Solarflow:
                                  Ok, ist mir nicht aufgefallen da ich immer auf meine errechneten Werte geschaut habe, die passen ja.
                                  • L lesiflo
                                    diet99
                                    schrieb am zuletzt editiert von diet99
                                    #121
                                    @lesiflo Super - vielen Dank. Klappt jetzt offenbar.
                                    Die Zeilen mit mqtt wollte ich gerade noch nachfragen, aber das hast Du ja geschrieben, daß die rauskönnen.
                                    Nun muß ich nur noch schauen, wie ich die erzeugten Daten visualisieren kann.
                                    Werden die eigentlich irgendwo als historische Daten abgelegt, oder wie funktioniert das genau?
                                    • D diet99
                                      L Online
                                      L Online
                                      lesiflo
                                      #122
                                      @diet99 Dafür gibt es mehrere Möglichkeiten. Am besten den history-Adapter installieren und dann für die jeweiligen Datenobjekte auswählen.
                                      History-Adapter
                                      Rechts auf das Zahnrad klicken
                                      Dann auf "Aktiviert" klicken. Ich nutze jedoch influxdb und nicht history. Damit kann man noch etwas mehr machen.
                                      • D diet99
                                        L Online
                                        L Online
                                        lesiflo
                                        #123
                                        Visualisieren z.B. damit:
                                        • L lesiflo
                                          diet99
                                          #124
                                          @lesiflo ich hätte mir jetzt eher sowas vorgestellt:
                                          b27faf59-5d2f-4621-af2a-c8a36dad6254-1709224143460-25534441-b687-4f3f-90c3-bc0be652a035-image.png
                                          Dein Script läuft jedenfalls sauber! Ich hab gerade mal den PVHub angeworfen, um den restlichen Tagesertrag einzuspeisen:
                                          Danke dafür 👏
