  4. [Gelöst] Keine Netzwerkverbindung zum iobroker mehr möglich
120 Beiträge 8 Kommentatoren 18.7k Aufrufe 6 Beobachtet
  • A Airframe75
    @wendy2702 said in Keine Netzwerkverbindung zum iobroker mehr möglich:
    curl -fsL https://iobroker.net/fix.sh | bash -
    lief alles wunderbar durch
    iobroker@iobroker:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
    library: loaded
    Library version=2024-01-04
        Welcome to the ioBroker installation fixer!
        Script version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:6 https://repos.influxdata.com/debian bullseye InRelease
    Fetched 44.1 kB in 2s (29.3 kB/s)
    Reading package lists... Done
        Checking ioBroker user and directory permissions (2/5)
    [sudo] password for iobroker:
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    Airframe75
    #105
    @airframe75
    habe iobroker start geklickt aber das Problem ist immer noch das selbe
    • A Airframe75
      @airframe75
      wendy2702W Offline
      wendy2702W Offline
      #106
      @airframe75 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
      @airframe75
      Geklickt?
      Wo?
      Ist das ne Windows Installation?
      A HomoranH 2 Antworten Letzte Antwort
      • A Airframe75
        library: loaded
        Done.
        Autostart enabled!
        #107
        @airframe75
        iob nodejs-update
        • wendy2702W wendy2702
          @airframe75
          Geklickt?
          Wo?
          Airframe75
          #108
          @wendy2702
          Sorry falsches wording
          Getippt natürlich
          ich habe jetzt auch nochmal das mit dem Nodejs-update probiert. Jetzt passiert auch was
            @airframe75
            iob nodejs-update
            Airframe75
            #109
            habe ich jetzt gemacht
            ioBroker nodejs updater 2023-10-13
            Recommended nodejs-version is: 18.19.1
            Checking your installation now. Please be patient!
            Your current setup is:
            /usr/bin/nodejs         v18.17.1
            /usr/bin/node           v18.17.1
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            /usr/bin/corepack       0.18.0
            We found these nodejs versions available for installation:
            nodejs:
              Installed: 18.17.1-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
             *** 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            Nothing to do - Your installation is using the correct paths.
            You are running nodejs v18.17.1. Do you want to install recommended version 18.19.1?
            Press <y> to continue or any other key to quit
            Trying to update your installation now. Please be patient.
            Waiting for ioBroker to shut down - Give me a minute...
            *** These repos are active on your system:
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:5 https://repos.influxdata.com/debian bullseye InRelease
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            (Reading database ... 50480 files and directories currently installed.)
            Preparing to unpack .../curl_7.74.0-1.3+deb11u11_arm64.deb ...
            Unpacking curl (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
            Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u11_arm64.deb ...
            Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
            Setting up libcurl4:arm64 (7.74.0-1.3+deb11u11) ...
            Setting up curl (7.74.0-1.3+deb11u11) ...
            Processing triggers for man-db (2.9.4-2) ...
            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
            Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
            Get:7 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [7416 B]
            Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [7392 B]
            Fetched 26.9 kB in 3s (9220 B/s)
            Installing the recommended nodejs version now!
            Installing the recommended nodejs version!
            Extracting templates from packages: 100%
            Preconfiguring packages ...
            Preparing to unpack .../base-files_11.1+deb11u9_arm64.deb ...
            Unpacking base-files (11.1+deb11u9) over (11.1+deb11u8) ...
            Setting up base-files (11.1+deb11u9) ...
            Installing new version of config file /etc/debian_version ...
            Preparing to unpack .../libperl5.32_5.32.1-4+deb11u3_arm64.deb ...
            Unpacking libperl5.32:arm64 (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
            Preparing to unpack .../perl_5.32.1-4+deb11u3_arm64.deb ...
            Unpacking perl (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
            Preparing to unpack .../perl-base_5.32.1-4+deb11u3_arm64.deb ...
            Unpacking perl-base (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
            Setting up perl-base (5.32.1-4+deb11u3) ...
            Preparing to unpack .../perl-modules-5.32_5.32.1-4+deb11u3_all.deb ...
            Unpacking perl-modules-5.32 (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
            Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
            Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
            Setting up tar (1.34+dfsg-1+deb11u1) ...
            Preparing to unpack .../0-nftables_0.9.8-3.1+deb11u2_arm64.deb ...
            Unpacking nftables (0.9.8-3.1+deb11u2) over (0.9.8-3.1+deb11u1) ...
            Preparing to unpack .../1-libnftables1_0.9.8-3.1+deb11u2_arm64.deb ...
            Unpacking libnftables1:arm64 (0.9.8-3.1+deb11u2) over (0.9.8-3.1+deb11u1) ...
            Preparing to unpack .../2-libglib2.0-dev_2.66.8-1+deb11u1_arm64.deb ...
            Unpacking libglib2.0-dev:arm64 (2.66.8-1+deb11u1) over (2.66.8-1) ...
            Preparing to unpack .../3-libglib2.0-dev-bin_2.66.8-1+deb11u1_arm64.deb ...
            Unpacking libglib2.0-dev-bin (2.66.8-1+deb11u1) over (2.66.8-1) ...
            Preparing to unpack .../4-libglib2.0-data_2.66.8-1+deb11u1_all.deb ...
            Unpacking libglib2.0-data (2.66.8-1+deb11u1) over (2.66.8-1) ...
            Preparing to unpack .../5-libglib2.0-bin_2.66.8-1+deb11u1_arm64.deb ...
            Unpacking libglib2.0-bin (2.66.8-1+deb11u1) over (2.66.8-1) ...
            Preparing to unpack .../6-libglib2.0-0_2.66.8-1+deb11u1_arm64.deb ...
            Unpacking libglib2.0-0:arm64 (2.66.8-1+deb11u1) over (2.66.8-1) ...
            Preparing to unpack .../7-bluez_5.55-3.1+rpt2+deb11u1_arm64.deb ...
            Unpacking bluez (5.55-3.1+rpt2+deb11u1) over (5.55-3.1+rpt2) ...
            Preparing to unpack .../8-libssl1.1_1.1.1w-0+deb11u1+rpt1_arm64.deb ...
            Unpacking libssl1.1:arm64 (1.1.1w-0+deb11u1+rpt1) over (1.1.1w-0+deb11u1) ...
            Setting up libssl1.1:arm64 (1.1.1w-0+deb11u1+rpt1) ...
            Preparing to unpack .../openssh-sftp-server_1%3a8.4p1-5+deb11u3_arm64.deb ...
            Unpacking openssh-sftp-server (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
            Preparing to unpack .../openssh-server_1%3a8.4p1-5+deb11u3_arm64.deb ...
            Unpacking openssh-server (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
            Preparing to unpack .../openssh-client_1%3a8.4p1-5+deb11u3_arm64.deb ...
            Unpacking openssh-client (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
            Preparing to unpack .../ssh_1%3a8.4p1-5+deb11u3_all.deb ...
            Unpacking ssh (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
            Preparing to unpack .../libgnutls30_3.7.1-5+deb11u4_arm64.deb ...
            Unpacking libgnutls30:arm64 (3.7.1-5+deb11u4) over (3.7.1-5+deb11u3) ...
            Setting up libgnutls30:arm64 (3.7.1-5+deb11u4) ...
            Preparing to unpack .../00-tzdata_2024a-0+deb11u1_all.deb ...
            Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u10) ...
            Preparing to unpack .../01-bind9-libs_1%3a9.16.48-1_arm64.deb ...
            Unpacking bind9-libs:arm64 (1:9.16.48-1) over (1:9.16.44-1~deb11u1) ...
            Preparing to unpack .../02-bind9-host_1%3a9.16.48-1_arm64.deb ...
            Unpacking bind9-host (1:9.16.48-1) over (1:9.16.44-1~deb11u1) ...
            Preparing to unpack .../03-bluez-firmware_1.2-4+rpt11_all.deb ...
            Unpacking bluez-firmware (1.2-4+rpt11) over (1.2-4+rpt10) ...
            Preparing to unpack .../04-cifs-utils_2%3a6.11-3.1+deb11u2_arm64.deb ...
            Unpacking cifs-utils (2:6.11-3.1+deb11u2) over (2:6.11-3.1+deb11u1) ...
            Preparing to unpack .../05-distro-info-data_0.51+deb11u5_all.deb ...
            Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
            Preparing to unpack .../06-firmware-atheros_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
            Unpacking firmware-atheros (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
            Preparing to unpack .../07-firmware-brcm80211_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
            Unpacking firmware-brcm80211 (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
            Preparing to unpack .../08-firmware-libertas_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
            Unpacking firmware-libertas (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
            Preparing to unpack .../09-firmware-misc-nonfree_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
            Unpacking firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
            Preparing to unpack .../10-firmware-realtek_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
            Unpacking firmware-realtek (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
            Preparing to unpack .../11-libbluetooth3_5.55-3.1+rpt2+deb11u1_arm64.deb ...
            Unpacking libbluetooth3:arm64 (5.55-3.1+rpt2+deb11u1) over (5.55-3.1+rpt2) ...
            Preparing to unpack .../12-libnghttp2-14_1.43.0-1+deb11u1_arm64.deb ...
            Unpacking libnghttp2-14:arm64 (1.43.0-1+deb11u1) over (1.43.0-1) ...
            Preparing to unpack .../13-libcurl3-gnutls_7.74.0-1.3+deb11u11_arm64.deb ...
            Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
            Preparing to unpack .../14-libtiff5_4.2.0-1+deb11u5_arm64.deb ...
            Unpacking libtiff5:arm64 (4.2.0-1+deb11u5) over (4.2.0-1+deb11u4) ...
            Preparing to unpack .../15-nodejs_18.19.1-1nodesource1_arm64.deb ...
            Detected old npm client, removing...
            Unpacking nodejs (18.19.1-1nodesource1) over (18.17.1-deb-1nodesource1) ...
            Preparing to unpack .../16-openssl_1.1.1w-0+deb11u1+rpt1_arm64.deb ...
            Unpacking openssl (1.1.1w-0+deb11u1+rpt1) over (1.1.1w-0+deb11u1) ...
            Preparing to unpack .../17-raspi-config_20231012~bullseye_all.deb ...
            Unpacking raspi-config (20231012~bullseye) over (20230214) ...
            Setting up bluez-firmware (1.2-4+rpt11) ...
            Setting up libnftables1:arm64 (0.9.8-3.1+deb11u2) ...
            Setting up nftables (0.9.8-3.1+deb11u2) ...
            Setting up bind9-libs:arm64 (1:9.16.48-1) ...
            Setting up libglib2.0-0:arm64 (2.66.8-1+deb11u1) ...
            No schema files found: doing nothing.
            Setting up distro-info-data (0.51+deb11u5) ...
            Setting up openssh-client (1:8.4p1-5+deb11u3) ...
            Setting up perl-modules-5.32 (5.32.1-4+deb11u3) ...
            Setting up firmware-atheros (1:20230210-5~bpo11+1+rpt2) ...
            Setting up cifs-utils (2:6.11-3.1+deb11u2) ...
            Setting up firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt2) ...
            Setting up libnghttp2-14:arm64 (1.43.0-1+deb11u1) ...
            Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u11) ...
            Setting up nodejs (18.19.1-1nodesource1) ...
            Setting up tzdata (2024a-0+deb11u1) ...
            Current default time zone: 'Europe/Berlin'
            Local time is now:      Sun Feb 25 22:12:24 CET 2024.
            Universal Time is now:  Sun Feb 25 21:12:24 UTC 2024.
            Run 'dpkg-reconfigure tzdata' if you wish to change it.
            Setting up bluez (5.55-3.1+rpt2+deb11u1) ...
            Installing new version of config file /etc/bluetooth/input.conf ...
            Setting up libglib2.0-data (2.66.8-1+deb11u1) ...
            Setting up firmware-brcm80211 (1:20230210-5~bpo11+1+rpt2) ...
            Setting up firmware-realtek (1:20230210-5~bpo11+1+rpt2) ...
            Setting up libperl5.32:arm64 (5.32.1-4+deb11u3) ...
            Setting up firmware-libertas (1:20230210-5~bpo11+1+rpt2) ...
            Setting up libbluetooth3:arm64 (5.55-3.1+rpt2+deb11u1) ...
            Setting up libtiff5:arm64 (4.2.0-1+deb11u5) ...
            Setting up bind9-host (1:9.16.48-1) ...
            Setting up openssl (1.1.1w-0+deb11u1+rpt1) ...
            Setting up raspi-config (20231012~bullseye) ...
            Setting up libglib2.0-dev-bin (2.66.8-1+deb11u1) ...
            Setting up openssh-sftp-server (1:8.4p1-5+deb11u3) ...
            Setting up openssh-server (1:8.4p1-5+deb11u3) ...
            rescue-ssh.target is a disabled or a static unit, not starting it.
            Setting up libglib2.0-bin (2.66.8-1+deb11u1) ...
            Setting up perl (5.32.1-4+deb11u3) ...
            Setting up libglib2.0-dev:arm64 (2.66.8-1+deb11u1) ...
            Setting up ssh (1:8.4p1-5+deb11u3) ...
            Processing triggers for dbus (1.12.28-0+deb11u1) ...
            Processing triggers for mailcap (3.69) ...
            Processing triggers for initramfs-tools (0.140) ...
            We tried our best to update or fix your nodejs. Please run iob diag again to verify.
            *** RESTARTING ioBroker NOW! ***
             Please refresh or restart your browser in a few moments.
            A wendy2702W 2 Antworten Letzte Antwort
            • A Airframe75
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              Package: nodejs
              Pin-Priority: 1001
              Airframe75
              #110
              @Thomas-Braun @wendy2702 @Homoran
              endlich
                @airframe75
                Geklickt?
                Wo?
                HomoranH Offline
                HomoranH Offline
                #111
                @wendy2702 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                Geklickt?
                Wo?
                freedesktop
                • A Airframe75
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  Package: nodejs
                  Pin-Priority: 1001
                  wendy2702W Offline
                  wendy2702W Offline
                  #112
                  @airframe75 und?
                  Geht jetzt?
                  Wenn nicht
                  iob diag
                  Zeigen
                    Geklickt?
                    Wo?
                    freedesktop
                    wendy2702W Offline
                    wendy2702W Offline
                    #113
                    @homoran sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                    Geklickt?
                    Wo?
                    freedesktop
                    Deshalb war ich verwundert ob eventuell iob in einer Virtualisierung unter Win läuft
                    Thomas BraunT A 2 Antworten Letzte Antwort
                      Geklickt?
                      Wo?
                      freedesktop
                      #114
                      freedesktop ist mit dem dbus-Dienst verbandelt. Da läuft kein Desktop notwendigerweise.
                        @airframe75 und?
                        Geht jetzt?
                        Wenn nicht
                        iob diag
                        Zeigen
                        Airframe75
                        #115
                        @wendy2702
                        ich habe jetzt so häufig iob diag eingegeben. Jetzt möchte ich es auch zeigen.
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                           Static hostname: iobroker
                                 Icon name: computer
                          Operating System: Debian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.1.21-v8+
                              Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : arm64
                        Systemuptime and Load:
                         22:17:40 up 46 min,  1 user,  load average: 0.42, 1.30, 1.01
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Sun 2024-02-25 22:17:40 CET
                                   Universal time: Sun 2024-02-25 21:17:40 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        iobroker
                        /home/iobroker
                        iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            3.8G        1.6G        889M        1.0M        1.3G        2.1G
                        Swap:            99M          0B         99M
                        Total:          3.9G        1.6G        989M
                                 3794 M total memory
                                 1628 M used memory
                                 1621 M active memory
                                 1020 M inactive memory
                                  889 M free memory
                                   77 M buffer memory
                                 1198 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                        * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                        1 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G  6.4G   22G  23% /
                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                        tmpfs          tmpfs     759M  1.2M  758M   1% /run
                        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                        [Sun Feb 25 21:31:11 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FB:C3:CA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8f761cd6-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Sun Feb 25 21:31:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Sun Feb 25 21:31:12 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sun Feb 25 21:31:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        3.0G    /var/
                        2.4G    /var/log
                        801M    /var/log/journal/54548f5b193440069d487fa9f59dd13a
                        355M    /var/cache
                        Archived and active journals take up 800.4M in the file system.
                        /opt/iobroker/backups:
                        239M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        345M    /opt/iobroker/iobroker-data/
                        237M    /opt/iobroker/iobroker-data/files
                        75M     /opt/iobroker/iobroker-data/backup-objects
                        52M     /opt/iobroker/iobroker-data/files/javascript.admin
                        43M     /opt/iobroker/iobroker-data/files/iot.admin
                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                        26M     /opt/iobroker/iobroker-data/objects.jsonl
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.19.1
                        /usr/bin/node           v18.19.1
                        /usr/bin/npm            10.2.4
                        /usr/bin/npx            10.2.4
                        /usr/bin/corepack       0.22.0
                        nodejs:
                          Installed: 18.19.1-1nodesource1
                          Candidate: 18.19.1-1nodesource1
                          Version table:
                         *** 18.19.1-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                             18.19.0-1nodesource1 1001
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.12
                        admin:          6.12.0
                        javascript:     7.1.4
                        Adapters from github:   1
                        Adapter State
                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                        + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled
                          system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 - disabled
                        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
                        + system.adapter.fronius-wattpilot.1      : fronius-wattpilot     : iobroker                                 -  enabled
                        + system.adapter.fronius-wattpilot.2      : fronius-wattpilot     : iobroker                                 -  enabled
                        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                        + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                        + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled
                        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                        + system.adapter.tibberlink.1             : tibberlink            : iobroker                                 -  enabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                          system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.13.16  , installed 6.12.0 [Updatable]
                        Adapter    "alexa2"       : 3.26.4   , installed 3.26.1 [Updatable]
                        Adapter    "backitup"     : 2.10.11  , installed 2.8.7  [Updatable]
                        Adapter    "bydhvs"       : 1.5.0    , installed 1.4.0  [Updatable]
                        Adapter    "device-reminder": 3.1.2  , installed 3.0.0  [Updatable]
                        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                        Adapter    "fritzdect"    : 2.5.9    , installed 2.3.1  [Updatable]
                        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                        Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.2  [Updatable]
                        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                        Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
                        Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
                        Adapter    "iot"          : 2.0.11   , installed 2.0.11
                        Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
                        Controller "js-controller": 5.0.19   , installed 5.0.12 [Updatable]
                        Adapter    "meross"       : 1.17.0   , installed 1.15.1 [Updatable]
                        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.0  [Updatable]
                        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                        Adapter    "synology"     : 3.0.1    , installed 3.0.1
                        Adapter    "tado"         : 0.5.3    , installed 0.4.12 [Updatable]
                        Adapter    "telegram"     : 3.0.1    , installed 2.0.1  [Updatable]
                        Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                        Adapter    "text2command" : 3.0.3    , installed 3.0.2  [Updatable]
                        Adapter    "tibberlink"   : 2.2.1    , installed 1.5.0  [Updatable]
                        Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                        Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
                        Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
                        Adapter    "yr"           : 5.3.0    , installed 5.3.0
                        Adapter    "zigbee"       : 1.10.1   , installed 1.8.24 [Updatable]
                        Objects and States
                        Objects:        17012
                        States:         14331
                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       34749      12221/io.shelly.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          34355      11265/sshd: /usr/sb
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       37604      12069/iobroker.js-c
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       36647      12069/iobroker.js-c
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       37936      12305/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       35606      12094/io.admin.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          34357      11265/sshd: /usr/sb
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14584      383/avahi-daemon: r
                        udp        0      0 0.0.0.0:50776           0.0.0.0:*                           108        14586      383/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13120      512/dhcpcd
                        udp6       0      0 :::55930                :::*                                108        14587      383/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        14585      383/avahi-daemon: r
                        udp6       0      0 :::546                  :::*                                0          14783      512/dhcpcd
                        2024-02-25 22:17:53.972  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                        2024-02-25 22:17:58.241  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                        2024-02-25 22:17:58.241  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                        2024-02-25 22:17:58.247  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2024-02-25 22:18:08.248  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                        2024-02-25 22:18:08.249  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                        2024-02-25 22:18:08.254  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2024-02-25 22:18:09.269  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                        2024-02-25 22:18:18.254  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                        2024-02-25 22:18:18.255  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                        2024-02-25 22:18:18.259  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2024-02-25 22:18:24.574  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                        2024-02-25 22:18:24.806  - info: shelly.0 (12221) [MQTT] Client Close: 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1) (false)
                        2024-02-25 22:18:26.995  - info: shelly.0 (12221) [MQTT] Device with client id "shellyplus1pm-64b7080975bc" connected!
                        2024-02-25 22:18:28.260  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                        2024-02-25 22:18:28.260  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                        2024-02-25 22:18:28.276  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2024-02-25 22:18:29.004  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                        2024-02-25 22:18:38.277  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                        2024-02-25 22:18:38.277  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                        2024-02-25 22:18:38.281  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2024-02-25 22:18:44.274  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                        2024-02-25 22:18:48.282  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                        2024-02-25 22:18:48.283  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                        2024-02-25 22:18:48.296  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                        Hier die summery
                        v.2023-10-10
                              Icon name: computer
                           Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               arm64
                        Timezone:               Europe/Berlin (CET, +0100)
                        User-ID:                1000
                        X-Server:               false
                        Pending OS-Updates:     0
                        Pending iob updates:    21
                        Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                                             /usr/bin/npm            10.2.4
                                             /usr/bin/npx            10.2.4
                        Recommended versions are nodejs 18.19.1 and npm 10.2.4
                        MEMORY:
                        Mem:            3.8G        1.7G        791M        1.0M        1.3G        2.1G
                        Swap:            99M          0B         99M
                        Total:          3.9G        1.7G        891M
                        Active iob-Instances:   27
                        ioBroker Core:          js-controller           5.0.12
                                             admin                   6.12.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects: 17012
                        States: 14331
                        Size of iob-Database:
                        7.9M /opt/iobroker/iobroker-data/states.jsonl
                          Geklickt?
                          Wo?
                          freedesktop
                          Airframe75
                          #116
                          @wendy2702 @Thomas-Braun
                          Ich mache alles mit der Powershell
                          Thomas BraunT wendy2702W A 3 Antworten Letzte Antwort
                          • A Airframe75
                            #117
                            @airframe75
                            influxdb klemmt.
                            Und halt den ioBroker jetzt auf Stand.
                            iob update
                            iob upgrade
                            iob stop
                            iob upgrade self
                            iob start
                            • A Airframe75
                              wendy2702W Offline
                              wendy2702W Offline
                              #118
                              @airframe75 kommst du denn jetzt mit Browser auf den admin ?
                              • A Airframe75
                                Airframe75
                                schrieb am zuletzt editiert von Airframe75
                                #119
                                @airframe75 @wendy2702 @Thomas-Braun @Marc-Berg @Homoran @Codierknecht @Meister-Mopper @Wildbill @MartinP
                                ich möchte mich rechtherzlich bei der Lösung meines Problems bedanken. Ohne euch hätte ich das nicht hinbekommen. Dieser Thread kann jetzt als gelöst betrachtet werden.
                                Nochmals danke
                                Marc aka Airframe75
                                • A Airframe75
                                  Nochmals danke
                                  Marc aka Airframe75
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  #120
                                  @airframe75 editiere bitte deinen ersten Post und setzte ein
                                  [Gelöst]
                                  Vor die Überschrift
