  4. [Gelöst] Keine Netzwerkverbindung zum iobroker mehr möglich
120 Beiträge 8 Kommentatoren 18.7k Aufrufe 6 Beobachtet
  • wendy2702W wendy2702
    @airframe75
    curl -fsL https://iobroker.net/fix.sh | bash -
    Airframe75
    #104
    @wendy2702 said in Keine Netzwerkverbindung zum iobroker mehr möglich:
    lief alles wunderbar durch
    iobroker@iobroker:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
    library: loaded
    Library version=2024-01-04
        Welcome to the ioBroker installation fixer!
        Script version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:6 https://repos.influxdata.com/debian bullseye InRelease
    Fetched 44.1 kB in 2s (29.3 kB/s)
    Reading package lists... Done
        Checking ioBroker user and directory permissions (2/5)
    [sudo] password for iobroker:
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    A Thomas BraunT 2 Antworten Letzte Antwort
    • A Airframe75
      library: loaded
      Done.
      Autostart enabled!
      Airframe75
      #105
      @airframe75
      habe iobroker start geklickt aber das Problem ist immer noch das selbe
      • A Airframe75
        @airframe75
        wendy2702W Offline
        wendy2702W Offline
        #106
        @airframe75 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
        @airframe75
        Geklickt?
        Wo?
        Ist das ne Windows Installation?
        A HomoranH 2 Antworten Letzte Antwort
        • A Airframe75
          library: loaded
          Done.
          Autostart enabled!
          #107
          @airframe75
          iob nodejs-update
            @airframe75
            Geklickt?
            Wo?
            Airframe75
            #108
            @wendy2702
            Sorry falsches wording
            Getippt natürlich
            ich habe jetzt auch nochmal das mit dem Nodejs-update probiert. Jetzt passiert auch was
              @airframe75
              iob nodejs-update
              Airframe75
              #109
              habe ich jetzt gemacht
              ioBroker nodejs updater 2023-10-13
              Recommended nodejs-version is: 18.19.1
              Checking your installation now. Please be patient!
              Your current setup is:
              /usr/bin/nodejs         v18.17.1
              /usr/bin/node           v18.17.1
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              /usr/bin/corepack       0.18.0
              We found these nodejs versions available for installation:
              nodejs:
                Installed: 18.17.1-deb-1nodesource1
                Candidate: 18.17.1-deb-1nodesource1
                Version table:
               *** 18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
              Nothing to do - Your installation is using the correct paths.
              You are running nodejs v18.17.1. Do you want to install recommended version 18.19.1?
              Press <y> to continue or any other key to quit
              Trying to update your installation now. Please be patient.
              Waiting for ioBroker to shut down - Give me a minute...
              *** These repos are active on your system:
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:5 https://repos.influxdata.com/debian bullseye InRelease
              *** Installing ca-certificates, curl and gnupg, just in case they are missing.
              (Reading database ... 50480 files and directories currently installed.)
              Preparing to unpack .../curl_7.74.0-1.3+deb11u11_arm64.deb ...
              Unpacking curl (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
              Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u11_arm64.deb ...
              Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
              Setting up libcurl4:arm64 (7.74.0-1.3+deb11u11) ...
              Setting up curl (7.74.0-1.3+deb11u11) ...
              Processing triggers for man-db (2.9.4-2) ...
              Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
              *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
              Package: nodejs
              Pin: origin deb.nodesource.com
              Pin-Priority: 1001
              *** These repos are active after the adjustments:
              Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
              Get:7 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [7416 B]
              Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [7392 B]
              Fetched 26.9 kB in 3s (9220 B/s)
              Installing the recommended nodejs version now!
              Installing the recommended nodejs version!
              Extracting templates from packages: 100%
              Preconfiguring packages ...
              Preparing to unpack .../base-files_11.1+deb11u9_arm64.deb ...
              Unpacking base-files (11.1+deb11u9) over (11.1+deb11u8) ...
              Setting up base-files (11.1+deb11u9) ...
              Installing new version of config file /etc/debian_version ...
              Preparing to unpack .../libperl5.32_5.32.1-4+deb11u3_arm64.deb ...
              Unpacking libperl5.32:arm64 (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
              Preparing to unpack .../perl_5.32.1-4+deb11u3_arm64.deb ...
              Unpacking perl (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
              Preparing to unpack .../perl-base_5.32.1-4+deb11u3_arm64.deb ...
              Unpacking perl-base (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
              Setting up perl-base (5.32.1-4+deb11u3) ...
              Preparing to unpack .../perl-modules-5.32_5.32.1-4+deb11u3_all.deb ...
              Unpacking perl-modules-5.32 (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
              Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
              Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
              Setting up tar (1.34+dfsg-1+deb11u1) ...
              Preparing to unpack .../0-nftables_0.9.8-3.1+deb11u2_arm64.deb ...
              Unpacking nftables (0.9.8-3.1+deb11u2) over (0.9.8-3.1+deb11u1) ...
              Preparing to unpack .../1-libnftables1_0.9.8-3.1+deb11u2_arm64.deb ...
              Unpacking libnftables1:arm64 (0.9.8-3.1+deb11u2) over (0.9.8-3.1+deb11u1) ...
              Preparing to unpack .../2-libglib2.0-dev_2.66.8-1+deb11u1_arm64.deb ...
              Unpacking libglib2.0-dev:arm64 (2.66.8-1+deb11u1) over (2.66.8-1) ...
              Preparing to unpack .../3-libglib2.0-dev-bin_2.66.8-1+deb11u1_arm64.deb ...
              Unpacking libglib2.0-dev-bin (2.66.8-1+deb11u1) over (2.66.8-1) ...
              Preparing to unpack .../4-libglib2.0-data_2.66.8-1+deb11u1_all.deb ...
              Unpacking libglib2.0-data (2.66.8-1+deb11u1) over (2.66.8-1) ...
              Preparing to unpack .../5-libglib2.0-bin_2.66.8-1+deb11u1_arm64.deb ...
              Unpacking libglib2.0-bin (2.66.8-1+deb11u1) over (2.66.8-1) ...
              Preparing to unpack .../6-libglib2.0-0_2.66.8-1+deb11u1_arm64.deb ...
              Unpacking libglib2.0-0:arm64 (2.66.8-1+deb11u1) over (2.66.8-1) ...
              Preparing to unpack .../7-bluez_5.55-3.1+rpt2+deb11u1_arm64.deb ...
              Unpacking bluez (5.55-3.1+rpt2+deb11u1) over (5.55-3.1+rpt2) ...
              Preparing to unpack .../8-libssl1.1_1.1.1w-0+deb11u1+rpt1_arm64.deb ...
              Unpacking libssl1.1:arm64 (1.1.1w-0+deb11u1+rpt1) over (1.1.1w-0+deb11u1) ...
              Setting up libssl1.1:arm64 (1.1.1w-0+deb11u1+rpt1) ...
              Preparing to unpack .../openssh-sftp-server_1%3a8.4p1-5+deb11u3_arm64.deb ...
              Unpacking openssh-sftp-server (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
              Preparing to unpack .../openssh-server_1%3a8.4p1-5+deb11u3_arm64.deb ...
              Unpacking openssh-server (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
              Preparing to unpack .../openssh-client_1%3a8.4p1-5+deb11u3_arm64.deb ...
              Unpacking openssh-client (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
              Preparing to unpack .../ssh_1%3a8.4p1-5+deb11u3_all.deb ...
              Unpacking ssh (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
              Preparing to unpack .../libgnutls30_3.7.1-5+deb11u4_arm64.deb ...
              Unpacking libgnutls30:arm64 (3.7.1-5+deb11u4) over (3.7.1-5+deb11u3) ...
              Setting up libgnutls30:arm64 (3.7.1-5+deb11u4) ...
              Preparing to unpack .../00-tzdata_2024a-0+deb11u1_all.deb ...
              Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u10) ...
              Preparing to unpack .../01-bind9-libs_1%3a9.16.48-1_arm64.deb ...
              Unpacking bind9-libs:arm64 (1:9.16.48-1) over (1:9.16.44-1~deb11u1) ...
              Preparing to unpack .../02-bind9-host_1%3a9.16.48-1_arm64.deb ...
              Unpacking bind9-host (1:9.16.48-1) over (1:9.16.44-1~deb11u1) ...
              Preparing to unpack .../03-bluez-firmware_1.2-4+rpt11_all.deb ...
              Unpacking bluez-firmware (1.2-4+rpt11) over (1.2-4+rpt10) ...
              Preparing to unpack .../04-cifs-utils_2%3a6.11-3.1+deb11u2_arm64.deb ...
              Unpacking cifs-utils (2:6.11-3.1+deb11u2) over (2:6.11-3.1+deb11u1) ...
              Preparing to unpack .../05-distro-info-data_0.51+deb11u5_all.deb ...
              Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
              Preparing to unpack .../06-firmware-atheros_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
              Unpacking firmware-atheros (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
              Preparing to unpack .../07-firmware-brcm80211_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
              Unpacking firmware-brcm80211 (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
              Preparing to unpack .../08-firmware-libertas_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
              Unpacking firmware-libertas (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
              Preparing to unpack .../09-firmware-misc-nonfree_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
              Unpacking firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
              Preparing to unpack .../10-firmware-realtek_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
              Unpacking firmware-realtek (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
              Preparing to unpack .../11-libbluetooth3_5.55-3.1+rpt2+deb11u1_arm64.deb ...
              Unpacking libbluetooth3:arm64 (5.55-3.1+rpt2+deb11u1) over (5.55-3.1+rpt2) ...
              Preparing to unpack .../12-libnghttp2-14_1.43.0-1+deb11u1_arm64.deb ...
              Unpacking libnghttp2-14:arm64 (1.43.0-1+deb11u1) over (1.43.0-1) ...
              Preparing to unpack .../13-libcurl3-gnutls_7.74.0-1.3+deb11u11_arm64.deb ...
              Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
              Preparing to unpack .../14-libtiff5_4.2.0-1+deb11u5_arm64.deb ...
              Unpacking libtiff5:arm64 (4.2.0-1+deb11u5) over (4.2.0-1+deb11u4) ...
              Preparing to unpack .../15-nodejs_18.19.1-1nodesource1_arm64.deb ...
              Detected old npm client, removing...
              Unpacking nodejs (18.19.1-1nodesource1) over (18.17.1-deb-1nodesource1) ...
              Preparing to unpack .../16-openssl_1.1.1w-0+deb11u1+rpt1_arm64.deb ...
              Unpacking openssl (1.1.1w-0+deb11u1+rpt1) over (1.1.1w-0+deb11u1) ...
              Preparing to unpack .../17-raspi-config_20231012~bullseye_all.deb ...
              Unpacking raspi-config (20231012~bullseye) over (20230214) ...
              Setting up bluez-firmware (1.2-4+rpt11) ...
              Setting up libnftables1:arm64 (0.9.8-3.1+deb11u2) ...
              Setting up nftables (0.9.8-3.1+deb11u2) ...
              Setting up bind9-libs:arm64 (1:9.16.48-1) ...
              Setting up libglib2.0-0:arm64 (2.66.8-1+deb11u1) ...
              No schema files found: doing nothing.
              Setting up distro-info-data (0.51+deb11u5) ...
              Setting up openssh-client (1:8.4p1-5+deb11u3) ...
              Setting up perl-modules-5.32 (5.32.1-4+deb11u3) ...
              Setting up firmware-atheros (1:20230210-5~bpo11+1+rpt2) ...
              Setting up cifs-utils (2:6.11-3.1+deb11u2) ...
              Setting up firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt2) ...
              Setting up libnghttp2-14:arm64 (1.43.0-1+deb11u1) ...
              Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u11) ...
              Setting up nodejs (18.19.1-1nodesource1) ...
              Setting up tzdata (2024a-0+deb11u1) ...
              Current default time zone: 'Europe/Berlin'
              Local time is now:      Sun Feb 25 22:12:24 CET 2024.
              Universal Time is now:  Sun Feb 25 21:12:24 UTC 2024.
              Run 'dpkg-reconfigure tzdata' if you wish to change it.
              Setting up bluez (5.55-3.1+rpt2+deb11u1) ...
              Installing new version of config file /etc/bluetooth/input.conf ...
              Setting up libglib2.0-data (2.66.8-1+deb11u1) ...
              Setting up firmware-brcm80211 (1:20230210-5~bpo11+1+rpt2) ...
              Setting up firmware-realtek (1:20230210-5~bpo11+1+rpt2) ...
              Setting up libperl5.32:arm64 (5.32.1-4+deb11u3) ...
              Setting up firmware-libertas (1:20230210-5~bpo11+1+rpt2) ...
              Setting up libbluetooth3:arm64 (5.55-3.1+rpt2+deb11u1) ...
              Setting up libtiff5:arm64 (4.2.0-1+deb11u5) ...
              Setting up bind9-host (1:9.16.48-1) ...
              Setting up openssl (1.1.1w-0+deb11u1+rpt1) ...
              Setting up raspi-config (20231012~bullseye) ...
              Setting up libglib2.0-dev-bin (2.66.8-1+deb11u1) ...
              Setting up openssh-sftp-server (1:8.4p1-5+deb11u3) ...
              Setting up openssh-server (1:8.4p1-5+deb11u3) ...
              rescue-ssh.target is a disabled or a static unit, not starting it.
              Setting up libglib2.0-bin (2.66.8-1+deb11u1) ...
              Setting up perl (5.32.1-4+deb11u3) ...
              Setting up libglib2.0-dev:arm64 (2.66.8-1+deb11u1) ...
              Setting up ssh (1:8.4p1-5+deb11u3) ...
              Processing triggers for dbus (1.12.28-0+deb11u1) ...
              Processing triggers for mailcap (3.69) ...
              Processing triggers for initramfs-tools (0.140) ...
              We tried our best to update or fix your nodejs. Please run iob diag again to verify.
              *** RESTARTING ioBroker NOW! ***
               Please refresh or restart your browser in a few moments.
              A wendy2702W 2 Antworten Letzte Antwort
              • A Airframe75
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                Package: nodejs
                Pin-Priority: 1001
                Airframe75
                #110
                @Thomas-Braun @wendy2702 @Homoran
                endlich
                  @airframe75
                  Geklickt?
                  Wo?
                  HomoranH Offline
                  HomoranH Offline
                  #111
                  @wendy2702 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                  Geklickt?
                  Wo?
                  freedesktop
                  • A Airframe75
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    Package: nodejs
                    Pin-Priority: 1001
                    wendy2702W Offline
                    wendy2702W Offline
                    #112
                    @airframe75 und?
                    Geht jetzt?
                    Wenn nicht
                    iob diag
                    Zeigen
                      Geklickt?
                      Wo?
                      freedesktop
                      wendy2702W Offline
                      wendy2702W Offline
                      #113
                      @homoran sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                      Geklickt?
                      Wo?
                      freedesktop
                      Deshalb war ich verwundert ob eventuell iob in einer Virtualisierung unter Win läuft
                      Thomas BraunT A 2 Antworten Letzte Antwort
                        Geklickt?
                        Wo?
                        freedesktop
                        #114
                        freedesktop ist mit dem dbus-Dienst verbandelt. Da läuft kein Desktop notwendigerweise.
                          @airframe75 und?
                          Geht jetzt?
                          Wenn nicht
                          iob diag
                          Zeigen
                          Airframe75
                          #115
                          @wendy2702
                          ich habe jetzt so häufig iob diag eingegeben. Jetzt möchte ich es auch zeigen.
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                             Static hostname: iobroker
                                   Icon name: computer
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.1.21-v8+
                                Architecture: arm64
                          Model           : Raspberry Pi 4 Model B Rev 1.5
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : arm64
                          Systemuptime and Load:
                           22:17:40 up 46 min,  1 user,  load average: 0.42, 1.30, 1.01
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Sun 2024-02-25 22:17:40 CET
                                     Universal time: Sun 2024-02-25 21:17:40 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          iobroker
                          /home/iobroker
                          iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
                          *** X-Server-Setup ***
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          Boot Target:    multi-user.target
                          *** MEMORY ***
                          Mem:            3.8G        1.6G        889M        1.0M        1.3G        2.1G
                          Swap:            99M          0B         99M
                          Total:          3.9G        1.6G        989M
                                   3794 M total memory
                                   1628 M used memory
                                   1621 M active memory
                                   1020 M inactive memory
                                    889 M free memory
                                     77 M buffer memory
                                   1198 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FAILED SERVICES ***
                            UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                          * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/root      ext4       29G  6.4G   22G  23% /
                          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                          tmpfs          tmpfs     759M  1.2M  758M   1% /run
                          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                          [Sun Feb 25 21:31:11 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FB:C3:CA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8f761cd6-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Sun Feb 25 21:31:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun Feb 25 21:31:12 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Sun Feb 25 21:31:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          TARGET  SOURCE         FSTYPE OPTIONS
                          /       /dev/mmcblk0p2 ext4   rw,noatime
                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          3.0G    /var/
                          2.4G    /var/log
                          801M    /var/log/journal/54548f5b193440069d487fa9f59dd13a
                          355M    /var/cache
                          Archived and active journals take up 800.4M in the file system.
                          /opt/iobroker/backups:
                          239M    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          345M    /opt/iobroker/iobroker-data/
                          237M    /opt/iobroker/iobroker-data/files
                          75M     /opt/iobroker/iobroker-data/backup-objects
                          52M     /opt/iobroker/iobroker-data/files/javascript.admin
                          43M     /opt/iobroker/iobroker-data/files/iot.admin
                          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                          26M     /opt/iobroker/iobroker-data/objects.jsonl
                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                          18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                          8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                          USB-Devices by-id:
                          /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v18.19.1
                          /usr/bin/node           v18.19.1
                          /usr/bin/npm            10.2.4
                          /usr/bin/npx            10.2.4
                          /usr/bin/corepack       0.22.0
                          nodejs:
                            Installed: 18.19.1-1nodesource1
                            Candidate: 18.19.1-1nodesource1
                            Version table:
                           *** 18.19.1-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                               18.19.0-1nodesource1 1001
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller:  5.0.12
                          admin:          6.12.0
                          javascript:     7.1.4
                          Adapters from github:   1
                          Adapter State
                          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                          + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled
                            system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 - disabled
                          + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                          + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
                          + system.adapter.fronius-wattpilot.1      : fronius-wattpilot     : iobroker                                 -  enabled
                          + system.adapter.fronius-wattpilot.2      : fronius-wattpilot     : iobroker                                 -  enabled
                          + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                          + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                            system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                          + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled
                          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                          + system.adapter.tibberlink.1             : tibberlink            : iobroker                                 -  enabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                            system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "admin"        : 6.13.16  , installed 6.12.0 [Updatable]
                          Adapter    "alexa2"       : 3.26.4   , installed 3.26.1 [Updatable]
                          Adapter    "backitup"     : 2.10.11  , installed 2.8.7  [Updatable]
                          Adapter    "bydhvs"       : 1.5.0    , installed 1.4.0  [Updatable]
                          Adapter    "device-reminder": 3.1.2  , installed 3.0.0  [Updatable]
                          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                          Adapter    "fritzdect"    : 2.5.9    , installed 2.3.1  [Updatable]
                          Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                          Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.2  [Updatable]
                          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                          Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
                          Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
                          Adapter    "iot"          : 2.0.11   , installed 2.0.11
                          Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
                          Controller "js-controller": 5.0.19   , installed 5.0.12 [Updatable]
                          Adapter    "meross"       : 1.17.0   , installed 1.15.1 [Updatable]
                          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.0  [Updatable]
                          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                          Adapter    "synology"     : 3.0.1    , installed 3.0.1
                          Adapter    "tado"         : 0.5.3    , installed 0.4.12 [Updatable]
                          Adapter    "telegram"     : 3.0.1    , installed 2.0.1  [Updatable]
                          Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                          Adapter    "text2command" : 3.0.3    , installed 3.0.2  [Updatable]
                          Adapter    "tibberlink"   : 2.2.1    , installed 1.5.0  [Updatable]
                          Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
                          Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                          Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
                          Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
                          Adapter    "yr"           : 5.3.0    , installed 5.3.0
                          Adapter    "zigbee"       : 1.10.1   , installed 1.8.24 [Updatable]
                          Objects and States
                          Objects:        17012
                          States:         14331
                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       34749      12221/io.shelly.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          34355      11265/sshd: /usr/sb
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       37604      12069/iobroker.js-c
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       36647      12069/iobroker.js-c
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       37936      12305/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       35606      12094/io.admin.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          34357      11265/sshd: /usr/sb
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14584      383/avahi-daemon: r
                          udp        0      0 0.0.0.0:50776           0.0.0.0:*                           108        14586      383/avahi-daemon: r
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13120      512/dhcpcd
                          udp6       0      0 :::55930                :::*                                108        14587      383/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        14585      383/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          14783      512/dhcpcd
                          2024-02-25 22:17:53.972  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                          2024-02-25 22:17:58.241  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                          2024-02-25 22:17:58.241  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                          2024-02-25 22:17:58.247  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                          2024-02-25 22:18:08.248  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                          2024-02-25 22:18:08.249  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                          2024-02-25 22:18:08.254  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                          2024-02-25 22:18:09.269  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                          2024-02-25 22:18:18.254  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                          2024-02-25 22:18:18.255  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                          2024-02-25 22:18:18.259  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                          2024-02-25 22:18:24.574  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                          2024-02-25 22:18:24.806  - info: shelly.0 (12221) [MQTT] Client Close: 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1) (false)
                          2024-02-25 22:18:26.995  - info: shelly.0 (12221) [MQTT] Device with client id "shellyplus1pm-64b7080975bc" connected!
                          2024-02-25 22:18:28.260  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                          2024-02-25 22:18:28.260  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                          2024-02-25 22:18:28.276  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                          2024-02-25 22:18:29.004  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                          2024-02-25 22:18:38.277  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                          2024-02-25 22:18:38.277  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                          2024-02-25 22:18:38.281  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                          2024-02-25 22:18:44.274  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                          2024-02-25 22:18:48.282  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                          2024-02-25 22:18:48.283  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                          2024-02-25 22:18:48.296  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                          Hier die summery
                          v.2023-10-10
                                Icon name: computer
                             Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               arm64
                          Timezone:               Europe/Berlin (CET, +0100)
                          User-ID:                1000
                          X-Server:               false
                          Pending OS-Updates:     0
                          Pending iob updates:    21
                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                                               /usr/bin/npm            10.2.4
                                               /usr/bin/npx            10.2.4
                          Recommended versions are nodejs 18.19.1 and npm 10.2.4
                          MEMORY:
                          Mem:            3.8G        1.7G        791M        1.0M        1.3G        2.1G
                          Swap:            99M          0B         99M
                          Total:          3.9G        1.7G        891M
                          Active iob-Instances:   27
                          ioBroker Core:          js-controller           5.0.12
                                               admin                   6.12.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 17012
                          States: 14331
                          Size of iob-Database:
                          7.9M /opt/iobroker/iobroker-data/states.jsonl
                            Geklickt?
                            Wo?
                            freedesktop
                            Airframe75
                            #116
                            @wendy2702 @Thomas-Braun
                            Ich mache alles mit der Powershell
                            Thomas BraunT wendy2702W A 3 Antworten Letzte Antwort
                            • A Airframe75
                              #117
                              @airframe75
                              influxdb klemmt.
                              Und halt den ioBroker jetzt auf Stand.
                              iob update
                              iob upgrade
                              iob stop
                              iob upgrade self
                              iob start
                              • A Airframe75
                                wendy2702W Offline
                                wendy2702W Offline
                                #118
                                @airframe75 kommst du denn jetzt mit Browser auf den admin ?
                                • A Airframe75
                                  Airframe75
                                  schrieb am zuletzt editiert von Airframe75
                                  #119
                                  @airframe75 @wendy2702 @Thomas-Braun @Marc-Berg @Homoran @Codierknecht @Meister-Mopper @Wildbill @MartinP
                                  ich möchte mich rechtherzlich bei der Lösung meines Problems bedanken. Ohne euch hätte ich das nicht hinbekommen. Dieser Thread kann jetzt als gelöst betrachtet werden.
                                  Nochmals danke
                                  Marc aka Airframe75
                                  • A Airframe75
                                    Nochmals danke
                                    Marc aka Airframe75
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    #120
                                    @airframe75 editiere bitte deinen ersten Post und setzte ein
                                    [Gelöst]
                                    Vor die Überschrift
