  4. [Gelöst] Keine Netzwerkverbindung zum iobroker mehr möglich
120 Beiträge 8 Kommentatoren 18.7k Aufrufe 6 Beobachtet
  • A Airframe75
    @homoran said in Keine Netzwerkverbindung zum iobroker mehr möglich:
    Ich habe mir die Videoanleitung angeschaut
    An das Video kommt man nur per Login dran
    wendy2702W Offline
    wendy2702W Offline
    #103
    @airframe75
    curl -fsL https://iobroker.net/fix.sh | bash -
    • wendy2702W wendy2702
      @airframe75
      Airframe75
      #104
      @wendy2702 said in Keine Netzwerkverbindung zum iobroker mehr möglich:
      lief alles wunderbar durch
      iobroker@iobroker:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2024-01-04
          Welcome to the ioBroker installation fixer!
          Script version: 2024-01-04
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:6 https://repos.influxdata.com/debian bullseye InRelease
      Fetched 44.1 kB in 2s (29.3 kB/s)
      Reading package lists... Done
          Checking ioBroker user and directory permissions (2/5)
      [sudo] password for iobroker:
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      A Thomas BraunT 2 Antworten Letzte Antwort
      • A Airframe75
        library: loaded
        Done.
        Autostart enabled!
        Airframe75
        #105
        @airframe75
        habe iobroker start geklickt aber das Problem ist immer noch das selbe
        • A Airframe75
          @airframe75
          wendy2702W Offline
          wendy2702W Offline
          #106
          @airframe75 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
          @airframe75
          Geklickt?
          Wo?
          Ist das ne Windows Installation?
          A HomoranH 2 Antworten Letzte Antwort
          • A Airframe75
            library: loaded
            Done.
            Autostart enabled!
            #107
            @airframe75
            iob nodejs-update
              @airframe75
              Geklickt?
              Wo?
              Airframe75
              #108
              @wendy2702
              Sorry falsches wording
              Getippt natürlich
              ich habe jetzt auch nochmal das mit dem Nodejs-update probiert. Jetzt passiert auch was
                @airframe75
                iob nodejs-update
                Airframe75
                #109
                habe ich jetzt gemacht
                ioBroker nodejs updater 2023-10-13
                Recommended nodejs-version is: 18.19.1
                Checking your installation now. Please be patient!
                Your current setup is:
                /usr/bin/nodejs         v18.17.1
                /usr/bin/node           v18.17.1
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                /usr/bin/corepack       0.18.0
                We found these nodejs versions available for installation:
                nodejs:
                  Installed: 18.17.1-deb-1nodesource1
                  Candidate: 18.17.1-deb-1nodesource1
                  Version table:
                 *** 18.17.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                Nothing to do - Your installation is using the correct paths.
                You are running nodejs v18.17.1. Do you want to install recommended version 18.19.1?
                Press <y> to continue or any other key to quit
                Trying to update your installation now. Please be patient.
                Waiting for ioBroker to shut down - Give me a minute...
                *** These repos are active on your system:
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:5 https://repos.influxdata.com/debian bullseye InRelease
                *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                (Reading database ... 50480 files and directories currently installed.)
                Preparing to unpack .../curl_7.74.0-1.3+deb11u11_arm64.deb ...
                Unpacking curl (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
                Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u11_arm64.deb ...
                Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
                Setting up libcurl4:arm64 (7.74.0-1.3+deb11u11) ...
                Setting up curl (7.74.0-1.3+deb11u11) ...
                Processing triggers for man-db (2.9.4-2) ...
                Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
                *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                Package: nodejs
                Pin: origin deb.nodesource.com
                Pin-Priority: 1001
                *** These repos are active after the adjustments:
                Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                Get:7 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [7416 B]
                Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [7392 B]
                Fetched 26.9 kB in 3s (9220 B/s)
                Installing the recommended nodejs version now!
                Installing the recommended nodejs version!
                Extracting templates from packages: 100%
                Preconfiguring packages ...
                Preparing to unpack .../base-files_11.1+deb11u9_arm64.deb ...
                Unpacking base-files (11.1+deb11u9) over (11.1+deb11u8) ...
                Setting up base-files (11.1+deb11u9) ...
                Installing new version of config file /etc/debian_version ...
                Preparing to unpack .../libperl5.32_5.32.1-4+deb11u3_arm64.deb ...
                Unpacking libperl5.32:arm64 (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
                Preparing to unpack .../perl_5.32.1-4+deb11u3_arm64.deb ...
                Unpacking perl (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
                Preparing to unpack .../perl-base_5.32.1-4+deb11u3_arm64.deb ...
                Unpacking perl-base (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
                Setting up perl-base (5.32.1-4+deb11u3) ...
                Preparing to unpack .../perl-modules-5.32_5.32.1-4+deb11u3_all.deb ...
                Unpacking perl-modules-5.32 (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
                Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
                Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
                Setting up tar (1.34+dfsg-1+deb11u1) ...
                Preparing to unpack .../0-nftables_0.9.8-3.1+deb11u2_arm64.deb ...
                Unpacking nftables (0.9.8-3.1+deb11u2) over (0.9.8-3.1+deb11u1) ...
                Preparing to unpack .../1-libnftables1_0.9.8-3.1+deb11u2_arm64.deb ...
                Unpacking libnftables1:arm64 (0.9.8-3.1+deb11u2) over (0.9.8-3.1+deb11u1) ...
                Preparing to unpack .../2-libglib2.0-dev_2.66.8-1+deb11u1_arm64.deb ...
                Unpacking libglib2.0-dev:arm64 (2.66.8-1+deb11u1) over (2.66.8-1) ...
                Preparing to unpack .../3-libglib2.0-dev-bin_2.66.8-1+deb11u1_arm64.deb ...
                Unpacking libglib2.0-dev-bin (2.66.8-1+deb11u1) over (2.66.8-1) ...
                Preparing to unpack .../4-libglib2.0-data_2.66.8-1+deb11u1_all.deb ...
                Unpacking libglib2.0-data (2.66.8-1+deb11u1) over (2.66.8-1) ...
                Preparing to unpack .../5-libglib2.0-bin_2.66.8-1+deb11u1_arm64.deb ...
                Unpacking libglib2.0-bin (2.66.8-1+deb11u1) over (2.66.8-1) ...
                Preparing to unpack .../6-libglib2.0-0_2.66.8-1+deb11u1_arm64.deb ...
                Unpacking libglib2.0-0:arm64 (2.66.8-1+deb11u1) over (2.66.8-1) ...
                Preparing to unpack .../7-bluez_5.55-3.1+rpt2+deb11u1_arm64.deb ...
                Unpacking bluez (5.55-3.1+rpt2+deb11u1) over (5.55-3.1+rpt2) ...
                Preparing to unpack .../8-libssl1.1_1.1.1w-0+deb11u1+rpt1_arm64.deb ...
                Unpacking libssl1.1:arm64 (1.1.1w-0+deb11u1+rpt1) over (1.1.1w-0+deb11u1) ...
                Setting up libssl1.1:arm64 (1.1.1w-0+deb11u1+rpt1) ...
                Preparing to unpack .../openssh-sftp-server_1%3a8.4p1-5+deb11u3_arm64.deb ...
                Unpacking openssh-sftp-server (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
                Preparing to unpack .../openssh-server_1%3a8.4p1-5+deb11u3_arm64.deb ...
                Unpacking openssh-server (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
                Preparing to unpack .../openssh-client_1%3a8.4p1-5+deb11u3_arm64.deb ...
                Unpacking openssh-client (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
                Preparing to unpack .../ssh_1%3a8.4p1-5+deb11u3_all.deb ...
                Unpacking ssh (1:8.4p1-5+deb11u3) over (1:8.4p1-5+deb11u2) ...
                Preparing to unpack .../libgnutls30_3.7.1-5+deb11u4_arm64.deb ...
                Unpacking libgnutls30:arm64 (3.7.1-5+deb11u4) over (3.7.1-5+deb11u3) ...
                Setting up libgnutls30:arm64 (3.7.1-5+deb11u4) ...
                Preparing to unpack .../00-tzdata_2024a-0+deb11u1_all.deb ...
                Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u10) ...
                Preparing to unpack .../01-bind9-libs_1%3a9.16.48-1_arm64.deb ...
                Unpacking bind9-libs:arm64 (1:9.16.48-1) over (1:9.16.44-1~deb11u1) ...
                Preparing to unpack .../02-bind9-host_1%3a9.16.48-1_arm64.deb ...
                Unpacking bind9-host (1:9.16.48-1) over (1:9.16.44-1~deb11u1) ...
                Preparing to unpack .../03-bluez-firmware_1.2-4+rpt11_all.deb ...
                Unpacking bluez-firmware (1.2-4+rpt11) over (1.2-4+rpt10) ...
                Preparing to unpack .../04-cifs-utils_2%3a6.11-3.1+deb11u2_arm64.deb ...
                Unpacking cifs-utils (2:6.11-3.1+deb11u2) over (2:6.11-3.1+deb11u1) ...
                Preparing to unpack .../05-distro-info-data_0.51+deb11u5_all.deb ...
                Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
                Preparing to unpack .../06-firmware-atheros_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
                Unpacking firmware-atheros (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
                Preparing to unpack .../07-firmware-brcm80211_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
                Unpacking firmware-brcm80211 (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
                Preparing to unpack .../08-firmware-libertas_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
                Unpacking firmware-libertas (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
                Preparing to unpack .../09-firmware-misc-nonfree_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
                Unpacking firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
                Preparing to unpack .../10-firmware-realtek_1%3a20230210-5~bpo11+1+rpt2_all.deb ...
                Unpacking firmware-realtek (1:20230210-5~bpo11+1+rpt2) over (1:20230210-5~bpo11+1+rpt1) ...
                Preparing to unpack .../11-libbluetooth3_5.55-3.1+rpt2+deb11u1_arm64.deb ...
                Unpacking libbluetooth3:arm64 (5.55-3.1+rpt2+deb11u1) over (5.55-3.1+rpt2) ...
                Preparing to unpack .../12-libnghttp2-14_1.43.0-1+deb11u1_arm64.deb ...
                Unpacking libnghttp2-14:arm64 (1.43.0-1+deb11u1) over (1.43.0-1) ...
                Preparing to unpack .../13-libcurl3-gnutls_7.74.0-1.3+deb11u11_arm64.deb ...
                Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u9) ...
                Preparing to unpack .../14-libtiff5_4.2.0-1+deb11u5_arm64.deb ...
                Unpacking libtiff5:arm64 (4.2.0-1+deb11u5) over (4.2.0-1+deb11u4) ...
                Preparing to unpack .../15-nodejs_18.19.1-1nodesource1_arm64.deb ...
                Detected old npm client, removing...
                Unpacking nodejs (18.19.1-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                Preparing to unpack .../16-openssl_1.1.1w-0+deb11u1+rpt1_arm64.deb ...
                Unpacking openssl (1.1.1w-0+deb11u1+rpt1) over (1.1.1w-0+deb11u1) ...
                Preparing to unpack .../17-raspi-config_20231012~bullseye_all.deb ...
                Unpacking raspi-config (20231012~bullseye) over (20230214) ...
                Setting up bluez-firmware (1.2-4+rpt11) ...
                Setting up libnftables1:arm64 (0.9.8-3.1+deb11u2) ...
                Setting up nftables (0.9.8-3.1+deb11u2) ...
                Setting up bind9-libs:arm64 (1:9.16.48-1) ...
                Setting up libglib2.0-0:arm64 (2.66.8-1+deb11u1) ...
                No schema files found: doing nothing.
                Setting up distro-info-data (0.51+deb11u5) ...
                Setting up openssh-client (1:8.4p1-5+deb11u3) ...
                Setting up perl-modules-5.32 (5.32.1-4+deb11u3) ...
                Setting up firmware-atheros (1:20230210-5~bpo11+1+rpt2) ...
                Setting up cifs-utils (2:6.11-3.1+deb11u2) ...
                Setting up firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt2) ...
                Setting up libnghttp2-14:arm64 (1.43.0-1+deb11u1) ...
                Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u11) ...
                Setting up nodejs (18.19.1-1nodesource1) ...
                Setting up tzdata (2024a-0+deb11u1) ...
                Current default time zone: 'Europe/Berlin'
                Local time is now:      Sun Feb 25 22:12:24 CET 2024.
                Universal Time is now:  Sun Feb 25 21:12:24 UTC 2024.
                Run 'dpkg-reconfigure tzdata' if you wish to change it.
                Setting up bluez (5.55-3.1+rpt2+deb11u1) ...
                Installing new version of config file /etc/bluetooth/input.conf ...
                Setting up libglib2.0-data (2.66.8-1+deb11u1) ...
                Setting up firmware-brcm80211 (1:20230210-5~bpo11+1+rpt2) ...
                Setting up firmware-realtek (1:20230210-5~bpo11+1+rpt2) ...
                Setting up libperl5.32:arm64 (5.32.1-4+deb11u3) ...
                Setting up firmware-libertas (1:20230210-5~bpo11+1+rpt2) ...
                Setting up libbluetooth3:arm64 (5.55-3.1+rpt2+deb11u1) ...
                Setting up libtiff5:arm64 (4.2.0-1+deb11u5) ...
                Setting up bind9-host (1:9.16.48-1) ...
                Setting up openssl (1.1.1w-0+deb11u1+rpt1) ...
                Setting up raspi-config (20231012~bullseye) ...
                Setting up libglib2.0-dev-bin (2.66.8-1+deb11u1) ...
                Setting up openssh-sftp-server (1:8.4p1-5+deb11u3) ...
                Setting up openssh-server (1:8.4p1-5+deb11u3) ...
                rescue-ssh.target is a disabled or a static unit, not starting it.
                Setting up libglib2.0-bin (2.66.8-1+deb11u1) ...
                Setting up perl (5.32.1-4+deb11u3) ...
                Setting up libglib2.0-dev:arm64 (2.66.8-1+deb11u1) ...
                Setting up ssh (1:8.4p1-5+deb11u3) ...
                Processing triggers for dbus (1.12.28-0+deb11u1) ...
                Processing triggers for mailcap (3.69) ...
                Processing triggers for initramfs-tools (0.140) ...
                We tried our best to update or fix your nodejs. Please run iob diag again to verify.
                *** RESTARTING ioBroker NOW! ***
                 Please refresh or restart your browser in a few moments.
                A wendy2702W 2 Antworten Letzte Antwort
                • A Airframe75
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  Package: nodejs
                  Pin-Priority: 1001
                  Airframe75
                  #110
                  @Thomas-Braun @wendy2702 @Homoran
                  endlich
                    @airframe75
                    Geklickt?
                    Wo?
                    HomoranH Offline
                    HomoranH Offline
                    #111
                    @wendy2702 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                    Geklickt?
                    Wo?
                    freedesktop
                    • A Airframe75
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Version table:
                      Package: nodejs
                      Pin-Priority: 1001
                      wendy2702W Offline
                      wendy2702W Offline
                      #112
                      @airframe75 und?
                      Geht jetzt?
                      Wenn nicht
                      iob diag
                      Zeigen
                        Geklickt?
                        Wo?
                        freedesktop
                        wendy2702W Offline
                        wendy2702W Offline
                        #113
                        @homoran sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                        Geklickt?
                        Wo?
                        freedesktop
                        Deshalb war ich verwundert ob eventuell iob in einer Virtualisierung unter Win läuft
                        Thomas BraunT A 2 Antworten Letzte Antwort
                          Geklickt?
                          Wo?
                          freedesktop
                          #114
                          freedesktop ist mit dem dbus-Dienst verbandelt. Da läuft kein Desktop notwendigerweise.
                            @airframe75 und?
                            Geht jetzt?
                            Wenn nicht
                            iob diag
                            Zeigen
                            Airframe75
                            #115
                            @wendy2702
                            ich habe jetzt so häufig iob diag eingegeben. Jetzt möchte ich es auch zeigen.
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                               Static hostname: iobroker
                                     Icon name: computer
                              Operating System: Debian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 6.1.21-v8+
                                  Architecture: arm64
                            Model           : Raspberry Pi 4 Model B Rev 1.5
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : arm64
                            Systemuptime and Load:
                             22:17:40 up 46 min,  1 user,  load average: 0.42, 1.30, 1.01
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            *** Time and Time Zones ***
                                           Local time: Sun 2024-02-25 22:17:40 CET
                                       Universal time: Sun 2024-02-25 21:17:40 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            iobroker
                            /home/iobroker
                            iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            3.8G        1.6G        889M        1.0M        1.3G        2.1G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.6G        989M
                                     3794 M total memory
                                     1628 M used memory
                                     1621 M active memory
                                     1020 M inactive memory
                                      889 M free memory
                                       77 M buffer memory
                                     1198 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FAILED SERVICES ***
                              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                            * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                            1 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G  6.4G   22G  23% /
                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                            tmpfs          tmpfs     759M  1.2M  758M   1% /run
                            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                            [Sun Feb 25 21:31:11 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FB:C3:CA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8f761cd6-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Sun Feb 25 21:31:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sun Feb 25 21:31:12 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Sun Feb 25 21:31:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            TARGET  SOURCE         FSTYPE OPTIONS
                            /       /dev/mmcblk0p2 ext4   rw,noatime
                            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            3.0G    /var/
                            2.4G    /var/log
                            801M    /var/log/journal/54548f5b193440069d487fa9f59dd13a
                            355M    /var/cache
                            Archived and active journals take up 800.4M in the file system.
                            /opt/iobroker/backups:
                            239M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            345M    /opt/iobroker/iobroker-data/
                            237M    /opt/iobroker/iobroker-data/files
                            75M     /opt/iobroker/iobroker-data/backup-objects
                            52M     /opt/iobroker/iobroker-data/files/javascript.admin
                            43M     /opt/iobroker/iobroker-data/files/iot.admin
                            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                            26M     /opt/iobroker/iobroker-data/objects.jsonl
                            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                            8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                            USB-Devices by-id:
                            /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v18.19.1
                            /usr/bin/node           v18.19.1
                            /usr/bin/npm            10.2.4
                            /usr/bin/npx            10.2.4
                            /usr/bin/corepack       0.22.0
                            nodejs:
                              Installed: 18.19.1-1nodesource1
                              Candidate: 18.19.1-1nodesource1
                              Version table:
                             *** 18.19.1-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                 18.19.0-1nodesource1 1001
                                 18.18.2-1nodesource1 1001
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  5.0.12
                            admin:          6.12.0
                            javascript:     7.1.4
                            Adapters from github:   1
                            Adapter State
                            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                            + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled
                              system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 - disabled
                            + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                            + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                            + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
                            + system.adapter.fronius-wattpilot.1      : fronius-wattpilot     : iobroker                                 -  enabled
                            + system.adapter.fronius-wattpilot.2      : fronius-wattpilot     : iobroker                                 -  enabled
                            + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                            + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
                              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                              system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                            + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                            + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
                            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled
                            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                            + system.adapter.tibberlink.1             : tibberlink            : iobroker                                 -  enabled
                              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                              system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): stable
                            Installed ioBroker-Instances
                            Used repository: stable
                            Adapter    "admin"        : 6.13.16  , installed 6.12.0 [Updatable]
                            Adapter    "alexa2"       : 3.26.4   , installed 3.26.1 [Updatable]
                            Adapter    "backitup"     : 2.10.11  , installed 2.8.7  [Updatable]
                            Adapter    "bydhvs"       : 1.5.0    , installed 1.4.0  [Updatable]
                            Adapter    "device-reminder": 3.1.2  , installed 3.0.0  [Updatable]
                            Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                            Adapter    "fritzdect"    : 2.5.9    , installed 2.3.1  [Updatable]
                            Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                            Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                            Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.2  [Updatable]
                            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                            Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
                            Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
                            Adapter    "iot"          : 2.0.11   , installed 2.0.11
                            Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
                            Controller "js-controller": 5.0.19   , installed 5.0.12 [Updatable]
                            Adapter    "meross"       : 1.17.0   , installed 1.15.1 [Updatable]
                            Adapter    "pvforecast"   : 2.9.1    , installed 2.9.0  [Updatable]
                            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                            Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                            Adapter    "synology"     : 3.0.1    , installed 3.0.1
                            Adapter    "tado"         : 0.5.3    , installed 0.4.12 [Updatable]
                            Adapter    "telegram"     : 3.0.1    , installed 2.0.1  [Updatable]
                            Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                            Adapter    "text2command" : 3.0.3    , installed 3.0.2  [Updatable]
                            Adapter    "tibberlink"   : 2.2.1    , installed 1.5.0  [Updatable]
                            Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
                            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                            Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
                            Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
                            Adapter    "yr"           : 5.3.0    , installed 5.3.0
                            Adapter    "zigbee"       : 1.10.1   , installed 1.8.24 [Updatable]
                            Objects and States
                            Objects:        17012
                            States:         14331
                            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       34749      12221/io.shelly.0
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          34355      11265/sshd: /usr/sb
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       37604      12069/iobroker.js-c
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       36647      12069/iobroker.js-c
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       37936      12305/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       35606      12094/io.admin.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          34357      11265/sshd: /usr/sb
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14584      383/avahi-daemon: r
                            udp        0      0 0.0.0.0:50776           0.0.0.0:*                           108        14586      383/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13120      512/dhcpcd
                            udp6       0      0 :::55930                :::*                                108        14587      383/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        14585      383/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          14783      512/dhcpcd
                            2024-02-25 22:17:53.972  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-02-25 22:17:58.241  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                            2024-02-25 22:17:58.241  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                            2024-02-25 22:17:58.247  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-02-25 22:18:08.248  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                            2024-02-25 22:18:08.249  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                            2024-02-25 22:18:08.254  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-02-25 22:18:09.269  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-02-25 22:18:18.254  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                            2024-02-25 22:18:18.255  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                            2024-02-25 22:18:18.259  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-02-25 22:18:24.574  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-02-25 22:18:24.806  - info: shelly.0 (12221) [MQTT] Client Close: 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1) (false)
                            2024-02-25 22:18:26.995  - info: shelly.0 (12221) [MQTT] Device with client id "shellyplus1pm-64b7080975bc" connected!
                            2024-02-25 22:18:28.260  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                            2024-02-25 22:18:28.260  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                            2024-02-25 22:18:28.276  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-02-25 22:18:29.004  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-02-25 22:18:38.277  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                            2024-02-25 22:18:38.277  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                            2024-02-25 22:18:38.281  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-02-25 22:18:44.274  - warn: shelly.0 (12221) [authEnabled] 192.168.178.54 (shellyplus1pm / shellyplus1pm-64b7080975bc / shellyplus1pm#64b7080975bc#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-02-25 22:18:48.282  - info: influxdb.0 (12147) Connecting http://localhost:8086/ ...
                            2024-02-25 22:18:48.283  - info: influxdb.0 (12147) Influx DB Version used: 2.x
                            2024-02-25 22:18:48.296  - error: influxdb.0 (12147) Error: connect ECONNREFUSED 127.0.0.1:8086
                            Hier die summery
                            v.2023-10-10
                                  Icon name: computer
                               Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               arm64
                            Timezone:               Europe/Berlin (CET, +0100)
                            User-ID:                1000
                            X-Server:               false
                            Pending OS-Updates:     0
                            Pending iob updates:    21
                            Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                                                 /usr/bin/npm            10.2.4
                                                 /usr/bin/npx            10.2.4
                            Recommended versions are nodejs 18.19.1 and npm 10.2.4
                            MEMORY:
                            Mem:            3.8G        1.7G        791M        1.0M        1.3G        2.1G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.7G        891M
                            Active iob-Instances:   27
                            ioBroker Core:          js-controller           5.0.12
                                                 admin                   6.12.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 17012
                            States: 14331
                            Size of iob-Database:
                            7.9M /opt/iobroker/iobroker-data/states.jsonl
                              Geklickt?
                              Wo?
                              freedesktop
                              Airframe75
                              #116
                              @wendy2702 @Thomas-Braun
                              Ich mache alles mit der Powershell
                              Thomas BraunT wendy2702W A 3 Antworten Letzte Antwort
                              • A Airframe75
                                #117
                                @airframe75
                                influxdb klemmt.
                                Und halt den ioBroker jetzt auf Stand.
                                iob update
                                iob upgrade
                                iob stop
                                iob upgrade self
                                iob start
                                • A Airframe75
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  #118
                                  @airframe75 kommst du denn jetzt mit Browser auf den admin ?
                                  • A Airframe75
                                    Airframe75
                                    schrieb am zuletzt editiert von Airframe75
                                    #119
                                    @airframe75 @wendy2702 @Thomas-Braun @Marc-Berg @Homoran @Codierknecht @Meister-Mopper @Wildbill @MartinP
                                    ich möchte mich rechtherzlich bei der Lösung meines Problems bedanken. Ohne euch hätte ich das nicht hinbekommen. Dieser Thread kann jetzt als gelöst betrachtet werden.
                                    Nochmals danke
                                    Marc aka Airframe75
                                    • A Airframe75
                                      Nochmals danke
                                      Marc aka Airframe75
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      #120
                                      @airframe75 editiere bitte deinen ersten Post und setzte ein
                                      [Gelöst]
                                      Vor die Überschrift
