  4. Hosts update 5.0.19 Problem
58 Beiträge 6 Kommentatoren 6.0k Aufrufe 5 Beobachtet
    @krisiun
    Dann solltest du das tun.
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    Ich verstehe aber trotzdem nicht warum das Backup nicht klappt.
    Habe alles so eingestellt wie auf meiner RP installation wo das Backup tatenlos funktioniert.
    • KrisiunK Krisiun
      Wenn ich versuche einen Backup zu machen kommt das
      Started iobroker ...
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups"
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups"
      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups
      mount: bad usage
      Try 'mount --help' for more information.
      [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups
      mount: bad usage
      [DEBUG] [iobroker] - host.Marek2 5739 states saved
      [DEBUG] [iobroker] - host.Marek2 6619 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_02_20-20_38_58_backupiobroker.tar.gz
      [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
      [DEBUG] [iobroker] - done
      [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - found Script: Finde_Kato
      [DEBUG] [javascripts] - found Script: Saugereinstellungen
      [DEBUG] [javascripts] - found Script: Saugersteuerung_mit_Alexa
      [DEBUG] [javascripts] - found Script: Waschmaschiene
      [DEBUG] [javascripts] - found Script: Staubsauger
      [DEBUG] [javascripts] - found Script: VU+Uno_4K_SE
      [DEBUG] [javascripts] - found Script: Fenseher
      [DEBUG] [javascripts] - found Script: TV_Box
      [DEBUG] [javascripts] - found Script: Lampe
      [DEBUG] [javascripts] - found Script: Skript_1_Saugersteuerung_mit_Alexa
      [DEBUG] [javascripts] - found Script: Skript_2_Saugereinstellungen
      [DEBUG] [javascripts] - found Script: Waschmaschine
      [DEBUG] [javascripts] - found Script: Fensterkontakt_Balkon
      [DEBUG] [javascripts] - found Script: Fensterkontakt_Schlafzimmer
      [DEBUG] [javascripts] - found Script: Fensterkontakt_Badezimmer
      [DEBUG] [javascripts] - found Script: Fensterkontakt_Kleineszimmer
      [DEBUG] [javascripts] - found Script: Fensterstatus1
      [DEBUG] [javascripts] - found Script: Abfrage_Fensterstatus
      [DEBUG] [javascripts] - found Script: Fenster_Alias
      [DEBUG] [javascripts] - found Script: Fensterscript_für_faule_leute_die_nicht_lernen_wollen
      [DEBUG] [javascripts] - found Script: Festnetz
      [DEBUG] [javascripts] - found Script: Fensterkontakt_Küche
      [DEBUG] [javascripts] - found Script: Fernseher
      [DEBUG] [javascripts] - found Script: Saugroboter
      [DEBUG] [javascripts] - found Script: Waschmaschine_Alexa
      [DEBUG] [javascripts] - found Script: TV_BOX_NEU_
      [DEBUG] [javascripts] - found Script: VU+Fernseher
      [DEBUG] [javascripts] - found Script: VU+Test_Neu
      [DEBUG] [javascripts] - found Script: Abwesenheit_Marek
      [DEBUG] [javascripts] - found Script: Abwesenheit_Johanna
      [DEBUG] [javascripts] - found Script: Adapter_Updates_2
      [DEBUG] [javascripts] - found Script: Geofency
      [DEBUG] [javascripts] - found Script: Geofency_Marek
      [DEBUG] [javascripts] - found Script: Geofency_Johanna
      [DEBUG] [javascripts] - found Script: Fenster_Schlafzimmer-Telegram
      [DEBUG] [javascripts] - found Script: Fenster_Küche-Telegram
      [DEBUG] [javascripts] - found Script: Fenster_Kleineszimmer-Telegram
      [DEBUG] [javascripts] - found Script: Fenster_Bad-Telegram
      [DEBUG] [javascripts] - found Script: Fenster_Baklon-Telegram
      [DEBUG] [javascripts] - found Script: FernseherNeu
      [DEBUG] [javascripts] - found Script: arminTest
      [DEBUG] [javascripts] - found Script: Spritpreis
      [DEBUG] [javascripts] - found Script: AlleTankstellenPreiseDiesel
      [DEBUG] [javascripts] - found Script: AlleTankstellenPreiseBenzin
      [DEBUG] [javascripts] - found Script: Benzin
      [DEBUG] [javascripts] - found Script: Diesel
      [DEBUG] [javascripts] - found Script: Briefkasten
      [DEBUG] [javascripts] - found Script: Festnetztelefon
      [DEBUG] [javascripts] - found Script: Johanna_Abwesenheit
      [DEBUG] [javascripts] - found Script: Mareks_Abwesenheit
      [DEBUG] [javascripts] - found Script: Stumm_Schaltung
      [DEBUG] [javascripts] - found Script: TV_Stummschallten
      [DEBUG] [javascripts] - found Script: Tel_TV_Stumm
      [DEBUG] [javascripts] - found Script: Batterie_Status
      [DEBUG] [javascripts] - found Script: Batteriestatus_Abfrage
      [DEBUG] [javascripts] - found Script: Schlafzimmertemperatur
      [DEBUG] [javascripts] - found Script: Benzinpreis
      [DEBUG] [javascripts] - found Script: Dieselpreis
      [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2024_02_20-20_39_06_backupiobroker.tar.gz
      [DEBUG] [javascripts] - done
      [DEBUG] [cifs] - used copy path: /Synology 215j-6TB/IOBroker-Backup
      [DEBUG] [cifs] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      @krisiun sagte in Hosts update 5.0.19 Problem:
      Leerzeichen in Verzeichnisnamen sind auch 'verboten'. Führen nämlich zu dem Verhalten da bei dir.
      KrisiunK HomoranH 2 Antworten Letzte Antwort
        KrisiunK Offline
        KrisiunK Offline
        Krisiun
        Ich habe das leerzeichen weggenommen aber leider das gleiche Problem
          HomoranH Offline
          HomoranH Offline
          @thomas-braun sagte in Hosts update 5.0.19 Problem:
          ich fürchte das ist kein Dateiname, sonder der falsch angegebene Share
          KrisiunK 1 Antwort Letzte Antwort
          • KrisiunK Krisiun
            @krisiun
            Und du hampelst da weiter als root herum? Dann bin ich nämlich eh raus.
            Lies dir an, wie man user anlegt und mit denen agiert.
              KrisiunK Offline
              KrisiunK Offline
              Krisiun
              Ich habe da alles so angegeben wie auch bei meiner funktionierende Backup aktion
                @krisiun
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                Das haben wir doch bei meinem letzten Problem schon behoben. Keine Ahnung warum sich da was geändert hat.
                Wie mache ich das schnell wieder in Ordnung? Bitte
                • KrisiunK Krisiun
                  Was?
                    Was?
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    Wie man schnell der root los werden kann
                    • KrisiunK Krisiun
                      @krisiun
                      Ich werde dir jetzt nicht das Wiki vorlesen...
                      Link haste, setzt dich hin und lies.
                      KrisiunK 2 Antworten Letzte Antwort
                        @krisiun
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        OK. Hast du recht.
                        Viele Dank
                          @krisiun
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          @krisiun
                          Hi ich bin jetzt den root los aber backup geht trotzdem nicht.
                          Immer der gleiche Fehler.
                          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.2/homes/iobroker-ubuntu-backup /opt/iobroker/backups
                          mount error: cifs filesystem not supported by the system
                          mount error(19): No such device
                          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                          [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.2/homes/iobroker-ubuntu-backup /opt/iobroker/backups
                          Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                          • KrisiunK Krisiun
                            @krisiun
                            @krisiun
                            Du hast da wohl was falsch eingestellt. Zeig mal die Einstellungen aus dem Backitup-Adapter.
                            • KrisiunK Krisiun
                              @krisiun
                              GlasfaserG Offline
                              GlasfaserG Offline
                              OK .. dann
                              zeige doch mal dann wie ganz oben schon gefragt
                              iob diag
                              • KrisiunK Krisiun
                                mount: bad usage
                                mount: bad usage
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Erst das Synology :
                                und jetzt das auf Laufwerk ... :
                                Was machst du ... !?
                                so kann man dir nicht helfen , wenn du etwas änders ohne etwas dazu zu schreiben
                                • GlasfaserG Glasfaser
                                  Erst das Synology :
                                  KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  @glasfaser
                                  Dann sag mir bitte was ich falsch mache?
                                  • KrisiunK Krisiun
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    ? das habe ich doch oben alles dazu geschrieben !
                                      @krisiun
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      • KrisiunK Krisiun
                                        @krisiun
                                        Die zum NAS natürlich.
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          @glasfaser
                                          Ja das verstehe ich auch nicht. Ich habe den Pfad doch geändert
