  4. Hosts update 5.0.19 Problem
58 Beiträge 6 Kommentatoren 6.0k Aufrufe 5 Beobachtet
    @krisiun sagte in Hosts update 5.0.19 Problem:
    Wenn ich wieder probleme bekommen sollte dann mache ich das mal.
    Mach es JETZT und verwende ein Linux so wie es vorgesehen ist: Mit einem user und NICHT per root.
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    Wenn ich versuche einen Backup zu machen kommt das
    Started iobroker ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups
    mount: bad usage
    Try 'mount --help' for more information.
    [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups
    mount: bad usage
    [DEBUG] [iobroker] - host.Marek2 5739 states saved
    [DEBUG] [iobroker] - host.Marek2 6619 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_02_20-20_38_58_backupiobroker.tar.gz
    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
    [DEBUG] [iobroker] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Finde_Kato
    [DEBUG] [javascripts] - found Script: Saugereinstellungen
    [DEBUG] [javascripts] - found Script: Saugersteuerung_mit_Alexa
    [DEBUG] [javascripts] - found Script: Waschmaschiene
    [DEBUG] [javascripts] - found Script: Staubsauger
    [DEBUG] [javascripts] - found Script: VU+Uno_4K_SE
    [DEBUG] [javascripts] - found Script: Fenseher
    [DEBUG] [javascripts] - found Script: TV_Box
    [DEBUG] [javascripts] - found Script: Lampe
    [DEBUG] [javascripts] - found Script: Skript_1_Saugersteuerung_mit_Alexa
    [DEBUG] [javascripts] - found Script: Skript_2_Saugereinstellungen
    [DEBUG] [javascripts] - found Script: Waschmaschine
    [DEBUG] [javascripts] - found Script: Fensterkontakt_Balkon
    [DEBUG] [javascripts] - found Script: Fensterkontakt_Schlafzimmer
    [DEBUG] [javascripts] - found Script: Fensterkontakt_Badezimmer
    [DEBUG] [javascripts] - found Script: Fensterkontakt_Kleineszimmer
    [DEBUG] [javascripts] - found Script: Fensterstatus1
    [DEBUG] [javascripts] - found Script: Abfrage_Fensterstatus
    [DEBUG] [javascripts] - found Script: Fenster_Alias
    [DEBUG] [javascripts] - found Script: Fensterscript_für_faule_leute_die_nicht_lernen_wollen
    [DEBUG] [javascripts] - found Script: Festnetz
    [DEBUG] [javascripts] - found Script: Fensterkontakt_Küche
    [DEBUG] [javascripts] - found Script: Fernseher
    [DEBUG] [javascripts] - found Script: Saugroboter
    [DEBUG] [javascripts] - found Script: Waschmaschine_Alexa
    [DEBUG] [javascripts] - found Script: TV_BOX_NEU_
    [DEBUG] [javascripts] - found Script: VU+Fernseher
    [DEBUG] [javascripts] - found Script: VU+Test_Neu
    [DEBUG] [javascripts] - found Script: Abwesenheit_Marek
    [DEBUG] [javascripts] - found Script: Abwesenheit_Johanna
    [DEBUG] [javascripts] - found Script: Adapter_Updates_2
    [DEBUG] [javascripts] - found Script: Geofency
    [DEBUG] [javascripts] - found Script: Geofency_Marek
    [DEBUG] [javascripts] - found Script: Geofency_Johanna
    [DEBUG] [javascripts] - found Script: Fenster_Schlafzimmer-Telegram
    [DEBUG] [javascripts] - found Script: Fenster_Küche-Telegram
    [DEBUG] [javascripts] - found Script: Fenster_Kleineszimmer-Telegram
    [DEBUG] [javascripts] - found Script: Fenster_Bad-Telegram
    [DEBUG] [javascripts] - found Script: Fenster_Baklon-Telegram
    [DEBUG] [javascripts] - found Script: FernseherNeu
    [DEBUG] [javascripts] - found Script: arminTest
    [DEBUG] [javascripts] - found Script: Spritpreis
    [DEBUG] [javascripts] - found Script: AlleTankstellenPreiseDiesel
    [DEBUG] [javascripts] - found Script: AlleTankstellenPreiseBenzin
    [DEBUG] [javascripts] - found Script: Benzin
    [DEBUG] [javascripts] - found Script: Diesel
    [DEBUG] [javascripts] - found Script: Briefkasten
    [DEBUG] [javascripts] - found Script: Festnetztelefon
    [DEBUG] [javascripts] - found Script: Johanna_Abwesenheit
    [DEBUG] [javascripts] - found Script: Mareks_Abwesenheit
    [DEBUG] [javascripts] - found Script: Stumm_Schaltung
    [DEBUG] [javascripts] - found Script: TV_Stummschallten
    [DEBUG] [javascripts] - found Script: Tel_TV_Stumm
    [DEBUG] [javascripts] - found Script: Batterie_Status
    [DEBUG] [javascripts] - found Script: Batteriestatus_Abfrage
    [DEBUG] [javascripts] - found Script: Schlafzimmertemperatur
    [DEBUG] [javascripts] - found Script: Benzinpreis
    [DEBUG] [javascripts] - found Script: Dieselpreis
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2024_02_20-20_39_06_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - used copy path: /Synology 215j-6TB/IOBroker-Backup
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
    • KrisiunK Krisiun
      @thomas-braun sagte in Hosts update 5.0.19 Problem:
      Und wie mache ich das bitte schön ?
      @krisiun
      Viel lesen:
      https://wiki.ubuntuusers.de/Startseite/
      https://wiki.ubuntuusers.de/Erste_Schritte/
      KrisiunK 1 Antwort Letzte Antwort
        @krisiun
        Viel lesen:
        KrisiunK Offline
        KrisiunK Offline
        Krisiun
        Stimmt, da ist echt viel zum Lesen :)
        • KrisiunK Krisiun
          @krisiun
          Dann solltest du das tun.
          KrisiunK 2 Antworten Letzte Antwort
            @krisiun
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            Mache ich auch. Nur das ist nicht in 10 min getan.
            Da braucht man Zeit.
            Vielen Dank für die Infos
            • KrisiunK Krisiun
              Das ist korrekt. Die Zeit für die Grundlagen/Erste Schritte muss man sich schon nehmen. Sonst rennst du immer wieder vor die Wand.
                @krisiun
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                Ich verstehe aber trotzdem nicht warum das Backup nicht klappt.
                Habe alles so eingestellt wie auf meiner RP installation wo das Backup tatenlos funktioniert.
                • KrisiunK Krisiun
                  mount: bad usage
                  mount: bad usage
                  Leerzeichen in Verzeichnisnamen sind auch 'verboten'. Führen nämlich zu dem Verhalten da bei dir.
                  KrisiunK HomoranH 2 Antworten Letzte Antwort
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    Ich habe das leerzeichen weggenommen aber leider das gleiche Problem
                      HomoranH Offline
                      HomoranH Offline
                      ich fürchte das ist kein Dateiname, sonder der falsch angegebene Share
                      • KrisiunK Krisiun
                        @krisiun
                        Und du hampelst da weiter als root herum? Dann bin ich nämlich eh raus.
                        Lies dir an, wie man user anlegt und mit denen agiert.
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          Ich habe da alles so angegeben wie auch bei meiner funktionierende Backup aktion
                            @krisiun
                            KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            Das haben wir doch bei meinem letzten Problem schon behoben. Keine Ahnung warum sich da was geändert hat.
                            Wie mache ich das schnell wieder in Ordnung? Bitte
                            • KrisiunK Krisiun
                              Was?
                                Was?
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                Wie man schnell der root los werden kann
                                • KrisiunK Krisiun
                                  @krisiun
                                  Ich werde dir jetzt nicht das Wiki vorlesen...
                                  Link haste, setzt dich hin und lies.
                                    @krisiun
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    OK. Hast du recht.
                                    Viele Dank
                                      @krisiun
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      @krisiun
                                      Hi ich bin jetzt den root los aber backup geht trotzdem nicht.
                                      Immer der gleiche Fehler.
                                      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.2/homes/iobroker-ubuntu-backup /opt/iobroker/backups
                                      mount error: cifs filesystem not supported by the system
                                      mount error(19): No such device
                                      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                      [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.2/homes/iobroker-ubuntu-backup /opt/iobroker/backups
                                      • KrisiunK Krisiun
                                        @krisiun
                                        @krisiun
                                        Du hast da wohl was falsch eingestellt. Zeig mal die Einstellungen aus dem Backitup-Adapter.
                                        • KrisiunK Krisiun
                                          @krisiun
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          OK .. dann
                                          zeige doch mal dann wie ganz oben schon gefragt
                                          iob diag
