Harmony Adapter versagt seinen Dienst !
Bei
Debian 5.10.140befürchte ich einen gewissen Update-Stau.
Wir werden sehen ...@codierknecht sagte in Harmony Adapter versagt seinen Dienst !:
Bei
Wir werden sehen ...das dürfte die Kernelversion sein
Den Befehl
groupsin dein Terminal hacken, vollständige Ein- wie Ausgaben hier wieder rein kopieren, in CodeTags eingebettet.
login as: dw dw@192.168.178.59's password: Linux iobroker 5.10.0-28-amd64 #1 SMP Debian 5.10.209-2 (2024-01-31) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Feb 18 13:09:56 2024 dw@iobroker:~$ iob diag [sudo] Passwort für dw: Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --o utput /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen. dw@iobroker:~$ groups dw cdrom floppy audio dip video plugdev netdev dw@iobroker:~$ iob groups iobroker [command] Commands: iobroker setup Setup ioBroker iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-con troller or a specified adapter instance or all instances of an adapter iobroker stop [<adapter>.<instance>|<adapter>] stops the js-cont roller or a specified adapter instance or all instances of an adapter iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-contr oller or a specified adapter instance or all instances of an adapter [aliases: r] iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance iobroker info Shows the host in fo iobroker logs [<adapter>] Monitor log iobroker add <adapter> [desiredNumber] Add instance of a dapter [aliases: a] iobroker install <adapter> Installs a specif ied adapter [aliases: i] iobroker rebuild [<module>] Rebuild all nativ e modules or path iobroker url <url> [<name>] Install adapter f rom specified url, e.g. GitHub iobroker del <adapter> Remove adapter an d all instances from this host [aliases: delete] iobroker del <adapter>.<instance> Remove adapter in stance [aliases: delete] iobroker update [<repositoryUrl>] Update repository and list adapters iobroker upgrade Upgrade managemen t iobroker upload [all|<adapter>] Upload management [aliases: u] iobroker object Object management [aliases: o] iobroker state State management [aliases: s] iobroker message <adapter>[.instance] <command> [<message>] Send message to a dapter instance/s iobroker list <type> [<filter>] List all entries, like objects iobroker chmod <mode> <file> Change file right s iobroker chown <user> <group> <file> Change file owner ship iobroker touch <file> Touch file iobroker rm <file> Remove file iobroker file File management iobroker user User commands iobroker group group management iobroker host <hostname> Set host to given hostname iobroker set <adapter>.<instance> Change settings o f adapter config iobroker license <license.file or license.text> Update license by given file iobroker cert Certificate manag ement iobroker clean <yes> Clears all object s and states iobroker backup Create backup iobroker restore <backup name or path> Restore a specifi ed backup iobroker validate <backup name or path> Validate a specif ied backup iobroker status [all|<adapter>.<instance>] Status of ioBroke r or adapter instance [aliases: isrun] iobroker repo [<name>] Show repo informa tion iobroker uuid Show uuid of the installation [aliases: id] iobroker unsetup Reset license, in stallation secret and language iobroker fix Execute the insta llation fixer script, this updates your ioBroker installation iobroker nodejs-update [<major-version>] Upgrade the Node. JS installation to the current LTS iobroker multihost Multihost managem ent iobroker compact compact group man agement iobroker plugin Plugin management iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase iobroker version [<adapter>] Show version of j s-controller or specified adapter [aliases: v] Options: --help Show help [boolean] dw@iobroker:~$ -
login as: dw dw@192.168.178.59's password: Linux iobroker 5.10.0-28-amd64 #1 SMP Debian 5.10.209-2 (2024-01-31) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Feb 18 13:09:56 2024 dw@iobroker:~$ iob diag [sudo] Passwort für dw: Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --o utput /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen. dw@iobroker:~$ groups dw cdrom floppy audio dip video plugdev netdev dw@iobroker:~$ iob groups iobroker [command] Commands: iobroker setup Setup ioBroker iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-con troller or a specified adapter instance or all instances of an adapter iobroker stop [<adapter>.<instance>|<adapter>] stops the js-cont roller or a specified adapter instance or all instances of an adapter iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-contr oller or a specified adapter instance or all instances of an adapter [aliases: r] iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance iobroker info Shows the host in fo iobroker logs [<adapter>] Monitor log iobroker add <adapter> [desiredNumber] Add instance of a dapter [aliases: a] iobroker install <adapter> Installs a specif ied adapter [aliases: i] iobroker rebuild [<module>] Rebuild all nativ e modules or path iobroker url <url> [<name>] Install adapter f rom specified url, e.g. GitHub iobroker del <adapter> Remove adapter an d all instances from this host [aliases: delete] iobroker del <adapter>.<instance> Remove adapter in stance [aliases: delete] iobroker update [<repositoryUrl>] Update repository and list adapters iobroker upgrade Upgrade managemen t iobroker upload [all|<adapter>] Upload management [aliases: u] iobroker object Object management [aliases: o] iobroker state State management [aliases: s] iobroker message <adapter>[.instance] <command> [<message>] Send message to a dapter instance/s iobroker list <type> [<filter>] List all entries, like objects iobroker chmod <mode> <file> Change file right s iobroker chown <user> <group> <file> Change file owner ship iobroker touch <file> Touch file iobroker rm <file> Remove file iobroker file File management iobroker user User commands iobroker group group management iobroker host <hostname> Set host to given hostname iobroker set <adapter>.<instance> Change settings o f adapter config iobroker license <license.file or license.text> Update license by given file iobroker cert Certificate manag ement iobroker clean <yes> Clears all object s and states iobroker backup Create backup iobroker restore <backup name or path> Restore a specifi ed backup iobroker validate <backup name or path> Validate a specif ied backup iobroker status [all|<adapter>.<instance>] Status of ioBroke r or adapter instance [aliases: isrun] iobroker repo [<name>] Show repo informa tion iobroker uuid Show uuid of the installation [aliases: id] iobroker unsetup Reset license, in stallation secret and language iobroker fix Execute the insta llation fixer script, this updates your ioBroker installation iobroker nodejs-update [<major-version>] Upgrade the Node. JS installation to the current LTS iobroker multihost Multihost managem ent iobroker compact compact group man agement iobroker plugin Plugin management iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase iobroker version [<adapter>] Show version of j s-controller or specified adapter [aliases: v] Options: --help Show help [boolean] dw@iobroker:~$@springreiter einfach nur
groupsohh, ist ha darüber! danke
dw@iobroker:~$ groups dw cdrom floppy audio dip video plugdev netdev dw@iobroker:~$ -
dw@iobroker:~$ groups dw cdrom floppy audio dip video plugdev netdev dw@iobroker:~$@springreiter
Dem User fehlt die Gruppesudo.Melde Dich ausnahmsweise als
rootanusermod -aG sudo dwDanach wieder ab- und als
dwanmelden. -
@springreiter
dwanmelden.@codierknecht sagte in Harmony Adapter versagt seinen Dienst !:
Dem User fehlt die Gruppe sudo.
und iobroker
@springreiter
dwanmelden.root@iobroker:/home/dw# root@iobroker:/home/dw# usermod -aG sudo dw bash: usermod: Kommando nicht gefunden. -
@springreiter
dwanmelden.@codierknecht muss ebend Essen
/usr/sbin/usermod -aG sudo dw /usr/sbin/usermod -aG iobroker dw -
/usr/sbin/usermod -aG sudo dw /usr/sbin/usermod -aG iobroker dw@codierknecht said in Harmony Adapter versagt seinen Dienst !:
das hat er genommen
das hat er genommen
@springreiter
OK. Dann melde Dich wieder als "dw" an.
iob diagsollte jetzt funktionieren.
Die Ausgabe postest Du dann hier. -
@springreiter
Die Ausgabe postest Du dann hier.@codierknecht ```
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: kvm Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 5.10.0-28-amd64 Architecture: x86-64 model name : Common KVM processor Docker : false Virtualization : kvm Kernel : x86_64 Userland : amd64 Systemuptime and Load: 13:53:23 up 43 min, 2 users, load average: 0.82, 0.39, 0.26 CPU threads: 4 *** Time and Time Zones *** Local time: Sun 2024-02-18 13:53:23 CET Universal time: Sun 2024-02-18 12:53:23 UTC RTC time: Sun 2024-02-18 12:53:24 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** dw /home/dw dw cdrom floppy sudo audio dip video plugdev netdev iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 6.8G 1.5G 4.4G 0.0K 897M 5.0G Swap: 974M 0B 974M Total: 7.8G 1.5G 5.4G 6779 M total memory 1504 M used memory 337 M active memory 1712 M inactive memory 4376 M free memory 180 M buffer memory 717 M swap cache 974 M total swap 0 M used swap 974 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.3G 0 3.3G 0% /dev tmpfs tmpfs 678M 540K 678M 1% /run /dev/sda1 ext4 39G 11G 26G 30% / tmpfs tmpfs 3.4G 0 3.4G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 678M 0 678M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Feb 18 13:09:46 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [Sun Feb 18 13:09:46 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 2.5G /var/ 2.0G /var/log 1.9G /var/log/journal/355caa6989dc454583274fa76a04282b 1.9G /var/log/journal 405M /var/cache Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 136.0M in the file system. /opt/iobroker/backups: 187M /opt/iobroker/backups/ 572K /opt/iobroker/backups/Testumgebung 376K /opt/iobroker/backups/common 288K /opt/iobroker/backups/Rollosteuerung 176K /opt/iobroker/backups/Anrufe /opt/iobroker/iobroker-data: 1010M /opt/iobroker/iobroker-data/ 711M /opt/iobroker/iobroker-data/files 207M /opt/iobroker/iobroker-data/backup-objects 150M /opt/iobroker/iobroker-data/files/vis-2 78M /opt/iobroker/iobroker-data/files/vis-2/static The five largest files in iobroker-data are: 41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 23M /opt/iobroker/iobroker-data/objects.jsonl 22M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.1 /usr/bin/node v18.19.1 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.1-1nodesource1 Candidate: 18.19.1-1nodesource1 Version table: *** 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages 500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: redis Core adapters versions js-controller: 5.0.17 admin: 6.13.16 javascript: 7.8.0 Adapters from github: 9 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alarm.0 : alarm : iobroker - enabled + system.adapter.alexa2.0 : alexa2 : iobroker - enabled system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.bosesoundtouch.0 : bosesoundtouch : iobroker - enabled system.adapter.cloud.0 : cloud : iobroker - enabled system.adapter.daswetter.0 : daswetter : iobroker - enabled system.adapter.device-reminder.0 : device-reminder : iobroker - enabled system.adapter.devices.0 : devices : iobroker - disabled system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.dwd.0 : dwd : iobroker - enabled + system.adapter.email.0 : email : iobroker - enabled system.adapter.ems-esp.0 : ems-esp : iobroker - enabled system.adapter.energiefluss.0 : energiefluss : iobroker - enabled system.adapter.flot.0 : flot : iobroker - disabled system.adapter.followthesun.0 : followthesun : iobroker - enabled system.adapter.fullybrowser.0 : fullybrowser : iobroker - enabled system.adapter.harmony.0 : harmony : iobroker - enabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.hm-rega.0 : hm-rega : iobroker - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0 system.adapter.hm-rpc.2 : hm-rpc : iobroker - disabled, port: 0 system.adapter.hyperion_ng.0 : hyperion_ng : iobroker - disabled system.adapter.ical.0 : ical : iobroker - enabled system.adapter.icons-material-png.0 : icons-material-png : iobroker - disabled system.adapter.icons-material-svg.0 : icons-material-svg : iobroker - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - disabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086 system.adapter.info.0 : info : iobroker - enabled system.adapter.iot.0 : iot : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.km200.0 : km200 : iobroker - disabled system.adapter.milight-smart-light.0 : milight-smart-light : iobroker - disabled system.adapter.mobile.0 : mobile : iobroker - disabled + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.nut.0 : nut : iobroker - enabled system.adapter.proxmox.0 : proxmox : iobroker - disabled, port: 8006 system.adapter.rickshaw.0 : rickshaw : iobroker - disabled system.adapter.rssfeed.0 : rssfeed : iobroker - disabled system.adapter.smartcontrol.0 : smartcontrol : iobroker - enabled system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - disabled system.adapter.statistics.0 : statistics : iobroker - enabled system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : iobroker - enabled system.adapter.time-switch.0 : time-switch : iobroker - enabled + system.adapter.tr-064.0 : tr-064 : iobroker - enabled system.adapter.trashschedule.0 : trashschedule : iobroker - enabled system.adapter.vis-2.0 : vis-2 : iobroker - disabled system.adapter.vis-bars.0 : vis-bars : iobroker - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - disabled system.adapter.vis-history.0 : vis-history : iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - disabled system.adapter.vis-lcars.0 : vis-lcars : iobroker - disabled system.adapter.vis-metro.0 : vis-metro : iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis-weather.0 : vis-weather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled system.adapter.vw-connect.0 : vw-connect : iobroker - disabled system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.web.1 : web : iobroker - disabled, port: 8083, bind: 0.0.0.0, run as: admin system.adapter.web.2 : web : iobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1884, bind: 0.0.0.0 system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 ioBroker-Repositories Stable (default): http://download.iobroker.net/sources-dist.json sources : conf/sources-dist.json online : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "alarm" : 3.6.0 , installed 3.6.0 Adapter "alexa2" : 3.26.4 , installed 3.26.4 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "bosesoundtouch": 0.10.3 , installed 0.10.3 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "coronavirus-statistics": 0.9.0, installed 0.9.0 Adapter "daswetter" : 3.1.13 , installed 3.1.13 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "email" : 1.2.2 , installed 1.2.2 Adapter "ems-esp" : 2.8.0 , installed 2.8.0 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.5.0 , installed 0.5.0 Adapter "fullybrowser" : 3.0.9 , installed 3.0.9 Adapter "harmony" : 1.3.0 , installed 1.3.0 Adapter "heatingcontrol": 2.12.3 , installed 2.12.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hm-rega" : 4.0.0 , installed 4.0.0 Adapter "hm-rpc" : 1.16.0 , installed 1.16.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "javascript" : 7.8.0 , installed 7.8.0 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "material" : 1.3.1 , installed 1.3.1 Adapter "milight-smart-light": 1.2.2, installed 1.2.2 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "proxmox" : 2.2.2 , installed 2.2.2 Adapter "radar2" : 2.1.0 , installed 2.1.0 Adapter "rickshaw" : 1.0.0 , installed 1.0.0 Adapter "rssfeed" : 2.6.1 , installed 2.6.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.1 , installed 3.0.1 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-2" : 2.9.11 , installed 2.9.11 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 1.3.0 , installed 1.3.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-lcars" : 1.1.1 , installed 1.1.1 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "vw-connect" : 0.0.67 , installed 0.2.2 Adapter "web" : 6.2.3 , installed 6.2.3 Adapter "ws" : 2.5.10 , installed 2.5.10 Adapter "zigbee" : 1.10.1 , installed 1.10.1 Objects and States Please stand by - This may take a while Objects: 17333 States: 12967 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://ftp.de.debian.org/debian bullseye InRelease Hit:3 http://ftp.de.debian.org/debian bullseye-updates InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 192.168.178.59:2001 0.0.0.0:* LISTEN 1001 102886 60347/io.hm-rpc.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13387 480/sshd: /usr/sbin tcp 0 0 192.168.178.59:2010 0.0.0.0:* LISTEN 1001 102920 60362/io.hm-rpc.1 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 104105 60407/io.sonoff.0 tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 102973 60392/io.mqtt.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 101345 60142/iobroker.js-c tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 108 12992 442/redis-server 12 tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 10634 1/init tcp6 0 0 :::8081 :::* LISTEN 1001 102423 60160/io.admin.0 tcp6 0 0 :::22 :::* LISTEN 0 13408 480/sshd: /usr/sbin tcp6 0 0 :::61991 :::* LISTEN 1001 106247 61395/io.harmony.0 tcp6 0 0 ::1:6379 :::* LISTEN 108 12993 442/redis-server 12 tcp6 0 0 :::111 :::* LISTEN 0 10639 1/init udp 0 0 192.168.178.59:5353 0.0.0.0:* 1001 104237 60567/io.tr-064.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12794 400/dhclient udp 0 0 0.0.0.0:111 0.0.0.0:* 0 11657 1/init udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 106248 61395/io.harmony.0 udp6 0 0 :::111 :::* 0 11662 1/init *** Log File - Last 25 Lines *** 2024-02-18 13:53:44.514 - error: javascript.0 (60217) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62) 2024-02-18 13:53:44.514 - error: javascript.0 (60217) at processImmediate (node:internal/timers:476:21) 2024-02-18 13:53:47.222 - info: host.iobroker instance scheduled system.adapter.daswetter.0 */15 * * * * 2024-02-18 13:53:47.226 - info: host.iobroker instance system.adapter.daswetter.0 started with pid 60733 2024-02-18 13:53:48.431 - info: daswetter.0 (60733) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:53:51.168 - info: host.iobroker instance system.adapter.device-reminder.0 started with pid 60763 2024-02-18 13:53:53.301 - warn: zigbee.0 (60592) DeviceAvailability:Failed to ping 0x00158d00053aceb8 tint-ColorTemperature 2024-02-18 13:53:54.004 - info: device-reminder.0 (60763) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:53:55.147 - info: host.iobroker instance scheduled system.adapter.dwd.0 */5 * * * * 2024-02-18 13:53:55.150 - info: host.iobroker instance system.adapter.dwd.0 started with pid 60785 2024-02-18 13:53:56.961 - info: dwd.0 (60785) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:53:57.581 - info: dwd.0 (60785) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-02-18 13:53:58.171 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-02-18 13:53:59.132 - info: host.iobroker instance system.adapter.fullybrowser.0 started with pid 60811 2024-02-18 13:53:59.493 - info: daswetter.0 (60733) still wrong data structure from server received! repaired... 2024-02-18 13:54:00.697 - info: fullybrowser.0 (60811) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:54:00.732 - warn: fullybrowser.0 (60811) Adapter instance settings: REST API timeout of undefined ms is not allowed, set to default of 10000ms 2024-02-18 13:54:00.734 - info: fullybrowser.0 (60811) 🗸 192.168.178.109 (192.168.178.109): Config successfully verified. 2024-02-18 13:54:01.601 - info: fullybrowser.0 (60811) 🚀 Start RESTApi request intervall 2024-02-18 13:54:02.061 - info: daswetter.0 (60733) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment 2024-02-18 13:54:02.569 - info: daswetter.0 (60733) cleaned everything up... 2024-02-18 13:54:02.638 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-02-18 13:54:03.128 - info: host.iobroker instance system.adapter.harmony.0 started with pid 61395 2024-02-18 13:54:04.165 - info: harmony.0 (61395) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:54:04.197 - info: harmony.0 (61395) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255 -
@codierknecht ```
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: kvm Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 5.10.0-28-amd64 Architecture: x86-64 model name : Common KVM processor Docker : false Virtualization : kvm Kernel : x86_64 Userland : amd64 Systemuptime and Load: 13:53:23 up 43 min, 2 users, load average: 0.82, 0.39, 0.26 CPU threads: 4 *** Time and Time Zones *** Local time: Sun 2024-02-18 13:53:23 CET Universal time: Sun 2024-02-18 12:53:23 UTC RTC time: Sun 2024-02-18 12:53:24 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** dw /home/dw dw cdrom floppy sudo audio dip video plugdev netdev iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 6.8G 1.5G 4.4G 0.0K 897M 5.0G Swap: 974M 0B 974M Total: 7.8G 1.5G 5.4G 6779 M total memory 1504 M used memory 337 M active memory 1712 M inactive memory 4376 M free memory 180 M buffer memory 717 M swap cache 974 M total swap 0 M used swap 974 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.3G 0 3.3G 0% /dev tmpfs tmpfs 678M 540K 678M 1% /run /dev/sda1 ext4 39G 11G 26G 30% / tmpfs tmpfs 3.4G 0 3.4G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 678M 0 678M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Feb 18 13:09:46 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [Sun Feb 18 13:09:46 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 2.5G /var/ 2.0G /var/log 1.9G /var/log/journal/355caa6989dc454583274fa76a04282b 1.9G /var/log/journal 405M /var/cache Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 136.0M in the file system. /opt/iobroker/backups: 187M /opt/iobroker/backups/ 572K /opt/iobroker/backups/Testumgebung 376K /opt/iobroker/backups/common 288K /opt/iobroker/backups/Rollosteuerung 176K /opt/iobroker/backups/Anrufe /opt/iobroker/iobroker-data: 1010M /opt/iobroker/iobroker-data/ 711M /opt/iobroker/iobroker-data/files 207M /opt/iobroker/iobroker-data/backup-objects 150M /opt/iobroker/iobroker-data/files/vis-2 78M /opt/iobroker/iobroker-data/files/vis-2/static The five largest files in iobroker-data are: 41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 23M /opt/iobroker/iobroker-data/objects.jsonl 22M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.1 /usr/bin/node v18.19.1 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.1-1nodesource1 Candidate: 18.19.1-1nodesource1 Version table: *** 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages 500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: redis Core adapters versions js-controller: 5.0.17 admin: 6.13.16 javascript: 7.8.0 Adapters from github: 9 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alarm.0 : alarm : iobroker - enabled + system.adapter.alexa2.0 : alexa2 : iobroker - enabled system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.bosesoundtouch.0 : bosesoundtouch : iobroker - enabled system.adapter.cloud.0 : cloud : iobroker - enabled system.adapter.daswetter.0 : daswetter : iobroker - enabled system.adapter.device-reminder.0 : device-reminder : iobroker - enabled system.adapter.devices.0 : devices : iobroker - disabled system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.dwd.0 : dwd : iobroker - enabled + system.adapter.email.0 : email : iobroker - enabled system.adapter.ems-esp.0 : ems-esp : iobroker - enabled system.adapter.energiefluss.0 : energiefluss : iobroker - enabled system.adapter.flot.0 : flot : iobroker - disabled system.adapter.followthesun.0 : followthesun : iobroker - enabled system.adapter.fullybrowser.0 : fullybrowser : iobroker - enabled system.adapter.harmony.0 : harmony : iobroker - enabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.hm-rega.0 : hm-rega : iobroker - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0 system.adapter.hm-rpc.2 : hm-rpc : iobroker - disabled, port: 0 system.adapter.hyperion_ng.0 : hyperion_ng : iobroker - disabled system.adapter.ical.0 : ical : iobroker - enabled system.adapter.icons-material-png.0 : icons-material-png : iobroker - disabled system.adapter.icons-material-svg.0 : icons-material-svg : iobroker - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - disabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086 system.adapter.info.0 : info : iobroker - enabled system.adapter.iot.0 : iot : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.km200.0 : km200 : iobroker - disabled system.adapter.milight-smart-light.0 : milight-smart-light : iobroker - disabled system.adapter.mobile.0 : mobile : iobroker - disabled + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.nut.0 : nut : iobroker - enabled system.adapter.proxmox.0 : proxmox : iobroker - disabled, port: 8006 system.adapter.rickshaw.0 : rickshaw : iobroker - disabled system.adapter.rssfeed.0 : rssfeed : iobroker - disabled system.adapter.smartcontrol.0 : smartcontrol : iobroker - enabled system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - disabled system.adapter.statistics.0 : statistics : iobroker - enabled system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : iobroker - enabled system.adapter.time-switch.0 : time-switch : iobroker - enabled + system.adapter.tr-064.0 : tr-064 : iobroker - enabled system.adapter.trashschedule.0 : trashschedule : iobroker - enabled system.adapter.vis-2.0 : vis-2 : iobroker - disabled system.adapter.vis-bars.0 : vis-bars : iobroker - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - disabled system.adapter.vis-history.0 : vis-history : iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - disabled system.adapter.vis-lcars.0 : vis-lcars : iobroker - disabled system.adapter.vis-metro.0 : vis-metro : iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis-weather.0 : vis-weather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled system.adapter.vw-connect.0 : vw-connect : iobroker - disabled system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.web.1 : web : iobroker - disabled, port: 8083, bind: 0.0.0.0, run as: admin system.adapter.web.2 : web : iobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1884, bind: 0.0.0.0 system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 ioBroker-Repositories Stable (default): http://download.iobroker.net/sources-dist.json sources : conf/sources-dist.json online : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "alarm" : 3.6.0 , installed 3.6.0 Adapter "alexa2" : 3.26.4 , installed 3.26.4 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "bosesoundtouch": 0.10.3 , installed 0.10.3 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "coronavirus-statistics": 0.9.0, installed 0.9.0 Adapter "daswetter" : 3.1.13 , installed 3.1.13 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "email" : 1.2.2 , installed 1.2.2 Adapter "ems-esp" : 2.8.0 , installed 2.8.0 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.5.0 , installed 0.5.0 Adapter "fullybrowser" : 3.0.9 , installed 3.0.9 Adapter "harmony" : 1.3.0 , installed 1.3.0 Adapter "heatingcontrol": 2.12.3 , installed 2.12.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hm-rega" : 4.0.0 , installed 4.0.0 Adapter "hm-rpc" : 1.16.0 , installed 1.16.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "javascript" : 7.8.0 , installed 7.8.0 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "material" : 1.3.1 , installed 1.3.1 Adapter "milight-smart-light": 1.2.2, installed 1.2.2 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "proxmox" : 2.2.2 , installed 2.2.2 Adapter "radar2" : 2.1.0 , installed 2.1.0 Adapter "rickshaw" : 1.0.0 , installed 1.0.0 Adapter "rssfeed" : 2.6.1 , installed 2.6.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.1 , installed 3.0.1 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-2" : 2.9.11 , installed 2.9.11 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 1.3.0 , installed 1.3.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-lcars" : 1.1.1 , installed 1.1.1 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "vw-connect" : 0.0.67 , installed 0.2.2 Adapter "web" : 6.2.3 , installed 6.2.3 Adapter "ws" : 2.5.10 , installed 2.5.10 Adapter "zigbee" : 1.10.1 , installed 1.10.1 Objects and States Please stand by - This may take a while Objects: 17333 States: 12967 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://ftp.de.debian.org/debian bullseye InRelease Hit:3 http://ftp.de.debian.org/debian bullseye-updates InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 192.168.178.59:2001 0.0.0.0:* LISTEN 1001 102886 60347/io.hm-rpc.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13387 480/sshd: /usr/sbin tcp 0 0 192.168.178.59:2010 0.0.0.0:* LISTEN 1001 102920 60362/io.hm-rpc.1 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 104105 60407/io.sonoff.0 tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 102973 60392/io.mqtt.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 101345 60142/iobroker.js-c tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 108 12992 442/redis-server 12 tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 10634 1/init tcp6 0 0 :::8081 :::* LISTEN 1001 102423 60160/io.admin.0 tcp6 0 0 :::22 :::* LISTEN 0 13408 480/sshd: /usr/sbin tcp6 0 0 :::61991 :::* LISTEN 1001 106247 61395/io.harmony.0 tcp6 0 0 ::1:6379 :::* LISTEN 108 12993 442/redis-server 12 tcp6 0 0 :::111 :::* LISTEN 0 10639 1/init udp 0 0 192.168.178.59:5353 0.0.0.0:* 1001 104237 60567/io.tr-064.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12794 400/dhclient udp 0 0 0.0.0.0:111 0.0.0.0:* 0 11657 1/init udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 106248 61395/io.harmony.0 udp6 0 0 :::111 :::* 0 11662 1/init *** Log File - Last 25 Lines *** 2024-02-18 13:53:44.514 - error: javascript.0 (60217) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62) 2024-02-18 13:53:44.514 - error: javascript.0 (60217) at processImmediate (node:internal/timers:476:21) 2024-02-18 13:53:47.222 - info: host.iobroker instance scheduled system.adapter.daswetter.0 */15 * * * * 2024-02-18 13:53:47.226 - info: host.iobroker instance system.adapter.daswetter.0 started with pid 60733 2024-02-18 13:53:48.431 - info: daswetter.0 (60733) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:53:51.168 - info: host.iobroker instance system.adapter.device-reminder.0 started with pid 60763 2024-02-18 13:53:53.301 - warn: zigbee.0 (60592) DeviceAvailability:Failed to ping 0x00158d00053aceb8 tint-ColorTemperature 2024-02-18 13:53:54.004 - info: device-reminder.0 (60763) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:53:55.147 - info: host.iobroker instance scheduled system.adapter.dwd.0 */5 * * * * 2024-02-18 13:53:55.150 - info: host.iobroker instance system.adapter.dwd.0 started with pid 60785 2024-02-18 13:53:56.961 - info: dwd.0 (60785) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:53:57.581 - info: dwd.0 (60785) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-02-18 13:53:58.171 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-02-18 13:53:59.132 - info: host.iobroker instance system.adapter.fullybrowser.0 started with pid 60811 2024-02-18 13:53:59.493 - info: daswetter.0 (60733) still wrong data structure from server received! repaired... 2024-02-18 13:54:00.697 - info: fullybrowser.0 (60811) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:54:00.732 - warn: fullybrowser.0 (60811) Adapter instance settings: REST API timeout of undefined ms is not allowed, set to default of 10000ms 2024-02-18 13:54:00.734 - info: fullybrowser.0 (60811) 🗸 192.168.178.109 (192.168.178.109): Config successfully verified. 2024-02-18 13:54:01.601 - info: fullybrowser.0 (60811) 🚀 Start RESTApi request intervall 2024-02-18 13:54:02.061 - info: daswetter.0 (60733) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment 2024-02-18 13:54:02.569 - info: daswetter.0 (60733) cleaned everything up... 2024-02-18 13:54:02.638 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-02-18 13:54:03.128 - info: host.iobroker instance system.adapter.harmony.0 started with pid 61395 2024-02-18 13:54:04.165 - info: harmony.0 (61395) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17 2024-02-18 13:54:04.197 - info: harmony.0 (61395) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255@springreiter
Ich bin jetzt auch kein Kind von Traurigkeit was Adapter aus dem "Beta-Repo" angeht, aber Du bist ja im Stable und dann:@springreiter sagte in Harmony Adapter versagt seinen Dienst !:
Ebenso kommt mir der Port 6379 in Deinem LOG (Harmony-Adapter) nicht ganz korrekt vor:
Da kenn ich mich aber nicht so gut aus, vll weiß da jemand weiter ;)
@springreiter
@djmarc75 said in Harmony Adapter versagt seinen Dienst !:
6379
Eigentlich läuft das System seit Jahren problemlos, der Harmony Adapter hat lediglich seit Donnerstag oder Freitag den Dienst versagt, nach dem einige Adapter (der Harmony nicht) ganz normal aktualisiert wurden. ( Mqtt, Zigbee u.a.) Das der eine oder andere Adapter mal über Github installiert wurde ist wohl historisch bedingt, dass System läuft ja schon einige Jahre.
@springreiter
@djmarc75 sagte in Harmony Adapter versagt seinen Dienst !:
wo siehst du das?
6379 ist redisdarüber die 61991 bei ipv6 ist harmony, aber warum?
@homoran sagte in Harmony Adapter versagt seinen Dienst !:
wo siehst du das?
2024-02-18 11:38:31.091 - debug: harmony.0 (4156085) States connected to redis: 127.0.0.1:6379
edit: aber wie geschrieben kenn ich mich mit Ports & Co nicht aus
wo siehst du das?
IPv6 ist schon komisch, benutze eigentlich nur ipv4
wo siehst du das?
Dein System verwendet richtigerweise beides.
Räum die Repos auf.
iob repo del sources iob repo del online -
Und setz den User noch in die Gruppe
admrein.
