  4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
1.0k Beiträge 49 Kommentatoren 501.7k Aufrufe 52 Beobachtet
  • B
    B
    Beowolf
    schrieb am zuletzt editiert von Beowolf
    #348
    Ich habe jetzt einen zweiten AP hier bei mir im Haus.
    In dem LOG Fenster erscheint nun ständig dieses hier:
    22:28:58 moved AP from local to external 00007E1C3E8CB29D
    22:28:58 moved AP from external to local 00007E1C3E8CB29D
    22:28:54 moved AP from local to external 000001811F073B3A
    22:28:54 moved AP from external to local 000001811F073B3A
    22:28:51 moved AP from local to external 00007E1BDCACB294
    22:28:50 moved AP from external to local 00007E1BDCACB294
    22:28:43 moved AP from local to external 000001814A2E3B31
    22:28:43 moved AP from external to local 000001814A2E3B31
    22:28:42 moved AP from local to external 0000018141903B3F
    22:28:41 moved AP from external to local 0000018141903B3F
    22:28:39 moved AP from local to external 00007E1BD7F3B295
    22:28:39 moved AP from external to local 00007E1BD7F3B295
    22:28:39 moved AP from local to external 000001811F763B3C
    22:28:38 moved AP from external to local 000001811F763B3C
    22:28:37 moved AP from local to external 0000018171233B34
    22:28:37 moved AP from external to local 0000018171233B34
    22:28:34 moved AP from local to external 00007E1BDDE2B29F
    22:28:33 moved AP from external to local 00007E1BDDE2B29F
    22:28:30 moved AP from local to external 00007E1C34B6B29E
    22:28:29 moved AP from external to local 00007E1C34B6B29E
    22:28:27 moved AP from local to external 00007E1C46F8B291
    22:28:27 moved AP from external to local 00007E1C46F8B291
    22:28:24 moved AP from local to external 00007E211D11B296
    22:28:23 moved AP from external to local 00007E211D11B296
    22:28:19 moved AP from local to external 00007E1C3E8CB29D
    22:28:18 moved AP from external to local 00007E1C3E8CB29D
    22:28:14 moved AP from local to external 000001811F073B3A
    22:28:14 moved AP from external to local 000001811F073B3A
    22:28:06 moved AP from local to external 00007E1BDCACB294
    22:28:05 moved AP from external to local 00007E1BDCACB294
    22:28:03 moved AP from local to external 000001814A2E3B31
    22:28:03 moved AP from external to local 000001814A2E3B31
    22:27:59 moved AP from local to external 00007E1BD7F3B295
    22:27:58 moved AP from external to local 00007E1BD7F3B295
    22:27:58 moved AP from local to external 000001811F763B3C
    22:27:58 moved AP from external to local 000001811F763B3C
    22:27:57 moved AP from local to external 0000018171233B34
    22:27:57 moved AP from external to local 0000018171233B34
    22:27:49 moved AP from local to external 00007E1C34B6B29E
    22:27:49 moved AP from external to local 00007E1C34B6B29E
    22:27:47 moved AP from local to external 00007E1C46F8B291
    22:27:47 moved AP from external to local 00007E1C46F8B291
    Das sieht für mich so aus, als ob die TAGs ständig versuchen sich bei dem einen oder anderen AP anzumelden.
    Ich musste den zweiten AP ausschalten. Es wird nur versucht die TAG hin und her zu schieben. Kein TAG wird mehr aktualisiert.
    Da funktioniert etwas noch nicht.
    • B
      B
      bimmi
      schrieb am zuletzt editiert von bimmi
      #349
      Da sind die ap zu nah bei einander. Das hatte ich auch bei ein paar Tags. Roaming.
      Das kannst du nur unterbinden indem du beide ap auf unterschiedlichen zigbee Kanälen laufen lässt. Ich habe meine auf 11 und 20.
      Gruß Bimmi
      iobroker in einer Proxmox Umgebung auf einem ausrangierten DELL OptiPlex 3080 24GB i5 in der VM auf SSD. Nutze den slaeh zigbee Router mit Tür- und Temperatursensoren von Aqara, viele Tasmota Devices, Unifi AP, Sprinklecontrol, günstige E-INK Displays, Adguard und noch vieles mehr 😬
      • B bimmi
        B
        B
        Beowolf
        #350
        @bimmi
        Kann es sein, das die weissen TAGs nur Kanal 11 können?
        • B Beowolf
          @bimmi
          B
          B
          bimmi
          #351
          @beowolf nein. Habe ich bei mir unterschiedlich.
          Gruß Bimmi
          • B bimmi
            B
            B
            Beowolf
            #352
            @bimmi
            Geht jetzt. Die ganze Geschichte benötigt manchml sehr viel Zeit, damit sich alle untereinander finden und zufrieden sind.😊
            • B bimmi
              Es kommt demnächst was neues:
              Ebenso wird aktuell an folgenden Sachen gearbeitet:
              • Aktualisierte Webserver-/TCP-Sockets-Bibliothek mit einer stabileren Version.
              • Warteschlangenbildung von ausstehenden Bildern, sodass ein ausstehendes Bild nicht mehr mit einem neuen während der Übertragung verwechselt wird.
              • Es wird kein Datei-Handler mehr während des JPEG-Uploads offen gehalten, keine gleichzeitigen Schreibvorgänge mehr.
              • Zlib-Komprimierung zum Übertragen von Bildern zwischen AP und Tags hinzugefügt. Die bevorstehende Tag-Firmware wird das nutzen.
              B
              B
              Beowolf
              #353
              @bimmi
              Gibt es schon etwas zu bewundern?
              PS
              Warum ist im ersten Beitrag der Link durchgestrichen?
              • B Beowolf
                @bimmi
                PS
                B
                B
                bimmi
                #354
                @beowolf ups. Da wollte ich eigentlich den ursprünglichen tindy link durchstreichen und nicht den github link. Danke!
                Was sollte es denn zu bewundern geben?
                Gruß Bimmi
                • B bimmi
                  B
                  B
                  Beowolf
                  #355
                  @bimmi
                  Natürlich die angekündigten Neuigkeiten aus diesem Beitrag
                  https://forum.iobroker.net/topic/66380/eps-e-ink-display-ansteuerung-statusdisplay-für-2/345?_=1707207991400
                  Freu. 😳
                  • B Beowolf
                    @bimmi
                    Freu. 😳
                    B
                    B
                    bimmi
                    #356
                    @beowolf nein. Da gibt es nix neues 😂 aber ich berichte dann
                    Gruß Bimmi
                    • B
                      B
                      bimmi
                      #357
                      OpenEPaperLink Mini Access Point v4
                      What the heck can I do with this?
                      Basicly, this is a universal WiFi <-> IEEE 802.15.4 gateway, with a size smaller than a credit card.
                      You can use this set to setup your own E-Paper display system at home. The displays can display nearly anything. Just send a jpg file to the AP, and it can be displayed on one of the displays. The AP can generate all kinds of content itself too! Stuff like weather forecasts and the date can be shown on a tag, making for a nice dynamic little screen. It's also possible to use the AP with HomeAssistant thanks to an integration.
                      All details can be found here: OpenEPaperLink. With this Access Point and some displays, you have a fully working system.
                      New: the access point has a flasher port! Now, you can revive your tags after a firmware update goes wrong, or when you find compatible tags on eBay which are not preflashed yet.
                      --> jetzt neu, Access Point V4 inkl. integriertem Flasher!
                      https://www.tindie.com/products/electronics-by-nic/openepaperlink-mini-ap-v3-zigbee-wifi-gateway/
                      Edit: alle weg.
                      Gruß Bimmi
                      • B bimmi
                        Edit: alle weg.
                        D
                        D
                        diwoma
                        #358
                        @bimmi
                        Ich habe das Mail bekommen und um 12:33 Uhr noch welche bekommen.
                        Ich bin neugierig, ob das schon der V4 ist, wie ich jetzt gerade gelesen habe
                        -- diwoma
                        ioBroker in LX-Container in Proxmox
                        Zigbee-Coordinator: CC2652P2-TCP FW: 20230507
                        • D diwoma
                          @bimmi
                          B
                          B
                          bimmi
                          #359
                          @diwoma ja ist der v4. Er konnte nur den Titel nicht mehr ändern, da sonst alle verteilten links nicht mehr gültig sind.
                          Gruß Bimmi
                          • B bimmi
                            D
                            D
                            diwoma
                            #360
                            @bimmi sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                            Ja, so habe ich es auch verstanden :)
                            -- diwoma
                            • F
                              F
                              Freak
                              #361
                              Hallo Zusammen,
                              die Anleitung oben habe ich gesehe, vielen Dank dafür. Ist ganz schön aufwändig.
                              Es gibt ja inzwischen auch einen Adapter dafür. Darüber ist aber (noch) keine steuerung möglich, oder?
                              Wird der das Schicken der bilder auf die Displays über den adapter möglich sein? Bzw. ist das angedacht?
                              ? mcm1957M 2 Antworten Letzte Antwort
                              • F Freak
                                Hallo Zusammen,
                                #362
                                @freak
                                ich hatte den Adapter mal testweise installiert, aber ausser Auslesen von den Tags kann er zur Zeit noch nichts, ist noch im Alpha-Status.
                                Es gibt auf Github einige PR's, aber seit November ist da nichts mehr passiert, und die Software des AP's hat sich ja weiterentwickelt..
                                Vielleicht kann uns einer der Dev's @Dutchman und/oder @ticaki etwas dazu sagen?
                                • F Freak
                                  Hallo Zusammen,
                                  mcm1957M
                                  mcm1957M
                                  mcm1957
                                  #363
                                  @freak said in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                                  Wenn du diesen Adapter meinst:
                                  ioBroker.open-epaper-link
                                  muss ich leider drauf hinweeisen, dass dieser bisher nicht in die offiziellen Repositories aufgenommen wurde und nach der anfänglichen Entwicklung derzeit scheinbar NICHT mehr gewartet wird. Beim Check zur Aufnahme in das Latest Repository sind einige Kleinigkeiten aufgefallen. Allerdings wurden diese nicht (mehr) behoben und es erfolgte auch trotz mehrfachen Nachfragen keine Reaktion.
                                  Siehe https://github.com/ioBroker/ioBroker.repositories/pull/3003
                                  Derzeit kann zu diesem Adapeter nur gesagt werden - use completly at own risk...
                                  Leider.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                    @freak
                                    T
                                    T
                                    ticaki
                                    #364
                                    @ilovegym
                                    Ich gehöre nicht zu den devs - dutchman hat den an einem Sonntag als ich keine Zeit habe geschrieben und da er fast fertig war, hatte ich dann kein interesse mehr mich einzubringen. Hatte auch nix da um zu testen oder so :)
                                    Spenden
                                    • F
                                      F
                                      Freak
                                      #365
                                      Danke für die Rückmeldungen, schade eigentlich, dann werde ich mich wohl doch mal an der Blockly Anleitung versuchen.
                                      • T ticaki
                                        @ilovegym
                                        #366
                                        @ticaki
                                        ah, ok, sorry, dann hab ich das verwechselt, dachte ich haette dein Name da als Dev/Contrib oder bei einem PR gelesen..
                                        @bimmi hab gesehen, dass du als Contrib drin stehst, kennst du die HACS implementation von HA fuer open-e-paper?
                                        Da sind auch ein paar Beispiele dabei, ganz nett gemacht.. so aehnlich koennte man das auch fuer den iobroker umsetzen..
                                        Nutze ich allerdings auch nicht, hab den HA nur um ueber den Tellerrand zu schauen, installiert.
                                        ( und bin immer wieder froh, mich mit iobroker soweit auszukennen und liebe das Konzept..) :-)
                                          @ticaki
                                          B
                                          B
                                          bimmi
                                          #367
                                          @ilovegym nein, ich hab bisher dort nur das drumherum erstellt (wiki, grafik, texte). Um den code wollte sich dutchman kümmern. Aber da ich selbst seit Anfang Dezember nichts mehr von ihm gehört habe, denke ich das für die Entwicklung des Adapters momentan keine Zeit ist.
                                          Gruß Bimmi
                                          83.8k
