  4. Update js-Controller 3.x auf 5.x funktioniert nicht
67 Beiträge 7 Kommentatoren 10.8k Aufrufe 5 Beobachtet
  • F Frank-KNX
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.63-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     22:44:41 up  4:00,  3 users,  load average: 0.34, 0.22, 0.27
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-02-02 22:44:41 CET
               Universal time: Fri 2024-02-02 21:44:41 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        975M        5.9G         50M        1.1G        6.7G
    Swap:           99M          0B         99M
    Total:         8.0G        975M        6.0G
             7898 M total memory
              975 M used memory
              534 M active memory
             1296 M inactive memory
             5866 M free memory
              134 M buffer memory
              922 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4      117G  9.5G  103G   9% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.7M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
    [Fri Feb  2 18:43:58 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:D3:7A:A7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=def5eda3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Feb  2 18:43:59 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Feb  2 18:43:59 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Feb  2 18:44:01 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET                SOURCE         FSTYPE          OPTIONS
    /                     /dev/mmcblk0p2 ext4            rw,noatime
    |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    914M    /var/
    552M    /var/cache
    539M    /var/cache/apt
    480M    /var/cache/apt/archives
    248M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    101M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    148M    /opt/iobroker/iobroker-data/
    69M     /opt/iobroker/iobroker-data/files
    59M     /opt/iobroker/iobroker-data/backup-objects
    16M     /opt/iobroker/iobroker-data/files/javascript.admin
    13M     /opt/iobroker/iobroker-data/files/vis.0
    6.3M    /opt/iobroker/iobroker-data/objects.json.bak
    4.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.7e0b7583.chunk.js.map
    3.5M    /opt/iobroker/iobroker-data/files/vis.0/Grundriss_final.png
    3.4M    /opt/iobroker/iobroker-data/files/vis.0/Parkplatz.jpg
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.0.0
    /usr/bin/node           v18.0.0
    /usr/bin/npm            8.6.0
    /usr/bin/npx            8.6.0
    /usr/bin/corepack       0.10.0
    nodejs:
      Installed: 18.0.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
     *** 18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: file
    States  type: file
    Core adapters versions
    js-controller:  3.1.6
    admin:          4.1.11
    javascript:     4.8.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.discovery.0             : discovery             -  enabled
      system.adapter.ical.0                  : ical                  -  enabled
      system.adapter.icons-mfd-png.0         : icons-mfd-png         -  enabled
    + system.adapter.influxdb.0              : influxdb              -  enabled, port: 8086
    + system.adapter.info.0                  : info                  -  enabled
    + system.adapter.javascript.0            : javascript            -  enabled
    + system.adapter.knx.0                   : knx                   -  enabled, bind: 192.168.2.98
    + system.adapter.linux-control.0         : linux-control         -  enabled
    + system.adapter.meldungsliste.0         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.1         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.10        : meldungsliste         -  enabled
    + system.adapter.meldungsliste.11        : meldungsliste         -  enabled
    + system.adapter.meldungsliste.12        : meldungsliste         -  enabled
    + system.adapter.meldungsliste.13        : meldungsliste         -  enabled
    + system.adapter.meldungsliste.2         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.3         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.4         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.5         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.6         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.7         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.8         : meldungsliste         -  enabled
    + system.adapter.meldungsliste.9         : meldungsliste         -  enabled
    + system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 192.168.2.98
    + system.adapter.statistics.0            : statistics            -  enabled
      system.adapter.tr-064.0                : tr-064                - disabled
    + system.adapter.trashschedule.0         : trashschedule         -  enabled
      system.adapter.upnp.0                  : upnp                  - disabled
      system.adapter.vis-bars.0              : vis-bars              -  enabled
      system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
      system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
      system.adapter.vis.0                   : vis                   -  enabled
    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest): http://download.iobroker.net/sources-dist-latest.json
    Active repo: Stable (default)
    Installed ioBroker-Instances
    hash changed or no sources cached => force download of new sources
    Cannot get any information of "_repoInfo". Ignored.
    update done
    Adapter    "admin"         : 6.13.15  , installed 4.1.11 [Updateable]
    Adapter    "backitup"      : 2.9.8    , installed 2.9.8
    Adapter    "discovery"     : 4.2.0    , installed 4.2.0
    Adapter    "ical"          : 1.13.3   , installed 1.7.4 [Updateable]
    Adapter    "icons-mfd-png" : 1.2.1    , installed 1.2.1
    Adapter    "influxdb"      : 3.2.0    , installed 1.9.4 [Updateable]
    Adapter    "info"          : 2.0.0    , installed 1.7.10 [Updateable]
    Adapter    "javascript"    : 7.1.6    , installed 4.8.4 [Updateable]
    Controller "js-controller" : 5.0.17   , installed 3.1.6 [Updateable]
    Adapter    "knx"           : 2.0.24   , installed 1.0.39 [Updateable]
    Adapter    "linux-control" : 1.1.5    , installed 1.1.2 [Updateable]
    Adapter    "node-red"      : 5.1.0    , installed 2.0.1 [Updateable]
    Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
    Adapter    "socketio"      : 6.6.0    , installed 6.6.0
    Adapter    "statistics"    : 2.4.0    , installed 1.0.2 [Updateable]
    Adapter    "tr-064"        : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule" : 2.3.0    , installed 1.0.3 [Updateable]
    Adapter    "upnp"          : 1.0.21   , installed 1.0.17 [Updateable]
    Adapter    "vis"           : 1.5.4    , installed 1.3.4 [Updateable]
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-colorpicker": 2.0.3   , installed 2.0.3
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.4.0
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-timeandweather": 1.2.2   , installed 1.2.2
    Adapter    "web"           : 6.2.3    , installed 3.1.0 [Updateable]
    Objects and States
    Objects:        3504
    States:         2428
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Get:3 https://repos.influxdata.com/debian buster InRelease [7047 B]
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Err:3 https://repos.influxdata.com/debian buster InRelease
    @frank-knx
    Ist tot, muss durch Version 12 'Bookworm' erstetzt werden. Neuinstallation als 64Bit-Version, wenn der ioBroker später up-to-date ist und du ein Backup davon gezogen hast.
    sudo rm /etc/apt/sources.list.d/infl*
    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    rm influxdata-archive_compat.key
    iob stop
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Wenn die Kiste wieder erreichbar ist nochmal ein
    iob diag
    Diesmal aber bitte vollständig. Bis zur zweiten Kopiermarke.
    F 1 Antwort Letzte Antwort
    • F Frank-KNX
      Hier der Auszug aus dem "iob diag".
      ich hoffe, dass ich mit Copy und paste alles korekt gemacht habe..
      Hoffe, dass hilft für Diagnose.
      Frank-KNX
      Hier gehts weiter mit Teil, der später ergänzt wurde:
      E: Broken packages
      Pending Updates:
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       56298      4883/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       56297      4883/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19548      545/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16869      429/cupsd
      tcp        0      0 192.168.2.98:1880       0.0.0.0:*               LISTEN      1001       59193      5432/node-red
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16895      437/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       58127      4901/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       61575      5493/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        19360      437/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          19558      545/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16868      429/cupsd
      udp        0      0 192.168.2.98:54637      0.0.0.0:*                           1001       59054      4954/io.knx.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16932      468/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17768      509/cups-browsed
      udp        0      0 0.0.0.0:36572           0.0.0.0:*                           108        16048      411/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16046      411/avahi-daemon: r
      udp6       0      0 :::33610                :::*                                108        16049      411/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          17164      468/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        16047      411/avahi-daemon: r
      • F Frank-KNX
        E: Broken packages
        Pending Updates:
        Frank-KNX
        So, hier nun nochmal alles von den beiden Marken:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           99M          0B         99M
                 7898 M total memory
                  975 M used memory
                  534 M active memory
                 5866 M free memory
                  134 M buffer memory
                  922 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        914M    /var/
        552M    /var/cache
        539M    /var/cache/apt
        248M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            8.6.0
        /usr/bin/npx            8.6.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: file
        States  type: file
        admin:          4.1.11
        javascript:     4.8.4
        Adapter State
        + instance is alive
        update done
        Objects and States
        Objects:        3504
        States:         2428
        Fetched 7047 B in 9s (744 B/s)
        Reading package lists...
        E: Broken packages
        Pending Updates:
        2024-02-02 22:46:00.781  - info: knx.0 (4954) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
        2024-02-02 22:46:00.781  - info: knx.0 (4954) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
        2024-02-02 22:46:00.781  - info: knx.0 (4954) =====> STATE_TUNNELING_ACK
        2024-02-02 22:46:00.783  - info: knx.0 (4954) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 4e e5 00   ChID : 78 SeqCntIN : 229 SeqCntOUT : 25 queue length : 0
        2024-02-02 22:46:00.783  - info: knx.0 (4954) ( 4.b ) return to STATE_READY, processing : false
        2024-02-02 22:46:00.784  - info: knx.0 (4954) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
        2024-02-02 22:46:04.851  - info: knx.0 (4954) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 4e e6 00 29 00 bc c0 12 49 23 03 03 00 80 02 26   ChID: 78
        2024-02-02 22:46:04.852  - info: knx.0 (4954) WRITE : mappedName : Temperatur Wasser Teich    dest : 4/3/3  val: 5.5   (DPT9.001) Temperatur_Wasser_Teich
        2024-02-02 22:46:04.852  - info: knx.0 (4954) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
        2024-02-02 22:46:04.853  - info: knx.0 (4954) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
        2024-02-02 22:46:04.853  - info: knx.0 (4954) =====> STATE_TUNNELING_ACK
        2024-02-02 22:46:04.854  - info: knx.0 (4954) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 4e e6 00   ChID : 78 SeqCntIN : 230 SeqCntOUT : 25 queue length : 0
        2024-02-02 22:46:04.854  - info: knx.0 (4954) ( 4.b ) return to STATE_READY, processing : false
        2024-02-02 22:46:04.854  - info: knx.0 (4954) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
        2024-02-02 22:46:06.513  - info: meldungsliste.8 (5708) state 0_userdata.0.DSL_Status_Fritzbox updated: true (ack = false)
        2024-02-02 22:46:06.514  - info: meldungsliste.8 (5708) trigger:false
        2024-02-02 22:46:06.514  - info: meldungsliste.8 (5708) value:true
        2024-02-02 22:46:06.554  - info: knx.0 (4954) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 4e e7 00 29 00 bc c0 12 3c 28 04 05 00 80 42 fa 00 00   ChID: 78
        2024-02-02 22:46:06.555  - info: knx.0 (4954) WRITE : mappedName : Leistung    dest : 5/0/4  val: 125   (DPT14.056) Leistung
        2024-02-02 22:46:06.555  - info: knx.0 (4954) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
        2024-02-02 22:46:06.555  - info: knx.0 (4954) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
        2024-02-02 22:46:06.556  - info: knx.0 (4954) =====> STATE_TUNNELING_ACK
        2024-02-02 22:46:06.557  - info: knx.0 (4954) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 4e e7 00   ChID : 78 SeqCntIN : 231 SeqCntOUT : 25 queue length : 0
        2024-02-02 22:46:06.557  - info: knx.0 (4954) ( 4.b ) return to STATE_READY, processing : false
        2024-02-02 22:46:06.557  - info: knx.0 (4954) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
        • F Frank-KNX
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : armhf
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   7898 M total memory
                    975 M used memory
                    534 M active memory
                   5866 M free memory
                    134 M buffer memory
                    922 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          914M    /var/
          552M    /var/cache
          539M    /var/cache/apt
          248M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            8.6.0
          /usr/bin/npx            8.6.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: file
          States  type: file
          admin:          4.1.11
          javascript:     4.8.4
          Adapter State
          + instance is alive
          update done
          Objects and States
          Objects:        3504
          States:         2428
          E: Broken packages
          Pending Updates:
          Frank-KNX
          Und hier noch das nachfolgende Summary:
                                  v.2023-10-10
                   Icon name: computer
                Architecture: arm
          Kernel:                 armv7l
          Userland:               armhf
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          X-Server:               true
          Pending OS-Updates:
          Pending iob updates:    14
          Nodejs-Installation:    /usr/bin/nodejs         v18.0.0
                                  /usr/bin/npm            8.6.0
                                  /usr/bin/npx            8.6.0
          Recommended versions are nodejs  and npm
          MEMORY:
          Mem:           7.9G        1.2G        5.6G         50M        1.1G        6.5G
          Swap:           99M          0B         99M
          Total:         8.0G        1.2G        5.7G
          Active iob-Instances:   26
          ioBroker Core:          js-controller           3.1.6
                                  admin                   4.1.11
          Objects type: file
          States  type: file
          Objects:                3504
          States:                 2428
          Size of iob-Database:
          652K    /opt/iobroker/iobroker-data/states.json.bak
            @frank-knx
            iob stop
            sudo apt update
            sudo reboot
            iob diag
            Frank-KNX
            Jetzt was ich raus.
            Also verstanden, dass ich nach dem Update des iobrokers und den Adaptern.. und deren Sicherung danach auf ein moderneres Betriebssystem wechseln soll.
            Was wolltest du mir mit den Auszug sudo rm /etc.... mitteilen ?
            • F Frank-KNX
              Jetzt was ich raus.
              @frank-knx sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
              Das ist kein Auszug, das ist das was du in dein Terminal eingeben sollst.
              Am besten zeilenweise kopieren und einfügen.
                Frank-KNX
                Hallo Thomas, leider nach der ersten Zeile bereits Fehlermeldung als Antwort.
                pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/infl*
                rm: das Entfernen von '/etc/apt/sources.list.d/infl*' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                pi@raspberrypi:~ $
                • F Frank-KNX
                  pi@raspberrypi:~ $
                  @frank-knx
                  grep -r influx /etc/apt/
                    @frank-knx
                    Frank-KNX
                    Hier das Ergebnis dieser Eingabe:
                    pi@raspberrypi:~ $ grep -r influx /etc/apt/
                    Übereinstimmungen in Binärdatei /etc/apt/trusted.gpg
                    pi@raspberrypi:~ $
                    • F Frank-KNX
                      pi@raspberrypi:~ $
                      @frank-knx
                      Dann mach mal mit der zweiten Zeile weiter.
                        @frank-knx
                        Frank-KNX
                        Hallo Thomas, sorry für meine erneute Rückfrage
                        Meinst du deine Zeile mit "wget -q.....>"
                        Nur den Inhalt der Zeile 2? Was ist mit dem echo.... diese Zeilen separat eingeben oder die Zeile 2-4 gemeinsam kopieren und eingeben ?
                        • F Frank-KNX
                          @frank-knx
                          Zeilenweise 2 - 9 eingeben.
                            @frank-knx
                            Frank-KNX
                            Hallo Thomas, heute ist der Wurm drin.
                            mit dem Befehl sudo apt full-upgrade sind zunächst Unmengen Daten erfolgreich geholt werden, aber dann starteten nachfolgende Fehlermeldungen:
                            Holen:322 http://mirror.netcologne.de/raspbian/raspbian buster/main armhf python-flask all 1.0.2-3+deb10u1 [93,0 kB]
                            Holen:323 http://mirror.netcologne.de/raspbian/raspbian buster/main armhf python-pil armhf 5.4.1-2+deb10u4 [364 kB]
                            Holen:333 http://mirror.netcologne.de/raspbian/raspbian buster/main armhf python3-renderpm armhf 3.5.13-1+deb10u2 [64,2 kB]
                            Holen:283 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libreoffice-avmedia-backend-gstreamer armhf 1:6.1.5-3+rpi1+deb10u11 [19,5 kB]
                            Holen:284 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libreoffice-writer armhf 1:6.1.5-3+rpi1+deb10u11 [6.736 kB]
                            Fehl:263 http://debian.bio.lmu.de/raspbian/raspbian buster/main armhf openjdk-11-jdk-headless armhf 11.0.22+7-1~deb10u1
                              Verbindung fehlgeschlagen [IP: 2001:4ca0:4300::1:22 80]
                            Fehl:284 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libreoffice-writer armhf 1:6.1.5-3+rpi1+deb10u11
                              Verbindung mit ftp.gwdg.de:80 nicht möglich (134.76.12.6) - connect (113: Keine Route zum Zielrechner) Verbindung mit ftp.gwdg.de:80 konnte nicht aufgebaut werden (2001:638:60f:110::1:2), Zeitüberschreitung aufgetreten [IP: 2001:638:60f:110::1:2 80]
                            Fehl:285 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libreoffice-core armhf 1:6.1.5-3+rpi1+deb10u11
                              Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            Fehl:287 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libreoffice-nlpsolver all 0.9+LibO6.1.5-3+rpi1+deb10u11
                            Fehl:288 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libreoffice-wiki-publisher all 1.2.0+LibO6.1.5-3+rpi1+deb10u11
                            Fehl:299 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libva-wayland2 armhf 2.4.0-1
                            Fehl:278 http://debian.bio.lmu.de/raspbian/raspbian buster/main armhf libreoffice-report-builder all 1:6.1.5-3+rpi1+deb10u11
                              Verbindung mit debian.bio.lmu.de:80 nicht möglich (141.84.43.22) - connect (113: Keine Route zum Zielrechner) Verbindung mit debian.bio.lmu.de:80 konnte nicht aufgebaut werden (2001:4ca0:4300::1:22), Zeitüberschreitung aufgetreten [IP: 2001:4ca0:4300::1:22 80]
                            Fehl:289 http://debian.bio.lmu.de/raspbian/raspbian buster/main armhf libruby2.5 armhf 2.5.5-3+deb10u6
                              Verbindung mit debian.bio.lmu.de:http nicht möglich: [IP: 2001:4ca0:4300::1:22 80]
                            Fehl:306 http://debian.bio.lmu.de/raspbian/raspbian buster/main armhf vlc-l10n all 3.0.20-0+deb10u1
                            Fehl:334 http://debian.bio.lmu.de/raspbian/raspbian buster/main armhf python3-reportlab-accel armhf 3.5.13-1+deb10u2
                            Fehl:341 http://debian.bio.lmu.de/raspbian/raspbian buster/main armhf sudo armhf 1.8.27-1+deb10u5
                            Fehl:345 http://debian.bio.lmu.de/raspbian/raspbian buster/main armhf vlc-plugin-samba armhf 3.0.20-0+deb10u1
                            Fehl:300 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libvlccore9 armhf 3.0.20-0+deb10u1
                            Fehl:301 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf vlc-plugin-skins2 armhf 3.0.20-0+deb10u1
                            Fehl:302 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf vlc armhf 3.0.20-0+deb10u1
                            Fehl:303 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf vlc-plugin-qt armhf 3.0.20-0+deb10u1
                            Fehl:311 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libvlc-bin armhf 3.0.20-0+deb10u1
                            Fehl:315 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf node-tough-cookie all 2.3.4+dfsg-1+deb10u1
                            Fehl:321 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python-jinja2 all 2.10-2+deb10u1
                            Fehl:325 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python-requests all 2.21.0-1+deb10u1
                            Fehl:327 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python3-jinja2 all 2.10-2+deb10u1
                            Fehl:329 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python3-flask all 1.0.2-3+deb10u1
                            Fehl:331 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python3-pil.imagetk armhf 5.4.1-2+deb10u4
                            Fehl:332 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python3-pil armhf 5.4.1-2+deb10u4
                            Fehl:335 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python3-reportlab all 3.5.13-1+deb10u2
                            Fehl:336 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python3-urllib3 all 1.24.1-1+deb10u2
                            Fehl:337 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf python3-requests all 2.21.0-1+deb10u1
                            Fehl:344 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf vlc-plugin-notify armhf 3.0.20-0+deb10u1
                            Fehl:346 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf vlc-plugin-video-splitter armhf 3.0.20-0+deb10u1
                            Fehl:347 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf vlc-plugin-visualization armhf 3.0.20-0+deb10u1
                            Es wurden 572 MB in 3 min 36 s geholt (2.656 kB/s).
                            E: Fehlschlag beim Holen von http://debian.bio.lmu.de/raspbian/raspbian/pool/main/o/openjdk-11/openjdk-11-jdk-headless_11.0.22+7-1~deb10u1_armhf.deb Verbindung fehlgeschlagen [IP: 2001:4ca0:4300::1:22 80]
                            E: Fehlschlag beim Holen von http://debian.bio.lmu.de/raspbian/raspbian/pool/main/libr/libreoffice/libreoffice-report-builder_6.1.5-3+rpi1+deb10u11_all.deb Verbindung mit debian.bio.lmu.de:80 nicht möglich (141.84.43.22) - connect (113: Keine Route zum Zielrechner) Verbindung mit debian.bio.lmu.de:80 konnte nicht aufgebaut werden (2001:4ca0:4300::1:22), Zeitüberschreitung aufgetreten [IP: 2001:4ca0:4300::1:22 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/libr/libreoffice/libreoffice-writer_6.1.5-3+rpi1+deb10u11_armhf.deb Verbindung mit ftp.gwdg.de:80 nicht möglich (134.76.12.6) - connect (113: Keine Route zum Zielrechner) Verbindung mit ftp.gwdg.de:80 konnte nicht aufgebaut werden (2001:638:60f:110::1:2), Zeitüberschreitung aufgetreten [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/libr/libreoffice/libreoffice-core_6.1.5-3+rpi1+deb10u11_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/libr/libreoffice/libreoffice-nlpsolver_0.9+LibO6.1.5-3+rpi1+deb10u11_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/libr/libreoffice/libreoffice-wiki-publisher_1.2.0+LibO6.1.5-3+rpi1+deb10u11_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://debian.bio.lmu.de/raspbian/raspbian/pool/main/r/ruby2.5/libruby2.5_2.5.5-3+deb10u6_armhf.deb Verbindung mit debian.bio.lmu.de:http nicht möglich: [IP: 2001:4ca0:4300::1:22 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/libv/libva/libva-wayland2_2.4.0-1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/v/vlc/libvlccore9_3.0.20-0+deb10u1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/v/vlc/vlc-plugin-skins2_3.0.20-0+deb10u1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/v/vlc/vlc_3.0.20-0+deb10u1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/v/vlc/vlc-plugin-qt_3.0.20-0+deb10u1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://debian.bio.lmu.de/raspbian/raspbian/pool/main/v/vlc/vlc-l10n_3.0.20-0+deb10u1_all.deb Verbindung mit debian.bio.lmu.de:http nicht möglich: [IP: 2001:4ca0:4300::1:22 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/v/vlc/libvlc-bin_3.0.20-0+deb10u1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/n/node-tough-cookie/node-tough-cookie_2.3.4+dfsg-1+deb10u1_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/j/jinja2/python-jinja2_2.10-2+deb10u1_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/r/requests/python-requests_2.21.0-1+deb10u1_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/j/jinja2/python3-jinja2_2.10-2+deb10u1_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/f/flask/python3-flask_1.0.2-3+deb10u1_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/p/pillow/python3-pil.imagetk_5.4.1-2+deb10u4_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/p/pillow/python3-pil_5.4.1-2+deb10u4_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://debian.bio.lmu.de/raspbian/raspbian/pool/main/p/python-reportlab/python3-reportlab-accel_3.5.13-1+deb10u2_armhf.deb Verbindung mit debian.bio.lmu.de:http nicht möglich: [IP: 2001:4ca0:4300::1:22 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/p/python-reportlab/python3-reportlab_3.5.13-1+deb10u2_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/p/python-urllib3/python3-urllib3_1.24.1-1+deb10u2_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/r/requests/python3-requests_2.21.0-1+deb10u1_all.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://debian.bio.lmu.de/raspbian/raspbian/pool/main/s/sudo/sudo_1.8.27-1+deb10u5_armhf.deb Verbindung mit debian.bio.lmu.de:http nicht möglich: [IP: 2001:4ca0:4300::1:22 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/v/vlc/vlc-plugin-notify_3.0.20-0+deb10u1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://debian.bio.lmu.de/raspbian/raspbian/pool/main/v/vlc/vlc-plugin-samba_3.0.20-0+deb10u1_armhf.deb Verbindung mit debian.bio.lmu.de:http nicht möglich: [IP: 2001:4ca0:4300::1:22 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/v/vlc/vlc-plugin-video-splitter_3.0.20-0+deb10u1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Fehlschlag beim Holen von http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/v/vlc/vlc-plugin-visualization_3.0.20-0+deb10u1_armhf.deb Verbindung mit ftp.gwdg.de:http nicht möglich: [IP: 2001:638:60f:110::1:2 80]
                            E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                            pi@raspberrypi:~ $
                            • F Frank-KNX
                              pi@raspberrypi:~ $
                              Da ist bei dir im Netzwerk wohl IPv6 nicht/nicht richtig eingerichtet.
                                Frank-KNX
                                Sorry, hatte ich bisher nicht gemerkt oder gebraucht. Daher an der Fritzbox nichts besonderes eingerichtet.
                                Habe ich nun ein Problem, dass ich ein paar Daten von IPV6 Adressen nicht laden kann ?
                                W Thomas BraunT 2 Antworten Letzte Antwort
                                • F Frank-KNX
                                  W Online
                                  W Online
                                  Wildbill
                                  @frank-knx Siehe HIER
                                  Schau, dass Du in Deiner Fritzbox IPv6 vernünftig einstellst, Du wirst sonst immer mehr Probleme bekommen. Wie kann ich Dir leider nicht sagen. Ich habe keine Fritzbox und weiss auch nicht, bei welchem Provider Du bist.
                                  Gruss, Jürgen
                                  • F Frank-KNX
                                    Jetzt brauchst du es. Einfachster Fall: Nur aktivieren.
                                      Frank-KNX
                                      Hallo Thomas,
                                      ich hatte parallel schon gestartet und es ist alles (wie auf deinem Bild) aktiviert und unter "Online Monitor" ist auch der Hinweis, dass die IPV6 Verbindung mit Adresse vergeben ist.
                                      Fritzbox ist also in Ordnung.
                                      Kann es am PI liegen, dass dort IPV6 aktiviert sein muss ?
                                      Ich habe unter Einstellungen nichts gefunden.. ich habe aber den PI in Verdacht.
                                      Gibt es eine Testmöglichkeit ?
                                      • F Frank-KNX
                                        Hallo Thomas,
                                        ip a
                                        anschauen.
                                          ip a
                                          anschauen.
                                          Frank-KNX
                                          PI hängt derzeit am W-Lan: hier das Ergebnis:
                                          pi@raspberrypi:~ $ ip a
                                          1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                              link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                              inet 127.0.0.1/8 scope host lo
                                                 valid_lft forever preferred_lft forever
                                              inet6 ::1/128 scope host
                                          2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
                                              link/ether dc:a6:32:d3:7a:a7 brd ff:ff:ff:ff:ff:ff
                                          3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                              link/ether dc:a6:32:d3:7a:a8 brd ff:ff:ff:ff:ff:ff
                                              inet 192.168.2.98/24 brd 192.168.2.255 scope global noprefixroute wlan0
                                              inet6 2a02:6d40:2458:4101:933:caf3:d3fe:118c/64 scope global dynamic mngtmpaddr noprefixroute
                                                 valid_lft 7081sec preferred_lft 3481sec
                                              inet6 fe80::199d:25f7:b037:5cec/64 scope link
                                          pi@raspberrypi:~ $
