  4. KNX-Adapter - keine UDP-Verbindung - OpenKNX-Adapter i.O.
    6.0k
43 Beiträge 2 Kommentatoren 5.1k Aufrufe 2 Beobachtet
  • N Nubbbi
    @glasfaser Das habe ich gemacht.
    Müssen dann neben dem Mounting von /docker/iobroker zu /opt/fhem noch Ports zugewiesen werden?
    Ich habe 3671-3671-udp und 7234-8081-tcp eingestellt, aber der Container bricht beim Start bei Schritt 3 ab.
    GlasfaserG Offline
    GlasfaserG Offline
    @nubbbi sagte in KNX-Adapter - keine UDP-Verbindung - OpenKNX-Adapter i.O.:
    Das gleiche wie deine Einstellungen im alten Container , zu Ordner Mounts !
    • N Nubbbi
      GlasfaserG Offline
      GlasfaserG Offline
      zusätzlich ... kann man hiermit mehr sehen :
      Trage in der ENV ein
      DEBUG = true
      N 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        DEBUG = true
        N Offline
        N Offline
        Nubbbi
        @glasfaser
        ![85b79597-054d-4765-be09-13b9ebbf71d3-image.png](/assets/uploads/files/1706468856325-85b79597-054d-4765-be09-13b9ebbf71d3-image.png) code_text
        ```iobroker
        date,stream,content
        2024/01/28 19:33:12,stdout,This Script will exit now.
        2024/01/28 19:31:23,stdout,[DEBUG] IoBroker is not running!
        2024/01/28 19:31:23,stdout,[DEBUG] If you want to stop or restart your container you have to do it manually.
        2024/01/28 19:31:23,stdout,[DEBUG] This enables you to investigate or fix your issue on the command line.
        2024/01/28 19:31:23,stdout,[DEBUG] Debug mode prevents the container from exiting on errors.
        2024/01/28 19:31:23,stdout,For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
        2024/01/28 19:31:23,stdout,Please check your configuration and try again.
        2024/01/28 19:31:23,stdout,[DEBUG] No connection to databases possible ...
        2024/01/28 19:31:23,stdout,[DEBUG]  Could not connect to states database at 127.0.0.1:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
        2024/01/28 19:31:23,stdout,[DEBUG] Error message:
        2024/01/28 19:31:23,stdout,Checking database connection... Failed.
        2024/01/28 19:30:30,stdout,
        2024/01/28 19:30:30,stdout,[DEBUG] Done.
        2024/01/28 19:30:30,stdout,[DEBUG] No custom states db settings detected.
        2024/01/28 19:30:30,stdout,[DEBUG] Checking custom states db settings...
        2024/01/28 19:30:30,stdout,[DEBUG] No custom objects db settings detected.
        2024/01/28 19:30:30,stdout,[DEBUG] Checking custom objects db settings...
        2024/01/28 19:30:30,stdout,[DEBUG] No multihost settings detected.
        2024/01/28 19:30:30,stdout,[DEBUG] Checking multihost settings...
        2024/01/28 19:30:30,stdout,(Re)setting permissions (This might take a while! Please be patient!)... Done.
        2024/01/28 19:30:30,stdout,--------------------------------------------------------------------------------
        2024/01/28 19:30:30,stdout,-----             Step 3 of 5: Checking ioBroker Installation              -----
        2024/01/28 19:30:30,stdout,Existing installation of ioBroker detected in "/opt/iobroker".
        2024/01/28 19:30:30,stdout,-----             Step 2 of 5: Detecting ioBroker Installation             -----
        2024/01/28 19:30:30,stdout,-----                   Step 1 of 5: Preparing Container                   -----
        2024/01/28 19:30:30,stdout,!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2024/01/28 19:30:30,stdout,!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
        2024/01/28 19:30:30,stdout,!!!!     For more information see ioBroker Docker image documentation:      !!!!
        2024/01/28 19:30:30,stdout,!!!!          Please make sure to deactivate if no longer needed.           !!!!
        2024/01/28 19:30:30,stdout,!!!! This will extend the logging output and may slow down container start. !!!!
        2024/01/28 19:30:30,stdout,!!!!               Environment variable DEBUG is set to true.               !!!!
        2024/01/28 19:30:30,stdout,!!!!                            DEBUG LOG ACTIVE                            !!!!
        N GlasfaserG 2 Antworten Letzte Antwort
        • N Nubbbi
          @glasfaser
          ```iobroker
          date,stream,content
          N Offline
          N Offline
          Nubbbi
          @nubbbi
          Kann es sein, dass der Port 9000, der hier erwartet wird, bereits anders genutzt wird? Nämlich bei mir von Portainer?
          • N Nubbbi
            @glasfaser
            ```iobroker
            date,stream,content
            GlasfaserG Offline
            GlasfaserG Offline
            Zeige mal vom vorhanden Container , die Full Ausgabe von
            iob diag
            • N Nubbbi
              @nubbbi
              GlasfaserG Offline
              GlasfaserG Offline
              Richtig , den mußt du ändern !!!
                N Offline
                N Offline
                Nubbbi
                @glasfaser Wenn ich den Port 9000 für den Container Portainer ändere, komme ich aber nicht mehr auf dessen Weboberfläche.
                • N Nubbbi
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @nubbbi
                  sieht dann so aus , also über den Port 8020 erreichbar :
                  Portainer ist im Bridge Modus :
                  .7572cd39-5cd1-482a-bf59-91ed9a451831-grafik.png .
                    @nubbbi
                    N Offline
                    N Offline
                    Nubbbi
                    @glasfaser
                    *** ioBroker-Installation ***
                    ioBroker Status
                     Could not connect to objects database at 127.0.0.1:9001 (invalid protocol). Plea
                    Core adapters versions
                    js-controller:  5.0.17
                    admin:          6.12.0
                    javascript:     "javascript" not found
                    Adapters from github:   0
                    Adapter State
                    • N Nubbbi
                      @glasfaser
                      ioBroker Status
                      admin:          6.12.0
                      Adapter State
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @nubbbi
                      was hast du denn noch auf 9001
                        @nubbbi
                        N Offline
                        N Offline
                        Nubbbi
                        @glasfaser Also, ich öffne die Einstellungen zum Container, gehe auf "Terminalfenster öffnen" und dann "Mit Befehl starten" und da gebe ich "iob diag" ein - soweit richtig?
                        Mir gelingt es aber nicht, das Ergebnis per STRG-C zu kopieren.
                        • GlasfaserG Offline
                          GlasfaserG Offline
                          Steht in der Beschreibung !!
                          vorher STRG-A dann STRG-C
                            N Offline
                            N Offline
                            Nubbbi
                            @glasfaser vorher heißt, wenn da steht "drücke eine Taste, um Summary zu erstellen"?
                            • N Nubbbi
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @nubbbi
                              dort abbrechen , brauche die Summary nicht , nur die Full Ausgabe davor
                                @nubbbi
                                N Offline
                                N Offline
                                Nubbbi
                                @glasfaser ```
                                                    admin                   6.12.0
                                ioBroker Status: iobroker is not running on this host.
                                Objects type: jsonl
                                States type: jsonl
                                system.adapter.admin.0 : admin : buildkitsandb
                                ox - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                Objects: 96
                                States: 22
                                Size of iob-Database:
                                4.1M /opt/iobroker/iobroker-data/objects.jsonl
                                12K /opt/iobroker/iobroker-data/states.jsonl
                                === Mark text until here for copying ===
                                • N Nubbbi
                                  @glasfaser ```
                                                      admin                   6.12.0
                                  Objects type: jsonl
                                  States type: jsonl
                                  Objects: 96
                                  States: 22
                                  N Offline
                                  N Offline
                                  Nubbbi
                                  @nubbbi Ich bekomme immer nur die letzte sichtbare Seite in die Zwischenablage kopiert, ich kapiere das mit STRG-A nicht.
