  4. KNX-Adapter - keine UDP-Verbindung - OpenKNX-Adapter i.O.
    6.1k
43 Beiträge 2 Kommentatoren 5.1k Aufrufe 2 Beobachtet
  • N Nubbbi
    @glasfaser
    ![85b79597-054d-4765-be09-13b9ebbf71d3-image.png](/assets/uploads/files/1706468856325-85b79597-054d-4765-be09-13b9ebbf71d3-image.png) code_text
    ```iobroker
    date,stream,content
    2024/01/28 19:33:12,stdout,This Script will exit now.
    2024/01/28 19:31:23,stdout,[DEBUG] IoBroker is not running!
    2024/01/28 19:31:23,stdout,[DEBUG] If you want to stop or restart your container you have to do it manually.
    2024/01/28 19:31:23,stdout,[DEBUG] This enables you to investigate or fix your issue on the command line.
    2024/01/28 19:31:23,stdout,[DEBUG] Debug mode prevents the container from exiting on errors.
    2024/01/28 19:31:23,stdout,For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
    2024/01/28 19:31:23,stdout,Please check your configuration and try again.
    2024/01/28 19:31:23,stdout,[DEBUG] No connection to databases possible ...
    2024/01/28 19:31:23,stdout,[DEBUG]  Could not connect to states database at 127.0.0.1:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
    2024/01/28 19:31:23,stdout,[DEBUG] Error message:
    2024/01/28 19:31:23,stdout,Checking database connection... Failed.
    2024/01/28 19:30:30,stdout,
    2024/01/28 19:30:30,stdout,[DEBUG] Done.
    2024/01/28 19:30:30,stdout,[DEBUG] No custom states db settings detected.
    2024/01/28 19:30:30,stdout,[DEBUG] Checking custom states db settings...
    2024/01/28 19:30:30,stdout,[DEBUG] No custom objects db settings detected.
    2024/01/28 19:30:30,stdout,[DEBUG] Checking custom objects db settings...
    2024/01/28 19:30:30,stdout,[DEBUG] No multihost settings detected.
    2024/01/28 19:30:30,stdout,[DEBUG] Checking multihost settings...
    2024/01/28 19:30:30,stdout,(Re)setting permissions (This might take a while! Please be patient!)... Done.
    2024/01/28 19:30:30,stdout,--------------------------------------------------------------------------------
    2024/01/28 19:30:30,stdout,-----             Step 3 of 5: Checking ioBroker Installation              -----
    2024/01/28 19:30:30,stdout,Existing installation of ioBroker detected in "/opt/iobroker".
    2024/01/28 19:30:30,stdout,-----             Step 2 of 5: Detecting ioBroker Installation             -----
    2024/01/28 19:30:30,stdout,-----                   Step 1 of 5: Preparing Container                   -----
    2024/01/28 19:30:30,stdout,!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    2024/01/28 19:30:30,stdout,!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
    2024/01/28 19:30:30,stdout,!!!!     For more information see ioBroker Docker image documentation:      !!!!
    2024/01/28 19:30:30,stdout,!!!!          Please make sure to deactivate if no longer needed.           !!!!
    2024/01/28 19:30:30,stdout,!!!! This will extend the logging output and may slow down container start. !!!!
    2024/01/28 19:30:30,stdout,!!!!               Environment variable DEBUG is set to true.               !!!!
    2024/01/28 19:30:30,stdout,!!!!                            DEBUG LOG ACTIVE                            !!!!
    GlasfaserG Offline
    GlasfaserG Offline
    @nubbbi sagte in KNX-Adapter - keine UDP-Verbindung - OpenKNX-Adapter i.O.:
    Zeige mal vom vorhanden Container , die Full Ausgabe von
    iob diag
    • N Nubbbi
      @nubbbi
      Kann es sein, dass der Port 9000, der hier erwartet wird, bereits anders genutzt wird? Nämlich bei mir von Portainer?
      GlasfaserG Offline
      GlasfaserG Offline
      Richtig , den mußt du ändern !!!
      N 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        N Offline
        N Offline
        Nubbbi
        @glasfaser Wenn ich den Port 9000 für den Container Portainer ändere, komme ich aber nicht mehr auf dessen Weboberfläche.
        • N Nubbbi
          GlasfaserG Offline
          GlasfaserG Offline
          @nubbbi
          sieht dann so aus , also über den Port 8020 erreichbar :
          Portainer ist im Bridge Modus :
          .7572cd39-5cd1-482a-bf59-91ed9a451831-grafik.png .
            @nubbbi
            N Offline
            N Offline
            Nubbbi
            @glasfaser
            *** ioBroker-Installation ***
            ioBroker Status
             Could not connect to objects database at 127.0.0.1:9001 (invalid protocol). Plea
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.12.0
            javascript:     "javascript" not found
            Adapters from github:   0
            Adapter State
            • N Nubbbi
              @glasfaser
              ioBroker Status
              admin:          6.12.0
              Adapter State
              GlasfaserG Offline
              GlasfaserG Offline
              @nubbbi
              was hast du denn noch auf 9001
                @nubbbi
                N Offline
                N Offline
                Nubbbi
                @glasfaser Also, ich öffne die Einstellungen zum Container, gehe auf "Terminalfenster öffnen" und dann "Mit Befehl starten" und da gebe ich "iob diag" ein - soweit richtig?
                Mir gelingt es aber nicht, das Ergebnis per STRG-C zu kopieren.
                • GlasfaserG Offline
                  GlasfaserG Offline
                  Steht in der Beschreibung !!
                  vorher STRG-A dann STRG-C
                    N Offline
                    N Offline
                    Nubbbi
                    @glasfaser vorher heißt, wenn da steht "drücke eine Taste, um Summary zu erstellen"?
                    • N Nubbbi
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @nubbbi
                      dort abbrechen , brauche die Summary nicht , nur die Full Ausgabe davor
                        @nubbbi
                        N Offline
                        N Offline
                        Nubbbi
                        @glasfaser ```
                                            admin                   6.12.0
                        ioBroker Status: iobroker is not running on this host.
                        Objects type: jsonl
                        States type: jsonl
                        system.adapter.admin.0 : admin : buildkitsandb
                        ox - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        Objects: 96
                        States: 22
                        Size of iob-Database:
                        4.1M /opt/iobroker/iobroker-data/objects.jsonl
                        12K /opt/iobroker/iobroker-data/states.jsonl
                        === Mark text until here for copying ===
                        • N Nubbbi
                          @glasfaser ```
                                              admin                   6.12.0
                          Objects type: jsonl
                          States type: jsonl
                          Objects: 96
                          States: 22
                          N Offline
                          N Offline
                          Nubbbi
                          @nubbbi Ich bekomme immer nur die letzte sichtbare Seite in die Zwischenablage kopiert, ich kapiere das mit STRG-A nicht.
