  4. Diverse kleine Adapter Fehler
29 Beiträge 5 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • R Radix75
    @thomas-braun ```
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    ^[[3~ Static hostname: raspberrypi5
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-2712
        Architecture: arm64
    Model		: Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     13:51:03 up  2:38,  3 users,  load average: 1.46, 1.34, 1.28
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-01-28 13:51:03 CET
               Universal time: Sun 2024-01-28 12:51:03 UTC
                     RTC time: Sat 1970-01-03 19:52:47
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    Radix1975
    /home/Radix1975
    Radix1975 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop: 	LXDE-pi-wayfire
    Terminal: 	wayland
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            8.4G        3.6G        2.9G         77M        2.2G        4.9G
    Swap:           104M          0B        104M
    Total:          8.5G        3.6G        3.0G
             8049 M total memory
             3393 M used memory
             3505 M active memory
             1134 M inactive memory
             2763 M free memory
              200 M buffer memory
             1861 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    vc_gencmd_read_response returned -1
    error=1 error_msg="Command not registered"
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    * deconz.service        loaded failed failed deCONZ: ZigBee gateway -- REST API
    * networking.service    loaded failed failed Raise network interfaces
    3 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     805M  6.3M  799M   1% /run
    /dev/mmcblk0p2 ext4      234G   19G  203G   9% /
    tmpfs          tmpfs     4.0G  608K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      511M   74M  438M  15% /boot/firmware
    tmpfs          tmpfs     805M  176K  805M   1% /run/user/1000
    [Sun Jan 28 11:12:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BC:98:3F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=749f5341-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Sun Jan 28 11:12:18 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Jan 28 11:12:19 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.8G	/var/
    983M	/var/cache
    966M	/var/cache/apt
    944M	/var/lib
    853M	/var/cache/apt/archives
    Archived and active journals take up 769.5M in the file system.
    /opt/iobroker/backups:
    670M	/opt/iobroker/backups/
    4.0K	/opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    743M	/opt/iobroker/iobroker-data/
    683M	/opt/iobroker/iobroker-data/files
    89M	/opt/iobroker/iobroker-data/files/echarts.admin
    78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    67M	/opt/iobroker/iobroker-data/files/minuvis
    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1962617-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /usr/bin/npm 		9.2.0
    /usr/bin/npx 		9.2.0
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.12.0
    javascript: 	7.1.6
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : raspberrypi5                             -  enabled, port: 8085, bind: 192.168.1.226, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspberrypi5                             -  enabled
    + system.adapter.chromecast.1             : chromecast            : raspberrypi5                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi5                             -  enabled
      system.adapter.deconz.1                 : deconz                : raspberrypi5                             - disabled, port: 80
    + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi5                             -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi5                             - disabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi5                             -  enabled
    + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi5                             -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi5                             -  enabled, port: 12010
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi5                             -  enabled, port: 12001
    + system.adapter.hue.0                    : hue                   : raspberrypi5                             -  enabled, port: 80
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi5                             - disabled
      system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: raspberrypi5                             - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi5                             - disabled
      system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi5                             - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi5                             - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi5                             - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi5                             - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi5                             - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi5                             - disabled
      system.adapter.icons-smarthome.0        : icons-smarthome       : raspberrypi5                             - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi5                             - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi5                             -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
    + system.adapter.lovelace.0               : lovelace              : raspberrypi5                             -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.minuvis.0                : minuvis               : raspberrypi5                             - disabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi5                             -  enabled
    + system.adapter.onvif.0                  : onvif                 : raspberrypi5                             -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi5                             -  enabled
    + system.adapter.solax.0                  : solax                 : raspberrypi5                             -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi5                             -  enabled
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi5                             -  enabled
    + system.adapter.tr-064.2                 : tr-064                : raspberrypi5                             -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi5                             - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi5                             - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi5                             - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi5                             - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi5                             -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi5                             - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi5                             - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi5                             - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi5                             -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi5                             - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi5                             - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi5                             - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi5                             - disabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi5                             - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi5                             - disabled
      system.adapter.vis-material.0           : vis-material          : raspberrypi5                             - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi5                             - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi5                             - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi5                             - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi5                             - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi5                             - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi5                             - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi5                             -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1962617-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.10.2   , installed 3.10.2
    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "onvif"        : 1.1.1    , installed 1.1.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solax"        : 0.8.0    , installed 0.8.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects: 	9022
    States: 	7052
    ^[[3~Hit:1 http://deb.debian.org/debian bookworm InRelease
    Hit:2 http://phoscon.de/apt/deconz bookworm InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          18204      1625/dnsmasq
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       27620      4840/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18630      1227/sshd: /usr/sbi
    tcp        0      0 192.168.1.65:12010      0.0.0.0:*               LISTEN      1001       29266      5027/io.hm-rpc.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18637      1207/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20677      1208/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19926      1208/iobroker.js-co
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18636      1207/cupsd
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       29905      4878/io.lovelace.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21406      2467/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31799      5141/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18632      1227/sshd: /usr/sbi
    tcp6       0      0 :::5900                 :::*                    LISTEN      992        19535      1216/wayvnc
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          18203      1625/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          18200      1625/dnsmasq
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19718      1513/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26092      4205/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24279      3643/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        18436      706/avahi-daemon: r
    udp        0      0 0.0.0.0:35225           0.0.0.0:*                           104        18438      706/avahi-daemon: r
    udp6       0      0 :::49052                :::*                                104        18439      706/avahi-daemon: r
    udp6       0      0 fe80::83ce:917a:6b2:546 :::*                                0          19764      922/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        18437      706/avahi-daemon: r
    2024-01-28 13:49:17.317  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    2024-01-28 13:49:17.318  - info: host.raspberrypi5 Restart adapter system.adapter.hm-rpc.1 because enabled
    2024-01-28 13:49:47.381  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 started with pid 51509
    2024-01-28 13:49:48.645  - info: hm-rpc.1 (51509) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
    2024-01-28 13:49:48.764  - info: hm-rpc.1 (51509) binrpc server is trying to listen on 192.168.1.65:12001
    2024-01-28 13:49:48.764  - info: hm-rpc.1 (51509) binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:3a6875486a20cf6d1ffc37d6d5a93d7e"]
    2024-01-28 13:49:53.773  - error: hm-rpc.1 (51509) Init not possible, going to stop: response timeout
    2024-01-28 13:49:58.225  - info: solax.0 (4965) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
    2024-01-28 13:50:23.773  - error: hm-rpc.1 (51509) Init not possible, going to stop: response timeout
    2024-01-28 13:50:23.775  - info: hm-rpc.1 (51509) binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
    2024-01-28 13:50:24.779  - info: hm-rpc.1 (51509) terminating
    2024-01-28 13:50:24.780  - info: hm-rpc.1 (51509) Terminated (NO_ERROR): Without reason
    2024-01-28 13:50:25.334  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    2024-01-28 13:50:25.334  - info: host.raspberrypi5 Restart adapter system.adapter.hm-rpc.1 because enabled
    2024-01-28 13:50:55.373  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 started with pid 51645
    2024-01-28 13:50:56.559  - info: hm-rpc.1 (51645) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
    2024-01-28 13:50:56.684  - info: hm-rpc.1 (51645) binrpc server is trying to listen on 192.168.1.65:12001
    2024-01-28 13:50:56.685  - info: hm-rpc.1 (51645) binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:9b9a06ee17e8730a5936df99e5cdd256"]
    2024-01-28 13:51:01.692  - error: hm-rpc.1 (51645) Init not possible, going to stop: response timeout
    2024-01-28 13:51:31.694  - error: hm-rpc.1 (51645) Init not possible, going to stop: response timeout
    2024-01-28 13:51:31.695  - info: hm-rpc.1 (51645) binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
    2024-01-28 13:51:32.707  - info: hm-rpc.1 (51645) terminating
    2024-01-28 13:51:32.710  - info: hm-rpc.1 (51645) Terminated (NO_ERROR): Without reason
    2024-01-28 13:51:33.269  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    2024-01-28 13:51:33.269  - info: host.raspberrypi5 Restart adapter system.adapter.hm-rpc.1 because enabled
    iob diag has finished.
    Press any key for a summary
    @radix75
    https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
    Und schalt den Desktop aus:
    sudo systemctl set-default multi-user.target
    R 1 Antwort Letzte Antwort
      @radix75
      Radix75
      schrieb am zuletzt editiert von Radix75
      @thomas-braun said in Diverse kleine Adapter Fehler:
      Radix1975@raspberrypi5:~ $ https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
      bash: https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur: Datei oder Verzeichnis nicht gefunden
      Radix1975@raspberrypi5:~ $ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
      sudo apt update
      iob stop
      sudo apt remove npm
      sudo apt install nodejs=18.19.0-1nodesource1
      iob restart
      Package: nodejs
      Pin-Priority: 1001
      OK:1 http://deb.debian.org/debian bookworm InRelease
      OK:2 http://deb.debian.org/debian-security bookworm-security InRelease
      OK:3 http://phoscon.de/apt/deconz bookworm InRelease
      OK:4 http://deb.debian.org/debian bookworm-updates InRelease
      OK:5 http://archive.raspberrypi.com/debian bookworm InRelease
      OK:6 https://apt.pivccu.de/piVCCU stable InRelease
      OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Alle Pakete sind aktuell.
      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
        eslint gyp handlebars libjs-async libjs-events libjs-inherits
        libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map
        libjs-sprintf-js libjs-typedarray-to-buffer libjs-util libnode-dev
        libuv1-dev node-abbrev node-agent-base node-ajv node-ajv-keywords
        node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles
        node-anymatch node-aproba node-archy node-are-we-there-yet node-argparse
        node-arrify node-assert node-async node-async-each
        node-babel-helper-define-polyfill-provider
        node-babel-plugin-add-module-exports node-babel-plugin-lodash
        node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3
        node-babel-plugin-polyfill-regenerator node-babel7 node-babel7-runtime
        node-balanced-match node-base64-js node-binary-extensions
        node-brace-expansion node-braces node-browserslist node-builtins
        node-cacache node-camelcase node-caniuse-lite node-chalk node-chokidar
        node-chownr node-chrome-trace-event node-ci-info node-cli-table node-cliui
        node-clone node-clone-deep node-color-convert node-color-name node-colors
        node-columnify node-commander node-commondir node-concat-stream
        node-console-control-strings node-convert-source-map node-copy-concurrently
        node-core-js node-core-js-compat node-core-js-pure node-core-util-is
        node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
        node-debbundle-es-to-primitive node-debug node-decamelize
        node-decompress-response node-deep-equal node-deep-is node-defaults
        node-define-properties node-defined node-del node-delegates node-depd
        node-diff node-doctrine node-electron-to-chromium node-encoding
        node-end-of-stream node-enhanced-resolve node-err-code node-errno
        node-error-ex node-es-abstract node-es-module-lexer node-es6-error
        node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
        node-eslint-visitor-keys node-espree node-esprima node-esquery
        node-esrecurse node-estraverse node-esutils node-events node-fancy-log
        node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache
        node-fill-range node-find-cache-dir node-find-up node-flat-cache
        node-flatted node-for-in node-for-own node-foreground-child
        node-fs-readdir-recursive node-fs-write-stream-atomic node-fs.realpath
        node-function-bind node-functional-red-black-tree node-gauge
        node-get-caller-file node-get-stream node-glob node-glob-parent node-globals
        node-globby node-got node-graceful-fs node-gyp node-has-flag
        node-has-unicode node-hosted-git-info node-https-proxy-agent node-iconv-lite
        node-icss-utils node-ieee754 node-iferr node-ignore node-imurmurhash
        node-indent-string node-inflight node-inherits node-ini node-interpret
        node-ip node-ip-regex node-is-arrayish node-is-binary-path node-is-buffer
        node-is-extendable node-is-extglob node-is-glob node-is-number
        node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object
        node-is-stream node-is-typedarray node-is-windows node-isarray node-isexe
        node-isobject node-istanbul node-jest-debbundle node-jest-worker
        node-js-tokens node-js-yaml node-jsesc node-json-buffer
        node-json-parse-better-errors node-json-schema node-json-schema-traverse
        node-json-stable-stringify node-json5 node-jsonify node-jsonparse
        node-kind-of node-levn node-loader-runner node-locate-path node-lodash
        node-lodash-packages node-lowercase-keys node-lru-cache node-make-dir
        node-memfs node-memory-fs node-merge-stream node-micromatch node-mime
        node-mime-types node-mimic-response node-minimatch node-minimist
        node-minipass node-mkdirp node-move-concurrently node-ms node-mute-stream
        node-n3 node-negotiator node-neo-async node-nopt node-normalize-package-data
        node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path
        node-npmlog node-object-assign node-object-inspect node-once node-optimist
        node-optionator node-osenv node-p-cancelable node-p-limit node-p-locate
        node-p-map node-parse-json node-path-dirname node-path-exists
        node-path-is-absolute node-path-is-inside node-path-type node-picocolors
        node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports
        node-postcss-modules-values node-postcss-value-parser node-prelude-ls
        node-process-nextick-args node-progress node-promise-inflight
        node-promise-retry node-promzard node-prr node-pump node-punycode
        node-quick-lru node-randombytes node-read node-read-package-json
        node-read-pkg node-readable-stream node-readdirp node-rechoir
        node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
        node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen
        node-regjsparser node-repeat-string node-require-directory node-resolve
        node-resolve-cwd node-resolve-from node-resumer node-retry node-rimraf
        node-run-queue node-safe-buffer node-schema-utils node-semver
        node-serialize-javascript node-set-blocking node-set-immediate-shim
        node-shebang-command node-shebang-regex node-signal-exit node-slash
        node-slice-ansi node-source-list-map node-source-map node-source-map-support
        node-spdx-correct node-spdx-exceptions node-spdx-expression-parse
        node-spdx-license-ids node-sprintf-js node-ssri node-string-decoder
        node-string-width node-strip-ansi node-strip-bom node-strip-json-comments
        node-supports-color node-tapable node-tape node-tar node-terser
        node-text-table node-through node-time-stamp node-to-fast-properties
        node-to-regex-range node-tslib node-type-check node-typedarray
        node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
        node-unicode-match-property-ecmascript
        node-unicode-match-property-value-ecmascript
        node-unicode-property-aliases-ecmascript node-unique-filename node-uri-js
        node-util node-util-deprecate node-uuid node-v8-compile-cache node-v8flags
        node-validate-npm-package-license node-validate-npm-package-name
        node-watchpack node-wcwidth.js node-webassemblyjs node-webpack-sources
        node-which node-wide-align node-wordwrap node-wrap-ansi node-wrappy
        node-write node-write-file-atomic node-y18n node-yallist node-yargs
        node-yargs-parser terser webpack
      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
      Die folgenden Pakete werden ENTFERNT:
        npm
      0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
      Nach dieser Operation werden 3.012 kB Plattenplatz freigegeben.
      Möchten Sie fortfahren? [J/n] j
      (Lese Datenbank ... 297731 Dateien und Verzeichnisse sind derzeit installiert.)
      Entfernen von npm (9.2.0~ds1-1) ...
      Trigger für man-db (2.11.2-2) werden verarbeitet ...
        gyp handlebars libc-ares2 libjs-async libjs-events libjs-inherits
        libjs-sprintf-js libjs-typedarray-to-buffer libuv1-dev node-abbrev
        node-aproba node-are-we-there-yet node-argparse node-arrify node-async
        node-async-each node-babel-plugin-add-module-exports node-babel7-runtime
        node-brace-expansion node-busboy node-camelcase node-caniuse-lite
        node-chownr node-chrome-trace-event node-ci-info node-cjs-module-lexer
        node-console-control-strings node-convert-source-map node-core-js
        node-core-js-pure node-core-util-is node-data-uri-to-buffer
        node-decompress-response node-deep-is node-defaults node-delegates node-depd
        node-diff node-electron-to-chromium node-encoding node-end-of-stream
        node-err-code node-error-ex node-es-module-lexer node-escape-string-regexp
        node-eslint-utils node-eslint-visitor-keys node-esquery node-estraverse
        node-esutils node-events node-fancy-log node-fast-deep-equal
        node-fast-levenshtein node-fetch node-find-up node-flatted node-for-in
        node-for-own node-foreground-child node-fs-readdir-recursive
        node-fs-write-stream-atomic node-fs.realpath node-function-bind
        node-functional-red-black-tree node-get-caller-file node-get-stream
        node-glob node-globals node-got node-graceful-fs node-has-flag
        node-has-unicode node-hosted-git-info node-iconv-lite node-ieee754
        node-iferr node-imurmurhash node-indent-string node-inflight node-inherits
        node-ini node-interpret node-ip node-ip-regex node-is-arrayish
        node-is-binary-path node-is-buffer node-is-extendable node-is-extglob
        node-is-path-cwd node-is-plain-obj node-is-plain-object node-is-stream
        node-is-typedarray node-is-windows node-isarray node-isexe node-isobject
        node-js-tokens node-jsesc node-json-buffer node-json-parse-better-errors
        node-json-schema node-json-schema-traverse node-json-stable-stringify
        node-jsonify node-jsonparse node-kind-of node-levn node-loader-runner
        node-locate-path node-lodash-packages node-lowercase-keys node-lru-cache
        node-memfs node-merge-stream node-mimic-response node-minimatch
        node-minimist node-minipass node-mute-stream node-n3 node-negotiator
        node-neo-async node-npm-run-path node-object-inspect node-once node-optimist
        node-p-map node-path-dirname node-path-exists node-path-is-absolute
        node-path-is-inside node-path-type node-pify node-pkg-dir
        node-postcss-value-parser node-prelude-ls node-process-nextick-args
        node-promise-inflight node-promise-retry node-promzard node-prr node-pump
        node-quick-lru node-randombytes node-read node-readable-stream node-rechoir
        node-regenerator-transform node-regexpp node-regjsgen node-repeat-string
        node-require-directory node-resolve node-resolve-cwd node-resolve-from
        node-resumer node-retry node-run-queue node-safe-buffer
        node-strip-bom node-strip-json-comments node-supports-color node-tapable
        node-terser node-text-table node-through node-time-stamp
        node-to-fast-properties node-tslib node-type-check node-typedarray
        node-typedarray-to-buffer node-undici
        node-util-deprecate node-uuid node-v8flags node-validate-npm-package-license
        node-wcwidth.js node-webpack-sources node-wordwrap node-wrappy
        node-write-file-atomic node-xtend node-y18n node-yallist
        eslint libjs-util libnode-dev libnode108 node-acorn node-agent-base node-ajv
        node-ajv-keywords node-anymatch node-archy node-assert
        node-babel-helper-define-polyfill-provider node-babel-plugin-lodash
        node-babel-plugin-polyfill-regenerator node-babel7 node-braces
        node-browserslist node-builtins node-cacache node-chalk node-chokidar
        node-cli-table node-cliui node-columnify node-copy-concurrently
        node-core-js-compat node-css-loader node-css-selector-tokenizer
        node-debbundle-es-to-primitive node-debug node-decamelize node-deep-equal
        node-define-properties node-defined node-del node-doctrine
        node-enhanced-resolve node-errno node-es-abstract node-es6-error
        node-escodegen node-eslint-scope node-espree node-esprima node-esrecurse
        node-file-entry-cache node-fill-range node-find-cache-dir node-flat-cache
        node-gauge node-glob-parent node-globby node-gyp node-https-proxy-agent
        node-icss-utils node-ignore node-is-glob node-is-number node-is-path-inside
        node-istanbul node-jest-debbundle node-jest-worker node-js-yaml node-json5
        node-lodash node-make-dir node-memory-fs node-micromatch node-mime
        node-mime-types node-mkdirp node-move-concurrently node-ms node-nopt
        node-normalize-package-data node-normalize-path node-npm-bundled
        node-npm-package-arg node-npmlog node-object-assign node-parse-json
        node-picocolors node-postcss node-postcss-modules-extract-imports
        node-postcss-modules-values node-progress node-punycode
        node-read-package-json node-read-pkg node-readdirp node-regexpu-core
        node-regjsparser node-rimraf node-schema-utils node-semver node-string-width
        node-strip-ansi node-tape node-tar node-to-regex-range
        node-unicode-match-property-ecmascript node-uri-js node-util
        node-v8-compile-cache node-validate-npm-package-name node-watchpack
        node-webassemblyjs node-which node-wide-align node-wrap-ansi node-write
        node-yargs node-yargs-parser nodejs-doc terser webpack
      Die folgenden Pakete werden durch eine ÄLTERE VERSION ERSETZT (Downgrade):
        nodejs
      0 aktualisiert, 0 neu installiert, 1 durch eine ältere Version ersetzt, 118 zu entfernen und 0 nicht aktualisiert.
      Es müssen noch 0 B von 29,0 MB an Archiven heruntergeladen werden.
      Nach dieser Operation werden 82,7 MB Plattenplatz zusätzlich benutzt.
      (Lese Datenbank ... 296772 Dateien und Verzeichnisse sind derzeit installiert.)
      Entfernen von node-css-loader (6.7.2+~cs14.0.11-1) ...
      Entfernen von webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
      Entfernen von eslint (6.4.0~dfsg+~6.1.9-7) ...
      Entfernen von node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
      Entfernen von node-gyp (9.3.0-2) ...
      Entfernen von libnode-dev (18.19.0+dfsg-6~deb12u1) ...
      Entfernen von nodejs-doc (18.19.0+dfsg-6~deb12u1) ...
      Entfernen von node-espree (9.4.1~dfsg-1) ...
      Entfernen von node-v8-compile-cache (2.3.0-3) ...
      Entfernen von node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
      Entfernen von node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
      Entfernen von terser (5.16.5-2) ...
      Entfernen von node-npm-package-arg (10.0.0+~3.0.0-2) ...
      Entfernen von node-cacache (17.0.3+~cs10.3.7-1) ...
      Entfernen von node-move-concurrently (1.0.1-5) ...
      Entfernen von node-schema-utils (3.1.1~ds-2) ...
      Entfernen von node-progress (2.0.3-2) ...
      Entfernen von node-postcss-modules-extract-imports (3.0.0-2) ...
      Entfernen von node-eslint-scope (7.1.1+~3.7.4-1) ...
      Entfernen von node-esrecurse (4.3.0-2) ...
      Entfernen von node-jest-worker (29.3.1~ds1+~cs70.48.25-2) ...
      Entfernen von node-https-proxy-agent (5.0.1+~cs8.0.0-3) ...
      Entfernen von node-tar (6.1.13+~cs7.0.5-1) ...
      Entfernen von node-mime-types (2.1.35-1) ...
      Entfernen von node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
      Entfernen von node-watchpack (2.4.0+~cs2.8.1-1) ...
      Entfernen von node-chokidar (3.5.3-2) ...
      Entfernen von node-file-entry-cache (6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
      Entfernen von node-flat-cache (3.0.4~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
      Entfernen von node-write (2.0.0~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
      Entfernen von node-enhanced-resolve (5.10.0-1) ...
      Entfernen von node-memory-fs (0.5.0+~0.3.3-2) ...
      Entfernen von node-errno (1.0.0-3) ...
      Entfernen von node-doctrine (3.0.0-4) ...
      Entfernen von node-css-selector-tokenizer (0.8.0+~cs4.8.3-1) ...
      Entfernen von node-deep-equal (2.1.0+~cs31.12.80-1) ...
      Entfernen von node-tape (5.6.1+~cs8.20.19-1) ...
      Entfernen von node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
      Entfernen von node-read-pkg (5.2.0-2) ...
      Entfernen von node-parse-json (5.2.0+~cs5.1.7-1) ...
      Entfernen von node-assert (2.0.0+~cs3.9.8-2) ...
      Entfernen von node-util (0.12.5+~1.0.10-1) ...
      Entfernen von libjs-util (0.12.5+~1.0.10-1) ...
      Entfernen von node-define-properties (1.1.4+~1.1.3-1) ...
      Entfernen von node-es-abstract (1.20.4+~cs26.27.47-1) ...
      Entfernen von node-debbundle-es-to-primitive (1.2.1+~cs9.7.25-2) ...
      Entfernen von node-which (2.0.2+~cs1.3.2-3) ...
      Entfernen von node-babel7 (7.20.15+ds1+~cs214.269.168-3+deb12u1) ...
      Entfernen von node-regexpu-core (5.2.2-3) ...
      Entfernen von node-unicode-match-property-ecmascript (2.0.0-2) ...
      Entfernen von node-yargs (16.2.0+~16.0.4-7) ...
      Entfernen von node-cliui (7.0.4+repack+~cs3.1.0-4) ...
      Entfernen von node-wrap-ansi (8.0.1+~8.0.1-3) ...
      Entfernen von node-regjsparser (0.9.1+ds-2) ...
      Entfernen von node-babel-plugin-polyfill-corejs3 (0.6.0~0~20220913+ds1-1) ...
      Entfernen von node-core-js-compat (3.26.1-3) ...
      Entfernen von node-browserslist (4.21.4+~cs6.1.17-2) ...
      Entfernen von node-object-assign (4.1.1-7) ...
      Entfernen von node-find-cache-dir (3.3.2+~3.2.1-1) ...
      Entfernen von node-del (7.0.0-5) ...
      Entfernen von node-globby (13.1.3+~cs16.25.40-1) ...
      Entfernen von node-micromatch (4.0.5+~4.0.2-1) ...
      Entfernen von node-nopt (5.0.0-4) ...
      Entfernen von node-lodash (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
      Entfernen von node-json5 (2.2.3+dfsg-1) ...
      Entfernen von node-js-yaml (4.1.0+dfsg+~4.0.5-7) ...
      Entfernen von node-is-path-inside (3.0.3-2) ...
      Entfernen von node-braces (3.0.2+~3.0.1-1) ...
      Entfernen von node-fill-range (7.0.1+~7.0.0-1) ...
      Entfernen von node-to-regex-range (5.0.1-4) ...
      Entfernen von node-is-number (7.0.0-4) ...
      Entfernen von node-glob-parent (6.0.2+~5.1.1-2) ...
      Entfernen von node-is-glob (4.0.3-2) ...
      Entfernen von node-ignore (5.2.1-1) ...
      Entfernen von node-escodegen (2.0.0+dfsg+~0.0.7-2) ...
      Entfernen von node-esprima (4.0.1+ds+~4.0.3-2) ...
      Entfernen von node-es6-error (4.1.1-5) ...
      Entfernen von node-defined (1.0.1+~1.0.0-1) ...
      Entfernen von node-yargs-parser (21.1.1+~21.0.0-4) ...
      Entfernen von node-decamelize (4.0.0-2) ...
      Entfernen von node-chalk (5.2.0-1) ...
      Entfernen von node-archy (1.0.0-6) ...
      Entfernen von node-babel-plugin-polyfill-corejs2 (0.3.3~0~20220913+ds1-1) ...
      dpkg: node-ajv: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfernt:
       node-ajv-keywords hängt ab von node-ajv (>= 6.9.1~).
      Entfernen von node-ajv (6.12.6-3) ...
      Entfernen von node-uri-js (4.4.0+dfsg-8) ...
      Entfernen von node-punycode (2.1.1-6) ...
      dpkg: node-postcss: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfe
      rnt:
       node-postcss-modules-values hängt ab von node-postcss (>= 8.1~).
       node-icss-utils hängt ab von node-postcss (>= 8.1~).
      Entfernen von node-postcss (8.4.20+~cs8.0.23-1) ...
      Entfernen von node-picocolors (1.0.0-4) ...
      dpkg: node-anymatch: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entf
      ernt:
       node-readdirp hängt ab von node-anymatch (>= 3.0.3).
      Entfernen von node-anymatch (3.1.3+~cs4.6.1-2) ...
      Entfernen von node-normalize-path (3.0.0+~3.0.0-1) ...
      dpkg: node-debug: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfern
      t:
       node-babel-helper-define-polyfill-provider hängt ab von node-debug.
       node-agent-base hängt ab von node-debug.
      Entfernen von node-debug (4.3.4+~cs4.1.7-1) ...
      Entfernen von node-ms (2.1.3+~cs0.7.31-3) ...
      dpkg: node-mkdirp: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfer
      nt:
       node-copy-concurrently hängt ab von node-mkdirp (>= 1).
      Entfernen von node-mkdirp (1.0.4+~1.0.2-4) ...
      dpkg: libnode108:arm64: Abhängigkeitsprobleme, wird aber wie gefordert dennoch e
      ntfernt:
       nodejs hängt ab von libnode108 (= 18.19.0+dfsg-6~deb12u1).
      Entfernen von libnode108:arm64 (18.19.0+dfsg-6~deb12u1) ...
      dpkg: node-strip-ansi: Abhängigkeitsprobleme, wird aber wie gefordert dennoch en
      tfernt:
       node-string-width hängt ab von node-strip-ansi.
       node-gauge hängt ab von node-strip-ansi.
       node-columnify hängt ab von node-strip-ansi.
      Entfernen von node-strip-ansi (6.0.1-2) ...
      dpkg: node-semver: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfer
      nt:
       node-normalize-package-data hängt ab von node-semver.
       node-make-dir hängt ab von node-semver.
       node-builtins hängt ab von node-semver.
       node-babel-helper-define-polyfill-provider hängt ab von node-semver.
       node-agent-base hängt ab von node-semver.
      Entfernen von node-semver (7.3.5+~7.3.9-2) ...
      dpkg: node-rimraf: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfer
      nt:
       node-copy-concurrently hängt ab von node-rimraf.
      Entfernen von node-rimraf (3.0.2-2) ...
      dpkg: Warnung: Version 18.19.0+dfsg-6~deb12u1 des Paketes nodejs wird durch älte
      re Version 18.19.0-1nodesource1 ersetzt
      (Lese Datenbank ... 283791 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../nodejs_18.19.0-1nodesource1_arm64.deb ...
      Entpacken von nodejs (18.19.0-1nodesource1) über (18.19.0+dfsg-6~deb12u1) ...
      (Lese Datenbank ... 289110 Dateien und Verzeichnisse sind derzeit installiert.)
      Entfernen von node-acorn (8.8.1+ds+~cs25.17.7-2) ...
      Entfernen von node-agent-base (6.0.2+~cs5.4.2-2) ...
      Entfernen von node-ajv-keywords (3.5.2-2) ...
      Entfernen von node-babel-plugin-polyfill-regenerator (0.4.1~0~20220913+ds1-1) ..
      Entfernen von node-babel-helper-define-polyfill-provider (0.3.3~0~20220913+ds1-1
      Entfernen von node-validate-npm-package-name (5.0.0+~4.0.0-1) ...
      Entfernen von node-builtins (5.0.1-1) ...
      Entfernen von node-cli-table (0.3.11+~cs0.13.4-3) ...
      Entfernen von node-columnify (1.6.0+~1.5.1-1) ...
      Entfernen von node-copy-concurrently (1.0.5-9) ...
      Entfernen von node-npmlog (7.0.1+~4.1.4-1) ...
      Entfernen von node-gauge (4.0.4-1) ...
      Entfernen von node-postcss-modules-values (4.0.0+~4.0.0-1) ...
      Entfernen von node-icss-utils (5.1.0+~5.1.0-1) ...
      Entfernen von node-make-dir (3.1.0-3) ...
      Entfernen von node-npm-bundled (2.0.1-2) ...
      Entfernen von node-read-package-json (5.0.2+~2.0.0-1) ...
      Entfernen von node-normalize-package-data (4.0.1+~2.4.1-1) ...
      Entfernen von node-readdirp (3.6.0-1) ...
      Entfernen von node-wide-align (1.1.3-4) ...
      Entfernen von node-string-width (4.2.3+~cs13.2.3-1) ...
      nodejs (18.19.0-1nodesource1) wird eingerichtet ...
      Trigger für libc-bin (2.36-9+rpt2+deb12u3) werden verarbeitet ...
      den zweiten Admin Adapter habe ich gelöscht die GUI möchte ich gerne behalten
      noch einer eine Idee warum zu hm-rpc.1 wechselt von gelb nach rot hin und her
      • R Radix75
        sudo apt update
        iob stop
        sudo apt remove npm
        iob restart
        Package: nodejs
        Pin-Priority: 1001
          npm
          nodejs
        rnt:
        ernt:
        t:
        nt:
        ntfernt:
        tfernt:
        nt:
        nt:
        @radix75 sagte in Diverse kleine Adapter Fehler:
        Warum? Die steht nur im Weg herum. Und macht die Bedienung und den Unterhalt eines Servers komplizierter.
          Radix75
          Diese Diskussion hatten wir ja schon mal....
          Ich tue mir einfach leichter damit und die Raspberry 5 mit 8GB solle genug Leistung dafür haben.
          Ich und mein Vater können so immer vom HW Raum auf das Smart home zugreifen.
          Es ist alles auf Deutsch .
          Ich kann meine Netzwerkverbindungen sehen.
          Ich kann Einstellungen direct über das GUI machen.
          Und ja ich möchte sie wirklich behalten.
          So habt ihr noch andere Fehler die ich beheben sollte " zu Deine Instanzen sind verwurschtelt....
          Und vieles andere auch 😞" was meist Du damit??
          und warum wechselt nun die hm-rpc.1 von gelb nach rot hin und her warum ist das so?
          code_text
          ```hm-rpc.1
          2024-01-27 09:32:55.726	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:32:50.719	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:3acb5d0ff60e8170c1bd75ea731ef0b9"]
          hm-rpc.1
          2024-01-27 09:32:50.719	info	binrpc server is trying to listen on 192.168.1.65:12001
          hm-rpc.1
          2024-01-27 09:32:50.615	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
          hm-rpc.1
          2024-01-27 09:32:18.821	info	Terminated (NO_ERROR): Without reason
          hm-rpc.1
          2024-01-27 09:32:18.820	info	terminating
          hm-rpc.1
          2024-01-27 09:32:17.817	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
          hm-rpc.1
          2024-01-27 09:32:17.815	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:31:47.815	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:31:42.808	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:a653d724b29195d887ed1f93dd71cb03"]
          hm-rpc.1
          2024-01-27 09:31:42.807	info	binrpc server is trying to listen on 192.168.1.65:12001
          hm-rpc.1
          2024-01-27 09:31:42.703	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
          hm-rpc.1
          2024-01-27 09:31:10.902	info	Terminated (NO_ERROR): Without reason
          hm-rpc.1
          2024-01-27 09:31:10.901	info	terminating
          hm-rpc.1
          2024-01-27 09:31:09.897	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
          hm-rpc.1
          2024-01-27 09:31:09.896	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:30:39.894	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:30:34.887	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:76df1607047ecef5fc1f2b38e8162df6"]
          hm-rpc.1
          2024-01-27 09:30:34.886	info	binrpc server is trying to listen on 192.168.1.65:12001
          hm-rpc.1
          2024-01-27 09:30:34.767	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
          hm-rpc.1
          2024-01-27 09:30:02.961	info	Terminated (NO_ERROR): Without reason
          hm-rpc.1
          2024-01-27 09:30:02.960	info	terminating
          hm-rpc.1
          2024-01-27 09:30:01.958	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:30:01.955	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
          hm-rpc.1
          2024-01-27 09:29:31.953	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:29:26.946	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:c2966d8591766baca963b02eec56645e"]
          hm-rpc.1
          2024-01-27 09:29:26.945	info	binrpc server is trying to listen on 192.168.1.65:12001
          hm-rpc.1
          2024-01-27 09:29:26.826	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
          hm-rpc.1
          2024-01-27 09:28:55.015	info	Terminated (NO_ERROR): Without reason
          hm-rpc.1
          2024-01-27 09:28:55.014	info	terminating
          hm-rpc.1
          2024-01-27 09:28:54.008	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
          hm-rpc.1
          2024-01-27 09:28:54.007	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:28:24.005	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:28:18.997	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:63715ec7769697d2091f2d779f4c15e1"]
          hm-rpc.1
          2024-01-27 09:28:18.996	info	binrpc server is trying to listen on 192.168.1.65:12001
          hm-rpc.1
          2024-01-27 09:28:18.876	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
          hm-rpc.1
          2024-01-27 09:27:47.191	info	Terminated (NO_ERROR): Without reason
          hm-rpc.1
          2024-01-27 09:27:47.190	info	terminating
          hm-rpc.1
          2024-01-27 09:27:46.186	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
          hm-rpc.1
          2024-01-27 09:27:46.184	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:27:16.183	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:27:11.176	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:0169b282d72839c63695bb1c43a8559d"]
          hm-rpc.1
          2024-01-27 09:27:11.176	info	binrpc server is trying to listen on 192.168.1.65:12001
          hm-rpc.1
          2024-01-27 09:27:11.073	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
          hm-rpc.1
          2024-01-27 09:26:39.226	info	Terminated (NO_ERROR): Without reason
          hm-rpc.1
          2024-01-27 09:26:39.225	info	terminating
          hm-rpc.1
          2024-01-27 09:26:38.221	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
          hm-rpc.1
          2024-01-27 09:26:38.219	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:26:08.218	error	Init not possible, going to stop: response timeout
          hm-rpc.1
          2024-01-27 09:26:03.210	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:4c8537fb5485d0deccecc3c8345a965d"]
          hm-rpc.1
          2024-01-27 09:26:03.209	info	binrpc server is trying to listen on 192.168.1.65:12001
          hm-rpc.1
          2024-01-27 09:26:03.088	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17**bolded text******bolded text****
          • R Radix75
            code_text
            ```hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            hm-rpc.1
            @radix75
            iob diag
            in der Langfassung. Und schalt den Desktop aus.
              @radix75
              iob diag
              Radix75
              hue.0 kann nicht gehen weil Deconz jetzt aus ist
              `======== Start marking the full check here =========
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
               14:45:43 up  3:33,  3 users,  load average: 0.20, 0.14, 0.37
              CPU threads: 4
              Current issues:
                             Local time: Sun 2024-01-28 14:45:43 CET
                         Universal time: Sun 2024-01-28 13:45:43 UTC
                               RTC time: Sat 1970-01-03 20:47:27
                            NTP service: active
                        RTC in local TZ: no
              Radix1975
              /home/Radix1975
              X-Server: 	false
              Terminal: 	wayland
              *** MEMORY ***
              Mem:            8.4G        3.1G        2.9G         71M        2.6G        5.3G
              Swap:           104M          0B        104M
              Total:          8.5G        3.1G        3.0G
                       8049 M total memory
                       2971 M used memory
                       3079 M active memory
                       1591 M inactive memory
                       2726 M free memory
                        301 M buffer memory
                       2214 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              *** FILESYSTEM ***
              /var:
              2.8G	/var/
              983M	/var/cache
              966M	/var/cache/apt
              942M	/var/lib
              750M	/opt/iobroker/iobroker-data/
              USB-Devices by-id:
              /usr/bin/npm 		10.2.3
              /usr/bin/npx 		10.2.3
              /usr/bin/corepack 	0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
               *** 18.19.0-1nodesource1 1001
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.12.0
              javascript: 	7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	8992
              States: 	7028
              Hit:1 http://phoscon.de/apt/deconz bookworm InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Pending Updates: 0
              tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       292691     56035/io.jarvis.0
              tcp        0      0 192.168.1.65:12001      0.0.0.0:*               LISTEN      1001       307537     57841/io.hm-rpc.1
              tcp        0      0 192.168.1.65:12010      0.0.0.0:*               LISTEN      1001       291020     55769/io.hm-rpc.0
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       287659     55535/iobroker.js-c
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       287670     55535/iobroker.js-c
              tcp6       0      0 :::8091                 :::*                    LISTEN      1001       292733     56052/io.lovelace.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       287730     55554/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       293959     56181/io.web.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       289388     55809/io.chromecast
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       289852     55629/io.chromecast
              2024-01-28 14:45:28.717  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:45:28.717  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:45:33.719  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:45:33.720  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:45:38.722  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:45:38.722  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:45:43.725  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:45:43.725  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:45:48.727  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:45:48.728  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:45:52.046  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 started with pid 57841
              2024-01-28 14:45:52.870  - info: hm-rpc.1 (57841) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
              2024-01-28 14:45:52.964  - info: hm-rpc.1 (57841) binrpc server is trying to listen on 192.168.1.65:12001
              2024-01-28 14:45:52.965  - info: hm-rpc.1 (57841) binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:e3ec02aa81cfcc459d730c6f1f53df95"]
              2024-01-28 14:45:53.729  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:45:53.729  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:45:57.969  - error: hm-rpc.1 (57841) Init not possible, going to stop: response timeout
              2024-01-28 14:45:58.731  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:45:58.731  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:46:03.734  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:46:03.734  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:46:08.736  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:46:08.737  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              2024-01-28 14:46:13.739  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
              2024-01-28 14:46:13.739  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
              • R Radix75
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                              NTP service: active
                          RTC in local TZ: no
                Radix1975
                /home/Radix1975
                X-Server: 	false
                Terminal: 	wayland
                *** MEMORY ***
                Swap:           104M          0B        104M
                         8049 M total memory
                         2971 M used memory
                         2726 M free memory
                          301 M buffer memory
                         2214 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                *** FILESYSTEM ***
                /var:
                2.8G	/var/
                983M	/var/cache
                966M	/var/cache/apt
                942M	/var/lib
                USB-Devices by-id:
                /usr/bin/npm 		10.2.3
                /usr/bin/npx 		10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin: 		6.12.0
                javascript: 	7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects: 	8992
                States: 	7028
                Pending Updates: 0
                haselchenH Offline
                haselchenH Offline
                haselchen
                Das erschliesst sich mir nicht, warum.
                Und beim Rest, dass ist ne OP an einem Komapatienten.
                Ich würde Deine Kiste neu aufsetzen.
                Vorher Skripte , VIS ... sichern.
                Deine Node ist immer noch falsch, Deine Ports 8082 immer noch doppelt, wozu brauchst du 3 TR-064 Instanzen?
                HM-RPC1 vermutlich falsch konfiguriert ( aber Schuss ins Blaue , weil keine Infos bekannt)
                Wozu 2 Chromecast Instanzen?
                • haselchenH haselchen
                  2mal Admin enabled.
                  Auf mich hört ja keiner :)
                  Und vieles andere auch :(
                  web und jarvis auf dem gleichen Port 8082....
                  @haselchen sagte in Diverse kleine Adapter Fehler:
                  2mal Admin enabled.
                  und einen davon auf eine fixe IP gebunden
                  • R Radix75
                    code_text
                    ```hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    hm-rpc.1
                    was denn nu?
                    2001 oder 12001?
                    da scheint auch noch ein Eintrag zu fehlen.
                    ganz hinten steht "". da gehört bestimmt noch was rein
                      Nee, das Setup stimmt.
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        Mit den *** davor ist die installierte Version?
                        Ja, dann stimmt es.
                        Hatte nur oben das dfsg gesehen.
                        R 2 Antworten Letzte Antwort
                          Ja, dann stimmt es.
                          Radix75
                          @haselchen said in Diverse kleine Adapter Fehler:
                          Ja, dann stimmt es.
                          wie kann ich den javis Port ändern ?
                          wozu brauchst du 3 TR-064 Instanzen? Weil das einmal die Fritz box und zwei mal Fritz repeater sind.
                          Wozu 2 Chromecast Instanzen? Ich habe die sinnlose gelöscht da war gar nix eingestellt
                          Was denn nu?
                          2001 oder 12001?
                          Was davon ist richtig?
                          Das ist die Rot gelbe
                          Das sind die Grünen
                            wie du in deinem geposteten log siehst, kommt die Meldung vom hm-rpc.1
                            • R Radix75
                              Ja, dann stimmt es.
                              Was denn nu?
                              2001 oder 12001?
                              Das sind die Grünen
                              da sind ja überhaupt keine Instanzen den jeweiligen Diensten zugeordnet.
                              ich kann auf den 4k ultrawide cinemascope Screenshots fast nichts entziffern.
                              Hast du in beiden rpc Instanzen den gleichen Port auf der CCU adressiert?
                              lies mal hier
                              https://www.iobroker.net/#de/adapters/adapterref/iobroker.hm-rpc/README.md?homematicport
                              wo sind die jeweils zweiten Seiten?
                                lies mal hier
                                Radix75
                                @homoran said in Diverse kleine Adapter Fehler:
                                lies mal hier
                                hab den Fehler im https://www.iobroker.net/#de/adapters/adapterref/iobroker.hm-rpc/README.md?homematicport gefunden habe das falsche Protokoll eingestellt
                                Ich habe das geändert und jetzt ist der Adapter grün Danke für die Hilfe
                                • R Radix75
                                  lies mal hier
                                  dafür ist eine Doku da!
                                    Ja, dann stimmt es.
                                    Radix75
