  4. Passwort Problem im mqtt Adapter
21 Beiträge 7 Kommentatoren 2.9k Aufrufe 7 Beobachtet
  • F Felix18
    @felix18
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi5
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-2712
        Architecture: arm64
    Model		: Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     13:32:10 up 23:08,  3 users,  load average: 0.99, 0.93, 0.94
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2024-01-24 13:32:10 CET
               Universal time: Wed 2024-01-24 12:32:10 UTC
                     RTC time: Wed 2024-01-24 12:32:10
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop: 	LXDE-pi-wayfire
    Terminal: 	wayland
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            8.4G        6.3G        1.4G        1.4G        2.3G        2.2G
    Swap:           104M         98M        6.6M
    Total:          8.5G        6.4G        1.4G
             8049 M total memory
             5972 M used memory
             1255 M active memory
             3786 M inactive memory
             1309 M free memory
               67 M buffer memory
             2087 M swap cache
               99 M total swap
               93 M used swap
                6 M free swap
    Raspberry only:
    vc_gencmd_read_response returned -1
    error=1 error_msg="Command not registered"
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     805M  6.1M  799M   1% /run
    /dev/mmcblk0p2 ext4      116G  8.6G  101G   8% /
    tmpfs          tmpfs     4.0G   84M  3.9G   3% /dev/shm
    tmpfs          tmpfs     5.0M   64K  5.0M   2% /run/lock
    /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
    tmpfs          tmpfs     805M  144K  805M   1% /run/user/1000
    [Tue Jan 23 14:23:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BB:0D:24 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e2eee0c6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Tue Jan 23 14:23:20 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Jan 23 14:23:20 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    807M	/var/
    255M	/var/cache
    249M	/var/log
    248M	/var/log/journal/ebc8e9f468b04fc0a8c5561fdead68d6
    Archived and active journals take up 247.8M in the file system.
    /opt/iobroker/backups:
    67M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    705M	/opt/iobroker/iobroker-data/
    578M	/opt/iobroker/iobroker-data/files
    141M	/opt/iobroker/iobroker-data/files/vis-2
    103M	/opt/iobroker/iobroker-data/backup-objects
    89M	/opt/iobroker/iobroker-data/files/echarts.admin
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a4dc61b289d8ed11876c736162c613ac-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /usr/bin/npm 		10.2.3
    /usr/bin/npx 		10.2.3
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.13.15
    javascript: 	7.7.0
    Adapters from github: 	1
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi5                             -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
      system.adapter.birthdays.0              : birthdays             : raspberrypi5                             -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi5                             - disabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi5                             - disabled
    + system.adapter.denon.0                  : denon                 : raspberrypi5                             -  enabled
      system.adapter.device-reminder.0        : device-reminder       : raspberrypi5                             - disabled
      system.adapter.devices.0                : devices               : raspberrypi5                             - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi5                             - disabled
      system.adapter.echarts.0                : echarts               : raspberrypi5                             - disabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi5                             -  enabled
    + system.adapter.enocean.0                : enocean               : raspberrypi5                             -  enabled
    + system.adapter.ham.0                    : ham                   : raspberrypi5                             -  enabled
      system.adapter.heos.0                   : heos                  : raspberrypi5                             - disabled
      system.adapter.history.0                : history               : raspberrypi5                             - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi5                             - disabled, port: 0
      system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
    + system.adapter.info.0                   : info                  : raspberrypi5                             -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi5                             - disabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi5                             -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
      system.adapter.lgtv.0                   : lgtv                  : raspberrypi5                             - disabled
      system.adapter.mediola-gateway.0        : mediola-gateway       : raspberrypi5                             - disabled
      system.adapter.mihome-cloud.0           : mihome-cloud          : raspberrypi5                             - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : raspberrypi5                             - disabled
      system.adapter.parcel.0                 : parcel                : raspberrypi5                             - disabled
      system.adapter.ping.0                   : ping                  : raspberrypi5                             - disabled
      system.adapter.pushover.0               : pushover              : raspberrypi5                             - disabled
      system.adapter.sainlogic.0              : sainlogic             : raspberrypi5                             - disabled, port: 45000, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.2                 : shelly                : raspberrypi5                             -  enabled, port: 1881, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi5                             - disabled
      system.adapter.smartthings.0            : smartthings           : raspberrypi5                             - disabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi5                             -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             - disabled
      system.adapter.vis-2-widgets-sweethome3d.0: vis-2-widgets-sweethome3d: raspberrypi5                             -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi5                             - disabled
    + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi5                             -  enabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi5                             -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi5                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a4dc61b289d8ed11876c736162c613ac-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.13.15  , installed 6.13.15
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "awtrix-light" : 0.11.0   , installed 0.11.0
    Adapter    "backitup"     : 2.10.5   , installed 2.10.2 [Updatable]
    Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
    Adapter    "chromecast"   : 3.2.0    , installed 3.0.3  [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "contactid"    : 1.0.2    , installed 1.0.2
    Adapter    "denon"        : 1.15.5   , installed 1.15.5
    Adapter    "device-reminder": 3.1.2  , installed 3.1.1  [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "enocean"      : 0.9.3    , installed 0.9.3
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "heos"         : 2.2.1    , installed 2.2.1
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "ical"         : 1.14.0   , installed 1.14.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.7.0    , installed 7.7.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "lcn"          : 1.1.8    , installed 1.1.8
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "mediola-gateway": 1.1.0  , installed 1.0.1  [Updatable]
    Adapter    "mihome-cloud" : 0.1.1    , installed 0.1.1
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "net-tools"    : 1.0.4    , installed 0.2.0  [Updatable]
    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
    Adapter    "parcel"       : 0.2.7    , installed 0.2.7
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
    Adapter    "shelly"       : 6.7.0    , installed 6.7.0
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "trashschedule": 3.2.0    , installed 3.1.3  [Updatable]
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.22   , installed 2.9.18 [Updatable]
    Adapter    "vis-2-widgets-radar-trap": 1.0.7, installed 1.0.7
    Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
    Adapter    "vw-connect"   : 0.5.1    , installed 0.5.1
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.0 [Updatable]
    Objects and States
    Objects: 	6298
    States: 	4420
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 13
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18184      931/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19481      931/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          153202     9376/cupsd
    tcp        0      0 0.0.0.0:8200            0.0.0.0:*               LISTEN      112        16185      771/minidlnad
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14929      974/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       27777      3106/io.jarvis.0
    tcp        0      0 0.0.0.0:33643           0.0.0.0:*               LISTEN      1001       25059      2998/io.yahka.0
    tcp        0      0 127.0.0.1:45211         0.0.0.0:*               LISTEN      1001       139002     2998/io.yahka.0
    tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       24510      2849/io.shelly.2
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22434      2558/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27715      3054/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14931      974/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          153201     9376/cupsd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          153226     9379/cups-browsed
    udp        0      0 0.0.0.0:54145           0.0.0.0:*                           104        14804      765/avahi-daemon: r
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       297615     2029/chromium-brows
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24929      2725/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14802      765/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25654      2706/io.shelly.1
    udp        0      0 239.255.255.250:1900    0.0.0.0:*                           112        16184      771/minidlnad
    udp        0      0 192.168.2.167:43545     0.0.0.0:*                           112        178923     771/minidlnad
    udp6       0      0 fe80::fd88:586a:223:546 :::*                                0          18359      894/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        14803      765/avahi-daemon: r
    udp6       0      0 :::46803                :::*                                104        14805      765/avahi-daemon: r
    2024-01-24 13:31:30.132  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    2024-01-24 13:31:40.133  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
    2024-01-24 13:31:40.137  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
    2024-01-24 13:31:40.138  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    2024-01-24 13:31:50.139  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
    2024-01-24 13:31:50.143  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
    2024-01-24 13:31:50.143  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    2024-01-24 13:32:00.144  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
    2024-01-24 13:32:00.213  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
    2024-01-24 13:32:00.214  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    2024-01-24 13:32:10.215  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
    2024-01-24 13:32:10.240  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
    2024-01-24 13:32:10.241  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    2024-01-24 13:32:20.242  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
    2024-01-24 13:32:20.277  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
    2024-01-24 13:32:20.277  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    2024-01-24 13:32:30.278  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
    2024-01-24 13:32:30.284  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
    2024-01-24 13:32:30.285  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    2024-01-24 13:32:40.286  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
    2024-01-24 13:32:40.290  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
    2024-01-24 13:32:40.291  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    2024-01-24 13:32:50.292  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
    2024-01-24 13:32:50.299  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
    2024-01-24 13:32:50.300  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
    iob diag has finished.
    Press any key for a summary
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    @felix18 sagte in Passwort Problem im mqtt Adapter:
    Wenn ich das richtig sehe, ist der MQTT Adapter als Client konfiguriert und du versuchst dich zu einem Broker mit der IP 192.168.2.190 zu verbinden. Was ist das für ein Broker und heißt das, du hast das Passwort vom Broker vergessen?
    F 1 Antwort Letzte Antwort
    • Marc BergM Marc Berg
      Felix18
      @marc-berg
      Ich möchte ein ESP 8266 mit dem mqtt Adapter verbinden. Ich habe noch keinerlei Instanzen über den mqtt Adapter angelegt. Ich habe den iobroker erst seit 2 Monaten am laufen und habe anfangs eben ein bisschen ausprobiert, aber nie etwas mit dem mqtt Adapter eingebunden. Jetzt wollte ich mal versuchen ein ESP 8266 einzubinden, aber der Adapter speichert wohl "Alte" Passwörter ab auch wenn ich ihn lösche. Auch bei neu angelegten Instanzen. Nach dem speichern ist wieder ein 11 stelliges Passwort mit Sternen markiert, obwohl ich nur 6 Zeichen benutzt habe.
      Marc BergM 2 Antworten Letzte Antwort
      • F Felix18
        @marc-berg
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        Wenn du da einen ESP anschließen willst, muss der Adapter als Broker konfiguriert sein.
        EDIT: Unklarheiten mit der angezeigten PW-Länge
        • F Felix18
          @marc-berg
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          Habe das gerade ausprobiert, da stehen immer 11 Sternchen, unabhängig von der PW Länge.
          F 2 Antworten Letzte Antwort
            Felix18
            @marc-berg vielen dank Marc Berg, es lag an dem Broker. Es funktioniert!!!
            1000 DANK für deine hilfe!!!!!
            • F Felix18
              @felix18
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server: 	false
              Terminal: 	wayland
              *** MEMORY ***
              Swap:           104M         98M        6.6M
                       8049 M total memory
                       5972 M used memory
                       1309 M free memory
                         67 M buffer memory
                       2087 M swap cache
                         99 M total swap
                         93 M used swap
                          6 M free swap
              Raspberry only:
              *** FILESYSTEM ***
              /var:
              807M	/var/
              255M	/var/cache
              249M	/var/log
              USB-Devices by-id:
              /usr/bin/npm 		10.2.3
              /usr/bin/npx 		10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.13.15
              javascript: 	7.7.0
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	6298
              States: 	4420
              Pending Updates: 13
              Losgelöst vom Problem:
              Halt die Kiste auf Stand, sowohl das OS:
              Pending Updates: 13
              wie auch den ioBroker.
              Und schalt den Desktop aus. Hat auf einem Server nix verloren.
                Felix18
                @marc-berg das hat mich immer irritiert mit dem Passwort.
                  Pending Updates: 13
                  Felix18
                  @thomas-braun ja werde ich demnächst machen. Muss ich da irgendwas vom raspi speichern? Oder kann ich den komplett löschen und neues Betriebssytem ohne Desktop installieren?
                  • F Felix18
                    Das wäre die radikale Lösung. Du kannst ihn im ersten Step aber auch nur ausschalten:
                    sudo systemctl set-default multi-user.target
                    Updates per
                    sudo apt update
                    sudo apt full-upgrade
                    sudo reboot
                      Updates per
                      sudo apt update
                      sudo reboot
                      Felix18
                      @thomas-braun bring das denn viel an freien speicher? Oder warum meinst du soll ich den Desktop runter schmeißen?
                      Müsste ich denn was speichern, wenn ich ein neues Betriebssystem auf dem raspberry installiere?
                      Thomas BraunT darkbluD 2 Antworten Letzte Antwort
                      • F Felix18
                        Weil ein Desktop viel zu viel Overhead anschleppt.
                        Was nicht läuft kann nicht kaputt gehen, muss nicht gepflegt werden, kann
                        keine Sicherheitslücken haben und verbraucht auch keine Systemressourcen.
                        Ein Backup des ioBrokers via Backitup-Adapter reicht eigentlich aus. Andere Dienste, die parallel laufen musst du dann über deren Prozesse backuppen.
                        • F Felix18
                          darkbluD Offline
                          darkbluD Offline
                          darkblu
                          @felix18 ,
                          bevor du neu installierst, mach doch erstmal ein „Probe Backup“,
                          erstellen und wieder herstellen.
                          Sicher ist sicher.
                          Raspi 4, 4GB für Influxdb 1.8 und Grafana
                          Raspi 5, 8 GB für ioBroker
                          Threadnetzwerk per Apple
                          • F Offline
                            Felix18
                            @darkblu alles klar, vielen vielen Dank Leute. Ja habe den back it up Adapter auch am laufen, und konnte den schon einmal benutzen und es hat funktioniert als meine Skripte auf einmal alle weg waren.
                            • mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              Wenn ich das diag richtig interpretiere verwendest du ein sd Karte für deinen Raspi.
                              In dem Fall kannst du jedenfalls die Neuinstalaltion auf anderen Karte machen. Damit kannst du zu 100% sicher sein, dass du jederzeit zurück kannst wenn was bei Backup / Restore nicht funktioniert. Einfach auf neuer Karte installieren.
                              Und mittelfristig überleg ob nicht eine ssd sinnvoll wäre. (Ich weiß, die ssd HATs sind noch rar ...)
                              Support Repositoryverwaltung.
                              LESEN - gute Forenbeitrage
